[geos-commits] r2106 - trunk/capi
svn_geos at osgeo.org
Wed Jan 9 18:49:31 EST 2008
Author: benjubb
Date: 2008-01-09 18:49:31 -0500 (Wed, 09 Jan 2008)
New Revision: 2106
trunk/capi/geos_c.cpp
trunk/capi/geos_c.h.in
Added support for prepared geometry
Modified: trunk/capi/geos_c.cpp
--- trunk/capi/geos_c.cpp 2008-01-09 23:48:27 UTC (rev 2105)
+++ trunk/capi/geos_c.cpp 2008-01-09 23:49:31 UTC (rev 2106)
@@ -16,6 +16,8 @@
#include <geos/geom/Geometry.h>
+#include <geos/geom/prep/PreparedGeometry.h>
+#include <geos/geom/prep/PreparedGeometryFactory.h>
#include <geos/geom/GeometryCollection.h>
#include <geos/geom/Polygon.h>
#include <geos/geom/Point.h>
@@ -53,6 +55,7 @@
// Some extra magic to make type declarations in geos_c.h work - for cross-checking of types in header.
#define GEOSGeometry geos::geom::Geometry
+#define GEOSPreparedGeometry geos::geom::prep::PreparedGeometry
#define GEOSCoordSequence geos::geom::CoordinateSequence
#define GEOSWKTReader_t geos::io::WKTReader
#define GEOSWKTWriter_t geos::io::WKTWriter
@@ -2281,4 +2284,128 @@
+// Prepared Geometry
+const geos::geom::prep::PreparedGeometry*
+GEOSPrepare(const Geometry *g)
+ try
+ const geos::geom::prep::PreparedGeometry* prep;
+ prep = geos::geom::prep::PreparedGeometryFactory::prepare( g);
+ return prep;
+ catch (const std::exception &e)
+ ERROR_MESSAGE("%s", e.what());
+ catch (...)
+ ERROR_MESSAGE("Unknown exception thrown");
+void
+GEOSPreparedGeom_destroy(geos::geom::prep::PreparedGeometry *a)
+ try
+ delete a;
+ catch (...)
+char
+GEOSPreparedContains(const geos::geom::prep::PreparedGeometry *pg1, const Geometry *g2)
+ try
+ bool result;
+ result = pg1->contains(g2);
+ return result;
+ return 2;
+ catch (...)
+ return 2;
+char
+GEOSPreparedContainsProperty(const geos::geom::prep::PreparedGeometry *pg1, const Geometry *g2)
+ try
+ bool result;
+ result = pg1->containsProperly(g2);
+ return result;
+ return 2;
+ catch (...)
+ return 2;
+char
+GEOSPreparedCovers(const geos::geom::prep::PreparedGeometry *pg1, const Geometry *g2)
+ try
+ bool result;
+ result = pg1->covers(g2);
+ return result;
+ return 2;
+ catch (...)
+ return 2;
+char
+GEOSPreparedIntersects(const geos::geom::prep::PreparedGeometry *pg1, const Geometry *g2)
+ try
+ bool result;
+ result = pg1->intersects(g2);
+ return result;
+ return 2;
+ catch (...)
+ return 2;
} //extern "C"
Modified: trunk/capi/geos_c.h.in
--- trunk/capi/geos_c.h.in 2008-01-09 23:48:27 UTC (rev 2105)
+++ trunk/capi/geos_c.h.in 2008-01-09 23:49:31 UTC (rev 2106)
@@ -86,6 +86,7 @@
#ifndef GEOSGeometry
typedef struct GEOSGeom_t GEOSGeometry;
+typedef struct GEOSPrepGeom_t GEOSPreparedGeometry;
typedef struct GEOSCoordSeq_t GEOSCoordSequence;
#endif
@@ -312,6 +313,25 @@
+ * Prepared Geometry Binary predicates - return 2 on exception, 1 on true, 0 on false
+ * Argument ownership is taken by prepared geometry
+extern const GEOSPreparedGeometry GEOS_DLL *GEOSPrepare(const GEOSGeometry* g);
+extern void GEOS_DLL GEOSPreparedGeom_destroy(GEOSPreparedGeometry* g);
+extern char GEOS_DLL GEOSPreparedContains(const GEOSPreparedGeometry* pg1, const GEOSGeometry* g2);
+extern char GEOS_DLL GEOSPreparedContainsProperly(const GEOSPreparedGeometry* pg1, const GEOSGeometry* g2);
+extern char GEOS_DLL GEOSPreparedCovers(const GEOSPreparedGeometry* pg1, const GEOSGeometry* g2);
+extern char GEOS_DLL GEOSPreparedIntersects(const GEOSPreparedGeometry* pg1, const GEOSGeometry* g2);
* Unary predicate - return 2 on exception, 1 on true, 0 on false
More information about the geos-commits
