[Geoprisma-users] GeoPrisma and existing application
Gabriel Vatin
gabriel.vatin at mines-paristech.fr
Wed Jan 25 11:53:57 EST 2012
Thank you Alexandre. I think I will try your 2nd option, knowing that
most of my tools have their specific JavaScript file.
Gabriel
On 16/01/2012 15:23, Alexandre Dube wrote:
> Hi Gabriel,
> There is currently no easy way to accomplish that in GeoPrisma. It
> would be possible with some modifications to the server 'core'.
> Here's some ideas :
> === Use proxy only ===
> In GeoPrisma, there are 2 main parts : the proxy (server) and the
> templating system (auto-builds the client app). In your case, you
> could only pick the server part. You would only need to setup the php
> files and config and instead of using the UI auto-generation (see an
> index.php in any sample), you would only setup a proxy.php.
> In your client application, change the hosts of your layers to point
> to proxy.php and by adding "osmservice" and "osmresource" parameters.
> Using firebug, look at any layer generated url to see an example of a
> call using the proxy.
> Then, the only thing remaining would be to add/remove tools
> depending on the user rights. You could create a small php file that
> would read the config and acl, browse them and return a JSON
> representing the rights of the currently logged user. You'd need to
> look at the core php files to see how they work. You would then use
> that JSON in your app to add/remove wanted/unwanted tools.
> === Create a new "box" widget ===
> This idea would focus more in using both parts : proxy and
> templating system.
> There is currently no widget in GeoPrisma that has the purpose of
> loading complete external files and treat them as widgets. It could
> be a good idea to create one that would do the following :
> * manually list the resources needing it
> * in xslt, it would check if the resource is existant in the config
> (has the ACL rights) and execute the included code for it
> * each resource+widget could have a unique js file to include
> * it could also be unbound, i.e. could simply load source not related
> to resource (like a widget adding some static feature in the app)
> In my opinion, this would be a simpler idea than the first one.
> Anybody else have other ideas ?
> Kind regards,
> Alexandre
More information about the Geoprisma-users
