[Geoprisma-users] Got GeoPrisma installed - Now what?
Alexandre Dube adube at mapgears.com
Fri Nov 13 07:53:36 EST 2009
Hi Stephen,
  Welcome to the community !
Stephen Woodbridge wrote:
> Hi all,
> First, (well second, really because I already posted a problem :) any
> I want to say that GeoPrisma looks very cool and I'm excited about
> getting it to work with my maps.
> I'm reading through the documentation but I missing the overview or
> tutorial that is not written yet. So I'm looking through the samples
> and will try to crib pieces from them.
I'm currently working on that, see :
http://trac.osgeo.org/geoprisma/ticket/19
> My goal is to have a simple login page using XML or postgres and have
> a map with a few layers some of which can be edited. I would like to
> use tinyOWS instead of FeatureServer. and my maps will all be via
> mapserver.
WFS is not yet implemented in GeoPrisma, so for now you should go with
FeatureServer.  WFS should be an important add-on to have.
> I assume I need to set up a directory similar to one of the sample
> directories for my project.
Exactly.  Just choose one that looks like what your trying to do and
copy all its files in your project directory.  That's a good start.
> I need to create acl.xml or equivalent postgres.
You should finish with that.  Start by using the "noacl" driver in your
"common.php" file ( the "core" config file ).
> And create a config.xml.
And start with that.
> Do you guys have any admin pages the present forms for creating some
> of the XML?
We have some for the ACL (see acl2 in samples), but not the config.xml
file yet.
> What do you guys use for editing and creating all the xml files. it
> seems a little tedious to do this in notepad or vi.
As a linux fan, I use Emacs even if it doesn't really help editing xml
files.  Copy/paste from existing xml config is my common behavior.
I'll let you know about the upcoming documentation change.
Regards,
Alexandre
> Thanks,
>   -Steve
> Geoprisma-users mailing list
> Geoprisma-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geoprisma-users
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-users mailing list
