[geos-commits] r2352 - trunk/tests/xmltester
svn_geos at osgeo.org
Tue Apr 14 05:54:01 EDT 2009
Author: strk
Date: 2009-04-14 05:53:59 -0400 (Tue, 14 Apr 2009)
New Revision: 2352
Added:
trunk/tests/xmltester/TestBuffer.xml
trunk/tests/xmltester/TestBufferExternal2.xml
trunk/tests/xmltester/Makefile.am
trunk/tests/xmltester/TestBufferExternal.xml
trunk/tests/xmltester/XMLTester.cpp
trunk/tests/xmltester/badguy3.xml
trunk/tests/xmltester/buffer.xml
trunk/tests/xmltester/buffer_snapround.xml
trunk/tests/xmltester/fme.xml
trunk/tests/xmltester/testLeaksBig.xml
Fix XML for Buffer testing to match jts layout (arg2 for distance, arg3 for quadrant segments); copy buffer-related tests from jts: they succeed w/out editing.
Modified: trunk/tests/xmltester/Makefile.am
--- trunk/tests/xmltester/Makefile.am 2009-04-14 09:22:22 UTC (rev 2351)
+++ trunk/tests/xmltester/Makefile.am 2009-04-14 09:53:59 UTC (rev 2352)
@@ -8,7 +8,7 @@
EXTRA_DIST = testrunner.sh
-SAFE_XMLTESTS=$(srcdir)/testLeaksBig.xml $(srcdir)/hexwkb.xml $(srcdir)/test.xml $(srcdir)/linemerge.xml $(srcdir)/TestInteriorPoint.xml $(srcdir)/TestCentroid.xml $(srcdir)/TestIsValid.xml $(srcdir)/TestValid.xml $(srcdir)/TestValid2.xml $(srcdir)/TestValid2-big.xml $(srcdir)/robustness.xml $(srcdir)/stmlf-cases-20061020.xml $(srcdir)/TestRobustOverlayFixed.xml $(srcdir)/fme.xml $(srcdir)/TestBufferExternal.xml $(srcdir)/heisenbugs.xml $(srcdir)/stmlf-cases-20070119.xml $(srcdir)/badguy3.xml $(srcdir)/hole_from_shell.xml $(srcdir)/hole_red.xml
+SAFE_XMLTESTS=$(srcdir)/testLeaksBig.xml $(srcdir)/hexwkb.xml $(srcdir)/test.xml $(srcdir)/linemerge.xml $(srcdir)/TestInteriorPoint.xml $(srcdir)/TestCentroid.xml $(srcdir)/TestIsValid.xml $(srcdir)/TestValid.xml $(srcdir)/TestValid2.xml $(srcdir)/TestValid2-big.xml $(srcdir)/robustness.xml $(srcdir)/stmlf-cases-20061020.xml $(srcdir)/TestRobustOverlayFixed.xml $(srcdir)/fme.xml $(srcdir)/TestBuffer.xml $(srcdir)/TestBufferExternal.xml $(srcdir)/TestBufferExternal2.xml $(srcdir)/heisenbugs.xml $(srcdir)/stmlf-cases-20070119.xml $(srcdir)/badguy3.xml $(srcdir)/hole_from_shell.xml $(srcdir)/hole_red.xml
XMLTESTS=$(SAFE_XMLTESTS)
@@ -39,7 +39,7 @@
test: XMLTester
./XMLTester $(XMLTESTS)
-testrunner: testrunner.sh
+testrunner: testrunner.sh Makefile
sh $(srcdir)/testrunner.sh $@ $(SAFE_XMLTESTS)
verbose-test: XMLTester
Added: trunk/tests/xmltester/TestBuffer.xml
--- trunk/tests/xmltester/TestBuffer.xml (rev 0)
+++ trunk/tests/xmltester/TestBuffer.xml 2009-04-14 09:53:59 UTC (rev 2352)
@@ -0,0 +1,119 @@
+<run>
+ <desc>
+ Basic buffer test cases.
+ </desc>
+ <precisionModel type="FLOATING" />
+ <resultMatcher>com.vividsolutions.jtstest.testrunner.BufferResultMatcher</resultMatcher>
+<case>
+ <desc>
+ Point
+ </desc>
+ <a>
+ POINT (100 100)
+ </a>
+<test><op name='buffer' arg1='A' arg2='-1.0'> POLYGON EMPTY </op></test>
+<test><op name='buffer' arg1='A' arg2='0.0'> POLYGON EMPTY </op></test>
+<test><op name='buffer' arg1='A' arg2='10.0'>
+ POLYGON ((110 100, 109.80785280403231 98.04909677983872, 109.23879532511287 96.1731656763491, 108.31469612302546 94.44429766980397, 107.07106781186548 92.92893218813452, 105.55570233019603 91.68530387697454, 103.8268343236509 90.76120467488713, 101.95090322016128 90.19214719596769, 100 90, 98.04909677983872 90.19214719596769, 96.1731656763491 90.76120467488713, 94.44429766980397 91.68530387697454, 92.92893218813452 92.92893218813452, 91.68530387697454 94.44429766980397, 90.76120467488713 96.1731656763491, 90.19214719596769 98.04909677983872, 90 100.00000000000001, 90.19214719596769 101.9509032201613, 90.76120467488714 103.82683432365091, 91.68530387697456 105.55570233019603, 92.92893218813454 107.07106781186549, 94.44429766980399 108.31469612302547, 96.17316567634911 109.23879532511287, 98.04909677983873 109.80785280403231, 100.00000000000003 110, 101.95090322016131 109.8078528040323, 103.82683432365093 109.23879532511286, 105.55570233019606 108.31469612302544, 107.0710678118655 107.07106781186545, 108.31469612302547 105.555702330196, 109.23879532511287 103.82683432365086, 109.80785280403231 101.95090322016124, 110 100))
+ </op></test>
+</case>
+<case>
+ <desc>
+ Line
+ </desc>
+ <a>
+ LINESTRING (10 10, 100 100)
+ </a>
+ POLYGON ((92.92893218813452 107.07106781186548, 94.44429766980397 108.31469612302546, 96.1731656763491 109.23879532511287, 98.04909677983872 109.80785280403231, 100 110, 101.95090322016128 109.80785280403231, 103.8268343236509 109.23879532511287, 105.55570233019603 108.31469612302546, 107.07106781186548 107.07106781186548, 108.31469612302546 105.55570233019603, 109.23879532511287 103.8268343236509, 109.80785280403231 101.95090322016128, 110 100, 109.80785280403231 98.04909677983872, 109.23879532511286 96.1731656763491, 108.31469612302544 94.44429766980397, 107.07106781186548 92.92893218813452, 17.071067811865476 2.9289321881345254, 15.555702330196024 1.6853038769745474, 13.826834323650898 0.7612046748871322, 11.950903220161283 0.1921471959676957, 10 0, 8.049096779838719 0.1921471959676957, 6.173165676349103 0.7612046748871322, 4.44429766980398 1.6853038769745474, 2.9289321881345254 2.9289321881345245, 1.6853038769745474 4.444297669803978, 0.7612046748871322 6.173165676349101, 0.1921471959676957 8.049096779838713, 0 9.999999999999998, 0.1921471959676957 11.950903220161283, 0.761204674887134 13.8268343236509, 1.685303876974551 15.555702330196027, 2.9289321881345254 17.071067811865476, 92.92893218813452 107.07106781186548))
+ </op></test>
+</case>
+<case>
+ <desc>
+ Polygon
+ </desc>
+ <a>
+ POLYGON ((100 100, 100 200, 200 200, 200 100, 100 100))
+ </a>
+<test><op name='buffer' arg1='A' arg2='-100.0'> POLYGON EMPTY </op></test>
+<test><op name='buffer' arg1='A' arg2='-10.0'> POLYGON ((110 110, 110 190, 190 190, 190 110, 110 110)) </op></test>
+<test><op name='buffer' arg1='A' arg2='0.0'> POLYGON ((100 100, 100 200, 200 200, 200 100, 100 100)) </op></test>
+ POLYGON ((100 90, 98.04909677983872 90.19214719596769, 96.1731656763491 90.76120467488714, 94.44429766980397 91.68530387697454, 92.92893218813452 92.92893218813452, 91.68530387697454 94.44429766980397, 90.76120467488713 96.1731656763491, 90.19214719596769 98.04909677983872, 90 100, 90 200, 90.19214719596769 201.95090322016128, 90.76120467488713 203.8268343236509, 91.68530387697454 205.55570233019603, 92.92893218813452 207.07106781186548, 94.44429766980397 208.31469612302544, 96.1731656763491 209.23879532511287, 98.04909677983872 209.8078528040323, 100 210, 200 210, 201.95090322016128 209.8078528040323, 203.8268343236509 209.23879532511287, 205.55570233019603 208.31469612302544, 207.07106781186548 207.07106781186548, 208.31469612302544 205.55570233019603, 209.23879532511287 203.8268343236509, 209.8078528040323 201.95090322016128, 210 200, 210 100, 209.8078528040323 98.04909677983872, 209.23879532511287 96.1731656763491, 208.31469612302544 94.44429766980397, 207.07106781186548 92.92893218813452, 205.55570233019603 91.68530387697454, 203.8268343236509 90.76120467488713, 201.95090322016128 90.19214719596769, 200 90, 100 90))
+ </op></test>
+<test><op name='buffer' arg1='A' arg2='20.0'>
+ POLYGON ((100 80, 96.09819355967743 80.3842943919354, 92.3463313526982 81.52240934977428, 88.88859533960796 83.37060775394909, 85.85786437626905 85.85786437626905, 83.37060775394909 88.88859533960796, 81.52240934977426 92.3463313526982, 80.38429439193538 96.09819355967743, 80 100, 80 200, 80.38429439193538 203.90180644032256, 81.52240934977426 207.6536686473018, 83.37060775394909 211.11140466039205, 85.85786437626905 214.14213562373095, 88.88859533960796 216.6293922460509, 92.3463313526982 218.47759065022575, 96.09819355967744 219.61570560806462, 100 220, 200 220, 203.90180644032256 219.61570560806462, 207.6536686473018 218.47759065022575, 211.11140466039205 216.6293922460509, 214.14213562373095 214.14213562373095, 216.6293922460509 211.11140466039205, 218.47759065022575 207.6536686473018, 219.61570560806462 203.90180644032256, 220 200, 220 100, 219.61570560806462 96.09819355967744, 218.47759065022575 92.3463313526982, 216.6293922460509 88.88859533960796, 214.14213562373095 85.85786437626905, 211.11140466039205 83.37060775394909, 207.6536686473018 81.52240934977426, 203.90180644032256 80.38429439193538, 200 80, 100 80))
+ </op></test>
+<test><op name='buffer' arg1='A' arg2='100.0'>
+ POLYGON ((100 0, 80.49096779838713 1.921471959676964, 61.73165676349097 7.61204674887135, 44.442976698039786 16.85303876974548, 29.28932188134523 29.28932188134526, 16.853038769745453 44.44297669803981, 7.612046748871322 61.73165676349103, 1.9214719596769498 80.49096779838716, 0 100, 0 200, 1.9214719596769498 219.50903220161285, 7.612046748871322 238.268343236509, 16.853038769745467 255.55702330196021, 29.28932188134526 270.71067811865476, 44.44297669803981 283.14696123025453, 61.731656763491024 292.3879532511287, 80.49096779838717 298.078528040323, 100 300, 200 300, 219.50903220161283 298.078528040323, 238.268343236509 292.3879532511287, 255.55702330196021 283.14696123025453, 270.71067811865476 270.71067811865476, 283.14696123025453 255.55702330196021, 292.3879532511287 238.26834323650897, 298.078528040323 219.50903220161283, 300 200, 300 100, 298.078528040323 80.49096779838717, 292.3879532511287 61.731656763491024, 283.14696123025453 44.44297669803978, 270.71067811865476 29.289321881345245, 255.55702330196021 16.85303876974548, 238.268343236509 7.612046748871322, 219.50903220161283 1.9214719596769498, 200 0, 100 0))
+ </op></test>
+</case>
+<case>
+ <desc>
+ Polygon
+ </desc>
+ <a>
+ POLYGON ((80 300, 280 300, 280 80, 80 80, 80 300), (260 280, 180 200, 100 280, 100 100, 260 100, 260 280))
+ </a>
+ MULTIPOLYGON (((90 100, 90.19214719596769 98.04909677983872, 90.76120467488713 96.1731656763491, 91.68530387697454 94.44429766980397, 92.92893218813452 92.92893218813452, 94.44429766980397 91.68530387697454, 96.1731656763491 90.76120467488713, 98.04909677983872 90.19214719596769, 100 90, 90 90, 90 100)),
+ ((260 90, 261.9509032201613 90.19214719596769, 263.82683432365087 90.76120467488713, 265.555702330196 91.68530387697454, 267.0710678118655 92.92893218813452, 268.31469612302544 94.44429766980397, 269.23879532511285 96.1731656763491, 269.8078528040323 98.04909677983872, 270 100, 270 90, 260 90)),
+ ((270 280, 269.8078528040323 281.9509032201613, 269.23879532511285 283.82683432365087, 268.31469612302544 285.555702330196, 267.0710678118655 287.0710678118655, 265.555702330196 288.31469612302544, 263.82683432365087 289.23879532511285, 261.9509032201613 289.8078528040323, 260 290, 270 290, 270 280)),
+ ((260 290, 258.0490967798387 289.8078528040323, 256.17316567634913 289.23879532511285, 254.44429766980397 288.31469612302544, 252.92893218813452 287.0710678118655, 180 214.14213562373095, 107.07106781186548 287.0710678118655, 105.55570233019603 288.31469612302544, 103.8268343236509 289.23879532511285, 101.95090322016128 289.8078528040323, 100 290, 260 290)),
+ ((100 290, 98.04909677983872 289.8078528040323, 96.1731656763491 289.23879532511285, 94.44429766980397 288.31469612302544, 92.92893218813452 287.0710678118655, 91.68530387697454 285.555702330196, 90.76120467488713 283.82683432365087, 90.19214719596769 281.9509032201613, 90 280, 90 290, 100 290)))
+ </op></test>
+ (260 280, 180 200, 100 280, 100 100, 260 100, 260 280))
+ </op></test>
+ POLYGON ((70 300, 70.19214719596769 301.9509032201613, 70.76120467488713 303.82683432365087, 71.68530387697454 305.555702330196, 72.92893218813452 307.0710678118655, 74.44429766980397 308.31469612302544, 76.1731656763491 309.23879532511285, 78.04909677983872 309.8078528040323, 80 310, 280 310, 281.9509032201613 309.8078528040323, 283.82683432365087 309.23879532511285, 285.555702330196 308.31469612302544, 287.0710678118655 307.0710678118655, 288.31469612302544 305.555702330196, 289.23879532511285 303.82683432365087, 289.8078528040323 301.9509032201613, 290 300, 290 80, 289.8078528040323 78.04909677983872, 289.23879532511285 76.1731656763491, 288.31469612302544 74.44429766980397, 287.0710678118655 72.92893218813452, 285.555702330196 71.68530387697454, 283.82683432365087 70.76120467488713, 281.9509032201613 70.19214719596769, 280 70, 80 70, 78.04909677983872 70.19214719596769, 76.1731656763491 70.76120467488714, 74.44429766980397 71.68530387697454, 72.92893218813452 72.92893218813452, 71.68530387697454 74.44429766980397, 70.76120467488713 76.1731656763491, 70.19214719596769 78.04909677983872, 70 80, 70 300),
+ (250 255.85786437626905, 187.07106781186548 192.92893218813452, 185.55570233019603 191.68530387697456, 183.8268343236509 190.76120467488713, 181.95090322016128 190.1921471959677, 180 190, 178.04909677983872 190.1921471959677, 176.1731656763491 190.76120467488713, 174.44429766980397 191.68530387697456, 172.92893218813452 192.92893218813452, 110 255.85786437626905, 110 110, 250 110, 250 255.85786437626905))
+ </op></test>
+ POLYGON ((60 300, 60.38429439193539 303.90180644032256, 61.522409349774264 307.6536686473018, 63.370607753949095 311.11140466039205, 65.85786437626905 314.14213562373095, 68.88859533960796 316.6293922460509, 72.3463313526982 318.47759065022575, 76.09819355967744 319.6157056080646, 80 320, 280 320, 283.90180644032256 319.6157056080646, 287.6536686473018 318.47759065022575, 291.11140466039205 316.6293922460509, 294.14213562373095 314.14213562373095, 296.6293922460509 311.11140466039205, 298.47759065022575 307.6536686473018, 299.6157056080646 303.90180644032256, 300 300, 300 80, 299.6157056080646 76.09819355967744, 298.47759065022575 72.3463313526982, 296.6293922460509 68.88859533960796, 294.14213562373095 65.85786437626905, 291.11140466039205 63.370607753949095, 287.6536686473018 61.522409349774264, 283.90180644032256 60.38429439193539, 280 60, 80 60, 76.09819355967743 60.3842943919354, 72.3463313526982 61.52240934977427, 68.88859533960796 63.370607753949095, 65.85786437626905 65.85786437626905, 63.37060775394909 68.88859533960796, 61.522409349774264 72.3463313526982, 60.38429439193539 76.09819355967743, 60 80, 60 300),
+ (240 231.7157287525381, 194.14213562373095 185.85786437626905, 191.11140466039205 183.3706077539491, 187.6536686473018 181.52240934977425, 183.90180644032256 180.38429439193538, 180 180, 176.09819355967744 180.38429439193538, 172.3463313526982 181.52240934977425, 168.88859533960795 183.3706077539491, 165.85786437626905 185.85786437626905, 120 231.7157287525381, 120 120, 240 120, 240 231.7157287525381))
+ </op></test>
+ POLYGON ((-20 300, -18.07852804032305 319.50903220161285, -12.387953251128678 338.268343236509, -3.146961230254533 355.5570233019602, 9.28932188134526 370.71067811865476, 24.442976698039807 383.14696123025453, 41.731656763491024 392.3879532511287, 60.49096779838718 398.078528040323, 80 400, 280 400, 299.50903220161285 398.078528040323, 318.268343236509 392.3879532511287, 335.5570233019602 383.14696123025453, 350.71067811865476 370.71067811865476, 363.14696123025453 355.5570233019602, 372.3879532511287 338.268343236509, 378.078528040323 319.50903220161285, 380 300, 380 80, 378.078528040323 60.490967798387175, 372.3879532511287 41.731656763491024, 363.14696123025453 24.44297669803978, 350.71067811865476 9.289321881345245, 335.5570233019602 -3.1469612302545187, 318.268343236509 -12.387953251128678, 299.50903220161285 -18.07852804032305, 280 -20, 80 -20, 60.49096779838713 -18.078528040323036, 41.73165676349097 -12.38795325112865, 24.442976698039786 -3.1469612302545187, 9.28932188134523 9.28932188134526, -3.146961230254547 24.442976698039807, -12.387953251128678 41.73165676349103, -18.07852804032305 60.49096779838716, -20 80, -20 300))
+ </op></test>
+</case>
+<case>
+ <desc>
+ MultiLineString which caused failure for distance > 10 in ver 1.10
+ </desc>
+ <a>
+ MULTILINESTRING ((1335558.59524 631743.01449, 1335572.28215 631775.89056, 1335573.2578018496 631782.1915185435),
+ (1335573.2578018496 631782.1915185435, 1335576.62035 631803.90754),
+ (1335573.2578018496 631782.1915185435, 1335580.70187 631802.08139))
+ </a>
+POLYGON ((1335548.595256113 631743.032441783, 1335548.790905219 631744.982996921, 1335549.363329412 631746.857903442, 1335562.585102127 631778.616709872, 1335563.375568292 631783.721701512, 1335566.738116443 631805.437722968, 1335567.226524677 631807.336249059, 1335568.075932351 631809.103011783, 1335569.253697204 631810.67011544, 1335570.714558392 631811.977337115, 1335572.402375839 631812.974441013, 1335574.252287668 631813.62310899, 1335576.193202805 631813.898413099, 1335578.150532968 631813.789773558, 1335580.049059059 631813.301365323, 1335581.815821783 631812.451957649, 1335582.575762837 631811.880820023, 1335584.207062652 631811.446945214, 1335585.966840541 631810.583159534, 1335587.524288564 631809.392655618, 1335588.819554868 631807.921183865, 1335589.802863095 631806.225292108, 1335590.436425262 631804.370152517, 1335590.695893928 631802.427057067, 1335590.57129786 631800.470677824, 1335590.067425214 631798.576197348, 1335582.983023804 631779.64732263, 1335582.164383558 631774.360377032, 1335581.514060589 631772.047146558, 1335567.827150589 631739.171076558, 1335566.899949249 631737.44387026, 1335565.653602591 631735.930739755, 1335564.136007016 631734.689833799, 1335562.405482873 631733.768839712, 1335560.528533233 631733.203150781, 1335558.577288218 631733.014506113, 1335556.626733079 631733.210155219, 1335554.751826558 631733.782579411, 1335553.02462026 631734.709780751, 1335551.511489755 631735.956127409, 1335550.270583799 631737.473722984, 1335549.349589712 631739.204247127, 1335548.783900781 631741.081196768, 1335548.595256113 631743.032441783))
+ </op></test>
+<test><op name='buffer' arg1='A' arg2='15.0'>
+POLYGON ((1335543.59526417 631743.041417674, 1335543.888737828 631745.967250381, 1335544.747374117 631748.779610163, 1335557.736578191 631779.97978481, 1335558.434451514 631784.486792996, 1335561.796999664 631806.202814452, 1335562.529612016 631809.050603588, 1335563.803723527 631811.700747674, 1335565.570370805 631814.051403159, 1335567.761662587 631816.012235673, 1335570.293388759 631817.507891519, 1335573.068256502 631818.480893485, 1335575.979629207 631818.893849648, 1335578.915624452 631818.730890336, 1335581.763413588 631817.998277984, 1335584.413557674 631816.724166473, 1335584.790893177 631816.440578026, 1335585.959658978 631816.129722821, 1335588.599325811 631814.834044301, 1335590.935497846 631813.048288427, 1335592.878397303 631810.841080797, 1335594.353359643 631808.297243162, 1335595.303702892 631805.514533776, 1335595.692905893 631802.5998906, 1335595.50601179 631799.665321737, 1335594.750202821 631796.823601022, 1335587.845634781 631778.375224674, 1335587.105500336 631773.595285547, 1335586.130015883 631770.125439837, 1335572.443105883 631737.249369837, 1335571.052303874 631734.65856039, 1335569.182783886 631732.388864632, 1335566.906390525 631730.527505698, 1335564.310604309 631729.146014568, 1335561.495179849 631728.297481171, 1335558.568312326 631728.01451417, 1335555.642479619 631728.307987828, 1335552.830119837 631729.166624117, 1335550.23931039 631730.557426126, 1335547.969614632 631732.426946114, 1335546.108255698 631734.703339476, 1335544.726764568 631737.299125691, 1335543.878231171 631740.114550151, 1335543.59526417 631743.041417674))
+ </op></test>
+</case>
+<case>
+ <desc>
+ Degenerate polygon which caused error in ver 1.10
+ </desc>
+ <a>
+ POLYGON ((-69 -90, -69 -90, -69 -90, -69 -90, -69 -90, -69 -90, -69 -90, -69 -90, -69 -90, -69 -90, -69 -90, -69 -90))
+ </a>
+POLYGON EMPTY
+ </op></test>
+</case>
+</run>
Modified: trunk/tests/xmltester/TestBufferExternal.xml
--- trunk/tests/xmltester/TestBufferExternal.xml 2009-04-14 09:22:22 UTC (rev 2351)
+++ trunk/tests/xmltester/TestBufferExternal.xml 2009-04-14 09:53:59 UTC (rev 2352)
@@ -2,10 +2,10 @@
<desc>
Various cases which have been reported or identified as causing buffer failures
in previous versions of JTS.
- The cases in this file should all pass in the current version of GEOS.
+ The cases in this file should all pass in the current version of JTS.
</desc>
- <geometryOperation>com.vividsolutions.jtstest.geomop.BufferValidatedGeometryOperation</geometryOperation>
<case>
<desc>
@@ -27,8 +27,8 @@
39.21870803833008, -2598.774169921875 61.087974548339844))
</a>
<test>
- <op name='buffer' arg1='A' arg3='1.0' arg2='1'>
-POLYGON ((-2699.7845794534141532 39.3276135169432237, -2699.0041374225334039 40.1956270391905264, -2598.9877800006584039 62.0648935492002920, -2597.8058559463916026 60.8382385980168152, -2598.8005672202098140 56.9813936913733556, -2598.3594225194010505 42.5167306848985689, -2594.3651864258899877 25.2029642876927902, -2586.0504175091409707 8.5188748551773390, -2571.9409713392496997 -8.5536690479851902, -2559.7642985933857744 -17.8112728170916981, -2551.2883050682994508 -21.7586754766669941, -2539.8801180014552301 -21.5137148084118408, -2532.5610544688979644 -17.1768136087722496, -2532.1021741477675278 -16.5822806831722751, -2530.6789157044022431 -16.4180159613365113, -2518.0629489075272431 -26.6965613409751832, -2518.3456049852547949 -28.4089623675790293, -2564.1668940477547949 -45.4721814380135996, -2564.1676040045695117 -45.4724455100536389, -2569.8863540045695117 -47.5970983726024670, -2570.8171618573137494 -47.4725023891361602, -2674.1330478688596486 26.5751235826636680, -2682.8083651094329980 30.7189608003279133, -2699.2105884679976953 38.3112122246230271, -2699.7845794534141532 39.3276135169432237))
+ <op name='buffer' arg1='A' arg2='1.0' arg3='1'>
+ POLYGON ((-2598.9877800006584 62.06489354920029, -2597.8058559463916 60.838238598016815, -2598.80056722021 56.981393691373356, -2598.359422519401 42.51673068489857, -2594.36518642589 25.202964287692787, -2586.050417509141 8.518874855177339, -2571.9409713392497 -8.553669047985187, -2559.764298593386 -17.811272817091698, -2551.2883050682995 -21.758675476666994, -2539.8801180014552 -21.51371480841184, -2532.561054468898 -17.176813608772246, -2532.1021741477675 -16.582280683172275, -2530.6789157044022 -16.41801596133651, -2518.0629489075272 -26.696561340975183, -2518.345604985255 -28.40896236757903, -2564.166894047755 -45.4721814380136, -2564.1676040045695 -45.47244551005364, -2569.8863540045695 -47.59709837260247, -2570.8171618573137 -47.47250238913616, -2674.1330478688596 26.575123582663668, -2682.808365109433 30.71896080032791, -2699.2105884679977 38.31121222462303, -2699.784579453414 39.327613516943224, -2699.0041374225334 40.195627039190526, -2598.9877800006584 62.06489354920029))
</op>
</test>
</case>
@@ -49,8 +49,8 @@
-57.39796829223633, -2985.708251953125 16.51972770690918))
</a>
<test>
-POLYGON ((-2986.7056636633501512 16.4478258272017506, -2985.0990937741125890 17.3127764525371539, -2981.9147343517970512 14.8667999628029062, -2972.7817300221790902 12.1436203489435375, -2956.3982051078096447 12.7602095344197295, -2941.3462585676961680 15.3264952683112998, -2922.8591038389686219 20.3793079269872521, -2921.6302322462556731 19.6761022339545164, -2913.6031326368806731 -9.9625839461602279, -2914.2207342589513246 -11.1616316755453830, -2930.6315593382983025 -17.2459005599821431, -2945.8190749722657529 -25.8145130479868747, -2958.4216504283335780 -34.8921233207297945, -2969.1479535875710098 -45.2964301092462236, -2977.8260723815997153 -55.7724244074717106, -2979.5941039171189004 -58.0167858332531736, -2980.6728998970838802 -58.3540006419969899, -2981.3770503821001512 -57.4698701719437537, -2986.7056636633501512 16.4478258272017506))
+ POLYGON ((-2986.70566366335 16.44782582720175, -2985.0990937741126 17.312776452537154, -2981.914734351797 14.8667999628029, -2972.781730022179 12.143620348943537, -2956.3982051078096 12.76020953441973, -2941.346258567696 15.3264952683113, -2922.8591038389686 20.379307926987252, -2921.6302322462557 19.676102233954516, -2913.6031326368807 -9.962583946160228, -2914.2207342589513 -11.161631675545383, -2930.6315593382983 -17.24590055998214, -2945.8190749722658 -25.814513047986875, -2958.4216504283336 -34.892123320729795, -2969.147953587571 -45.296430109246224, -2977.8260723815997 -55.7724244074717, -2979.594103917119 -58.016785833253174, -2980.672899897084 -58.35400064199699, -2981.3770503821 -57.469870171943754, -2986.70566366335 16.44782582720175))
</op>
</test>
</case>
Added: trunk/tests/xmltester/TestBufferExternal2.xml
--- trunk/tests/xmltester/TestBufferExternal2.xml (rev 0)
+++ trunk/tests/xmltester/TestBufferExternal2.xml 2009-04-14 09:53:59 UTC (rev 2352)
@@ -0,0 +1,508 @@
+<run>
+ <desc>
+ </desc>
+<case><desc>
+ #1 Polygon - gid: 2501
+ </desc>
+ <a>POLYGON((152663.569985 545814.381985,152650.846985 545793.256985,152627.901985 545778.769985,152678.109985 545771.821985,152727.534985 545773.861985,152781.614985 545740.377985,152811.447985 545734.737985,152805.889985 545712.243985,152779.265985 545710.106985,152757.181985 545678.531985,152728.757985 545672.422985,152667.835985 545695.186985,152611.069985 545717.462985,152570.710985 545744.322985,152523.739985 545745.457985,152517.151985 545743.782985,152484.214985 545735.408985,152436.306985 545736.893985,152438.217985 545750.268985,152430.574985 545761.733985,152394.269985 545761.733985,152371.340985 545769.376985,152363.697985 545788.483985,152367.457985 545791.825985,152370.144985 545794.213985,152380.894985 545803.770985,152403.823985 545794.216985,152436.384985 545810.298985,152453.895985 545794.486985,152489.732985 545814.599985,152492.430985 545838.063985,152521.966985 545844.735985,152539.616985 545818.847985,152582.766985 545797.723985,152629.325985 545840.687985,152634.972885 545846.287385,152649.676985 545837.847985,152663.569985 545814.381985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>POLYGON( EMPTY)
+ </op></test></case><case><desc>
+ #2 Polygon - gid: 2502
+ </desc>
+ <a>POLYGON((142903.674985 525488.153985,142887.424985 525486.421985,142876.299985 525510.439985,142859.487985 525524.993985,142857.580985 525565.813985,142858.104985 525616.072985,142881.339985 525658.486985,142907.528985 525716.283985,142929.703985 525786.082985,142957.279985 525858.237985,142960.930985 525890.791985,142975.490985 525922.709985,142984.234985 525947.127985,142986.419985 525953.232985,142993.173985 525984.254985,143000.571985 526013.485985,143007.015985 526020.469985,143016.093985 526003.985985,143035.005985 525986.830985,143053.948985 525965.933985,143071.269985 525941.972985,143091.351985 525917.505985,143099.479985 525910.991985,143095.500985 525903.225985,143092.658985 525881.416985,143085.816985 525850.459985,143076.886985 525815.718985,143061.518985 525786.881985,143044.455985 525757.313985,143032.301985 525728.902985,143013.483985 525713.680985,143000.030985 525684.275985,143000.320985 525648.294985,143005.159985 525613.976985,143003.725985 525572.864985,143004.494985 525550.515985,143001.962985 525548.017985,142985.622985 525535.307985,142974.204985 525515.602985,142968.977985 525509.074985,142939.044985 525498.260985,142903.674985 525488.153985))</a>
+ #3 Polygon - gid: 2503
+ </desc>
+ <a>POLYGON((146220.994985 549967.552985,146213.166985 549966.121985,146208.007985 549968.568985,146206.036985 549974.608985,146205.864985 549983.214985,146206.109985 549988.066985,146208.381985 549999.999985,146322.285985 549999.999985,146316.339985 549994.911985,146312.438985 549992.675985,146308.350985 549990.750985,146302.286985 549988.489985,146293.636985 549985.962985,146269.463985 549981.745985,146257.525985 549979.090985,146240.391985 549974.375985,146234.981985 549972.660985,146220.994985 549967.552985))</a>
+ #4 Polygon - gid: 2504
+ </desc>
+ <a>POLYGON((144896.566985 524882.672985,144899.299985 524881.825985,144903.913985 524879.874985,144908.281985 524877.329985,144911.797985 524874.348985,144913.851985 524871.090985,144914.168985 524869.389985,144913.622985 524865.233985,144911.859985 524860.681985,144909.399985 524856.197985,144906.748985 524852.222985,144903.927985 524848.842985,144900.666985 524845.737985,144897.109985 524842.856985,144889.669985 524837.573985,144883.779985 524833.850985,144879.800985 524831.683985,144875.716985 524829.743985,144871.552985 524828.061985,144867.693985 524826.762985,144863.373985 524825.537985,144816.049985 524814.269985,144768.463985 524802.145985,144743.475985 524796.359985,144724.202985 524791.404985,144714.293985 524789.489985,144705.353985 524788.164985,144700.870985 524787.764985,144696.389985 524787.619985,144689.024985 524787.828985,144680.046985 524788.515985,144662.118985 524790.538985,144653.609985 524791.745985,144640.283985 524793.947985,144634.330985 524794.724985,144629.764985 524794.975985,144620.521985 524795.100985,144615.989985 524795.370985,144611.611985 524796.041985,144606.579985 524797.679985,144602.565985 524799.585985,144598.598985 524801.833985,144594.733985 524804.380985,144591.026985 524807.186985,144587.534985 524810.208985,144584.313985 524813.405985,144581.419985 524816.734985,144581.806985 524818.560985,144583.642985 524822.862985,144586.460985 524826.772985,144589.858985 524829.672985,144591.561985 524830.552985,144595.734985 524831.793985,144604.956985 524833.056985,144609.445985 524833.994985,144619.190985 524837.204985,144627.621985 524840.384985,144636.348985 524843.925985,144652.801985 524851.249985,144701.221985 524871.437985,144720.997985 524878.409985,144729.636985 524881.012985,144733.994985 524882.035985,144740.905985 524883.100985,144745.358985 524883.385985,144749.845985 524883.427985,144772.449985 524882.398985,144799.041985 524881.859985,144816.235985 524881.915985,144834.523985 524882.327985,144857.002985 524883.450985,144883.361985 524884.143985,144887.877985 524883.994985,144892.292985 524883.537985,144896.566985 524882.672985))</a>
+ #5 Polygon - gid: 2505
+ </desc>
+ <a>POLYGON((144446.439985 524841.154985,144441.934985 524841.141985,144435.845985 524841.674985,144425.648985 524843.342985,144420.748985 524844.729985,144417.119985 524846.780985,144415.753985 524848.861985,144415.428985 524852.340985,144416.080985 524856.335985,144417.458985 524860.698985,144419.313985 524865.282985,144423.459985 524874.528985,144425.249985 524878.896985,144427.325985 524883.109985,144429.289985 524885.370985,144439.587985 524894.381985,144443.173985 524897.220985,144446.878985 524899.799985,144450.724985 524902.010985,144453.174985 524903.142985,144457.321985 524904.547985,144461.659985 524905.496985,144466.133985 524906.119985,144479.827985 524907.342985,144483.155985 524907.782985,144517.007985 524913.042985,144521.480985 524913.453985,144530.608985 524913.781985,144550.777985 524913.633985,144559.793985 524913.451985,144568.795985 524913.012985,144574.880985 524912.364985,144579.291985 524911.566985,144594.257985 524907.594985,144607.560985 524904.598985,144611.775985 524903.277985,144615.327985 524899.282985,144614.465985 524894.617985,144613.841985 524893.603985,144607.933985 524886.826985,144601.507985 524880.434985,144594.663985 524874.523985,144591.115985 524871.777985,144586.969985 524868.873985,144583.162985 524866.495985,144575.256985 524862.134985,144558.682985 524853.946985,144554.551985 524852.069985,144550.343985 524850.422985,144546.048985 524849.133985,144540.520985 524848.023985,144536.086985 524847.329985,144522.628985 524845.891985,144507.564985 524844.759985,144480.579985 524843.741985,144461.960985 524842.043985,144446.439985 524841.154985))</a>
+ #6 Polygon - gid: 2506
+ </desc>
+ <a>POLYGON((144455.196985 524980.805985,144461.047985 524980.714985,144465.526985 524981.158985,144474.517985 524982.448985,144479.009985 524982.843985,144490.646985 524982.725985,144495.270985 524982.522985,144499.829985 524982.093985,144504.251985 524981.331985,144508.466985 524980.130985,144509.918985 524979.570985,144513.913985 524977.623985,144517.852985 524975.167985,144521.610985 524972.300985,144525.060985 524969.118985,144528.074985 524965.720985,144530.334985 524962.519985,144532.084985 524958.448985,144532.948985 524953.701985,144532.919985 524948.863985,144531.990985 524944.516985,144529.776985 524940.368985,144526.744985 524936.825985,144523.097985 524933.699985,144519.179985 524931.193985,144517.924985 524930.555985,144513.860985 524929.018985,144509.523985 524927.994985,144493.342985 524925.809985,144437.476985 524916.661985,144433.088985 524915.698985,144428.782985 524914.494985,144423.543985 524912.609985,144419.404985 524910.860985,144411.280985 524906.906985,144400.576985 524901.079985,144396.728985 524898.765985,144393.000985 524896.236985,144385.751985 524890.870985,144381.960985 524887.848985,144375.108985 524881.988985,144371.554985 524879.239985,144363.304985 524873.572985,144355.718985 524868.636985,144347.909985 524864.180985,144344.379985 524862.452985,144340.237985 524860.702985,144335.937985 524859.212985,144331.535985 524858.026985,144327.084985 524857.185985,144323.250985 524856.770985,144318.804985 524856.633985,144309.840985 524857.119985,144296.319985 524858.530985,144291.864985 524858.855985,144278.326985 524858.971985,144273.869985 524859.393985,144269.275985 524860.279985,144251.862985 524864.968985,144247.472985 524865.953985,144238.178985 524867.630985,144229.241985 524868.924985,144219.237985 524869.738985,144214.767985 524869.549985,144205.816985 524868.188985,144200.865985 524867.789985,144191.538985 524867.752985,144186.945985 524868.099985,144182.709985 524869.007985,144181.284985 524869.531985,144177.852985 524872.620985,144176.025985 524877.123985,144175.996985 524878.261985,144176.451985 524882.564985,144177.369985 524887.022985,144178.706985 524891.527985,144180.417985 524895.971985,144182.460985 524900.245985,144184.791985 524904.243985,144188.570985 524909.302985,144191.772985 524912.018985,144195.672985 524914.042985,144208.945985 524918.742985,144213.022985 524920.777985,144217.149985 524923.817985,144220.469985 524926.853985,144226.873985 524933.289985,144230.199985 524936.340985,144232.588985 524938.226985,144239.984985 524943.454985,144247.712985 524948.238985,144251.712985 524950.295985,144255.808985 524952.038985,144260.553985 524953.530985,144264.923985 524954.479985,144269.384985 524955.181985,144282.909985 524956.875985,144311.048985 524961.124985,144317.314985 524962.407985,144321.673985 524963.513985,144325.997985 524964.818985,144330.259985 524966.323985,144337.091985 524969.241985,144349.052985 524975.446985,144371.128985 524988.101985,144374.990985 524990.509985,144382.600985 524995.675985,144386.503985 524997.875985,144390.576985 524999.444985,144395.149985 525000.415985,144399.750985 525000.903985,144404.419985 525000.929985,144408.992985 525000.459985,144413.301985 524999.458985,144417.441985 524997.544985,144421.099985 524994.911985,144428.244985 524988.981985,144432.035985 524986.535985,144437.425985 524984.344985,144441.760985 524983.043985,144446.208985 524982.029985,144450.707985 524981.288985,144455.196985 524980.805985))</a>
+ #7 Polygon - gid: 2507
+ </desc>
+ <a>POLYGON((144180.284985 525120.032985,144183.832985 525116.794985,144186.310985 525113.187985,144186.773985 525112.080985,144187.835985 525108.131985,144188.392985 525103.916985,144188.543985 525099.491985,144188.385985 525094.909985,144188.017985 525090.227985,144186.627985 525076.124985,144185.841985 525059.007985,144185.204985 525050.018985,144184.199985 525041.093985,144182.718985 525031.683985,144181.494985 525027.301985,144179.611985 525023.346985,144176.818985 525019.465985,144173.767985 525015.993985,144170.357985 525012.802985,144166.672985 525010.048985,144162.791985 525007.884985,144158.428985 525006.304985,144154.095985 525005.337985,144140.459985 525003.668985,144135.956985 525002.943985,144132.489985 525002.111985,144128.279985 525000.587985,144116.048985 524994.706985,144112.117985 524993.299985,144098.939985 524989.717985,144094.477985 524988.770985,144090.015985 524988.064985,144085.573985 524987.673985,144082.099985 524987.632985,144077.708985 524988.016985,144073.317985 524988.862985,144068.938985 524990.056985,144060.269985 524993.031985,144056.006985 524994.585985,144051.298985 524996.571985,144039.237985 525003.001985,144035.090985 525004.553985,144033.429985 525004.964985,144029.061985 525005.651985,144024.594985 525005.978985,144020.064985 525006.023985,144015.503985 525005.866985,144005.304985 525005.175985,144000.845985 525004.540985,143991.981985 525002.425985,143987.562985 525001.659985,143984.325985 525001.504985,143979.862985 525001.775985,143975.358985 525002.379985,143970.879985 525003.298985,143966.493985 525004.512985,143962.267985 525006.001985,143957.854985 525007.995985,143953.888985 525010.251985,143950.109985 525012.839985,143946.599985 525015.694985,143944.902985 525017.266985,143941.891985 525020.593985,143939.241985 525024.341985,143937.049985 525028.360985,143935.728985 525031.561985,143947.089985 525038.847985,143958.611985 525045.903985,143978.120985 525057.118985,143986.179985 525061.258985,144002.539985 525068.796985,144015.419985 525074.941985,144023.406985 525079.086985,144032.735985 525085.069985,144047.490985 525095.410985,144052.695985 525098.806985,144056.554985 525101.113985,144071.198985 525108.843985,144087.471985 525116.537985,144095.654985 525120.979985,144099.734985 525122.957985,144103.931985 525124.188985,144108.802985 525124.422985,144113.258985 525123.960985,144122.292985 525122.295985,144135.544985 525120.385985,144140.040985 525119.859985,144144.496985 525119.751985,144146.224985 525119.877985,144150.651985 525120.958985,144159.475985 525124.711985,144163.736985 525125.992985,144167.459985 525126.023985,144171.674985 525124.798985,144176.090985 525122.751985,144180.284985 525120.032985))</a>
+ #8 Polygon - gid: 2508
+ </desc>
+ <a>POLYGON((145511.322985 525055.058985,145421.842985 525011.893985,145360.382985 525010.401985,145268.686985 525018.327985,145146.589985 524998.812985,145037.826985 525008.605985,144973.835985 525025.487985,145025.537985 525040.060985,145053.665985 525046.467985,145095.857985 525056.078985,145116.953985 525060.883985,145237.680985 525091.930985,145337.492985 525112.002985,145422.613985 525124.136985,145582.586985 525143.477985,145594.862985 525133.291985,145599.488985 525122.480985,145601.426985 525108.224985,145582.118985 525096.831985,145543.502985 525074.046985,145511.322985 525055.058985))</a>
+ #9 Polygon - gid: 2509
+ </desc>
+ <a>POLYGON((144327.439985 525055.359985,144323.575985 525054.083985,144319.137985 525053.820985,144309.540985 525054.540985,144304.876985 525054.629985,144288.008985 525053.381985,144279.029985 525053.080985,144271.827985 525053.508985,144258.386985 525054.981985,144243.660985 525055.827985,144230.778985 525056.779985,144226.202985 525057.165985,144221.779985 525057.904985,144216.743985 525059.629985,144212.867985 525061.883985,144209.230985 525064.754985,144205.958985 525068.049985,144203.179985 525071.576985,144199.872985 525077.084985,144197.994985 525081.332985,144196.679985 525085.738985,144196.099985 525090.172985,144195.983985 525096.039985,144196.147985 525105.052985,144196.712985 525114.141985,144198.291985 525127.709985,144199.820985 525136.570985,144200.724985 525140.909985,144204.646985 525148.438985,144214.701985 525150.449985,144224.757985 525146.427985,144239.841985 525143.410985,144256.935985 525142.405985,144273.025985 525137.377985,144284.086985 525131.343985,144293.136985 525124.304985,144300.175985 525117.265985,144311.054985 525104.626985,144312.513985 525103.587985,144316.441985 525102.209985,144321.398985 525100.876985,144326.356985 525099.200985,144330.789985 525096.313985,144333.887985 525092.901985,144336.779985 525088.924985,144339.157985 525084.646985,144340.713985 525080.335985,144341.139985 525076.255985,144340.875985 525074.291985,144339.526985 525070.035985,144337.293985 525065.704985,144334.418985 525061.624985,144331.142985 525058.119985,144327.439985 525055.359985))</a>
+ #10 Polygon - gid: 2510
+ </desc>
+ <a>POLYGON((144510.896985 525506.174985,144491.815985 525502.887985,144452.960985 525504.373985,144356.543985 525498.078985,144342.420985 525498.616985,144329.347985 525503.644985,144327.336985 525503.644985,144316.275985 525508.672985,144310.241985 525515.711985,144314.264985 525527.778985,144324.779985 525538.713985,144356.897985 525552.292985,144379.210985 525556.506985,144460.334985 525561.721985,144473.144985 525559.956985,144485.211985 525553.922985,144497.278985 525540.850985,144512.361985 525525.766985,144520.406985 525516.716985,144517.389985 525510.683985,144510.896985 525506.174985))</a>
+ #11 Polygon - gid: 2511
+ </desc>
+ <a>POLYGON((145442.154985 525572.074985,145501.507985 525553.758985,145522.070985 525554.647985,145516.394985 525541.746985,145505.936985 525519.454985,145532.899985 525496.685985,145547.030985 525513.347985,145591.958985 525554.366985,145632.751985 525552.852985,145668.799985 525544.771985,145702.316985 525529.254985,145724.534985 525515.925985,145745.168985 525499.920985,145723.440985 525498.117985,145705.446985 525491.319985,145691.799985 525487.926985,145650.858985 525477.747985,145578.241985 525453.820985,145543.290985 525453.401985,145502.225985 525452.909985,145398.531985 525436.386985,145380.777985 525443.215985,145344.364985 525481.970985,145328.089985 525529.882985,145370.877985 525553.686985,145442.154985 525572.074985))</a>
+ #12 Polygon - gid: 2512
+ </desc>
+ <a>POLYGON((144625.991985 525513.700985,144598.841985 525508.672985,144583.757985 525509.677985,144566.662985 525514.705985,144552.584985 525519.733985,144542.529985 525530.794985,144526.439985 525542.861985,144519.400985 525555.934985,144519.400985 525571.017985,144522.417985 525577.051985,144538.506985 525584.090985,144554.595985 525589.117985,144566.662985 525595.151985,144585.768985 525597.162985,144602.863985 525597.162985,144612.919985 525594.145985,144623.980985 525590.123985,144647.108985 525580.067985,144660.180985 525574.034985,144674.259985 525562.973985,144689.342985 525551.911985,144692.359985 525544.872985,144691.353985 525537.833985,144678.281985 525530.794985,144658.169985 525524.761985,144625.991985 525513.700985))</a>
+ #13 Polygon - gid: 2513
+ </desc>
+ <a>POLYGON((146081.670985 525417.759985,146034.312985 525383.398985,146018.183985 525405.148985,145997.047985 525436.541985,145975.994985 525451.787985,145927.068985 525472.385985,145872.869985 525488.849985,145830.388985 525510.994985,145793.352985 525537.222985,145768.063985 525549.233985,145754.442985 525585.944985,145741.111985 525601.945985,145729.163985 525609.328985,145747.791985 525621.222985,145785.820985 525616.608985,145835.405985 525606.033985,145888.006985 525585.051985,145922.153985 525572.522985,145965.920985 525551.110985,145987.088985 525544.372985,146029.350985 525531.069985,146071.462985 525518.113985,146123.223985 525504.811985,146160.742985 525500.837985,146164.508985 525498.816985,146132.472985 525456.997985,146081.670985 525417.759985))</a>
+ #14 Polygon - gid: 2514
+ </desc>
+ <a>POLYGON((147625.665985 525733.355985,147685.615985 525723.612985,147746.451985 525726.828985,147807.643985 525705.752985,147778.828985 525680.379985,147736.635985 525673.137985,147681.802985 525656.781985,147634.046985 525660.702985,147593.909985 525649.092985,147543.925985 525630.287985,147525.748985 525647.754985,147521.204985 525652.120985,147486.998985 525649.400985,147473.315985 525648.312985,147433.858985 525642.752985,147433.938985 525662.319985,147457.769985 525676.556985,147464.271985 525685.355985,147463.991985 525695.137985,147478.318985 525707.779985,147479.694885 525707.945085,147513.227985 525711.970985,147572.805985 525729.496985,147625.665985 525733.355985))</a>
+ #15 Polygon - gid: 2515
+ </desc>
+ <a>POLYGON((149067.995985 525965.488985,149025.297985 525963.470985,148994.143985 525964.208985,148997.616985 525989.339985,149029.151985 526015.805985,149120.123985 526059.526985,149131.062985 526066.577985,149148.502985 526077.820985,149183.975985 526087.501985,149232.395985 526086.935985,149294.555985 526084.930985,149312.038985 526079.485985,149314.993985 526078.565985,149316.243985 526056.762985,149244.224985 526035.142985,149176.959985 526005.418985,149113.972985 525980.563985,149067.995985 525965.488985))</a>
+ #16 Polygon - gid: 2516
+ </desc>
+ <a>POLYGON((150716.409985 526216.711985,150707.088985 526192.800985,150622.180985 526127.431985,150583.008985 526115.338985,150539.865985 526092.923985,150506.113985 526087.030985,150457.230985 526063.119985,150414.652985 526045.317985,150412.516485 526044.107285,150403.373985 526054.606985,150398.109985 526096.678985,150386.500985 526126.603985,150356.405985 526157.275985,150349.132985 526185.598985,150364.836985 526203.184985,150392.348985 526202.980985,150449.647985 526187.409985,150479.794985 526174.863985,150494.337985 526175.134985,150530.693985 526175.812985,150537.911985 526177.023985,150588.433985 526185.497985,150654.506985 526212.614985,150706.931985 526211.847985,150716.409985 526216.711985))</a>
+ #17 Polygon - gid: 2517
+ </desc>
+ <a>POLYGON((142576.939985 544993.306985,142591.447985 544982.626985,142598.216985 544976.869985,142601.519985 544973.710985,142604.578985 544970.396985,142606.691985 544967.715985,142607.297985 544962.618985,142603.363985 544961.993985,142598.959985 544961.672985,142594.273985 544961.623985,142589.490985 544961.812985,142582.524985 544962.474985,142578.110985 544963.214985,142573.719985 544964.260985,142569.373985 544965.557985,142561.217985 544968.551985,142557.131985 544970.386985,142553.145985 544972.465985,142545.288985 544976.918985,142529.062985 544985.730985,142525.008985 544987.637985,142521.706985 544988.893985,142517.221985 544989.644985,142511.940985 544988.902985,142507.623985 544990.118985,142503.346985 544991.624985,142499.158985 544993.401985,142495.106985 544995.428985,142491.643985 544997.434985,142488.002985 545000.007985,142484.572985 545002.922985,142477.897985 545009.067985,142474.427985 545011.944985,142468.738985 545015.692985,142464.809985 545017.875985,142452.730985 545023.989985,142433.515985 545034.313985,142415.405985 545044.738985,142396.233985 545056.516985,142390.894985 545059.567985,142382.948985 545063.811985,142374.326985 545067.766985,142365.958985 545071.089985,142353.644985 545075.660985,142323.390985 545086.250985,142304.370985 545093.446985,142300.236985 545095.217985,142296.256985 545097.143985,142292.326985 545099.358985,142288.519985 545101.843985,142284.895985 545104.541985,142282.462985 545106.558985,142280.138985 545111.115985,142283.834985 545112.105985,142288.493985 545112.673985,142293.452985 545112.769985,142297.356985 545112.450985,142301.654985 545111.424985,142305.872985 545109.806985,142313.771985 545106.396985,142329.263985 545100.265985,142342.005985 545095.779985,142350.590985 545093.089985,142360.163985 545090.637985,142374.837985 545087.416985,142388.124985 545084.842985,142392.515985 545083.872985,142396.843985 545082.667985,142401.034985 545081.083985,142413.291985 545075.346985,142419.186985 545073.209985,142427.794985 545070.561985,142434.889985 545068.590985,142452.450985 545064.549985,142456.788985 545063.385985,142462.902985 545061.340985,142471.265985 545058.003985,142481.625985 545053.473985,142500.169985 545044.593985,142516.816985 545037.701985,142520.898985 545035.827985,142526.185985 545033.097985,142534.018985 545028.599985,142537.797985 545026.147985,142541.355985 545023.602985,142544.809985 545020.751985,142554.510985 545011.319985,142561.212985 545005.502985,142576.939985 544993.306985))</a>
+ #18 Polygon - gid: 2518
+ </desc>
