[geos-commits] r2144 - in trunk: capi tests/unit tests/unit/capi
svn_geos at osgeo.org
Thu Jul 31 13:01:15 EDT 2008
Author: mloskot
Date: 2008-07-31 13:01:15 -0400 (Thu, 31 Jul 2008)
New Revision: 2144
Added:
trunk/tests/unit/capi/GEOSPolygonizer_getCutEdgesTest.cpp
trunk/capi/geos_c.cpp
trunk/capi/geos_c.h.in
trunk/tests/unit/Makefile.am
Patch completing C API interface with wrapper on Polygonizer::getCutEdges (Ticket #195). Unit test included in tests/unit/capi/GEOSPolygonizer_getCutEdgeTest.cpp. Thanks to Jurgen E. Fischer for this patch.
Modified: trunk/capi/geos_c.cpp
--- trunk/capi/geos_c.cpp 2008-07-26 23:06:11 UTC (rev 2143)
+++ trunk/capi/geos_c.cpp 2008-07-31 17:01:15 UTC (rev 2144)
@@ -1352,6 +1352,54 @@
Geometry *
+GEOSPolygonizer_getCutEdges(const Geometry * const * g, unsigned int ngeoms)
+ using geos::operation::polygonize::Polygonizer;
+ unsigned int i;
+ Geometry *out = NULL;
+ try{
+ // Polygonize
+ Polygonizer plgnzr;
+ for (i=0; i<ngeoms; i++) plgnzr.add(g[i]);
+#if GEOS_DEBUG
+ NOTICE_MESSAGE("geometry vector added to polygonizer");
+#endif
+ std::vector<const LineString *>*lines = plgnzr.getCutEdges();
+#if GEOS_DEBUG
+ NOTICE_MESSAGE("output polygons got");
+#endif
+ // We need a vector of Geometry pointers, not
+ // Polygon pointers.
+ // STL vector doesn't allow transparent upcast of this
+ // nature, so we explicitly convert.
+ // (it's just a waste of processor and memory, btw)
+ std::vector<Geometry*> *linevec =
+ new std::vector<Geometry *>(lines->size());
+ for (i=0; i<lines->size(); i++) (*linevec)[i] = (*lines)[i]->clone();
+ out = geomFactory->createGeometryCollection(linevec);
+ // the above method takes ownership of the passed
+ // vector, so we must *not* delete it
+ catch (const std::exception &e)
+ ERROR_MESSAGE("%s", e.what());
+ return NULL;
+ catch (...)
+ ERROR_MESSAGE("Unknown exception thrown");
+ return NULL;
+ return out;
+Geometry *
GEOSLineMerge(const Geometry *g)
using geos::operation::linemerge::LineMerger;
Modified: trunk/capi/geos_c.h.in
--- trunk/capi/geos_c.h.in 2008-07-26 23:06:11 UTC (rev 2143)
+++ trunk/capi/geos_c.h.in 2008-07-31 17:01:15 UTC (rev 2144)
@@ -294,8 +294,8 @@
* all arguments remain ownership of the caller
* (both Geometries and pointers)
-extern GEOSGeometry GEOS_DLL *GEOSPolygonize(const GEOSGeometry * const geoms[],
- unsigned int ngeoms);
+extern GEOSGeometry GEOS_DLL *GEOSPolygonize(const GEOSGeometry * const geoms[], unsigned int ngeoms);
+extern GEOSGeometry GEOS_DLL *GEOSPolygonizer_getCutEdges(const GEOSGeometry * const geoms[], unsigned int ngeoms);
extern GEOSGeometry GEOS_DLL *GEOSLineMerge(const GEOSGeometry* g);
extern GEOSGeometry GEOS_DLL *GEOSSimplify(const GEOSGeometry* g1, double tolerance);
Modified: trunk/tests/unit/Makefile.am
