[geos-commits] r2130 - trunk/source
svn_geos at osgeo.org
Tue Jul 15 09:35:05 EDT 2008
Author: mloskot
Date: 2008-07-15 09:35:05 -0400 (Tue, 15 Jul 2008)
New Revision: 2130
trunk/source/Makefile.vc
For building with Visual C++, added new flag DEBUG=1 (see GEOS building instructions on GEOS Wiki). Added missing flags for Visual C++ compiler, in release and debug configuration.
Modified: trunk/source/Makefile.vc
--- trunk/source/Makefile.vc 2008-05-20 21:34:42 UTC (rev 2129)
+++ trunk/source/Makefile.vc 2008-07-15 13:35:05 UTC (rev 2130)
@@ -19,32 +19,42 @@
# Check compiler version given in command line
# nmake -f makefile.vc MSVC_VER=xxxx
+# By default, Visual C++ 7.1 (1310) is configured.
!IFNDEF MSVC_VER
-#assume msvc 7.1
MSVC_VER=1310
!ENDIF
+# Collect compiler version specific flags
!IF $(MSVC_VER) >= 1400
MSVC_CPPFLAGS = /EHs /D "_CRT_SECURE_NO_DEPRECATE"
!ELSE
MSVC_CPPFLAGS = /GX
!ENDIF
-#CFLAGS = -Iheaders /GX /MD /GR /Zi /nologo
-#CFLAGS = -Iheaders /GX /MD /GR /O1 /D "NDEBUG" /nologo
-CFLAGS = -Iheaders /MD /GR /O2 /D "NDEBUG" /nologo \
- /D "NOMINMAX" /D "WIN32_LEAN_AND_MEAN" /D "NOGDI" \
- $(MSVC_CPPFLAGS)
+# Determine requested build configuration, by default use release and
+# build optimized binaries. For Debug, use
+# nmake -f makefile.vc DEBUG=1
+!IFNDEF DEBUG
+CFLAGS = -Iheaders /MD /GR /O2 /W3 /nologo /D "NDEBUG" \
+ /D "NOMINMAX" /D "WIN32_LEAN_AND_MEAN" /D "NOGDI" \
+ $(MSVC_CPPFLAGS)
+!ELSE
+CFLAGS = -Iheaders /MDd /GR /Od /W4 /Zi /nologo /D "_DEBUG" \
+ $(MSVC_CPPFLAGS)
+!ENDIF
+# Names of binary files
LIBNAME = geos.lib
DLLNAME = geos.dll
-CDLLNAME = geos_c.dll
-CLIBNAME = geos_c_i.lib
+CDLLNAME = geos_c.dll
+CLIBNAME = geos_c_i.lib
SLIBNAME = geos_i.lib
-OBJ = algorithm\CGAlgorithms.obj \
+# List of objects
+OBJ = \
+ algorithm\CGAlgorithms.obj \
algorithm\CentroidArea.obj \
algorithm\CentroidLine.obj \
algorithm\CentroidPoint.obj \
More information about the geos-commits
