[geos-commits] r2113 - trunk/source/operation/predicate
svn_geos at osgeo.org
Tue Jan 29 12:49:18 EST 2008
Author: benjubb
Date: 2008-01-29 12:49:18 -0500 (Tue, 29 Jan 2008)
New Revision: 2113
trunk/source/operation/predicate/RectangleContains.cpp
Fix a bug in the shortcut test for containment in a rectangle. This test wasn't correctly testing for case of a point on the boundary.
Was also a bug in JTS (now fixed).
Modified: trunk/source/operation/predicate/RectangleContains.cpp
--- trunk/source/operation/predicate/RectangleContains.cpp 2008-01-29 17:37:22 UTC (rev 2112)
+++ trunk/source/operation/predicate/RectangleContains.cpp 2008-01-29 17:49:18 UTC (rev 2113)
@@ -79,10 +79,9 @@
// we already know that the point is contained in the
// rectangle envelope
- if (! (pt.x == rectEnv.getMinX() || pt.x == rectEnv.getMaxX()) )
- return false;
- if (! (pt.y == rectEnv.getMinY() || pt.y == rectEnv.getMaxY()) )
- return false;
+ return
+ pt.x == rectEnv.getMinX() || pt.x == rectEnv.getMaxX() ||
+ pt.y == rectEnv.getMinY() || pt.y == rectEnv.getMaxY();
return true;
More information about the geos-commits
