[geos-commits] r2349 - in trunk/source:
headers/geos/operation/buffer operation/buffer
svn_geos at osgeo.org
Tue Apr 14 05:14:35 EDT 2009
Author: strk
Date: 2009-04-14 05:14:35 -0400 (Tue, 14 Apr 2009)
New Revision: 2349
trunk/source/headers/geos/operation/buffer/BufferSubgraph.h
trunk/source/operation/buffer/BufferSubgraph.cpp
Sync BufferSubgraph to JTS-1.9
Modified: trunk/source/headers/geos/operation/buffer/BufferSubgraph.h
--- trunk/source/headers/geos/operation/buffer/BufferSubgraph.h 2009-04-14 08:52:30 UTC (rev 2348)
+++ trunk/source/headers/geos/operation/buffer/BufferSubgraph.h 2009-04-14 09:14:35 UTC (rev 2349)
@@ -11,6 +11,10 @@
* by the Free Software Foundation.
* See the COPYING file for more information.
+ * Last port: operation/buffer/BufferSubgraph.java rev. 1.21 (JTS-1.9)
#ifndef GEOS_OP_BUFFER_BUFFERSUBGRAPH_H
@@ -41,7 +45,8 @@
namespace buffer { // geos.operation.buffer
- * \brief A connected subset of the graph of DirectedEdges and geomgraph::Node.
+ * \brief
+ * A connected subset of the graph of DirectedEdge and geomgraph::Node.
* Its edges will generate either
* - a single polygon in the complete buffer, with zero or more holes, or
@@ -96,11 +101,7 @@
friend std::ostream& operator<< (std::ostream& os, const BufferSubgraph& bs);
- /** \brief
- * algorithm::CGAlgorithms arg kept for backward-compatibility.
- * It is unused.
- BufferSubgraph(algorithm::CGAlgorithms *cga=NULL);
+ BufferSubgraph();
~BufferSubgraph();
Modified: trunk/source/operation/buffer/BufferSubgraph.cpp
--- trunk/source/operation/buffer/BufferSubgraph.cpp 2009-04-14 08:52:30 UTC (rev 2348)
+++ trunk/source/operation/buffer/BufferSubgraph.cpp 2009-04-14 09:14:35 UTC (rev 2349)
@@ -4,8 +4,8 @@
* GEOS - Geometry Engine Open Source
* http://geos.refractions.net
+ * Copyright (C) 2005 Refractions Research Inc.
* Copyright (C) 2001-2002 Vivid Solutions Inc.
- * Copyright (C) 2005 Refractions Research Inc.
* This is free software; you can redistribute and/or modify it under
* the terms of the GNU Lesser General Public Licence as published
@@ -14,7 +14,7 @@
- * Last port: operation/buffer/BufferSubgraph.java rev. 1.17
@@ -49,7 +49,11 @@
// Argument is unused
-BufferSubgraph::BufferSubgraph(CGAlgorithms* /*cga*/):
+BufferSubgraph::BufferSubgraph()
+ finder(),
+ dirEdgeList(),
+ nodes(),
rightMostCoord(NULL),
env(NULL)
@@ -171,11 +175,12 @@
// MD - testing Result: breaks algorithm
//if (startEdge==null) return;
- //assert(startEdge!=NULL);
- if (startEdge==NULL)
+ // only compute string append if assertion would fail
+ if (startEdge == NULL)
throw util::TopologyException(
- "unable to find edge to compute depths",
+ "unable to find edge to compute depths at",
n->getCoordinate());
More information about the geos-commits