+ <a>POLYGON((142142.650985 544835.425985,142145.030985 544834.924985,142149.928985 544836.666985,142147.868985 544839.863985,142145.054985 544843.328985,142141.764985 544846.863985,142135.589985 544852.711985,142131.385985 544855.469985,142121.934985 544860.323985,142119.418985 544862.762985,142120.643985 544866.423985,142123.832985 544869.166985,142142.007985 544880.482985,142146.185985 544882.686985,142150.034985 544885.110985,142152.992985 544888.177985,142154.918985 544892.177985,142156.098985 544896.476985,142157.758985 544905.619985,142158.869985 544910.072985,142159.515985 544911.889985,142161.471985 544915.923985,142166.292985 544923.628985,142168.551985 544927.529985,142170.143985 544931.144985,142171.234985 544935.498985,142172.207985 544944.679985,142172.887985 544949.148985,142174.226985 544953.296985,142176.709985 544957.283985,142179.723985 544960.618985,142201.533985 544980.806985,142208.081985 544987.628985,142214.086985 544994.480985,142216.762985 544998.084985,142218.813985 545001.396985,142220.731985 545005.664985,142221.760985 545010.296985,142221.410985 545013.929985,142219.731985 545017.878985,142217.358985 545021.757985,142214.506985 545025.474985,142211.394985 545028.938985,142209.403985 545030.945985,142205.982985 545033.801985,142202.150985 545036.254985,142198.084985 545038.353985,142194.906985 545039.761985,142190.673985 545041.191985,142181.848985 545043.208985,142175.903985 545044.966985,142167.646985 545048.537985,142159.620985 545052.668985,142151.626985 545057.376985,142144.153985 545062.424985,142140.530985 545065.106985,142133.753985 545070.520985,142130.329985 545073.481985,142127.047985 545076.586985,142123.979985 545079.866985,142120.258985 545084.585985,142117.704985 545088.320985,142115.321985 545092.177985,142111.638985 545098.836985,142110.590985 545104.805985,142114.324985 545106.169985,142118.865985 545107.103985,142123.727985 545107.542985,142128.424985 545107.422985,142133.319985 545106.555985,142137.609985 545105.268985,142146.150985 545102.097985,142152.816985 545099.968985,142161.600985 545098.020985,142170.475985 545096.461985,142179.596985 545095.135985,142193.021985 545093.676985,142203.872985 545092.852985,142217.391985 545092.380985,142223.658985 545091.743985,142228.073985 545090.957985,142236.822985 545088.833985,142260.302985 545082.618985,142275.993985 545078.035985,142284.552985 545075.245985,142292.377985 545072.316985,142304.771985 545066.945985,142315.772985 545061.600985,142326.339985 545055.888985,142334.073985 545051.287985,142344.223985 545044.758985,142358.879985 545034.305985,142372.971985 545025.050985,142382.274985 545019.649985,142386.325985 545017.721985,142394.717985 545014.429985,142415.323985 545006.078985,142427.651985 545000.555985,142435.089985 544996.886985,142439.032985 544994.722985,142446.714985 544990.017985,142457.124985 544983.221985,142464.485985 544977.997985,142467.866985 544975.111985,142470.779985 544971.360985,142476.685985 544960.284985,142479.910985 544956.180985,142483.304985 544953.234985,142493.778985 544944.676985,142496.933985 544941.723985,142499.886985 544938.302985,142505.255985 544930.884985,142508.155985 544927.477985,142510.754985 544925.197985,142514.462985 544922.808985,142518.456985 544920.774985,142522.642985 544918.997985,142537.322985 544913.615985,142545.912985 544910.920985,142554.584985 544908.470985,142570.055985 544904.514985,142609.687985 544895.396985,142618.402985 544893.149985,142625.191985 544891.116985,142633.745985 544888.300985,142642.213985 544885.246985,142647.284985 544883.222985,142659.650985 544877.784985,142663.825985 544876.113985,142672.611985 544873.031985,142681.231985 544870.419985,142688.566985 544868.542985,142701.784985 544865.776985,142712.430985 544863.748985,142735.115985 544859.827985,142748.404985 544857.440985,142759.820985 544854.793985,142772.902985 544851.448985,142791.990985 544847.041985,142836.872985 544838.059985,142856.026985 544833.591985,142866.014985 544830.834985,142870.276985 544829.394985,142882.911985 544824.582985,142891.044985 544822.276985,142899.893985 544820.435985,142907.005985 544819.604985,142911.480985 544819.457985,142915.973985 544819.549985,142931.392985 544820.445985,142949.396985 544820.976985,142953.877985 544821.305985,142963.412985 544822.566985,142997.291985 544828.686985,143001.762985 544829.190985,143015.237985 544830.244985,143021.078985 544830.979985,143029.925985 544832.658985,143034.317985 544833.689985,143042.431985 544835.985985,143046.664985 544837.487985,143059.123985 544842.750985,143063.328985 544844.341985,143069.061985 544846.084985,143073.419985 544847.201985,143091.561985 544851.204985,143104.799985 544853.865985,143117.818985 544855.976985,143131.660985 544857.736985,143149.611985 544859.148985,143158.523985 544860.304985,143171.796985 544862.806985,143187.420985 544865.182985,143195.694985 544866.198985,143218.129985 544867.941985,143229.421985 544869.235985,143238.331985 544870.546985,143242.752985 544871.361985,143248.974985 544872.787985,143245.893985 544864.243985,143243.278985 544855.627985,143239.596985 544845.254985,143238.703985 544840.809985,143239.565985 544838.343985,143242.559985 544836.757985,143246.782985 544835.973985,143251.747985 544835.772985,143256.966985 544835.932985,143263.459985 544836.324985,143267.887985 544836.914985,143281.079985 544840.308985,143285.493985 544841.010985,143291.165985 544841.147985,143295.708985 544840.906985,143300.240985 544840.360985,143304.693985 544839.501985,143308.795985 544838.387985,143312.930985 544836.782985,143316.929985 544834.744985,143328.699985 544827.895985,143340.615985 544821.459985,143349.622985 544816.936985,143353.765985 544815.199985,143379.048985 544806.047985,143383.197985 544804.295985,143387.085985 544802.178985,143391.866985 544798.607985,143395.237985 544795.519985,143398.377985 544792.144985,143401.217985 544788.550985,143403.683985 544784.802985,143406.240985 544779.636985,143407.710985 544775.344985,143408.807985 544770.880985,143409.578985 544766.357985,143410.053985 544762.114985,143410.135985 544757.674985,143409.747985 544753.192985,143409.089985 544748.693985,143407.345985 544737.228985,143405.081985 544723.917985,143403.266985 544711.498985,143400.336985 544688.230985,143398.896985 544674.807985,143397.734985 544659.841985,143397.090985 544646.826985,143396.850985 544637.820985,143396.972985 544632.012985,143396.751985 544622.050985,143396.978985 544617.243985,143398.170985 544613.367985,143399.194985 544612.065985,143402.692985 544610.512985,143407.447985 544610.199985,143412.699985 544610.353985,143417.686985 544610.201985,143421.647985 544608.970985,143424.221985 544605.463985,143425.185985 544600.971985,143426.503985 544586.295985,143426.695985 544576.790985,143427.602985 544572.592985,143428.607985 544570.612985,143431.663985 544567.852985,143435.852985 544565.881985,143440.409985 544564.122985,143444.574985 544561.998985,143446.602985 544560.270985,143449.266985 544556.772985,143451.512985 544552.774985,143453.316985 544548.468985,143454.651985 544544.046985,143455.302985 544540.930985,143455.737985 544536.554985,143455.685985 544532.081985,143455.310985 544527.548985,143454.248985 544518.460985,143453.293985 544507.420985,143452.183985 544498.480985,143451.387985 544494.277985,143450.256985 544489.941985,143444.947985 544474.661985,143441.252985 544461.587985,143439.691985 544457.395985,143436.586985 544451.416985,143434.254985 544447.469985,143431.718985 544443.640985,143428.959985 544440.027985,143425.961985 544436.729985,143424.373985 544435.233985,143420.802985 544432.682985,143416.748985 544430.681985,143412.436985 544429.034985,143402.691985 544425.747985,143398.354985 544424.509985,143389.557985 544422.502985,143382.443985 544421.349985,143377.969985 544420.862985,143361.255985 544419.733985,143322.639985 544418.450985,143317.223985 544418.508985,143307.965985 544419.035985,143303.487985 544418.885985,143299.248985 544418.062985,143294.848985 544416.073985,143291.138985 544413.485985,143287.645985 544410.410985,143284.360985 544407.112985,143282.416985 544405.061985,143279.570985 544401.609985,143272.098985 544390.222985,143269.351985 544386.691985,143264.746985 544382.250985,143261.177985 544379.420985,143257.402985 544376.844985,143253.487985 544374.564985,143250.331985 544372.994985,143246.011985 544371.209985,143241.373985 544369.908985,143236.897985 544369.654985,143234.944985 544370.069985,143230.996985 544371.823985,143227.070985 544374.360985,143223.425985 544377.476985,143220.320985 544380.965985,143218.559985 544383.604985,143216.857985 544387.535985,143215.805985 544391.869985,143215.175985 544396.447985,143213.672985 544410.851985,143212.338985 544428.813985,143211.334985 544435.596985,143204.880985 544467.076985,143202.713985 544478.328985,143195.991985 544515.066985,143188.876985 544557.021985,143187.823985 544561.374985,143184.665985 544571.935985,143182.777985 544576.196985,143180.223985 544579.484985,143175.783985 544581.612985,143171.287985 544582.118985,143155.656985 544581.868985,143136.206985 544580.819985,143122.601985 544580.581985,143118.118985 544580.285985,143113.728985 544579.627985,143108.946985 544578.417985,143104.513985 544576.714985,143100.732985 544574.296985,143099.409985 544572.940985,143097.056985 544569.351985,143095.214985 544565.213985,143093.790985 544560.757985,143092.692985 544556.218985,143091.497985 544549.010985,143091.198985 544544.529985,143091.120985 544540.004985,143091.190985 544525.360985,143091.987985 544506.978985,143093.802985 544482.938985,143096.515985 544453.401985,143097.660985 544445.625985,143100.216985 544432.363985,143102.727985 544417.272985,143103.883985 544408.352985,143104.696985 544397.702985,143104.824985 544393.173985,143104.700985 544388.683985,143104.380985 544385.282985,143103.655985 544380.423985,143102.277985 544375.659985,143099.755985 544372.531985,143095.802985 544371.270985,143091.229985 544370.919985,143086.346985 544371.240985,143081.583985 544372.059985,143079.325985 544372.617985,143075.204985 544374.152985,143071.230985 544376.260985,143063.417985 544381.056985,143059.424985 544383.176985,143057.485985 544383.999985,143052.909985 544385.539985,143048.244985 544386.078985,143045.943985 544385.387985,143042.625985 544382.880985,143039.587985 544379.631985,143030.944985 544368.616985,143018.916985 544355.157985,143006.538985 544342.290985,143003.228985 544339.249985,143000.059985 544336.689985,142996.399985 544334.047985,142992.577985 544331.547985,142988.612985 544329.303985,142984.520985 544327.429985,142981.796985 544326.464985,142977.495985 544325.372985,142973.057985 544324.651985,142963.981985 544323.950985,142953.878985 544323.685985,142949.368985 544323.805985,142940.377985 544324.559985,142928.660985 544326.438985,142919.876985 544328.519985,142915.586985 544329.838985,142910.935985 544331.578985,142906.815985 544333.396985,142898.760985 544337.492985,142891.323985 544341.669985,142883.714985 544346.485985,142873.049985 544353.650985,142865.638985 544358.793985,142862.071985 544361.528985,142852.868985 544369.200985,142849.644985 544372.462985,142847.241985 544376.065985,142846.832985 544377.001985,142845.639985 544381.155985,142845.045985 544385.649985,142844.939985 544390.314985,142845.205985 544394.983985,142845.730985 544399.487985,142847.359985 544404.070985,142849.883985 544408.193985,142851.902985 544412.235985,142852.270985 544414.588985,142851.234985 544418.764985,142848.804985 544422.901985,142845.666985 544426.437985,142841.451985 544429.726985,142837.382985 544432.073985,142833.070985 544433.782985,142829.180985 544434.554985,142824.843985 544434.518985,142820.388985 544433.803985,142815.908985 544432.626985,142808.656985 544430.234985,142804.514985 544428.545985,142792.485985 544422.309985,142789.356985 544420.953985,142780.856985 544417.736985,142776.523985 544416.379985,142772.150985 544415.400985,142769.493985 544415.056985,142765.048985 544415.082985,142751.517985 544417.132985,142747.071985 544417.221985,142741.891985 544416.537985,142737.389985 544415.594985,142732.957985 544414.305985,142728.713985 544412.646985,142724.776985 544410.591985,142720.722985 544407.567985,142717.590985 544404.379985,142708.851985 544393.768985,142695.798985 544379.805985,142685.746985 544368.505985,142681.717985 544363.733985,142676.115985 544356.691985,142646.529985 544317.476985,142637.252985 544305.929985,142629.738985 544297.399985,142626.583985 544294.195985,142619.961985 544288.074985,142606.708985 544277.250985,142603.032985 544274.509985,142599.218985 544272.148985,142595.218985 544270.380985,142590.945985 544269.249985,142586.455985 544268.616985,142581.850985 544268.406985,142577.242985 544268.544985,142572.745985 544268.960985,142568.202985 544269.774985,142563.879985 544270.976985,142559.588985 544272.441985,142512.041985 544289.931985,142499.063985 544293.973985,142494.844985 544295.512985,142490.821985 544297.411985,142486.858985 544299.660985,142482.929985 544302.124985,142479.179985 544304.838985,142475.776985 544307.826985,142472.884985 544311.110985,142470.374985 544315.361985,142468.770985 544319.648985,142467.680985 544324.191985,142466.879985 544330.867985,142466.891985 544335.290985,142467.346985 544339.759985,142468.106985 544344.244985,142469.978985 544353.154985,142472.266985 544362.401985,142476.753985 544376.733985,142479.688985 544385.253985,142482.130985 544391.383985,142485.988985 544399.514985,142490.328985 544407.410985,142493.108985 544412.007985,142500.694985 544423.185985,142503.886985 544427.401985,142512.460985 544437.928985,142515.999985 544443.400985,142518.088985 544447.422985,142520.010985 544451.634985,142521.614985 544455.961985,142522.756985 544460.330985,142523.276985 544464.467985,142523.056985 544468.822985,142522.131985 544473.237985,142520.735985 544477.644985,142519.105985 544481.978985,142516.222985 544488.854985,142507.660985 544504.729985,142498.246985 544525.424985,142495.238985 544531.607985,142491.152985 544539.627985,142482.068985 544556.762985,142476.213985 544566.860985,142471.338985 544575.732985,142468.701985 544579.756985,142465.777985 544582.273985,142464.715985 544582.617985,142461.172985 544582.107985,142457.227985 544579.900985,142453.175985 544576.750985,142447.704985 544572.038985,142444.441985 544568.990985,142435.526985 544558.787985,142427.051985 544549.664985,142423.735985 544546.556985,142420.069985 544544.196985,142415.422985 544542.528985,142411.043985 544541.542985,142406.504985 544540.908985,142401.901985 544540.531985,142395.232985 544540.246985,142390.735985 544540.243985,142386.201985 544540.518985,142381.689985 544541.072985,142377.257985 544541.902985,142370.099985 544543.816985,142365.592985 544545.677985,142362.366985 544548.445985,142360.671985 544552.905985,142359.988985 544557.315985,142359.794985 544562.023985,142360.111985 544571.441985,142360.600985 544576.236985,142361.477985 544580.650985,142363.537985 544589.470985,142366.377985 544604.633985,142366.965985 544609.086985,142367.335985 544617.125985,142367.289985 544621.772985,142366.887985 544626.340985,142365.944985 544630.666985,142365.333985 544632.397985,142363.153985 544636.188985,142360.091985 544639.631985,142356.569985 544642.705985,142354.358985 544644.404985,142350.648985 544646.900985,142346.683985 544649.103985,142342.551985 544651.012985,142338.337985 544652.626985,142329.120985 544655.754985,142324.613985 544656.911985,142320.187985 544657.470985,142316.566985 544657.265985,142312.451985 544656.082985,142308.414985 544654.079985,142304.498985 544651.523985,142300.747985 544648.684985,142297.537985 544646.100985,142294.429985 544642.836985,142289.020985 544635.306985,142285.887985 544632.242985,142284.879985 544631.587985,142280.948985 544629.665985,142276.699985 544628.156985,142272.248985 544626.990985,142267.710985 544626.098985,142261.157985 544625.144985,142256.637985 544625.059985,142252.097985 544625.862985,142250.010985 544626.622985,142241.865985 544627.069985,142232.842985 544626.961985,142228.189985 544626.652985,142219.256985 544625.578985,142210.379985 544623.978985,142201.928985 544621.981985,142189.033985 544617.937985,142173.175985 544613.480985,142168.754985 544612.685985,142164.493985 544612.651985,142159.712985 544614.117985,142155.595985 544616.806985,142152.724985 544620.553985,142151.801985 544624.611985,142151.792985 544629.186985,142152.818985 544644.306985,142153.735985 544653.425985,142153.819985 544657.896985,142153.318985 544662.241985,142152.623985 544664.931985,142151.012985 544669.139985,142148.905985 544673.227985,142146.451985 544677.131985,142143.800985 544680.784985,142141.760985 544683.177985,142138.544985 544686.291985,142127.599985 544695.435985,142117.560985 544704.466985,142109.963985 544710.975985,142099.369985 544719.346985,142082.249985 544732.007985,142078.514985 544734.516985,142074.669985 544736.825985,142070.918985 544738.762985,142040.406985 544751.752985,142036.369985 544753.717985,142032.516985 544755.964985,142027.531985 544759.240985,142023.678985 544761.987985,142020.080985 544764.951985,142016.968985 544768.159985,142014.575985 544771.637985,142013.343985 544775.609985,142013.207985 544780.181985,142013.704985 544784.959985,142014.681985 544791.876985,142015.536985 544796.277985,142019.864985 544813.795985,142022.666985 544828.695985,142025.800985 544848.146985,142027.072985 544858.744985,142027.856985 544867.714985,142028.179985 544873.963985,142028.369985 544882.972985,142028.035985 544892.629985,142027.589985 544897.101985,142025.218985 544914.955985,142024.641985 544922.434985,142023.963985 544936.376985,142023.670985 544943.302985,142023.091985 544947.790985,142020.706985 544959.048985,142019.522985 544963.574985,142017.933985 544967.794985,142015.721985 544971.446985,142013.338985 544973.773985,142009.459985 544976.166985,142005.088985 544977.998985,142000.003985 544979.579985,141995.653985 544980.532985,141991.200985 544981.173985,141977.392985 544982.301985,141968.411985 544982.825985,141939.455985 544983.523985,141916.541985 544984.122985,141907.570985 544984.733985,141899.202985 544985.735985,141890.317985 544987.263985,141885.942985 544988.266985,141877.874985 544990.674985,141873.665985 544992.331985,141869.642985 544994.298985,141866.567985 544996.096985,141862.799985 544998.647985,141859.259985 545001.498985,141855.939985 545004.762985,141853.094985 545008.215985,141850.524985 545011.948985,141848.222985 545015.872985,141843.299985 545026.123985,141841.513985 545030.329985,141839.937985 545034.597985,141838.672985 545038.912985,141837.817985 545043.263985,141837.564985 545045.479985,141837.372985 545049.948985,141837.531985 545054.478985,141837.971985 545059.024985,141839.581985 545068.905985,141840.655985 545073.249985,141842.000985 545077.543985,141849.605985 545098.429985,141852.868985 545106.820985,141856.108985 545114.396985,141863.822985 545130.663985,141870.756985 545147.135985,141873.752985 545155.384985,141879.091985 545172.579985,141883.341985 545185.112985,141884.625985 545189.420985,141885.627985 545193.781985,141886.145985 545197.442985,141886.449985 545201.927985,141886.736985 545210.964985,141887.107985 545215.451985,141888.688985 545225.889985,141890.837985 545235.495985,141892.625985 545240.137985,141895.222985 545246.128985,141896.344985 545249.128985,141899.344985 545249.585985,141901.987985 545249.987985,141910.946985 545254.647985,141922.303985 545260.209985,141934.615985 545265.751985,141949.278985 545271.886985,141952.650985 545273.232985,141953.085985 545270.082985,141953.697985 545260.435985,141955.736985 545245.635985,141956.724985 545241.274985,141957.339985 545239.311985,141959.039985 545235.186985,141961.133985 545231.187985,141963.487985 545227.299985,141969.128985 545218.902985,141971.839985 545215.291985,141974.698985 545211.797985,141977.702985 545208.448985,141981.598985 545204.640985,142003.749985 545186.021985,142007.106985 545183.020985,142010.279985 545179.861985,142011.503985 545178.509985,142014.209985 545174.939985,142021.256985 545163.293985,142023.970985 545159.756985,142027.727985 545156.132985,142031.253985 545153.355985,142042.379985 545145.535985,142054.026985 545136.633985,142060.975985 545130.928985,142064.714985 545127.423985,142070.881985 545120.853985,142082.306985 545108.149985,142087.613985 545102.034985,142096.113985 545091.529985,142099.094985 545088.167985,142102.615985 545084.656985,142116.917985 545071.592985,142126.193985 545061.774985,142132.719985 545055.619985,142139.502985 545049.705985,142152.899985 545038.492985,142163.689985 545030.315985,142167.166985 545027.473985,142169.362985 545025.434985,142175.735985 545018.911985,142178.744985 545015.461985,142181.470985 545011.872985,142183.788985 545008.130985,142185.713985 545003.380985,142186.467985 544998.647985,142185.842985 544994.279985,142183.834985 544990.319985,142181.236985 544986.676985,142178.209985 544983.168985,142171.763985 544976.505985,142168.169985 544973.241985,142160.932985 544967.826985,142150.992985 544959.115985,142147.610985 544955.911985,142144.697985 544952.514985,142142.553985 544948.835985,142141.448985 544944.453985,142141.366985 544939.973985,142142.555985 544927.576985,142143.282985 544922.932985,142144.283985 544918.248985,142144.317985 544913.913985,142143.855985 544912.514985,142141.673985 544908.912985,142138.777985 544905.543985,142135.430985 544902.337985,142124.215985 544892.360985,142113.700985 544883.804985,142110.516985 544880.674985,142107.108985 544876.724985,142104.234985 544873.018985,142101.700985 544869.152985,142099.737985 544865.197985,142099.013985 544863.104985,142098.927985 544858.542985,142100.632985 544853.979985,142102.038985 544852.214985,142105.407985 544849.594985,142109.303985 544847.361985,142113.516985 544845.413985,142125.369985 544840.695985,142129.650985 544839.159985,142138.320985 544836.494985,142142.650985 544835.425985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>MULTIPOLYGON(((141915.20707389 545059.387655348,141919.801422452 545072.005349505,141922.317819047 545078.476414118,141924.497039105 545083.5720225,141931.58949003 545098.528322628,141932.948007704 545101.565338362,141939.882007704 545118.037338362,141941.251466939 545121.532703646,141944.247466939 545129.781703646,141945.379704287 545133.145086525,141946.3559021 545136.289068806,141953.641588396 545130.165092772,141957.089854983 545124.466424874,141961.755195593 545117.637254309,141964.469195593 545114.100254309,141971.902043368 545105.777124706,141975.659043368 545102.153124706,141981.323503868 545097.212495093,141984.849503868 545094.435495093,141988.126685407 545091.996095579,141998.026564897 545085.037884397,142007.445824641 545077.838584126,142011.481024278 545074.525760133,142011.672439934 545074.346323954,142015.650983665 545070.107791068,142026.098161322 545058.491078161,142030.123193498 545053.85322782,142036.276326015 545046.248679928,142034.080027084 545047.169206041,142027.356134783 545049.617237147,142022.271134783 545051.198237147,142016.054354808 545052.84242851,142011.704354808 545053.79542851,142006.339933412 545054.767818512,142001.886933412 545055.408818512,141997.307525709 545055.92497269,141983.499525709 545057.05297269,141981.761460455 545057.174653059,141972.780460455 545057.698653059,141970.219375418 545057.804204103,141941.339643255 545058.500365626,141920.0716525 545059.05633693,141915.20707389 545059.387655348)),((142293.528899252 544988.140168692,142294.601996184 544987.501777305,142302.137667721 544982.654447309,142315.330088769 544973.24530585,142317.708599738 544971.616934636,142331.800599738 544962.361934636,142335.315689827 544960.189567857,142344.618689827 544954.788567857,142350.044243235 544951.928649475,142354.095243235 544950.000649475,142358.937068202 544947.901878751,142366.937744911 544944.76338641,142385.89759784 544937.079520943,142395.719750516 544932.679151927,142400.441873082 544930.349833872,142401.383459124 544929.833071966,142406.6210572 544926.62519655,142411.537774632 544923.415397158,142417.71510139 544913.944561111,142420.94010139 544909.840561111,142430.748006338 544899.541762468,142434.142006338 544896.595762468,142435.850811608 544895.156577415,142442.412433986 544889.795267093,142444.49999699 544886.911016326,142448.144051661 544882.271951045,142451.044051661 544878.864951045,142458.695997856 544871.097938249,142461.294997856 544868.817938249,142470.134593455 544862.150512483,142473.842593455 544859.761512483,142480.427575735 544855.976426197,142484.421575735 544853.942426197,142489.150076298 544851.738001417,142493.336076298 544849.961001417,142496.826705207 544848.581227778,142511.506705207 544843.199227778,142514.871735859 544842.055231706,142523.461735859 544839.360231706,142525.522241398 544838.746075403,142534.194241398 544836.296075403,142536.004975022 544835.808868122,142551.475975022 544831.852868122,142553.240283912 544831.424409705,142591.914597139 544822.526741457,142598.275411491 544820.886724263,142602.704241198 544819.56048906,142609.292780478 544817.391524059,142615.583028111 544815.122934514,142618.279611019 544814.046641119,142629.45972981 544809.13013732,142631.782307416 544808.154985648,142635.957307416 544806.483985648,142639.000194615 544805.341955696,142647.786194615 544802.259955696,142650.862354779 544801.254874545,142659.482354779 544798.642874545,142662.638869661 544797.761220477,142669.973869661 544795.884220477,142673.205218145 544795.133066603,142686.423218145 544792.367066603,142687.75030488 544792.101834821,142698.39630488 544790.073834821,142699.656984019 544789.844824773,142722.099112074 544785.965804094,142733.29544748 544783.954693204,142742.05873277 544781.922771676,142754.323614283 544778.786704663,142756.030972713 544778.371387876,142775.118972713 544773.964387876,142777.273451963 544773.500199454,142820.991420451 544764.751150994,142837.522686446 544760.894948819,142844.015926493 544759.102611734,142844.917722818 544758.79792222,142856.218794477 544754.493944632,142862.453241526 544752.427321221,142870.586241526 544750.121321221,142875.768629606 544748.849245243,142884.617629605 544747.008245243,142891.189843383 544745.942777802,142898.301843383 544745.111777802,142904.543626015 544744.64541731,142909.018626015 544744.49841731,142913.016385389 544744.473703009,142917.509385389 544744.565703009,142920.324904418 544744.676294693,142934.674637347 544745.510159451,142951.608031998 544746.00958361,142954.88878603 544746.178321099,142959.36978603 544746.507321098,142963.711087962 544746.953378548,142973.246087962 544748.214378548,142976.745416005 544748.761522577,143008.170847153 544754.438302843,143008.88998273 544754.51936845,143021.086540262 544755.473370056,143024.601737995 544755.83181325,143030.442737995 544756.56681325,143035.06301864 544757.295205003,143043.91001864 544758.974205003,143047.065941417 544759.643768134,143051.457941418 544760.674768134,143054.738751825 544761.523564261,143062.852751825 544763.819564261,143067.512244981 544765.303734333,143071.745244981 544766.805734333,143075.849809935 544768.399302906,143086.996807532 544773.108079562,143087.534249256 544773.311425527,143089.290648579 544773.84542239,143090.815558434 544774.236272392,143107.033443497 544777.814719857,143118.197003623 544780.058732056,143128.554297917 544781.738142783,143139.336028988 544783.109031866,143155.49321177 544784.379932768,143159.259616953 544784.772085376,143168.171616953 544785.928085376,143172.417029432 544786.602995092,143183.484514979 544788.689249054,143192.757948937 544779.743577493,143204.458134003 544772.068508402,143207.452134003 544770.482508402,143217.877333406 544765.935907155,143228.870152028 544763.017979079,143233.093152028 544762.233979079,143243.749216234 544761.035368472,143248.714216234 544760.834368472,143254.046196302 544760.808205104,143259.265196302 544760.968205104,143261.486708783 544761.06929489,143267.979708783 544761.46129489,143273.365665557 544761.982012954,143277.793665557 544762.572012954,143286.575211331 544764.280368101,143288.189141126 544764.695595339,143290.978852032 544763.072253793,143293.057985348 544761.906229274,143304.973985348 544755.470229274,143306.958931092 544754.43608835,143315.965931092 544749.91308835,143320.623980386 544747.770101801,143324.766980386 544746.033101801,143328.238303539 544744.678091384,143332.286621343 544743.212671752,143331.143833831 544736.493747471,143330.870339244 544734.763796825,143329.055339244 544722.344796825,143328.854637586 544720.869286613,143325.924637586 544697.601286613,143325.764871004 544696.23097339,143324.324871004 544682.80797339,143324.122032336 544680.613710979,143322.960032336 544665.647710979,143322.826631958 544663.548552757,143322.182631958 544650.533552757,143322.117601971 544648.824943242,143321.877601971 544639.818943242,143321.867525705 544636.245919223,143321.955512321 544632.05717934,143321.77043356 544623.714398257,143321.835470129 544618.513217395,143322.062470129 544613.706217395,143325.292360964 544595.19794376,143326.484360964 544591.32194376,143331.729639817 544578.575059709,143339.219112454 544567.003378636,143340.243112454 544565.701378636,143353.146702893 544552.866696871,143356.357813689 544550.944227443,143360.724831274 544538.647255457,143361.729831274 544536.667255457,143369.036727648 544525.046930776,143378.339104196 544514.952948864,143378.62159647 544514.697818407,143378.155226847 544510.94165225,143374.102410185 544499.277113056,143373.007822462 544495.79929448,143372.379651765 544495.697483851,143371.381974607 544495.588885555,143357.48234826 544494.649991326,143321.795908582 544493.464324709,143319.758089386 544493.486147736,143312.228365485 544493.914767793,143305.455111006 544493.993943295,143300.977111006 544493.843943295,143289.193680868 544492.511203977,143284.954680868 544491.688203977,143277.00659789 544489.158340983,143276.426513723 544492.170388535,143269.854826429 544528.086878837,143262.821219905 544569.56192616,143261.774448627 544574.656037193,143260.721448627 544579.009037193,143259.680215806 544582.861773835,143256.522215806 544593.422773835,143253.23631489 544602.318708031,143251.34831489 544606.579708031,143242.008489251 544622.205107828,143239.454489251 544625.493107828,143227.30524964 544637.866099411,143212.639192566 544647.118218831,143208.199192566 544649.246218831,143196.474866603 544653.702425409,143184.171866906 544656.142465323,143179.675866906 544656.648465323,143170.088599017 544657.109394209,143154.457599017 544656.859394209,143151.617868051 544656.760142918,143133.53063217 544655.784641096,143121.290168068 544655.570511698,143117.660703231 544655.419032874,143113.177703231 544655.123032874,143107.001712981 544654.457450287,143102.611712981 544653.799450287,143095.331388678 544652.336502036,143090.549388678 544651.126502036,143082.051072215 544648.429483166,143077.618072215 544646.726483166,143064.106773636 544639.899296896,143060.325773636 544637.481296896,143047.050786815 544626.672758007,143045.727786815 544625.316758007,143036.688110558 544614.062347654,143034.335110558 544610.473347654,143028.538883685 544599.852309461,143026.696883685 544595.714309461,143023.774244043 544588.04423974,143022.350244043 544583.58823974,143020.893544138 544578.392131302,143019.795544138 544573.853131302,143018.702925331 544568.485649998,143017.507925331 544561.277649998,143016.664393871 544554.004344462,143016.365393871 544549.523344462,143016.210125035 544545.822610653,143016.132125035 544541.297610653,143016.121841841 544539.646480492,143016.191841841 544525.002480492,143016.261381424 544522.112214787,143017.058381424 544503.730214787,143017.200830162 544501.332617029,143019.015830162 544477.292617029,143019.117369181 544476.079044054,143020.974562841 544455.859387166,143012.017779016 544452.276044828,143000.730737927 544445.227455997,142997.412737927 544442.720455997,142987.84396231 544434.105295537,142984.80596231 544430.856295537,142980.583823832 544425.930029936,142973.422760994 544416.803672518,142963.91211261 544406.161519492,142956.819698158 544398.788915133,142953.893144036 544398.712152108,142953.503590826 544398.72251716,142949.462514144 544399.061408476,142943.263353163 544400.055538669,142939.663325572 544400.908414059,142939.238212841 544401.067454297,142938.976680873 544401.182858452,142934.137324015 544403.643690941,142929.769658667 544406.096795439,142926.652207278 544408.069938545,142927.198338169 544417.889249693,142925.064366118 544432.647879358,142924.028366118 544436.823879358,142915.90414904 544456.750498323,142913.47414904 544460.887498323,142904.900927942 544472.683961512,142901.762927942 544476.219961512,142891.805707433 544485.566812929,142887.590707433 544488.855812929,142878.925179228 544494.69435923,142874.856179228 544497.04135923,142865.016904724 544501.797485204,142860.704904724 544503.506485204,142847.670574801 544507.348275577,142843.780574801 544508.120275577,142828.558456297 544509.552401342,142824.221456297 544509.516401342,142812.959042535 544508.571318809,142808.504042535 544507.856318809,142801.33147797 544506.342329521,142796.85147797 544505.165329521,142792.415950273 544503.852523393,142785.163950273 544501.460523393,142780.337883578 544499.683012291,142776.195883578 544497.994012292,142769.99669122 544495.130423081,142762.606498738 544491.299245068,142753.019033808 544492.117962512,142748.573033808 544492.206962512,142737.253736829 544491.576554482,142732.073736829 544490.892554482,142726.515986909 544489.944923928,142722.013986909 544489.001923928,142716.444900051 544487.610979171,142712.012900051 544486.321979171,142705.652238558 544484.158660047,142701.408238558 544482.499660047,142694.009414955 544479.134523818,142690.072414955 544477.079523818,142679.933733744 544470.709227259,142675.879733744 544467.685227259,142667.222163891 544460.129017531,142664.090163891 544456.941017531,142659.697634783 544452.059750107,142652.455628131 544443.266417622,142641.010698615 544431.023595985,142639.761894936 544429.654199985,142629.709894936 544418.354199985,142628.440663554 544416.889717001,142624.411663554 544412.117717001,142623.024567126 544410.425340713,142617.422567126 544403.383340713,142616.24429217 544401.862555039,142587.346543277 544363.559802966,142579.850312854 544354.229311137,142574.837307005 544348.538475379,142574.380798773 544348.074877161,142573.482496771 544347.244537906,142549.020471652 544356.242809497,142550.021077146 544359.147463265,142550.918398887 544361.399953959,142552.790926445 544365.346434407,142555.308399385 544369.926610982,142556.270059459 544371.516809313,142561.662565615 544379.462687748,142562.879228922 544381.069659085,142570.613225941 544390.565318825,142575.437699753 544397.198978876,142578.976699753 544402.670978876,142582.557765089 544408.83131752,142584.646765089 544412.85331752,142586.320905962 544416.287716222,142588.242905962 544420.499716222,142590.33468939 544425.566294951,142591.93868939 544429.893294952,142594.177100548 544436.995188031,142595.319100548 544441.364188031,142597.171443512 544450.977463505,142597.691443512 544455.114463505,142598.181470333 544468.251908484,142597.961470333 544472.606908484,142596.463179074 544484.202538685,142595.538179074 544488.617538685,142593.630550396 544495.886498114,142592.234550396 544500.293498114,142590.935346415 544504.046682994,142589.305346415 544508.380682994,142588.272299374 544510.979346306,142585.389299374 544517.855346306,142582.234135189 544524.457345184,142574.877841918 544538.096816766,142566.515543165 544556.479839147,142565.689384712 544558.235390683,142562.681384712 544564.418390683,142562.065802624 544565.6546654,142557.979802624 544573.6746654,142557.417031773 544574.757404369,142548.333031773 544591.892404369,142546.951454584 544594.382994845,142541.529148564 544603.734736294,142537.069563867 544611.85072305,142534.069380318 544616.841347935,142531.432380318 544620.865347935,142517.631297233 544636.598188404,142514.707297233 544639.115188404,142502.521690675 544647.656705143,142488.889548013 544653.624217341,142487.827548013 544653.968217341,142471.094086772 544657.34629167,142454.030188709 544656.852840409,142450.487188709 544656.342840409,142437.358589199 544653.203168585,142436.668505703 544655.630630956,142436.057505703 544657.361630956,142430.350660746 544669.785574852,142428.170660746 544673.576574852,142419.197109221 544686.030415834,142416.135109221 544689.473415834,142409.409371599 544696.136811157,142405.887371599 544699.210811157,142402.268389353 544702.175774301,142400.057389353 544703.874774301,142396.224336385 544706.632730849,142392.514336385 544709.128730849,142387.07501259 544712.461220768,142383.11001259 544714.664220768,142378.13946881 544717.188877144,142374.00746881 544719.097877144,142369.377380348 544721.051532704,142365.163380348 544722.665532704,142362.440763496 544723.64850335,142353.223763496 544726.77650335,142347.769688407 544728.399502076,142343.262688407 544729.556502076,142334.011762954 544731.32086733,142329.585762954 544731.87986733,142315.948708737 544732.351079396,142312.327708737 544732.146079396,142295.844939335 544729.346473507,142291.729939335 544728.163473507,142279.117488381 544723.267889072,142275.080488381 544721.264889072,142267.421421377 544716.88546041,142263.505421377 544714.32946041,142259.236675046 544711.326353663,142255.485675046 544708.487353663,142253.718508244 544707.107825706,142250.508508244 544704.523825706,142247.621056086 544701.867004341,142245.975822652 544701.957295237,142240.968343436 544702.064613072,142231.945343436 544701.956613072,142227.873273827 544701.797150336,142223.220273827 544701.488150336,142219.237330033 544701.116734362,142218.770797848 544701.060643959,142217.679033889 544703.500397184,142215.572033889 544707.588397184,142212.403307436 544713.141517084,142209.949307436 544717.045517084,142207.152428394 544721.18259421,142204.501428394 544724.835594209,142200.876344685 544729.440953974,142198.836344685 544731.833953974,142193.932660441 544737.058559252,142190.716660441 544740.172559252,142186.630675434 544743.848621242,142176.739173701 544752.112476139,142167.720757309 544760.225367705,142166.358606458 544761.421283697,142164.679487397 544762.859928684,142170.162971622 544764.26110987,142175.060971622 544766.00310987,142188.609375456 544772.411032792,142200.613171778 544781.384861211,142210.593018116 544792.566247069,142218.150393529 544805.50868886,142222.983512571 544819.695361583,142224.899376364 544834.559754896,142223.821479538 544849.508295329,142221.544108779 544857.668809516,142222.493621098 544859.640797719,142227.243951322 544872.326051932,142228.423951322 544876.625051932,142229.892583503 544883.079044115,142230.100737768 544884.225522696,142231.196159123 544886.044706521,142233.455159123 544889.945706521,142237.190809781 544897.302319979,142238.782809781 544900.917319979,142242.894833084 544912.915500558,142243.985833084 544917.269500558,142244.120402998 544918.028161309,142252.480830463 544925.766827503,142255.642471805 544928.871720914,142262.190471805 544935.693720914,142264.486464574 544938.196863015,142270.491464574 544945.048863015,142274.302826793 544949.770221228,142276.978826793 544953.374221228,142280.526715791 544958.598447604,142282.577715791 544961.910447604,142287.223684419 544970.654294399,142289.141684419 544974.922294399,142293.528899252 544988.140168692)))
+ </op></test></case><case><desc>
+ #19 Polygon - gid: 2519
+ </desc>
+ <a>POLYGON((142639.054985 546593.084985,142638.983985 546578.467985,142637.899985 546522.015985,142637.938985 546492.896985,142637.097985 546450.097985,142637.323985 546438.583985,142638.161985 546425.106985,142640.378985 546405.030985,142641.014985 546394.820985,142641.331985 546384.084985,142641.148985 546370.582985,142641.244985 546363.069985,142641.584985 546354.071985,142642.254985 546344.252985,142643.286985 546335.313985,142644.522985 546326.394985,142648.737985 546299.023985,142650.292985 546287.844985,142651.629985 546274.394985,142652.493985 546269.090985,142653.436985 546264.685985,142655.832985 546255.985985,142657.324985 546251.745985,142659.948985 546245.601985,142667.821985 546229.388985,142674.155985 546214.865985,142677.911985 546205.201985,142679.361985 546200.940985,142681.914985 546192.299985,142684.417985 546181.838985,142686.974985 546168.576985,142689.654985 546153.350985,142694.878985 546120.270985,142697.142985 546106.960985,142699.359985 546095.284985,142703.219985 546077.702985,142704.624985 546066.572985,142705.358985 546062.133985,142706.612985 546057.889985,142708.252985 546054.334985,142710.527985 546050.471985,142713.073985 546046.712985,142719.613985 546037.284985,142728.418985 546025.982985,142730.690985 546022.264985,142732.054985 546018.591985,142731.686985 546016.665985,142724.660985 546009.840985,142717.691985 546000.791985,142714.941985 545996.960985,142712.738985 545993.180985,142711.360985 545988.681985,142714.052985 545984.850985,142718.418985 545982.397985,142721.651985 545982.033985,142726.312985 545982.683985,142730.716985 545984.217985,142731.895985 545984.775985,142735.810985 545986.892985,142743.367985 545991.857985,142750.724985 545997.160985,142754.125985 545999.891985,142761.223985 546006.385985,142764.713985 546009.110985,142768.178985 546010.905985,142772.098985 546007.143985,142774.143985 546005.180985,142774.113985 545999.566985,142773.537985 545995.098985,142768.381985 545968.404985,142767.068985 545958.959985,142766.199985 545949.980985,142765.940985 545945.485985,142765.750985 545931.805985,142766.233985 545927.222985,142767.634985 545923.521985,142769.098985 545922.223985,142773.757985 545921.006985,142778.814985 545921.309985,142783.002985 545922.544985,142787.137985 545924.271985,142795.346985 545928.342985,142811.462985 545935.870985,142815.626985 545937.556985,142820.576985 545938.996985,142825.031985 545939.950985,142829.609985 545940.709985,142834.206985 545941.141985,142838.717985 545941.118985,142843.041985 545940.509985,142847.204985 545939.284985,142851.513985 545937.443985,142855.628985 545935.100985,142859.326985 545932.341985,142862.380985 545929.253985,142863.263985 545928.078985,142865.435985 545924.062985,142866.966985 545919.494985,142867.782985 545914.817985,142867.736985 545909.942985,142866.022985 545905.989985,142862.937985 545902.315985,142859.441985 545899.133985,142854.047985 545895.067985,142850.262985 545892.621985,142837.767985 545885.201985,142825.932985 545878.689985,142819.751985 545874.844985,142805.176985 545864.270985,142794.436985 545857.191985,142790.895985 545854.458985,142787.923985 545851.332985,142786.743985 545846.536985,142788.245985 545842.303985,142791.773985 545840.313985,142796.261985 545838.819985,142801.083985 545837.998985,142802.463985 545837.997985,142805.463985 545837.994985,142805.357985 545834.997985,142805.262985 545828.997985,142805.520985 545820.191985,142805.877985 545815.707985,142807.383985 545802.278985,142807.642985 545798.275985,142807.624985 545793.783985,142807.104985 545784.785985,142806.722985 545767.919985,142806.979985 545763.439985,142807.737985 545759.086985,142809.044985 545754.836985,142810.745985 545750.671985,142812.747985 545746.584985,142814.955985 545742.585985,142818.189985 545737.179985,142820.793985 545733.508985,142829.696985 545723.146985,142832.161985 545719.462985,142832.897985 545718.055985,142834.513985 545713.945985,142835.658985 545709.600985,142836.487985 545705.114985,142837.768985 545696.409985,142838.248985 545691.931985,142838.646985 545682.880985,142839.065985 545678.409985,142839.638985 545675.304985,142841.047985 545671.041985,142844.967985 545662.753985,142846.660985 545658.581985,142847.581985 545654.707985,142847.927985 545650.295985,142847.867985 545645.793985,142847.478985 545641.250985,142846.840985 545636.716985,142845.620985 545630.188985,142844.442985 545625.866985,142839.491985 545613.185985,142838.170985 545608.906985,142836.982985 545602.039985,142836.453985 545597.426985,142836.195985 545592.787985,142836.317985 545588.225985,142836.932985 545583.845985,142837.506985 545581.601985,142839.204985 545577.594985,142841.653985 545573.762985,142844.599985 545570.136985,142850.556985 545564.008985,142855.814985 545562.041985,142856.880985 545561.642985,142856.292985 545557.919985,142855.390985 545553.820985,142854.135985 545549.506985,142852.244985 545544.563985,142850.361985 545540.478985,142844.125985 545527.977985,142834.606985 545507.539985,142826.544985 545491.433985,142821.485985 545479.737985,142819.843985 545475.499985,142818.480985 545471.212985,142817.540985 545466.871985,142817.213985 545464.155985,142817.030985 545459.662985,142817.207985 545455.117985,142817.660985 545450.581985,142818.485985 545445.117985,142819.662985 545440.740985,142822.757985 545432.078985,142823.990985 545427.764985,142824.559985 545422.879985,142823.987985 545418.543985,142822.645985 545414.208985,142819.284985 545405.255985,142813.283985 545388.284985,142808.968985 545375.562985,142806.315985 545366.954985,142804.586985 545358.943985,142803.925985 545354.485985,142803.102985 545345.493985,142802.904985 545340.751985,142802.834985 545331.720985,142803.009985 545327.199985,142803.393985 545322.710985,142804.037985 545318.278985,142805.452985 545311.744985,142806.650985 545307.380985,142809.573985 545298.818985,142811.266985 545294.665985,142813.004985 545291.210985,142815.400985 545287.398985,142820.519985 545279.931985,142826.842985 545268.466985,142829.338985 545264.782985,142832.164985 545262.098985,142833.230985 545261.695985,142835.992985 545262.345985,142846.160985 545258.387985,142854.318985 545254.575985,142858.403985 545252.356985,142869.987985 545245.401985,142875.644985 545242.347985,142912.309985 545224.049985,142926.307985 545216.705985,142951.656985 545202.846985,142972.226985 545191.088985,142985.020985 545184.003985,142989.016985 545181.876985,142993.087985 545179.977985,142997.011985 545178.519985,143001.320985 545177.379985,143005.734985 545176.563985,143019.196985 545174.781985,143029.936985 545172.947985,143038.782985 545171.290985,143053.861985 545168.157985,143058.239985 545167.099985,143064.886985 545165.078985,143073.421985 545161.808985,143077.597985 545159.899985,143081.563985 545157.748985,143085.208985 545155.311985,143088.708985 545151.406985,143090.492985 545147.010985,143090.813985 545144.727985,143089.978985 545140.305985,143088.118985 545135.725985,143086.667985 545131.314985,143086.751985 545128.175985,143088.720985 545124.505985,143091.965985 545121.090985,143095.880985 545118.148985,143099.492985 545116.076985,143103.605985 545114.680985,143108.081985 545114.016985,143112.694985 545113.606985,143117.223985 545112.973985,143130.923985 545110.673985,143135.304985 545109.618985,143139.420985 545108.092985,143140.758985 545107.421985,143144.429985 545105.021985,143147.844985 545102.071985,143151.027985 545098.743985,143154.002985 545095.206985,143156.794985 545091.631985,143159.329985 545087.702985,143165.032985 545075.706985,143169.544985 545068.380985,143174.812985 545061.053985,143177.619985 545057.534985,143179.712985 545055.221985,143186.158985 545048.939985,143193.007985 545043.061985,143196.559985 545040.305985,143204.126985 545034.852985,143207.925985 545032.379985,143211.823985 545030.116985,143215.833985 545028.136985,143220.506985 545026.334985,143224.814985 545025.059985,143229.211985 545023.991985,143247.739985 545020.064985,143271.248985 545015.903985,143300.088985 545011.067985,143319.233985 545008.037985,143322.181985 545007.660985,143320.621985 545004.756985,143318.426985 545000.669985,143317.771985 544996.915985,143316.818985 544987.902985,143316.483985 544978.913985,143318.127985 544975.428985,143320.969985 544971.163985,143325.529985 544961.287985,143327.718985 544957.410985,143330.469985 544955.005985,143333.411985 544952.432985,143330.469985 544950.953985,143324.550985 544948.182985,143312.064985 544943.041985,143303.953985 544939.926985,143290.772985 544935.169985,143255.834985 544921.723985,143240.383985 544916.255985,143231.802985 544913.548985,143223.892985 544911.297985,143215.153985 544909.116985,143210.750985 544908.213985,143206.364985 544907.516985,143192.930985 544906.053985,143187.453985 544905.270985,143183.055985 544904.302985,143178.713985 544903.106985,143172.673985 544900.844985,143164.258985 544899.268985,143136.152985 544894.663985,143127.654985 544893.030985,143118.870985 544891.059985,143108.925985 544888.514985,143090.565985 544883.345985,143073.319985 544878.131985,143068.474985 544876.994985,143064.055985 544876.187985,143059.601985 544875.538985,143050.639985 544874.541985,143041.819985 544873.776985,143028.327985 544873.125985,143023.847985 544872.745985,143018.942985 544872.112985,143000.433985 544869.180985,142987.018985 544867.640985,142978.053985 544866.860985,142970.405985 544866.438985,142944.598985 544865.635985,142935.601985 544865.579985,142927.194985 544865.844985,142918.206985 544866.397985,142911.314985 544867.017985,142902.373985 544868.047985,142889.004985 544869.952985,142864.821985 544874.363985,142848.911985 544876.576985,142844.480985 544877.334985,142838.073985 544878.661985,142829.326985 544880.811985,142819.324985 544883.870985,142800.796985 544890.606985,142773.388985 544901.131985,142760.875985 544906.196985,142750.977985 544910.668985,142742.913985 544914.664985,142737.069985 544917.874985,142724.981985 544924.919985,142713.020985 544931.285985,142709.136985 544933.547985,142705.137985 544936.250985,142701.645985 544939.051985,142695.074985 544945.218985,142680.742985 544959.330985,142671.103985 544969.088985,142662.768985 544973.041985,142652.842985 544978.358985,142641.271985 544985.338985,142634.830985 544989.779985,142627.829985 544995.416985,142602.075985 545017.695985,142591.628985 545026.268985,142584.723985 545031.405985,142577.151985 545036.249985,142563.479985 545044.293985,142523.221985 545068.752985,142513.631985 545074.114985,142504.669985 545078.768985,142449.282985 545105.186985,142429.396985 545115.264985,142420.658985 545120.011985,142411.075985 545125.488985,142395.834985 545135.064985,142387.294985 545140.246985,142363.037985 545154.362985,142356.402985 545157.748985,142344.050985 545163.201985,142339.898985 545164.937985,142325.684985 545170.528985,142317.212985 545173.561985,142303.543985 545177.834985,142294.845985 545180.144985,142285.745985 545182.081985,142259.033985 545187.070985,142250.228985 545188.919985,142245.783985 545190.007985,142229.466985 545194.445985,142212.023985 545198.894985,142204.533985 545201.039985,142191.663985 545205.131985,142180.193985 545209.385985,142171.855985 545212.806985,142165.722985 545215.687985,142161.756985 545217.791985,142154.012985 545222.384985,142140.577985 545231.018985,142133.147985 545236.100985,142115.719985 545248.557985,142102.333985 545258.662985,142094.400985 545265.020985,142087.591985 545270.906985,142078.153985 545279.664985,142065.304985 545292.272985,142061.463985 545295.538985,142058.168985 545298.695985,142057.175985 545300.454985,142056.463985 545305.537985,142057.721985 545310.009985,142062.115985 545310.976985,142066.520985 545310.561985,142076.187985 545308.856985,142080.192985 545308.520985,142089.203985 545308.646985,142098.195985 545309.362985,142102.054985 545309.894985,142106.458985 545310.741985,142110.825985 545311.824985,142130.830985 545317.813985,142152.372985 545324.883985,142164.840985 545328.945985,142177.742985 545332.933985,142189.838985 545336.203985,142198.607985 545338.303985,142203.018985 545339.200985,142207.448985 545339.939985,142216.683985 545340.889985,142225.692985 545341.292985,142234.270985 545341.415985,142251.656985 545340.922985,142291.579985 545340.124985,142300.184985 545339.602985,142309.174985 545338.801985,142313.628985 545338.177985,142321.257985 545336.558985,142325.609985 545335.368985,142334.166985 545332.488985,142341.767985 545329.286985,142345.811985 545327.301985,142349.793985 545325.177985,142357.421985 545320.738985,142361.221985 545318.337985,142368.622985 545313.204985,142382.291985 545302.859985,142389.289985 545297.184985,142392.681985 545294.234985,142397.402985 545289.625985,142406.329985 545279.577985,142412.737985 545273.259985,142419.291985 545267.086985,142429.992985 545257.467985,142440.308985 545248.759985,142441.612985 545247.714985,142446.109985 545245.262985,142446.338985 545248.994985,142446.199985 545253.571985,142445.640985 545258.488985,142444.609985 545263.241985,142443.857985 545265.512985,142442.012985 545269.516985,142439.699985 545273.376985,142437.056985 545277.103985,142431.323985 545284.203985,142427.990985 545287.884985,142424.744985 545290.998985,142418.000985 545297.012985,142412.625985 545302.081985,142402.843985 545311.388985,142393.281985 545319.861985,142386.339985 545325.596985,142383.071985 545328.078985,142375.719985 545333.293985,142368.108985 545338.125985,142364.187985 545340.316985,142359.849985 545342.473985,142355.742985 545344.307985,142347.378985 545347.681985,142328.337985 545354.886985,142316.107985 545358.925985,142307.469985 545361.469985,142299.454985 545363.561985,142286.275985 545366.538985,142276.143985 545368.318985,142267.208985 545369.345985,142248.532985 545370.511985,142219.161985 545371.185985,142203.715985 545371.164985,142199.205985 545371.018985,142194.733985 545370.628985,142188.003985 545369.399985,142183.639985 545368.295985,142179.306985 545367.017985,142170.748985 545364.137985,142165.665985 545362.193985,142149.185985 545354.923985,142140.126985 545351.437985,142131.579985 545348.557985,142127.240985 545347.464985,142122.210985 545346.513985,142117.678985 545345.875985,142113.128985 545345.532985,142108.629985 545345.592985,142105.518985 545345.933985,142101.168985 545346.844985,142096.841985 545348.164985,142092.578985 545349.812985,142088.422985 545351.707985,142084.414985 545353.767985,142080.190985 545356.407985,142076.653985 545359.241985,142073.333985 545362.356985,142067.997985 545368.049985,142062.268985 545375.019985,142056.981985 545382.321985,142054.076985 545386.833985,142049.685985 545394.701985,142044.122985 545405.734985,142038.521985 545418.021985,142023.289985 545452.443985,142017.545985 545464.659985,142014.837985 545469.791985,142005.253985 545486.555985,141988.171985 545519.134985,141977.076985 545541.374985,141973.492985 545549.619985,141971.566985 545555.125985,141970.306985 545559.444985,141965.979985 545576.568985,141962.918985 545589.719985,141960.635985 545598.142985,141955.825985 545613.701985,141951.434985 545626.601985,141950.141985 545630.915985,141948.934985 545636.962985,141948.704985 545641.499985,141949.123985 545646.141985,141950.244985 545650.549985,141951.056985 545652.499985,141953.342985 545656.425985,141956.355985 