[geos-commits] r2096 - in trunk: . source/headers/geos/algorithm
source/headers/geos/algorithm/locate tests/unit
svn_geos at osgeo.org
Fri Dec 21 18:21:40 EST 2007
Author: mloskot
Date: 2007-12-21 18:21:40 -0500 (Fri, 21 Dec 2007)
New Revision: 2096
trunk/
trunk/source/headers/geos/algorithm/
trunk/source/headers/geos/algorithm/locate/
trunk/tests/unit/
Updated svn:ignore property.
Property changes on: trunk
___________________________________________________________________
- aclocal.m4
autom4te.cache
config.guess
config.log
config.status
config.sub
configure
depcomp
install-sh
libtool
ltmain.sh
missing
mkinstalldirs
Makefile
Makefile.in
py-compile
tags
ID
*.swp
+ aclocal.m4
autom4te.cache
config.guess
config.log
config.status
config.sub
configure
depcomp
install-sh
libtool
ltmain.sh
missing
mkinstalldirs
Makefile
Makefile.in
py-compile
tags
ID
*.swp
.gdb*
Property changes on: trunk/source/headers/geos/algorithm
- Makefile.in
Makefile
+ Makefile
Makefile.in
Property changes on: trunk/source/headers/geos/algorithm/locate
+ Makefile
Makefile.in
Property changes on: trunk/tests/unit
- .deps
.libs
Makefile
Makefile.in
geos_unit
+ .deps
.libs
.gdb*
Makefile
Makefile.in
geos_unit
More information about the geos-commits