--- trunk/tests/unit/Makefile.am 2008-07-26 23:06:11 UTC (rev 2143)
+++ trunk/tests/unit/Makefile.am 2008-07-31 17:01:15 UTC (rev 2144)
@@ -57,7 +57,8 @@
simplify/TopologyPreservingSimplifierTest.cpp \
util/UniqueCoordinateArrayFilterTest.cpp \
capi/GEOSCoordSeqTest.cpp \
- capi/GEOSSimplifyTest.cpp
+ capi/GEOSSimplifyTest.cpp \
+ capi/GEOSPolygonizer_getCutEdgesTest.cpp
-noinst_HEADERS = \
+noinst_HEADERS = \
utility.h
Added: trunk/tests/unit/capi/GEOSPolygonizer_getCutEdgesTest.cpp
--- trunk/tests/unit/capi/GEOSPolygonizer_getCutEdgesTest.cpp (rev 0)
+++ trunk/tests/unit/capi/GEOSPolygonizer_getCutEdgesTest.cpp 2008-07-31 17:01:15 UTC (rev 2144)
@@ -0,0 +1,107 @@
+// $Id$
+// Test Suite for C-API GEOSPolygonizeGetCutEdges
+// TUT
+#include <tut.h>
+// GEOS CAPI
+#include <geos_c.h>
+// C+
+#include <cstdarg>
+#include <cstdio>
+#include <cstdlib>
+#include <memory>
+namespace tut
+ // Test Group
+ // Common data used in test cases.
+ struct test_capigeospolygonizegetcutedges_data
+ static void notice(const char *fmt, ...)
+ std::fprintf( stdout, "NOTICE: ");
+ va_list ap;
+ va_start(ap, fmt);
+ std::vfprintf(stdout, fmt, ap);
+ va_end(ap);
+ std::fprintf(stdout, "\n");
+ test_capigeospolygonizegetcutedges_data()
+ initGEOS(notice, notice);
+ ~test_capigeospolygonizegetcutedges_data()
+ finishGEOS();
+ typedef test_group<test_capigeospolygonizegetcutedges_data> group;
+ typedef group::object object;
+ group test_capigeospolygonizegetcutedges_group("capi::GEOSPolygonizeGetCutEdges");
+ // Test Cases
+ template<>
+ template<>
+ void object::test<1>()
+ const int size = 2;
+ GEOSGeometry* geoms[size] = { 0 };
+ geoms[0] = GEOSGeomFromWKT("LINESTRING(1 3, 3 3, 3 1, 1 1, 1 3)");
+ geoms[1] = GEOSGeomFromWKT("LINESTRING(1 3, 3 3, 3 1, 1 1, 1 3)");
+ GEOSGeometry* g = GEOSPolygonizer_getCutEdges(geoms, size);
+ ensure(0 != g);
+ ensure_equals(GEOSGetNumGeometries(g), size);
+ GEOSGeom_destroy(g);
+ GEOSGeom_destroy(geoms[0]);
+ GEOSGeom_destroy(geoms[1]);
+ template<>
+ template<>
+ void object::test<2>()
+ const int size = 6;
+ // Example from JTS Developer's Guide, Chapter 6 - Polygonization
+ geoms[0] = GEOSGeomFromWKT("LINESTRING(0 0, 10 10)"); // isolated edge
+ geoms[1] = GEOSGeomFromWKT("LINESTRING(185 221, 100 100)"); // dangling edge
+ geoms[2] = GEOSGeomFromWKT("LINESTRING(185 221, 88 275, 180 316)");
+ geoms[3] = GEOSGeomFromWKT("LINESTRING(185 221, 292 281, 180 316)");
+ geoms[4] = GEOSGeomFromWKT("LINESTRING(189 98, 83 187, 185 221)");
+ geoms[5] = GEOSGeomFromWKT("LINESTRING(189 98, 325 168, 185 221)");
+ ensure(0 != g);
+ ensure_equals(GEOSGetNumGeometries(g), 0);
+ for (int i = 0; i < size; ++i)
+ if (0 != geoms[i])
+ GEOSGeom_destroy(geoms[i]);
+} // namespace tut
More information about the geos-commits