545660.122985,141959.910985 545663.037985,141962.039985 545664.112985,141966.156985 545665.317985,141970.561985 545665.989985,141975.146985 545666.276985,141979.804985 545666.327985,141986.719985 545666.292985,141991.278985 545665.940985,142000.535985 545664.247985,142005.024985 545663.753985,142009.282985 545664.058985,142010.548985 545664.383985,142014.485985 545666.064985,142018.279985 545668.475985,142021.898985 545671.414985,142025.310985 545674.677985,142028.480985 545678.062985,142030.032985 545679.813985,142032.714985 545683.400985,142034.950985 545687.417985,142036.704985 545691.669985,142037.858985 545695.616985,142038.718985 545700.121985,142039.089985 545704.851985,142038.672985 545709.406985,142037.721985 545712.350985,142035.592985 545716.121985,142032.841985 545719.745985,142029.638985 545723.145985,142026.149985 545726.245985,142022.543985 545728.968985,142018.629985 545731.298985,142014.527985 545733.136985,142010.234985 545734.681985,142001.549985 545737.362985,141997.219985 545738.546985,141983.982985 545741.310985,141979.609985 545742.365985,141969.681985 545745.217985,141965.394985 545746.710985,141961.337985 545748.534985,141959.777985 545749.404985,141955.834985 545752.283985,141952.703985 545755.965985,141951.963985 545758.506985,141952.751985 545762.553985,141954.762985 545766.861985,141957.561985 545770.888985,141959.982985 545773.460985,141963.411985 545776.158985,141967.224985 545778.496985,141971.289985 545780.580985,141985.212985 545786.896985,142000.150985 545792.668985,142008.343985 545796.429985,142016.334985 545800.578985,142022.250985 545804.295985,142046.437985 545822.371985,142052.748985 545826.682985,142056.617985 545828.963985,142064.603985 545833.129985,142070.922985 545836.248985,142083.286985 545841.758985,142087.295985 545843.769985,142092.594985 545847.153985,142096.154985 545849.929985,142099.578985 545852.884985,142104.802985 545857.704985,142111.182985 545864.060985,142117.370985 545870.603985,142120.682985 545874.288985,142142.202985 545899.659985,142165.737985 545927.016985,142172.879985 545934.881985,142182.253985 545944.598985,142186.214985 545948.917985,142202.883985 545967.751985,142211.384985 545977.403985,142225.593985 545992.922985,142238.418985 546008.296985,142250.230985 546021.879985,142259.725985 546033.693985,142269.350985 546046.564985,142278.361985 546059.624985,142298.361985 546090.836985,142309.584985 546107.625985,142341.472985 546156.462985,142356.456985 546178.710985,142366.251985 546193.812985,142376.758985 546209.595985,142385.270985 546221.615985,142387.634985 546225.427985,142392.256985 546234.208985,142394.167985 546238.328985,142395.821985 546242.520985,142397.123985 546246.785985,142398.005985 546251.510985,142398.388985 546255.983985,142399.224985 546283.243985,142399.697985 546292.227985,142400.941985 546305.891985,142401.545985 546310.351985,142403.237985 546319.045985,142405.506985 546327.777985,142408.303985 546336.338985,142410.310985 546341.331985,142418.668985 546358.807985,142424.819985 546375.738985,142426.239985 546379.047985,142430.073985 546387.302985,142432.170985 546391.346985,142434.510985 546395.185985,142437.187985 546398.706985,142440.399985 546401.785985,142444.036985 546404.428985,142451.744985 546409.342985,142464.608985 546418.886985,142474.778985 546427.251985,142481.544985 546433.292985,142484.647985 546436.537985,142486.778985 546439.146985,142489.315985 546442.826985,142491.601985 546446.723985,142493.656985 546450.776985,142496.820985 546458.222985,142498.276985 546462.456985,142499.496985 546466.785985,142503.472985 546484.744985,142506.642985 546502.467985,142509.386985 546520.985985,142510.336985 546525.363985,142510.840985 546527.218985,142512.350985 546531.439985,142518.183985 546543.729985,142519.807985 546547.903985,142520.462985 546550.160985,142521.369985 546554.533985,142521.977985 546559.000985,142522.344985 546563.520985,142522.608985 546574.349985,142522.280985 546578.872985,142521.351985 546583.333985,142520.542985 546585.903985,142517.219985 546589.425985,142514.512985 546586.565985,142511.824985 546583.070985,142509.171985 546579.181985,142498.742985 546562.904985,142494.176985 546555.142985,142490.162985 546547.838985,142484.052985 546535.786985,142480.174985 546526.738985,142475.650985 546514.011985,142472.138985 546503.403985,142468.153985 546490.503985,142463.423985 546476.206985,142461.831985 546471.994985,142459.996985 546467.916985,142456.960985 546462.582985,142454.434985 546458.849985,142451.705985 546455.233985,142445.862985 546448.329985,142442.104985 546444.394985,142428.626985 546432.421985,142418.075985 546422.798985,142411.737985 546416.428985,142408.499985 546412.663985,142405.701985 546409.137985,142400.377985 546401.856985,142392.425985 546390.103985,142387.707985 546382.429985,142380.885985 546369.973985,142378.896985 546365.914985,142377.106985 546361.786985,142375.751985 546358.075985,142374.507985 546353.777985,142373.513985 546349.392985,142370.442985 546330.776985,142368.191985 546312.914985,142365.265985 546293.674985,142363.190985 546283.190985,142361.213985 546274.351985,142359.975985 546270.025985,142358.455985 546265.821985,142356.394985 546261.322985,142354.263985 546257.363985,142351.945985 546253.483985,142345.725985 546243.935985,142343.151985 546240.252985,142316.274985 546206.202985,142310.966985 546198.936985,142307.937985 546194.352985,142294.814985 546172.627985,142290.329985 546164.823985,142287.005985 546158.186985,142275.101985 546130.634985,142271.989985 546124.071985,142267.678985 546116.171985,142261.093985 546105.453985,142258.578985 546101.726985,142253.279985 546094.447985,142243.571985 546081.658985,142236.439985 546072.727985,142230.606985 546065.874985,142222.765985 546057.102985,142213.581985 546047.200985,142208.292985 546041.857985,142201.735985 546035.693985,142192.537985 546027.675985,142181.948985 546019.303985,142169.155985 546009.780985,142160.153985 546003.473985,142152.572985 545998.626985,142143.089985 545992.867985,142131.365985 545986.142985,142125.570985 545982.482985,142118.447985 545976.998985,142096.890985 545958.860985,142084.848985 545949.882985,142068.162985 545938.270985,142059.174985 545932.384985,142042.151985 545921.873985,142030.906985 545914.386985,142023.584985 545909.156985,142018.526985 545905.193985,142015.089985 545902.283985,142007.356985 545895.188985,141997.952985 545885.504985,141978.411985 545863.813985,141970.581985 545855.994985,141963.934985 545849.915985,141957.167985 545844.315985,141949.939985 545838.921985,141943.509985 545834.697985,141935.696985 545830.192985,141927.585985 545826.245985,141920.060985 545823.365985,141915.730985 545822.001985,141911.337985 545820.882985,141906.909985 545820.080985,141900.193985 545819.531985,141895.681985 545819.481985,141891.151985 545819.648985,141882.152985 545820.550985,141875.954985 545821.657985,141871.598985 545822.759985,141835.260985 545833.483985,141828.631985 545835.167985,141819.750985 545837.019985,141815.382985 545838.106985,141811.145985 545839.501985,141805.788985 545841.924985,141801.806985 545844.098985,141797.952985 545846.526985,141794.270985 545849.180985,141790.809985 545852.035985,141787.313985 545855.407985,141784.315985 545858.759985,141778.763985 545865.928985,141772.511985 545874.919985,141762.709985 545891.608985,141755.482985 545903.062985,141753.252985 545906.957985,141749.978985 545913.877985,141748.666985 545918.387985,141748.768985 545921.000985,141751.304985 545924.740985,141755.513985 545927.302985,141756.711985 545927.533985,141760.888985 545927.181985,141765.244985 545925.936985,141769.700985 545924.397985,141774.175985 545923.166985,141780.031985 545922.354985,141784.630985 545921.853985,141789.209985 545921.625985,141793.664985 545921.852985,141796.571985 545922.361985,141800.821985 545923.878985,141804.901985 545926.294985,141808.334985 545929.381985,141809.624985 545931.053985,141811.674985 545934.859985,141813.219985 545939.084985,141814.397985 545943.557985,141815.347985 545948.104985,141816.698985 545956.095985,141817.630985 545969.607985,141818.087985 545974.081985,141819.103985 545980.957985,141820.067985 545985.702985,141821.975985 545989.546985,141822.773985 545990.339985,141826.310985 545992.454985,141830.547985 545993.897985,141842.968985 545996.468985,141847.509985 545997.140985,141856.800985 545997.868985,141861.005985 545998.965985,141862.625985 545999.768985,141866.109985 546002.355985,141869.292985 546005.647985,141872.113985 546009.408985,141874.515985 546013.402985,141875.853985 546016.074985,141877.440985 546020.184985,141878.605985 546024.508985,141879.480985 546028.971985,141881.195985 546039.871985,141881.790985 546044.335985,141882.519985 546053.351985,141883.053985 546057.813985,141883.746985 546061.327985,141884.939985 546065.652985,141886.382985 546069.934985,141888.045985 546074.147985,141889.902985 546078.266985,141893.383985 546084.869985,141898.220985 546092.482985,141903.490985 546099.802985,141906.468985 546103.551985,141909.433985 546106.937985,141929.822985 546129.167985,141938.792985 546139.272985,141943.052985 546143.689985,141949.747985 546149.692985,141964.954985 546162.315985,141973.916985 546169.572985,141988.206985 546180.523985,141994.103985 546185.427985,142000.869985 546191.374985,142006.985985 546197.194985,142010.101985 546200.434985,142022.076985 546213.883985,142031.699985 546223.931985,142040.717985 546233.530985,142049.725985 546243.589985,142058.221985 546253.642985,142066.572985 546264.239985,142071.784985 546271.572985,142087.501985 546294.715985,142092.258985 546301.453985,142100.397985 546312.229985,142108.079985 546321.503985,142125.060985 546340.016985,142133.543985 546348.938985,142143.242985 546358.327985,142163.998985 546377.305985,142173.789985 546386.599985,142191.111985 546403.493985,142204.870985 546417.738985,142212.229985 546425.909985,142226.183985 546442.081985,142233.915985 546451.275985,142245.281985 546465.234985,142249.865985 546470.532985,142260.724985 546482.422985,142276.240985 546498.862985,142283.837985 546507.332985,142289.597985 546514.245985,142305.035985 546533.383985,142311.432985 546541.561985,142319.545985 546552.352985,142325.631985 546560.748985,142331.597985 546569.324985,142352.206985 546601.281985,142358.484985 546610.374985,142363.806985 546617.636985,142370.309985 546626.052985,142375.995985 546633.031985,142381.874985 546639.851985,142388.050985 546646.513985,142394.445985 546652.851985,142406.112985 546663.869985,142412.850985 546669.837985,142418.240985 546674.127985,142443.384985 546692.509985,142450.371985 546698.165985,142457.310985 546704.523985,142460.526985 546707.694985,142466.605985 546714.329985,142470.300985 546719.095985,142475.145985 546726.700985,142483.032985 546740.420985,142501.498985 546775.196985,142510.156985 546792.354985,142514.053985 546800.467985,142518.478985 546810.391985,142522.272985 546820.003985,142525.007985 546828.570985,142528.781985 546841.541985,142532.004985 546851.396985,142534.853985 546859.935985,142539.055985 546873.966985,142541.391985 546882.669985,142542.843985 546889.440985,142543.557985 546893.873985,142544.550985 546902.823985,142545.871985 546922.835985,142546.360985 546938.371985,142546.544985 546956.386985,142546.739985 546960.876985,142547.362985 546967.620985,142548.653985 546976.536985,142550.299985 546985.393985,142551.436985 546990.406985,142554.966985 547003.451985,142555.834985 547007.422985,142557.197985 547016.310985,142558.683985 547029.428985,142559.219985 547035.983985,142568.219985 547036.121985,142572.728985 547036.024985,142581.714985 547035.501985,142591.573985 547035.199985,142595.869985 547034.180985,142597.816985 547032.770985,142600.066985 547029.423985,142601.774985 547025.338985,142603.042985 547020.781985,142603.973985 547016.020985,142604.933985 547009.293985,142605.238985 547004.860985,142605.137985 547000.377985,142603.950985 546984.754985,142603.663985 546971.251985,142603.742985 546962.255985,142604.252985 546952.983985,142607.153985 546916.365985,142607.517985 546898.350985,142607.740985 546893.863985,142608.381985 546887.057985,142608.975985 546882.544985,142609.858985 546878.111985,142611.177985 546873.849985,142613.093985 546869.621985,142615.298985 546865.709985,142622.403985 546854.127985,142624.843985 546849.369985,142627.944985 546842.588985,142629.542985 546838.792985,142626.214985 546838.483985,142622.666985 546837.753985,142618.842985 546836.097985,142616.469985 546834.131985,142613.916985 546830.574985,142611.830985 546826.313985,142607.626985 546815.755985,142606.081985 546811.513985,142604.771985 546807.169985,142603.734985 546802.764985,142603.006985 546798.336985,142602.576985 546792.392985,142602.860985 546774.337985,142602.460985 546761.163985,142602.555985 546756.672985,142603.363985 546746.339985,142604.441985 546737.393985,142606.371985 546725.978985,142608.360985 546717.192985,142611.192985 546706.280985,142617.884985 546683.219985,142621.661985 546670.257985,142624.159985 546661.045985,142628.692985 546643.625985,142629.847985 546640.178985,142633.051985 546631.746985,142634.346985 546627.450985,142636.677985 546616.584985,142638.067985 546607.674985,142638.672985 546602.065985,142639.054985 546593.084985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>MULTIPOLYGON(((141877.641440651 545899.174621292,141877.705860312 545899.294221892,141882.11313423 545909.102129247,141883.65813423 545913.327129247,141885.747003497 545919.984419878,141886.925003497 545924.457419878,141887.812773449 545928.219509296,141888.066269442 545929.432821165,141894.314514948 545931.768203543,141895.934514948 545932.571203543,141907.337873997 545939.553978711,141910.821873997 545942.140978711,141920.028110834 545950.223119104,141923.211110834 545953.515119104,141929.291070623 545960.64543261,141932.112070623 545964.40643261,141936.386163135 545970.755561895,141938.788163135 545974.749561895,141941.577933878 545979.821814492,141942.915933878 545982.493814492,141945.819306375 545989.059178425,141947.406306375 545993.169178425,141949.858608213 546000.673761355,141951.023608213 546004.997761355,141952.204821483 546010.079457345,141953.079821483 546014.542457345,141953.569534375 546017.314933424,141955.284534375 546028.214933424,141955.538513823 546029.962978582,141956.133513823 546034.426978582,141956.547015579 546038.291492288,141957.068194351 546044.737236885,141957.152341479 546044.950412983,141957.325820875 546045.335206539,141958.314278321 546047.210180545,141960.358181963 546050.427099798,141963.321167297 546054.54266956,141964.077791321 546055.495182476,141965.289877034 546056.879372097,141985.095300574 546078.473102308,141985.912357827 546079.378606053,141993.853063383 546088.324072012,141995.14764048 546089.666360049,141998.751538347 546092.897756449,142012.507137526 546104.315980189,142020.334324491 546110.654062739,142033.82710591 546120.994122174,142036.162117405 546122.858525009,142042.059117405 546127.762525009,142043.617847653 546129.095246693,142050.383847653 546135.042246693,142052.571936283 546137.04351867,142058.687936283 546142.86351867,142061.043334899 546145.20649664,142064.159334899 546148.44649664,142066.115612895 546150.560407407,142077.185044474 546162.992372778,142085.866152691 546172.056882324,142086.361437562 546172.579033734,142095.379437562 546182.178033734,142096.589433311 546183.497183789,142105.597433311 546193.556183789,142107.009124291 546195.178809091,142115.505124291 546205.23180909,142117.128865006 546207.221228377,142125.479865006 546217.818228377,142127.704781975 546220.789974659,142132.916781975 546228.122974659,142133.82969278 546229.436845684,142149.16407951 546252.016454521,142152.833135573 546257.213448373,142159.230621321 546265.683691205,142164.630419358 546272.202530961,142179.877347538 546288.825013818,142186.825973671 546296.133235243,142194.640460695 546303.69795518,142214.608251982 546321.955265984,142215.633435038 546322.910364135,142225.424435038 546332.204364135,142226.155519359 546332.907799244,142243.477519359 546349.801799244,142245.057240492 546351.389192419,142258.816240492 546365.634192419,142260.60074664 546367.547415314,142267.95974664 546375.718415314,142269.0138111 546376.914096464,142282.9678111 546393.086096464,142283.584044577 546393.80949635,142291.316044577 546403.00349635,142292.07492763 546403.920548225,142302.732765765 546417.009828757,142305.924370984 546420.698555731,142315.690325376 546431.391731689,142330.784633982 546447.384927968,142332.07318498 546448.785390755,142339.67018498 546457.255390755,142341.457996817 546459.323254338,142347.217996817 546466.236254338,142347.972808202 546467.156920281,142363.410808202 546486.294920281,142364.109985813 546487.175085122,142370.506985813 546495.353085122,142371.380279621 546496.491796764,142379.493279621 546507.282796764,142380.270548754 546508.335632093,142386.356548754 546516.731632093,142387.199582483 546517.918727702,142393.165582483 546526.494727702,142394.627797238 546528.67719577,142409.419852589 546551.614248168,142404.98285813 546539.132013755,142404.451559945 546537.584042013,142400.939559945 546526.976042013,142400.480225918 546525.54043112,142396.715362473 546513.353043807,142392.913672221 546501.861972869,142390.068674641 546498.500366966,142389.992878233 546498.421000584,142378.817000124 546488.493059598,142378.086926955 546487.835905028,142367.535926955 546478.212905028,142364.909602613 546475.69828352,142358.571602613 546469.32828352,142354.874841929 546465.33279835,142351.636841929 546461.56779835,142349.749969065 546459.284105417,142346.951969065 546455.758105417,142345.160602985 546453.406947759,142339.836602985 546446.125947759,142338.260264246 546443.885413098,142330.308264246 546432.132413098,142328.535037117 546429.384346234,142323.817037117 546421.710346234,142321.927671973 546418.457063955,142315.105671973 546406.001063955,142313.537302447 546402.97633277,142311.548302447 546398.91733277,142310.087612695 546395.75238239,142308.297612695 546391.62438239,142306.656350972 546387.510673792,142305.301350972 546383.799673792,142303.708958315 546378.927898727,142302.464958315 546374.629898727,142301.363692554 546370.358469992,142300.369692554 546365.973469992,142299.514129585 546361.6004171,142296.443129585 546342.9844171,142296.031539165 546340.154443547,142293.900397619 546323.243537151,142291.369310869 546306.600300969,142289.797647252 546298.659423202,142288.737110427 546293.917852643,142288.308553476 546293.200509688,142283.551347786 546285.897969508,142282.92865993 546285.0069985,142257.404927525 546252.671429486,142255.713626811 546250.444615783,142250.405626811 546243.178615783,142248.3936298 546240.283994795,142245.3646298 546235.699994795,142243.741022598 546233.13120077,142230.618022598 546211.40620077,142229.788732319 546209.998915712,142225.303732319 546202.194915712,142223.270189057 546198.409454597,142219.946189057 546191.772454597,142218.157262755 546187.933471266,142206.773016008 546161.584448555,142205.134661009 546158.129267366,142202.766978579 546153.79043851,142198.029228403 546146.079093577,142197.157513648 546144.787292029,142193.087439501 546139.196412672,142184.390821916 546127.739774611,142178.566384699 546120.446161489,142174.083672624 546115.179570395,142167.308082543 546107.599481607,142159.422241281 546099.097129671,142155.940166917 546095.579503782,142151.391959633 546091.303897605,142144.611559904 546085.39334694,142136.289796977 546078.813896639,142125.237365832 546070.586561238,142118.417472551 546065.808393395,142112.902198665 546062.282139269,142104.960071982 546057.458907426,142094.048646282 546051.200007919,142091.316510646 546049.554652727,142085.521510646 546045.894652727,142079.817683837 546041.910549586,142072.694683837 546036.426549586,142070.161582194 546034.387340126,142050.293055847 546017.670017174,142041.002535456 546010.743402652,142026.189911721 546000.435109064,142018.921797166 545995.675415887,142002.7487187 545985.68920736,142000.586631141 545984.302515005,141989.341631141 545976.815515005,141987.314120471 545975.41699534,141979.992120471 545970.186995341,141977.328827015 545968.19398906,141972.270827015 545964.23098906,141970.064148329 545962.43342474,141966.627148329 545959.52342474,141964.385724723 545957.547698138,141956.652724723 545950.452698138,141953.551828905 545947.438436458,141944.147828905 545937.754436458,141942.230328359 545935.704442536,141924.014894557 545915.484854254,141918.751360697 545910.228714887,141914.688959696 545906.513454516,141910.802596742 545903.297312571,141906.884006543 545900.37300771,141904.155584242 545898.580650665,141900.513236871 545896.480461889,141897.716337661 545895.119426113,141896.158027917 545894.523023181,141892.501650467 545894.889514175,141891.765476277 545895.020999304,141891.418106088 545895.108878539,141877.641440651 545899.174621292)),((142522.12691348 546663.927344692,142525.878983767 546668.376621498,142529.573983767 546673.142621498,142533.555039396 546678.79803713,142538.400039396 546686.40303713,142538.732285602 546686.951715847,142539.164401741 546685.379234028,142545.856401741 546662.318234028,142545.879636654 546662.23833088,142547.048457102 546658.227144582,142546.952449096 546658.28076391,142532.429577358 546662.867582888,142522.12691348 546663.927344692)),((142563.173159694 546422.597768887,142563.306554182 546420.452473534,142563.615151908 546416.874751041,142565.635474263 546398.579761601,142566.083844628 546391.381866262,142566.316980211 546383.486145069,142566.155872751 546371.599407718,142566.155107006 546369.624724347,142566.251107006 546362.111724347,142566.298470045 546360.238042892,142566.638470045 546351.240042892,142566.758978497 546348.966228369,142567.428978497 546339.147228369,142567.749862505 546335.651431536,142568.781862505 546326.712431536,142568.996946745 546325.018830018,142570.232946745 546316.099830018,142570.396767822 546314.979910454,142574.528541313 546288.149359514,142575.805994456 546278.965662607,142576.99781354 546266.976158737,142577.605675477 546262.336726435,142578.469675477 546257.032726435,142579.155638085 546253.391084627,142580.098638085 546248.986084627,142581.12902275 546244.772205971,142583.52502275 546236.072205971,142585.085329672 546231.090819493,142586.577329672 546226.850819493,142588.352000116 546222.288772705,142590.976000116 546216.144772706,142592.48278958 546212.840536993,142599.687446415 546198.003867201,142604.801459699 546186.278130712,142607.426212139 546179.524774062,142607.868379264 546178.225412599,142609.43144457 546172.934990623,142611.089485303 546166.005400484,142613.216029802 546154.975978058,142615.676026847 546140.99989037,142620.79705315 546108.57195199,142620.94099002 546107.694304261,142623.20499002 546094.384304261,142623.459485201 546092.970207417,142625.676485201 546081.294207417,142626.104627492 546079.202304987,142629.236043552 546064.93894821,142630.215513188 546057.179875575,142630.629732904 546054.337680869,142631.363732904 546049.898680869,142633.433075569 546040.881607426,142634.687075569 546036.637607426,142638.510425367 546026.472770429,142640.150425367 546022.917770429,142642.480430748 546018.466523724,142641.027357955 546015.14555981,142639.649357955 546010.64655981,142636.858689639 545997.307991374,142636.527659805 545983.684641682,142638.667197159 545970.226275604,142643.206666449 545957.377211197,142649.996200436 545945.561650871,142652.688200436 545941.730650871,142663.754572282 545929.217634588,142677.316104529 545919.464429706,142681.682104529 545917.011429706,142693.426179898 545911.879893636,142696.091415905 545900.670772273,142697.492415905 545896.969772273,142705.889871009 545880.948038762,142715.414212808 545870.187671046,142715.095917569 545869.251483659,142713.915917569 545864.45548366,142711.827420359 545850.073698504,142712.551757998 545835.559123076,142716.061734334 545821.456725019,142717.563734334 545817.223725019,142723.160850488 545805.035697335,142730.839253034 545794.039431495,142732.423638146 545792.465251846,142732.229913007 545789.113061844,142732.124214445 545786.484233213,142731.742214445 545769.618233213,142731.846088725 545763.62459162,142732.103088725 545759.14459162,142733.091845837 545750.573637772,142733.849845837 545746.220637772,142736.051277823 545737.041214111,142737.358277823 545732.791214111,142739.612245794 545726.480420921,142741.313245794 545722.315420921,142743.392610534 545717.679213852,142745.394610534 545713.592213852,142747.091156317 545710.33335266,142749.299156317 545706.33435266,142750.593646243 545704.082876687,142753.827646243 545698.676876687,142757.017309888 545693.78754534,142759.621309888 545690.11654534,142763.473053418 545685.188206237,142763.719391077 545679.586190791,142763.97417557 545675.88301874,142764.39317557 545671.41201874,142765.311343032 545664.799224985,142765.884343032 545661.694224985,142768.427830273 545651.768387062,142769.836830273 545647.505387062,142771.122607947 545644.29092145,142769.627987702 545640.4627495,142767.829230953 545635.309494721,142766.508230953 545631.030494721,142764.268758247 545621.692167086,142763.080758247 545614.825167086,142762.471320045 545610.584678423,142761.942320045 545605.971678423,142761.569706987 545601.591706649,142761.311706987 545596.952706649,142761.222789487 545590.783002569,142761.344789487 545586.221002568,142762.046551039 545577.797461739,142762.661551039 545573.417461739,142764.272420575 545565.259904795,142764.846420575 545563.015904795,142768.451340483 545552.339073997,142770.149340483 545548.332073997,142770.531903099 545547.60567335,142767.066219406 545540.164593055,142759.477943146 545525.004982854,142757.708431209 545521.208619544,142752.649431209 545509.512619544,142751.551624273 545506.833836891,142749.909624273 545502.595836891,142748.369517131 545498.224430932,142747.006517131 545493.937430932,142745.17982804 545487.085615164,142744.23982804 545482.744615164,142743.078730528 545475.837064976,142742.751730528 545473.121064976,142742.276117764 545467.208206167,142742.093117764 545462.715206167,142742.087793899 545456.744405281,142742.264793899 545452.199405281,142742.579218995 545447.664979929,142743.032218995 545443.128979929,142743.501544877 545439.384778174,142744.326544877 545433.920778174,142746.058895095 545425.641931808,142746.440700134 545424.222084185,142742.574413931 545413.288115987,142742.258216828 545412.375237292,142737.943216828 545399.653237293,142737.295828758 545397.652771653,142734.642828758 545389.044771653,142733.004052335 545382.777770118,142731.275052335 545374.766770118,142730.39806615 545369.944181358,142729.73706615 545365.486181358,142729.2381615 545361.321847849,142728.4151615 545352.329847849,142728.168278677 545348.622848739,142727.970278677 545343.880848739,142727.90723787 545341.333298509,142727.83723787 545332.302298509,142727.891109263 545328.820038693,142728.066109263 545324.299038693,142728.282894716 545320.807647582,142728.666894716 545316.318647582,142729.173441485 545311.926230933,142729.817441485 545307.494230933,142730.73712472 545302.404984802,142732.15212472 545295.870984802,142733.128689816 545291.890606991,142734.326689816 545287.526606991,142735.673200147 545283.149723014,142738.596200148 545274.587723014,142740.12311926 545270.506845414,142741.81611926 545266.353845414,142744.266591111 545260.962168915,142746.004591111 545257.507168915,142749.506386092 545251.299483692,142751.902386092 545247.487483692,142753.541574429 545244.99128141,142756.602947282 545240.525707843,142761.168560631 545232.247239227,142764.752112802 545226.398902209,142767.248112802 545222.714902209,142777.68985613 545210.401301622,142780.51585613 545207.717301622,142792.291920722 545198.576243048,142805.643305572 545191.944865233,142806.709305572 545191.541865233,142819.295518248 545188.157532351,142820.513152317 545187.588566786,142821.183881269 545187.224222223,142831.382030154 545181.101283212,142834.358861949 545179.405276062,142840.015861949 545176.351276062,142842.154490622 545175.240706808,142878.139161168 545157.282231378,142890.894082364 545150.59040817,142915.054824443 545137.381061669,142935.007701726 545125.975814653,142935.893060169 545125.477660471,142948.687060169 545118.392660471,142949.781054504 545117.798643081,142953.777054504 545115.671643081,142957.311543596 545113.908131947,142961.382543596 545112.009131947,142966.965898379 545109.67409755,142970.889898379 545108.21609755,142977.829755463 545106.014522654,142982.138755463 545104.874522654,142987.687026808 545103.629627821,142992.101026808 545102.813627821,142995.892894258 545102.212567732,143007.959724981 545100.615249922,143016.719596759 545099.11938355,143018.248987647 545098.832903706,143020.662952108 545092.718408498,143022.631952108 545089.048408498,143034.351990238 545072.843499495,143037.596990238 545069.428499495,143046.909646142 545061.133280502,143050.824646142 545058.191280502,143058.561995631 545053.092908939,143062.173995631 545051.020908939,143075.387740364 545045.056303639,143079.500740364 545043.660303638,143092.60041902 545040.492862518,143097.07641902 545039.828862518,143099.449103684 545039.54767643,143101.172981562 545036.376335872,143105.684981562 545029.050335872,143108.650602588 545024.598863184,143113.918602588 545017.271863184,143116.181237624 545014.285211233,143118.988237624 545010.766211233,143122.008219297 545007.212708468,143124.101219297 545004.899708468,143127.367650635 545001.510105772,143133.813650635 544995.228105772,143137.31405608 544992.026252749,143144.16305608 544986.148252749,143147.031765936 544983.806712825,143150.583765936 544981.050712825,143152.71192648 544979.459064256,143158.471531126 544975.308525848,143152.488954432 544973.36863557,143151.290852891 544973.14424959,143124.026374215 544968.677127825,143121.99971731 544968.316446016,143113.50171731 544966.683446016,143111.234393337 544966.211338712,143102.450393337 544964.240338712,143100.277112445 544963.71855575,143090.332112445 544961.17355575,143088.600937133 544960.708422577,143070.240937133 544955.539422577,143068.861417602 544955.136734781,143053.880810284 544950.60763316,143053.161057972 544950.438725341,143051.908121465 544950.209913447,143050.045946936 544949.938572794,143043.252308486 544949.182797573,143036.770444719 544948.620595103,143024.713379063 544948.038831855,143021.989139953 544947.857631867,143017.509139953 544947.477631867,143014.248691155 544947.129138722,143009.343691155 544946.496138722,143007.208594828 544946.189324592,142990.285346989 544943.508522675,142979.490357485 544942.269291678,142972.736217625 544941.681647607,142967.173223031 544941.374693669,142943.1990916 544940.628724454,142936.550379826 544940.587340897,142930.68011804 544940.772379481,142923.870913325 544941.191325877,142918.967690534 544941.632416726,142911.957397573 544942.439999966,142901.028620542 544943.997283252,142878.280006558 544948.146650008,142875.154627162 544948.64881862,142860.404282733 544950.700516434,142858.413860331 544951.041012977,142854.636083924 544951.823455507,142849.26098959 544953.144645952,142843.121410858 544955.022367542,142827.055332059 544960.863316742,142800.904758162 544970.905450071,142790.397929902 544975.15839382,142783.07867129 544978.465296681,142777.633670208 544981.163489181,142774.012250742 544983.152667224,142762.746978398 544989.718173814,142760.219205152 544991.126769516,142749.907137747 544996.615158539,142747.05567702 544999.291304986,142733.734838985 545012.407664625,142724.461345351 545021.795645835,142714.509975712 545030.252045505,142703.242610105 545036.854084988,142696.565524036 545040.020794194,142689.943985687 545043.567713336,142681.965999583 545048.380291592,142679.697345719 545049.944503952,142675.897007748 545053.004424698,142651.14402007 545074.417479465,142649.653387682 545075.673487137,142639.206387682 545084.246487137,142636.395792489 545086.443173381,142629.490792489 545091.580173381,142625.140699585 545094.584218452,142617.568699585 545099.428218452,142615.184279799 545100.891647667,142601.969416944 545108.666688393,142562.164704472 545132.850290716,142559.823579005 545134.215365924,142550.233579005 545139.577365924,142548.196955126 545140.675204652,142539.234955126 545145.329204653,142536.958074485 545146.462997124,142482.383727063 545172.493385305,142474.761779489 545176.356102174,142482.406079363 545179.630725143,142494.771377493 545188.192249236,142505.179836294 545199.048780818,142513.212896402 545211.763742002,142518.547521275 545225.825821154,142520.969187589 545240.669534466,142521.198187589 545244.401534466,142521.304423008 545251.27162819,142521.165423008 545255.84862819,142520.719953948 545262.043952184,142520.160953948 545266.960952184,142518.93644197 545274.387915388,142517.90544197 545279.140915388,142515.808118995 545286.817941304,142515.056118995 545289.088941304,142511.974344504 545296.900268538,142510.129344504 545300.904268538,142506.347002978 545308.067395254,142504.034002978 545311.927395254,142500.87826191 545316.761526421,142498.23526191 545320.488526421,142495.409062494 545324.221232926,142489.676062494 545331.321232926,142486.919842444 545334.543836362,142483.586842444 545338.224836361,142479.912126979 545342.007023169,142476.666126979 545345.121023169,142474.661850396 545346.974931165,142468.697811973 545352.293396033,142464.203470399 545356.531873697,142454.541347208 545365.724817935,142452.584128009 545367.522024945,142443.022128009 545375.995024945,142441.04960024 545377.682871661,142434.107600241 545383.417871661,142431.701765061 545385.323937958,142428.433765061 545387.805937958,142426.46390746 545389.252026981,142419.11190746 545394.467026981,142415.918336539 545396.61138019,142408.307336539 545401.44338019,142404.693715607 545403.597791806,142400.772715607 545405.788791806,142397.580305623 545407.473168062,142393.242305623 545409.630168062,142390.430997905 545410.956111498,142386.323997905 545412.790111498,142383.800762344 545413.862000919,142375.436762344 545417.236000919,142373.921850366 545417.828091793,142354.880850366 545425.033091793,142351.857572356 545426.103759784,142339.627572356 545430.142759784,142337.296611591 545430.870700603,142328.658611591 545433.414700603,142326.411210068 545434.038779898,142318.396210068 545436.130779898,142315.980343142 545436.718751866,142302.801343142 545439.695751866,142299.253317627 545440.407712063,142289.121317627 545442.187712063,142284.708190846 545442.828409761,142275.773190846 545443.855409761,142271.882365889 545444.20024013,142253.206365889 545445.36624013,142250.25361744 545445.492245229,142220.88261744 545446.166245229,142219.060016947 545446.185915684,142203.614016947 545446.164915683,142201.2893183 545446.125716645,142196.7793183 545445.979716645,142192.690018858 545445.735396753,142188.218018858 545445.345396753,142181.260662092 545444.40885739,142174.530662092 545443.17985739,142169.610029942 545442.109423296,142165.246029942 545441.005423296,142162.422688099 545440.232250626,142158.089688099 545438.954250626,142155.385672467 545438.100829672,142146.827672467 545435.220829672,142143.957663255 545434.189573698,142138.874663255 545432.245573698,142135.395019772 545430.81372461,142120.566269665 545424.27215827,142119.500301508 545423.861962333,142118.932465517 545424.64621397,142118.416616784 545425.447422053,142115.945297515 545429.875647972,142111.755470398 545438.185258358,142106.938614375 545448.752069634,142091.875059809 545482.79340861,142091.161457398 545484.35735578,142085.417457398 545496.57335578,142083.87780535 545499.661265107,142081.16980535 545504.793265107,142079.948570884 545507.01578929,142071.042744047 545522.593552343,142054.94650702 545553.292493106,142045.071599927 545573.0868089,142043.375666967 545576.98830646,142043.012707197 545578.025926654,142042.687487035 545579.140709098,142038.867375782 545594.258708892,142038.702371777 545594.967616983,142039.999868991 545595.408297746,142043.936868991 545597.089297746,142054.71169485 545602.764967093,142058.50569485 545605.175967093,142065.560500836 545610.256118784,142069.179500836 545613.195118784,142073.735272826 545617.211670854,142077.147272826 545620.474670854,142080.054005554 545623.411995294,142083.224005554 545626.796995294,142084.607367054 545628.315329402,142086.159367054 545630.066329402,142090.099232188 545634.902450304,142092.781232188 545638.489450304,142098.246747572 545646.923757937,142100.482747572 545650.940757937,142104.283592674 545658.817469041,142106.037592674 545663.069469041,142108.691283741 545670.623066138,142109.845283741 545674.570066138,142111.528646058 545681.553520292,142112.388646058 545686.058520292,142113.489339174 545694.257333541,142113.860339174 545698.987333541,142113.777659688 545711.68947355,142113.360659688 545716.24447355,142110.041757597 545732.461231854,142109.090757597 545735.405231854,142103.032253541 545749.223316403,142100.903253541 545752.994316403,142095.330868988 545761.46936879,142093.646225074 545763.688616171,142098.550316565 545766.24689881,142102.797775984 545768.343405524,142113.816242033 545773.253770126,142116.914930893 545774.720479237,142120.923930893 545776.731479237,142127.662708786 545780.559799026,142132.961708786 545783.943799026,142138.714106076 545788.009867193,142142.274106076 545790.785867193,142145.156612386 545793.151111169,142148.580612386 545796.106111169,142150.437720568 545797.763401057,142155.661720568 545802.583401057,142157.735963031 545804.572134176,142164.115963031 545810.928134176,142165.673621997 545812.526816921,142171.861621997 545819.069816921,142173.151904 545820.469275711,142176.463904 545824.154275711,142177.878853344 545825.774733029,142199.229459399 545850.946026069,142221.937738805 545877.342049,142227.64281376 545883.624660946,142236.231104288 545892.527201918,142237.528325489 545893.90631015,142241.489325489 545898.22531015,142242.377659016 545899.211304892,142259.046659016 545918.045304892,142259.16655617 545918.181104611,142267.189603148 545927.29043874,142280.910275395 545942.276089567,142283.18600906 545944.879684065,142295.517998649 545959.662686634,142306.82496395 545972.664930935,142308.690271817 545974.895819744,142318.185271817 545986.709819744,142319.789204154 545988.778400791,142329.414204154 546001.649400791,142331.082877465 546003.971869915,142340.093877465 546017.031869915,142341.509990276 546019.161057488,142361.117748757 546049.760925374,142371.936714522 546065.945512046,142372.383540469 546066.621821419,142403.978907861 546115.010649734,142418.663908489 546136.81470032,142419.380778098 546137.899267784,142428.93169517 546152.624939006,142438.590926089 546167.134469946,142446.478024591 546178.272031506,142449.009493112 546182.088746497,142451.373493112 546185.900746497,142454.002540033 546190.494510525,142458.624540033 546199.275510525,142460.294366874 546202.650869281,142462.205366874 546206.770869281,142463.933813868 546210.802105003,142465.587813868 546214.994105003,142467.553964639 546220.622969176,142468.855964639 546224.887969176,142470.850503657 546233.023701517,142471.732503657 546237.748701517,142472.732551988 546245.112533143,142473.115551988 546249.585533143,142473.353740942 546253.684992485,142474.164517048 546280.122500448,142474.518945557 546286.854394166,142475.484082272 546297.455381361,142475.577554892 546298.145593092,142476.412377262 546302.435159099,142477.515627436 546306.680897539,142478.821771293 546310.678715758,142479.005469818 546311.135719612,142486.329182661 546326.449096693,142489.161147018 546333.19831702,142494.444598775 546347.741337944,142496.432724976 546349.110054672,142509.296724976 546358.654054672,142512.252083793 546360.963456642,142522.422083793 546369.328456642,142524.729839064 546371.306366957,142531.495839064 546377.347366957,142535.750742092 546381.459251793,142538.853742092 546384.704251793,142542.734440379 546389.093662879,142544.865440379 546391.702662879,142548.527244314 546396.577600794,142551.064244314 546400.257600794,142554.007091707 546404.878853121,142556.293091707 546408.775853121,142558.494817299 546412.807189941,142560.549817299 546416.860189941,142562.683639161 546421.445755647,142563.173159694 546422.597768887)),((142330.52667867 545247.979227065,142325.921467736 545249.418839789,142322.795018404 545250.322209481,142314.097018404 545252.632209481,142310.460457631 545253.50156783,142301.360457631 545255.43856783,142299.515629523 545255.807129216,142273.62732534 545260.642287556,142266.855884877 545262.064251601,142264.544640488 545262.629973512,142252.558719513 545265.889979474,142288.558655642 545265.17039555,142294.585171074 545264.804812626,142300.630922759 545264.266142203,142303.567647948 545263.642920539,142303.739033976 545263.596057171,142307.610458301 545262.293065229,142310.660293699 545261.008290469,142311.629833117 545260.532391423,142313.271351219 545259.656805173,142318.51700937 545256.60417322,142319.800897554 545255.792958607,142324.602377781 545252.462868348,142330.52667867 545247.979227065)))
+ #20 Polygon - gid: 2520
+ </desc>
+ <a>POLYGON((158481.432985 510583.562985,158489.304985 510568.137985,158489.742985 510554.602985,158495.366985 510539.211985,158506.487985 510532.681985,158525.237985 510536.074985,158524.509985 510524.803985,158520.526985 510499.704985,158521.742985 510487.947985,158532.814985 510476.516985,158555.418985 510459.975985,158566.707985 510455.588985,158567.920985 510448.494985,158577.510985 510431.915985,158588.800985 510429.989985,158644.968985 510413.253985,158646.535985 510388.879985,158639.226985 510363.317985,158625.047985 510378.536985,158614.302985 510385.658985,158587.607985 510397.181985,158536.683985 510422.499985,158517.905985 510433.457985,158502.462985 510442.913985,158484.671985 510442.967985,158476.273985 510428.753985,158462.699985 510418.836985,158461.863985 510434.462985,158450.400985 510443.041985,158440.544985 510461.406985,158426.745985 510479.269985,158426.784985 510498.045985,158425.669985 510520.088985,158428.047985 510546.655985,158419.106985 510571.356985,158413.970985 510573.103985,158389.245985 510566.742985,158363.334985 510557.918985,158334.185985 510548.758985,158315.090985 510548.140985,158310.171985 510556.985985,158307.972985 510575.658985,158306.700985 510582.332985,158301.611985 510609.026985,158300.440985 510636.711985,158311.307985 510641.956985,158342.899985 510660.167985,158356.271985 510670.241985,158374.033985 510686.769985,158399.760985 510698.276985,158425.077985 510713.270985,158449.656985 510724.790985,158472.445985 510734.800985,158484.168985 510734.772985,158490.402985 510728.308985,158497.468985 510716.696985,158500.802985 510700.146985,158495.940985 510683.642985,158479.917985 510651.629985,158470.433985 510635.228985,158468.860985 510617.597985,158470.049985 510610.615985,158481.432985 510583.562985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>POLYGON( EMPTY)
+ #21 Polygon - gid: 2521
+ </desc>
+ <a>POLYGON((157869.315985 520433.637985,157856.178985 520399.216985,157834.269985 520383.765985,157837.129985 520350.383985,157849.976985 520324.750985,157884.267985 520315.565985,157928.572985 520281.754985,157969.435985 520288.428985,157995.223985 520278.692985,158043.757985 520253.692985,158088.001985 520238.144985,158131.710985 520233.176985,158161.789985 520246.081985,158177.706985 520240.052985,158184.062985 520208.456985,158173.722985 520194.194985,158141.933985 520199.529985,158117.247985 520208.894985,158058.927985 520207.808985,158035.018985 520213.752985,158019.448985 520203.796985,158016.808985 520180.093985,158007.024985 520150.917985,157971.159985 520128.594985,157943.413985 520100.672985,157936.868985 520070.503985,157895.009985 520063.382985,157866.038985 520063.004985,157831.988985 520058.373985,157815.198985 520060.788985,157814.667985 520062.114985,157805.376985 520079.736985,157805.131985 520111.664985,157793.919985 520111.222985,157780.766985 520105.771985,157761.185985 520162.929985,157768.122985 520191.771985,157788.795985 520203.076985,157809.040985 520190.281985,157822.093985 520173.832985,157849.686985 520173.862985,157865.312985 520195.645985,157879.132985 520236.462985,157885.168985 520252.260985,157867.794985 520266.033985,157813.882985 520286.000985,157795.021985 520258.542985,157778.258985 520254.263985,157744.848985 520244.603985,157712.168985 520249.566985,157684.754985 520260.299985,157665.400985 520256.359985,157651.387985 520249.849985,157648.472985 520254.899985,157628.126985 520277.906985,157632.442985 520323.400985,157637.148985 520356.136985,157613.676985 520373.009985,157611.837985 520410.654985,157615.005985 520437.710985,157641.030985 520432.938985,157674.459985 520440.319985,157700.786985 520441.225985,157736.859985 520437.355985,157780.029985 520431.763985,157800.420985 520439.994985,157800.694985 520446.629985,157801.243985 520459.900985,157790.056985 520479.632985,157799.422985 520483.141985,157816.313985 520487.074985,157838.367985 520462.690985,157869.315985 520433.637985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>POLYGON((157709.297185021 520330.935932945,157711.385825117 520345.464985685,157712.092131453 520359.056710976,157711.360558615 520364.661253674,157728.04149239 520362.871682146,157761.152813139 520358.582627117,157762.403736042 520343.98182,157762.978712539 520340.826547721,157761.146281582 520339.328652421,157752.062634395 520328.465608525,157748.887917416 520323.843829254,157739.832907843 520321.225709156,157731.711564547 520322.459069829,157712.097710963 520330.138193288,157709.297185021 520330.935932945))
+ </op></test></case><case><desc>
+ #22 Polygon - gid: 2522
+ </desc>
+ <a>POLYGON((153150.576985 520940.908985,153155.070985 520940.770985,153160.755985 520940.781985,153164.005985 520941.150985,153168.185985 520942.767985,153171.314985 520944.415985,153176.455985 520947.720985,153181.606985 520950.538985,153187.215985 520951.893985,153191.791985 520952.155985,153194.139985 520957.187985,153198.008985 520954.124985,153208.046985 520950.059985,153211.950985 520947.552985,153213.758985 520945.586985,153214.902985 520941.306985,153215.775985 520929.532985,153215.470985 520922.256985,153214.866985 520917.795985,153213.474985 520912.584985,153211.409985 520906.797985,153210.203985 520901.480985,153209.430985 520896.154985,153208.215985 520891.322985,153205.244985 520887.996985,153199.275985 520882.262985,153186.430985 520871.760985,153179.902985 520862.984985,153170.213985 520851.001985,153166.668985 520848.128985,153161.060985 520844.857985,153155.362985 520842.770985,153143.662985 520841.207985,153139.192985 520839.449985,153135.769985 520836.517985,153129.812985 520836.242985,153123.860985 520836.882985,153110.129985 520839.130985,153102.570985 520841.192985,153093.632985 520838.265985,153088.575985 520835.220985,153089.898985 520839.123985,153088.596985 520843.497985,153087.569985 520848.617985,153085.579985 520853.123985,153082.305985 520856.232985,153076.601985 520860.218985,153069.971985 520867.620985,153066.452985 520870.596985,153062.482985 520874.551985,153057.274985 520878.033985,153053.286985 520880.057985,153052.184985 520880.379985,153040.541985 520881.305985,153032.802985 520886.739985,153029.682985 520891.650985,153029.254985 520893.428985,153029.218985 520898.552985,153030.785985 520902.794985,153034.873985 520909.239985,153042.145985 520918.628985,153045.594985 520922.358985,153049.039985 520925.290985,153052.880985 520927.634985,153059.322985 520930.915985,153063.631985 520932.293985,153066.569985 520934.161985,153070.047985 520937.030985,153074.235985 520943.145985,153077.665985 520949.675985,153079.284985 520953.852985,153079.434985 520955.143985,153079.208985 520960.521985,153080.289985 520975.063985,153079.732985 520983.766985,153078.599985 520992.696985,153083.367985 520992.610985,153087.736985 520990.589985,153091.101985 520987.618985,153094.791985 520983.665985,153100.121985 520976.287985,153104.957985 520972.316985,153117.724985 520959.010985,153121.262985 520956.153985,153125.222985 520953.503985,153129.591985 520951.482985,153136.603985 520946.987985,153144.695985 520943.045985,153149.109985 520941.277985,153150.576985 520940.908985))</a>
+ #23 Polygon - gid: 2523
+ </desc>
+ <a>POLYGON((157261.821985 521212.042985,157255.517985 521158.904985,157227.447985 521110.819985,157193.480985 521080.159985,157154.275985 521056.383985,157110.994985 521055.200985,157075.666985 521042.824985,157053.089985 521016.601985,157057.673985 520992.362985,157039.358985 520960.816985,157034.486985 520926.714985,157029.615985 520902.356985,156995.512985 520877.997985,156966.282985 520873.125985,156937.052985 520873.125985,156907.821985 520863.382985,156873.719985 520843.895985,156855.757985 520822.219985,156849.459985 520818.621985,156836.865985 520811.424985,156793.392985 520777.048985,156766.039985 520737.460985,156728.760985 520722.977985,156710.216985 520732.313985,156697.880985 520740.090985,156693.336985 520756.434985,156668.342985 520768.289985,156629.440985 520764.303985,156604.591985 520776.688985,156602.502985 520800.105985,156616.097985 520861.121985,156609.482985 520899.994985,156586.751985 520928.161985,156566.844985 520935.459985,156563.162985 520961.757985,156557.828985 520985.666985,156555.414985 521022.078985,156562.430985 521063.373985,156560.713985 521082.827985,156553.817985 521111.533985,156555.075985 521118.090985,156559.312985 521117.477985,156590.563985 521112.953985,156645.119985 521099.542985,156681.977985 521069.587985,156745.810985 521043.788985,156797.577985 521042.609985,156839.811985 521059.742985,156900.802985 521071.653985,156963.644985 521085.826985,156980.767985 521096.550985,157015.014985 521117.998985,157045.450985 521159.433985,157060.450985 521187.893985,157099.503985 521191.189985,157138.274985 521174.733985,157191.026985 521169.054985,157232.239985 521201.560985,157257.694985 521216.582985,157261.821985 521212.042985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>POLYGON((156631.095656882 521014.295354275,156634.676048003 521011.38552151,156643.851709985 521005.00170818,156653.874255463 521000.052523643,156717.707255463 520974.253523643,156730.658675837 520970.335547184,156744.103293312 520968.808428927,156795.870293312 520967.629428927,156811.101565777 520968.83930815,156825.771566439 520973.110906117,156861.294856822 520987.521583157,156915.178256666 520998.044532044,156917.303575206 520998.491627719,156978.458943209 521012.284235063,156979.041998034 521006.300667263,156974.497999612 520998.474023844,156968.502649166 520985.401119564,156965.112860065 520971.424196327,156961.82603665 520948.41778169,156960.075376293 520948.125985,156937.052985 520948.125985,156925.040076572 520947.157667617,156913.337363025 520944.277719163,156884.106363025 520934.534719163,156870.611358984 520928.501103151,156836.509358984 520909.014103151,156825.461831265 520901.308096946,156815.970836196 520891.750303639,156806.709938491 520880.574531528,156799.653894166 520876.542266084,156790.346650885 520870.254837571,156746.873650885 520835.878837571,156738.67880068 520828.345749364,156732.07152263 520820.156651212,156725.478303553 520824.198807514,156700.484303553 520836.053807514,156688.345254244 520840.513209791,156689.302884797 520844.811171234,156691.07391221 520859.221895786,156690.035101518 520873.703829102,156683.420101518 520912.576829102,156680.22196136 520924.914800881,156674.980833687 520936.533072215,156667.848085666 520947.096099894,156645.117085666 520975.263099894,156635.733933358 520984.95783639,156634.659225174 520985.727668446,156632.28366467 520996.375826696,156631.095656882 521014.295354275))
