[geos-commits] r2341 - in trunk/source:
headers/geos/operation/buffer operation/buffer
svn_geos at osgeo.org
Thu Apr 9 07:45:57 EDT 2009
Author: strk
Date: 2009-04-09 07:45:57 -0400 (Thu, 09 Apr 2009)
New Revision: 2341
trunk/source/headers/geos/operation/buffer/BufferBuilder.h
trunk/source/headers/geos/operation/buffer/BufferOp.h
trunk/source/headers/geos/operation/buffer/OffsetCurveBuilder.h
trunk/source/operation/buffer/BufferBuilder.cpp
trunk/source/operation/buffer/BufferOp.cpp
trunk/source/operation/buffer/OffsetCurveBuilder.cpp
Sync BufferBuilder and BufferOp classes to JTS-1.9. Adapt OffsetCurveBuilder to use of BufferParameter (needs more work for JTS-sync).
Modified: trunk/source/headers/geos/operation/buffer/BufferBuilder.h
--- trunk/source/headers/geos/operation/buffer/BufferBuilder.h 2009-04-09 10:21:50 UTC (rev 2340)
+++ trunk/source/headers/geos/operation/buffer/BufferBuilder.h 2009-04-09 11:45:57 UTC (rev 2341)
@@ -11,6 +11,10 @@
* by the Free Software Foundation.
* See the COPYING file for more information.
+ * Last port: operation/buffer/BufferBuilder.java rev. 1.30 (JTS-1.9)
#ifndef GEOS_OP_BUFFER_BUFFERBUILDER_H
@@ -84,10 +88,8 @@
static int depthDelta(geomgraph::Label *label);
- int quadrantSegments;
+ const BufferParameters& bufParams;
- int endCapStyle;
const geom::PrecisionModel* workingPrecisionModel;
algorithm::LineIntersector* li;
@@ -115,7 +117,7 @@
* The function takes responsability of releasing the Edge parameter
* memory when appropriate.
- void insertEdge(geomgraph::Edge *e);
+ void insertUniqueEdge(geomgraph::Edge *e);
void createSubgraphs(geomgraph::PlanarGraph *graph,
std::vector<BufferSubgraph*>& list);
@@ -156,11 +158,16 @@
public:
* Creates a new BufferBuilder
+ * @param nBufParams buffer parameters, this object will
+ * keep a reference to the passed parameters
+ * so caller must make sure the object is
+ * kept alive for the whole lifetime of
+ * the buffer builder.
- BufferBuilder()
+ BufferBuilder(const BufferParameters& nBufParams)
- quadrantSegments(OffsetCurveBuilder::DEFAULT_QUADRANT_SEGMENTS),
- endCapStyle(BufferOp::CAP_ROUND),
+ bufParams(nBufParams),
workingPrecisionModel(NULL),
li(NULL),
intersectionAdder(NULL),
@@ -171,17 +178,7 @@
~BufferBuilder();
- * Sets the number of segments used to approximate a angle fillet
- * @param quadrantSegments the number of segments in a fillet for
- * a quadrant
- void setQuadrantSegments(int nQuadrantSegments) {
- quadrantSegments=nQuadrantSegments;
* Sets the precision model to use during the curve computation
* and noding,
@@ -205,10 +202,6 @@
void setNoder(noding::Noder* newNoder) { workingNoder = newNoder; }
- void setEndCapStyle(int nEndCapStyle) {
- endCapStyle=nEndCapStyle;
geom::Geometry* buffer(const geom::Geometry *g, double distance);
// throw (GEOSException);
Modified: trunk/source/headers/geos/operation/buffer/BufferOp.h
--- trunk/source/headers/geos/operation/buffer/BufferOp.h 2009-04-09 10:21:50 UTC (rev 2340)
+++ trunk/source/headers/geos/operation/buffer/BufferOp.h 2009-04-09 11:45:57 UTC (rev 2341)
@@ -4,19 +4,26 @@
* GEOS - Geometry Engine Open Source
* http://geos.refractions.net
- * Copyright (C) 2006 Refractions Research Inc.
