[geos-commits] r2044 - trunk/tests/xmltester
svn_geos at osgeo.org
Mon Dec 17 18:09:45 EST 2007
Author: mloskot
Date: 2007-12-17 18:09:45 -0500 (Mon, 17 Dec 2007)
New Revision: 2044
trunk/tests/xmltester/XMLTester.cpp
Fixed std::tolower usage in XMLTester.cpp (Ticket #163).
Modified: trunk/tests/xmltester/XMLTester.cpp
--- trunk/tests/xmltester/XMLTester.cpp 2007-12-17 23:05:42 UTC (rev 2043)
+++ trunk/tests/xmltester/XMLTester.cpp 2007-12-17 23:09:45 UTC (rev 2044)
@@ -67,12 +67,10 @@
using namespace geos::operation::polygonize;
using namespace geos::operation::linemerge;
-template <int (&F)(int)> unsigned char safe_ctype(unsigned char c) { return F(c); }
void
tolower(std::string& str)
- std::transform(str.begin(), str.end(), str.begin(), safe_ctype<std::tolower>);
+ std::transform(str.begin(), str.end(), str.begin(), (int(*)(int))std::tolower);
std::string
More information about the geos-commits