+ #24 Polygon - gid: 2524
+ </desc>
+ <a>POLYGON((157198.781985 521343.128985,157167.375985 521333.418985,157161.598985 521339.797985,157164.714985 521379.602985,157160.482985 521417.461985,157147.909985 521451.287985,157146.214985 521493.149985,157153.755985 521521.467985,157172.019985 521558.894985,157193.474985 521583.667985,157202.389985 521607.497985,157215.882985 521640.795985,157219.352985 521646.857985,157226.292985 521658.980985,157246.124985 521668.670985,157251.301985 521666.452985,157261.655985 521662.017985,157262.134985 521635.987985,157274.849985 521612.355985,157297.013985 521594.829985,157301.610985 521571.282985,157288.486985 521545.637985,157285.205985 521539.225985,157270.572985 521505.724985,157269.548985 521478.705985,157307.010985 521424.848985,157283.533985 521402.041985,157242.954985 521367.245985,157198.781985 521343.128985))</a>
+ #25 Polygon - gid: 2525
+ </desc>
+ <a>POLYGON((153125.509985 521860.224985,153129.708985 521849.726985,153136.136985 521836.144985,153138.731985 521832.043985,153142.336985 521823.841985,153148.967985 521810.226985,153150.370985 521805.542985,153153.006985 521792.564985,153154.402985 521777.197985,153153.618985 521769.895985,153152.742985 521765.487985,153148.961985 521758.774985,153144.279985 521752.074985,153143.056985 521750.968985,153139.230985 521748.538985,153134.217985 521746.356985,153114.663985 521739.427985,153109.650985 521737.245985,153103.330985 521736.862985,153086.671985 521737.137985,153084.952985 521736.685985,153066.181985 521728.868985,153061.034985 521727.319985,153055.740985 521726.155985,153040.417985 521725.642985,153034.931985 521727.163985,153030.266985 521728.048985,153025.756985 521727.483985,153021.504985 521725.925985,153021.401985 521740.811985,153025.620985 521762.422985,153028.396985 521782.239985,153029.073985 521790.804985,153029.015985 521795.534985,153024.560985 521796.077985,153020.647985 521795.895985,153016.211985 521796.659985,153013.478985 521797.356985,153008.572985 521799.235985,152992.029985 521803.995985,152987.552985 521804.245985,152977.157985 521803.766985,152967.736985 521805.261985,152960.981985 521805.362985,152944.483985 521808.310985,152939.425985 521807.940985,152933.133985 521808.486985,152926.828985 521808.580985,152920.548985 521809.576985,152911.549985 521809.710985,152907.098985 521810.416985,152899.442985 521812.148985,152887.438985 521818.195985,152882.959985 521819.165985,152878.228985 521818.958985,152873.052985 521819.313985,152871.421985 521823.741985,152865.942985 521823.030985,152861.490985 521823.806985,152857.111985 521826.478985,152855.683985 521831.547985,152854.440985 521846.644985,152854.133985 521857.957985,152854.309985 521860.213985,152855.839985 521866.961985,152865.036985 521874.045985,152874.713985 521882.075985,152878.858985 521884.969985,152882.944985 521886.866985,152892.209985 521888.583985,152896.537985 521889.822985,152903.363985 521892.428985,152907.024985 521893.185985,152911.504985 521893.661985,152917.130985 521892.998985,152921.564985 521892.074985,152925.843985 521890.738985,152929.677985 521888.711985,152935.486985 521884.287985,152943.654985 521875.835985,152946.532985 521872.376985,152949.115985 521867.824985,152953.949985 521863.238985,152957.006985 521859.582985,152964.207985 521853.973985,152968.477985 521851.612985,152980.671985 521851.556985,152998.660985 521850.384985,153009.055985 521850.742985,153026.285985 521852.273985,153035.705985 521854.344985,153040.268985 521856.533985,153046.370985 521860.369985,153050.401985 521863.561985,153053.601985 521866.714985,153054.745985 521870.862985,153054.699985 521875.367985,153050.734985 521877.589985,153036.784985 521883.448985,153031.563985 521884.752985,153019.770985 521884.870985,153013.815985 521886.226985,153007.358985 521888.514985,153003.322985 521890.484985,152999.693985 521893.183985,152996.722985 521896.450985,152996.967985 521901.236985,153000.089985 521904.523985,153001.564985 521905.515985,153009.179985 521909.352985,153018.336985 521912.795985,153031.944985 521916.685985,153035.712985 521918.129985,153039.695985 521920.180985,153040.907985 521921.185985,153047.115985 521928.193985,153060.087985 521944.758985,153063.400985 521947.809985,153066.383985 521949.961985,153070.274985 521952.220985,153072.724985 521953.203985,153077.118985 521954.381985,153081.603985 521954.758985,153084.286985 521954.026985,153088.286985 521951.951985,153089.550985 521950.525985,153093.585985 521943.221985,153095.608985 521939.204985,153100.205985 521925.595985,153104.279985 521909.286985,153106.388985 521903.838985,153108.425985 521895.684985,153111.363985 521887.516985,153114.763985 521879.792985,153125.509985 521860.224985))</a>
+ #26 Polygon - gid: 2526
+ </desc>
+ <a>POLYGON((157932.417985 522155.088985,157944.275985 522122.344985,157937.133985 522096.277985,157945.879985 522082.105985,157967.232985 522064.316985,157982.322985 522039.440985,158000.496985 522030.869985,158009.669985 522049.652985,158032.912985 522049.223985,158031.812985 522022.937985,158031.808985 521996.628985,158045.642985 521975.762985,158053.730985 521989.459985,158063.586985 522015.397985,158083.101985 522030.407985,158106.174985 522054.201985,158119.395985 522059.194985,158140.518985 522030.272985,158150.745985 522010.370985,158145.639985 521985.458985,158099.206985 521948.659985,158056.817985 521923.022985,158031.872985 521941.121985,157999.283985 521920.250985,157975.074985 521885.098985,157938.659985 521874.332985,157900.267985 521882.868985,157865.445985 521868.290985,157831.202985 521856.440985,157809.952985 521830.208985,157790.517985 521806.917985,157761.250985 521788.022985,157741.055985 521775.447985,157745.715985 521787.101985,157755.892985 521825.646985,157771.649985 521862.272985,157803.680985 521930.634985,157790.216985 521978.321985,157761.706985 521986.509985,157746.491985 522006.246985,157772.072985 522027.363985,157800.108985 522054.487985,157816.264985 522079.960985,157836.791985 522101.384985,157844.809985 522124.051985,157862.795985 522126.713985,157889.746985 522125.611985,157916.287985 522156.041985,157921.886985 522165.446985,157932.417985 522155.088985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>POLYGON ((157858.57914185867 522008.3453885631, 157863.44444038192 522014.31809463963, 157875.59429040362 522033.47463893297, 157883.09502664296 522041.3031464203, 157889.22642461277 522032.95952942636, 157897.8743840681 522024.48253249004, 157909.60455873946 522014.7102252157, 157918.19873357913 522000.54265110625, 157926.94878182272 521988.85741432256, 157937.7967307582 521979.0885808789, 157946.77683321957 521973.72816572373, 157937.51531493766 521962.7907475608, 157930.72356280676 521952.92897421593, 157916.54584579886 521956.0812192769, 157901.29505984765 521957.86195211863, 157886.00122668233 521956.4995466379, 157875.2308944553 521953.23936733446, 157862.3952427896 521998.70087364636, 157858.57914185867 522008.3453885631))
+ #27 Polygon - gid: 2527
+ </desc>
+ <a>POLYGON((149946.529985 522862.341985,149966.481985 522827.471985,149971.102985 522795.593985,149955.120985 522773.194985,149939.535985 522777.700985,149919.295985 522795.320985,149896.669985 522804.718985,149890.945985 522795.728985,149898.974985 522765.579985,149920.144985 522727.754985,149913.346985 522702.453985,149883.812985 522706.570985,149875.847985 522712.141985,149848.867985 522733.237985,149847.635985 522734.278985,149844.408985 522737.640985,149838.341985 522744.662985,149834.815985 522747.431985,149824.076985 522739.434985,149816.408985 522734.720985,149812.125985 522731.061985,149802.392985 522719.891985,149798.360985 522714.476985,149788.169985 522702.133985,149784.674985 522696.954985,149783.454985 522694.846985,149781.555985 522690.771985,149780.739985 522687.972985,149780.149985 522683.502985,149780.341985 522679.629985,149782.374985 522664.239985,149783.390985 522660.945985,149785.909985 522654.333985,149795.392985 522633.032985,149790.732985 522630.377985,149788.450985 522629.815985,149783.947985 522629.324985,149779.954985 522629.236985,149763.488985 522630.011985,149759.275985 522628.393985,149754.474985 522624.634985,149751.188985 522621.536985,149746.287985 522615.463985,149744.142985 522613.104985,149740.146985 522609.133985,149736.579985 522606.158985,149729.751985 522601.390985,149726.308985 522598.550985,149724.513985 522596.066985,149722.709985 522591.906985,149718.527985 522593.569985,149708.661985 522598.397985,149706.262985 522599.786985,149703.001985 522602.886985,149699.606985 522606.922985,149697.587985 522611.774985,149695.862985 522616.877985,149695.505985 522618.594985,149695.224985 522623.072985,149695.263985 522627.591985,149695.661985 522632.426985,149694.473985 522637.230985,149693.005985 522640.325985,149689.515985 522643.252985,149684.312985 522644.206985,149680.293985 522644.052985,149676.063985 522642.545985,149670.784985 522639.861985,149661.685985 522633.920985,149656.545985 522630.804985,149652.902985 522628.165985,149645.682985 522622.646985,149640.918985 522618.527985,149634.442985 522612.273985,149630.501985 522609.470985,149628.581985 522608.498985,149624.066985 522606.761985,149622.208985 522606.930985,149618.814985 522609.527985,149615.790985 522613.190985,149614.293985 522615.264985,149612.288985 522619.274985,149611.210985 522622.320985,149608.321985 522633.178985,149608.059985 522634.774985,149607.991985 522646.548985,149608.575985 522654.849985,149610.186985 522665.048985,149611.456985 522683.114985,149612.528985 522687.482985,149614.559985 522694.254985,149615.501985 522696.106985,149618.647985 522699.565985,149620.744985 522700.686985,149625.134985 522700.457985,149632.636985 522698.591985,149637.449985 522697.223985,149639.247985 522696.603985,149643.376985 522694.800985,149645.312985 522693.777985,149650.006985 522690.545985,149656.345985 522685.250985,149661.382985 522680.526985,149666.521985 522677.267985,149670.359985 522674.578985,149674.725985 522673.240985,149679.179985 522672.528985,149684.103985 522674.538985,149686.519985 522678.573985,149687.938985 522682.812985,149688.390985 522687.254985,149688.214985 522693.094985,149687.852985 522697.577985,149687.255985 522702.043985,149686.243985 522707.382985,149684.070985 522716.888985,149682.707985 522721.337985,149682.734985 522723.346985,149684.410985 522727.516985,149689.127985 522735.746985,149690.970985 522739.883985,149691.645985 522744.652985,149686.699985 522813.572985,149681.925985 522845.160985,149688.863985 522854.293985,149701.543985 522856.177985,149715.246985 522845.580985,149731.486985 522843.349985,149755.832985 522836.089985,149821.720985 522854.503985,149835.820985 522867.489985,149866.684985 522900.071985,149876.926985 522910.894985,149904.293985 522940.758985,149925.071985 522967.911985,149942.329985 522987.487985,149953.714985 522987.343985,149958.169985 522985.691985,149957.918985 522959.085985,149944.105985 522944.060985,149933.546985 522923.664985,149934.447985 522897.200985,149946.529985 522862.341985))</a>
+ #28 Polygon - gid: 2528
+ </desc>
+ <a>POLYGON((149018.973985 523298.843985,149027.116985 523297.053985,149050.059985 523306.128985,149076.982985 523309.933985,149115.614985 523303.010985,149138.271985 523304.959985,149139.167985 523304.141985,149158.847985 523286.186985,149166.967985 523275.518985,149179.148985 523259.517985,149173.818985 523231.813985,149167.615985 523190.279985,149174.951985 523171.330985,149185.861985 523154.667985,149195.141985 523139.933985,149191.733985 523114.168985,149179.721985 523100.162985,149165.431985 523093.446985,149150.425985 523084.926985,149129.423985 523071.851985,149098.282985 523060.898985,149029.121985 523053.160985,148976.031985 523045.466985,148942.291985 523052.693985,148917.595985 523075.582985,148901.824985 523080.306985,148893.055985 523076.432985,148886.454985 523062.972985,148880.164985 523039.382985,148859.571985 523028.839985,148828.760985 523030.525985,148815.572985 523023.883985,148808.978985 523020.562985,148786.739985 522996.944985,148759.561985 522965.858985,148738.872985 522945.856985,148717.476985 522944.896985,148697.866985 522970.021985,148695.903985 522969.977985,148704.000985 522984.059985,148700.995985 523005.520985,148692.918985 523043.111985,148700.707985 523095.498985,148713.148985 523150.650985,148718.970985 523185.296985,148758.818985 523237.659985,148789.883985 523278.936985,148800.434985 523312.142985,148803.769985 523339.866985,148811.075985 523356.087985,148827.548985 523364.911985,148845.611985 523373.323985,148865.454985 523377.353985,148887.737985 523385.980985,148924.789985 523406.226985,148965.668985 523381.699985,148987.450985 523364.512985,148997.741985 523354.362985,149008.032985 523344.212985,149012.970985 523325.510985,149013.840985 523319.029985,149015.580985 523306.067985,149018.973985 523298.843985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>POLYGON((148775.869980556 523087.862959271,148786.310671602 523134.147421339,148787.111961451 523138.222062501,148789.865944358 523154.610673249,148818.502518906 523192.24109267,148818.744164544 523192.560396791,148849.809164544 523233.837396791,148856.532562419 523244.542695822,148861.362459323 523256.225144291,148871.913459323 523289.431144291,148874.797171531 523302.720185688,148880.382311599 523303.854495746,148892.533152951 523307.412775256,148914.816152951 523316.039775256,148922.993522609 523319.837088612,148937.737582778 523308.203346892,148939.909113975 523306.06156848,148941.247736763 523296.089598028,148943.633232915 523284.889671328,148947.695961634 523274.183449523,148951.088961634 523266.959449523,148958.027601821 523255.134279242,148967.002982154 523244.769824229,148977.715158376 523236.212449607,148989.806145024 523229.748130485,149002.871878778 523225.592895075,149011.014878778 523223.802895075,149025.71461237 523222.06709714,149040.468968727 523223.252057311,149054.703261967 523227.311621095,149069.369014283 523233.112593168,149075.580815666 523233.990500691,149097.719711958 523230.023127037,149093.438673537 523201.358182694,149092.638110024 523188.458374701,149094.064168772 523175.612663174,149097.674500032 523163.202527946,149104.777682602 523144.854898924,149096.773874623 523139.87205018,149081.455489755 523134.484224822,149020.782728186 523127.695921746,149018.365082411 523127.38557019,148978.587395614 523121.620840068,148978.156201803 523121.713200402,148968.57836411 523130.590230162,148954.812334417 523140.697832278,148939.116564598 523147.429102875,148923.345564598 523152.153102875,148910.37689581 523154.81782194,148897.141731088 523155.160623073,148884.05250663 523153.170823854,148871.517110822 523148.910430707,148862.748110822 523145.036430707,148851.284582351 523138.723834414,148841.092845365 523130.514702052,148832.483202211 523120.658972668,148825.717786074 523109.456718366,148823.588688058 523105.115306566,148819.851506172 523104.994912661,148807.1123677 523102.333626439,148795.025066567 523097.510220515,148781.837066567 523090.868220515,148775.869980556 523087.862959271))
+ #29 Polygon - gid: 2529
+ </desc>
+ <a>POLYGON((166489.986985 524726.636985,166376.609985 524695.830985,166378.076985 524731.146985,166372.372985 524775.920985,166374.920985 524808.597985,166378.349985 524862.041985,166381.024985 524891.550985,166405.372985 524894.150985,166442.538985 524856.230985,166488.936985 524799.975985,166481.518985 524768.759985,166489.986985 524726.636985))</a>
+ #30 Polygon - gid: 2530
+ </desc>
+ <a>POLYGON((165889.593985 526270.470985,165805.380985 526135.686985,165716.140985 526213.946985,165715.046985 526215.272985,165666.137985 526274.538985,165628.837985 526322.818985,165601.443985 526328.382985,165602.962985 526339.012985,165604.480985 526357.234985,165631.029985 526379.970985,165679.641985 526437.375985,165710.443985 526485.694985,165719.290985 526538.574985,165726.370985 526574.918985,165757.470985 526592.793985,165821.282985 526618.710985,165829.798985 526578.755985,165848.131985 526528.820985,165848.301985 526502.670985,165846.277985 526476.475985,165868.778985 526437.395985,165879.115985 526419.443985,165895.576985 526384.512985,165905.738985 526349.287985,165898.707985 526305.446985,165893.362985 526284.934985,165889.593985 526270.470985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>POLYGON((165703.241357534 526349.188222767,165736.877004846 526388.907928476,165742.884833191 526397.060452601,165773.686833191 526445.379452601,165776.198479916 526450.359932548,165781.281584047 526439.053159569,165803.782584047 526399.973159569,165803.783866343 526399.970932552,165812.584332105 526384.687391741,165825.177332734 526357.964464521,165829.030216992 526344.609037639,165825.224121391 526320.876561857,165820.786544579 526303.846893836,165820.786523568 526303.846813204,165819.910071494 526300.483320819,165788.513879131 526250.233307264,165770.138988224 526266.347370043,165724.751493689 526321.346148409,165703.241357534 526349.188222767))
+ #31 Polygon - gid: 2531
+ </desc>
+ <a>POLYGON((167187.935985 527215.129985,167246.663985 527205.580985,167280.107985 527210.602985,167314.083985 527213.149985,167354.196985 527218.563985,167363.609985 527204.834985,167358.459985 527177.204985,167344.405985 527172.240985,167323.325985 527164.793985,167304.557985 527167.748985,167285.789985 527170.703985,167260.854985 527176.007985,167211.198985 527149.591985,167165.408985 527140.439985,167141.660985 527146.308985,167119.062985 527137.503985,167119.967985 527139.010985,167078.296985 527188.560985,167105.238985 527267.140985,167090.957985 527316.213985,167094.770985 527321.819985,167082.593985 527377.599985,167065.952985 527417.668985,167056.312985 527449.383985,167043.546985 527485.510985,167019.927985 527525.916985,166982.769985 527539.710985,166961.717985 527606.388985,166933.263985 527657.009985,166899.206985 527710.191985,166916.325985 527722.287985,166973.067985 527744.810985,166978.160985 527695.099985,167043.308985 527684.770985,167080.550985 527644.941985,167101.716985 527610.077985,167109.672985 527576.692985,167099.068985 527561.394985,167097.537985 527527.027985,167105.044985 527510.384985,167137.888985 527502.771985,167160.386985 527500.228985,167174.041985 527468.108985,167205.365985 527466.936985,167200.090985 527446.692985,167182.286985 527416.893985,167214.905985 527399.163985,167245.980985 527379.346985,167258.755985 527325.736985,167261.469985 527296.920985,167237.119985 527273.314985,167201.524985 527264.407985,167192.491985 527252.494985,167172.090985 527216.630985,167187.935985 527215.129985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>POLYGON((167167.684716539 527339.467819639,167176.568351121 527334.639135708,167168.740671452 527331.710602359,167168.045301243 527337.816065116,167167.684716539 527339.467819639))
+ #32 Polygon - gid: 2532
+ </desc>
+ <a>POLYGON((142944.641985 528279.290985,142921.268985 528196.701985,142908.679985 528170.159985,142909.618985 528164.288985,142912.434985 528146.676985,142911.663985 528129.837985,142892.611985 528111.135985,142875.445985 528095.294985,142871.223985 528075.213985,142854.274985 528025.284985,142841.880985 528009.836985,142829.662985 527984.586985,142829.518985 527971.020985,142821.625985 527942.611985,142810.393985 527922.096985,142789.127985 527903.516985,142784.945985 527870.354985,142783.608985 527857.660985,142778.632985 527857.959985,142770.042985 527846.295985,142767.281985 527824.398985,142767.032985 527762.941985,142754.713985 527740.629985,142749.027985 527714.461985,142756.918985 527695.423985,142775.315985 527696.868985,142782.056985 527690.556985,142783.976985 527671.253985,142777.663985 527661.951985,142758.085985 527654.506985,142741.418985 527651.378985,142749.028985 527626.803985,142752.867985 527606.969985,142752.399985 527587.588985,142752.387985 527556.136985,142751.802985 527550.469985,142750.634985 527539.133985,142751.546185 527536.749185,142733.070985 527540.946985,142718.408985 527549.965985,142690.566985 527548.196985,142650.139985 527549.089985,142626.239985 527552.656985,142624.198985 527552.960985,142624.067985 527566.105985,142630.327985 527597.955985,142624.594985 527613.792985,142600.863985 527617.535985,142581.009985 527622.064985,142574.816985 527639.138985,142579.145985 527659.088985,142596.746985 527682.702985,142605.791985 527694.419985,142613.689985 527704.650985,142638.048985 527728.309985,142660.964985 527755.984985,142669.209985 527774.633985,142695.332985 527818.005985,142686.660985 527842.858985,142682.940985 527858.629985,142701.685985 527880.643985,142711.497985 527934.757985,142716.267985 527963.420985,142735.213985 528000.631985,142745.226985 528012.751985,142773.134985 528057.404985,142816.514985 528078.155985,142825.383985 528108.455985,142801.994985 528142.618985,142779.507985 528173.811985,142780.961985 528203.725985,142794.349985 528212.859985,142840.494985 528200.237985,142842.379985 528210.587985,142861.982985 528212.674985,142888.962985 528201.345985,142905.705985 528247.638985,142932.216985 528293.509985,142941.837985 528289.539985,142944.641985 528279.290985))</a>
+ #33 Polygon - gid: 2533
+ </desc>
+ <a>POLYGON((157248.267985 510397.734985,157245.305985 510363.097985,157245.806985 510339.634985,157249.376985 510312.049985,157264.999985 510313.014985,157298.816985 510310.020985,157313.463985 510303.902985,157331.569985 510277.161985,157335.597985 510263.931985,157342.919985 510246.050985,157356.304985 510238.818985,157373.099985 510233.719985,157379.080985 510235.892985,157395.913985 510233.044985,157408.176985 510225.851985,157412.515985 510212.622985,157409.981985 510194.654985,157398.325985 510184.101985,157382.360985 510173.357985,157354.165985 510179.672985,157341.808985 510184.636985,157327.343985 510198.734985,157317.441985 510214.933985,157308.672985 510231.087985,157299.867985 510244.974985,157293.245985 510254.256985,157288.312985 510254.760985,157282.069985 510246.244985,157282.741985 510240.644985,157284.759985 510223.843985,157287.182985 510197.241985,157275.293985 510195.644985,157261.763985 510193.043985,157245.218985 510187.050985,157227.608985 510177.984985,157227.523985 510173.393985,157241.396985 510142.853985,157246.112985 510129.441985,157230.683985 510109.990985,157224.665985 510099.018985,157249.180985 510051.905985,157212.257985 510031.046985,157194.338985 510064.208985,157211.972985 510077.542985,157204.306985 510095.641985,157222.207985 510119.716985,157199.619985 510159.627985,157215.047985 510174.354985,157196.172985 510227.723985,157155.328985 510207.689985,157139.189985 510197.898985,157127.587985 510195.991985,157123.056985 510200.777985,157088.217985 510252.205985,157106.896985 510285.860985,157126.853985 510245.967985,157133.861985 510250.332985,157165.215985 510274.869985,157156.396985 510293.534985,157144.581985 510312.557985,157138.589985 510331.438985,157137.075985 510351.638985,157138.046985 510372.580985,157139.419985 510383.981985,157146.858985 510390.097985,157156.021985 510361.922985,157163.523985 510331.258985,157181.372985 510302.572985,157207.566985 510320.651985,157199.540985 510385.307985,157193.303985 510383.664985,157180.758985 510375.835985,157168.702985 510402.140985,157158.766985 510420.761985,157135.709985 510449.280985,157153.437985 510466.189985,157170.048985 510460.713985,157195.357985 510432.173985,157213.684985 510416.564985,157235.371985 510403.145985,157248.267985 510397.734985))</a>
+ #34 Polygon - gid: 2534
+ </desc>
+ <a>POLYGON((148568.584985 517215.314985,148572.193985 517207.069985,148579.062985 517190.138985,148582.935985 517182.009985,148585.298985 517176.571985,148590.114985 517163.127985,148593.549985 517154.807985,148597.590985 517143.996985,148600.469985 517135.577985,148608.361985 517111.099985,148609.844985 517106.851985,148612.196985 517100.884985,148622.119985 517079.608985,148627.202985 517066.037985,148629.036985 517061.925985,148631.715985 517056.590985,148633.922985 517052.667985,148636.222985 517048.798985,148640.302985 517042.471985,148642.585985 517038.589985,148645.384985 517033.290985,148649.309985 517023.332985,148650.753985 517019.073985,148653.515985 517009.328985,148656.822985 516996.237985,148657.633985 516992.786985,148659.628985 516988.121985,148661.362985 516983.557985,148665.486985 516963.310985,148660.494985 516962.211985,148654.487985 516960.588985,148645.936985 516957.776985,148635.343985 516953.477985,148633.216985 516952.851985,148628.798985 516951.955985,148618.420985 516950.600985,148610.940985 516948.509985,148606.474985 516948.012985,148596.479985 516947.539985,148583.884985 516947.227985,148578.576985 516948.520985,148573.335985 516949.453985,148568.101985 516949.901985,148563.600985 516949.922985,148557.829985 516950.415985,148551.628985 516950.385985,148538.365985 516949.276985,148531.699985 516950.682985,148527.384985 516949.334985,148523.285985 516949.346985,148518.771985 516949.590985,148497.282985 516949.746985,148489.616985 516950.081985,148471.013985 516949.990985,148458.481985 516951.381985,148447.844985 516952.931985,148445.775985 516960.073985,148444.006985 516964.211985,148439.749985 516975.102985,148439.138985 516980.117985,148438.535985 516987.396985,148438.974985 516992.234985,148440.426985 516998.642985,148438.052985 516999.297985,148434.382985 517002.110985,148433.464985 517004.416985,148433.080985 517009.095985,148433.160985 517012.537985,148433.810985 517017.196985,148435.364985 517021.423985,148438.897985 517029.838985,148440.124985 517034.169985,148440.387985 517035.613985,148440.767985 517040.101985,148439.957985 517047.071985,148439.243985 517059.119985,148437.869985 517063.408985,148436.038985 517067.531985,148435.453985 517068.518985,148432.633985 517072.210985,148428.173985 517080.220985,148425.223985 517084.065985,148420.701985 517084.881985,148419.037985 517084.605985,148414.693985 517083.070985,148410.519985 517081.244985,148406.277985 517079.881985,148401.927985 517079.498985,148397.300985 517079.560985,148392.976985 517080.302985,148391.493985 517081.154985,148388.218985 517085.555985,148385.939985 517089.438985,148383.889985 517093.599985,148382.148985 517097.753985,148380.707985 517102.019985,148384.575985 517104.329985,148387.963985 517107.541985,148388.744985 517108.571985,148388.577985 517113.061985,148386.761985 517129.667985,148386.096985 517138.880985,148383.851985 517150.211985,148381.844985 517157.153985,148381.255985 517161.619985,148379.568985 517166.273985,148378.896985 517171.011985,148375.602985 517182.746985,148375.188985 517183.854985,148372.920985 517187.744985,148371.004985 517192.626985,148369.776985 517197.309985,148368.879985 517199.356985,148366.322985 517203.048985,148363.430985 517206.559985,148360.265985 517209.805985,148362.396985 517211.296985,148366.277985 517213.583985,148368.574985 517214.675985,148372.756985 517216.354985,148379.858985 517218.946985,148383.740985 517221.386985,148387.723985 517223.321985,148391.527985 517223.539985,148398.523985 517222.910985,148402.982985 517222.342985,148413.732985 517218.530985,148420.566985 517215.834985,148422.017985 517215.401985,148426.452985 517214.656985,148427.536985 517214.761985,148431.947985 517215.979985,148436.367985 517216.822985,148437.734985 517217.291985,148441.849985 517219.129985,148444.098985 517220.426985,148447.861985 517222.907985,148462.423985 517233.358985,148486.641985 517247.438985,148491.717985 517250.701985,148501.712985 517257.844985,148508.651985 517262.200985,148516.517985 517266.864985,148528.978985 517274.823985,148533.037985 517276.758985,148535.665985 517277.495985,148540.045985 517278.576985,148548.901985 517280.224985,148550.178985 517272.247985,148551.544985 517265.555985,148552.858985 517261.250985,148555.563985 517251.244985,148562.513985 517233.664985,148568.584985 517215.314985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>POLYGON ((148465.04603866642 517147.5219424748, 148468.32193007902 517148.81250785006, 148472.43693007904 517150.65050785005, 148479.31833130663 517154.15981472895, 148481.5673313066 517155.45681472897, 148485.38224162365 517157.8115498219, 148489.14524162366 517160.2925498219, 148491.5920858998 517161.976234038, 148503.2307818219 517170.32920829166, 148505.60300960566 517171.7083877117, 148509.5648041141 517161.94319003774, 148511.35506775207 517157.8800646531, 148514.66822819778 517150.926106155, 148515.52675331026 517148.95037210436, 148519.50861371885 517137.8348963292, 148520.79090495792 517134.5068053192, 148523.74161982184 517127.35980454256, 148526.96791581967 517118.7284048809, 148529.29095782075 517111.9351813287, 148536.9803214243 517088.0856828127, 148537.55288063685 517086.3801399501, 148539.03588063686 517082.1321399501, 148540.0697946662 517079.348843109, 148542.42179466618 517073.381843109, 148544.22615053327 517069.18379161716, 148552.9117266564 517050.5609640856, 148556.9678805225 517039.7315200335, 148558.7070182858 517035.4879842818, 148560.5410182858 517031.37598428177, 148562.0128355156 517028.2694345842, 148563.56937478343 517025.16971939424, 148557.4671445434 517025.4151073069, 148551.2661445434 517025.3851073069, 148545.3795881285 517025.1251650781, 148541.3465654276 517024.7879395503, 148534.52321633883 517025.62982859474, 148521.78631390657 517025.0248919264, 148519.75491128486 517024.57557388005, 148519.31643526338 517024.58900880005, 148514.50006083903 517024.6239734057, 148515.12058260432 517029.2863586431, 148515.50058260432 517033.7743586431, 148515.26660871692 517048.7596442845, 148514.70125120823 517053.6245107481, 148514.11262726612 517063.5569214688, 148510.66844475336 517082.0011245901, 148509.29444475335 517086.2901245901, 148506.41476057115 517093.8493158441, 148504.58376057114 517097.97231584415, 148500.5576643297 517105.7725396188, 148499.97266432972 517106.75953961874, 148495.78269539468 517112.9680895764, 148493.70102171606 517116.7067008243, 148487.67826782848 517125.8744659743, 148484.72826782847 517129.71946597425, 148475.34539209885 517139.8588568604, 148465.04603866642 517147.5219424748))
+ #35 Polygon - gid: 2535
+ </desc>
+ <a>POLYGON((163066.126985 517974.868985,163091.240985 517970.440985,163098.588985 517969.145985,163130.376985 517949.819985,163160.357985 517938.404985,163155.338985 517935.096985,163137.491985 517928.756985,163088.458985 517930.116985,163058.237985 517933.448985,163033.542985 517933.704985,162996.678985 517946.546985,162965.765985 517963.550985,162954.719985 517971.409985,162940.542985 517971.623985,162929.808985 517967.346985,162916.631985 517960.832985,162906.856985 517973.017985,162901.910985 517996.119985,162896.149985 518019.757985,162889.466985 518026.940985,162862.081985 518041.778985,162841.243985 518051.554985,162822.497985 518056.625985,162814.259985 518061.351985,162810.905985 518070.579985,162808.826985 518099.445985,162806.167985 518118.106985,162793.741985 518127.807985,162755.145985 518154.644985,162735.806985 518166.902985,162720.621985 518167.404985,162718.765985 518184.458985,162717.545985 518210.367985,162713.617985 518236.309985,162706.542985 518271.841985,162701.859985 518290.587985,162705.218985 518294.761985,162726.625985 518278.475985,162753.229985 518258.870985,162782.068985 518236.877985,162816.208985 518212.657985,162824.470985 518182.138985,162845.014985 518153.858985,162882.445985 518140.582985,162920.703985 518125.470985,162943.696985 518115.392985,162965.820985 518065.592985,162984.425985 518034.931985,163005.550985 518008.892985,163025.235985 517978.313985,163066.126985 517974.868985))</a>
+ #36 Polygon - gid: 2536
+ </desc>
+ <a>POLYGON((151640.372985 520078.439985,151631.962985 520059.790985,151629.274985 520055.812985,151626.569985 520052.200985,151615.221985 520034.782985,151606.240985 520019.252985,151596.253985 520003.198985,151594.521985 519999.999985,151585.007985 519979.511985,151579.071985 519969.479985,151573.199985 519957.304985,151572.035985 519955.222985,151567.491985 519949.971985,151564.650985 519946.439985,151563.903985 519945.128985,151561.474985 519937.032985,151559.718985 519932.885985,151558.187985 519929.892985,151554.220985 519932.057985,151549.028985 519934.369985,151543.618985 519935.855985,151538.622985 519936.867985,151534.164985 519937.482985,151528.132985 519939.763985,151523.603985 519940.766985,151518.324985 519941.678985,151514.201985 519943.500985,151511.453985 519945.404985,151507.599985 519948.857985,151505.118985 519952.626985,151501.093985 519964.334985,151499.289985 519968.439985,151498.111985 519970.475985,151495.027985 519973.673985,151492.288985 519974.096985,151486.380985 519973.413985,151480.685985 519972.343985,151476.198985 519971.871985,151471.575985 519971.639985,151467.126985 519972.326985,151465.579985 519972.930985,151461.230985 519976.087985,151459.824985 519980.451985,151459.120985 519986.854985,151457.196985 519995.647985,151457.505985 519999.999985,151457.755985 520002.163985,151458.895985 520006.518985,151459.809985 520012.864985,151461.700985 520019.709985,151462.600985 520024.748985,151466.236985 520038.107985,151470.320985 520048.063985,151476.146985 520063.414985,151477.708985 520067.993985,151480.097985 520076.675985,151484.051985 520078.930985,151488.522985 520079.897985,151492.694985 520078.104985,151494.938985 520076.848985,151506.520985 520073.368985,151510.381985 520072.425985,151515.922985 520072.149985,151520.376985 520071.501985,151525.461985 520071.155985,151533.320985 520071.044985,151541.199985 520071.316985,151545.772985 520072.216985,151550.689985 520074.159985,151556.344985 520076.869985,151559.924985 520080.906985,151561.475985 520085.626985,151562.598985 520089.906985,151564.866985 520095.728985,151566.733985 520099.823985,151570.978985 520111.588985,151575.985985 520119.712985,151580.454985 520125.992985,151585.750985 520135.315985,151588.951985 520138.478985,151591.959985 520142.387985,151595.794985 520145.608985,151596.717985 520146.180985,151600.930985 520147.761985,151610.593985 520152.335985,151615.876985 520148.420985,151619.366985 520145.538985,151620.268985 520145.005985,151624.502985 520143.522985,151627.066985 520142.840985,151640.810985 520139.486985,151645.648985 520138.596985,151646.664985 520138.210985,151650.623985 520136.078985,151654.429985 520133.610985,151656.825985 520131.812985,151657.034985 520127.310985,151655.434985 520118.142985,151654.368985 520103.131985,151653.199985 520098.779985,151649.007985 520092.899985,151646.566985 520089.118985,151642.541985 520082.381985,151640.372985 520078.439985))</a>
+ #37 Polygon - gid: 2537
+ </desc>
+ <a>POLYGON((149074.863985 521147.685985,149079.195985 521146.453985,149084.481985 521146.550985,149083.352985 521142.190985,149082.307985 521139.131985,149078.212985 521129.952985,149074.534985 521119.799985,149072.006985 521114.769985,149062.256985 521087.740985,149058.326985 521077.315985,149057.272985 521073.684985,149056.706985 521069.234985,149056.032985 521058.372985,149055.989985 521055.324985,149056.653985 521049.602985,149056.828985 521045.104985,149057.483985 521039.922985,149057.955985 521027.280985,149059.078985 521021.526985,149059.679985 521014.389985,149061.083985 521010.116985,149063.420985 521004.372985,149065.076985 521001.246985,149068.057985 520997.888985,149069.914985 520996.183985,149073.453985 520993.403985,149077.695985 520990.619985,149083.699985 520985.301985,149087.481985 520982.855985,149091.155985 520979.558985,149091.687985 520978.602985,149092.102085 520973.780785,149091.433985 520972.943985,149085.922985 520963.780985,149080.736985 520952.972985,149079.151985 520948.023985,149078.605985 520943.551985,149078.175985 520937.077985,149077.300985 520934.467985,149076.557985 520932.161985,149075.476985 520927.756985,149074.024985 520923.526985,149072.892985 520921.352985,149070.466985 520917.501985,149067.489985 520913.906985,149063.902985 520911.245985,149060.015985 520908.880985,149057.583985 520907.012985,149053.836985 520904.575985,149046.407985 520903.194985,149043.748985 520900.710985,149040.669985 520896.363985,149030.471985 520876.382985,149027.005985 520870.944985,149023.474985 520864.091985,149020.424985 520857.679985,149016.414985 520850.386985,149015.312985 520847.716985,149011.691985 520837.466985,149011.094985 520836.292985,149008.704985 520832.469985,149005.259985 520827.502985,149004.610985 520825.876985,149003.577985 520821.217985,149003.854985 520816.719985,149002.972985 520816.201985,148998.602985 520814.693985,148988.265985 520815.477985,148983.673985 520817.423985,148979.484985 520821.816985,148976.129985 520824.776985,148973.845985 520825.367985,148966.379985 520826.025985,148961.056985 520826.999985,148956.409985 520829.091985,148951.949985 520829.751985,148946.441985 520830.130985,148931.710985 520830.198985,148924.824985 520830.672985,148921.727985 520830.400985,148917.057985 520829.109985,148913.971985 520825.698985,148910.100985 520821.942985,148901.275985 520808.640985,148896.799985 520799.352985,148894.695985 520795.375985,148891.228985 520789.937985,148887.698985 520783.085985,148884.606985 520775.729985,148881.994985 520768.813985,148880.715985 520766.573985,148878.047985 520762.936985,148875.219985 520759.448985,148871.608985 520756.679985,148867.217985 520756.296985,148862.582985 520756.904985,148861.392985 520757.168985,148857.137985 520758.698985,148853.364985 520759.509985,148848.917985 520760.210985,148844.572985 520761.389985,148836.362985 520765.784985,148831.786985 520766.128985,148822.120985 520765.033985,148817.121985 520763.908985,148812.548985 520762.503985,148807.295985 520761.442985,148803.827985 520760.947985,148794.718985 520760.628985,148790.131985 520761.085985,148779.499985 520762.621985,148777.012985 520764.595985,148773.926985 520768.885985,148773.466985 520774.629985,148773.332985 520779.128985,148772.635985 520787.462985,148772.583985 520792.333985,148774.114985 520796.576985,148778.330985 520798.178985,148785.801985 520800.503985,148791.415985 520802.481985,148797.424985 520804.176985,148801.266985 520806.534985,148808.780985 520809.801985,148816.731985 520814.761985,148820.614985 520817.028985,148822.486985 520817.871985,148828.485985 520820.053985,148840.253985 520823.719985,148844.481985 520824.577985,148848.642985 520825.980985,148849.614985 520826.820985,148851.668985 520831.391985,148850.423985 520836.473985,148851.647985 520862.196985,148851.608985 520865.784985,148852.006985 520870.213985,148852.588985 520871.618985,148855.610985 520875.318985,148859.688985 520877.253985,148865.606985 520879.625985,148869.560985 520881.777985,148874.694985 520884.932985,148878.973985 520886.333985,148879.781985 520887.091985,148882.398985 520890.827985,148893.628985 520903.399985,148896.470985 520906.888985,148900.771985 520910.377985,148903.113985 520912.783985,148907.271985 520917.520985,148910.265985 520921.543985,148913.153985 520928.363985,148914.659985 520932.599985,148915.336985 520935.164985,148915.886985 520939.775985,148914.248985 520943.980985,148917.390985 520947.207985,148919.572985 520949.764985,148923.999985 520956.081985,148928.384985 520961.456985,148931.471985 520964.733985,148935.306985 520967.792985,148938.422985 520971.552985,148942.810985 520975.127985,148945.672985 520978.715985,148945.467985 520983.562985,148943.924985 520989.715985,148941.045985 520998.242985,148938.175985 521005.247985,148932.651985 521015.561985,148930.709985 521019.641985,148929.317985 521023.359985,148928.157985 521027.888985,148928.257985 521030.527985,148930.431985 521034.393985,148933.165985 521037.285985,148936.637985 521040.110985,148942.203985 521043.759985,148949.976985 521048.302985,148956.663985 521051.603985,148960.826985 521053.323985,148970.378985 521056.011985,148974.655985 521057.444985,148977.871985 521058.807985,148985.582985 521063.452985,148996.173985 521068.099985,149000.446985 521070.923985,149004.131985 521074.654985,149005.361985 521076.309985,149007.752985 521080.130985,149009.883985 521084.114985,149010.875985 521086.337985,149012.155985 521090.634985,149013.087985 521095.060985,149013.828985 521099.645985,149014.305985 521101.238985,149016.320985 521105.262985,149018.796985 521108.970985,149021.783985 521112.417985,149024.099985 521114.282985,149028.473985 521115.337985,149036.160985 521116.290985,149040.418985 521117.807985,149041.315985 521118.300985,149044.645985 521121.332985,149046.237985 521125.627985,149045.253985 521130.390985,149045.181985 521135.783985,149045.437985 521138.357985,149046.177985 521142.841985,149046.609985 521143.953985,149049.230985 521147.622985,149050.514985 521148.887985,149054.171985 521151.491985,149060.050985 521155.216985,149064.906985 521154.540985,149066.395985 521153.944985,149070.858985 521150.799985,149074.863985 521147.685985))</a>
+ #38 Polygon - gid: 2538
+ </desc>
+ <a>POLYGON((150340.263985 521736.242985,150319.707985 521734.229985,150320.397985 521743.203985,150320.776985 521753.617985,150321.365985 521762.839985,150321.838985 521767.321985,150322.439985 521771.069985,150323.456985 521775.456985,150325.665985 521782.261985,150327.698985 521786.281985,150328.983985 521788.230985,150331.756985 521791.771985,150334.245985 521794.557985,150337.451985 521797.714985,150345.035985 521804.348985,150348.315985 521807.525985,150350.157985 521808.786985,150354.399985 521810.150985,150370.210985 521813.514985,150374.540985 521814.689985,150378.907985 521817.179985,150387.202985 521823.648985,150391.093985 521825.901985,150398.280985 521829.395985,150414.053985 521839.397985,150417.301985 521841.772985,150425.706985 521851.706985,150429.010985 521854.761985,150432.472985 521857.645985,150437.069985 521860.954985,150439.941985 521862.714985,150449.894985 521867.787985,150455.159985 521869.676985,150457.271985 521870.216985,150461.740985 521869.363985,150463.846985 521868.400985,150466.973985 521865.126985,150468.871985 521858.611985,150470.712985 521854.484985,150471.314985 521852.772985,150472.425985 521842.584985,150472.585985 521837.769985,150471.114985 521817.439985,150467.720985 521797.270985,150467.236985 521792.050985,150467.787985 521786.877985,150468.844985 521782.176985,150469.472985 521777.288985,150470.980985 521770.720985,150464.397985 521768.068985,150460.133985 521766.625985,150453.794985 521764.881985,150449.391985 521763.947985,150441.118985 521762.424985,150435.455985 521761.036985,150424.480985 521757.289985,150408.178985 521751.226985,150399.551985 521747.851985,150390.966985 521745.146985,150382.787985 521742.940985,150374.289985 521739.977985,150369.950985 521738.975985,150358.848985 521736.928985,150354.376985 521736.424985,150340.263985 521736.242985))</a>
+ #39 Polygon - gid: 2539
+ </desc>
+ <a>POLYGON((151414.655985 521903.498985,151419.118985 521902.909985,151421.110985 521903.031985,151425.514985 521903.903985,151432.945985 521906.160985,151435.281985 521907.106985,151439.154985 521909.607985,151440.214985 521905.223985,151439.494985 521900.455985,151436.942985 521890.300985,151435.309985 521886.095985,151435.222985 521881.294985,151435.805985 521873.232985,151435.489985 521868.742985,151435.595985 521863.657985,151437.865985 521855.470985,151438.586985 521850.956985,151447.004985 521843.098985,151449.266985 521833.184985,151450.435985 521826.542985,151446.671985 521824.075985,151441.776985 521820.429985,151435.135985 521814.354985,151430.862985 521811.043985,151429.653985 521809.812985,151427.434985 521805.925985,151424.123985 521798.914985,151422.976985 521796.117985,151421.981985 521791.729985,151420.446985 521786.732985,151420.164985 521785.502985,151419.969985 521781.007985,151419.525985 521775.880985,151419.146985 521773.395985,151417.498985 521767.866985,151415.384985 521762.360985,151413.246985 521758.395985,151410.199985 521754.143985,151407.420985 521751.067985,151403.914985 521748.258985,151398.761985 521744.954985,151394.600985 521743.247985,151389.313985 521741.332985,151386.449985 521740.426985,151382.047985 521739.436985,151380.811985 521739.305985,151374.773985 521739.607985,151370.237985 521739.382985,151365.883985 521738.649985,151359.674985 521735.218985,151349.485985 521730.180985,151343.877985 521725.720985,151340.551985 521722.689985,151334.626985 521716.831985,151329.218985 521710.554985,151325.247985 521705.141985,151319.417985 521699.821985,151315.446985 521694.409985,151305.560985 521681.809985,151300.596985 521675.043985,151296.688985 521671.030985,151293.246985 521668.105985,151289.929985 521665.757985,151285.914985 521663.658985,151282.327985 521662.396985,151277.836985 521662.113985,151271.818985 521662.894985,151268.877985 521663.536985,151263.367985 521665.215985,151261.932985 521669.477985,151258.678985 521677.877985,151256.217985 521682.629985,151251.459985 521683.882985,151247.452985 521683.781985,151241.286985 521681.283985,151234.212985 521679.299985,151230.126985 521677.337985,151227.560985 521676.358985,151223.087985 521675.729985,151219.620985 521675.820985,151215.249985 521676.783985,151210.898985 521678.040985,151205.964985 521678.817985,151196.349985 521681.136985,151192.448985 521682.323985,151188.367985 521684.271985,151187.444985 521684.912985,151184.336985 521688.179985,151181.542985 521692.671985,151179.378985 521696.641985,151177.884985 521699.887985,151173.838985 521718.013985,151172.909985 521723.517985,151173.083985 521728.013985,151173.884985 521734.691985,151175.904985 521738.784985,151180.466985 521741.060985,151183.536985 521742.158985,151187.621985 521744.146985,151191.251985 521748.103985,151194.752985 521753.288985,151196.865985 521758.794985,151198.738985 521762.886985,151200.502985 521767.587985,151203.883985 521779.954985,151208.659985 521792.808985,151211.765985 521799.668985,151213.414985 521805.197985,151215.020985 521809.793985,151218.548985 521815.695985,151221.215985 521819.333985,151222.013985 521820.198985,151227.821985 521825.052985,151230.947985 521828.290985,151234.125985 521832.083985,151238.592985 521842.773985,151240.775985 521849.351985,151242.232985 521855.194985,151242.763985 521866.859985,151242.540985 521871.354985,151242.852985 521879.013985,151243.124985 521888.008985,151243.896985 521899.613985,151243.956985 521904.112985,151243.781985 521911.524985,151243.249985 521917.736985,151244.213985 521932.376985,151246.639985 521941.861985,151247.152985 521948.509985,151248.543985 521959.890985,151248.626985 521963.699985,151248.136985 521968.176985,151246.966985 521973.552985,151251.430985 521972.917985,151254.743985 521972.063985,151260.584985 521969.324985,151264.784985 521967.712985,151273.249985 521964.701985,151285.945985 521960.539985,151294.351985 521957.321985,151299.279985 521955.774985,151324.985985 521948.448985,151340.816985 521942.669985,151349.401985 521939.968985,151363.226985 521935.306985,151367.526985 521933.980985,151372.861985 521932.688985,151382.530985 521930.905985,151385.598985 521927.434985,151395.219985 521921.249985,151396.763985 521920.086985,151401.989985 521915.074985,151408.377985 521907.711985,151412.054985 521904.855985,151414.655985 521903.498985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>POLYGON((151279.645830086 521767.755326376,151280.089101957 521768.734349246,151281.60849228 521772.801761659,151281.779965797 521772.961370432,151284.905965797 521776.199370432,151288.436416127 521780.123773262,151291.614416127 521783.916773262,151298.197909309 521793.099519948,151303.3272236 521803.167059572,151307.7942236 521813.857059572,151309.775551863 521819.151068694,151311.958551863 521825.729068694,151313.547648501 521831.205773513,151315.004648501 521837.048773513,151317.155400222 521851.784457569,151317.686400222 521863.449457569,151317.671859293 521870.576215471,151317.633144616 521871.356585304,151318.308321815 521871.127269916,151326.162616192 521868.656163438,151339.261758571 521864.238933653,151341.126044189 521863.637267439,151345.426044189 521862.311267439,151349.429937 521861.210224374,151351.72695172 521858.562616456,151362.371481661 521848.480222824,151362.64012267 521848.271563938,151363.173322839 521844.636869635,151362.301287147 521843.109333478,151359.617270262 521837.953435221,151356.306270262 521830.942435221,151354.732095129 521827.371366009,151353.585095129 521824.574366009,151349.833842604 521812.703542585,151349.58867297 521811.62233218,151341.169193044 521809.460853224,151329.609871097 521804.294395733,151324.898612404 521801.69102505,151316.24354186 521797.411483839,151302.802545748 521788.880699647,151297.194545748 521784.420699647,151293.360366598 521781.1553627,151290.034366598 521778.1243627,151287.821382925 521776.02368546,151281.896382925 521770.16568546,151279.645830086 521767.755326376))
+ #40 Polygon - gid: 2540
+ </desc>
+ <a>POLYGON((148804.969985 522529.061985,148825.777985 522528.289985,148844.208985 522531.065985,148856.496985 522532.916985,148882.440985 522530.570985,148894.474985 522523.984985,148904.794985 522513.633985,148902.807985 522495.733985,148896.519985 522475.100985,148873.973985 522465.040985,148844.137985 522468.478985,148809.638985 522482.020985,148787.006985 522487.163985,148762.897985 522493.321985,148738.759985 522488.933985,148716.846985 522484.385985,148694.991985 522485.158985,148688.417985 522484.461985,148687.828985 522493.001985,148665.144985 522531.758985,148646.934985 522583.394985,148650.294985 522613.315985,148667.775985 522637.046985,148692.509985 522655.222985,148702.550985 522673.036985,148703.442985 522695.940985,148697.442985 522721.471985,148703.390985 522728.395985,148743.857985 522739.557985,148760.692985 522732.650985,148771.972985 522702.999985,148787.125985 522672.393985,148803.225985 522652.100985,148801.228985 522634.074985,148780.811985 522619.038985,148757.441985 522607.968985,148749.196985 522601.119985,148766.539985 522585.682985,148782.051985 522574.165985,148778.702985 522559.073985,148779.149985 522545.714985,148791.097985 522529.576985,148804.969985 522529.061985))</a>
+ #41 Polygon - gid: 2541
+ </desc>