+ * Copyright (C) 2009 Sandro Santilli <strk at keybit.net>
+ * Copyright (C) 2005-2007 Refractions Research Inc.
+ * Copyright (C) 2001-2002 Vivid Solutions Inc.
* This is free software; you can redistribute and/or modify it under
* the terms of the GNU Lesser General Public Licence as published
+ * Last port: operation/buffer/BufferOp.java rev. 1.43 (JTS-1.9)
#ifndef GEOS_OP_BUFFER_BUFFEROP_H
#define GEOS_OP_BUFFER_BUFFEROP_H
-#include <geos/operation/buffer/OffsetCurveBuilder.h> // for enum values
+//#include <geos/operation/buffer/OffsetCurveBuilder.h> // for enum values
+#include <geos/operation/buffer/BufferParameters.h> // for enum values
#include <geos/util/TopologyException.h> // for composition
// Forward declarations
@@ -60,8 +67,6 @@
* - CAP_SQUARE - end caps are squared off at the buffer distance
* beyond the line ends
- * Last port: operation/buffer/BufferOp.java rev. 1.31 (JTS-1.7)
class BufferOp {
@@ -101,10 +106,10 @@
double distance;
+ //int quadrantSegments;
+ //int endCapStyle;
+ BufferParameters bufParams;
- int endCapStyle;
geom::Geometry* resultGeometry;
void computeGeometry();
@@ -121,11 +126,16 @@
enum {
/// Specifies a round line buffer end cap style.
- CAP_ROUND,
+ /// @deprecated use BufferParameters
+ CAP_ROUND = BufferParameters::CAP_ROUND,
/// Specifies a butt (or flat) line buffer end cap style.
- CAP_BUTT,
+ CAP_BUTT = BufferParameters::CAP_FLAT,
/// Specifies a square line buffer end cap style.
- CAP_SQUARE
+ CAP_SQUARE = BufferParameters::CAP_FLAT
@@ -142,8 +152,8 @@
static geom::Geometry* bufferOp(const geom::Geometry *g,
double distance,
int quadrantSegments=
- OffsetCurveBuilder::DEFAULT_QUADRANT_SEGMENTS,
- int endCapStyle=BufferOp::CAP_ROUND);
+ BufferParameters::DEFAULT_QUADRANT_SEGMENTS,
+ int endCapStyle=BufferParameters::CAP_ROUND);
* Initializes a buffer computation for the given geometry
@@ -153,12 +163,29 @@
BufferOp(const geom::Geometry *g)
argGeom(g),
+ bufParams(),
resultGeometry(NULL)
+ * Initializes a buffer computation for the given geometry
+ * with the given set of parameters
+ * @param g the geometry to buffer
+ * @param params the buffer parameters to use. This class will
+ * copy it to private memory.
+ BufferOp(const geom::Geometry* g, const BufferParameters& params)
+ argGeom(g),
+ bufParams(params),
+ resultGeometry(NULL)
* Specifies the end cap style of the generated buffer.
* The styles supported are CAP_ROUND, CAP_BUTT, and CAP_SQUARE.
* The default is CAP_ROUND.
@@ -186,26 +213,22 @@
geom::Geometry* getResultGeometry(double nDistance);
- * Comutes the buffer for a geometry for a given buffer distance
- * and accuracy of approximation.
