[Geoprisma-users] OverviewMap widget configuration
Alexandre Dubé adube at mapgears.com
Wed Nov 21 07:46:08 PST 2012
Philippe,
   You can define any OpenLayers.Control.OverviewMap APIProperty as an
option with this widget, with the exception of 'layers'.  You can play
with the mapOptions property, which will allow you to define specific
options for you overview map object.
   I haven't tested your needs, but it's possible that they could only
be controlled at the overview map layer level, which is currently only a
clone of the resource that has a "overview" option set.  We currently
have no control over this layer, and it would required work to enable some.
HTH,
Alexandre
On 12-11-21 09:53 AM, Philippe Gregoire wrote:
> Hi again list,
> I am using GP version 1.6.1.
> I have been using the OverviewMap widget. It works mostly fine but the
> way it defines wchich extent and zoom to use to display the overview
> map does not seem right all the time. Is it possible to set a maximum
> scale for this widget, or to have any power over which scale is used?
> Thanks,
> *Philippe* *Gregoire*
> Product Manager
> Boreal - Information Strategies
> Canada
> 202A-101 du Moulin Street
> Magog, Québec, J1X 4A1
> www.boreal-is.com <http://www.boreal-is.com>
> Work : +1 819 575 6037 ext:1122
> Cell: +1 819 432 5600
> Borealis | Delivering Sustainability technologies at a human scale
> <http://www.boreal-is.com/>
> Geoprisma-users mailing list
> Geoprisma-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geoprisma-users
Alexandre Dubé
Mapgears
www.mapgears.com
URL: <http://lists.osgeo.org/pipermail/geoprisma-users/attachments/20121121/3f5c0c50/attachment.html>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geoprisma-users/attachments/20121121/3f5c0c50/attachment.gif>
More information about the Geoprisma-users mailing list