+ <a>POLYGON((148410.699985 522834.902985,148442.757985 522825.725985,148460.309985 522827.514985,148487.864985 522844.888985,148500.821985 522849.224985,148522.555985 522842.060985,148549.245985 522836.360985,148568.572985 522826.852985,148584.252985 522812.743985,148609.816985 522787.145985,148614.009985 522767.881985,148612.795985 522752.758985,148612.563985 522743.189985,148618.720985 522735.053985,148625.781585 522726.296485,148618.662985 522724.739985,148612.278985 522723.775985,148605.112985 522714.525985,148611.687985 522677.987985,148611.797985 522647.963985,148594.739985 522625.727985,148584.565985 522622.805985,148562.730985 522628.324985,148543.283985 522615.292985,148536.597985 522557.684985,148536.223985 522555.223985,148534.274985 522546.378985,148533.665985 522541.970985,148533.794985 522540.094985,148535.172985 522535.741985,148538.094985 522529.403985,148538.611985 522526.777985,148539.936985 522513.990985,148540.169985 522509.496985,148540.192985 522500.589985,148540.851985 522495.877985,148540.474985 522491.607985,148539.391985 522489.734985,148536.121985 522486.259985,148532.239985 522483.953985,148529.487985 522487.690985,148527.557985 522489.161985,148523.269985 522490.157985,148512.547985 522491.130985,148508.089985 522491.855985,148503.708985 522492.860985,148499.171985 522494.926985,148493.577985 522498.401985,148488.746985 522500.495985,148483.626985 522501.803985,148480.736985 522503.655985,148464.117985 522534.086985,148427.843985 522552.590985,148408.790985 522571.476985,148398.223985 522596.340985,148407.833985 522615.400985,148416.753985 522662.875985,148420.236985 522689.856985,148421.081985 522713.013985,148415.508985 522722.819985,148391.177985 522725.213985,148358.228985 522724.834985,148355.953985 522741.826985,148341.696985 522767.846985,148328.778985 522795.425985,148312.269985 522806.114985,148322.213985 522836.436985,148339.137985 522884.626985,148351.181985 522896.189985,148376.682985 522893.652985,148389.158985 522851.634985,148410.699985 522834.902985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>POLYGON((148482.813746868 522756.183508667,148484.759834217 522756.612200335,148500.311458172 522764.073026139,148507.47578582 522768.590283572,148524.485305735 522764.957677221,148526.135900505 522764.145660091,148532.598883594 522758.330211851,148537.783159503 522753.13904088,148537.640235854 522747.24405639,148537.573978828 522747.137066634,148532.272275747 522732.393023801,148530.149598324 522716.869200329,148531.298587695 522701.24311067,148532.147803475 522696.523924938,148520.979243698 522690.629014551,148501.532243698 522677.597014551,148493.394526839 522670.763509214,148494.619771809 522680.254848443,148495.187102679 522687.122051743,148496.032102679 522710.279051743,148495.262613882 522724.069947131,148491.977169924 522737.485861809,148486.287201914 522750.071773483,148482.813746868 522756.183508667))
+ #42 Polygon - gid: 2542
+ </desc>
+ <a>POLYGON((150213.068985 524020.273985,150226.206985 524020.218985,150245.019985 524022.421985,150248.570985 524017.633985,150243.628985 523991.402985,150233.942985 523969.968985,150203.852985 523929.546985,150189.509985 523905.746985,150179.578985 523905.795985,150163.996985 523891.573985,150150.529985 523872.591985,150158.960985 523848.710985,150150.727985 523827.265985,150129.075985 523796.394985,150110.126985 523782.119985,150064.853985 523787.149985,150051.774985 523791.993985,150035.273985 523796.784985,150034.124985 523803.948985,150047.317985 523842.088985,150048.538985 523846.850985,150048.758985 523856.362985,150044.002985 523858.774985,150033.285985 523861.216985,150022.584985 523866.044985,150013.239985 523875.626985,150010.897985 523882.801985,150007.322985 523904.295985,150015.725985 523913.798985,150028.883985 523920.894985,150036.292985 523937.604985,150033.171985 523964.012985,150028.264985 524013.973985,150020.417985 524042.804985,150014.532985 524064.428985,150004.476985 524083.491985,149987.717985 524115.262985,149981.881985 524139.242985,149991.382985 524146.196985,150012.547985 524165.288985,150017.553385 524169.126585,150024.575985 524166.982985,150037.645985 524157.385985,150054.301985 524147.777985,150067.231985 524142.754985,150080.313985 524135.548985,150096.808985 524132.911985,150108.662985 524120.938985,150113.586985 524111.551985,150113.285985 524097.054985,150114.403985 524085.116985,150121.501985 524075.543985,150134.308985 524061.036985,150143.802985 524053.844985,150159.042985 524051.270985,150177.151985 524046.558985,150188.764985 524039.234985,150195.842985 524027.285985,150213.068985 524020.273985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>POLYGON((150106.011000335 523989.689500602,150114.057919676 523984.995648846,150131.312562914 523979.892369386,150139.180475973 523978.563497456,150141.030635187 523976.094127171,150143.466198894 523973.995184804,150140.693804819 523969.864680568,150140.146542734 523969.593183191,150129.018561804 523961.19132421,150113.436561804 523946.96932421,150110.842199358 523944.035224328,150110.774630149 523946.407515086,150107.74049457 523972.080521291,150106.011000335 523989.689500602))
+ </op></test></case><case><desc>
+ #43 Polygon - gid: 2543
+ </desc>
+ <a>POLYGON((144922.318985 524491.962985,144916.174985 524471.916985,144914.549985 524467.677985,144912.593985 524463.720985,144910.192985 524460.155985,144908.311985 524458.069985,144904.928985 524455.185985,144901.087985 524452.661985,144896.952985 524450.467985,144892.685985 524448.577985,144888.450985 524446.961985,144885.347985 524445.991985,144881.001985 524445.002985,144876.555985 524444.286985,144863.031985 524442.562985,144857.685985 524441.514985,144849.003985 524439.122985,144839.775985 524435.911985,144819.128985 524426.964985,144802.963985 524420.784985,144798.693985 524419.372985,144786.193985 524415.740985,144781.645985 524414.507985,144777.135985 524413.576985,144772.740985 524413.149985,144768.538985 524413.428985,144766.698985 524413.878985,144762.631985 524415.739985,144758.763985 524418.497985,144755.294985 524421.804985,144752.424985 524425.313985,144750.466985 524428.343985,144748.348985 524432.485985,144746.691985 524436.901985,144745.642985 524441.399985,144745.357985 524445.949985,144746.099985 524450.217985,144747.674985 524454.490985,144751.644985 524463.042985,144753.198985 524467.313985,144753.903985 524471.578985,144753.795985 524474.709985,144752.079885 524484.578885,144754.670985 524482.704985,144758.730985 524480.197985,144763.800985 524478.457985,144768.027985 524478.293985,144772.474985 524478.930985,144781.635985 524481.187985,144786.155985 524482.100985,144808.055985 524485.287985,144816.937985 524486.725985,144833.164985 524489.675985,144841.977985 524491.504985,144850.254985 524493.511985,144867.643985 524498.751985,144876.325985 524501.135985,144885.821985 524503.463985,144894.632985 524505.384985,144899.063985 524506.183985,144907.993985 524507.149985,144917.005985 524507.531985,144926.006985 524507.397985,144924.626985 524500.677985,144922.318985 524491.962985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>POLYGON( EMPTY)
+ #44 Polygon - gid: 2544
+ </desc>
+ <a>POLYGON((152738.586985 525524.931985,152740.326985 525497.058985,152695.275985 525498.501985,152656.986985 525505.098985,152622.061985 525523.010985,152648.325985 525540.128985,152652.935985 525590.321985,152647.410985 525629.067985,152666.698985 525650.755985,152708.041985 525659.923985,152735.752985 525671.255985,152760.563985 525666.811985,152771.160985 525648.828985,152770.241985 525625.353985,152756.879985 525597.961985,152746.550985 525573.880985,152738.586985 525524.931985))</a>
+ #45 Polygon - gid: 2545
+ </desc>
+ <a>POLYGON((149453.122985 526139.892985,149396.797985 526127.534985,149353.639985 526128.716985,149378.053985 526143.048985,149404.918985 526161.498985,149438.396985 526192.728985,149474.027985 526233.837985,149507.380985 526288.575985,149516.204985 526264.755985,149536.833985 526225.717985,149553.115985 526196.776985,149518.161985 526170.998985,149453.122985 526139.892985))</a>
+ #46 Polygon - gid: 2546
+ </desc>
+ <a>POLYGON((143371.698985 526340.324985,143367.501985 526296.992985,143367.318985 526278.597985,143349.180985 526262.013985,143334.789985 526251.329985,143319.597985 526245.894985,143315.281985 526251.019985,143278.726985 526298.107985,143265.495985 526287.517985,143253.409985 526293.227985,143236.509985 526310.988985,143223.254985 526345.656985,143210.652985 526371.956985,143208.644985 526376.798985,143242.636985 526387.900985,143277.186985 526389.196985,143320.427985 526393.579985,143367.418985 526393.302985,143375.058985 526381.563985,143371.698985 526340.324985))</a>
+ #47 Polygon - gid: 2547
+ </desc>
+ <a>POLYGON((158778.588985 529695.437985,158715.314985 529674.844985,158709.040985 529734.142985,158680.951985 529777.857985,158654.349985 529824.912985,158644.110985 529853.468985,158638.251985 529907.850985,158646.861985 529965.652985,158652.583985 529994.969985,158651.137985 529999.999985,158636.793985 530049.891985,158653.691985 530103.927985,158665.644985 530140.105985,158674.780985 530159.977985,158719.076985 530181.397985,158712.966985 530164.850985,158699.313985 530129.290985,158686.188985 530067.699985,158690.286985 530025.745985,158687.319985 529999.999985,158684.767985 529977.857985,158708.706985 529901.824985,158719.982985 529824.505985,158735.250985 529780.284985,158743.835985 529751.756985,158759.095985 529710.610985,158778.588985 529695.437985))</a>
+ #48 Polygon - gid: 2548
+ </desc>
+ <a>POLYGON((161952.205985 531803.507985,161950.166985 531785.171985,161948.777985 531776.277985,161947.155985 531767.422985,161941.486985 531770.695985,161937.729985 531773.172985,161932.269985 531777.472985,161926.725985 531782.098985,161924.613985 531783.667985,161920.829985 531786.099985,161918.605985 531787.218985,161914.388985 531788.805985,161912.462985 531789.286985,161907.980985 531789.764985,161906.546985 531789.681985,161902.168985 531788.569985,161900.603985 531787.696985,161897.146985 531784.749985,161895.220985 531782.338985,161888.204985 531771.801985,161886.264985 531769.242985,161883.356985 531765.807985,161881.285985 531763.666985,161877.947985 531760.643985,161875.477985 531758.658985,161871.750985 531756.139985,161869.201985 531754.809985,161868.431985 531755.733985,161866.239985 531759.658985,161864.319985 531763.806985,161862.714985 531768.076985,161861.469985 531772.366985,161861.207985 531774.035985,161861.449985 531778.536985,161862.001985 531783.085985,161863.613985 531807.082985,161864.280985 531822.215985,161864.630985 531826.696985,161866.742985 531841.487985,161867.721985 531846.033985,161869.164985 531850.249985,161871.272985 531853.934985,161872.321985 531855.188985,161875.579985 531857.980985,161879.435985 531860.329985,161887.847985 531864.517985,161891.856985 531866.765985,161905.113985 531875.495985,161909.626985 531878.077985,161917.664985 531882.167985,161925.928985 531885.781985,161936.320985 531889.414985,161940.808985 531890.825985,161945.292985 531891.980985,161949.678985 531892.708985,161953.873985 531892.835985,161955.851985 531892.353985,161959.869985 531889.472985,161962.230985 531885.504985,161962.474985 531884.239985,161962.567985 531879.959985,161961.965985 531875.401985,161960.428985 531866.167985,161959.158985 531853.444985,161957.935985 531843.738985,161952.205985 531803.507985))</a>
+ #49 Polygon - gid: 2549
+ </desc>
+ <a>POLYGON((144515.492985 534697.249985,144520.510985 534691.952985,144527.310985 534683.949985,144535.496985 534673.356985,144546.006985 534658.516985,144553.414985 534648.475985,144571.337985 534625.843985,144588.734985 534602.871985,144591.563985 534598.255985,144593.687985 534594.272985,144595.170985 534590.539985,144595.782985 534587.574985,144596.004985 534583.199985,144595.414985 534578.711985,144594.709985 534576.051985,144592.684985 534571.167985,144584.642985 534570.602985,144578.354985 534570.640985,144565.341985 534571.789985,144550.736985 534573.859985,144535.843985 534577.740985,144530.135985 534579.076985,144502.804985 534584.561985,144492.056985 534586.945985,144456.640985 534596.072985,144421.529985 534606.221985,144416.729985 534607.810985,144413.648985 534609.062985,144409.481985 534611.224985,144405.573985 534613.952985,144401.917985 534617.122985,144394.939985 534623.644985,144392.859085 534625.096885,144391.528985 534626.710985,144388.152985 534629.686985,144383.914985 534633.745985,144381.967985 534636.004985,144380.598985 534637.904985,144379.020985 534640.527985,144378.413985 534641.899985,144377.712985 534644.700985,144377.358985 534647.693985,144377.278985 534650.747985,144377.449985 534653.772985,144377.702985 534655.737985,144378.069985 534657.174985,144379.935985 534661.330985,144381.203985 534663.625985,144382.840985 534666.139985,144386.549985 534671.102985,144395.619985 534681.742985,144397.803985 534684.814985,144400.044985 534688.738985,144401.674985 534692.606985,144402.653985 534692.013985,144409.805985 534694.346985,144417.124985 534696.033985,144420.474985 534696.361985,144428.018985 534696.322985,144429.277985 534696.473985,144430.696985 534696.874985,144451.529985 534707.358985,144457.662985 534710.086985,144461.881985 534711.659985,144465.832985 534712.829985,144468.756985 534713.530985,144473.000985 534714.248985,144475.995985 534714.553985,144480.201985 534714.653985,144484.693985 534714.285985,144488.789985 534713.532985,144493.108985 534712.257985,144496.962985 534710.702985,144499.635985 534709.353985,144504.686985 534706.313985,144509.614985 534702.550985,144515.492985 534697.249985))</a>
+ #50 Polygon - gid: 2550
+ </desc>
+ <a>POLYGON((139580.306985 536284.245985,139581.537985 536275.353985,139582.391985 536270.934985,139584.727985 536262.895985,139588.416985 536252.326985,139591.066985 536246.306985,139593.754985 536241.295985,139596.494985 536237.619985,139599.804985 536234.137985,139603.593985 536230.963985,139607.726985 536228.169985,139622.104985 536219.993985,139630.326985 536215.966985,139647.195985 536208.674985,139656.268985 536204.452985,139664.079985 536200.252985,139671.632985 536195.480985,139678.904985 536190.269985,139684.418985 536185.885985,139690.667985 536180.238985,139699.139985 536171.792985,139704.019985 536167.257985,139707.535985 536164.362985,139719.234985 536155.582985,139724.584985 536151.291985,139728.111985 536147.960985,139730.160985 536145.764985,139731.363985 536144.185985,139731.781985 536143.091985,139730.140985 536138.628985,139728.244985 536134.603985,139725.033985 536129.308985,139723.167985 536126.742985,139720.321985 536123.255985,139715.151985 536117.777985,139709.530985 536112.704985,139702.374985 536107.119985,139693.638985 536101.087985,139672.813985 536087.921985,139664.262985 536082.684985,139655.423985 536077.697985,139647.610985 536073.673985,139639.545985 536070.005985,139626.896985 536064.817985,139618.344985 536061.630985,139595.270985 536053.548985,139589.311985 536051.161985,139582.993985 536048.148985,139578.633985 536045.693985,139573.206985 536042.191985,139559.712985 536032.655985,139544.953985 536022.737985,139538.344985 536017.628985,139533.269985 536012.957985,139527.127985 536006.378985,139522.507985 536000.966985,139517.569985 535994.673985,139514.710985 535990.549985,139512.017985 535986.156985,139509.458985 535981.492985,139503.627985 535970.144985,139500.680985 535965.036985,139498.267985 535961.301985,139493.873985 535955.337985,139482.644985 535941.539985,139476.252985 535933.272985,139471.574985 535926.605985,139468.229985 535920.871985,139466.243985 535916.364985,139465.202985 535913.222985,139464.494985 535910.303985,139463.964985 535907.107985,139463.809985 535904.115985,139464.450985 535898.265985,139465.320985 535895.316985,139466.778985 535892.646985,139467.714985 535891.405985,139469.884985 535889.355985,139472.222985 535888.202985,139473.703985 535887.781985,139478.694985 535887.027985,139527.523985 535887.045985,139534.405985 535886.815985,139539.706985 535886.209985,139543.334985 535885.541985,139549.575985 535883.796985,139555.393985 535881.390985,139561.941985 535877.533985,139566.488985 535874.094985,139570.786985 535869.895985,139574.370985 535865.516985,139577.146985 535860.922985,139578.381985 535858.167985,139579.597985 535854.520985,139580.483985 535850.089985,139580.752985 535847.100985,139580.748985 535844.297985,139580.113985 535838.063985,139579.392985 535835.150985,139578.222985 535831.671985,139577.100985 535828.887985,139575.349985 535825.206985,139573.169985 535821.251985,139570.621985 535817.165985,139565.947985 535810.671985,139563.686985 535807.948985,139560.612985 535804.659985,139558.108985 535802.262985,139554.445985 535799.139985,139549.466985 535795.479985,139544.282985 535792.276985,139538.972985 535789.483985,139532.216985 535786.483985,139528.012985 535784.877985,139522.443985 535783.012985,139498.844985 535775.793985,139481.569985 535769.907985,139475.702985 535767.695985,139470.596985 535765.137985,139468.001985 535763.386985,139466.883985 535762.396985,139464.852985 535760.143985,139462.813985 535757.076985,139461.575985 535754.350985,139459.684985 535748.568985,139458.819985 535743.777985,139458.353985 535740.212985,139457.651985 535731.980985,139457.160985 535721.682985,139457.087985 535713.035985,139457.389985 535710.492985,139458.081985 535707.539985,139459.525985 535704.076985,139461.210985 535701.557985,139463.801985 535698.894985,139466.281985 535697.157985,139469.421985 535695.731985,139473.755985 535694.584985,139480.230985 535693.382985,139487.658985 535692.342985,139497.732985 535690.655985,139507.707985 535688.863985,139515.608985 535688.004985,139536.445985 535687.421985,139560.876985 535685.892985,139568.980985 535685.624985,139575.288985 535685.903985,139579.849985 535686.480985,139588.121985 535688.083985,139596.121985 535690.179985,139601.973985 535691.519985,139606.159985 535692.152985,139612.312985 535692.703985,139618.514985 535692.777985,139621.601985 535692.529985,139627.534985 535691.492985,139631.225985 535690.396985,139635.337985 535688.505985,139638.406985 535686.551985,139639.584985 535685.626985,139642.840985 535682.480985,139645.451985 535679.212985,139648.795985 535673.937985,139651.978985 535668.218985,139668.201985 535637.219985,139672.423985 535629.667985,139677.545985 535622.037985,139680.573985 535618.604985,139682.864985 535616.615985,139685.943985 535614.660985,139688.770985 535613.559985,139692.249985 535612.928985,139695.280985 535613.008985,139698.224985 535613.644985,139700.766985 535614.733985,139702.087985 535615.482985,139705.439985 535617.839985,139707.680985 535619.832985,139712.062985 535624.286985,139715.241985 535628.088985,139718.403985 535632.235985,139721.539985 535636.765985,139724.665985 535641.644985,139731.570985 535653.529985,139737.212985 535664.169985,139739.633985 535669.254985,139741.716985 535674.194985,139743.466985 535678.998985,139744.879985 535683.722985,139745.639985 535686.957985,139746.437985 535691.658985,139746.900985 535696.335985,139746.980985 535699.429985,139746.262985 535708.502985,139744.114985 535718.330985,139740.327985 535733.143985,139738.458985 535739.114985,139735.962985 535745.484985,139733.105985 535751.646985,139724.889985 535768.299985,139722.678985 535773.301985,139720.685985 535778.355985,139718.976985 535783.420985,139717.642985 535788.432985,139716.487985 535794.996985,139716.255985 535798.802985,139716.424985 535806.302985,139716.897985 535814.641985,139720.252985 535833.369985,139721.254985 535840.218985,139722.032985 535848.318985,139722.636985 535860.654985,139723.041985 535865.500985,139723.595985 535869.969985,139724.425985 535873.622985,139725.907985 535877.893985,139727.294985 535880.672985,139728.946985 535883.210985,139731.655985 535886.283985,139734.007985 535888.197985,139736.641985 535889.770985,139739.492985 535890.878985,139740.985985 535891.198985,139742.449985 535891.287985,139744.945985 535890.794985,139746.374985 535890.179985,139748.401985 535888.804985,139750.468985 535886.617985,139753.620985 535882.153985,139757.971985 535874.263985,139766.546985 535856.319985,139770.020985 535849.785985,139775.406985 535840.970985,139787.949985 535822.120985,139792.813985 535813.795985,139795.325985 535808.760985,139797.476985 535803.700985,139799.223985 535798.645985,139800.003985 535795.747985,139800.796985 535792.077985,139801.378985 535788.309985,139801.878985 535781.357985,139801.971985 535757.446985,139801.772985 535751.399985,139801.317985 535745.229985,139799.979985 535735.531985,139797.665985 535724.587985,139795.239985 535715.729985,139790.553985 535700.992985,139787.074985 535690.615985,139784.300985 535683.246985,139781.903985 535677.405985,139774.772985 535661.279985,139771.370985 535653.166985,139767.425985 535643.120985,139764.622985 535635.052985,139762.357985 535626.853985,139760.604985 535617.923985,139759.689985 535609.708985,139759.670985 535602.051985,139760.175985 535597.480985,139761.074985 535592.961985,139762.333985 535588.513985,139764.487985 535582.705985,139767.018985 535577.178985,139769.898985 535571.857985,139773.045985 535567.308985,139774.918985 535564.960985,139776.980985 535562.899985,139779.363985 535561.024985,139782.591985 535559.191985,139785.460985 535558.179985,139786.945985 535557.864985,139788.990985 535557.684985,139790.500985 535557.739985,139793.505985 535558.303985,139795.110985 535558.903985,139796.414985 535559.597985,139798.880985 535561.344985,139802.353985 535564.379985,139805.549985 535568.247985,139808.696985 535572.568985,139814.126985 535580.708985,139823.426985 535595.492985,139828.793985 535604.633985,139833.129985 535612.775985,139838.706985 535624.155985,139843.536985 535634.544985,139847.396985 535643.335985,139852.464985 535655.668985,139857.816985 535669.898985,139867.280985 535697.844985,139870.030985 535705.535985,139874.258985 535716.398985,139878.906985 535727.026985,139883.055985 535735.583985,139886.787985 535742.582985,139890.766985 535749.443985,139897.980985 535760.815985,139901.071985 535765.981985,139903.940985 535771.255985,139912.046985 535787.324985,139914.373985 535791.455985,139918.063985 535797.258985,139921.357985 535801.454985,139923.505985 535803.573985,139924.970985 535804.706985,139926.243985 535805.496985,139928.986985 535806.781985,139932.583985 535807.856985,139935.570985 535808.318985,139938.005985 535808.411985,139941.020985 535808.199985,139943.963985 535807.605985,139946.733985 535806.629985,139949.456985 535805.316985,139952.528985 535803.450985,139954.949985 535801.662985,139958.129985 535798.972985,139963.401985 535793.632985,139968.154985 535787.926985,139971.450985 535782.908985,139972.879985 535780.264985,139974.014985 535777.692985,139974.980985 535774.850985,139976.502985 535769.142985,139979.454985 535754.014985,139980.658985 535746.509985,139981.662985 535736.074985,139982.932985 535711.663985,139983.270985 535696.456985,139983.238985 535689.010985,139982.549985 535678.406985,139980.323985 535658.404985,139979.190985 535646.066985,139978.378985 535634.706985,139977.762985 535622.123985,139976.315985 535580.869985,139975.971985 535561.243985,139976.099985 535549.548985,139977.004985 535534.281985,139979.934985 535490.984985,139981.030985 535482.383985,139982.469985 535475.733985,139984.430985 535469.066985,139986.517985 535463.165985,139987.679985 535460.401985,139990.234985 535455.396985,139991.909985 535452.941985,139993.957985 535450.827985,139996.385985 535448.994985,139999.024985 535447.621985,140001.905985 535446.712985,140006.993985 535445.807985,140011.507985 535445.571985,140015.764985 535445.938985,140021.851985 535447.221985,140024.694985 535448.179985,140030.425985 535450.706985,140036.028985 535453.823985,140040.617985 535457.090985,140045.514985 535461.247985,140049.628985 535465.627985,140052.229985 535469.119985,140053.784985 535471.700985,140055.287985 535475.350985,140056.580985 535480.715985,140057.299985 535485.168985,140057.913985 535487.470985,140058.937985 535490.320985,140059.568985 535491.686985,140060.850985 535493.785985,140061.778985 535494.965985,140065.399985 535498.531985,140067.800985 535500.346985,140070.706985 535502.078985,140073.444985 535503.331985,140077.253985 535504.488985,140080.220985 535504.966985,140084.207985 535505.256985,140088.710985 535505.234985,140093.405985 535504.976985,140098.169985 535504.301985,140102.967985 535503.305985,140107.692985 535501.965985,140112.290985 535500.232985,140115.396985 535498.769985,140119.794985 535496.227985,140124.107985 535493.220985,140127.651985 535490.446985,140132.374985 535486.472985,140136.271985 535482.899985,140139.926985 535479.270985,140143.308985 535475.520985,140148.197985 535469.094985,140157.833985 535454.685985,140162.452985 535448.684985,140165.258985 535445.833985,140168.592985 535442.802985,140172.883985 535439.551985,140176.709985 535437.178985,140180.297985 535435.354985,140184.482985 535433.693985,140188.370985 535432.634985,140192.812985 535431.857985,140197.194985 535431.510985,140203.273985 535431.345985,140218.438985 535431.784985,140223.355985 535431.715985,140226.351985 535431.429985,140228.064985 535431.012985,140229.448985 535430.482985,140232.118985 535429.063985,140235.867985 535426.512985,140238.434985 535423.996985,140242.173985 535419.828985,140246.735985 535413.958985,140251.061985 535407.683985,140254.278985 535402.487985,140257.229985 535397.194985,140259.817985 535391.773985,140261.404985 535387.658985,140263.054985 535382.041985,140264.205985 535376.314985,140264.964985 535370.504985,140265.716985 535361.336985,140266.322985 535350.243985,140266.837985 535333.228985,140267.009985 535310.682985,140266.988985 535300.110985,140266.512985 535282.732985,140266.469985 535273.905985,140266.663985 535269.411985,140267.088985 535264.675985,140267.757985 535259.825985,140268.568985 535255.397985,140270.540985 535247.578985,140272.980985 535240.592985,140276.555985 535232.562985,140281.174985 535223.841985,140284.880985 535217.943985,140288.095985 535213.604985,140291.593985 535209.455985,140300.508985 535199.762985,140303.734985 535195.825985,140306.452985 535191.609985,140307.757985 535188.901985,140308.504985 535186.947985,140309.798985 535181.881985,140310.622985 535175.071985,140311.020985 535164.614985,140311.111985 535143.903985,140311.541985 535136.992985,140312.125985 535133.284985,140312.934985 535130.353985,140313.482985 535128.949985,140314.663985 535126.829985,140316.736985 535124.574985,140318.681985 535123.326985,140320.096985 535122.827985,140321.594985 535122.491985,140325.004985 535122.068985,140329.517985 535122.050985,140333.688985 535122.249985,140338.046985 535122.680985,140342.500985 535123.340985,140346.868985 535124.218985,140352.700985 535125.724985,140357.000985 535127.058985,140361.769985 535128.868985,140365.893985 535130.673985,140370.855985 535133.092985,140376.893985 535136.308985,140381.311985 535138.990985,140386.114985 535142.595985,140390.161985 535146.262985,140396.094985 535152.500985,140402.651985 535160.317985,140406.637985 535166.186985,140408.086985 535168.819985,140409.150985 535171.253985,140410.478985 535175.562985,140411.454985 535179.981985,140411.791985 535184.591985,140411.749985 535187.599985,140411.076985 535193.566985,140410.362985 535197.454985,140408.200985 535205.090985,140406.393985 535210.820985,140405.547985 535214.829985,140405.220985 535217.828985,140405.477985 535221.410985,140406.248985 535224.350985,140407.091985 535226.325985,140407.834985 535227.629985,140409.638985 535230.070985,140412.571985 535232.946985,140415.007985 535234.735985,140418.789985 535236.858985,140422.981985 535238.528985,140426.187985 535239.435985,140431.511985 535240.551985,140444.577985 535242.758985,140451.616985 535244.179985,140456.451985 535245.428985,140462.114985 535247.443985,140464.307985 535248.483985,140466.910985 535250.001985,140469.343985 535251.758985,140471.538985 535253.752985,140472.546985 535254.879985,140473.907985 535256.799985,140474.620985 535258.138985,140475.485985 535260.538985,140477.086985 535260.852985,140479.858985 535262.010985,140485.998985 535265.048985,140497.212985 535272.587985,140502.401985 535275.601985,140506.981985 535277.963985,140515.753985 535282.120985,140520.316985 535284.063985,140524.534985 535285.638985,140530.215985 535287.306985,140533.160985 535287.824985,140537.199985 535287.933985,140540.948985 535287.423985,140543.882985 535286.586985,140545.275985 535285.996985,140546.977985 535284.982985,140548.154985 535284.034985,140550.199985 535281.745985,140551.314985 535279.744985,140552.235985 535276.904985,140553.238985 535271.991985,140553.703985 535266.730985,140553.976985 535261.326985,140554.223985 535250.450985,140554.140985 535235.153985,140553.689985 535228.522985,140552.718985 535221.486985,140551.431985 535214.670985,140548.875985 535202.927985,140548.084985 535198.157985,140547.564985 535191.826985,140547.545985 535186.972985,140547.729985 535182.096985,140548.541985 535172.313985,140550.093985 535162.251985,140551.974985 535154.083985,140556.616985 535137.953985,140558.129985 535131.991985,140558.777985 535128.123985,140559.194985 535122.126985,140558.828985 535116.905985,140557.672985 535111.402985,140555.608985 535105.762985,140553.963985 535100.689985,140550.879985 535094.895985,140550.582985 535093.633985,140547.674985 535086.614985,140544.826985 535081.157985,140540.731985 535075.516985,140536.634985 535070.725985,140532.837985 535067.360985,140528.420985 535064.135985,140524.987985 535060.547985,140522.647985 535058.438985,140515.451985 535050.544985,140510.767985 535045.123985,140507.746985 535042.235985,140498.425985 535035.674985,140497.011985 535035.121985,140495.522985 535034.908985,140494.213985 535035.000985,140483.052985 535036.945985,140481.288985 535037.516985,140470.264985 535043.040985,140459.888985 535049.152985,140451.570985 535053.489985,140448.087985 535054.901985,140443.674985 535055.846985,140439.213985 535056.280985,140437.365985 535055.718985,140436.189985 535054.770985,140434.891985 535053.225985,140433.170985 535050.768985,140431.587985 535048.207985,140429.521985 535044.372985,140428.541985 535041.540985,140428.349985 535040.066985,140428.414985 535037.029985,140429.080985 535033.642985,140431.959985 535025.978985,140437.970985 535012.180985,140441.433985 535004.957985,140442.520985 535002.161985,140444.779985 534995.680985,140446.918985 534988.089985,140447.830985 534983.115985,140448.041985 534980.115985,140448.067985 534976.101985,140447.958985 534974.597985,140447.484985 534972.392985,140445.934985 534969.613985,140442.502985 534965.963985,140440.878985 534964.878985,140434.970985 534964.190985,140432.581985 534964.231985,140429.211985 534964.880985,140419.422985 534963.985985,140412.037985 534963.573985,140406.589985 534962.345985,140404.198985 534961.905985,140398.724985 534961.259985,140392.228985 534959.924985,140388.840985 534958.945985,140386.096985 534957.699985,140384.810985 534956.932985,140382.742985 534955.224985,140381.314985 534953.714985,140379.548985 534951.284985,140377.433985 534947.807985,140376.736985 534946.372985,140375.493985 534942.046985,140374.387985 534939.275985,140369.021985 534927.245985,140367.341985 534923.070985,140366.161985 534920.648985,140362.125985 534913.096985,140348.646985 534890.235985,140346.185985 534886.399985,140340.156985 534878.582985,140338.021985 534876.008985,140332.861985 534870.325985,140325.793985 534864.759985,140322.300985 534862.358985,140320.999985 534861.615985,140316.091985 534859.481985,140313.404985 534858.117985,140289.152985 534843.579985,140283.129985 534840.332985,140280.196985 534839.230985,140270.767985 534836.812985,140268.395985 534836.550985,140264.431985 534837.035985,140261.915985 534837.946985,140258.399985 534839.743985,140255.958985 534841.489985,140255.068985 534842.413985,140252.241985 534846.335985,140250.636985 534848.868985,140249.317985 534851.316985,140248.088985 534854.054985,140246.920985 534858.179985,140246.664985 534861.168985,140247.428985 534872.649985,140247.973985 534878.666985,140248.255985 534880.138985,140249.969985 534885.156985,140252.936985 534892.820985,140254.655985 534896.813985,140266.365985 534919.755985,140267.822985 534922.376985,140271.482985 534927.812985,140275.051985 534934.410985,140279.541985 534940.825985,140281.945985 534944.629985,140285.361985 534950.376985,140287.187985 534953.884985,140288.441985 534956.616985,140289.360985 534959.482985,140290.166985 534965.964985,140290.128985 534967.672985,140289.844985 534969.134985,140288.872985 534972.725985,140287.580985 534978.738985,140286.713985 534981.607985,140283.568985 534990.459985,140281.708985 534999.392985,140280.605985 535003.757985,140278.935985 535013.332985,140276.071985 535028.122985,140273.766985 535037.947985,140272.565985 535045.351985,140270.781985 535053.996985,140267.939985 535070.338985,140267.049985 535074.638985,140264.681985 535083.629985,140262.124985 535094.986985,140259.633985 535105.080985,140257.324985 535112.628985,140254.862985 535119.003985,140254.045985 535120.295985,140252.515985 535121.828985,140251.200985 535122.602985,140248.949985 535123.338985,140247.425985 535123.533985,140245.402985 535123.264985,140242.580985 535122.286985,140238.106985 535120.252985,140234.151985 535118.094985,140231.083985 535115.983985,140224.514985 535110.280985,140219.876985 535107.707985,140217.334985 535106.077985,140215.997985 535105.431985,140213.564985 535104.791985,140202.236985 535102.879985,140203.060985 535106.831985,140203.249985 535112.368985,140202.870985 535114.529985,140202.232985 535116.056985,140201.439985 535119.281985,140199.089985 535125.794985,140197.089985 535128.776985,140196.021985 535129.930985,140193.315985 535131.267985,140191.140985 535131.820985,140188.152985 535132.081985,140182.311985 535132.222985,140178.272985 535131.905985,140171.238985 535130.223985,140166.918985 535128.959985,140161.858985 535127.208985,140157.472985 535126.136985,140155.339985 535125.322985,140151.491985 535122.966985,140143.886985 535119.310985,140140.533985 535117.044985,140134.495985 535112.594985,140132.690985 535111.964985,140132.591985 535116.758985,140133.193985 535124.798985,140132.877985 535132.797985,140133.264985 535137.308985,140133.141985 535141.806985,140134.180985 535154.799985,140134.230985 535161.325985,140135.180985 535167.325985,140134.694985 535173.307985,140134.768985 535180.436985,140134.511985 535184.933985,140134.020985 535189.622985,140132.969985 535193.999985,140130.296985 535211.773985,140130.152985 535216.772985,140130.483985 535223.319985,140130.987985 535226.790985,140130.998985 535228.298985,140129.698985 535229.685985,140128.371985 535229.879985,140121.819985 535229.406985,140114.812985 535229.358985,140110.320985 535229.666985,140106.544985 535230.140985,140096.959985 535232.159985,140092.659985 535232.188985,140089.160985 535231.737985,140087.234985 535231.118985,140084.488985 535229.880985,140081.339985 535227.816985,140075.055985 535222.764985,140069.553985 535217.390985,140058.896985 535209.433985,140055.811985 535207.661985,140052.908985 535206.682985,140051.409985 535206.419985,140049.938985 535206.351985,140048.540985 535206.542985,140047.094985 535206.993985,140043.881985 535208.465985,140042.590985 535209.230985,140039.517985 535211.655985,140036.378985 535214.890985,140034.416985 535216.648985,140032.004985 535218.446985,140028.812985 535220.321985,140023.891985 535222.473985,140020.987985 535223.247985,140017.304985 535223.940985,140012.839985 535224.522985,140008.579985 535224.869985,140004.271985 535224.983985,140000.726985 535224.755985,139991.620985 535222.385985,139980.642985 535218.147985,139976.590985 535216.220985,139970.813985 535212.595985,139963.060985 535208.257985,139960.458985 535206.495985,139958.259985 535204.477985,139954.212985 535200.011985,139950.851985 535195.994985,139944.482985 535189.621985,139941.329985 535186.243985,139936.998985 535180.118985,139931.563985 535173.032985,139929.868985 535170.570985,139927.461985 535165.212985,139925.360985 535163.349985,139922.568985 535160.114985,139908.953985 535143.622985,139905.486985 535139.190985,139901.433985 535133.560985,139895.564985 535124.415985,139888.179985 535114.063985,139882.622985 535104.655985,139876.825985 535095.889985,139873.897985 535092.106985,139870.957985 535088.698985,139862.467985 535079.806985,139860.188985 535077.835985,139858.445985 535076.757985,139857.026985 535076.297985,139852.667985 535075.738985,139849.657985 535075.687985,139845.757985 535076.064985,139844.290985 535076.553985,139841.735985 535078.096985,139838.563985 535080.460985,139837.273985 535081.847985,139835.644985 535084.379985,139834.712985 535086.347985,139822.859985 535120.960985,139821.772985 535124.628985,139817.808985 535144.003985,139815.981985 535157.572985,139813.602985 535180.207985,139810.843985 535213.080985,139808.202985 535231.937985,139807.272985 535235.411985,139805.576985 535239.595985,139803.498985 535245.955985,139802.607985 535247.923985,139800.882985 535250.388985,139798.520985 535253.177985,139794.469985 535257.125985,139790.983985 535259.661985,139789.648985 535260.326985,139786.940985 535261.222985,139785.460985 535261.547985,139783.467985 535261.730985,139781.992985 535261.435985,139777.419985 535259.850985,139767.456985 535255.351985,139757.514985 535251.322985,139749.332985 535247.573985,139743.283985 535245.221985,139739.177985 535243.346985,139737.320985 535242.730985,139731.388985 535241.792985,139725.950985 535240.505985,139724.191985 535240.234985,139715.787985 535240.185985,139714.330985 535240.482985,139713.014985 535241.140985,139710.528985 535242.883985,139707.610985 535245.432985,139702.496985 535251.004985,139699.773985 535254.580985,139695.755985 535262.914985,139694.924985 535265.663985,139694.254985 535268.599985,139693.910985 535271.629985,139693.843985 535274.629985,139694.395985 535288.182985,139694.935985 535293.205985,139698.184985 535312.557985,139698.401985 535318.113985,139698.331985 535324.742985,139697.885985 535330.729985,139696.769985 535337.460985,139695.373985 535342.903985,139692.205985 535352.885985,139690.615985 535356.610985,139688.348985 535360.684985,139686.555985 535363.086985,139682.976985 535367.067985,139670.956985 535378.401985,139667.649985 535380.806985,139665.862985 535382.309985,139662.748985 535385.564985,139659.886985 535388.248985,139657.574985 535390.172985,139654.486985 535392.070985,139645.811985 535395.942985,139640.779985 535397.682985,139637.638985 535398.419985,139627.571985 535400.047985,139626.086985 535400.245985,139622.765985 535400.265985,139619.772985 535399.924985,139615.927985 535399.162985,139608.762985 535396.929985,139604.126985 535397.211985,139598.119985 535397.050985,139593.613985 535396.546985,139587.709985 535395.435985,139582.905985 535394.251985,139574.205985 535391.195985,139562.531985 535388.361985,139559.299985 535387.180985,139555.330985 535384.999985,139554.167985 535385.182985,139554.356985 535389.318985,139555.044985 535392.524985,139555.398985 535396.109985,139557.087985 535403.488985,139557.241985 535404.991985,139556.820985 535407.038985,139553.825985 535415.329985,139552.035985 535421.066985,139551.328985 535425.310985,139551.184985 535429.773985,139551.681985 535434.246985,139552.627985 535438.656985,139554.313985 535444.464985,139556.074985 535448.477985,139558.544985 535452.208985,139561.411985 535455.719985,139565.435985 535460.273985,139568.557985 535462.977985,139571.141985 535464.460985,139584.237985 535470.517985,139586.503985 535471.376985,139593.668985 535473.612985,139598.687985 535475.707985,139602.933985 535477.933985,139604.020985 535478.940985,139604.533985 535480.482985,139604.866985 535483.813985,139606.271985 535492.704985,139606.804985 535498.248985,139606.777985 535499.741985,139606.314985 535503.020985,139604.821985 535509.007985,139603.021985 535514.733985,139601.600985 535520.071985,139601.043985 535521.446985,139598.935985 535524.578985,139595.269985 535529.391985,139591.348985 535534.002985,139588.301985 535537.258985,139586.464985 535538.377985,139579.904985 535538.899985,139575.514985 535538.902985,139574.105985 535538.705985,139571.152985 535537.945985,139569.775985 535537.346985,139567.971985 535535.995985,139558.235985 535525.528985,139554.190985 535520.960985,139553.092985 535519.974985,139551.210985 535518.832985,139548.269985 535517.989985,139545.546985 535517.716985,139540.672985 535518.378985,139537.739985 535519.077985,139536.353985 535519.563985,139535.014985 535520.213985,139531.146985 535522.544985,139524.426985 535525.648985,139520.505985 535527.857985,139514.722985 535530.645985,139512.707985 535531.967985,139506.205985 535537.460985,139504.142985 535539.613985,139500.756985 535544.674985,139490.017985 535562.863985,139483.034985 535575.309985,139481.369985 535577.781985,139479.936985 535579.366985,139477.659985 535581.322985,139468.886985 535587.682985,139467.595985 535588.447985,139465.277985 535589.398985,139463.794985 535589.646985,139462.170985 535589.641985,139460.563985 535589.370985,139459.135985 535588.819985,139457.345985 535587.287985,139455.504985 535584.838985,139454.027985 535582.019985,139453.087985 535579.127985,139452.866985 535577.169985,139453.221985 535574.213985,139454.052985 535571.208985,139455.938985 535565.568985,139457.701985 535561.409985,139459.377985 535558.048985,139460.959985 535555.511985,139468.242985 535545.227985,139470.055985 535542.130985,139471.381985 535539.436985,139472.228985 535537.299985,139473.089985 535534.404985,139473.345985 535532.931985,139473.544985 535529.790985,139473.052985 535511.213985,139472.672985 535506.749985,139472.245985 535504.385985,139471.092985 535501.582985,139468.019985 535496.222985,139466.240985 535493.791985,139465.240985 535492.732985,139463.860985 535491.761985,139462.409985 535491.206985,139460.885985 535490.885985,139458.629985 535490.789985,139457.113985 535490.968985,139454.295985 535491.715985,139452.943985 535492.368985,139451.714985 535493.290985,139450.985985 535494.052985,139449.229985 535496.453985,139445.203985 535503.081985,139440.597985 535511.241985,139439.176985 535513.361985,139438.183985 535514.476985,139435.886985 535516.435985,139432.947985 535518.499985,139429.292985 535520.347985,139426.442985 535521.320985,139423.421985 535522.038985,139418.953985 535522.644985,139415.086985 535522.753985,139405.229985 535522.513985,139398.935985 535523.454985,139397.055985 535523.531985,139392.550985 535523.406985,139385.713985 535523.826985,139382.359985 535523.869985,139377.014985 535523.663985,139372.533985 535523.228985,139368.639985 535523.038985,139365.764985 535523.028985,139358.901985 535523.395985,139352.037985 535523.311985,139350.543985 535523.443985,139348.721985 535524.098985,139344.531985 535526.261985,139343.144985 535526.680985,139341.956985 535526.738985,139344.312985 535541.041985,139344.781985 535545.978985,139344.872985 535552.866985,139344.745985 535555.864985,139344.378985 535558.230985,139343.620985 535561.141985,139341.916985 535566.051985,139340.141985 535570.191985,139334.077985 535581.003985,139330.716985 535587.709985,139327.445985 535594.730985,139321.842985 535607.611985,139311.911985 535631.802985,139307.926985 535640.247985,139305.909985 535646.602985,139304.759985 535651.531985,139304.319985 535654.520985,139304.320985 535655.940985,139304.672985 535658.901985,139306.569985 535667.331985,139309.298985 535675.337985,139311.277985 535680.026985,139313.291985 535684.055985,139314.594985 535686.249985,139324.683985 535701.010985,139328.374985 535706.014985,139330.247985 535709.049985,139333.267985 535715.439985,139336.405985 535723.879985,139337.956985 535729.191985,139339.254985 535735.057985,139339.965985 535739.703985,139340.333985 535744.195985,139340.488985 535748.689985,139340.347985 535753.192985,139339.698985 535757.116985,139338.541985 535761.181985,139333.834985 535774.093985,139330.743985 535781.597985,139328.768985 535785.647985,139326.442985 535789.755985,139324.780985 535792.267985,139322.984985 535794.593985,139320.784985 535796.638985,139317.034985 535798.995985,139309.875985 535802.400985,139304.190985 535804.395985,139301.761985 535805.793985,139298.141985 535808.463985,139286.886985 535817.737985,139283.524985 535820.727985,139280.744985 535823.457985,139275.774985 535829.099985,139273.210985 535832.538985,139271.575985 535835.043985,139267.939985 535841.620985,139266.006985 535845.485985,139264.273985 535849.641985,139257.668985 535867.878985,139254.447985 535874.600985,139248.687985 535885.134985,139239.109985 535899.576985,139236.806985 535903.449985,139235.467985 535906.129985,139222.758985 535935.269985,139218.757985 535944.996985,139214.967985 535954.740985,139212.922985 535960.311985,139212.544985 535962.399985,139213.872985 535966.725985,139214.457985 535969.337985,139215.059985 535973.798985,139215.361985 535979.096985,139215.233985 535982.446985,139214.623985 535986.910985,139213.582985 535991.775985,139212.443985 535996.131985,139211.037985 536000.887985,139209.570985 536004.718985,139208.867985 536006.032985,139205.748985 536010.832985,139202.012985 536019.020985,139196.508985 536028.023985,139193.752985 536033.960985,139191.136985 536041.551985,139185.845985 536060.914985,139184.695985 536064.146985,139182.251985 536069.591985,139180.979985 536072.081985,139179.312985 536074.584985,139177.948985 536075.898985,139176.737985 536076.803985,139174.690985 536077.732985,139165.450985 536080.395985,139164.104985 536080.741985,139162.607985 536080.840985,139155.248985 536082.210985,139153.937985 536082.710985,139153.402985 536084.303985,139153.711985 536085.826985,139156.356985 536093.057985,139158.557985 536098.139985,139159.347985 536099.447985,139159.781985 536101.659985,139159.839985 536103.160985,139159.666985 536109.541985,139159.192985 536118.407985,139158.693985 536121.775985,139156.142985 536130.712985,139154.566985 536135.078985,139153.366985 536140.956985,139151.410985 536148.587985,139151.034985 536151.564985,139150.105985 536156.119985,139149.442985 536160.574985,139148.108985 536165.856985,139147.217985 536168.724985,139146.011985 536171.763985,139143.883985 536175.739985,139142.534985 536178.735985,139138.221985 536190.634985,139135.120985 536198.181985,139132.997985 536201.772985,139129.278985 536206.605985,139128.223985 536207.663985,139127.030985 536208.570985,139124.729985 536210.052985,139121.139985 536212.776985,139119.376985 536213.599985,139116.517985 536214.580985,139114.620985 536216.016985,139113.566985 536217.101985,139111.812985 536217.600985,139109.701985 536217.540985,139107.064985 536217.186985,139104.274985 536222.606985,139106.650985 536223.998985,139108.467985 536225.621985,139110.372985 536227.758985,139113.634985 536232.128985,139115.101985 536234.750985,139116.269985 536237.632985,139119.094985 536248.394985,139119.441985 536258.707985,139119.084985 536262.309985,139119.038985 536264.577985,139119.158985 536268.730985,139119.361985 536270.400985,139120.184985 536274.028985,139121.742985 536279.104985,139122.687985 536281.195985,139125.576985 536286.680985,139126.289985 536287.509985,139127.625985 536288.091985,139129.180985 536288.317985,139130.867985 536288.281985,139136.723985 536286.994985,139138.343985 536285.291985,139139.628985 536284.393985,139140.966985 536283.755985,139141.986985 536283.598985,139145.652985 536283.996985,139150.149985 536284.130985,139152.737985 536284.686985,139170.372985 536289.333985,139177.323985 536290.759985,139180.190985 536291.636985,139182.875985 536292.951985,139184.562985 536294.429985,139186.322985 536298.559985,139187.023985 536300.802985,139187.542985 536303.788985,139187.992985 536305.195985,139189.250985 536307.428985,139191.192985 536309.734985,139192.620985 536309.942985,139196.984985 536311.296985,139207.398985 536313.624985,139211.158985 536314.025985,139214.750985 536313.860985,139226.458985 536310.802985,139227.958985 536310.711985,139231.027985 536309.928985,139234.113985 536310.030985,139235.572985 536310.361985,139237.446985 536311.468985,139239.651985 536313.662985,139240.737985 536315.338985,139241.907985 536312.463985,139243.362985 536309.812985,139244.852985 536307.492985,139246.692985 536305.118985,139249.714985 536301.688985,139252.882985 536298.487985,139261.604985 536290.682985,139264.851985 536287.558985,139267.358985 536284.624985,139269.958985 536280.927985,139271.167985 536278.583985,139272.642985 536274.325985,139273.863985 536269.860985,139275.682985 536261.698985,139277.976985 536254.114985,139281.137985 536247.564985,139283.562985 536243.806985,139286.536985 536240.387985,139288.028985 536239.104985,139290.590985 536237.405985,139291.970985 536236.766985,139293.946985 536236.266985,139296.987985 536236.296985,139298.506985 536236.584985,139300.735985 536237.364985,139303.320985 536238.858985,139307.150985 536241.609985,139313.057985 536246.684985,139329.186985 536261.910985,139337.424985 536269.251985,139339.812985 536271.063985,139343.434985 536273.282985,139347.491985 536275.193985,139351.619985 536276.124985,139357.829985 536276.737985,139419.726985 536276.633985,139424.622985 536276.791985,139429.727985 536277.342985,139433.511985 536278.012985,139437.399985 536278.909985,139445.643985 536281.428985,139458.811985 536286.331985,139474.140985 536292.642985,139478.189985 536294.606985,139481.873985 536296.640985,139485.725985 536299.011985,139489.666985 536301.691985,139493.379985 536304.574985,139499.949985 536310.724985,139508.143985 536318.870985,139512.767985 536324.433985,139517.950985 536331.394985,139520.965985 536336.046985,139523.329985 536340.050985,139532.860985 536331.971985,139544.945985 536324.366985,139558.648985 536313.804985,139563.238985 536309.939985,139568.581985 536305.092985,139571.546985 536301.976985,139574.386985 536298.469985,139577.138985 536294.067985,139578.415985 536291.338985,139579.359985 536288.658985,139580.306985 536284.245985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>MULTIPOLYGON(((139209.864361365 536222.972189994,139210.431297005 536221.517745343,139213.592297005 536214.967745343,139218.119433008 536206.899740567,139220.544433008 536203.141740567,139226.975410525 536194.584567191,139229.949410525 536191.165567191,139237.636669051 536183.52183426,139239.128669051 536182.23883426,139246.578605338 536176.600056987,139249.140605338 536174.901056987,139259.077204942 536169.348056245,139260.457204942 536168.709056245,139273.573099412 536164.058541158,139275.549099412 536163.558541158,139294.686837194 536161.270634297,139297.727837194 536161.300634297,139310.958972088 536162.609730201,139312.477972088 536162.897730201,139323.27902284 536165.79412301,139325.50802284 536166.57412301,139338.265174743 536172.42994117,139340.850174743 536173.92394117,139347.074678732 536177.944173297,139350.904678732 536180.695173297,139356.026133182 536184.722201688,139361.933133182 536189.797201688,139364.542337504 536192.147278345,139374.67174683 536201.709581426,139419.600969378 536201.634090866,139422.146068807 536201.673008262,139427.042068807 536201.831008262,139432.671246054 536202.225065431,139437.776246054 536202.776065431,139442.804190975 536203.491696336,139446.588190975 536204.161696336,139450.37232967 536204.932695061,139454.26032967 536205.829695061,139459.31637517 536207.183617171,139467.56037517 536209.702617171,139471.814386673 536211.143068372,139484.982386673 536216.046068372,139487.364579531 536216.979628547,139502.693579531 536223.290628547,139506.872946853 536225.162479124,139510.921946853 536227.126479124,139514.440572203 536228.949579268,139516.703269686 536230.198853611,139517.606430487 536227.611294244,139519.773402566 536222.110125623,139522.423402566 