- * @param g the geometry to buffer
- * @param distance the buffer distance
- * @param quadrantSegments the number of segments used to
- * approximate a quarter circle
- * @return the buffer of the input geometry
- * @deprecated use setQuadrantSegments instead
- geom::Geometry* getResultGeometry(double nDistance, int nQuadrantSegments);
// BufferOp inlines
-void BufferOp::setQuadrantSegments(int q) { quadrantSegments=q; }
-void BufferOp::setEndCapStyle(int s) { endCapStyle=s; }
+void
+BufferOp::setQuadrantSegments(int q)
+ bufParams.setQuadrantSegments(q);
+void
+BufferOp::setEndCapStyle(int s)
+ bufParams.setEndCapStyle((BufferParameters::EndCapStyle)s);
} // namespace geos::operation::buffer
} // namespace geos
Modified: trunk/source/headers/geos/operation/buffer/OffsetCurveBuilder.h
--- trunk/source/headers/geos/operation/buffer/OffsetCurveBuilder.h 2009-04-09 10:21:50 UTC (rev 2340)
+++ trunk/source/headers/geos/operation/buffer/OffsetCurveBuilder.h 2009-04-09 11:45:57 UTC (rev 2341)
@@ -25,6 +25,7 @@
#include <geos/algorithm/LineIntersector.h> // for composition
#include <geos/geom/Coordinate.h> // for composition
#include <geos/geom/LineSegment.h> // for composition
+#include <geos/operation/buffer/BufferParameters.h> // for composition
namespace geos {
@@ -70,13 +71,18 @@
static const int DEFAULT_QUADRANT_SEGMENTS=8;
OffsetCurveBuilder(const geom::PrecisionModel *newPrecisionModel,
- int quadrantSegments=DEFAULT_QUADRANT_SEGMENTS);
+ const BufferParameters& bufParams);
~OffsetCurveBuilder();
- void setEndCapStyle(int newEndCapStyle);
* This method handles single points as well as lines.
* Lines are assumed to <b>not</b> be closed (the function will not
@@ -135,10 +141,8 @@
const geom::PrecisionModel* precisionModel;
- int endCapStyle;
- //int joinStyle;
geom::Coordinate s0, s1, s2;
geom::LineSegment seg0;
@@ -215,12 +219,6 @@
std::vector<OffsetCurveVertexList*> vertexLists;
-// INLINES
-inline void OffsetCurveBuilder::setEndCapStyle(int newEndCapStyle) {
- endCapStyle=newEndCapStyle;
} // namespace geos
Modified: trunk/source/operation/buffer/BufferBuilder.cpp
--- trunk/source/operation/buffer/BufferBuilder.cpp 2009-04-09 10:21:50 UTC (rev 2340)
+++ trunk/source/operation/buffer/BufferBuilder.cpp 2009-04-09 11:45:57 UTC (rev 2341)
@@ -14,7 +14,7 @@
- * Last port: operation/buffer/BufferBuilder.java rev. 1.23 (JTS-1.7)
@@ -113,8 +113,7 @@
// factory must be the same as the one used by the input
geomFact=g->getFactory();
- OffsetCurveBuilder curveBuilder(precisionModel, quadrantSegments);
- curveBuilder.setEndCapStyle(endCapStyle);
+ OffsetCurveBuilder curveBuilder(precisionModel, bufParams);
OffsetCurveSetBuilder curveSetBuilder(*g, distance, curveBuilder);
std::vector<SegmentString*>& bufferSegStrList=curveSetBuilder.getCurves();
@@ -284,7 +283,7 @@
Edge* edge = new Edge(cs, new Label(*oldLabel));
// will take care of the Edge ownership
- insertEdge(edge);
+ insertUniqueEdge(edge);
if ( nodedSegStrings != &bufferSegStrList )
@@ -297,7 +296,7 @@
/*private*/
void
-BufferBuilder::insertEdge(Edge *e)
+BufferBuilder::insertUniqueEdge(Edge *e)
//<FIX> MD 8 Oct 03 speed up identical edge lookup
// fast lookup
Modified: trunk/source/operation/buffer/BufferOp.cpp
