[geos-commits] r2221 - trunk/source
svn_geos at osgeo.org
Mon Nov 17 22:09:56 EST 2008
Author: pramsey
Date: 2008-11-17 22:09:56 -0500 (Mon, 17 Nov 2008)
New Revision: 2221
trunk/source/inlines.cpp
Cygwin build fix from MCA
Modified: trunk/source/inlines.cpp
--- trunk/source/inlines.cpp 2008-11-11 17:32:38 UTC (rev 2220)
+++ trunk/source/inlines.cpp 2008-11-18 03:09:56 UTC (rev 2221)
@@ -23,13 +23,18 @@
// Otherwise we'll end up with duplicated symbols
#ifdef GEOS_INLINE
-// If using MingW or Cygwin with GEOS_INLINE to build a DLL then Win32 gcc
+// If using MingW with GEOS_INLINE to build a DLL then MingW's gcc
// has already generated the stubs for the contents of this file.
// Hence we need to supress it to avoid "multiple definition" errors
// during the final link phase
-#if !(defined(__GNUC__) && defined(_WIN32)) || defined(__GNUC__) && defined(_WIN32) && !defined(DLL_EXPORT)
+#if ! defined(__MINGW32__) || defined(__MINGW32__) && !defined(DLL_EXPORT)
+// If using cygwin then we suppress the "multiple definition" errors by
+// ignoring this section completely; the cygwin linker seems to handle
+// the stubs correctly at link time by itself
+#if ! defined(__CYGWIN__)
// Undefine GEOS_INLINE so that .inl files
// will be ready for an implementation file
#undef GEOS_INLINE
@@ -57,7 +62,7 @@
#include <geos/noding/snapround/MCIndexSnapRounder.inl>
#include <geos/noding/MCIndexNoder.inl>
+#endif // defined __CYGWIN__
#endif // defined __MINGW32__ and !defined DLL_EXPORT
#endif // defined GEOS_INLINE
More information about the geos-commits