536216.090125623,139524.975408584 536210.854149756,139527.663408584 536205.843149756,139533.621765 536196.474161606,139536.361765 536192.798161606,139542.136400548 536185.946546017,139545.446400548 536182.464546017,139551.643555573 536176.644709606,139555.432555573 536173.470709606,139561.589895469 536168.829803886,139565.722895469 536166.035803886,139570.653377554 536162.973760946,139585.031377554 536154.797760946,139589.115600527 536152.638951691,139597.337600527 536148.611951691,139600.567941215 536147.123689662,139614.605788305 536141.055518402,139609.780279514 536138.860854268,139599.564476841 536134.670832585,139592.850953429 536132.168961781,139570.478033169 536124.332525032,139567.382442866 536123.171030486,139561.423442866 536120.784030486,139557.028291501 536118.858093707,139550.710291501 536115.845093707,139546.19592971 536113.501132072,139541.83592971 536111.046132072,139537.968651123 536108.712479275,139532.541651123 536105.210479275,139529.922961463 536103.441420152,139517.149119949 536094.414344958,139503.122045358 536084.988196452,139499.083924571 536082.075473624,139492.474924571 536076.966473624,139487.553968081 536072.812973623,139482.478968081 536068.141973623,139478.447490872 536064.13897891,139472.305490872 536057.55997891,139470.085647335 536055.073663495,139465.465647335 536049.661663495,139463.50451461 536047.265910279,139458.56651461 536040.972910279,139455.933024069 536037.404361165,139453.074024069 536033.280361165,139450.769238377 536029.747600218,139448.076238377 536025.354600218,139446.264916956 536022.233764829,139443.705916956 536017.569764829,139442.750176555 536015.770308056,139437.752885533 536006.04483069,139436.660390725 536004.151222451,139436.520633654 536003.934897271,139434.563198932 536001.278060521,139424.473850796 535988.88044492,139423.312028848 535987.415908034,139416.920028848 535979.148908034,139414.858650413 535976.351235667,139410.180650413 535969.684235667,139406.79238699 535964.397716835,139403.44738699 535958.663716836,139399.597759121 535951.114629906,139397.611759121 535946.607629906,139395.049803009 535939.952872795,139394.008803009 535936.810872795,139392.316306585 535930.901562704,139391.608306585 535927.982562704,139390.505453999 535922.573838389,139389.975453999 535919.377838389,139389.065423082 535910.988142787,139388.910423082 535907.996142787,139389.256202186 535895.946929482,139389.897202186 535890.096929482,139392.516075974 535877.044089153,139393.386075974 535874.095089153,139399.495783559 535859.37198736,139400.953783559 535856.70198736,139406.900793906 535847.485029425,139407.836793906 535846.244029425,139416.210843149 535836.886966555,139418.380843149 535834.836966555,139427.069812462 535827.77789636,139428.282449354 535827.062723795,139426.051808198 535825.55757826,139418.280774941 535819.536795955,139417.162774941 535818.546795955,139411.177513878 535812.614403045,139409.146513878 535810.361403045,139403.176776753 535802.672230565,139400.091205427 535810.16305141,139398.155617167 535814.471558711,139396.180617167 535818.521558711,139394.033365481 535822.60147794,139391.707365481 535826.70947794,139388.991944659 535831.139890635,139387.329944659 535833.651890635,139384.144194408 535838.104753743,139382.348194408 535840.430753743,139374.047542467 535849.526809658,139371.847542467 535851.571809658,139360.69611695 535860.137816064,139356.94611695 535862.494816064,139349.248784927 535866.725381087,139342.089784927 535870.130381087,139340.396090461 535870.828023817,139335.672157912 535874.720493871,139335.049995174 535875.273815283,139335.005800216 535875.323985896,139334.326249791 535876.553194682,139334.238154548 535876.729339594,139334.183755187 535876.859797612,139328.186511935 535893.418726482,139325.305023776 535900.288339493,139322.084023776 535907.010339493,139320.252874876 535910.583153757,139314.492874876 535921.117153757,139311.191451761 535926.587568066,139302.946140159 535939.020099926,139291.820459021 535964.529766174,139289.905363157 535969.185636576,139289.938432344 535969.530715635,139290.240432344 535974.828715635,139290.307297712 535981.960567098,139290.179297712 535985.310567098,139289.543408393 535992.601274487,139288.933408393 535997.065274487,139287.96379567 536002.604046235,139286.92279567 536007.469046235,139286.143478057 536010.74898812,139285.004478057 536015.10498812,139284.366950036 536017.394324958,139282.960950036 536022.150324958,139281.078410585 536027.708476865,139279.611410585 536031.539476865,139275.701425462 536040.099273923,139274.998425462 536041.413273923,139271.757242369 536046.897900362,139271.671203889 536047.030309693,139270.245880296 536050.154118467,139266.002269543 536058.140947471,139263.129272395 536062.840364862,139262.840581028 536063.678077464,139258.193605811 536080.684197504,139256.506257371 536086.057099241,139255.356257371 536089.289099241,139253.119457724 536094.859008386,139250.675457724 536100.304008386,139249.041831343 536103.711135421,139247.769831343 536106.201135421,139243.402934482 536113.655719233,139241.735934482 536116.158719233,139233.753605977 536125.716781793,139233.383126401 536129.39993291,139232.884126401 536132.76793291,139230.813455626 536142.361950041,139228.262455626 536151.298950041,139227.011345979 536155.174874632,139226.851289519 536155.958884527,139226.018301756 536159.579180725,139225.047552546 536163.366393004,139224.522159551 536166.552819283,139223.993843355 536169.143217853,139223.625986791 536171.615014223,139222.15973211 536178.94002488,139220.82573211 536184.22202488,139219.732210239 536188.108133427,139218.841210239 536190.976133427,139216.929413838 536196.389342743,139215.723413838 536199.428342743,139212.136823127 536207.154743435,139211.740680059 536207.894905485,139208.732925569 536216.192904714,139207.594144186 536219.139432547,139206.556147112 536221.665638259,139209.864361365 536222.972189994)),((139393.648507081 535668.974736443,139397.187012699 535662.377434254,139398.872012699 535659.858434254,139407.456267504 535649.256643269,139410.047267504 535646.593643269,139410.699960735 535646.038230011,139410.368589237 535645.800166734,139408.578589237 535644.268166734,139397.3959599 535632.354541231,139395.5549599 535629.905541231,139394.594734167 535628.386189625,139390.928598216 535636.814441846,139383.694768091 535654.435384807,139385.84169416 535657.576506395,139388.732034058 535661.495027351,139392.199486509 535666.626750626,139393.648507081 535668.974736443)),((139548.724566362 535611.506800266,139554.628778365 535611.137288574,139552.459746567 535610.579054857,139549.764858782 535609.652657427,139548.724566362 535611.506800266)),((139593.98450066 535612.829328195,139594.118510319 535612.850765761,139596.104127044 535613.235551013,139596.587685007 535612.311565728,139593.98450066 535612.829328195)),((139673.793292709 535540.214143275,139675.386311294 535539.763978944,139678.865311294 535539.132978944,139694.228840552 535537.95509534,139697.259840552 535538.03509534,139702.578710636 535538.674149893,139703.940626818 535536.15791517,139708.219930733 535529.188390852,139711.366930733 535524.639390852,139714.415105893 535520.539122747,139716.288105893 535518.191122747,139721.898840694 535511.915115248,139723.960840694 535509.854115248,139730.603961741 535503.95788024,139732.986961741 535502.08288024,139742.32994248 535495.806278369,139745.55794248 535493.973278369,139757.643371885 535488.463159874,139760.512371885 535487.451159874,139769.898169371 535484.812425618,139771.383169371 535484.497425618,139780.369942617 535483.153836792,139782.414942617 535482.973836792,139791.720962751 535482.734686659,139793.230962751 535482.789686659,139804.33595446 535484.027071477,139807.34095446 535484.591071477,139819.768277813 535488.052351736,139821.373277813 535488.652351737,139830.347113557 535492.696619516,139831.651113557 535493.390619516,139839.770416859 535498.399075464,139842.236416859 535500.146075465,139848.23313285 535504.870517295,139851.70613285 535507.905517294,139860.17101037 535516.607696199,139863.36701037 535520.475696199,139866.175448217 535524.094239862,139869.322448217 535528.415239862,139871.088962473 535530.948783811,139876.518962473 535539.088783811,139877.61079229 535540.773960122,139886.91079229 535555.557960122,139888.103132131 535557.519362678,139893.470132131 535566.660362678,139894.992049347 535569.380385515,139899.328049347 535577.522385515,139900.477386794 535579.771023682,139901.31516658 535581.480533089,139900.983503197 535562.558365808,139900.97647671 535560.423170544,139901.10447671 535548.728170544,139901.231410096 535545.110912013,139902.136410096 535529.843912013,139902.176129275 535529.218157315,139905.106129275 535485.921157315,139905.536580389 535481.504616269,139906.632580389 535472.903616269,139907.727569766 535466.521787328,139909.166569766 535459.871787328,139910.517916095 535454.570342114,139912.478916095 535447.903342114,139913.722873363 535444.05972708,139915.809873363 535438.15872708,139917.379333372 535434.099735655,139918.541333372 535431.335735655,139920.880565071 535426.301581819,139923.435565071 535421.296581819,139928.281284908 535413.127148888,139929.956284908 535410.672148888,139938.042764184 535400.756522259,139940.090764184 535398.642522259,139948.768873328 535390.970285527,139951.196873328 535389.137285526,139961.770241772 535382.461156606,139964.409241772 535381.088156606,139976.45795545 535376.097659227,139979.338955449 535375.188659227,139988.77191981 535372.871964344,139993.85991981 535371.966964344,140003.078198775 535370.910277303,140007.592198775 535370.674277303,140017.949911065 535370.849153224,140022.206911065 535371.216153224,140031.233391578 535372.551462914,140037.320391578 535373.834462914,140045.801435499 535376.14861572,140048.644435499 535377.10661572,140054.954143977 535379.555038384,140060.685143977 535382.082038384,140066.886939636 535385.166167283,140072.489939636 535388.283167283,140079.526078487 535392.725680129,140084.115078487 535395.992680129,140089.15466377 535399.91414691,140094.05166377 535404.07114691,140098.726512732 535408.516819305,140103.01981089 535402.9389708,140108.999803458 535396.075505027,140111.805803459 535393.224505026,140114.807696967 535390.339232673,140118.141696967 535387.308232673,140123.301512613 535383.022699546,140127.592512613 535379.771699546,140133.352921212 535375.815849286,140137.178921212 535373.442849286,140142.722507012 535370.322038166,140146.310507012 535368.498038166,140152.630459311 535365.644813416,140156.815459311 535363.983813416,140164.772803628 535361.330259624,140168.660803628 535360.271259624,140175.448108298 535358.756711754,140179.890108298 535357.979711754,140186.892449945 535357.092035099,140190.838930916 535356.779522799,140190.884425591 535356.224874951,140191.384904544 535347.063467311,140191.846641347 535331.808221288,140192.00941674 535310.471395717,140191.991024918 535301.212427353,140191.541104092 535284.786536347,140191.513874886 535283.098336958,140191.470874886 535274.271336958,140191.512545689 535272.093904653,140185.720426649 535279.58800745,140184.420426649 535280.97500745,140171.647989504 535291.857369263,140156.775783199 535299.627725036,140140.548240181 535303.897127438,140139.221240181 535304.091127438,140122.971661697 535304.685309063,140118.859796961 535304.388466569,140117.960082912 535304.382303265,140112.418874501 535305.549512423,140097.46578745 535307.158279406,140093.16578745 535307.187279406,140083.072252838 535306.573629867,140079.573252838 535306.122629867,140066.212696596 535303.140898521,140064.286696596 535302.521898521,140056.410017786 535299.491650564,140053.664017786 535298.253650564,140045.91041656 535293.998970293,140043.207364236 535294.944090043,140040.303364236 535295.718090043,140034.856746414 535296.954548187,140031.173746414 535297.647548187,140026.999015077 535298.311851479,140022.534015077 535298.893851479,140018.928973161 535299.275404514,140014.668973161 535299.622404514,140010.563970137 535299.843739094,140006.255970137 535299.957739094,139999.458235513 535299.829344348,139995.913235513 535299.601344348,139981.836229486 535297.337934244,139972.730229486 535294.967934244,139964.610449657 535292.353341535,139953.632449657 535288.115341535,139948.432359296 535285.878890735,139944.380359296 535283.951890735,139936.727452829 535279.749709235,139932.54725805 535277.126685853,139926.439384794 535273.709175962,139921.007929164 535270.359035674,139918.405929164 535268.597035674,139909.748922084 535261.754373676,139907.549922084 535259.736373676,139902.684028655 535254.839806614,139898.637028655 535250.373806614,139896.691574038 535248.139807316,139895.458387161 535246.665927017,139891.433330773 535242.638342725,139889.65545913 535240.797588631,139886.50245913 535237.419588631,139883.656864185 535233.923766068,139882.478064239 535242.340513731,139880.651880309 535251.332766992,139879.721880309 535254.806766992,139876.779680676 535263.586783247,139876.060577869 535265.360796302,139874.79020805 535269.248934921,139871.822763689 535276.889159193,139870.931763689 535278.857159193,139864.05623411 535290.925295228,139862.33123411 535293.390295228,139858.115934725 535298.859485986,139855.753934725 535301.648485986,139850.866768772 535306.889426252,139846.815768772 535310.837426252,139838.591137687 535317.775172015,139835.105137687 535320.311172015,139824.424394308 535326.794235263,139823.089394308 535327.459235263,139813.208246239 535331.530645088,139810.500246239 535332.426645088,139803.02729072 535334.477546416,139801.54729072 535334.802546416,139792.31873936 535336.233801626,139790.32573936 535336.416801626,139772.739552331 535335.485350733,139772.678742189 535336.301651896,139771.875901206 535342.997515306,139770.759901206 535349.728515306,139769.418622067 535356.093631949,139768.022622067 535361.536631949,139766.860140665 535365.591636888,139763.692140665 535375.573636888,139761.184890728 535382.329329996,139759.594890728 535386.054329996,139756.15272478 535393.079269016,139753.88572478 535397.153269016,139748.450918814 535405.548751581,139746.657918814 535407.950751581,139742.330206559 535413.229145,139738.751206559 535417.210145,139734.43001005 535421.6352482,139722.41001005 535432.9692482,139716.367341855 535437.98096576,139714.053470745 535440.271929189,139711.191470745 535442.955929189,139707.861562168 535445.898268999,139705.549562168 535447.822268999,139696.847652128 535454.068662605,139693.759652128 535455.966662605,139685.055743243 535460.55858256,139677.244733764 535464.044948981,139679.161996055 535473.022424303,139679.281976452 535474.222588568,139680.352720534 535480.998379059,139680.927760864 535485.527580863,139681.460760864 535491.071580863,139681.792723809 535499.605092802,139681.765723809 535501.098092802,139681.041311863 535510.228084524,139680.578311863 535513.507084524,139679.086384778 535521.168254061,139677.593384778 535527.155254061,139676.370083997 535531.49952852,139675.069518067 535535.63677325,139674.076936689 535539.365414627,139673.793292709 535540.214143275)),((140348.349868583 535048.405807409,140349.040549268 535048.491083095,140353.494549268 535049.151083095,140353.949912521 535049.230533165,140353.367156934 535038.462150023,140353.432156934 535035.425150023,140354.487097864 535025.675012826,140353.046982524 535024.921582566,140352.820628165 535026.219392737,140352.568155198 535027.591439053,140349.704155198 535042.381439053,140349.089465707 535045.253294723,140348.349868583 535048.405807409)),((140470.06810426 535126.311451101,140472.345219058 535130.026794286,140473.794219058 535132.659794286,140476.807853807 535138.779309401,140477.871853807 535141.213309401,140477.93607927 535141.386279119,140478.88796169 535137.252852428,140479.90027765 535133.341840454,140482.491412105 535124.338178506,140481.861863133 535122.666316784,140481.426968742 535122.285601366,140481.294236525 535122.340592859,140481.273605186 535122.290795276,140479.748404943 535122.995617904,140476.265404943 535124.407617904,140470.06810426 535126.311451101)))
+ </op></test></case><case><desc>
+ #51 Polygon - gid: 2551
+ </desc>
+ <a>POLYGON((167603.370985 536610.679985,167627.312985 536610.283985,167671.695985 536624.130985,167685.005985 536588.552985,167710.046985 536546.816985,167709.176985 536506.215985,167690.358985 536469.760985,167672.327985 536431.817985,167630.130985 536412.716985,167595.078985 536402.756985,167542.703985 536389.811985,167506.924985 536432.458985,167469.539985 536465.608985,167446.234985 536432.913985,167420.629985 536414.438985,167396.383985 536428.615985,167396.997985 536430.166985,167397.062985 536435.715985,167395.979985 536476.018985,167395.650985 536485.335985,167393.612985 536527.161985,167393.405985 536534.767985,167393.625985 536539.256985,167394.056985 536541.856985,167395.254985 536546.202985,167396.337985 536548.977985,167398.387985 536552.990985,167400.219985 536555.799985,167403.048985 536559.308985,167405.697985 536561.920985,167409.163985 536564.807985,167412.098985 536566.934985,167418.852985 536571.198985,167422.776985 536573.403985,167443.578985 536583.279985,167447.746985 536585.454985,167451.828985 536587.817985,167455.912985 536590.371985,167464.088985 536595.878985,167471.759985 536601.610985,167474.551985 536604.070985,167511.324985 536596.279985,167534.715985 536616.533985,167548.609985 536632.724985,167575.399985 536624.196985,167603.370985 536610.679985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>POLYGON((167518.99487489 536521.948060763,167523.287951439 536522.240215727,167536.666844921 536525.691103894,167549.185676584 536531.537664739,167560.419577491 536539.581475424,167566.761745414 536545.073086262,167570.737869345 536543.151622347,167586.028245886 536537.712667658,167602.130656777 536535.690241795,167626.072656777 536535.294241795,167629.371484375 536535.503008799,167634.600578813 536526.787642581,167634.56625147 536525.185660445,167623.714310522 536504.162836168,167622.618760385 536501.952008114,167616.376875282 536488.817082348,167604.275130745 536483.339076272,167575.825658869 536475.255179779,167570.105583803 536473.841406572,167564.382352842 536480.663247059,167556.684223921 536488.575098034,167519.299223921 536521.725098034,167518.99487489 536521.948060763))
+ #52 Polygon - gid: 2552
+ </desc>
+ <a>POLYGON((139328.097985 537673.993985,139333.694985 537673.778985,139339.685985 537674.116985,139343.484985 537674.560985,139347.201985 537675.198985,139349.266985 537662.315985,139350.795985 537650.307985,139350.815985 537648.813985,139350.170985 537642.977985,139349.497985 537639.338985,139348.573985 537636.478985,139347.401985 537633.734985,139336.285985 537613.547985,139333.452985 537607.471985,139331.129985 537601.716985,139328.904985 537595.513985,139326.508985 537587.806985,139319.008985 537559.965985,139317.097985 537554.004985,139314.973985 537548.226985,139312.575985 537542.468985,139306.136985 537528.279985,139299.926985 537514.031985,139288.894985 537489.864985,139279.105985 537467.759985,139274.759985 537456.114985,139264.851985 537426.033985,139261.266985 537416.840985,139258.190985 537410.222985,139246.959985 537387.429985,139229.076985 537347.488985,139217.864985 537323.218985,139213.134985 537312.367985,139200.100985 537278.784985,139189.030985 537249.549985,139177.539985 537217.909985,139166.856985 537192.155985,139162.415985 537180.965985,139158.622985 537170.454985,139150.636985 537146.582985,139135.766985 537108.920985,139128.573985 537089.138985,139126.052985 537082.845985,139123.397985 537077.227985,139120.597985 537072.327985,139117.710985 537068.104985,139114.766985 537064.522985,139112.716985 537062.323985,139107.519985 537058.085985,139104.012985 537055.863985,139101.294985 537054.558985,139100.275085 537053.707685,139098.476985 537053.526985,139095.233985 537052.734985,139092.248985 537052.457985,139089.268985 537052.711985,139087.784985 537053.032985,139084.678985 537054.199985,139080.094985 537057.047985,139075.290985 537060.908985,139069.415985 537066.744985,139061.822985 537075.205985,139058.488985 537078.691985,139054.032985 537082.720985,139050.724985 537085.113985,139048.133985 537086.645985,139045.410985 537087.957985,139042.557985 537088.968985,139040.380985 537089.363985,139037.334985 537089.294985,139035.878985 537088.972985,139033.462985 537087.869985,139030.014985 537085.492985,139025.487985 537081.543985,139018.084985 537074.336985,139013.673985 537069.604985,139009.409985 537064.385985,139006.208985 537059.858985,139002.414985 537053.912985,138998.748985 537047.430985,138995.999985 537041.968985,138993.942985 537037.449985,138990.339985 537028.148985,138987.242985 537017.910985,138981.534985 536995.496985,138978.988985 536986.537985,138977.585985 536982.260985,138976.022985 536978.202985,138973.066985 536972.030985,138970.402985 536968.255985,138968.487985 536965.910985,138966.359985 536963.834985,138963.995985 536962.186985,138961.235985 536960.885985,138958.980985 536960.276985,138955.951985 536960.106985,138952.749985 536960.533985,138949.931985 536961.489985,138935.372985 536968.382985,138907.537985 536979.752985,138901.926985 536982.393985,138896.463985 536985.384985,138891.293985 536988.728985,138886.976985 536992.219985,138884.882985 536994.338985,138883.500985 536996.130985,138882.011985 536998.803985,138881.564985 537000.190985,138881.413985 537001.324985,138881.475985 537002.858985,138881.775985 537004.391985,138882.629985 537006.611985,138883.396985 537007.887985,138887.677985 537013.078985,138890.845985 537016.283985,138895.056985 537020.219985,138905.804985 537029.443985,138913.316985 537036.186985,138920.975985 537043.717985,138932.473985 537056.309985,138954.679985 537081.634985,138960.113985 537088.091985,138965.986985 537095.578985,138977.422985 537111.070985,138982.004985 537117.556985,138986.599985 537124.630985,138993.679985 537137.096985,139005.600985 537160.149985,139020.608985 537187.869985,139033.486985 537210.770985,139044.059985 537228.558985,139053.006985 537244.088985,139060.092985 537255.519985,139080.707985 537286.417985,139090.120985 537300.972985,139103.078985 537322.123985,139116.233985 537344.359985,139119.222985 537349.562985,139122.383985 537355.881985,139125.129985 537362.380985,139130.126985 537375.644985,139131.858985 537379.337985,139134.566985 537383.961985,139137.705985 537388.053985,139140.085985 537390.525985,139142.627985 537392.724985,139146.633985 537395.533985,139157.818985 537402.034985,139160.679985 537403.920985,139163.066985 537405.758985,139166.396985 537408.850985,139168.416985 537411.072985,139169.280985 537412.268985,139170.702985 537414.781985,139171.293985 537416.228985,139171.679985 537417.695985,139171.789985 537419.141985,139171.407985 537421.760985,139170.997985 537423.212985,139169.908985 537426.097985,139168.082985 537430.080985,139164.605985 537435.318985,139160.534985 537442.262985,139157.693985 537447.550985,139155.404985 537452.605985,139153.763985 537456.816985,139152.517985 537461.396985,139151.670985 537466.320985,139151.198985 537471.522985,139151.025985 537479.913985,139151.322985 537488.108985,139151.969985 537496.769985,139153.000985 537505.180985,139154.541985 537513.906985,139156.515985 537522.716985,139158.932985 537531.649985,139161.825985 537540.914985,139164.822985 537549.648985,139168.521985 537559.663985,139171.990985 537568.494985,139174.560985 537574.436985,139178.737985 537582.989985,139191.871985 537607.370985,139200.694985 537624.740985,139204.472985 537633.189985,139210.692985 537649.126985,139214.176985 537657.443985,139221.014985 537672.431985,139229.336985 537691.644985,139232.848985 537698.786985,139235.354985 537703.365985,139240.767985 537712.073985,139247.162985 537721.413985,139250.052985 537724.904985,139254.219985 537729.231985,139256.988985 537731.610985,139259.413985 537733.383985,139264.102985 537736.538985,139269.901985 537740.072985,139273.000985 537741.589985,139275.922985 537742.341985,139277.410985 537742.524985,139279.635985 537727.507985,139281.333985 537721.724985,139283.443985 537716.470985,139285.539985 537712.482985,139287.579985 537709.020985,139295.083985 537697.805985,139298.702985 537692.885985,139303.840985 537687.353985,139308.168985 537683.551985,139313.904985 537679.507985,139316.481985 537677.948985,139319.149985 537676.579985,139323.819985 537674.867985,139328.097985 537673.993985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>POLYGON( EMPTY)
+ #53 Polygon - gid: 2553
+ </desc>
+ <a>POLYGON((159078.115985 538635.625985,159073.785985 538635.186985,159069.280985 538635.348985,159064.698985 538635.981985,159060.140985 538636.953985,159053.718985 538638.713985,159049.352985 538640.261985,159045.098985 538642.416985,159041.557985 538645.223985,159040.211985 538646.934985,159038.272985 538650.769985,159036.869985 538655.096985,159035.937985 538659.695985,159035.410985 538664.343985,159035.238985 538667.833985,159035.436985 538672.256985,159036.130985 538676.707985,159037.159985 538681.153985,159040.569985 538692.905985,159043.786985 538701.322985,159048.117985 538711.817985,159054.692985 538726.630985,159055.753985 538730.994985,159058.420985 538739.629985,159061.765985 538747.994985,159063.932985 538752.384985,159068.550985 538760.122985,159075.501985 538770.881985,159083.125985 538782.032985,159087.563985 538789.479985,159095.628985 538805.198985,159112.434985 538839.730985,159114.544985 538843.709985,159116.844985 538847.550985,159120.775985 538852.888985,159123.785985 538856.247985,159126.988985 538859.454985,159136.194985 538868.100985,159140.257985 538871.235985,159142.189985 538871.273985,159143.808985 538868.428985,159144.961985 538864.099985,159145.681985 538858.985985,159146.004985 538853.787985,159146.011985 538850.486985,159145.553985 538846.088985,159144.577985 538841.705985,159142.124985 538832.929985,159141.174985 538828.511985,159140.509985 538823.611985,159139.715985 538814.637985,159139.301985 538806.178985,159139.157985 538797.168985,159139.285985 538792.663985,159139.602985 538788.179985,159140.747985 538778.977985,159143.071985 538765.663985,159144.541985 538759.111985,159147.121985 538750.372985,159148.229985 538746.003985,159148.933985 538741.616985,159149.054985 538739.850985,159148.987985 538735.412985,159148.521985 538730.945985,159146.822985 538722.006985,159144.223985 538711.122985,159142.868985 538706.798985,159141.212985 538702.601985,159140.035985 538700.141985,159137.864985 538696.224985,159135.480985 538692.403985,159132.936985 538688.667985,159128.117985 538682.115985,159125.304985 538678.613985,159114.153985 538665.988985,159111.392985 538662.402985,159106.122985 538654.963985,159103.346985 538651.417985,159099.169985 538647.188985,159095.641985 538644.364985,159091.850985 538641.679985,159087.859985 538639.280985,159083.733985 538637.315985,159079.537985 538635.934985,159078.115985 538635.625985))</a>
+ #54 Polygon - gid: 2554
+ </desc>
+ <a>POLYGON((159293.559985 538980.522985,159275.390985 538925.668985,159258.421985 538914.962985,159239.576985 538917.108985,159216.488985 538918.359985,159211.120985 538917.908985,159109.160985 538909.360985,159070.236985 538904.177985,158994.276985 538919.645985,158907.657985 538925.081985,158879.874985 538905.635985,158856.684985 538889.787985,158848.906985 538928.927985,158849.561985 538935.309985,158856.845985 538954.454985,158919.290985 538985.661985,158941.977985 538986.370985,158963.373985 538974.307985,159015.169985 538975.497985,159047.536985 538978.284985,159103.429985 539036.779985,159124.581985 539056.686985,159201.858985 539071.122985,159248.370985 539062.766985,159298.256985 538995.795985,159293.559985 538980.522985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>POLYGON((159178.260710927 538990.41719613,159202.122936517 538994.874862559,159205.932369085 538994.190488235,159206.951084137 538992.82288278,159204.848542186 538992.646234788,159178.260710927 538990.41719613))
+ #55 Polygon - gid: 2555
+ </desc>
+ <a>POLYGON((157894.850985 539376.542985,157892.525985 539323.248985,157914.055985 539274.176985,157921.162985 539246.664985,157923.305985 539204.844985,157931.860985 539190.504985,157926.415985 539170.883985,157884.235985 539120.656985,157872.168985 539101.762985,157863.337985 539018.735985,157870.107985 538987.808985,157855.347985 538912.078985,157845.930985 538889.356985,157836.700985 538868.127985,157832.085985 538857.051985,157829.933985 538849.014985,157827.652985 538828.317985,157824.558985 538808.198985,157824.169985 538803.715985,157824.279985 538799.462985,157824.905985 538795.026985,157826.159985 538791.593985,157828.431985 538787.680985,157830.534985 538785.180985,157833.976985 538782.242985,157836.893985 538780.476985,157841.164985 538778.627985,157845.477985 538777.369985,157850.291985 538776.294985,157855.209985 538775.547985,157860.070985 538775.108985,157864.887985 538774.919985,157869.668985 538774.988985,157874.460985 538775.379985,157879.234985 538776.127985,157883.962985 538777.336985,157888.619985 538779.057985,157893.193985 538781.401985,157897.645985 538784.384985,157901.081985 538787.293985,157905.846985 538792.271985,157913.197985 538801.228985,157916.806985 538805.366985,157919.960985 538808.577985,157924.360985 538812.466985,157928.241985 538815.462985,157932.185985 538818.104985,157936.120985 538820.297985,157940.258985 538822.065985,157944.049985 538823.115985,157948.470985 538823.935985,157951.507985 538824.056985,157957.445985 538823.609985,157962.089985 538822.710985,157966.395985 538821.399985,157967.516985 538821.197985,157978.098985 538820.149985,157983.664985 538819.095985,157987.936985 538817.671985,157993.610985 538815.038985,158009.406985 538806.036985,158013.444985 538804.049985,158021.216985 538800.892985,158025.239985 538799.556985,158029.581985 538798.376985,158033.885985 538797.537985,158038.348985 538796.937985,158047.069985 538796.476985,158055.493985 538796.531985,158059.440985 538796.795985,158063.897985 538797.395985,158067.999985 538798.407985,158072.465985 538799.848985,158076.903985 538801.904985,158090.543985 538808.987985,158095.284985 538811.078985,158100.145985 538812.821985,158105.063985 538814.186985,158109.978985 538815.246985,158114.795985 538816.011985,158119.457985 538816.484985,158124.006985 538816.661985,158128.505985 538816.527985,158146.349985 538815.322985,158150.970985 538815.210985,158155.747985 538815.325985,158160.700985 538815.703985,158188.319985 538818.681985,158198.973985 538820.038985,158224.467985 538824.125985,158249.631985 538827.579985,158282.513985 538833.577985,158297.911985 538835.739985,158309.261985 538836.962985,158322.577985 538838.114985,158350.431985 538840.147985,158373.537985 538841.500985,158393.243985 538842.897985,158403.919985 538843.057985,158417.449985 538842.716985,158446.769985 538842.727985,158454.328985 538842.431985,158477.319985 538840.930985,158485.069985 538839.962985,158487.523985 538839.435985,158491.846985 538838.176985,158493.370985 538837.623985,158497.890985 538835.417985,158501.542985 538832.151985,158503.237985 538827.961985,158503.543985 538826.486985,158503.986985 538821.992985,158504.118985 538819.313985,158504.107985 538811.859985,158503.701985 538805.305985,158502.893985 538800.236985,158501.004985 538795.729985,158497.499985 538792.873985,158495.013985 538791.985985,158490.503985 538790.995985,158485.352985 538790.283985,158475.110985 538789.285985,158460.091985 538788.446985,158443.718985 538788.015985,158419.535985 538788.139985,158370.102985 538785.725985,158363.523985 538785.576985,158341.759985 538785.543985,158328.013985 538784.975985,158315.142985 538784.111985,158309.210985 538783.546985,158303.783985 538782.812985,158298.653985 538781.775985,158293.695985 538780.383985,158288.891985 538778.574985,158284.493985 538776.409985,158280.587985 538773.824985,158277.161985 538770.813985,158274.219985 538767.365985,158271.819985 538763.557985,158269.485985 538759.344985,158267.810985 538755.165985,158266.174985 538750.044985,158265.046985 538745.351985,158264.334985 538740.709985,158264.009985 538736.128985,158263.951985 538731.628985,158264.820985 538714.602985,158264.696985 538711.176985,158264.065985 538706.727985,158263.152985 538703.633985,158261.153985 538699.601985,158258.338985 538696.437985,158254.234985 538693.033985,158248.922985 538690.248985,158244.763985 538688.523985,158238.701985 538686.365985,158219.956985 538680.881985,158214.905985 538679.588985,158209.880985 538678.512985,158204.789985 538677.634985,158194.991985 538676.496985,158190.391985 538676.269985,158185.894985 538676.461985,158181.499985 538677.416985,158177.267985 538678.902985,158173.525985 538681.123985,158170.075985 538684.071985,158167.147985 538687.454985,158155.693985 538703.261985,158152.504985 538707.158985,158149.100985 538710.705985,158145.361985 538713.823985,158141.173985 538716.406985,158136.519985 538718.383985,158131.652985 538719.748985,158126.839985 538720.697985,158117.628985 538722.144985,158113.056985 538722.697985,158108.422985 538723.049985,158103.729985 538723.101985,158099.001985 538722.677985,158094.281985 538721.555985,158089.580985 538719.729985,158084.972985 538717.302985,158080.509985 538714.483985,158076.807985 538711.924985,158064.225985 538702.839985,158059.555985 538699.062985,158055.796985 538695.251985,158052.555985 538690.995985,158049.871985 538686.466985,158047.646985 538681.856985,158045.714985 538677.292985,158042.545985 538668.600985,158041.272985 538664.284985,158040.567985 538660.514985,158040.181985 538656.045985,158040.422985 538653.092985,158041.614985 538648.744985,158042.988985 538646.338985,158045.975985 538642.906985,158049.107985 538640.411985,158053.137985 538637.772985,158057.450985 538635.399985,158069.991985 538628.978985,158073.367985 538626.988985,158076.908985 538624.277985,158078.558985 538622.151985,158080.301985 538617.970985,158080.363985 538614.351985,158079.497985 538609.782985,158078.086985 538605.522985,158076.318985 538601.292985,158070.542985 538589.426985,158068.926985 538585.236985,158067.994985 538581.148985,158067.361985 538576.584985,158067.374985 538571.859985,158067.748985 538567.085985,158068.393985 538562.314985,158070.227985 538552.962985,158072.642985 538543.813985,158074.086985 538539.333985,158078.921985 538526.522985,158080.207985 538522.633985,158081.174985 538518.267985,158081.197985 538515.026985,158080.286985 538510.603985,158078.490985 538507.288985,158075.655985 538503.563985,158072.129985 538500.224985,158068.272985 538497.122985,158064.230985 538494.194985,158048.184985 538483.456985,158044.526985 538480.501985,158041.153985 538477.160985,158038.257985 538473.456985,158035.905985 538469.491985,158034.038985 538465.378985,158032.606985 538461.112985,158031.773985 538456.880985,158031.263985 538452.412985,158031.321985 538448.226985,158031.779985 538443.737985,158032.454985 538439.607985,158033.482985 538435.224985,158034.695985 538431.234985,158036.329985 538427.040985,158038.173985 538423.260985,158040.536985 538419.428985,158042.856985 538416.351985,158048.788985 538409.566985,158051.573985 538406.967985,158055.068985 538404.117985,158061.460985 538399.268985,158063.495985 538397.453985,158066.529985 538394.137985,158067.820985 538392.177985,158069.642985 538388.050985,158070.119985 538385.776985,158070.207985 538381.247985,158069.715985 538378.650985,158068.212985 538374.373985,158066.928985 538371.761985,158061.014985 538361.608985,158059.800985 538358.879985,158058.368985 538354.611985,158057.626985 538350.721985,158057.157985 538346.234985,158056.977985 538341.777985,158057.089985 538332.997985,158057.300985 538328.502985,158057.558985 538324.295985,158058.435985 538316.173985,158059.366985 538311.783985,158060.130985 538309.651985,158062.391985 538305.757985,158063.681985 538304.510985,158067.577985 538302.144985,158069.820985 538301.225985,158074.188985 538300.056985,158076.684985 538299.637985,158081.181985 538299.322985,158083.170985 538299.331985,158087.634985 538299.892985,158089.280985 538300.425985,158093.269985 538302.556985,158095.089985 538304.054985,158098.111985 538307.423985,158100.076985 538310.360985,158102.302985 538314.444985,158106.037985 538322.825985,158109.425985 538331.312985,158113.039985 538339.731985,158115.042985 538343.775985,158117.384985 538347.618985,158119.861985 538350.533985,158123.195985 538353.524985,158126.449985 538355.133985,158130.893985 538356.553985,158135.882985 538357.249985,158141.180985 538357.583985,158152.139985 538357.780985,158168.051985 538357.678985,158188.401985 538357.183985,158202.609985 538356.222985,158207.082985 538355.729985,158210.973985 538354.835985,158215.136985 538353.233985,158217.729985 538351.307985,158220.493985 538347.735985,158221.433985 538344.432985,158221.372985 538339.617985,158219.946985 538335.383985,158217.662985 538330.880985,158214.641985 538326.800985,158211.346985 538323.025985,158207.875985 538319.480985,158200.767985 538312.736985,158193.677985 538306.380985,158190.103985 538303.374985,158186.291985 538300.525985,158182.249985 538297.930985,158166.312985 538289.347985,158151.859985 538281.067985,158148.211985 538277.990985,158145.853985 538274.126985,158143.951985 538269.908985,158142.731985 538265.633985,158142.984985 538262.325985,158145.929985 538254.323985,158147.844985 538250.241985,158155.192985 538236.687985,158156.224985 538234.422985,158157.763985 538230.195985,158158.398985 538227.494985,158158.947985 538223.020985,158158.877985 538219.108985,158158.464985 538214.348985,158157.713985 538209.333985,158156.661985 538204.204985,158155.368985 538199.075985,158152.362985 538189.255985,158144.650985 538168.703985,158142.349985 538161.187985,158141.388985 538156.791985,158140.973985 538153.813985,158140.468985 538146.374985,158140.397985 538134.390985,158140.686985 538124.819985,158141.168985 538120.349985,158141.665985 538118.248985,158143.141985 538113.987985,158143.956985 538112.177985,158146.935985 538107.017985,158150.157985 538102.798985,158153.495985 538099.192985,158156.280985 538095.660985,158156.827985 538094.007985,158157.212985 538089.323985,158155.053985 538085.353985,158154.319985 538084.377985,158151.243985 538081.080985,158149.720985 538079.744985,158146.073985 538077.099985,158143.919985 538075.876985,158139.789985 538074.073985,158137.153985 538073.271985,158132.717985 538072.477985,158129.626985 538072.391985,158125.124985 538072.754985,158121.831985 538073.284985,158117.451985 538074.342985,158114.286985 538075.324985,158110.105985 538076.993985,158106.980985 538078.619985,158103.162985 538081.015985,158099.949985 538083.412985,158087.029985 538094.229985,158083.349985 538096.801985,158081.179985 538097.975985,158076.918985 538099.391985,158075.075985 538099.453985,158070.640985 538098.406985,158068.071985 538096.893985,158064.644985 538093.890985,158062.142985 538090.949985,158059.592985 538087.217985,158057.747985 538083.957985,158044.570985 538058.204985,158041.020985 538049.863985,158035.247985 538034.982985,158032.494985 538030.015985,158030.781985 538028.331985,158026.737985 538025.714985,158021.573985 538025.298985,158016.216985 538026.502985,158012.235985 538028.622985,158011.213985 538029.459985,158008.190985 538032.821985,158007.233985 538034.176985,158004.100985 538039.870985,157996.432985 538057.069985,157989.897985 538069.852985,157982.231985 538086.803985,157980.959985 538091.121985,157980.237285 538096.385085,157980.018985 538098.246985,157981.218985 538102.537985,157982.150985 538106.968985,157982.792985 538111.477985,157983.105985 538116.000985,157983.049985 538120.473985,157982.818985 538123.211985,157982.150985 538127.670985,157981.161985 538132.109985,157979.900985 538136.476985,157977.381985 538143.277985,157975.445985 538147.335985,157973.268985 538151.299985,157970.931985 538155.180985,157966.403985 538162.108985,157960.987985 538169.299985,157944.405985 538190.387985,157938.918985 538197.853985,157933.800985 538205.258985,157925.858985 538217.287985,157921.028985 538224.884985,157915.684985 538233.737985,157911.252985 538241.570985,157904.469985 538254.211985,157889.954985 538283.213985,157872.365985 538317.704985,157869.421985 538324.117985,157865.994985 538332.439985,157850.146985 538373.508985,157848.054985 538378.057985,157843.903985 538386.079985,157839.265985 538393.818985,157836.681985 538397.474985,157835.511985 538398.919985,157832.386985 538402.141985,157825.693985 538408.250985,157822.657985 538411.557985,157816.062985 538420.021985,157813.484985 538423.769985,157811.194985 538427.638985,157809.201985 538431.900985,157807.927985 538436.127985,157807.156985 538440.551985,157806.141985 538449.623985,157805.406985 538454.090985,157803.584985 538462.511985,157801.351985 538471.241985,157798.925985 538478.573985,157797.268985 538482.902985,157795.271985 538486.997985,157792.758985 538490.567985,157789.944985 538493.109985,157785.739985 538495.510985,157781.509985 538496.489985,157779.126985 538496.112985,157774.783985 538493.943985,157771.498985 538490.729985,157770.302985 538487.250985,157769.943985 538482.564985,157769.120985 538478.016985,157765.407985 538467.734985,157763.532985 538463.466985,157761.262985 538459.640985,157758.444985 538456.507985,157757.260985 538455.596985,157753.480985 538453.635985,157749.173985 538452.289985,157739.939985 538450.302985,157735.492985 538449.094985,157720.063985 538444.009985,157707.829985 538438.930985,157703.698985 538436.982985,157699.789985 538434.765985,157696.234985 538432.162985,157694.135985 538430.282985,157690.829985 538426.887985,157687.852985 538423.152985,157685.503985 538419.230985,157684.078985 538415.272985,157683.931985 538412.866985,157684.996985 538408.546985,157687.004985 538404.139985,157691.766985 538394.860985,157694.075985 538390.973985,157696.564985 538387.200985,157700.504985 538381.882985,157706.366985 538375.007985,157709.523985 538371.780985,157715.421985 538366.520985,157718.953985 538363.583985,157722.623985 538360.832985,157726.452985 538358.449985,157731.239985 538356.344985,157735.523985 538355.147985,157739.996985 538354.347985,157744.569985 538353.900985,157749.150985 538353.760985,157754.339985 538353.933985,157758.737985 538354.662985,157771.845985 538358.438985,157776.724985 538359.145985,157781.252985 538359.339985,157785.861985 538359.295985,157790.447985 538358.943985,157794.906985 538358.210985,157799.135985 538357.025985,157803.133985 538355.158985,157806.933985 538352.553985,157810.391985 538349.443985,157813.628985 538345.736985,157816.180985 538342.092985,157818.466985 538338.181985,157820.491985 538334.084985,157822.264985 538329.878985,157823.791985 538325.644985,157825.241985 538320.266985,157826.059985 538315.842985,157829.628985 538291.410985,157832.528985 538267.630985,157832.704985 538263.149985,157832.440985 538258.726985,157831.456985 538252.638985,157830.382985 538248.145985,157828.976985 538243.756985,157827.203985 538239.587985,157825.032985 538235.753985,157821.223985 538230.814985,157817.992985 538227.513985,157814.450985 538224.503985,157810.696985 538221.866985,157806.826985 538219.683985,157805.027985 538218.891985,157800.815985 538217.618985,157796.373985 538216.812985,157787.242985 538215.661985,157782.774985 538214.843985,157774.650985 538213.190985,157770.281985 538212.022985,157766.222985 538210.266985,157761.186985 538207.260985,157757.325985 538204.628985,157753.690985 538201.737985,157750.453985 538198.594985,157747.787985 538195.204985,157746.441985 538192.257985,157745.667985 538187.829985,157745.010985 538176.371985,157744.896985 538167.227985,157744.610985 538162.735985,157743.513985 538157.837985,157741.963985 538153.529985,157740.076985 538149.198985,157737.848985 538145.063985,157735.278985 538141.346985,157732.362985 538138.266985,157731.013985 538137.365985,157726.813985 538136.259985,157722.014985 538135.977985,157717.325985 538135.483985,157701.969985 538133.163985,157697.707985 538131.947985,157693.949985 538130.011985,157692.656985 538129.033985,157689.531985 538125.960985,157686.756985 538122.299985,157684.322985 538118.262985,157682.220985 538114.058985,157679.890985 538108.330985,157678.970985 538103.997985,157678.572985 538099.470985,157678.128985 538090.325985,157676.777985 538069.713985,157674.658985 538041.742985,157674.212985 538032.747985,157674.225985 538028.257985,157674.653985 538020.461985,157675.673985 538011.499985,157676.808985 538005.013985,157679.061985 537996.303985,157687.726985 537967.493985,157691.624985 537951.552985,157693.043985 537946.610985,157695.798985 537938.016985,157698.944985 537929.570985,157700.764985 537925.475985,157702.499985 537922.122985,157704.831985 537918.255985,157707.394985 537914.526985,157716.260985 537902.940985,157719.273985 537899.377985,157722.469985 537896.284985,157725.906985 537893.933985,157699.757985 537858.216985,157696.717985 537861.534985,157693.117985 537864.316985,157689.466985 537866.704985,157685.256985 537868.294985,157680.818985 537869.271985,157676.120985 537869.814985,157671.133985 537870.090985,157655.686985 537870.508985,157650.862985 537870.058985,157646.963985 537869.269985,157642.838985 537867.507985,157639.159985 537865.479985,157635.448985 537862.933985,157631.255985 537859.617985,157620.465985 537850.340985,157617.253985 537847.942985,157613.306985 537845.716985,157610.491985 537844.634985,157606.031985 537843.942985,157603.608985 537843.964985,157599.159985 537844.692985,157596.682985 537845.448985,157592.534985 537847.253985,157590.327985 537848.622985,157586.982985 537851.671985,157585.725985 537853.299985,157583.691985 537857.346985,157583.184985 537859.128985,157582.840985 537863.647985,157583.066985 537865.460985,157584.506985 537869.751985,157585.586985 537871.656985,157588.477985 537875.120985,157590.700985 537877.039985,157594.509985 537879.411985,157598.223985 537881.289985,157602.400985 537882.962985,157606.757985 537884.423985,157614.839985 537886.561985,157621.994985 537888.022985,157628.701985 537889.090985,157633.094985 537890.106985,157635.078985 537890.731985,157639.232985 537892.495985,157641.014985 537893.504985,157644.631985 537896.194985,157646.430985 537897.874985,157649.393985 537901.271985,157651.034985 537903.602985,157653.254985 537907.525985,157654.555985 537910.486985,157655.953985 537914.769985,157656.789985 537918.485985,157657.337985 537922.945985,157657.634985 537927.445985,157657.729985 537931.973985,157657.414985 537943.723985,157656.551985 537953.906985,157655.576985 537960.555985,157653.309985 537971.679985,157650.554985 537983.222985,157646.076985 537999.896985,157644.766985 538005.718985,157644.011985 538010.155985,157643.252985 538016.621985,157642.710985 538026.241985,157642.686985 538033.156985,157643.281985 538046.170985,157648.640985 538127.079985,157649.926985 538144.736985,157650.397985 538149.211985,157651.502985 538157.833985,157653.322985 538169.315985,157655.151985 538178.166985,157656.832985 538184.178985,157658.907985 538190.036985,157661.365985 538195.831985,157664.119985 538201.663985,157672.816985 538218.797985,157675.695985 538224.841985,157688.117985 538254.313985,157690.185985 538259.777985,157691.983985 538265.088985,157695.235985 538275.605985,157696.570985 538280.841985,157697.331985 538286.018985,157697.398985 538291.073985,157696.925985 538296.088985,157695.991985 538301.369985,157694.545985 538306.988985,157692.577985 538312.661985,157690.141985 538318.220985,157686.480985 538324.864985,157683.185985 538329.860985,157679.585985 538334.674985,157675.687985 538339.434985,157671.404985 538344.219985,157648.215985 538367.966985,157626.002985 538389.847985,157620.155985 538396.224985,157616.230985 538401.133985,157612.753985 538406.141985,157609.722985 538411.230985,157607.082985 538416.385985,157604.866985 538421.568985,157603.364985 538425.810985,157601.886985 538431.022985,157600.749985 538436.136985,157600.010985 538441.116985,157599.729985 538445.850985,157600.011985 538450.412985,157600.713985 538454.693985,157602.157985 538458.998985,157604.116985 538462.578985,157607.135985 538465.879985,157610.622985 538468.799985,157614.677985 538471.377985,157619.375985 538473.843985,157624.328985 538476.070985,157629.351985 538477.911985,157634.398985 538479.357985,157649.427985 538482.622985,157654.405985 538483.448985,157659.287985 538484.000985,157664.051985 538484.198985,157668.653985 538483.904985,157673.141985 538483.278985,157681.535985 538481.385985,157686.075985 538480.892985,157689.165985 538481.106985,157693.343985 538482.731985,157696.278985 538484.445985,157699.623985 538487.455985,157702.733985 538490.853985,157705.956985 538494.813985,157709.169985 538499.121985,157712.204985 538503.661985,157714.931985 538508.386985,157717.580985 538514.358985,157718.997985 538518.630985,157720.436985 538524.371985,157721.422985 538530.422985,157721.923985 538536.618985,157722.084985 538543.809985,157721.267985 538570.228985,157721.565985 538588.334985,157721.925985 538592.820985,157722.989985 538601.368985,157724.124985 538608.022985,157725.099985 538612.415985,157728.908985 538626.314985,157734.432985 538644.392985,157736.458985 538650.344985,157751.780985 538692.488985,157755.982985 538704.913985,157759.725985 538717.638985,157761.686985 538725.851985,157762.870985 538732.135985,157763.517985 538736.589985,157764.164985 538743.030985,157764.533985 538749.625985,157764.635985 538758.218985,157763.571985 538781.415985,157763.560985 538787.517985,157763.985985 538795.140985,157765.090985 538805.619985,157767.118985 538817.780985,157771.069985 538836.646985,157772.226985 538842.835985,157774.950985 538861.298985,157776.209985 538868.595985,157777.203985 538872.984985,157778.685985 538878.475985,157785.242985 538900.066985,157787.862985 538909.639985,157789.220985 538918.429985,157790.549985 538939.199985,157791.472985 538968.735985,157785.934985 539003.809985,157781.319985 539027.807985,157779.473985 539056.420985,157781.391985 539100.007985,157797.747985 539180.876985,157803.491985 539200.448985,157827.922985 539240.544985,157833.664985 539260.134985,157826.269985 539283.508985,157788.481985 539323.838985,157766.071985 539330.904985,157748.957985 539338.548985,157724.435985 539343.146985,157719.837985 539350.809985,157723.668985 539360.005985,157755.088985 539363.071985,157784.668985 539359.430985,157814.248985 539355.790985,157845.111985 539361.041985,157836.673985 539450.713985,157848.437985 539555.994985,157862.922985 539563.816985,157877.311985 539544.437985,157890.813985 539516.196985,157928.073985 539487.990985,157945.996985 539481.522985,157939.848985 539455.276985,157917.797985 539437.388985,157895.036985 539412.848985,157894.850985 539376.542985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>POLYGON((157796.315971774 538569.836655627,157796.287068268 538570.771296678,157796.51655414 538584.714488642,157796.554360558 538585.185598617,157797.206645716 538590.425949682,157797.745244705 538593.583515912,157797.919481214 538594.368563076,157800.953785266 538605.440705901,157805.813578304 538621.345003246,157807.209346082 538625.445501674,157822.267151913 538666.862821146,157822.828057742 538668.461636939,157827.030057742 538680.886636939,157827.934857368 538683.749673937,157831.677857368 538696.474673937,157832.675381246 538700.221017627,157833.391842316 538703.221677889,157833.946541803 538703.097809599,157839.029337825 538702.145455139,157843.947337825 538701.398455139,157848.464141048 538700.851977146,157853.325141048 538700.412977146,157857.130544557 538700.166648434,157861.947544557 538699.977648434,157865.97028183 538699.927794516,157870.75128183 538699.996794516,157875.768289503 538700.237406525,157880.560289503 538700.628406525,157886.070498612 538701.283971654,157890.844498612 538702.031971655,157897.815434141 538703.465980419,157902.543434141 538704.674980419,157909.960878759 538706.987077252,157914.617878759 538708.708077252,157922.824771831 538712.311954722,157927.398771831 538714.655954722,157934.941721853 538719.095272138,157939.393721853 538722.078272138,157946.107333833 538727.144285587,157949.543333833 538730.053285587,157955.261447511 538735.432767872,157960.026447511 538740.410767872,157963.822197432 538744.691792236,157964.38101881 538745.372701376,157972.27211218 538740.875637403,157976.293272272 538738.742988021,157980.331272272 538736.755988021,157985.219584274 538734.563822681,157990.250173409 538732.520388571,157988.035045636 538729.232726279,157985.351045636 538724.703726279,157982.327645477 538719.067018718,157980.102645477 538714.457018718,157978.580290662 538711.09380653,157976.648290662 538706.52980653,157975.252041945 538702.982937432,157972.083041945 538694.290937432,157970.609783042 538689.818497764,157969.336783042 538685.502497764,157967.550938196 538678.071203302,157966.845938196 538674.301203302,157965.846189067 538666.968915013,157965.460189067 538662.499915014,157965.430513151 538649.945373854,157965.671513151 538646.992373853,157968.091866643 538633.263478771,157969.283866643 538628.915478771,157976.48675695 538611.552056761,157977.86075695 538609.146056761,157986.415224019 538597.10069128,157989.402224019 538593.66869128,157993.472939651 538589.771346564,157993.073094374 538586.888417902,157992.362268865 538576.378636575,157992.375268865 538571.653636575,157992.604080307 538566.002356522,157992.978080307 538561.228356522,157993.425111595 538557.038007983,157994.070111595 538552.267007984,157994.795861715 538547.881820104,157996.629861715 538538.529820104,157996.70088911 538538.220715465,157991.747339704 538533.78715219,157988.374339704 538530.44615219,157982.069573379 538523.356572488,157979.173573379 538519.652572488,157973.753039013 538511.720700753,157971.401039013 538507.755700753,157967.612586264 538500.492173534,157965.745586264 538496.379173534,157962.93789653 538489.246017041,157961.50589653 538484.980017041,157959.018966831 538475.597583095,157958.185966831 538471.365583095,157957.257852642 538465.386631263,157956.747852642 538460.918631263,157956.271183239 538451.373906524,157956.329183239 538447.187906524,157956.709321548 538440.614465539,157957.167321548 538436.125465539,157957.762055759 538431.640623683,157958.437055759 538427.510623683,157959.436480734 538422.482038756,157960.464480734 538418.099038756,157961.725695513 538413.410049625,157962.938695513 538409.420049625,157964.812534203 538404.008099305,157966.446534203 538399.814099305,157968.923037128 538394.157807255,157970.767037128 538390.377807255,157974.335673585 538383.895136913,157976.698673585 538380.063136913,157980.651617094 538374.276546409,157982.971617094 538371.199546409,157984.778589215 538368.975203492,157984.697241855 538368.664538577,157983.955241855 538364.774538577,157983.033357126 538358.518822859,157982.564357126 538354.031822858,157982.219073597 538349.261461117,157982.039073597 538344.804461117,157981.984086341 538340.821343012,157982.096086341 538332.041343012,157982.172478513 538329.481278912,157982.383478513 538324.986278912,157982.441623023 538323.912132756,157982.699623023 538319.705132756,157982.992422962 538316.244412123,157983.869422962 538308.122412123,157985.067706085 538300.61456184,157985.998706085 538296.22456184,157988.763354436 538286.483246844,157989.527354436 538284.351246844,157995.271580689 538271.99222302,157997.532580689 538268.09822302,158010.265327737 538251.833856796,158011.555327737 538250.586856796,158024.751755253 538240.406092739,158028.647755253 538238.040092738,158039.143177393 538232.744252177,158041.386177393 538231.825252177,158050.431255267 538228.775737375,158054.799255267 538227.606737375,158061.772571758 538226.09190755,158064.268571758 538225.67290755,158071.444323691 538224.821305917,158075.941323691 538224.506305917,158077.197262624 538224.465217282,158078.030556455 538222.470137458,158079.945556455 538218.388137458,158081.751151683 538214.813369151,158081.327734832 538213.430151094,158074.431914697 538195.053219633,158072.936478878 538190.659157777,158070.635478878 538183.143157777,158069.080309692 538177.205309379,158068.266766762 538173.483837246,158057.843915446 538172.447517446,158053.408915446 538171.400517446,158047.613039717 538169.563495325,158045.073072605 538175.572205208,158043.137072605 538179.630205208,158041.184574479 538183.439140725,158039.007574479 538187.403140725,158037.519521703 538189.989370281,158035.182521703 538193.870370281,158033.712367603 538196.212967163,158029.184367603 538203.140967163,158026.31288683 538207.230193777,158020.89688683 538214.421193777,158019.944393919 538215.658822856,158004.117151368 538235.786967285,157999.997829803 538241.392007344,157995.951261752 538247.246801485,157988.803794101 538258.072398108,157984.787642157 538264.38931453,157980.440001128 538271.591722095,157976.942518167 538277.773081309,157971.061487748 538288.733144043,157957.024068947 538316.780902919,157956.768749663 538317.286273616,157939.881981569 538350.400237931,157938.204571002 538354.054189686,157935.664217882 538360.223089209,157920.118047022 538400.509919791,157918.286839608 538404.845229414,157916.194839608 538409.394229414,157914.665582115 538412.525772164,157910.514582115 538420.547772164,157908.235749676 538424.63415538,157903.597749676 538432.37315538,157900.512564652 538437.107048955,157897.928564652 538440.763048955,157894.970653103 538444.670653984,157893.800653103 538446.115653984,157889.349200165 538451.136402565,157886.224200165 538454.358402565,157882.948159266 538457.536638685,157880.416711585 538459.847204034,157880.146892975 538461.800749577,157879.411892975 538466.267749577,157878.710811231 538469.95128323,157876.888811231 538478.37228323,157876.245699025 538481.097480351,157874.012699024 538489.827480351,157872.555499637 538494.801685834,157870.129499637 538502.133685834,157868.970184323 538505.384619853,157867.313184323 538509.713619853,157864.680256862 538515.777297554,157862.683256862 538519.872297554,157856.601177321 538530.16892626,157854.088177321 538533.73892626,157843.033967768 538546.222509593,157840.219967768 538548.764509593,157827.133718922 538558.24060813,157822.928718922 538560.64160813,157802.651122881 538568.57953785,157798.421122881 538569.55853785,157796.315971774 538569.836655627))
