[geos-commits] r2326 - in trunk/source:
headers/geos/noding/snapround noding/snapround
svn_geos at osgeo.org
Wed Apr 8 09:16:37 EDT 2009
Author: strk
Date: 2009-04-08 09:16:37 -0400 (Wed, 08 Apr 2009)
New Revision: 2326
trunk/source/headers/geos/noding/snapround/SimpleSnapRounder.h
trunk/source/noding/snapround/SimpleSnapRounder.cpp
Complete porting of SimpleSnapRounder (refactoring for adding snapped nodes)
Modified: trunk/source/headers/geos/noding/snapround/SimpleSnapRounder.h
--- trunk/source/headers/geos/noding/snapround/SimpleSnapRounder.h 2009-04-08 13:02:06 UTC (rev 2325)
+++ trunk/source/headers/geos/noding/snapround/SimpleSnapRounder.h 2009-04-08 13:16:37 UTC (rev 2326)
@@ -125,19 +125,6 @@
void add(const SegmentString* segStr);
- * Adds a new node (equal to the snap pt) to the segment if the segment
- * passes through the hot pixel.
- * @param hotPix
- * @param segStr
- * @param segIndex
- * @return <code>true</code> if a node was added
- static bool addSnappedNode(const HotPixel& hotPix,
- NodedSegmentString& segStr,
- unsigned int segIndex);
* Computes nodes introduced as a result of
* snapping segments to vertices of other segments
Modified: trunk/source/noding/snapround/SimpleSnapRounder.cpp
--- trunk/source/noding/snapround/SimpleSnapRounder.cpp 2009-04-08 13:02:06 UTC (rev 2325)
+++ trunk/source/noding/snapround/SimpleSnapRounder.cpp 2009-04-08 13:16:37 UTC (rev 2326)
@@ -117,30 +117,11 @@
const Coordinate& snapPt = *it;
HotPixel hotPixel(snapPt, scaleFactor, li);
for (int i=0, n=ss->size()-1; i<n; ++i) {
- addSnappedNode(hotPixel, *ss, i);
+ hotPixel.addSnappedNode(*ss, i);
-/* public static */
-bool
-SimpleSnapRounder::addSnappedNode(const HotPixel& hotPix,
- NodedSegmentString& segStr, unsigned int segIndex)
- const Coordinate& p0 = segStr.getCoordinate(segIndex);
- const Coordinate& p1 = segStr.getCoordinate(segIndex + 1);
- if (hotPix.intersects(p0, p1)) {
- //cerr<<"snapped: "<<snapPt<<endl;
- //cerr<<"POINT ("<<snapPt.x<<" "<<snapPt.y<<")"<<endl;
- segStr.addIntersection(hotPix.getCoordinate(), segIndex);
- return true;
- return false;
/*private*/
void
SimpleSnapRounder::computeVertexSnaps(NodedSegmentString* e0, NodedSegmentString* e1)
@@ -160,7 +141,7 @@
continue;
//cerr<<"trying "<<p0<<" against "<<pts1->getAt(i1)<<" "<<pts1->getAt(i1 + 1)<<endl;
- bool isNodeAdded = addSnappedNode(hotPixel, *e1, i1);
+ bool isNodeAdded = hotPixel.addSnappedNode(*e1, i1);
// if a node is created for a vertex, that vertex must be noded too
if (isNodeAdded) {
e0->addIntersection(p0, i0);
More information about the geos-commits
