[Geoprisma-users] GeoPrisma 1.0.0 release
Alexandre Dube
adube at mapgears.com
Thu Dec 1 16:13:21 EST 2011
The GeoPrisma Team is pleased to announce the first official release of
GeoPrisma : 1.0.0.
The 1.0 release includes :
- several widgets which are listed below.
- a list of supported browsers
- a list of softwares commonly used as services in GeoPrisma
The source for this release can be downloaded using SVN at :
https://svn.osgeo.org/geoprisma/projects/geoprisma/tags/rel-1-0-0/
The 1.0 branch was also created and is available at :
https://svn.osgeo.org/geoprisma/projects/geoprisma/branches/branch-1-0/
Please help out by testing your applications with this new code base.
Thanks! - The GeoPrisma Team
Version 1.0.0 (2011-12-01)
Since it's the first release, there are were no documentation per change
made.
Instead, here's an overview of what it features :
Supported Browsers
GeoPrisma has been tested and fully supports the following browsers :
- Internet Explorer 7 and 8
- Firefox 3.6+
Other browsers were not tested so can't be qualified as fully supported.
Supported JavaScript Libraries
The following libraries (version) are packaged with GeoPrisma 1.0 :
- OpenLayers (2.11)
- Proj4js (1.0.1)
- MapFish (trunk, revision 3862)
- GeoExt (trunk, revision 2865)
- GeoExt-ux (trunk, revision 2865)
- GeoExt-ux-AttributeFilterPanel (trunk, revision 2865)
- GeoExt-ux-FeatureEditing (trunk, revision 2865)
- GeoExt-ux-LayerManager (trunk, revision 2865)
- GeoExt-ux-LayerTreeBuilder (trunk, revision 2865)
- GeoExt-ux-ShortcutCombo (trunk, revision 2865)
- GeoExt-ux-Styler (trunk, revision 2865)
- GeoExt-ux-WFSTFeatureEditing (trunk, revision 2865)
- GeoExt-ux-ZoomTo (trunk, revision 2865)
The following libraries (version) were tested with GeoPrisma 1.0 :
- ExtJS (3.3.0, 3.3.1)
Softwares
The following softwares are used with this release of GeoPrisma as its
services :
- MapServer (5.6.6+, 6.0.0+), for WMS and WFS services
- TileCache (2.10+)
- FeatureServer (1.12+)
- MapFish Print (1.2+)
Tile providers
The following tile providers are supported by this release of GeoPrisma as
"gymo" services :
- GoogleMaps (2+), (3+ is untested)
- YahooMaps (3.0+)
- OpenStreetMaps
Stable Widgets
- featurepanel_selector
- geoextprintform
- geoexttoolbar
- geoextux_layertreebuilder
- geoextux_redliningpanel
- geoextux_shortcutcombo
- geoextux_zoomto
- getmouseposition
- htwindow
- initialview
- layer
- mappanel
- mouseposition
- querybyrect
- queryonclick
- queryonclickwizard
- resultextgrid
- resultvectorlayer
- scale
- shortcut
- toggle
- unselectall
- vectorlayer
- zoomslider
Unstable Widgets
- attributefilterpanel
- editfeature_confirm
- editfeature_copy
- editfeature_create
- editfeature_delete
- editfeature_drag
- editfeature_update
- editfeature_split
- filetreepanel
- featurepanel_customform
- featurepanel_attributeform
- featurepanel_form
- geoextux_printpreview
- geoextux_wmsbrowser
- geoextux_geonamessearchcombo
- keepactivesession
- measuretool
- pdfprint
- templatepopup
- wfsfilterbuilder
- wmslayeradder
Deprecated Widgets
- map
- mapfishlayertree
- mapfishrecenter
Removed Widgets
- delegatefeature
- legendpanel
- merge
- popup
- quickzoom
- split
- toolbar
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-users
