[geos-commits] r2040 - in trunk: . build/msvc80/geos_unit
source/geom tests/unit/geom
svn_geos at osgeo.org
Thu Dec 13 11:09:25 EST 2007
Author: mloskot
Date: 2007-12-13 11:09:25 -0500 (Thu, 13 Dec 2007)
New Revision: 2040
trunk/ChangeLog
trunk/build/msvc80/geos_unit/geos_unit.vcproj
trunk/source/geom/Geometry.cpp
trunk/source/geom/GeometryCollection.cpp
trunk/tests/unit/geom/GeometryFactoryTest.cpp
* build\msvc80\geos_unit\geos_unit.vcproj: fixed post-build event
* source\geom\GeometryCollection.cpp: removed unreachable code,
shorten exception message.
* source\geom\Geometry.cpp: purified condition based on dynamic_cast
* tests\unit\geom\GeometryFactoryTest.cpp: use std::size_t instead of
int where unsigned integral type required.
Modified: trunk/ChangeLog
--- trunk/ChangeLog 2007-12-12 22:50:09 UTC (rev 2039)
+++ trunk/ChangeLog 2007-12-13 16:09:25 UTC (rev 2040)
@@ -1,4 +1,13 @@
+2007-12-13 Mateusz Loskot <mateusz at loskot.net>
+ * build\msvc80\geos_unit\geos_unit.vcproj: fixed post-build event
+ * source\geom\GeometryCollection.cpp: removed unreachable code,
+ shorten exception message.
+ * source\geom\Geometry.cpp: purified condition based on dynamic_cast
+ * tests\unit\geom\GeometryFactoryTest.cpp: use std::size_t instead of
+ int where unsigned integral type required.
2007-12-09 Mateusz Loskot <mateusz at loskot.net>
* tests/unit/precision/SimpleGeometryPrecisionReducerTest.cpp:
Modified: trunk/build/msvc80/geos_unit/geos_unit.vcproj
--- trunk/build/msvc80/geos_unit/geos_unit.vcproj 2007-12-12 22:50:09 UTC (rev 2039)
+++ trunk/build/msvc80/geos_unit/geos_unit.vcproj 2007-12-13 16:09:25 UTC (rev 2040)
@@ -91,8 +91,8 @@
<Tool
Name="VCPostBuildEventTool"
- Description="Running regression tests using $(ProjectName).exe..."
- CommandLine=""
+ Description="Running regression tests using $(ProjectName)d.exe..."
+ CommandLine="cd $(OutDir)
$(ProjectName)d.exe"
</Configuration>
<Configuration
@@ -372,6 +372,10 @@
<Filter
Name="operation"
+ <File
+ RelativePath="..\..\..\tests\unit\operation\IsSimpleOpTest.cpp"
+ </File>
<Filter
Name="distance"
@@ -408,6 +412,10 @@
RelativePath="..\..\..\tests\unit\precision\LineStringSnapperTest.cpp"
</File>
+ <File
+ RelativePath="..\..\..\tests\unit\precision\SimpleGeometryPrecisionReducerTest.cpp"
+ </File>
</Filter>
<Filter
Name="capi"
Modified: trunk/source/geom/Geometry.cpp
--- trunk/source/geom/Geometry.cpp 2007-12-12 22:50:09 UTC (rev 2039)
+++ trunk/source/geom/Geometry.cpp 2007-12-13 16:09:25 UTC (rev 2040)
@@ -550,7 +550,7 @@
size_t ngeoms, i;
vector<Geometry *> *v = new vector<Geometry *>();
- if ( (coll = dynamic_cast<const GeometryCollection *>(this)) )
+ if ( NULL != (coll = dynamic_cast<const GeometryCollection *>(this)) )
ngeoms = coll->getNumGeometries();
for (i=0; i<ngeoms; i++)
@@ -559,7 +559,7 @@
v->push_back(this->clone());
- if ( (coll = dynamic_cast<const GeometryCollection *>(other)) )
+ if ( NULL != (coll = dynamic_cast<const GeometryCollection *>(other)) )
Modified: trunk/source/geom/GeometryCollection.cpp
--- trunk/source/geom/GeometryCollection.cpp 2007-12-12 22:50:09 UTC (rev 2039)
+++ trunk/source/geom/GeometryCollection.cpp 2007-12-13 16:09:25 UTC (rev 2040)
@@ -154,15 +154,13 @@
bool
GeometryCollection::isSimple() const
- throw util::IllegalArgumentException("This method is not supported by GeometryCollection objects\n");
- return false;
+ throw util::IllegalArgumentException("Operation not supported by GeometryCollection\n");
Geometry*
GeometryCollection::getBoundary() const
- return NULL;
bool
Modified: trunk/tests/unit/geom/GeometryFactoryTest.cpp
--- trunk/tests/unit/geom/GeometryFactoryTest.cpp 2007-12-12 22:50:09 UTC (rev 2039)
+++ trunk/tests/unit/geom/GeometryFactoryTest.cpp 2007-12-13 16:09:25 UTC (rev 2040)
@@ -24,6 +24,7 @@
#include <geos/util/IllegalArgumentException.h>
// STL
#include <vector>
+#include <cstring> // std::size_t
* \brief
@@ -503,7 +504,7 @@
template<>
void object::test<13>()
- const size_t size = 5;
+ const std::size_t size = 5;
CoordArrayPtr coords = new geos::geom::CoordinateArraySequence(size);
ensure( coords != 0 );
ensure_equals( coords->getSize(), size );
@@ -533,7 +534,7 @@
template<>
void object::test<14>()
geos::geom::CoordinateArraySequence coords(size);
ensure_equals( coords.getSize(), size );
@@ -603,7 +604,7 @@
template<>
void object::test<16>()
@@ -633,7 +634,7 @@
template<>
void object::test<17>()
@@ -705,7 +706,7 @@
void object::test<19>()
using geos::geom::Coordinate;
- const size_t size = 7;
+ const std::size_t size = 7;
// Create sequence of coordiantes
@@ -753,8 +754,8 @@
void object::test<20>()
- const size_t exteriorSize = 7;
- const size_t interiorSize = 5;
+ const std::size_t exteriorSize = 7;
+ const std::size_t interiorSize = 5;
CoordArrayPtr coords = new geos::geom::CoordinateArraySequence(exteriorSize);
@@ -894,7 +895,7 @@
template<>
void object::test<23>()
- const size_t size = 3;
+ const std::size_t size = 3;
geos::geom::Coordinate coord(x_, y_, z_);
std::vector<GeometryPtr> vec;
@@ -978,7 +979,7 @@
template<>
void object::test<25>()
std::vector<GeometryPtr>* vec = new std::vector<GeometryPtr>();
@@ -1019,7 +1020,7 @@
template<>
void object::test<26>()
@@ -1063,7 +1064,7 @@
void object::test<27>()
// Add collection of coordinates
@@ -1133,14 +1134,14 @@
- const size_t lineSize = 2;
+ const std::size_t lineSize = 2;
std::vector<GeometryPtr>* lines = new std::vector<GeometryPtr>();
- for (size_t i = 0; i < size; ++i)
+ for (std::size_t i = 0; i < size; ++i)
- const int factor = i * i;
+ const std::size_t factor = i * i;
CoordArrayPtr coords = new geos::geom::CoordinateArraySequence(lineSize);
coords->setAt(Coordinate(0 + factor, 0 + factor), 0);
@@ -1175,14 +1176,14 @@
std::vector<GeometryPtr> lines;
More information about the geos-commits
