[geos-commits] r2053 - trunk/source/headers/geos/algorithm/locate
svn_geos at osgeo.org
Fri Dec 21 15:00:22 EST 2007
Author: benjubb
Date: 2007-12-21 15:00:22 -0500 (Fri, 21 Dec 2007)
New Revision: 2053
Added:
trunk/source/headers/geos/algorithm/locate/SimplePointInAreaLocator.h
Moved from geos::algorithm as in JTS 1.9
Copied: trunk/source/headers/geos/algorithm/locate/SimplePointInAreaLocator.h (from rev 2051, trunk/source/headers/geos/algorithm/SimplePointInAreaLocator.h)
--- trunk/source/headers/geos/algorithm/locate/SimplePointInAreaLocator.h (rev 0)
+++ trunk/source/headers/geos/algorithm/locate/SimplePointInAreaLocator.h 2007-12-21 20:00:22 UTC (rev 2053)
@@ -0,0 +1,77 @@
+ * $Id$
+ * GEOS - Geometry Engine Open Source
+ * http://geos.refractions.net
+ * Copyright (C) 2005-2006 Refractions Research Inc.
+ * Copyright (C) 2001-2002 Vivid Solutions Inc.
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+#ifndef GEOS_ALGORITHM_LOCATE_SIMPLEPOINTINAREALOCATOR_H
+#define GEOS_ALGORITHM_LOCATE_SIMPLEPOINTINAREALOCATOR_H
+#include <geos/algorithm/locate/PointOnGeometryLocator.h> // inherited
+// Forward declarations
+namespace geos {
+ namespace geom {
+ class Geometry;
+ class Coordinate;
+ class Polygon;
+namespace geos {
+namespace algorithm { // geos::algorithm
+namespace locate { // geos::algorithm::locate
+class SimplePointInAreaLocator : public PointOnGeometryLocator
+public:
+ static int locate(const geom::Coordinate& p,
+ const geom::Geometry *geom);
+ static bool containsPointInPolygon(const geom::Coordinate& p,
+ const geom::Polygon *poly);
+ SimplePointInAreaLocator( const geom::Geometry * g)
+ : g( g)
+ int locate( const geom::Coordinate * p)
+ return locate( *p, g);
+private:
+ static bool containsPoint(const geom::Coordinate& p,
+ const geom::Geometry * g;
+} // geos::algorithm::locate
+} // geos
+#endif // GEOS_ALGORITHM_LOCATE_SIMPLEPOINTINAREALOCATOR_H
+ * $Log$
+ * Revision 1.1 2006/03/09 16:46:48 strk
+ * geos::geom namespace definition, first pass at headers split
More information about the geos-commits
