[geos-commits] r2033 - in trunk: . source source/headers/geos
svn_geos at osgeo.org
Mon Nov 26 01:16:15 EST 2007
Author: mloskot
Date: 2007-11-26 01:16:14 -0500 (Mon, 26 Nov 2007)
New Revision: 2033
trunk/ChangeLog
trunk/source/Makefile.vc
trunk/source/headers/geos/version.h.vc
Enabled target copying version.h.vc and geos_c.h.vc to headers used by Visual C++. Added test if version.h.vc is used with Visual C++.
Modified: trunk/ChangeLog
--- trunk/ChangeLog 2007-11-23 02:33:41 UTC (rev 2032)
+++ trunk/ChangeLog 2007-11-26 06:16:14 UTC (rev 2033)
@@ -1,4 +1,11 @@
+2007-11-26 Mateusz Loskot <mateusz at loskot.net>
+ * source\Makefile.vc: enabled target copying version.h.vc
+ and geos_c.h.vc to headers used by Visual C++
+ source\headers\geos\version.h.vc: added test if used
+ with Visual C++ compiler
2007-11-22 Mateusz Loskot <mateusz at loskot.net>
* source/headers/geos/io/WKBWriter.h: added purifying cast of
Modified: trunk/source/Makefile.vc
--- trunk/source/Makefile.vc 2007-11-23 02:33:41 UTC (rev 2032)
+++ trunk/source/Makefile.vc 2007-11-26 06:16:14 UTC (rev 2033)
@@ -330,13 +330,13 @@
# version.h should already be in distribution, if is not you'll
# have to run ./configure to recreate
-#headers/geos/version.h: headers/geos/version.h.vc
-# copy headers\geos\version.h.vc headers\geos\version.h
+headers/geos/version.h: headers/geos/version.h.vc
+ copy headers\geos\version.h.vc headers\geos\version.h
# geos_c.h should already be in distribution, if is not you'll
-#capi/geos_c.h: ../capi/geos_c.h.vc
-# copy ..\capi\geos_c.h.vc ..\capi\geos_c.h
+../capi/geos_c.h: ../capi/geos_c.h.in.
+ copy ..\capi\geos_c.h.in ..\capi\geos_c.h
.cpp.obj:
$(CC) $(CFLAGS) /c $*.cpp /Fo$@
Modified: trunk/source/headers/geos/version.h.vc
--- trunk/source/headers/geos/version.h.vc 2007-11-23 02:33:41 UTC (rev 2032)
+++ trunk/source/headers/geos/version.h.vc 2007-11-26 06:16:14 UTC (rev 2033)
@@ -23,6 +23,10 @@
#ifndef GEOS_VERSION_H
#define GEOS_VERSION_H
+#ifndef _MSC_VER
+#error "This version.h intended for use with MS Visual C++"
+#endif
#define GEOS_VERSION_MAJOR 3
#define GEOS_VERSION_MINOR 0
#define GEOS_VERSION_PATCH 0rc4
More information about the geos-commits
