[Geoprisma-users] Back to GP again
Alexandre Dube
adube at mapgears.com
Wed Nov 25 17:16:24 EST 2009
Stephen Woodbridge wrote:
> Alexandre,
> The new doc is a great improvement!
> Here are some random comments:
> 1) Looking at the Widget list
> http://geoprisma.org/dist/naturaldoc/files2/featurepanel/form/Form-txt.html
> I think it would be very helpful to standardize Widget names a little
> bit with the client project. This is already done for some of the
> MapFish widgets:
> FeaturePanel_Form => ExtFeaturePanel_Form
> FeaturePanel_Selector => ExtFeaturePanel_Selector
> GeoExtToolbar => GeoExtNavToolbar
> GetMousePosition => GPGetMousePosition
> MapFishLayerTree => MapFishLayerTree
> MapFishRecenter => MapFishRecenter
> Merge => PGMerge
> MeasureTool => GPMeasureTool
> MousePosition => OLMousePosition
> PopUp => OLPopUp
> QueryOnClick => GeoExtQueryOnClick
> QuickZoom => Use Shortcut Widget **No Docs*
> ResultExtGrid => ExtResultGrid
> Scale => OLScale
> Split => PGSplit
> Toolbar => MapFishNavToolbar
> EditFeature_Create => GeoExtEditFeature_Create
> EditFeature_Delete => GeoExtEditFeature_Delete
> EditFeature_Update => GeoExtEditFeature_Update
> Why bother you might ask? :)
> Maybe this is not the way to do it, but you already started with this
> naming conventions and I think is has some value in making sensible
> widget choices. For example if I don't want to add in all the MapFish
> stuff then I can avoid using those widgets. I assume that over time
> and growth of the wisget library this will become more and more
> useful. Obviously there are other ways to do this and if you use the
> EditFeature tools then you are already commited to using the MapFish
> protocol which I assume means using some of there JS files?
I agree that some "sorting" / "cleaning" work could be done. It's kind
of a mess right now :)
> 2) Reading through the tutorial and trying to implement a project.
> http://geoprisma.org/dist/build/html/tutorials/create-your-own-geoprisma-project.html#services-datastores-and-resources-list
> section 1. 2nd bullet needs a link to the list of widgets which got me
> side tracked to the above comment.
> In this section, you talk about making a list. It would be helpful to
> show and example list and to comment that it will be used below in
> another step (I haven't gotten to that step yet).
Right. I'll take a note about that.
> In general, the current doc is a little bit abstract,
Yeah, I know...
> and would benefit from being a little more concrete. I would suggest
> defining a specific example for the Tutorial and referring to that
> example to explain each step, like:
> 1) a city wants to setup a GP service and has the following resouces:
> citylimits - polygon shapefile
> lakes - polygon shapefile with object names
> parcels - polygon shapefile with lots of attribute
> streets - line shapefile with moderate number of attributes
> The example data can be downloaded from HERE(link).
> The citylimits layer is a reference only layer
> The lakes layer is also a reference only layer
> The parcels layer is managed by the city tax department which needs to
> make sure it is updated as things change, but the public needs to be
> able to view it.
> The streets layer is managed by the highway department which needs to
> mantain it, and add new streets as new subdivision are created. The
> public needs to view this as a reference layer also.
> 2) we have loaded all these layers into postgis database
> 3) we have configured mapserver to serve WMS maps from the database
> - show a sample mapfile for the above
> 4) we have featureserver installed
> - show a sample config file for the above
I wouldn't go that far for the current tutorial. It could be a nice 2nd
tutorial *for dummies* What do you think ?
> Now based on this, show the services, DataStores and Resource Lists
> and follow through with this example in the tutorial. This way when
> the user is finished with the tutorial they will have a working
> example. Also making it concrete like this will make it much easier to
> write up the docs because you will have an example to show what you
> are talking about.
> Still wading through the tutorial. It is a really good start and I'll
> probably add to this as I progress through it.
That would be much appreciated :)
> Thanks for the amazing amount of additional work you have done on the
> docs.
Thanks a lot for the nice comments.
Alexandre
> -Steve
> Geoprisma-users mailing list
> Geoprisma-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geoprisma-users
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-users
