[geos-commits] r2055 - trunk/source/headers/geos/geom
svn_geos at osgeo.org
Fri Dec 21 15:30:13 EST 2007
Author: benjubb
Date: 2007-12-21 15:30:13 -0500 (Fri, 21 Dec 2007)
New Revision: 2055
trunk/source/headers/geos/geom/Geometry.h
changed IsRectangle to be public
Modified: trunk/source/headers/geos/geom/Geometry.h
--- trunk/source/headers/geos/geom/Geometry.h 2007-12-21 20:03:37 UTC (rev 2054)
+++ trunk/source/headers/geos/geom/Geometry.h 2007-12-21 20:30:13 UTC (rev 2055)
@@ -288,6 +288,9 @@
/// Returns whether or not the set of points in this Geometry is empty.
virtual bool isEmpty() const=0; //Abstract
+ /// Polygon overrides to check for actual rectangle
+ virtual bool isRectangle() const { return false; }
/// Returns the dimension of this Geometry (0=point, 1=line, 2=surface)
virtual Dimension::DimensionType getDimension() const=0; //Abstract
@@ -707,7 +710,7 @@
//Geometry* fromInternalGeometry(const Geometry *g) const;
- virtual bool isRectangle() const { return false; }
+ //virtual bool isRectangle() const { return false; } -- moved to public
Geometry(const Geometry &geom);
More information about the geos-commits
