[Geoprisma-dev] CSV Export and multiline text
Alexandre Dube adube at mapgears.com
Fri Apr 20 08:36:11 EDT 2012
Hi Belug,
  +1
   I agree with the workaround your proposed : an option (Defaults to
false) that, when turned on, converts now lines in to spaced double
slashes.  That'd do the trick until someone ends up finding a solution
to the initial issue.
Regards,
Alexandre
On 12-04-19 11:56 AM, Lessard Alexandre wrote:
> Hi you all,
> I have a problem with the WFS_Fillter_Builder and it's about the CSV
> export.
> I already made a ticket about it, but now I'd like your help for the
> solution.
> ticket : http://trac.osgeo.org/geoprisma/ticket/383
> The problem is multilined text in CSV when you import data into Excel.
> When you "import"
> id from the file the newline caracter will cause a newline in the
> worksheet breaking the order
> of the columns.
> The encoding does not change anything about that it's a bug that I
> wasn't able to pass.
> It doesn't append when you "open" the CSV file with Excel, but it
> might break dates and some
> strings or numbers.
> So for this I'd like to propose an option to convert new line into
> something else
> (i.e. Converting new lines into spaced double slashes " // ").
> So if you set the option in the widget it would replace the newlines
> by what you write there.
> What do you think about that?
> Belug
> P.S. I've joined a sample Try opening it and then try importing it.
> Geoprisma-dev mailing list
> Geoprisma-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geoprisma-dev
Alexandre Dubé
Mapgears
www.mapgears.com
URL: http://lists.osgeo.org/pipermail/geoprisma-dev/attachments/20120420/e20f8002/attachment.html
More information about the Geoprisma-dev mailing list
