[geos-commits] r2101 - in trunk/build/bjam: geos geos_c geos_unit
svn_geos at osgeo.org
Fri Dec 21 19:04:25 EST 2007
Author: mloskot
Date: 2007-12-21 19:04:25 -0500 (Fri, 21 Dec 2007)
New Revision: 2101
trunk/build/bjam/geos/Jamfile
trunk/build/bjam/geos_c/
trunk/build/bjam/geos_unit/
Updated configuration of experimental builder based on Boost.Build. GEOS compiles with bjam successfully as static library.
Modified: trunk/build/bjam/geos/Jamfile
--- trunk/build/bjam/geos/Jamfile 2007-12-21 23:50:57 UTC (rev 2100)
+++ trunk/build/bjam/geos/Jamfile 2007-12-22 00:04:25 UTC (rev 2101)
@@ -43,10 +43,12 @@
[ set.difference
[ glob algorithm/*.cpp ] : [ glob algorithm/*RobustLineIntersector.cpp ]
+ [ glob algorithm/locate/*.cpp ]
[ glob geom/*.cpp ]
[ glob geom/util/*.cpp ]
[ glob index/*.cpp ]
[ glob index/chain/*.cpp ]
+ [ glob index/intervalrtree/*.cpp ]
[ glob index/strtree/*.cpp ]
[ glob index/sweepline/*.cpp ]
[ glob io/*.cpp ]
Property changes on: trunk/build/bjam/geos_c
___________________________________________________________________
+ bin
Property changes on: trunk/build/bjam/geos_unit
+ bin
More information about the geos-commits
