[geos-commits] r2313 - trunk/source/headers/geos/noding
svn_geos at osgeo.org
Tue Apr 7 05:55:46 EDT 2009
Author: strk
Date: 2009-04-07 05:55:45 -0400 (Tue, 07 Apr 2009)
New Revision: 2313
trunk/source/headers/geos/noding/SegmentStringUtil.h
Update port info, minor tweaks to doxygen comments
Modified: trunk/source/headers/geos/noding/SegmentStringUtil.h
--- trunk/source/headers/geos/noding/SegmentStringUtil.h 2009-04-07 08:14:25 UTC (rev 2312)
+++ trunk/source/headers/geos/noding/SegmentStringUtil.h 2009-04-07 09:55:45 UTC (rev 2313)
@@ -12,6 +12,10 @@
* See the COPYING file for more information.
+ * Last port: noding/SegmentStringUtil.java rev. 1.2 (JTS-1.9)
#ifndef GEOS_NODING_SEGMENTSTRINGUTIL_H
@@ -33,29 +37,34 @@
class SegmentStringUtil
-private:
-protected:
public:
+ /** \brief
* Extracts all linear components from a given {@link Geometry}
* to {@link SegmentString}s.
* The SegmentString data item is set to be the source Geometry.
* @param geom the geometry to extract from
- * @return a List of SegmentStrings
+ * @param segStr a List of SegmentStrings (output parameter).
+ * Ownership of elements pushed to the vector
+ * is transferred to caller.
- static void extractSegmentStrings( const geom::Geometry * g, SegmentString::ConstVect & segStr)
+ static void extractSegmentStrings(const geom::Geometry * g,
+ SegmentString::ConstVect& segStr)
geom::LineString::ConstVect lines;
- geom::util::LinearComponentExtracter::getLines( *g, lines);
+ geom::util::LinearComponentExtracter::getLines(*g, lines);
for (size_t i=0, n=lines.size(); i<n; i++)
- geom::LineString * line = (geom::LineString *)(lines[i]);
+ geom::LineString* line = (geom::LineString*)(lines[i]);
- geom::CoordinateSequence * pts = line->getCoordinates();
+ // we take ownership of the coordinates here
+ // TODO: check if this can be optimized by getting
+ // the internal CS.
+ geom::CoordinateSequence* pts = line->getCoordinates();
- segStr.push_back( new NodedSegmentString( pts, g));
+ segStr.push_back(new NodedSegmentString(pts, g));
More information about the geos-commits
