[Geoprisma-users] Some of the samples are broken
Yves Moisan
yves.moisan at boreal-is.com
Fri Dec 18 09:33:54 EST 2009
> http://geoprisma.org/samples/sample1/auth_xml/index.php?logout=true
> http://geoprisma.org/samples/sample0/select_username.php
> all logins respond with "Droit insuffisant"
Hi Stephen,
The acl.xml file was corrupted by someone probably deleting a resource
using http://geoprisma.org/samples/acl2/index.php?lang=en_US. I just
learned about the coupling between the two samples. We should point
that sample to a database rather than the xml file sample0 depends on
(http://trac.osgeo.org/geoprisma/ticket/46). I reverted the xml file
and now it works.
Thanks for reporting,
Yves
More information about the Geoprisma-users
