[Geoprisma-users] New to GeoPrisma - Samples don't work
Yves Moisan
yves.moisan at boreal-is.com
Fri Nov 13 09:15:27 EST 2009
> Hi all,
> I have downloaded geoprisma-r699 and the release demo works but I get
> errors with the other samples:
> http://imaptools.com:8080/gp/samples/acl/index.php
> Warning: require_once(com/borealis/Autoload.php)
> [function.require-once]: failed to open stream: No such file or
> directory in /var/www/geoprisma-r699/samples/acl/roles.php on line 14
> Fatal error: require_once() [function.require]: Failed opening required
> 'com/borealis/Autoload.php'
> (include_path='.;/var/www/geoprisma-r699/samples/acl/../../lib/borealis-foundation-0.1.0.0;/var/www/geoprisma-r699/samples/acl/../../lib/borealis-acl-0.1.0.0;/var/www/geoprisma-r699/samples/acl/../../lib/Smarty-2.6.22/libs')
> woodbri at mappy:/u/www/html/gp$ find . -name Autoload.php
> ./lib/php-borealis-foundation-0.3.1.28/com/borealis/Autoload.php
> I probably have to look for where the path gets set and maybe update
> that assuming that the versions may or may not be compatible.
Hi Stephen,
Welcome ! I tried the url here
http://localhost:8080/geoprisma-r699/samples/acl/roles.php and things
don't work indeed, even with the right names of the libraries (indeed it
should look for php-borealis-foundation-0.3.1.28 and not
borealis-foundation-0.1.0.0). Will report back later.
Thanx for reporting the issue.
Yves
> -Steve W
> Geoprisma-users mailing list
> Geoprisma-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geoprisma-users
More information about the Geoprisma-users
