[Geoprisma-users] FeatureServer, OL, GP ack!
Alexandre Dube
adube at mapgears.com
Fri Nov 20 15:38:16 EST 2009
Stephen,
== about the roadmap ==
Currently, we don't have one. As you know, GeoPrisma is an OpenSource
project, so we're driven by the customers needs. Currently, GeoPrisma
fills all the needs of the customers it was developed for, so there's no
real "plan" for the near future. If a new project emerges, with new
needs and fundings, then the project goes toward that way.
When that happens, we (in that case the contributors [1]) usually
gather together in a codesprint.
== about the "upload your gis files" topic ==
It has been discussed a while ago because some customer showed some
interests in GeoPrisma and wanted to know if it would be possible to do
so. "It's currently not available, but it could be possible with some
developments." we (Mapgears) answered. Since you showed the same kind
of need, I thought "hey, we could go the same way" and introduced
GeoPrisma to you.
== about the doc ==
I'm currently working on the doc. It changed a lot this week, so keep
in touch :) I'll add a new topic next week : "how to create a new
widget in GeoPrisma".
Thanks a lot for sharing your ideas and thoughts.
Kind regards,
Alexandre
[1] http://geoprisma.org --> see contributors
Stephen Woodbridge wrote:
> Alexandre,
> Thanks for your quick response. I realize much (most :) of what I'm
> asking is not there. It helps me to write out my thoughts, rather than
> just think them, hence my often rambling emails.
> The MapFish stuff that I have seen looks very good, but licensing
> prevents me from using it. :( Hmmm, I wonder if it would be possible
> to add GeoJson support to tinyOWS as an option.
> Yes, I saw the bdga demo in GP, I'm going to use that as my model to
> build my app on.
> A lot of the ideas below are just trying to think through the problem
> of building a web based GIS system. I'm trying to hold a big picture
> in my head while I deal with all the details of creating WMS mapfiles,
> loading shapefiles into postGIS, trying to figure out how to connect
> FS to all of this, etc .... you know it is just a lot of new to me
> pieces I'm trying to understand.
> Do you have a roadmap of what your next steps are with respect to GP
> development.
> I understand just getting the project website, documentation and all
> is a big step all by itself.
> Thanks again for you comments and support.
> -Steve
> Alexandre Dube wrote:
>> Hey,
>> My quick thoughts on the subject (look inline)
>>> So you said tinyOWS was not supported in GP yet.
>>> So I installed FS and started reading your past threads on
>>> implementing FS with OL, then looked at
>>> http://dev4.mapgears.com/bdga-fs/
>>> Now my head is ready to explode :) And this was easier then adding
>>> support of tinyOWS?
>>> ok I know that is rhetorical, but I'm just saying ...
>> Maybe not "easier", but GeoJSON had its advantages over GML (XML).
>> It's much lighter. That's why we decided to go with FS instead of WFS.
>>> Anyway, this may be a little OT, but my GP use case is a web based
>>> GIS systems or something close to that. And I have all data layers
>>> loaded in postGIS, I can create a Mapserver mapfile to display
>>> these, I already have one displaying them from the shapefiles. And
>>> I'm trying to figure out how to integrate FS and how this fits into
>>> the bigger design.
>>> In OL, I will likely have Mapserver (WMS? or not) base layer, and
>>> Google base layer. Then I need to be able to select one of the
>>> layers to be editable (I'm assuming only one can be editable at a
>>> time) and it will then get overdrawn via FS so edits can take place.
>>> I'm not sure the best way to select the layer for editing. It
>>> probably means hacking OL.layerswitcher so that the layers are in a
>>> radio button field that also selects the layer as editable and only
>>> one can be on at a time. This probably means the select control
>>> needs to be notified maybe it is listening for a layer switch change
>>> event.
>>> Seems like the draw/edit tools needs to be selected based on the
>>> layer type polygon, line, point.
>> Did you look at this example [1] ?
>> [1] http://geoprisma.org/samples/bdga/index.php?id=302&locale=fr_CA
>>> So I guess I need to pick apart the bdga-fs demo. And ideas on how
>>> to find out what the layer type is?
>>> And finally (or not) GP needs to be wrapped around all of this.
>>> I think someone mentioned that a future enhancement was to be able
>>> to upload a shapefile and install it under GP.
>> We're not at the state of 'development' for this enhancement yet. So
>> far, we barely discussed the topic.
>>> I assume that would get loaded into postGIS, then a mapfile
>>> generated, FS cfg fragment would be generated and added to
>>> featureserver.cfg or something along these lines. Where does this
>>> stand in your plans?
>> That would be nice. We could try to use MapFish-Studio to do so, I
>> don't know... (yet)... sorry.
>>> I'm assuming this is all initiated from an OL application so when
>>> the server is ready with the new data, it response to OL and the
>>> code there will dynamically add a new OL layer to the map and
>>> refresh the page. Also any GP config files also need to be updated.
>>> Since a lot of stuff needs to get changed, I might make sense that
>>> the yours needs to reload the browser page before the changes are
>>> visible instead of trying to dynamically update the page.
>> The dynamism of the UI without reloading the page is also in a
>> "discuss" phase. There's currently no short-period development for
>> that, yet. Contributions / ideas are welcomed :)
>>> Thoughts, examples, help appreciated.
>>> -Steve
>>> Geoprisma-users mailing list
>>> Geoprisma-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geoprisma-users
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-users