+ #56 Polygon - gid: 2556
+ </desc>
+ <a>POLYGON((165866.082985 541862.721985,165851.682985 541848.138985,165804.193985 541863.105985,165801.945985 541874.734985,165814.893985 541890.902985,165824.346985 541905.179985,165834.300985 541928.120985,165826.139985 541936.876985,165823.907985 541948.444985,165827.893985 541968.536985,165846.896985 541979.346985,165875.377985 541971.704985,165921.822985 541960.759985,165900.301985 541937.964985,165886.338985 541910.918985,165892.219985 541895.974985,165878.605985 541877.133985,165866.082985 541862.721985))</a>
+ #57 Polygon - gid: 2557
+ </desc>
+ <a>POLYGON((164054.834985 543306.880985,164069.572985 543304.004985,164103.605985 543312.388985,164098.333985 543300.131985,164075.912985 543252.912985,164094.128985 543217.655985,164100.007985 543181.949985,164113.692985 543153.753985,164056.104985 543132.795985,164041.707985 543117.852985,164019.452985 543100.919985,163992.041985 543102.519985,163994.001985 543156.339985,163998.122985 543200.290985,163968.364985 543209.075985,163940.187985 543232.044985,163942.884985 543247.017985,163977.816985 543288.031985,163999.532985 543335.043985,164021.073985 543335.717985,164039.006985 543320.999985,164054.834985 543306.880985))</a>
+ #58 Polygon - gid: 2558
+ </desc>
+ <a>POLYGON((166001.678985 545096.446985,165986.188985 545050.627985,166031.006985 545078.395985,166053.356985 545047.590985,166042.301985 545030.529985,166001.118985 545004.006985,165970.376985 544983.927985,165949.330985 544958.286985,165946.693985 544938.892985,165963.120985 544919.755985,165995.255985 544914.667985,166022.427985 544917.764985,166062.571985 544932.058985,166097.433985 544907.541985,166121.008985 544885.492985,166149.252985 544896.697985,166161.300985 544855.607985,166120.499985 544852.803985,166098.819985 544833.284985,166055.523985 544765.349985,166034.012985 544756.903985,166001.675985 544764.667985,165941.932985 544777.760985,165896.886985 544801.133985,165869.851985 544814.425985,165811.901985 544827.664985,165792.911985 544829.897985,165725.363985 544817.517985,165706.523985 544809.004985,165670.402985 544807.309985,165679.523985 544816.702985,165708.514985 544857.040985,165719.255985 544868.100985,165743.555985 544882.196985,165762.492985 544890.766985,165804.664985 544895.609985,165839.702985 544901.606985,165850.419985 544915.467985,165839.532985 544931.763985,165828.625985 544950.808985,165805.144985 544992.480985,165777.668985 545014.324985,165794.091985 545037.066985,165845.431985 545028.795985,165878.092985 545037.633985,165894.460985 545035.084985,165902.747985 545013.031985,165924.190985 544999.320985,165937.750985 545007.789985,165924.471985 545029.942985,165905.294985 545049.089985,165910.679985 545063.023985,165933.681985 545062.029985,165942.031985 545072.420985,165942.314985 545083.029985,165940.263985 545106.979985,165926.679985 545138.892985,165924.557985 545160.165985,165927.736985 545178.652985,165939.544985 545184.712985,165957.986985 545197.293985,166012.773985 545218.448985,166021.131985 545230.145985,166042.780985 545212.268985,166042.259985 545193.319985,165989.913985 545147.241985,166007.501985 545109.760985,166001.678985 545096.446985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>POLYGON((166006.280209145 544840.438913134,166015.082113057 544841.442133229,166013.442395777 544838.869281385,166006.280209145 544840.438913134))
+ #59 Polygon - gid: 2559
+ </desc>
+ <a>POLYGON((165400.049985 545327.155985,165416.553985 545307.426985,165440.890985 545317.388985,165451.763985 545309.292985,165455.551985 545256.760985,165447.188985 545219.754985,165398.556985 545171.589985,165389.391985 545144.568985,165415.765985 545137.758985,165442.139985 545130.948985,165489.105985 545131.514985,165494.821985 545142.545985,165481.339985 545161.579985,165465.034985 545177.852985,165498.516985 545230.195985,165501.015485 545233.148485,165500.118985 545227.637985,165495.059985 545208.332985,165494.628985 545189.451985,165502.564985 545178.421985,165543.025985 545176.478985,165553.648985 545165.414985,165533.901985 545125.965985,165527.694985 545101.709985,165538.434985 545096.018985,165543.367985 545074.397985,165455.769985 545021.301985,165446.998985 544999.756985,165456.894985 544967.294985,165470.818985 544959.256985,165498.705985 544959.917985,165512.415985 544957.533985,165543.312985 544958.262985,165559.703985 544955.955985,165576.629985 544937.412985,165585.025985 544918.665985,165601.227985 544929.893985,165617.565985 544930.296985,165631.216985 544927.924985,165645.767985 544866.148985,165647.031985 544810.287985,165637.518985 544792.335985,165631.176985 544780.367985,165623.202985 544753.101985,165617.222985 544732.652985,165603.753985 544721.524985,165569.450985 544664.526985,165591.777985 544638.643985,165605.444985 544628.162985,165630.409985 544619.262985,165676.081985 544636.350985,165692.189985 544644.760985,165703.053985 544639.627985,165714.273985 544611.021985,165711.822985 544589.522985,165717.739985 544537.900985,165709.916985 544513.571985,165688.731985 544478.238985,165664.676985 544458.963985,165649.007985 544415.726985,165633.175985 544388.605985,165620.914985 544351.710985,165616.066985 544331.517985,165621.967985 544306.302985,165608.605985 544308.702985,165557.297985 544334.741985,165548.928985 544345.515985,165535.686985 544374.908985,165530.527985 544420.499985,165516.300985 544469.034985,165507.960985 544482.428985,165470.557985 544508.864985,165473.122985 544522.557985,165487.876985 544573.189985,165495.818985 544598.017985,165498.986985 544643.158985,165497.702985 544705.431985,165497.357985 544732.783985,165492.488985 544763.520985,165489.441985 544787.979985,165475.893985 544776.771985,165461.065985 544768.463985,165445.447985 544782.600985,165426.917985 544783.943985,165387.584985 544770.301985,165336.710985 544775.354985,165307.761985 544818.243985,165296.603985 544828.963985,165272.205985 544863.745985,165246.740985 544798.278985,165233.268985 544781.600985,165225.202985 544770.505985,165186.730985 544815.540985,165165.320985 544803.562985,165100.432985 544802.416985,165068.731985 544809.183985,165045.724985 544775.915985,165029.079985 544781.054985,165025.965985 544805.761985,164992.296985 544823.851985,164975.557985 544831.778985,164939.477985 544836.522985,164925.475985 544847.265985,164976.638985 544865.093985,164981.929985 544881.753985,164984.490985 544917.716985,164982.509985 544967.675985,164975.129985 545022.482985,165012.349985 545052.423985,165001.279985 545060.555985,164980.136985 545083.879985,165029.438985 545065.380985,165085.830985 545066.792985,165152.434985 545059.322985,165208.605985 545056.969985,165236.407985 545062.741985,165253.818985 545076.317985,165267.921985 545098.393985,165269.473985 545169.154985,165280.723985 545180.182985,165294.528985 545180.342985,165328.757985 545168.612985,165334.547985 545185.199985,165365.423985 545204.772985,165367.357985 545210.305985,165371.225985 545221.370985,165365.881985 545235.094985,165359.200985 545246.854985,165349.177985 545264.494985,165335.491985 545269.816985,165294.894985 545285.114985,165266.383985 545324.205985,165274.795985 545337.924985,165288.510985 545338.064985,165318.892985 545349.229985,165343.732985 545360.387985,165374.453985 545370.711985,165396.429985 545376.374985,165420.281985 545364.710985,165400.264985 545340.826985,165400.049985 545327.155985),(165342.461985 545093.777985,165322.031985 545055.610985,165307.902985 545033.527985,165304.183985 545003.597985,165314.784985 544970.879985,165305.688985 544951.716985,165327.686985 544941.061985,165380.740985 544947.170985,165397.607985 544966.537985,165396.440985 545017.969985,165394.198985 545050.695985,165377.954985 545069.612985,165386.777985 545105.268985,165378.710985 545118.851985,165345.544985 545115.710985,165342.702985 545110.200985,165342.461985 545093.777985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>MULTIPOLYGON(((165057.217205208 544883.120216485,165059.30153673 544912.389570074,165059.432092366 544920.688588389,165057.451092366 544970.647588389,165056.839151797 544977.684729339,165055.105079377 544990.562684236,165055.666345379 544991.014185186,165082.574837416 544991.687947258,165144.075738552 544984.790287485,165149.295992153 544984.388702299,165205.466992153 544982.035702299,165223.851710387 544983.535879454,165231.859198159 544985.198321703,165232.835721359 544980.480345081,165234.671869136 544974.813419038,165232.980105736 544970.113149715,165230.792111361 544955.6486919,165231.453631581 544941.034648987,165234.596064132 544928.226786517,165229.177458967 544925.175179585,165218.024334311 544915.604916041,165208.951612951 544904.043434258,165202.307658569 544890.934658417,165201.450878229 544888.731994426,165192.63043154 544890.308601857,165177.936402401 544890.023568984,165163.580078568 544886.878461346,165150.112731992 544880.994048692,165145.151531196 544878.218464239,165107.693212873 544877.556905356,165084.388987872 544882.531502075,165069.804209359 544884.176320174,165057.217205208 544883.120216485)),((165433.450985222 544894.243752377,165445.727600121 544888.578682779,165458.965228219 544885.199652816,165472.596195875 544884.27804448,165493.116772708 544884.764439621,165499.5672165 544883.642786958,165514.185081919 544882.554852596,165519.617671597 544882.683031962,165523.817930203 544875.323465139,165533.380754455 544864.280599446,165544.902815038 544855.300921817,165557.947005961 544848.72508928,165571.226811748 544845.023247916,165571.608985418 544828.133530063,165571.248634832 544827.453511802,165564.906634832 544815.485511802,165561.598307512 544807.342441787,165560.674592039 544811.451578352,165554.799933434 544824.767735359,165546.463962451 544836.698503939,165535.980603089 544846.794583753,165523.744647759 544854.675766933,165510.216889818 544860.045256316,165495.906770564 544862.700842514,165481.353194207 544862.542518913,165467.1042333 544859.576247815,165458.583903741 544855.97784482,165450.869543946 544857.404772996,165432.339543946 544858.747772996,165417.139633107 544858.30381175,165402.341694045 544854.803041746,165379.029034346 544846.717431606,165369.926358081 544860.203378698,165362.080227598 544869.526690428,165389.320308912 544872.663299482,165402.872948774 544875.510841409,165415.671006543 544880.801612583,165427.278136608 544888.355225886,165433.450985222 544894.243752377)),((165564.244956383 544565.763054216,165569.5976314 544562.284557272,165580.260093066 544557.517948244,165605.225093066 544548.617948244,165617.918405741 544545.31056484,165630.99381411 544544.265257411,165641.322078728 544545.252988251,165641.157714701 544544.741827264,165631.329809072 544528.350541467,165617.778879255 544517.492334349,165607.933959442 544508.007119591,165599.974337952 544496.892436919,165594.164474795 544484.51757388,165591.817078659 544478.040174765,165588.272635808 544490.131939281,165579.967528816 544508.678032292,165571.627528816 544522.072032292,165562.518379322 544533.89247424,165556.154902685 544539.416730683,165559.608905593 544551.269995916,165564.244956383 544565.763054216)))
+ #60 Polygon - gid: 2560
+ </desc>
+ <a>POLYGON((165039.888985 545214.900985,165061.521985 545211.327985,165071.841985 545218.422985,165077.658585 545221.274385,165042.910985 545188.529985,165018.330985 545164.645985,165012.696985 545156.314985,165001.478985 545145.165985,164983.560985 545134.409985,164959.705985 545136.405985,164912.749985 545126.728985,164872.247985 545143.406985,164854.636985 545152.272985,164842.895985 545158.183985,164822.013985 545183.452985,164819.327985 545202.866985,164836.326985 545230.849985,164837.880985 545249.634985,164820.022985 545295.891985,164797.828985 545328.982985,164765.676985 545371.292985,164741.785985 545411.115985,164755.907985 545414.000985,164781.197985 545405.853985,164828.946985 545376.498985,164869.393985 545349.987985,164902.767985 545314.165985,164924.560985 545268.486985,164951.092985 545252.883985,164976.229985 545250.334985,164992.874985 545239.445985,165003.027985 545231.057985,165018.255985 545218.473985,165039.888985 545214.900985))</a>
+ #61 Polygon - gid: 2561
+ </desc>
+ <a>POLYGON((165238.510985 545710.471985,165192.124985 545700.368985,165160.156985 545630.008985,165164.336985 545624.861985,165176.876985 545609.422985,165172.523985 545591.077985,165168.170985 545572.732985,165167.980985 545556.368985,165147.570985 545540.142985,165125.931985 545556.256985,165090.936985 545602.197985,165089.392985 545634.903985,165089.504985 545645.843985,165092.417985 545662.279985,165111.877985 545683.285985,165129.554985 545701.137985,165121.586985 545728.577985,165086.923985 545743.977985,165052.963985 545734.373985,165039.091985 545717.850985,165027.966985 545701.352985,165001.879985 545672.568985,164978.299985 545619.010985,164961.459985 545577.792985,164935.200985 545546.003985,164911.800985 545505.448985,164900.849985 545521.874985,164920.431985 545580.077985,164932.021985 545610.339985,164933.689985 545628.314985,164928.252985 545677.904985,164913.400985 545715.258985,164921.835985 545729.167985,164935.169985 545781.427985,164942.610985 545813.897985,164966.247985 545817.882985,164988.465985 545801.288985,165002.312985 545787.436985,165021.889985 545790.358985,165045.185985 545849.211985,165056.368985 545885.476985,165064.812985 545891.120985,165084.289985 545868.904985,165091.803985 545835.123985,165099.316985 545801.341985,165105.409985 545799.161985,165129.781985 545790.441985,165134.147985 545761.590985,165141.310985 545750.056985,165158.590985 545709.009985,165176.243985 545724.213985,165199.478985 545747.702985,165208.061985 545779.326985,165211.808985 545797.165985,165223.206985 545816.746985,165225.387985 545823.733985,165238.473985 545865.656985,165240.654985 545872.643985,165224.011985 545880.913985,165213.049985 545897.603985,165243.117985 545899.699985,165243.477985 545927.700985,165258.375985 545942.579985,165264.112985 545953.801985,165275.516985 545970.657985,165295.826985 545982.700985,165309.815985 545985.574985,165329.383985 545988.480985,165354.767985 546001.160985,165354.562985 545987.341985,165383.586985 545955.589985,165373.711985 545912.320985,165357.023985 545909.441985,165340.294985 545903.784985,165317.425985 545856.465985,165311.411985 545823.162985,165287.933985 545774.854985,165249.668985 545718.827985,165238.510985 545710.471985))</a>
+ #62 Polygon - gid: 2562
+ </desc>
+ <a>POLYGON((167132.502985 546739.675985,167129.431985 546728.461985,167149.272985 546730.744985,167174.754985 546732.873985,167203.344985 546749.030985,167214.701985 546712.855985,167222.891985 546698.488985,167172.714985 546705.889985,167136.868985 546710.488985,167119.637985 546696.854985,167075.210985 546707.329985,167010.354985 546685.151985,166970.378985 546680.545985,166953.227985 546678.167985,166944.879985 546686.925985,166934.540985 546732.693985,166943.806985 546763.687985,166970.472985 546795.157985,166972.578985 546790.292985,166993.557985 546761.456985,166991.220985 546735.941985,166999.607985 546730.041985,167040.797985 546729.182985,167063.593985 546739.815985,167081.551985 546762.749985,167104.289985 546789.026985,167117.932985 546804.791985,167133.736985 546789.873985,167149.540985 546774.955985,167144.229985 546759.119985,167132.502985 546739.675985))</a>
+ #63 Polygon - gid: 2563
+ </desc>
+ <a>POLYGON((142722.192985 546177.308985,142726.778985 546176.811985,142731.932985 546176.961985,142741.768985 546177.534985,142746.228985 546178.131985,142757.116985 546179.802985,142766.625985 546181.831985,142771.037985 546182.101985,142773.400985 546181.387985,142776.497985 546178.776985,142779.106985 546174.996985,142781.284985 546170.613985,142783.085985 546166.194985,142784.732985 546161.198985,142785.744985 546156.827985,142788.327985 546142.074985,142788.603985 546137.521985,142789.852985 546132.215985,142789.471985 546113.620985,142789.307985 546106.890985,142788.828985 546101.181985,142787.251985 546087.771985,142785.818985 546077.995985,142784.285985 546069.126985,142781.610985 546055.891985,142777.385985 546039.293985,142776.636985 546036.164985,142776.002985 546033.293985,142774.917985 546027.582985,142773.500985 546018.687985,142772.098985 546007.143985,142768.178985 546010.905985,142764.713985 546009.110985,142761.223985 546006.385985,142754.125985 545999.891985,142750.724985 545997.160985,142743.367985 545991.857985,142735.810985 545986.892985,142731.895985 545984.775985,142730.716985 545984.217985,142726.312985 545982.683985,142721.651985 545982.033985,142718.418985 545982.397985,142714.052985 545984.850985,142711.360985 545988.681985,142712.738985 545993.180985,142714.941985 545996.960985,142717.691985 546000.791985,142724.660985 546009.840985,142731.686985 546016.665985,142732.054985 546018.591985,142730.690985 546022.264985,142728.418985 546025.982985,142719.613985 546037.284985,142713.073985 546046.712985,142710.527985 546050.471985,142708.252985 546054.334985,142706.612985 546057.889985,142705.358985 546062.133985,142704.624985 546066.572985,142703.219985 546077.702985,142699.359985 546095.284985,142697.142985 546106.960985,142694.878985 546120.270985,142689.654985 546153.350985,142686.974985 546168.576985,142684.417985 546181.838985,142681.914985 546192.299985,142679.361985 546200.940985,142677.911985 546205.201985,142674.155985 546214.865985,142667.821985 546229.388985,142659.948985 546245.601985,142657.324985 546251.745985,142655.832985 546255.985985,142653.436985 546264.685985,142652.493985 546269.090985,142651.629985 546274.394985,142650.292985 546287.844985,142648.737985 546299.023985,142644.522985 546326.394985,142643.286985 546335.313985,142642.254985 546344.252985,142641.584985 546354.071985,142641.244985 546363.069985,142641.148985 546370.582985,142641.331985 546384.084985,142641.014985 546394.820985,142640.378985 546405.030985,142638.161985 546425.106985,142637.323985 546438.583985,142637.097985 546450.097985,142637.938985 546492.896985,142637.899985 546522.015985,142638.983985 546578.467985,142639.054985 546593.084985,142638.672985 546602.065985,142638.067985 546607.674985,142636.677985 546616.584985,142634.346985 546627.450985,142633.051985 546631.746985,142629.847985 546640.178985,142628.692985 546643.625985,142624.159985 546661.045985,142621.661985 546670.257985,142617.884985 546683.219985,142611.192985 546706.280985,142608.360985 546717.192985,142606.371985 546725.978985,142604.441985 546737.393985,142603.363985 546746.339985,142602.555985 546756.672985,142602.460985 546761.163985,142602.860985 546774.337985,142602.576985 546792.392985,142603.006985 546798.336985,142603.734985 546802.764985,142604.771985 546807.169985,142606.081985 546811.513985,142607.626985 546815.755985,142611.830985 546826.313985,142613.916985 546830.574985,142616.469985 546834.131985,142618.842985 546836.097985,142622.666985 546837.753985,142626.214985 546838.483985,142629.542985 546838.792985,142632.214985 546838.947985,142636.772985 546838.722985,142641.319985 546838.062985,142646.320985 546836.579985,142650.481985 546834.504985,142654.367985 546831.854985,142657.767985 546828.806985,142658.902985 546827.563985,142661.479985 546824.014985,142663.628985 546820.007985,142665.381985 546815.716985,142666.772985 546811.314985,142667.543985 546808.276985,142668.299985 546803.903985,142668.664985 546799.432985,142669.208985 546770.941985,142669.215985 546758.058985,142668.827985 546740.061985,142668.678985 546721.600985,142668.824985 546701.557985,142669.123985 546692.563985,142669.921985 546681.612985,142671.489985 546668.197985,142672.558985 546661.898985,142675.484985 546648.710985,142678.156985 546634.495985,142679.352985 546625.575985,142679.521985 546623.224985,142679.455985 546618.725985,142678.608985 546609.684985,142678.607985 546605.216985,142679.456985 546599.497985,142680.422985 546595.072985,142681.628985 546590.688985,142683.064985 546586.385985,142684.719985 546582.209985,142687.493985 546577.462985,142693.608985 546570.163985,142695.807985 546566.427985,142696.403985 546564.167985,142696.269985 546560.021985,142695.131985 546555.716985,142689.869985 546543.023985,142687.819985 546538.859985,142685.414985 546534.767985,142683.696985 546530.666985,142683.426985 546528.227985,142684.250985 546524.018985,142686.016985 546519.785985,142690.072985 546511.275985,142691.212985 546507.010985,142691.313985 546505.828985,142690.736985 546501.570985,142689.136985 546497.313985,142687.185985 546493.037985,142685.555985 546488.722985,142684.996985 546485.984985,142684.940985 546481.564985,142686.794985 546468.070985,142686.805985 546461.676985,142686.570985 546457.185985,142684.003985 546424.297985,142682.826985 546413.320985,142681.650985 546404.390985,142679.775985 546393.190985,142678.747985 546388.810985,142676.254985 546380.136985,142675.183985 546375.772985,142674.211985 546369.312985,142673.537985 546360.327985,142673.033985 546348.190985,142672.839985 546339.186985,142673.098985 546325.855985,142673.657985 546316.845985,142674.183985 546312.381985,142676.192985 546300.558985,142677.569985 546296.219985,142679.674985 546292.826985,142682.886985 546290.084985,142686.799985 546287.904985,142702.595985 546281.269985,142715.240985 546276.391985,142719.265985 546274.457985,142724.245985 546271.640985,142728.191985 546268.787985,142730.616985 546265.350985,142731.096985 546260.779985,142730.599985 546256.356985,142729.561985 546251.755985,142727.094985 546242.736985,142725.781985 546238.435985,142722.504985 546229.989985,142721.019985 546225.740985,142720.025985 546221.775985,142719.361985 546217.356985,142718.965985 546212.880985,142718.544985 546197.266985,142717.538985 546187.249985,142717.532985 546182.587985,142718.818985 546179.148985,142722.192985 546177.308985))</a>
+ </op></test></case><case><desc>
+ #64 Polygon - gid: 2564
+ </desc>
+ <a>POLYGON((164037.000985 546901.414985,164106.537985 546859.892985,164138.256985 546862.893985,164190.193985 546854.347985,164219.006985 546863.152985,164224.504985 546879.653985,164241.465985 546901.930985,164267.345985 546890.411985,164324.403985 546869.382985,164341.607985 546857.870985,164388.533985 546827.945985,164369.933985 546821.741985,164340.564985 546826.620985,164308.425985 546822.759985,164308.404985 546843.093985,164299.745985 546854.692985,164283.505985 546842.787985,164277.086985 546808.974985,164262.628985 546820.547985,164248.158985 546840.876985,164213.916985 546848.404985,164193.642985 546839.577985,164196.758985 546825.842985,164191.001985 546805.342985,164179.409985 546796.532985,164106.760985 546814.691985,164077.598985 546829.265985,164036.608985 546881.968985,164022.598985 546855.664985,164029.130985 546839.253985,163976.139985 546849.840985,163958.295985 546855.749985,163940.475985 546855.696985,163921.815985 546832.990985,163901.558985 546850.001985,163887.908985 546861.066985,163923.509985 546885.561985,163987.096985 546921.878985,164037.000985 546901.414985))</a>
+ #65 Polygon - gid: 2565
+ </desc>
+ <a>POLYGON((165997.948985 547128.168985,166014.238985 547102.270985,166026.375985 547112.440985,166060.687985 547117.495985,166091.450985 547096.872985,166113.825985 547082.132985,166119.200985 547070.590985,166109.259985 547010.901985,166075.888985 547034.320985,166069.749985 547061.434985,166058.900985 547078.693985,166028.270985 547076.283985,166018.907985 547042.519985,165995.926985 547026.000985,165977.533985 546969.846985,165948.195985 546992.608985,165951.810985 547025.403985,165967.402985 547043.519985,165969.936985 547070.390985,165940.250985 547086.636985,165949.182985 547103.514985,165974.111985 547121.355985,165997.948985 547128.168985))</a>
+ #66 Polygon - gid: 2566
+ </desc>
+ <a>POLYGON((165100.071985 522081.185985,165136.799985 522076.135985,165166.082985 522092.836985,165183.181985 522109.283985,165190.140985 522118.074985,165206.348985 522101.100985,165220.161985 522076.505985,165220.503985 522074.959985,165225.622985 522051.802985,165237.799985 522011.812985,165240.146985 521960.824985,165236.333985 521894.861985,165237.261985 521814.285985,165243.911985 521772.257985,165226.779985 521761.751985,165193.019985 521743.035985,165165.246985 521728.639985,165152.601985 521722.553985,165133.996985 521739.272985,165111.166985 521751.180985,165092.073985 521752.238985,165109.023985 521784.973985,165126.567985 521832.153985,165144.191985 521855.304985,165157.186985 521856.297985,165161.740985 521873.524985,165162.965985 521907.180985,165164.675985 521942.335985,165164.830985 521979.277985,165164.301985 521990.709985,165142.466985 521995.789985,165110.505985 522011.506985,165079.857985 522028.091985,165054.334985 522038.602985,165032.108985 522040.275985,165001.716985 522035.707985,164983.310985 522019.245985,164959.550985 521989.898985,164922.332985 521959.299985,164891.493985 521946.315985,164842.601985 521944.356985,164828.038985 521942.830985,164784.350985 521938.253985,164721.590985 521932.459985,164654.326985 521933.159985,164615.460985 521948.266985,164665.212985 521993.048985,164721.052985 522031.550985,164773.155985 522075.997985,164829.624985 522115.536985,164873.224985 522125.840985,164944.614985 522131.113985,164945.480985 522178.821985,164954.957985 522264.115985,164978.215985 522266.299985,165016.474985 522263.290985,165041.880985 522239.804985,165055.918985 522218.725985,165063.579985 522211.999985,165067.228985 522203.579985,165070.618985 522174.606985,165076.243985 522151.298985,165077.752985 522136.665985,165079.504985 522123.716985,165083.574985 522101.381985,165100.071985 522081.185985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>POLYGON((164820.266857 522017.427204655,164860.865764155 522045.854132527,164884.683758641 522051.483045719,164914.706877136 522053.700609857,164906.045863843 522043.003019071,164883.150492441 522024.179453335,164874.91441489 522020.711856107,164839.599301485 522019.296853506,164834.785821452 522018.948590341,164820.266857 522017.427204655))
+ #67 Polygon - gid: 2567
+ </desc>
+ <a>POLYGON((154374.974985 540624.728985,154320.493985 540619.008985,154292.141985 540622.113985,154300.537985 540553.371985,154315.955985 540540.285985,154376.940985 540530.412985,154405.631985 540496.147985,154445.668985 540435.041985,154454.521985 540417.090985,154451.884985 540403.553985,154445.292985 540369.710985,154445.579985 540362.563985,154447.014985 540326.827985,154437.326985 540254.795985,154511.563985 540278.324985,154528.041985 540293.316985,154555.203985 540318.597985,154568.395985 540311.500985,154566.744985 540300.457985,154553.075985 540281.217985,154539.316985 540265.833985,154513.536985 540265.913985,154479.903985 540247.544985,154439.739985 540232.015985,154403.476985 540219.274985,154352.216985 540193.238985,154334.278985 540175.092985,154332.774985 540144.333985,154350.235985 540125.468985,154371.989985 540117.381985,154383.699985 540112.299985,154407.119985 540102.135985,154415.975985 540097.389985,154420.402985 540095.016985,154432.473985 540079.628985,154446.542985 540043.686985,154432.038985 540027.748985,154407.872985 540019.283985,154375.098985 540051.097985,154358.677985 540070.534985,154354.465985 540108.800985,154334.695985 540111.082985,154308.823985 540096.567985,154262.980985 540157.924985,154255.293985 540164.418985,154215.750985 540176.802985,154206.665985 540194.763985,154166.906985 540153.065985,154162.757985 540169.964985,154166.319985 540198.641985,154180.928985 540222.157985,154211.961985 540249.040985,154209.983985 540262.387985,154208.994985 540269.061985,154197.947985 540292.833985,154192.961985 540297.380985,154158.065985 540329.211985,154140.829985 540316.837985,154117.762985 540294.223985,154092.528985 540254.239985,154073.822985 540242.348985,154048.200985 540266.020985,154064.357985 540290.020985,154062.051985 540304.767985,154040.168985 540346.540985,154041.641985 540357.709985,154049.520985 540373.836985,154104.527985 540418.794985,154090.465985 540443.160985,154069.529985 540448.440985,154046.019985 540476.715985,154023.556985 540493.431985,154012.295985 540517.485985,153979.630985 540532.522985,153949.623985 540550.285985,153937.859985 540571.634985,153958.642985 540598.024985,154012.244985 540548.784985,154030.269985 540532.534985,154070.531985 540499.593985,154087.180985 540483.491985,154132.461985 540455.676985,154148.344985 540445.370985,154180.755985 540450.271985,154197.244985 540479.738985,154193.874985 540497.126985,154183.840985 540529.466985,154188.908985 540557.187985,154202.879985 540575.534985,154249.118985 540618.863985,154258.226985 540629.278985,154262.780985 540634.485985,154280.201985 540662.114985,154287.169985 540673.165985,154298.532985 540705.614985,154310.100985 540727.104985,154343.491985 540740.559985,154373.404985 540748.738985,154410.171985 540758.451985,154418.213985 540774.691985,154432.851985 540756.015985,154427.625985 540739.482985,154393.172985 540712.859985,154367.238985 540699.027985,154362.824985 540688.093985,154374.974985 540624.728985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>POLYGON ((154211.34039180956 540382.1317209445, 154217.6503256708 540384.9741471609, 154228.8660526432 540392.7357234654, 154238.49064413007 540402.4001860456, 154246.20578777403 540413.6479038943, 154262.69478777403 540443.1149038943, 154268.08157501929 540455.0980127293, 154271.29462502326 540467.8372703156, 154272.15180599023 540479.7780934644, 154278.51581715897 540475.2995723275, 154290.83214622788 540469.6192125722, 154303.9701183911 540466.2499194533, 154337.37449228237 540460.8420095831, 154345.30698193613 540451.368420026, 154375.74125760913 540404.9184650026, 154371.67648756542 540384.050137885, 154370.35338301142 540366.7016572024, 154370.6403821483 540359.5546786959, 154371.8131743791 540330.3484744037, 154365.60057125118 540284.1566671671, 154318.252931651 540260.1078348488, 154307.99700814812 540253.816156007, 154298.8791629049 540245.9654179738, 154285.6658256004 540232.5988654748, 154284.9711923334 540232.8950064374, 154286.85393501408 540245.0165815549, 154286.15170738756 540260.035760671, 154284.17376698626 540273.3823585154, 154283.18482683104 540280.055954669, 154277.00972538022 540300.6688686018, 154265.96272538023 540324.4408686018, 154258.40762354335 540337.2145224822, 154248.48523614364 540348.2504649211, 154243.50247502665 540352.7945112105, 154211.34039180956 540382.1317209445))
+ #68 Polygon - gid: 2568
+ </desc>
+ <a>POLYGON((151090.928985 540950.574985,151117.445985 540939.721985,151149.481985 540941.866985,151212.221985 540950.239985,151224.726985 540959.131985,151249.097985 540961.645985,151268.213985 540941.565985,151298.490985 540913.861985,151331.140985 540899.607985,151337.670985 540896.756985,151348.111985 540887.739985,151353.647985 540867.974985,151359.183985 540848.209985,151369.021985 540811.954985,151379.284985 540781.097985,151400.204985 540762.390985,151448.885985 540728.437985,151463.818985 540705.351985,151467.765985 540683.006985,151476.666985 540635.436985,151502.123985 540589.717985,151524.591985 540550.077985,151549.839985 540521.107985,151566.568985 540511.980985,151568.176985 540482.157985,151563.945985 540460.707985,151540.525985 540413.008985,151531.631985 540402.717985,151516.708985 540476.937985,151515.687985 540483.808985,151509.564985 540525.034985,151508.544985 540531.905985,151482.998985 540568.953985,151467.271985 540597.511985,151456.715985 540625.756985,151448.935985 540653.713985,151423.440985 540680.452985,151380.551985 540719.880985,151350.280985 540763.588985,151319.225985 540796.248985,151296.298985 540802.965985,151285.001985 540839.802985,151267.089985 540869.796985,151235.102985 540900.984985,151195.281985 540918.277985,151141.469985 540910.674985,151100.987985 540911.757985,151081.554985 540915.883985,151051.966985 540895.325985,151048.320985 540889.129985,151026.445985 540851.954985,151007.887985 540827.846985,151044.137985 540791.294985,151075.221985 540763.652985,151091.194985 540751.370985,151090.038985 540734.632985,151083.686985 540723.848985,151064.053985 540703.043985,151053.089985 540686.671985,151050.667985 540661.563985,151063.916985 540610.385985,151108.013985 540532.246985,151121.916985 540503.720985,151119.042985 540462.231985,151138.133985 540416.520985,151140.118985 540378.023985,151158.122985 540338.727985,151164.124985 540325.628985,151178.649985 540301.860985,151189.543985 540284.034985,151224.790985 540245.614985,151236.485985 540217.614985,151242.398985 540178.166985,151252.590985 540145.914985,151264.740985 540108.947985,151277.958985 540082.053985,151275.701985 540049.776985,151262.771985 540058.740985,151247.206985 540085.158985,151233.574985 540106.623985,151183.995985 540125.600985,151183.849985 540187.672985,151167.715985 540232.645985,151145.098985 540276.657985,151124.279985 540320.641985,151108.773985 540335.412985,151085.813985 540350.102985,151070.872985 540391.428985,151052.396985 540415.220985,151020.243985 540439.842985,150982.357985 540466.123985,150936.027985 540486.159985,150893.723985 540505.026985,150878.560985 540522.467985,150839.929985 540557.935985,150820.111985 540562.409985,150778.385985 540607.088985,150766.205985 540627.265985,150708.205985 540687.434985,150691.026985 540725.163985,150659.099985 540758.887985,150603.544985 540779.848985,150572.506985 540787.861985,150565.131985 540805.432985,150578.367985 540817.865985,150622.790985 540865.068985,150638.099985 540848.467985,150624.889985 540826.636985,150650.151985 540813.062985,150687.839985 540773.076985,150744.405985 540759.742985,150794.881985 540710.287985,150801.830985 540687.127985,150805.950985 540664.161985,150796.514985 540650.612985,150798.383985 540636.310985,150816.631985 540612.414985,150843.735985 540593.600985,150877.839985 540583.571985,150887.979985 540551.552985,150921.691985 540521.649985,150965.257985 540501.931985,151002.649985 540474.224985,151015.114985 540468.395985,151040.044985 540456.737985,151051.554985 540457.180985,151063.064985 540457.624985,151084.186985 540492.617985,151070.647985 540537.901985,151049.601985 540575.147985,151021.902985 540596.656985,151007.014985 540622.638985,150965.907985 540664.320985,150940.152985 540688.413985,150936.950985 540716.690985,150931.070985 540753.445985,150916.065985 540779.631985,150873.511985 540808.008985,150882.496985 540821.066985,150907.599985 540814.139985,150933.307985 540820.832985,150937.628985 540842.986985,150925.954985 540877.445985,150903.298985 540910.400985,150878.953985 540924.700985,150854.609985 540939.000985,150848.572985 540949.540985,150839.517985 540965.350985,150833.587985 541002.358985,150828.749985 541024.918985,150841.377985 541046.423985,150859.617985 541023.612985,150895.948985 540986.867985,150908.718985 540964.327985,150920.310985 540934.969985,150933.505985 540917.905985,150946.847985 540895.692985,150973.058985 540868.670985,150994.634985 540855.997985,151011.929985 540871.185985,151031.681985 540896.146985,151051.614985 540918.938985,151063.916985 540934.921985,151046.624985 540959.176985,151017.447985 540963.574985,150995.564985 540966.871985,150975.912985 540968.450985,150943.158985 540971.082985,150926.615985 540975.000985,150961.104985 540994.376985,151021.350985 541033.454985,151067.459985 541065.693985,151094.333985 541073.195985,151089.675985 541035.539985,151088.718985 540990.623985,151085.166985 540969.224985,151090.928985 540950.574985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>POLYGON( EMPTY)
+ #69 Polygon - gid: 2569
+ </desc>
+ <a>POLYGON((157856.121985 509999.999985,157796.029985 509999.999985,157791.006985 510004.813985,157791.813985 510018.198985,157800.933985 510029.066985,157811.325985 510037.421985,157822.700985 510041.583985,157836.355985 510047.726985,157846.509985 510047.168985,157860.168985 510044.667985,157865.721985 510035.395985,157865.310985 510029.671985,157864.898985 510023.947985,157864.938985 510012.985985,157856.897985 510002.060985,157856.121985 509999.999985))</a>
+ #70 Polygon - gid: 2570
+ </desc>
+ <a>POLYGON((166912.823985 510008.038985,166922.037985 510006.063985,166931.908985 510006.063985,166939.147985 510009.354985,166945.070985 510014.619985,166951.361985 510005.018985,166956.501985 509999.999985,166817.427985 509999.999985,166829.662985 510020.674985,166846.946985 510042.171985,166864.977985 510054.010985,166876.718985 510056.295985,166886.332985 510051.098985,166888.756985 510038.698985,166892.223985 510028.810985,166906.901985 510012.644985,166912.823985 510008.038985))</a>
+ #71 Polygon - gid: 2571
+ </desc>
+ <a>POLYGON((160978.349985 510216.528985,160976.017985 510196.815985,160972.315985 510179.827985,160967.100985 510160.634985,160968.288985 510153.324985,160933.313985 510163.101985,160874.570985 510167.697985,160863.688985 510172.638985,160844.319985 510175.223985,160810.435985 510182.778985,160768.056985 510200.089985,160716.009985 510219.903985,160738.406985 510250.985985,160748.943985 510253.617985,160780.763985 510240.957985,160797.438985 510248.395985,160805.905985 510245.900985,160816.794985 510243.385985,160819.530985 510230.970985,160825.180985 510216.642985,160843.337985 510214.067985,160859.081985 510213.938985,160867.450985 510238.436985,160922.763985 510238.573985,160931.321985 510255.515985,160938.802985 510279.789985,160937.700985 510301.677985,160953.256985 510301.882985,160978.462985 510235.998985,160978.349985 510216.528985))</a>
+ #72 Polygon - gid: 2572
+ </desc>
+ <a>POLYGON((164410.173985 510269.608985,164385.850985 510262.988985,164380.056985 510272.454985,164384.086985 510288.828985,164411.898985 510335.704985,164423.329985 510359.345985,164423.798985 510376.111985,164433.397985 510390.825985,164433.551985 510400.397985,164424.317985 510428.944985,164425.629985 510436.100985,164434.162985 510445.550985,164452.393985 510464.357985,164473.162985 510490.376985,164484.334985 510507.267985,164489.125985 510507.205985,164520.300985 510472.028985,164486.035985 510438.688985,164469.919985 510416.977985,164461.182985 510395.537985,164460.812985 510357.662985,164462.293985 510314.057985,164459.977985 510300.216985,164455.056985 510293.082985,164433.141985 510278.881985,164410.173985 510269.608985))</a>
+ #73 Polygon - gid: 2573
+ </desc>
+ <a>POLYGON((165811.803985 510461.433985,165827.476985 510461.338985,165854.112985 510465.702985,165860.990985 510489.889985,165940.128985 510487.374985,165967.267985 510478.917985,165996.204985 510476.027985,166010.928985 510478.380985,166019.470985 510482.908985,166045.518985 510470.094985,166044.175985 510465.335985,166021.852985 510442.020985,166001.663985 510418.254985,165994.615985 510423.284985,165980.675985 510431.298985,165958.830985 510417.903985,165925.719985 510435.804985,165903.141985 510416.529985,165886.871985 510433.864985,165815.334985 510412.070985,165802.365985 510419.692985,165789.470985 510429.714985,165779.722985 510425.222985,165778.145985 510413.260985,165776.187985 510391.342985,165769.739985 510377.140985,165758.796985 510372.686985,165747.033985 510380.266985,165729.008985 510378.757985,165718.359985 510383.904985,165721.532985 510409.525985,165740.376985 510475.641985,165741.587985 510513.924985,165761.560985 510539.628985,165782.635985 510526.535985,165800.213985 510512.079985,165787.945985 510464.582985,165790.350985 510462.507985,165811.803985 510461.433985))</a>
+ #74 Polygon - gid: 2574
+ </desc>
+ <a>POLYGON((156787.353985 510717.616985,156798.209985 510707.476985,156835.337985 510722.081985,156846.303985 510701.194985,156809.056985 510660.576985,156747.023985 510612.786985,156725.321985 510631.224985,156706.853985 510627.359985,156670.055985 510617.736985,156669.633985 510645.101985,156641.531985 510673.194985,156607.232985 510646.565985,156586.956985 510678.596985,156610.864985 510701.168985,156633.590985 510723.694985,156644.244985 510734.684985,156664.910985 510709.964985,156667.638985 510693.338985,156677.663985 510681.579985,156691.318985 510674.355985,156706.414985 510680.618985,156733.650985 510698.475985,156758.149985 510713.483985,156755.055985 510727.250985,156776.436985 510742.942985,156787.353985 510717.616985))</a>
+ #75 Polygon - gid: 2575
+ </desc>
+ <a>POLYGON((158008.700985 510611.812985,158026.072985 510610.072985,158045.611985 510612.296985,158069.846985 510619.338985,158090.368985 510618.785985,158109.698985 510613.651985,158128.025985 510597.619985,158093.668985 510549.634985,158057.574985 510514.193985,158039.492985 510494.646985,158015.478985 510474.555985,157995.775985 510460.308985,157942.439985 510496.109985,157921.521985 510507.754985,157902.162985 510523.671985,157865.738985 510559.611985,157883.243985 510610.932985,157890.286985 510634.366985,157893.710985 510647.347985,157892.650985 510661.155985,157898.540985 510682.313985,157906.960985 510705.486985,157913.131985 510731.023985,157917.901985 510747.795985,157920.336985 510757.682985,157923.967985 510759.058985,157940.909985 510743.266985,157936.142985 510728.843985,157938.154985 510709.160985,157948.143985 510678.120985,157961.674985 510650.062985,157989.091985 510622.655985,158008.700985 510611.812985))</a>
+ #76 Polygon - gid: 2576
+ </desc>
+ <a>POLYGON((166305.250985 510805.834985,166318.509985 510802.975985,166330.838985 510809.846985,166344.515985 510802.850985,166343.020985 510793.191985,166337.462985 510785.456985,166339.794985 510768.209985,166353.422985 510755.048985,166364.727985 510750.532985,166376.738985 510747.721985,166389.828985 510743.756985,166403.788985 510746.369985,166415.423985 510749.148985,166427.334985 510741.479985,166440.525985 510736.196985,166441.389985 510724.034985,166448.601985 510697.764985,166461.649985 510665.331985,166471.117985 510635.466985,166472.253985 510610.734985,166471.971985 510578.827985,166450.104985 510554.829985,166436.845985 510555.257985,166419.250985 510572.731985,166370.997985 510552.013985,166344.073985 510538.399985,166314.873985 510529.684985,166260.933985 510516.455985,166239.242985 510517.141985,166214.020985 510520.366985,166199.574985 510535.799985,166179.736985 510555.676985,166167.104985 510575.319985,166158.002985 510592.441985,166148.310985 510604.147985,166128.052985 510621.052985,166117.555985 510630.988985,166109.528985 510643.243985,166108.834985 510660.055985,166116.902985 510679.485985,166129.322985 510693.478985,166155.820985 510708.809985,166202.941985 510748.637985,166216.897985 510760.809985,166224.033985 510771.474985,166226.512985 510787.120985,166225.393985 510816.346985,166224.544985 510828.097985,166226.469985 510838.410985,166239.357985 510850.789985,166263.214985 510837.894985,166280.875985 510820.358985,166305.250985 510805.834985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>POLYGON((166205.479485534 510652.581119516,166251.356748955 510691.357878233,166252.239160589 510692.115525049,166266.195160589 510704.287525049,166279.231532196 510719.102325104,166281.223092437 510722.078781098,166287.694391735 510714.260673777,166301.322391735 510701.099673777,166312.697826602 510692.069135259,166325.600553693 510685.400493874,166336.905553693 510680.884493874,166347.637140521 510677.506256777,166357.30243744 510675.244234494,166368.086801066 510671.977618621,166378.921550784 510670.069434357,166379.021705943 510669.772400869,166390.259992941 510641.837747114,166389.661020874 510641.648122609,166341.408020874 510620.930122609,166337.155021141 510618.944200876,166316.207348437 510608.352104004,166295.204881635 510602.083730778,166253.041853345 510591.743080032,166249.594867469 510591.852094477,166238.483846016 510602.984959354,166231.869257152 510613.27077071,166224.227146735 510627.646535877,166215.772193165 510640.272086276,166206.080193165 510651.978086276,166205.479485534 510652.581119516))
+ #77 Polygon - gid: 2577
+ </desc>
