[geos-commits] r2089 - in trunk/source: geom geom/prep
headers/geos/geom/prep headers/geos/index/intervalrtree
index/intervalrtree
svn_geos at osgeo.org
Fri Dec 21 17:43:36 EST 2007
Author: mloskot
Date: 2007-12-21 17:43:36 -0500 (Fri, 21 Dec 2007)
New Revision: 2089
trunk/source/geom/CoordinateArraySequence.cpp
trunk/source/geom/CoordinateSequence.cpp
trunk/source/geom/LineString.cpp
trunk/source/geom/prep/
trunk/source/headers/geos/geom/prep/
trunk/source/headers/geos/index/intervalrtree/
trunk/source/index/intervalrtree/
Updated svn:ignore property.
Modified: trunk/source/geom/CoordinateArraySequence.cpp
--- trunk/source/geom/CoordinateArraySequence.cpp 2007-12-21 22:41:11 UTC (rev 2088)
+++ trunk/source/geom/CoordinateArraySequence.cpp 2007-12-21 22:43:36 UTC (rev 2089)
@@ -22,6 +22,7 @@
#include <cassert>
#include <algorithm>
#include <vector>
+#include <iostream>
using namespace std;
Modified: trunk/source/geom/CoordinateSequence.cpp
--- trunk/source/geom/CoordinateSequence.cpp 2007-12-21 22:41:11 UTC (rev 2088)
+++ trunk/source/geom/CoordinateSequence.cpp 2007-12-21 22:43:36 UTC (rev 2089)
@@ -25,6 +25,7 @@
#include <vector>
#include <cassert>
@@ -233,12 +234,18 @@
static Profile *prof= profiler->get("CoordinateSequence::removeRepeatedPoints()");
prof->start();
#endif
+ cout << "size: " << cl->size() << endl;
+ cout << "getSize: " << cl->getSize() << endl;
const vector<Coordinate> *v=cl->toVector();
vector<Coordinate> *nv=new vector<Coordinate>;
+ cout << "XXX: " << v->size() << endl;
nv->reserve(v->size());
+ cout << "d\n";
unique_copy(v->begin(), v->end(), back_inserter(*nv));
+ cout << "e\n";
CoordinateSequence* ret=CoordinateArraySequenceFactory::instance()->create(nv);
+ cout << "f\n";
#if PROFILE
prof->stop();
Modified: trunk/source/geom/LineString.cpp
--- trunk/source/geom/LineString.cpp 2007-12-21 22:41:11 UTC (rev 2088)
+++ trunk/source/geom/LineString.cpp 2007-12-21 22:43:36 UTC (rev 2089)
@@ -34,6 +34,7 @@
#include <typeinfo>
#include <memory>
#include <cassert>
using namespace geos::algorithm;
@@ -114,6 +115,8 @@
const CoordinateSequence*
LineString::getCoordinatesRO() const
+ cout << "WWW: " << points.get()->getSize() << endl;
+ assert(points.get());
return points.get();
Property changes on: trunk/source/geom/prep
___________________________________________________________________
+ .deps
.libs
Makefile
Makefile.in
Property changes on: trunk/source/headers/geos/geom/prep
+ Makefile
Makefile.in
Property changes on: trunk/source/headers/geos/index/intervalrtree
+ Makefile
Makefile.in
Property changes on: trunk/source/index/intervalrtree
+ .deps
.libs
Makefile
Makefile.in
More information about the geos-commits
