[Geoprisma-users] More Sample Problems - using r702
Yves Moisan
yves.moisan at boreal-is.com
Sun Nov 15 08:59:19 EST 2009
Hi Stephen,
There is a path issue for some of the samples. We'll correct those
tomorrow.
Thanx for your patience,
Yves
> Alexandre Dube wrote:
> > I can confirm that problem as well locally.
> > Stephen, could you confirm that you don't have this kind of behavior
> > with trunk ?
> OK, things look much better with trunk.
> Only this one fails because it looks like apache does not have write
> perms to my home dir where the svn is linked from:
> http://imaptools.com:8080/gp2/samples/sandbox1/default/index.php
> So I think trunk is looking good.
> -Steve
> > Alexandre
> > Stephen Woodbridge wrote:
> >> Hi guys,
> >> I'm have gone through all the samples and the follow fail to load:
> >> http://imaptools.com:8080/gp/samples/borealis-authentication/
> >> http://imaptools.com:8080/gp/samples/helloworld/
> >> http://imaptools.com:8080/gp/samples/mapfishlayertree/
> >> failed to load external entity
> >> "/var/www/geoprisma-r702/src/client/templates/inc/Globals.xslt"
> >> and a lot more errors.
> >> http://imaptools.com:8080/gp/samples/merge_split/
> >> http://imaptools.com:8080/gp/samples/navtools/
> >> http://imaptools.com:8080/gp/samples/queryonclick/myownmarker/
> >> http://imaptools.com:8080/gp/samples/queryonclick/simple/
> >> http://imaptools.com:8080/gp/samples/quickzoom/
> >> http://imaptools.com:8080/gp/samples/sample0/
> >> loads with only "Droit insuffisant" message
> >> http://imaptools.com:8080/gp/samples/sample1/default/
> >> loads with Google apikey error, but does not show a google layer
> >> option.
> >> http://imaptools.com:8080/gp/samples/sample1/auth_xml/
> >> loads with Google apikey error, and then displays "Droit
> >> http://imaptools.com:8080/gp/samples/sandbox1/default/index.php
> >> http://imaptools.com:8080/gp/samples/shortcut/activateresources/
> >> http://imaptools.com:8080/gp/samples/shortcut/inpanel/
> >> http://imaptools.com:8080/gp/samples/shortcut/intoolbar/
> >> So it looks like there are probably three separate errors effecting
> >> the bulk of these:
> >> 1) is the Autoload.php path problem
> >> 2) is an xslt path problem
> >> 3) issues is the google apikey issue which seems to be cached
> >> somewhere or defined also in some other place that config/*.xml
> >> So it looks like these run:
> >> http://imaptools.com:8080/gp/samples/acl2/
> >> http://imaptools.com:8080/gp/samples/bdga/
> >> http://imaptools.com:8080/gp/samples/complex_workspace/
> >> http://imaptools.com:8080/gp/samples/google/ (with apikey issue)
> >> http://imaptools.com:8080/gp/samples/onegeology/default/ (with
> >> apikey issue)
> >> http://imaptools.com:8080/gp/samples/release/
> >> http://imaptools.com:8080/gp/samples/sampleLink/ ( but links might
> >> have issues)
> >> http://imaptools.com:8080/gp/samples/sampleObservable/
> >> http://imaptools.com:8080/gp/samples/workspace/
> >> Nothing critical from my point of view, but thought I could help with
> >> the little extrat testing.
> >> -Steve
> >> _______________________________________________
> >> Geoprisma-users mailing list
> >> Geoprisma-users at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/geoprisma-users
More information about the Geoprisma-users
