[geos-commits] r2038 - in trunk: . tests/unit tests/unit/precision
    svn_geos at osgeo.org
    Sat Dec  8 19:02:38 EST 2007
Author: mloskot
Date: 2007-12-08 19:02:37 -0500 (Sat, 08 Dec 2007)
New Revision: 2038
Added:
   trunk/tests/unit/precision/SimpleGeometryPrecisionReducerTest.cpp
   trunk/ChangeLog
   trunk/tests/unit/Makefile.am
Added test suite for class geos::precision::SimpleGeometryPrecisionReducer.
Modified: trunk/ChangeLog
--- trunk/ChangeLog	2007-12-08 22:59:54 UTC (rev 2037)
+++ trunk/ChangeLog	2007-12-09 00:02:37 UTC (rev 2038)
@@ -1,4 +1,9 @@
+2007-12-09 Mateusz Loskot <mateusz at loskot.net>
+	* tests/unit/precision/SimpleGeometryPrecisionReducerTest.cpp:
+	  test suite for class geos::precision::SimpleGeometryPrecisionReducer
 2007-11-26 Mateusz Loskot <mateusz at loskot.net>
 	* source\Makefile.vc: enabled target copying version.h.vc
Modified: trunk/tests/unit/Makefile.am
--- trunk/tests/unit/Makefile.am	2007-12-08 22:59:54 UTC (rev 2037)
+++ trunk/tests/unit/Makefile.am	2007-12-09 00:02:37 UTC (rev 2038)
@@ -50,8 +50,9 @@
 	noding/SegmentNodeTest.cpp \
 	noding/SegmentPointComparatorTest.cpp \
 	noding/SegmentStringTest.cpp \
+	precision/GeometrySnapperTest.cpp \
 	precision/LineStringSnapperTest.cpp \
-	precision/GeometrySnapperTest.cpp \
+	precision/SimpleGeometryPrecisionReducerTest.cpp \
 	simplify/DouglasPeuckerSimplifierTest.cpp \
 	simplify/TopologyPreservingSimplifierTest.cpp \
 	util/UniqueCoordinateArrayFilterTest.cpp \
Added: trunk/tests/unit/precision/SimpleGeometryPrecisionReducerTest.cpp
--- trunk/tests/unit/precision/SimpleGeometryPrecisionReducerTest.cpp	                        (rev 0)
+++ trunk/tests/unit/precision/SimpleGeometryPrecisionReducerTest.cpp	2007-12-09 00:02:37 UTC (rev 2038)
@@ -0,0 +1,149 @@
+// $Id$
+// Test Suite for geos::precision::SimpleGeometryPrecisionReducer class.
+// TUT
+#include <tut.h>
+// GEOS
+#include <geos/precision/SimpleGeometryPrecisionReducer.h>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/PrecisionModel.h>
+#include <geos/io/WKTReader.h>
+// STL
+#include <string>
+#include <vector>
+namespace tut
+    // Test Group
+    // Common data used by tests
+    struct test_sgpr_data
+        typedef std::auto_ptr<geos::geom::Geometry> GeometryPtr;
+        geos::geom::PrecisionModel pm_float_;
+        geos::geom::PrecisionModel pm_fixed_;
+        geos::geom::GeometryFactory factory_;
+        geos::io::WKTReader reader_;
+        geos::precision::SimpleGeometryPrecisionReducer reducer_;
+        geos::precision::SimpleGeometryPrecisionReducer reducer2_; // keep collapse
+        test_sgpr_data() :
+            pm_float_(),
+            pm_fixed_(1),
+            factory_(&pm_float_, 0),
+            reader_(&factory_),
+            reducer_(&pm_fixed_),
+            reducer2_(&pm_fixed_)
+            reducer2_.setRemoveCollapsedComponents(false);
+    typedef test_group<test_sgpr_data> group;
+    typedef group::object object;
+    group test_sgpr_group("geos::precision::SimpleGeometryPrecisionReducer");
+    // Test Cases
+    // Test square
+    template<>
+    template<>
+    void object::test<1>()
+        GeometryPtr g1(reader_.read("POLYGON (( 0 0, 0 1.4, 1.4 1.4, 1.4 0, 0 0 ))"));
+        GeometryPtr g2(reader_.read("POLYGON (( 0 0, 0 1, 1 1, 1 0, 0 0 ))"));
+        GeometryPtr result(reducer_.reduce(g1.get()));
+        ensure( result->equalsExact(g2.get()) );
+    // Test tiny square collapse
+    template<>
+    template<>
+    void object::test<2>()
+        GeometryPtr g1(reader_.read("POLYGON (( 0 0, 0 .4, .4 .4, .4 0, 0 0 ))"));
+        GeometryPtr g2(reader_.read("POLYGON EMPTY"));
+    // Test square collapse
+    template<>
+    template<>
+    void object::test<3>()
+        GeometryPtr g1(reader_.read("POLYGON (( 0 0, 0 1.4, .4 .4, .4 0, 0 0 ))"));
+    // Test square keep collapse
+    template<>
+    template<>
+    void object::test<4>()
+        GeometryPtr g2(reader_.read("POLYGON (( 0 0, 0 1, 0 0, 0 0, 0 0 ))"));
+        GeometryPtr result(reducer2_.reduce(g1.get()));
+    // Test line
+    template<>
+    template<>
+    void object::test<5>()
+        GeometryPtr g1(reader_.read("LINESTRING ( 0 0, 0 1.4 )"));
+        GeometryPtr g2(reader_.read("LINESTRING (0 0, 0 1)"));
+    // Test line remove collapse
+    template<>
+    template<>
+    void object::test<6>()
+        GeometryPtr g1(reader_.read("LINESTRING ( 0 0, 0 .4 )"));
+        GeometryPtr g2(reader_.read("LINESTRING EMPTY"));
+    // Test line keep collapse
+    template<>
+    template<>
+    void object::test<7>()
+        GeometryPtr g2(reader_.read("LINESTRING ( 0 0, 0 0 )"));
+} // namespace tut
Property changes on: trunk/tests/unit/precision/SimpleGeometryPrecisionReducerTest.cpp
___________________________________________________________________
   + Id
More information about the geos-commits
