[Geoprisma-users] Tutorial Problems
Alexandre Dube
adube at mapgears.com
Thu Nov 26 08:42:13 EST 2009
Stephen Woodbridge wrote:
>> 5. sample.xml –> config
> Also I think you have a typo on number 5. it should be:
> 5. config.xml -> config
It could be anything.xml. I'll make the correction.
> Warning: require_once(com/borealis/Autoload.php)
> [function.require-once]: failed to open stream: No such file or
> directory in /u/geoprisma/projects/myproj/config/common.php on line 15
Check your $strGeoprismaRoot. Use a direct path if needed, like :
"/u/geoprisma"; Tell me if that works for you.
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-users
