[Geoprisma-users] Re: [Geoprisma-dev] Trac
Alexandre Dube
adube at mapgears.com
Mon Nov 9 08:58:45 EST 2009
Yves Moisan wrote:
>> Thanks a lot for the efforts.
>> Should we have more detailed components, like OpenLayers - MapServer -
>> GeoExt - etc do ? Like :
>> Widget
>> Widget - QuickZoom
>> Widget - MapFishRecenter
>> Widget - Merge
>> etc.
>> Alexandre
> Hi Alexandre,
> I was going to answer you I thought we had enough components for now,
> but I checked the GeoExt Trac and they have quite a few. I'm not sure
> we need a detailed set of components at this point. Or maybe you'd like
> to sort active tickets per component type ? Trac provides default
> filters for version and milestone. Do we need to filter by component ?
> Cheers,
> Yves
I get your point. It could be interesting to do so, but not mandatory.
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-users
