[Geoprisma-users] Tutorial Problems
Stephen Woodbridge woodbri at swoodbridge.com
Sun Nov 29 21:57:57 EST 2009
Stephen Woodbridge wrote:
>>>> 5. sample.xml –> config
>>> Also I think you have a typo on number 5. it should be:
>>> 5. config.xml -> config
>> It could be anything.xml.  I'll make the correction.
>>> Warning: require_once(com/borealis/Autoload.php)
>>> [function.require-once]: failed to open stream: No such file or
>>> directory in /u/geoprisma/projects/myproj/config/common.php on line 15
>> Check your $strGeoprismaRoot.  Use a direct path if needed, like :
>> "/u/geoprisma";  Tell me if that works for you.
> I finally have time to report that I got bdga sample to work from its
> own directory, but I'm not sure if it is using the bdga-config.xml or my
> copy of that. Below is my directory layout and the diff of the files I
> had to change (assuming I'm remembering everything. So next I plan to
> start swapping in my WMS layers and comment out the other stuff.
> -Steve
> woodbri at mappy:/u/geoprisma/projects$ ls
> lib/  myproj/
> woodbri at mappy:/u/geoprisma/projects/myproj$ ls -R
> config/  config.php  htdocs/
> ./config:
> common.php  config.xml
> ./htdocs:
> css/  img/  index.php  js/  proxy.php  xslt/
> ./htdocs/css:
> ./htdocs/img:
> ./htdocs/js:
> ./htdocs/xslt:
> woodbri at mappy:/u/geoprisma/projects/myproj$ diff -w ./htdocs/index.php
> /var/www/geoprisma-r728/samples/bdga/index.php
> 5c5
> < require_once '../config/common.php';
>  > require_once 'common.php';
> woodbri at mappy:/u/geoprisma/projects/myproj$ diff -w ./htdocs/proxy.php
> /var/www/geoprisma-r728/samples/bdga/proxy.php
> 3c3
> woodbri at mappy:/u/geoprisma/projects/myproj$ diff config/config.xml
> /var/www/geoprisma-r728/config/config-bdga.xml
> woodbri at mappy:/u/geoprisma/projects/myproj$ diff -w config.php
> /var/www/geoprisma-r728/samples/config.php
> 4d3
> < #echo "g_strCurrentDir=$g_strCurrentDir<br>\n";
> 6,7d4
> < #echo "g_strUrlPrefix=$g_strUrlPrefix<br>\n";
> < $g_strUrlPrefix  = '';
> 10d6
> < #echo "g_strGeoprisma=$g_strGeoprisma<br>\n";
> 21,22c17
> < $g_strConfigDir                 = "$g_strCurrentDir/config";
> < #echo "g_strConfigDir=$g_strConfigDir<br>\n";
>  > $g_strConfigDir                 = "$g_strCurrentDir/../config";
> 25d19
> < #echo "g_strLibUrl=$g_strLibUrl<br>\n";
Alexandre,
Now that I have time to dig into this in some more detail. I think that
I probably need to make more changes to my config.php.
Currently in my myproj/config/config.xml that is a copy of
geoprisma-r728/config/config-bdga.xml it references "bdga/bdga.xslt" and
the config.php $g_strTemplateDir = "$g_strGeoprisma/src/clinet/templates"
Should the TemplateDir and TemplateUrl be changed to point to
.../myproj/htdocs/xslt/
as implied by the tutorial? and then copy the bdga/bdga.xslt into
htdocs/xslt/ and update the xml to reference that.
-Steve
More information about the Geoprisma-users mailing list
