[Geoprisma-users] initial position solved (was: New Widgets
Ideas)
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Dec 4 10:46:38 EST 2009
>>> 1) initialView widget that x,y,zoom and positions the map to that
>>> location and zoom on initial load. You should also be able to pass
>>> the x,y,zoom on the url.
>> You could do that directly in your template.xslt file. Replace the
>> oMap.zoomToMaxExtent() for your initial load.
> Yeah, I found this and tried it. The zoom part works, but the
> positioning seems to be off. I you load
> http://imaptools.com:8080/project/myproj/
> that should zoom to the center of the map objects. Zoom out three steps
> and you will see the features.double click on them to recenter and then
> zoom in.
> I'm not sure if this is a bug or the fact that the template is not
> installing the widgets correctly.
Solved! this was a typo in the initial coordinates <seesh> That is what
I get for working so late at night on this stuff.
-Steve
More information about the Geoprisma-users