--- trunk/source/operation/buffer/BufferOp.cpp 2009-04-09 10:21:50 UTC (rev 2340)
+++ trunk/source/operation/buffer/BufferOp.cpp 2009-04-09 11:45:57 UTC (rev 2341)
@@ -4,6 +4,7 @@
@@ -14,7 +15,7 @@
- * Last port: operation/buffer/BufferOp.java rev. 1.35 (JTS-1.7)
@@ -98,16 +99,6 @@
return resultGeometry;
-/*public*/
-Geometry*
-BufferOp::getResultGeometry(double nDistance, int nQuadrantSegments)
- distance=nDistance;
- setQuadrantSegments(nQuadrantSegments);
- computeGeometry();
- return resultGeometry;
/*private*/
void
BufferOp::computeGeometry()
@@ -163,9 +154,7 @@
void
BufferOp::bufferOriginalPrecision()
- BufferBuilder bufBuilder;
- bufBuilder.setQuadrantSegments(quadrantSegments);
- bufBuilder.setEndCapStyle(endCapStyle);
+ BufferBuilder bufBuilder(bufParams);
//std::cerr<<"computing with original precision"<<std::endl;
try
@@ -221,14 +210,11 @@
ScaledNoder noder(inoder, fixedPM.getScale());
bufBuilder.setWorkingPrecisionModel(&fixedPM);
bufBuilder.setNoder(&noder);
// this may throw an exception, if robustness errors are encountered
resultGeometry=bufBuilder.buffer(argGeom, distance);
Modified: trunk/source/operation/buffer/OffsetCurveBuilder.cpp
--- trunk/source/operation/buffer/OffsetCurveBuilder.cpp 2009-04-09 10:21:50 UTC (rev 2340)
+++ trunk/source/operation/buffer/OffsetCurveBuilder.cpp 2009-04-09 11:45:57 UTC (rev 2341)
@@ -25,6 +25,7 @@
#include <geos/algorithm/CGAlgorithms.h>
#include <geos/operation/buffer/BufferOp.h>
#include <geos/geomgraph/Position.h>
#include <geos/geom/CoordinateArraySequence.h>
#include <geos/geom/CoordinateSequence.h>
@@ -53,14 +54,14 @@
/*public*/
OffsetCurveBuilder::OffsetCurveBuilder(const PrecisionModel *newPrecisionModel,
- int quadrantSegments)
+ const BufferParameters& nBufParams)
li(),
maxCurveSegmentError(0.0),
vertexList(new OffsetCurveVertexList()),
distance(0.0),
precisionModel(newPrecisionModel),
s0(),
s1(),
s2(),
@@ -71,8 +72,7 @@
side(0),
vertexLists()
- int limitedQuadSegs=quadrantSegments<1 ? 1 : quadrantSegments;
- filletAngleQuantum=PI / 2.0 / limitedQuadSegs;
+ filletAngleQuantum=PI / 2.0 / bufParams.getQuadrantSegments();
/*public*/
@@ -94,14 +94,17 @@
init(distance);
if (inputPts->getSize() < 2) {
- switch (endCapStyle) {
- case BufferOp::CAP_ROUND:
+ switch (bufParams.getEndCapStyle()) {
+ case BufferParameters::CAP_ROUND:
addCircle(inputPts->getAt(0), distance);
break;
- case BufferOp::CAP_SQUARE:
+ case BufferParameters::CAP_SQUARE:
addSquare(inputPts->getAt(0), distance);
break;
- // default is for buffer to be empty (e.g. for a butt line cap);
+ default:
+ // default is for buffer to be empty
+ // (e.g. for a butt line cap);
+ break;
} else {
computeLineBufferCurve(*inputPts);
@@ -325,19 +328,19 @@
double dx=p1.x-p0.x;
double dy=p1.y-p0.y;
double angle=atan2(dy, dx);
// add offset seg points with a fillet between them
vertexList->addPt(offsetL.p1);
addFillet(p1, angle+PI/2.0, angle-PI/2.0, CGAlgorithms::CLOCKWISE, distance);
vertexList->addPt(offsetR.p1);
break;
- case BufferOp::CAP_BUTT:
+ case BufferParameters::CAP_FLAT:
// only offset segment points are added
break;
// add a square defined by extensions of the offset segment endpoints
Coordinate squareCapSideOffset;
squareCapSideOffset.x=fabs(distance)*cos(angle);
More information about the geos-commits
