[geos-commits] r2165 - trunk/tests/unit/algorithm/CGAlgorithms
svn_geos at osgeo.org
Mon Aug 18 19:45:39 EDT 2008
Author: mloskot
Date: 2008-08-18 19:45:34 -0400 (Mon, 18 Aug 2008)
New Revision: 2165
trunk/tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp
tests/unit/algorithm/CGAlgorithms: Fixed number of memory leaks.
Modified: trunk/tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp
--- trunk/tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp 2008-08-18 23:30:00 UTC (rev 2164)
+++ trunk/tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp 2008-08-18 23:45:34 UTC (rev 2165)
@@ -8,12 +8,14 @@
// geos
#include <geos/algorithm/CGAlgorithms.h>
#include <geos/geom/Polygon.h>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/CoordinateSequence.h>
#include <geos/geom/Coordinate.h>
-#include <geos/geom/Geometry.h>
#include <geos/io/WKTReader.h>
// std
#include <string>
#include <memory>
+#include <cassert>
using namespace geos::algorithm;
@@ -27,9 +29,20 @@
typedef std::auto_ptr<geos::geom::Geometry> GeometryPtr;
+ geos::geom::CoordinateSequence* cs_;
geos::io::WKTReader reader_;
- test_isccw_data() {}
+ test_isccw_data()
+ : cs_(0)
+ assert(0 == cs_);
+ ~test_isccw_data()
+ delete cs_;
+ cs_ = 0;
typedef test_group<test_isccw_data> group;
@@ -49,7 +62,8 @@
const std::string wkt("POLYGON ((60 180, 140 240, 140 240, 140 240, 200 180, 120 120, 60 180))");
GeometryPtr geom(reader_.read(wkt));
- bool isCCW = CGAlgorithms::isCCW(geom->getCoordinates());
+ cs_ = geom->getCoordinates();
+ bool isCCW = CGAlgorithms::isCCW(cs_);
ensure_equals( false, isCCW );
@@ -62,7 +76,8 @@
const std::string wkt("POLYGON ((60 180, 140 120, 100 180, 140 240, 60 180))");
ensure_equals( true, isCCW );
@@ -75,9 +90,11 @@
const std::string wkt("POLYGON ((60 180, 140 120, 100 180, 140 240, 140 240, 60 180))");
} // namespace tut
More information about the geos-commits
