[Geoprisma-users] InitialView troubles
Philippe Gregoire philippe.gregoire at boreal-is.com
Mon Aug 15 02:59:01 EDT 2011
Hi list,
I am encoutering some problems with the InitialView
widget. I want to show multiple polygons that have the same te_tenure_id
 value. I have this configuration in my  xml configuration file:
        <initialview>
            <name>InitialViewTenures</name>
            <options>
                <urlfield>te_tenure_id</urlfield>
                <queryfield>te_tenure_id</queryfield>
  <defaultzoom>7</defaultzoom>
                <highlight>true</highlight>
            </options>
        </initialview>
When I call GeoPrisma with the option "&te_tenure_id=1564", the URL request sent to featureserver looks like this:
/featureserver/featureserver.cgi/tenures?random=0.8489123610585759&queryable=te_tenure_id&te_tenure_id=1564
But this request produces an error in FeatureServer:
An error occurred: 'NoneType' object has no attribute 'has_key'
  File "D:\Borealis\pact\System\GeoPrisma\ms4w\Apache\htdocs\featureserver\web_request\handlers.py", line 219, in cgi
    accepts = accepts )
  File "D:\Borealis\pact\System\GeoPrisma\ms4w\Apache\htdocs\featureserver\FeatureServer\Server.py", line 167, in dispatchRequest
    result = method(action)
  File "D:\Borealis\pact\System\GeoPrisma\ms4w\Apache\htdocs\featureserver\FeatureServer\DataSource\PostGIS.py", line 157, in select
    filters = self.feature_predicates(match)
  File "D:\Borealis\pact\System\GeoPrisma\ms4w\Apache\htdocs\featureserver\FeatureServer\DataSource\PostGIS.py", line 92, in feature_predicates
    if feature.geometry.has_key("coordinates"):However, if I remove the "queryable=te_tenure_id" option from the URL, FS responds correctly.
So,
 is there an easy solution to my problem? I would need whether a way to
remove the "queryable=te_tenure_id" option from the URL request sent by
GP to FS, or I would need to make sure that my request returns the right
 thing even with this option.
Here is my FS config if that helps:
[tenures]
type=PostGIS
dsn=host=127.0.0.1 port=6433 dbname=pact_dev_data user=gpuser password=GP_RULES
layer=te_vg_tenure_featureserver
fid=unique_id
geometry=the_geom_900913_single
srid=900913
encoding=iso-8859-1
attribute_cols=te_tenure_id
gaping_security_hole=yes
I am using GeoPrisma r1034
Thanks!
Philippe
URL: http://lists.osgeo.org/pipermail/geoprisma-users/attachments/20110814/b488f133/attachment.html
More information about the Geoprisma-users mailing list
