[geos-commits] r2124 - branches/3.0/source/geom
svn_geos at osgeo.org
Mon Apr 21 19:22:11 EDT 2008
Author: pramsey
Date: 2008-04-21 19:22:11 -0400 (Mon, 21 Apr 2008)
New Revision: 2124
branches/3.0/source/geom/Geometry.cpp
Fix for rectangle optimization logic.
Modified: branches/3.0/source/geom/Geometry.cpp
--- branches/3.0/source/geom/Geometry.cpp 2008-02-07 22:59:35 UTC (rev 2123)
+++ branches/3.0/source/geom/Geometry.cpp 2008-04-21 23:22:11 UTC (rev 2124)
@@ -422,9 +422,11 @@
if (isRectangle()) {
return predicate::RectangleContains::contains((Polygon&)*this, *g);
+/* Removed per: http://www.nabble.com/ST_Contains-doesn't-work--to14946025.html
if (g->isRectangle()) {
return predicate::RectangleContains::contains((const Polygon&)*g, *this);
IntersectionMatrix *im=relate(g);
bool res=im->isContains();
More information about the geos-commits
