[geos-commits] r2315 - trunk/source/headers/geos/operation/valid
    svn_geos at osgeo.org
    Tue Apr  7 06:18:59 EDT 2009
Author: strk
Date: 2009-04-07 06:18:59 -0400 (Tue, 07 Apr 2009)
New Revision: 2315
   trunk/source/headers/geos/operation/valid/IsValidOp.h
Port info, indenting
Modified: trunk/source/headers/geos/operation/valid/IsValidOp.h
--- trunk/source/headers/geos/operation/valid/IsValidOp.h	2009-04-07 09:56:43 UTC (rev 2314)
+++ trunk/source/headers/geos/operation/valid/IsValidOp.h	2009-04-07 10:18:59 UTC (rev 2315)
@@ -12,6 +12,10 @@
  * by the Free Software Foundation.
  * See the COPYING file for more information.
+ * Last port: operation/valid/IsValidOp.java rev. 1.41 (JTS-1.9)
 #ifndef GEOS_OP_ISVALIDOP_H
@@ -49,16 +53,20 @@
 namespace valid { // geos::operation::valid
 /** \brief
- * Implements the algorithsm required to compute the <code>isValid()</code> method
- * for {@link Geometry}s.
+ * Implements the algorithsm required to compute the <code>isValid()</code>
+ * method for {@link Geometry}s.
 class IsValidOp {
 friend class Unload;
 private:
-	const geom::Geometry *parentGeometry;  // the base Geometry to be validated
+	/// the base Geometry to be validated
+	const geom::Geometry *parentGeometry;
 	bool isChecked;
-	TopologyValidationError* validErr; // CHECKME: should this really be a pointer ?
+	// CHECKME: should this really be a pointer ?
+	TopologyValidationError* validErr;
 	void checkValid(const geom::Geometry *g);
 	void checkValid(const geom::Point *g);
 	void checkValid(const geom::LinearRing *g);
@@ -187,7 +195,8 @@
 	static const geom::Coordinate *findPtNotNode(
 			const geom::CoordinateSequence *testCoords,
-			const geom::LinearRing *searchRing, geomgraph::GeometryGraph *graph);
+			const geom::LinearRing *searchRing,
+			geomgraph::GeometryGraph *graph);
 	 * Checks whether a coordinate is valid for processing.
More information about the geos-commits