+ <a>POLYGON((144747.238985 510959.113985,144755.551985 510958.391985,144759.999985 510957.706985,144761.994985 510957.120985,144771.077985 510953.546985,144775.163985 510951.478985,144778.521985 510947.974985,144780.605985 510943.978985,144783.010985 510937.753985,144785.651985 510927.645985,144788.862985 510919.396985,144791.739985 510910.868985,144793.064985 510907.386985,144797.114985 510897.469985,144801.720985 510888.417985,144806.413985 510877.909985,144812.059985 510868.414985,144816.693985 510858.877985,144823.432985 510847.907985,144827.479985 510839.866985,144834.878985 510826.552985,144841.353985 510811.739985,144851.055985 510795.249985,144855.529985 510786.973985,144859.568985 510778.929985,144864.231985 510768.907985,144870.294985 510757.055985,144880.482985 510735.040985,144889.839985 510714.509985,144891.739985 510708.263985,144893.819985 510702.414985,144900.412985 510685.150985,144904.567985 510672.305985,144908.464985 510662.652985,144909.972985 510658.420985,144911.556985 510652.787985,144917.287985 510628.138985,144918.793985 510620.165985,144920.156985 510611.264985,144921.001985 510603.657985,144921.262985 510599.163985,144921.704985 510582.021985,144921.011985 510568.365985,144920.854985 510559.601985,144920.289985 510555.194985,144918.636985 510551.096985,144916.208985 510547.234985,144912.630985 510542.505985,144909.599985 510539.168985,144904.439985 510534.334985,144900.938985 510531.501985,144888.767985 510523.199985,144879.383985 510515.890985,144875.229985 510513.144985,144871.087985 510511.405985,144865.524985 510509.747985,144861.155985 510508.663985,144853.171985 510506.969985,144848.717985 510506.417985,144846.972985 510506.478985,144842.481985 510507.088985,144838.009985 510507.423985,144833.879985 510506.773985,144826.316985 510504.723985,144817.749985 510501.823985,144813.612985 510500.064985,144808.494985 510497.375985,144804.803985 510494.824985,144801.777985 510491.930985,144795.754985 510485.194985,144790.391985 510479.676985,144787.152985 510476.557985,144784.745985 510474.805985,144780.836985 510471.086985,144779.143985 510466.926985,144777.440985 510461.086985,144776.698985 510456.647985,144776.804985 510454.324985,144777.616985 510449.872985,144778.467985 510446.885985,144780.081985 510442.676985,144781.219985 510440.385985,144790.599985 510424.970985,144792.765985 510421.025985,144795.397985 510415.850985,144801.206985 510403.663985,144814.508985 510378.077985,144817.035985 510373.557985,144824.707985 510361.955985,144828.960985 510354.013985,144830.830985 510349.922985,144832.887985 510344.566985,144834.325985 510340.296985,144844.487985 510308.646985,144847.131985 510299.010985,144851.930985 510282.590985,144853.658985 510277.818985,144856.216985 510274.101985,144858.400985 510272.120985,144864.813985 510267.654985,144868.883985 510265.877985,144871.922985 510266.041985,144881.496985 510268.362985,144886.044985 510268.061985,144890.714985 510268.243985,144895.858985 510267.153985,144899.844985 510265.018985,144903.565985 510262.479985,144905.971985 510256.254985,144907.871985 510250.007985,144910.335985 510242.811985,144916.629985 510224.581985,144919.195985 510215.951985,144920.522985 510210.838985,144923.217985 510197.609985,144925.864985 510187.491985,144928.414985 510179.174985,144931.325985 510170.656985,144934.161985 510161.574985,144945.007985 510123.082985,144951.327985 510101.949985,144953.064985 510095.110985,144954.861985 510090.194985,144957.165985 510086.165985,144960.615985 510082.533985,144965.980985 510081.919985,144970.351985 510080.854985,144973.430985 510080.840985,144983.058985 510081.509985,144987.516985 510082.067985,144997.989985 510084.944985,145001.100985 510085.352985,145018.225985 510086.588985,145031.277985 510087.813985,145034.023985 510087.583985,145038.746985 510086.578985,145043.185985 510085.397985,145047.248985 510083.622985,145048.202985 510082.830985,145050.585985 510078.877985,145051.978985 510074.620985,145056.128985 510060.096985,145057.553985 510055.831985,145063.088985 510042.322985,145066.150985 510034.166985,145069.126985 510025.644985,145071.569985 510017.003985,145072.764985 510011.254985,145073.282985 510006.603985,145072.958985 510002.462985,145072.176985 510001.292985,145067.525985 509999.999985,144820.948985 509999.999985,144819.191985 510006.807985,144817.797985 510013.075985,144817.072985 510017.518985,144816.707985 510022.887985,144816.139985 510027.720985,144815.755985 510030.023985,144814.530985 510034.358985,144813.610985 510047.578985,144813.566985 510049.397985,144814.106985 510057.207985,144813.995985 510061.708985,144813.679985 510066.204985,144813.429985 510068.372985,144811.294985 510078.502985,144810.411985 510093.065985,144808.486985 510108.070985,144806.898985 510131.620985,144806.743985 510136.109985,144806.915985 510141.233985,144807.389985 510145.737985,144808.036985 510148.932985,144809.863985 510153.023985,144814.180985 510159.646985,144816.820985 510162.931985,144819.994985 510166.132985,144823.469985 510168.999985,144830.897985 510173.260985,144834.408985 510176.059985,144850.660985 510190.157985,144857.639985 510195.848985,144860.332985 510197.867985,144867.177985 510202.050985,144870.801985 510204.797985,144871.522985 510205.641985,144873.715985 510209.796985,144873.726985 510211.088985,144872.243985 510215.158985,144869.975985 510219.190985,144867.963985 510222.524985,144865.436985 510226.291985,144864.099985 510227.714985,144858.836985 510230.898985,144855.291985 510233.691985,144848.874985 510236.316985,144840.763985 510240.217985,144825.553985 510248.383985,144822.676985 510250.294985,144819.567985 510253.537985,144812.468985 510261.818985,144809.626985 510264.829985,144802.536985 510270.407985,144801.628985 510271.304985,144799.024985 510274.943985,144796.656985 510278.806985,144788.849985 510289.744985,144786.429985 510293.536985,144777.870985 510307.318985,144775.474985 510311.721985,144773.491985 510315.763985,144769.628985 510325.155985,144765.706985 510336.945985,144761.518985 510347.475985,144757.242985 510359.461985,144752.043985 510369.948985,144748.608985 510378.269985,144745.802985 510386.171985,144744.461985 510390.470985,144743.491985 510393.920985,144742.009985 510401.644985,144740.079985 510408.376985,144736.020985 510433.511985,144734.117985 510442.308985,144731.955985 510450.373985,144731.311985 510454.824985,144730.521985 510463.096985,144730.379985 510467.588985,144730.705985 510472.313985,144731.923985 510481.243985,144733.045985 510486.401985,144735.374985 510494.319985,144737.113985 510498.490985,144741.895985 510503.842985,144744.758985 510507.317985,144748.950985 510512.901985,144751.358985 510516.696985,144755.859985 510524.387985,144758.284985 510528.189985,144760.097985 510533.152985,144760.327985 510534.309985,144760.479985 510540.156985,144760.990985 510548.451985,144760.920985 510552.976985,144760.519985 510556.218985,144758.114985 510562.443985,144757.126985 510566.831985,144756.006985 510573.652985,144754.061985 510578.134985,144752.979985 510580.233985,144750.126985 510585.466985,144746.174985 510592.112985,144743.798985 510597.851985,144739.787985 510605.468985,144728.326985 510634.151985,144724.192985 510643.531985,144716.312985 510659.718985,144710.915985 510671.895985,144704.293985 510683.664985,144701.675985 510689.308985,144688.772985 510721.296985,144686.795985 510726.842985,144684.601985 510737.943985,144680.325985 510749.929985,144677.804985 510758.571985,144676.148985 510765.873985,144674.837985 510773.544985,144674.582985 510778.037985,144673.654985 510784.687985,144673.065985 510793.668985,144672.865985 510800.351985,144672.925985 510810.570985,144673.228985 510816.790985,144674.961985 510830.004985,144676.832985 510853.625985,144678.406985 510863.803985,144680.015985 510872.072985,144681.138985 510876.426985,144685.448985 510891.059985,144686.723985 510895.230985,144689.315985 510902.640985,144690.423985 510907.002985,144690.926985 510909.521985,144692.208985 510918.431985,144693.494985 510923.676985,144693.735985 510930.081985,144694.095985 510934.577985,144694.246985 510938.376985,144693.763985 510942.859985,144693.358985 510944.665985,144696.127985 510949.162985,144701.143985 510951.096985,144705.788985 510953.835985,144710.002985 510955.607985,144714.455985 510956.265985,144719.900985 510958.442985,144721.946985 510958.696985,144734.595985 510958.578985,144747.238985 510959.113985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>POLYGON((144749.805324897 510825.061482914,144752.789028351 510819.62041865,144757.866524274 510811.355078054,144760.486491976 510806.149454063,144761.923067335 510803.434986066,144767.587610419 510793.24202396,144772.632499225 510781.700720814,144776.712345391 510773.707651011,144785.72556147 510758.388342297,144789.013934301 510752.305514056,144792.041340364 510746.276186408,144796.232065554 510737.269227828,144797.461513493 510734.750933975,144802.851102428 510724.215323211,144812.32672505 510703.739682063,144819.532622703 510687.928601084,144819.986383875 510686.436920937,144821.075239258 510683.134446422,144823.155239258 510677.285446422,144823.755352034 510675.657795175,144829.653168763 510660.214156769,144833.20844985 510649.223161446,144835.021528296 510644.229475959,144838.337343242 510636.016090875,144838.465649457 510635.656016669,144838.893478571 510634.134576393,144843.881842558 510612.679649866,144844.855340723 510607.525798029,144845.786560233 510601.444517867,144846.242579414 510597.339265905,144846.319063859 510596.02232684,144846.597559236 510585.2214948,144846.505245047 510585.158526071,144842.681852769 510582.369811905,144842.420062933 510582.165909314,144830.869719025 510581.69593476,144830.480274411 510583.247819704,144830.403008562 510583.447811353,144830.015933856 510585.805165431,144824.807966602 510603.50972512,144822.862966602 510607.99172512,144820.726062732 510612.499221354,144819.644062732 510614.598221354,144818.829365104 510616.134669394,144815.976365104 510621.367669394,144814.590794636 510623.799963586,144813.402521291 510625.798259296,144813.0949506 510626.541166785,144810.160479719 510632.796970601,144807.977881994 510636.941784083,144797.972947012 510661.980746658,144796.957259087 510664.399058888,144792.823259087 510673.779058888,144791.627021635 510676.359575578,144784.335439559 510691.337854647,144779.483161999 510702.285822749,144776.279551757 510708.673751936,144771.096265127 510717.885787628,144770.516318056 510719.136063131,144759.249566685 510747.067617255,144758.178740747 510752.485684136,144755.241424314 510763.144572561,144751.706995828 510773.051883092,144750.442994832 510777.384884522,144749.737494578 510780.495731656,144749.478023586 510782.013963529,144749.462483862 510782.287767375,144748.863209928 510788.403706614,144748.314579795 510792.335161771,144747.992515989 510797.245951313,144747.872572957 510801.253847731,144747.915266496 510808.525268963,144747.990947665 510810.078855983,144749.325187901 510820.252341544,144749.727807841 510824.08284561,144749.805324897 510825.061482914))
+ #78 Polygon - gid: 2578
+ </desc>
+ <a>POLYGON((164261.154985 510650.157985,164222.546985 510625.817985,164154.918985 510621.315985,164140.780985 510624.098985,164100.762985 510630.061985,164079.139985 510626.535985,164059.912985 510617.594985,164015.891985 510599.380985,163982.805985 510602.715985,163983.143985 510614.572985,163970.818985 510623.941985,163962.940985 510638.400985,163944.888985 510642.579985,163933.276985 510650.021985,163930.136985 510664.321985,163942.960985 510666.830985,163941.293985 510678.107985,163929.785985 510687.883985,163929.852985 510705.547985,163938.943985 510721.193985,163934.579985 510733.094985,163953.814985 510756.399985,163950.048985 510774.682985,163998.911985 510843.113985,164035.797985 510852.162985,164061.288985 510859.960985,164064.966985 510901.893985,164073.003985 510919.767985,164104.848985 510938.739985,164122.787985 510951.327985,164144.387985 510967.544985,164162.825985 510996.374985,164172.641985 511008.200985,164185.573985 511018.018985,164202.763985 511022.535985,164212.601985 511010.055985,164213.482985 511003.929985,164225.152985 510978.161985,164230.919985 510950.063985,164230.938985 510918.038985,164233.340985 510891.355985,164227.100985 510877.482985,164217.221985 510859.031985,164207.163985 510838.163985,164213.661985 510828.524985,164218.967985 510814.960985,164226.671985 510801.335985,164224.750985 510783.190985,164225.316985 510765.035985,164230.416985 510743.577985,164239.929985 510713.941985,164248.933985 510702.513985,164260.336985 510694.005985,164268.258985 510684.930985,164271.205985 510666.516985,164261.154985 510650.157985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>MULTIPOLYGON(((164014.772946481 510692.038226625,164012.326520825 510702.178274868,164011.527687693 510703.983065768,164012.792704249 510710.315333713,164019.220139731 510719.696228589,164024.701026238 510731.901634901,164027.926009408 510744.88668568,164028.625355324 510755.663210165,164043.789058394 510776.899470009,164053.667376006 510779.322852758,164057.737747794 510780.44376297,164083.228747794 510788.24176297,164096.890697277 510793.949485374,164109.165116963 510802.229918941,164119.573627528 510812.760344693,164127.710570996 510825.130353169,164132.468221954 510836.901739132,164133.325767413 510825.014170419,164137.645626258 510810.01797644,164144.975438653 510796.240427145,164146.837342966 510793.478516453,164149.121889886 510787.638411963,164149.973044149 510785.847891558,164149.787406278 510780.853921626,164150.353406278 510762.698921626,164152.349592409 510747.69356249,164157.449592409 510726.23556249,164159.005822839 510720.655377845,164166.517509919 510697.254099772,164159.752582182 510696.803758128,164155.266414285 510697.686839558,164151.834541591 510698.279972367,164111.816541591 510704.242972367,164100.248309551 510705.06021904,164088.69238323 510704.084282809,164067.06938323 510700.558282809,164047.515386117 510694.54249017,164029.749639703 510686.281006908,164022.566743301 510683.309032735,164019.818736513 510687.28780718,164014.772946481 510692.038226625)),((164136.84918064 510863.064920405,164137.537585488 510870.913446915,164140.559339427 510872.713689205,164139.602082474 510870.727604686,164136.84918064 510863.064920405)))
+ #79 Polygon - gid: 2579
+ </desc>
+ <a>POLYGON((161163.886985 511013.234985,161189.226985 511008.259985,161204.882985 511010.529985,161216.939985 511017.641985,161227.792985 511024.762985,161248.543985 511023.948985,161299.183985 511005.191985,161318.473985 510994.650985,161337.727985 510983.346985,161348.559985 510978.469985,161375.078985 510969.443985,161394.349985 510955.624985,161394.328985 510946.004985,161386.939985 510926.037985,161379.543985 510910.182985,161373.427985 510893.386985,161363.695985 510872.502985,161346.474985 510842.958985,161332.028985 510828.673985,161317.614985 510828.796985,161308.031985 510836.768985,161299.658985 510853.659985,161291.142985 510866.375985,161274.318985 510871.326985,161257.475985 510869.066985,161241.807985 510872.311985,161238.216985 510879.558985,161240.655985 510891.564985,161229.883985 510913.302985,161231.180985 510932.556985,161185.371985 510950.503985,161191.407985 510980.108985,161185.480985 510984.191985,161121.102985 510988.479985,161103.734985 510957.896985,161083.239985 510960.482985,161098.380985 511024.842985,161108.119985 511034.441985,161137.241985 511023.833985,161163.886985 511013.234985))</a>
+ #80 Polygon - gid: 2580
+ </desc>
+ <a>POLYGON((153813.688985 511062.953985,153835.321985 511057.586985,153844.786985 511047.891985,153846.824985 511035.417985,153842.431985 511021.764985,153850.025985 511008.873985,153863.361985 510999.755985,153876.654985 510996.614985,153892.257985 510993.431985,153902.800985 510983.707985,153905.732985 510969.043985,153904.396985 510957.029985,153901.984985 510954.939985,153890.617985 510951.489985,153860.008985 510941.167985,153846.688985 510938.404985,153830.265985 510936.142985,153810.244985 510933.880985,153789.735985 510928.797985,153776.421985 510929.931985,153733.777985 510924.325985,153700.997985 510915.447985,153687.636985 510916.347985,153676.673985 510919.325985,153663.820985 510943.732985,153641.900985 510991.329985,153631.225985 511030.452985,153671.961985 511040.388985,153697.242985 511041.748985,153714.534985 511045.144985,153735.736985 511055.102985,153749.989985 511063.251985,153773.223985 511062.327985,153792.770985 511065.572985,153813.688985 511062.953985))</a>
+ #81 Polygon - gid: 2581
+ </desc>
+ <a>POLYGON((144665.365985 511341.906985,144664.510985 511337.457985,144663.984985 511333.542985,144661.230985 511335.031985,144656.989985 511336.582985,144654.973985 511336.925985,144649.894985 511337.240985,144645.424985 511337.740985,144643.682985 511337.588985,144639.352985 511336.370985,144637.147985 511334.599985,144633.775985 511330.501985,144631.204985 511326.779985,144628.821985 511322.413985,144627.874985 511317.609985,144627.824985 511311.225985,144628.204985 511306.750985,144629.551985 511302.647985,144631.234985 511298.457985,144632.940985 511294.276985,144634.697985 511290.801985,144636.006985 511286.610985,144635.336985 511282.657985,144632.316985 511273.996985,144630.183985 511267.028985,144629.061985 511262.662985,144628.107985 511257.545985,144627.616985 511253.074985,144627.010985 511243.356985,144627.072985 511241.389985,144627.116985 511234.355985,144626.579985 511230.453985,144622.517985 511209.850985,144621.773985 511205.415985,144620.186985 511189.774985,144618.065985 511174.597985,144617.482985 511167.000985,144617.043985 511158.007985,144616.767985 511145.828985,144617.268985 511137.576985,144620.089985 511116.855985,144620.822985 511112.419985,144623.492985 511101.825985,144624.945985 511094.587985,144627.469985 511086.420985,144630.555985 511069.704985,144634.070985 511056.450985,144634.616985 511052.168985,144634.472985 511051.111985,144631.341985 511047.649985,144625.618985 511056.693985,144623.466985 511060.456985,144613.544985 511081.937985,144608.763985 511093.902985,144604.703985 511101.953985,144604.128985 511103.439985,144602.908985 511107.755985,144601.369985 511115.489985,144598.939985 511130.473985,144596.298985 511140.582985,144594.291985 511149.356985,144592.663985 511157.537985,144591.198985 511166.160985,144589.244985 511181.651985,144588.862985 511187.962985,144587.885985 511195.707985,144587.384985 511203.960985,144586.684985 511208.405985,144584.601985 511224.769985,144584.400985 511229.274985,144582.378985 511236.355985,144581.725985 511240.804985,144581.099985 511248.591985,144581.095985 511253.941985,144581.897985 511269.049985,144581.451985 511276.710985,144581.585985 511281.208985,144582.173985 511289.881985,144582.056985 511291.823985,144575.283985 511305.626985,144572.076985 511322.283985,144568.363985 511349.427985,144566.469985 511360.018985,144564.565985 511367.244985,144560.273985 511380.836985,144557.896985 511388.835985,144555.477985 511397.505985,144553.900985 511404.108985,144552.233985 511412.954985,144551.618985 511417.905985,144549.373985 511444.507985,144547.950985 511456.490985,144547.265985 511469.973985,144545.938985 511482.897985,144544.783985 511500.860985,144543.674985 511514.445985,144543.507985 511521.138985,144543.695985 511525.637985,144544.907985 511534.198985,144545.816985 511543.153985,144546.797985 511550.352985,144551.118985 511574.736985,144551.888985 511582.932985,144552.571985 511587.378985,144555.698985 511605.441985,144558.436985 511618.524985,144558.653985 511620.435985,144558.639985 511624.942985,144558.299985 511628.256985,144565.200985 511620.333985,144568.479985 511617.196985,144569.415985 511612.446985,144570.165985 511606.524985,144570.813985 511597.777985,144571.561985 511593.330985,144572.193985 511590.917985,144573.736985 511586.693985,144577.541985 511578.519985,144579.708985 511574.574985,144582.277985 511570.335985,144584.829985 511566.786985,144587.868985 511563.470985,144591.176985 511560.405985,144594.825985 511557.595985,144596.719985 511556.343985,144602.203985 511553.326985,144608.153985 511548.349985,144619.625985 511542.308985,144623.156985 511539.530985,144631.920985 511531.965985,144635.205985 511527.763985,144641.644985 511518.581985,144647.686985 511508.167985,144651.603985 511502.244985,144655.044985 511497.794985,144658.227985 511494.613985,144668.411985 511483.048985,144672.012985 511478.307985,144675.713985 511475.049985,144678.988985 511470.922985,144681.256985 511466.552985,144685.996985 511456.770985,144687.908985 511451.367985,144691.283985 511443.499985,144692.095985 511439.073985,144693.475985 511434.284985,144694.371985 511429.253985,144694.509985 511427.819985,144694.410985 511423.320985,144694.807985 511417.069985,144694.285985 511412.598985,144692.567985 511405.382985,144691.736985 511400.949985,144689.740985 511395.877985,144687.240985 511390.324985,144685.113985 511384.496985,144683.189985 511380.429985,144681.438985 511376.739985,144679.837985 511372.530985,144678.788985 511369.942985,144673.535985 511360.160985,144668.260985 511351.627985,144666.478985 511346.301985,144665.365985 511341.906985))</a>
+ #82 Polygon - gid: 2582
+ </desc>
+ <a>POLYGON((150793.118985 511863.872985,150782.435985 511854.966985,150773.079985 511846.582985,150769.853985 511843.245985,150766.986985 511839.782985,150761.511985 511832.617985,150758.605985 511829.192985,150754.526985 511825.034985,150751.182985 511821.998985,150747.703985 511819.159985,150745.002985 511817.382985,150740.884985 511815.528985,150736.708985 511814.410985,150732.238985 511813.744985,150725.323985 511813.170985,150720.857985 511813.353985,150717.259985 511814.287985,150711.627985 511816.933985,150702.186985 511822.826985,150698.518985 511825.423985,150696.368985 511827.525985,150684.761985 511840.202985,150681.550985 511843.503985,150678.272985 511846.599985,150674.783985 511849.436985,150669.637985 511852.923985,150665.663985 511855.000985,150661.936985 511856.225985,150656.873985 511856.914985,150652.348985 511856.798985,150647.905985 511856.025985,150645.239985 511855.186985,150641.073985 511853.447985,150636.151985 511851.082985,150628.316985 511846.527985,150624.260985 511844.691985,150620.988985 511843.836985,150616.496985 511843.242985,150611.814985 511842.919985,150607.312985 511842.716985,150602.796985 511842.724985,150598.313985 511843.011985,150596.601985 511843.287985,150592.221985 511844.505985,150587.641985 511845.379985,150583.110985 511845.114985,150578.119985 511843.789985,150574.644985 511840.859985,150566.899985 511831.685985,150563.749985 511828.530985,150562.674985 511827.708985,150554.656985 511823.535985,150545.568985 511816.704985,150540.506985 511813.718985,150530.264985 511808.717985,150526.014985 511807.641985,150524.251985 511807.730985,150515.536985 511810.459985,150509.160985 511811.415985,150500.505985 511813.304985,150490.484985 511815.200985,150479.709985 511816.692985,150470.899985 511818.531985,150462.891985 511820.493985,150458.194985 511821.964985,150445.836985 511827.404985,150439.625985 511829.715985,150435.355985 511831.140985,150422.598985 511834.889985,150419.093985 511836.166985,150399.357985 511844.231985,150390.792985 511848.186985,150386.777985 511850.257985,150382.945985 511852.571985,150380.704985 511854.175985,150377.924985 511857.651985,150377.614985 511859.079985,150377.897985 511868.209985,150376.511985 511876.021985,150376.611985 511877.158985,150379.114985 511885.853985,150380.117985 511890.230985,150380.935985 511898.667985,150381.832985 511915.743985,150382.366985 511932.541985,150382.275985 511937.039985,150381.956985 511940.848985,150381.344985 511945.308985,150381.694985 511947.764985,150384.059985 511951.718985,150387.229985 511954.008985,150396.270985 511958.492985,150415.434985 511967.136985,150427.214985 511971.698985,150435.461985 511975.194985,150439.538985 511977.090985,150442.724985 511978.823985,150450.449985 511983.451985,150461.357985 511990.730985,150470.449985 511996.184985,150476.812985 512000.277985,150486.281985 512004.468985,150498.388985 512009.375985,150506.829985 512012.490985,150515.408985 512015.156985,150519.751985 512016.347985,150529.479985 512018.627985,150538.331985 512020.289985,150542.988985 512021.027985,150551.938985 512021.972985,150568.897985 512022.823985,150577.823985 512023.998985,150585.204985 512025.356985,150590.396985 512025.748985,150594.855985 512025.332985,150603.774985 512023.841985,150612.102985 512022.714985,150617.473985 512021.715985,150621.801985 512020.489985,150636.118985 512015.843985,150644.319985 512013.498985,150645.997985 512012.737985,150661.643985 512004.213985,150668.485985 511999.122985,150671.737985 511997.405985,150679.881985 511993.545985,150696.995985 511983.795985,150705.252985 511978.647985,150720.985985 511967.981985,150724.570985 511965.274985,150726.337985 511963.711985,150732.784985 511957.421985,150738.545985 511953.334985,150742.362985 511950.937985,150749.200985 511947.223985,150750.312985 511946.426985,150753.762985 511943.523985,150759.775985 511938.828985,150769.269985 511930.492985,150772.469985 511927.344985,150775.669985 511922.275985,150776.549985 511921.269985,150779.777985 511918.119985,150782.178985 511915.393985,150785.867985 511911.585985,150793.096985 511906.023985,150796.180985 511902.741985,150798.947985 511899.183985,150800.512985 511896.731985,150803.753985 511890.480985,150805.353985 511886.291985,150805.688985 511883.904985,150805.356985 511879.352985,150802.648985 511875.749985,150797.659985 511868.435985,150796.383985 511866.983985,150793.118985 511863.872985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>POLYGON((150457.10488879 511902.90912939,150464.733870064 511906.143144005,150467.087964112 511907.189121685,150471.164964112 511909.085121685,150475.376080646 511911.206976503,150478.562080646 511912.939976503,150481.269290797 511914.486309485,150488.994290797 511919.114309485,150492.08021185 511921.066696571,150501.486797912 511927.343790442,150509.030924817 511931.869270879,150511.024338606 511933.107874813,150512.491255491 511934.051469158,150515.55259617 511935.406425202,150525.464472069 511939.423735439,150530.957806829 511941.45095233,150536.461059094 511943.161136564,150538.233258087 511943.647134491,150544.964737503 511945.224824979,150551.123863489 511946.381226628,150552.802642224 511946.647264572,150557.760384086 511947.17073564,150572.656744079 511947.918232683,150578.686383311 511948.465480049,150587.612383311 511949.640480049,150590.267735925 511950.059246398,150591.408748513 511949.868501946,150593.717167366 511949.519442629,150600.209475453 511948.640860591,150600.252315061 511948.632892472,150612.969191529 511944.506147479,150615.49980374 511943.73400397,150616.316038105 511943.500609313,150621.116996024 511940.885029273,150623.714257734 511938.952457018,150633.468454743 511932.799741904,150636.720454743 511931.082741904,150638.019151806 511930.432505435,150635.050484011 511929.916012029,150625.391778503 511927.56695582,150622.725778503 511926.72795582,150616.34901009 511924.399061755,150612.18301009 511922.660061755,150608.591920771 511921.049135163,150603.669920771 511918.684135163,150603.656921969 511918.677247374,150601.700523332 511919.050586328,150583.263019067 511920.25204025,150578.732019067 511919.98704025,150563.866752358 511917.604015274,150558.875752358 511916.279015274,150543.486379129 511910.314516899,150529.774245546 511901.128361997,150526.299245546 511898.198361997,150517.336788462 511889.24149603,150515.759481157 511887.373165854,150514.988775912 511886.887589413,150514.448819526 511886.997571909,150504.427819526 511888.893571909,150500.771984776 511889.492152952,150492.530977352 511890.633274351,150487.491266548 511891.685263927,150484.051346716 511892.528061469,150476.053921669 511896.04853341,150471.991319844 511897.696881893,150465.780319844 511900.007881893,150463.368057644 511900.858897413,150459.098057644 511902.283897413,150457.10488879 511902.90912939))
+ #83 Polygon - gid: 2583
+ </desc>
+ <a>POLYGON((156449.341985 511947.023985,156464.014985 511945.970985,156481.530985 511959.981985,156488.552985 511957.898985,156502.465985 511951.515985,156519.696985 511967.276985,156532.436985 511968.984985,156546.765985 511960.382985,156557.920985 511953.685985,156617.345985 511926.606985,156650.552985 511912.686985,156629.697985 511893.765985,156618.726985 511870.069985,156571.803985 511869.954985,156520.017985 511866.320985,156489.605985 511875.922985,156479.281985 511900.711985,156450.551985 511915.185985,156420.762985 511933.429985,156402.252985 511952.078985,156397.242985 511979.578985,156395.515985 512016.444985,156378.536985 512022.679985,156378.119985 512031.838985,156381.340985 512046.684985,156381.973985 512059.782985,156387.971985 512068.254985,156389.726985 512093.748985,156394.837985 512106.687985,156406.149985 512102.202985,156420.544985 512083.467985,156439.940985 512083.059985,156434.834985 512074.138985,156430.875985 512065.561985,156431.200985 512050.264985,156442.042985 512026.074985,156436.831985 511998.762985,156428.771985 511968.333985,156449.341985 511947.023985))</a>
+ #84 Polygon - gid: 2584
+ </desc>
+ <a>POLYGON((155602.027985 512384.736985,155651.324985 512362.529985,155690.321985 512347.470985,155728.819985 512327.098985,155734.742985 512356.836985,155759.349985 512351.936985,155787.291985 512340.198985,155805.031985 512324.680985,155807.589985 512298.852985,155807.126985 512268.633985,155818.253985 512240.316985,155826.566985 512208.914985,155827.900985 512153.049985,155845.759985 512111.821985,155872.507985 512069.193985,155889.837985 512044.252985,155912.490985 512003.645985,155927.073985 511997.027985,155950.234985 512000.369985,155966.659985 511999.703985,155977.448985 511982.546985,155986.844985 511959.429985,155997.767985 511948.403985,156006.318985 511939.771985,156026.620985 511926.970985,156045.097985 511907.642985,156056.068985 511885.544985,156051.584985 511870.282985,156034.120985 511859.853985,156026.020985 511861.511985,156014.495985 511863.870985,155993.202985 511891.082985,155979.638985 511907.819985,155960.158985 511915.091985,155951.804985 511911.642985,155944.020985 511895.340985,155936.829985 511869.525985,155922.587985 511855.727985,155888.814985 511836.983985,155840.846985 511835.381985,155800.677985 511839.829985,155775.670985 511860.233985,155774.333985 511899.906985,155795.411985 511943.754985,155816.206985 511963.053985,155845.433985 511975.560985,155878.744985 511980.178985,155881.067985 511998.835985,155876.445985 512018.197985,155856.169985 512033.153985,155847.373985 512031.370985,155820.826985 512018.441985,155810.139985 512012.400985,155794.109985 512003.338985,155772.511985 512000.769985,155747.437985 512018.467985,155743.449985 512037.075985,155734.345985 512063.507985,155719.020985 512086.564985,155704.834985 512109.490985,155702.872985 512125.983985,155716.012985 512136.488985,155732.291985 512135.876985,155741.646985 512132.513985,155752.134985 512114.732985,155766.085985 512102.084985,155788.547985 512103.687985,155796.852985 512111.554985,155796.473985 512128.617985,155787.305985 512152.726985,155777.070985 512175.994985,155766.262985 512204.174985,155762.622985 512221.408985,155755.035985 512230.476985,155736.132985 512235.898985,155721.747985 512236.656985,155705.074985 512229.699985,155686.855985 512217.112985,155670.731985 512211.063985,155654.433985 512228.409985,155640.417985 512242.145985,155618.476985 512253.328985,155601.188985 512251.812985,155596.704985 512241.110985,155597.324985 512234.943985,155608.428985 512222.055985,155617.613985 512215.614985,155621.498985 512204.875985,155620.091985 512189.821985,155601.632985 512166.310985,155571.728985 512189.472985,155512.046985 512240.386985,155484.043985 512264.760985,155478.016985 512282.219985,155490.242985 512305.307985,155510.088985 512325.660985,155531.257985 512342.424985,155545.862985 512369.388985,155548.396985 512380.288985,155551.240985 512378.547985,155571.923985 512396.101985,155602.027985 512384.736985))</a>
+ #85 Polygon - gid: 2585
+ </desc>
+ <a>POLYGON((158639.754985 512372.943985,158642.449985 512349.639985,158651.455985 512332.998985,158654.537985 512321.227985,158662.359985 512307.021985,158667.084985 512302.182985,158674.148985 512294.948985,158682.389985 512285.305985,158690.575985 512270.902985,158694.679985 512247.278985,158692.208985 512240.181985,158683.712985 512228.424985,158668.883985 512217.032985,158646.555985 512214.750985,158627.649985 512229.323985,158617.422985 512243.507985,158608.087985 512260.305985,158586.772985 512272.531985,158565.598985 512272.645985,158544.191985 512277.739985,158539.545985 512287.325985,158537.795985 512315.696985,158533.147985 512325.284985,158525.175985 512334.748985,158523.574985 512355.881985,158524.640985 512365.547985,158529.449985 512367.856985,158536.445985 512375.035985,158563.901985 512374.626985,158573.392985 512369.724985,158581.691985 512364.839985,158593.207985 512355.298985,158604.326985 512359.738985,158609.225985 512369.189985,158611.793985 512383.436985,158613.851985 512401.113985,158626.612985 512394.997985,158634.009985 512385.227985,158638.305985 512373.378985,158639.754985 512372.943985))</a>
+ #86 Polygon - gid: 2586
+ </desc>
+ <a>POLYGON((155727.202985 512684.126985,155741.919985 512679.921985,155754.534985 512679.921985,155769.250985 512673.614985,155781.865985 512667.307985,155798.163985 512654.965985,155820.165985 512662.878985,155835.705985 512670.729985,155850.180985 512672.093985,155857.418985 512672.776985,155870.184985 512655.342985,155879.069985 512649.526985,155883.511985 512646.618985,155904.577985 512658.609985,155930.402985 512657.713985,155952.915985 512644.276985,155976.753985 512624.405985,155979.221985 512607.413985,156006.945985 512594.025985,156026.550985 512576.591985,156049.621985 512550.417985,156054.729985 512531.129985,156054.755985 512505.514985,156044.897985 512478.134985,156019.611985 512455.590985,156003.719985 512436.978985,155985.013985 512416.265985,155959.225985 512408.307985,155929.903985 512411.681985,155923.048985 512441.509985,155927.659985 512492.523985,155928.478985 512511.588985,155908.647985 512524.923985,155882.165985 512527.804985,155865.679985 512509.153985,155855.593985 512479.621985,155854.702985 512472.706985,155852.030985 512451.962985,155847.595985 512433.051985,155825.610985 512418.598985,155813.750985 512399.623985,155799.230985 512404.242985,155778.543985 512443.422985,155785.678985 512477.221985,155802.478985 512510.914985,155793.319985 512534.784985,155772.281985 512535.697985,155760.161985 512563.378985,155745.307985 512608.348985,155729.305985 512650.488985,155722.998985 512656.795985,155712.486985 512652.590985,155693.564985 512646.283985,155625.087985 512605.101985,155576.978985 512579.241985,155565.134985 512573.289985,155585.397985 512555.877985,155608.591985 512548.877985,155605.820985 512529.964985,155602.102985 512511.257985,155573.935985 512503.813985,155483.898985 512506.544985,155470.203985 512506.897985,155425.981985 512510.850985,155377.120985 512514.465985,155322.665985 512512.452985,155316.148985 512512.497985,155316.519985 512514.568985,155310.172985 512526.065985,155306.522985 512576.960985,155296.149985 512617.554985,155292.347985 512627.995985,155313.655985 512633.929985,155348.186985 512651.970985,155370.507985 512655.437985,155395.810985 512650.471985,155419.682985 512637.003985,155449.809985 512621.252985,155479.012985 512613.969985,155504.153985 512617.337985,155528.206985 512637.756985,155555.101985 512657.978985,155582.666985 512663.452985,155608.860985 512671.327985,155653.082985 512686.633985,155695.712985 512698.015985,155710.383985 512700.946985,155718.793985 512694.638985,155727.202985 512684.126985))</a>
+ #87 Polygon - gid: 2587
+ </desc>
+ <a>POLYGON((146166.976985 512563.940985,146169.594985 512563.533985,146174.055985 512564.781985,146177.356985 512561.339985,146181.129985 512554.989985,146185.373985 512548.630985,146189.013985 512541.920985,146194.870985 512530.011985,146198.574985 512521.811985,146202.486985 512510.766985,146206.272985 512502.588985,146208.002985 512498.444985,146209.826985 512492.155985,146212.021985 512482.022985,146213.069985 512474.579985,146213.899985 512465.609985,146214.122985 512461.084985,146213.982985 512452.080985,146213.290985 512444.415985,146211.750985 512435.542985,146210.899985 512432.081985,146209.279985 512427.626985,146202.014985 512417.721985,146193.565985 512405.040985,146190.827985 512399.745985,146189.280985 512395.443985,146188.608985 512391.002985,146188.735985 512383.754985,146189.509985 512374.731985,146190.957985 512365.827985,146193.621985 512354.666985,146196.283985 512346.008985,146199.521985 512337.449985,146202.058985 512333.521985,146205.570985 512330.766985,146209.847985 512330.235985,146220.199985 512330.990985,146232.889985 512334.095985,146236.718985 512336.497985,146243.325985 512339.763985,146249.933985 512343.512985,146258.162985 512349.266985,146262.031985 512352.246985,146265.456985 512355.165985,146272.146985 512361.243985,146278.196985 512367.051985,146281.562985 512370.018985,146283.636985 512371.307985,146288.761985 512373.835985,146292.889985 512375.617985,146295.481985 512376.220985,146299.968985 512376.458985,146303.856985 512375.344985,146308.377985 512373.216985,146316.009985 512368.440985,146319.433985 512366.733985,146324.146985 512364.674985,146334.262985 512360.634985,146338.382985 512358.815985,146343.177985 512356.459985,146352.192985 512351.076985,146356.303985 512348.809985,146360.631985 512347.534985,146365.076985 512346.785985,146369.540985 512346.711985,146374.638985 512347.185985,146383.481985 512348.875985,146386.523985 512348.970985,146391.031985 512348.741985,146396.693985 512348.157985,146398.836985 512347.264985,146402.911985 512345.190985,146406.601985 512342.664985,146407.369985 512341.866985,146413.207985 512329.834985,146414.615985 512325.605985,146415.160985 512322.986985,146415.639985 512318.282985,146415.082985 512313.996985,146413.604985 512312.108985,146409.418985 512309.747985,146407.116985 512308.829985,146402.755985 512307.423985,146394.786985 512303.239985,146391.945985 512301.969985,146387.707985 512300.465985,146384.157985 512299.758985,146373.077985 512298.308985,146371.668985 512297.962985,146366.140985 512295.894985,146362.222985 512293.667985,146360.086985 512292.216985,146355.784985 512288.717985,146352.559985 512285.575985,146348.870985 512281.607985,146346.171985 512278.002985,146344.075985 512274.769985,146341.569985 512269.924985,146339.050985 512260.216985,146339.079985 512246.711985,146338.564985 512238.156985,146338.130985 512233.677985,146335.336985 512214.430985,146334.344985 512210.061985,146332.244985 512204.923985,146330.093985 512200.952985,146327.794985 512197.206985,146324.899985 512193.795985,146321.434985 512191.598985,146317.091985 512189.432985,146309.323985 512184.888985,146303.936985 512181.457985,146300.355985 512178.763985,146298.733985 512177.197985,146295.789985 512172.900985,146294.087985 512168.735985,146292.744985 512164.191985,146290.697985 512155.428985,146288.537985 512143.477985,146287.578985 512134.336985,146287.272985 512129.846985,146287.102985 512123.380985,146287.228985 512114.373985,146287.112985 512109.880985,146286.374985 512101.930985,146284.902985 512090.429985,146283.740985 512081.485985,146282.851985 512077.088985,146280.837985 512070.639985,146275.584985 512056.262985,146273.874985 512052.114985,146273.243985 512050.980985,146254.611985 512024.878985,146248.543985 512017.815985,146245.732985 512014.270985,146243.655985 512010.600985,146243.852985 512008.166985,146246.012985 512003.791985,146252.863985 511979.961985,146254.225985 511974.758985,146255.146985 511970.352985,146257.351985 511957.390985,146257.964985 511952.925985,146258.260985 511948.133985,146257.735985 511943.629985,146256.366985 511939.322985,146254.473985 511936.211985,146251.644985 511932.639985,146247.278985 511926.685985,146233.230985 511908.799985,146222.941985 511895.214985,146212.626985 511883.086985,146203.013985 511872.601985,146198.631985 511866.609985,146192.859985 511859.687985,146189.793985 511856.402985,146187.793985 511854.542985,146180.824985 511848.828985,146174.327985 511842.730985,146170.156985 511839.261985,146166.346985 511836.872985,146162.414985 511834.655985,146155.353985 511830.943985,146151.558985 511828.564985,146150.071985 511827.399985,146146.718985 511824.409985,146131.468985 511809.734985,146128.133985 511806.716985,146124.322985 511803.666985,146120.556985 511801.187985,146116.544985 511799.068985,146112.378985 511797.359985,146112.171985 511800.770985,146111.199985 511805.322985,146109.552985 511809.493985,146107.855985 511811.576985,146103.683985 511814.013985,146095.647985 511813.349985,146091.150985 511813.203985,146082.184985 511813.362985,146080.884985 511813.180985,146076.120985 511811.909985,146071.102985 511810.343985,146066.266985 511808.030985,146061.890985 511806.956985,146060.071985 511806.842985,146055.518985 511805.799985,146053.676985 511801.503985,146053.392985 511796.956985,146052.060985 511798.081985,146048.202985 511800.432985,146046.939985 511800.933985,146041.831985 511802.104985,146033.783985 511803.032985,146021.534985 511804.853985,146010.430985 511805.941985,146001.961985 511808.986985,145999.868985 511809.336985,145993.249985 511809.685985,145988.748985 511809.704985,145972.952985 511808.649985,145968.456985 511808.614985,145962.536985 511809.137985,145955.586985 511810.173985,145946.751985 511811.900985,145931.180985 511815.560985,145923.630985 511815.211985,145921.449985 511815.416985,145916.390985 511816.456985,145912.040985 511817.607985,145899.094985 511821.446985,145898.671985 511827.626985,145897.959985 511833.437985,145896.272985 511842.280985,145894.388985 511851.014985,145893.746985 511866.238985,145892.513985 511880.048985,145892.097985 511882.450985,145891.100985 511886.840985,145886.859985 511899.482985,145880.730985 511914.091985,145878.241985 511922.288985,145876.483985 511926.259985,145871.473985 511927.983985,145867.052985 511928.834985,145851.133985 511929.639985,145846.673985 511930.725985,145844.102985 511934.297985,145839.483985 511943.835985,145835.917985 511952.104985,145834.022985 511955.925985,145833.089985 511959.888985,145834.858985 511961.248985,145839.696985 511961.704985,145847.667985 511964.562985,145851.967985 511965.836985,145857.630985 511965.736985,145861.503985 511967.145985,145867.018985 511969.482985,145871.317985 511970.809985,145879.898985 511972.132985,145888.307985 511975.341985,145891.449985 511976.221985,145897.298985 511977.362985,145906.240985 511978.406985,145912.375985 511979.747985,145920.173985 511980.489985,145927.160985 511981.356985,145931.603985 511982.135985,145935.971985 511983.195985,145941.276985 511984.958985,145949.658985 511988.269985,145953.697985 511989.930985,145957.682985 511991.993985,145960.523985 511994.105985,145965.656985 511999.048985,145971.858985 512005.613985,145974.677985 512009.092985,145976.774985 512012.567985,145978.664985 512017.548985,145978.930985 512022.067985,145978.934985 512030.767985,145980.033985 512039.324985,145980.355985 512043.792985,145979.736985 512049.515985,145974.978985 512077.720985,145970.939985 512094.710985,145970.097985 512099.899985,145969.429985 512104.353985,145968.212985 512110.362985,145963.403985 512127.711985,145959.777985 512138.566985,145958.219985 512142.787985,145954.919985 512150.579985,145954.316985 512152.865985,145950.023985 512173.319985,145949.268985 512177.747985,145948.670985 512184.400985,145948.801985 512188.872985,145949.475985 512191.375985,145951.382985 512196.412985,145955.761985 512214.480985,145957.308985 512218.688985,145958.951985 512221.666985,145965.956985 512232.465985,145968.169985 512236.379985,145971.396985 512243.185985,145972.893985 512247.412985,145974.089985 512252.919985,145975.258985 512261.871985,145975.389985 512263.170985,145975.261985 512267.671985,145974.422985 512270.700985,145972.905985 512274.963985,145970.962985 512281.855985,145968.886985 512288.012985,145966.777985 512291.988985,145962.060985 512296.906985,145960.735985 512298.727985,145958.760985 512302.764985,145957.946985 512308.248985,145956.867985 512324.439985,145956.311985 512329.454985,145954.998985 512333.765985,145953.531985 512341.807985,145952.899985 512346.276985,145952.677985 512352.128985,145953.306985 512356.903985,145955.010985 512360.832985,145956.774985 512361.674985,145962.064985 512362.327985,145966.355985 512363.971985,145970.113985 512366.364985,145972.275985 512368.577985,145975.177985 512372.065985,145977.783985 512375.818985,145980.028985 512379.722985,145980.947985 512381.625985,145982.588985 512385.838985,145983.846985 512390.212985,145984.753985 512394.622985,145985.225985 512398.653985,145985.264985 512403.214985,145984.759985 512407.672985,145984.234985 512409.635985,145980.270985 512418.610985,145977.746985 512427.267985,145976.275985 512431.506985,145974.447985 512435.293985,145972.231985 512439.224985,145969.560985 512444.528985,145966.183985 512453.477985,145964.959985 512457.841985,145964.811985 512462.320985,145964.972985 512483.908985,145966.055985 512493.902985,145966.394985 512498.383985,145966.345985 512501.348985,145965.651985 512510.442985,145966.007985 512515.207985,145967.991985 512519.177985,145970.988985 512523.506985,145981.550985 512539.664985,145983.874985 512543.507985,145985.060985 512545.952985,145986.235985 512550.291985,145983.358985 512554.463985,145979.245985 512556.198985,145974.914985 512557.683985,145968.780985 512560.209985,145965.765985 512560.497985,145959.080985 512560.161985,145954.623985 512559.494985,145947.257985 512557.988985,145942.825985 512557.286985,145938.688985 512556.844985,145934.331985 512557.437985,145932.222985 512558.727985,145928.878985 512561.837985,145925.633985 512565.565985,145922.904985 512569.126985,145914.850985 512580.807985,145912.164985 512584.415985,145905.868985 512591.644985,145894.297985 512609.011985,145889.770985 512616.314985,145882.367985 512628.854985,145879.953985 512632.675985,145877.267985 512636.269985,145874.109985 512639.263985,145869.573985 512643.201985,145859.814985 512652.529985,145850.545985 512661.964985,145845.579985 512667.687985,145842.865985 512671.301985,145840.476985 512675.106985,145838.542985 512678.871985,145836.761985 512683.029985,145835.290985 512687.282985,145834.663985 512692.058985,145833.664985 512697.458985,145832.411985 512701.812985,145831.523985 512706.199985,145831.460985 512712.157985,145832.017985 512721.523985,145832.476985 512725.999985,145833.300985 512728.179985,145836.406985 512734.549985,145838.616985 512738.457985,145840.467985 512740.636985,145843.809985 512743.682985,145846.311985 512745.633985,145849.977985 512748.254985,145854.914985 512751.492985,145860.112985 512754.126985,145878.402985 512762.178985,145898.977985 512770.121985,145903.383985 512771.155985,145907.855985 512770.825985,145912.244985 512769.534985,145914.149985 512768.607985,145917.905985 512766.050985,145929.966985 512758.667985,145933.945985 512756.582985,145937.171985 512755.312985,145941.494985 512754.031985,145945.543985 512753.171985,145953.081985 512751.955985,145960.672985 512750.985985,145965.480985 512750.093985,145973.107985 512745.253985,145975.481985 512743.387985,145978.768985 512740.319985,145981.568985 512736.896985,145986.785985 512729.543985,145992.444985 512719.776985,145996.313985 512714.047985,145999.352985 512710.106985,146008.645985 512699.953985,146032.532985 512667.829985,146036.110985 512662.656985,146041.021985 512655.112985,146046.773985 512645.487985,146061.241985 512626.123985,146063.657985 512622.326985,146074.236985 512610.353985,146077.335985 512607.099985,146083.940985 512601.665985,146089.128985 512596.256985,146090.859985 512595.001985,146096.079985 512592.079985,146100.081985 512589.961985,146104.225985 512588.255985,146107.119985 512587.579985,146111.607985 512586.972985,146116.021985 512586.112985,146118.617985 512585.203985,146127.304985 512581.405985,146134.333985 512579.170985,146138.669985 512577.976985,146146.690985 512576.867985,146149.532985 512576.265985,146153.768985 512574.808985,146154.806985 512574.093985,146158.013985 512570.866985,146163.266985 512566.206985,146166.976985 512563.940985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>POLYGON((145961.546571986 511912.662006029,145964.929660209 511913.786300946,145968.831148249 511915.203927207,145977.213148249 511918.514927207,145978.184122361 511918.906330695,145982.223122361 511920.567330695,145988.178345514 511923.326895495,145992.163345514 511925.389895495,146002.428346021 511931.803847377,146005.269346021 511933.915847377,146012.547718291 511940.082553283,146017.680718291 511945.025553283,146020.175831511 511947.544661152,146026.377831511 511954.109661152,146030.130500873 511958.397140147,146032.949500873 511961.876140147,146038.891918642 511970.342878856,146040.988918642 511973.817878856,146046.896740518 511985.960854318,146048.786740518 511990.941854318,146052.005918251 512001.861170943,146053.535391539 512013.141919689,146053.801391539 512017.660919689,146053.930977073 512022.033502245,146053.93277973 512025.954280873,146054.422971197 512029.770994603,146054.839972833 512033.933864122,146055.161972833 512038.401864122,146054.921099551 512051.857951959,146054.302099551 512057.580951959,146053.692078361 512061.991728103,146048.934078361 512090.196728103,146047.945483201 512095.067170181,146044.535831084 512109.409826645,146044.201732362 512111.468779462,146043.600455739 512115.477890356,146042.937560607 512119.241440403,146041.720560607 512125.250440403,146040.487739668 512130.396952099,146035.678739668 512147.745952099,146034.540145377 512151.474280488,146030.914145377 512162.329280488,146030.138053291 512164.537367942,146028.580053291 512168.758367942,146027.281759347 512172.036426395,146026.57950483 512173.694598273,146024.940649099 512181.502926976,146026.518236958 512188.012143106,146028.878434452 512191.650654561,146031.243915918 512195.552347259,146033.456915918 512199.466347259,146035.938356115 512204.248258055,146039.165356115 512211.054258055,146042.094355838 512218.148378153,146043.591355838 512222.375378153,146046.185453891 512231.495680334,146047.381453891 512237.002680334,146048.458578972 512243.208536569,146049.627578972 512252.160536569,146049.880491616 512254.346644456,146050.011491616 512255.645644456,146050.359676122 512265.302982437,146050.231676122 512269.803982437,146047.540509038 512287.692348707,146046.701509038 512290.721348707,146045.082457196 512295.845347966,146044.409241749 512297.737185443,146043.149165993 512302.206790234,146042.031853863 512305.818786975,146039.955853863 512311.975786975,146035.143089159 512323.157382301,146033.900092563 512325.500746201,146036.782654969 512329.289067883,146039.388654969 512333.042067883,146042.800518365 512338.43114755,146045.045518365 512342.33514755,146047.566044974 512347.107873011,146048.485044974 512349.010873011,146050.833693904 512354.404895916,146052.474693904 512358.617895916,146054.667103858 512365.108698415,146055.925103858 512369.482698415,146057.30935832 512375.104056972,146058.21635832 512379.514056972,146059.245062512 512385.900636058,146059.717062512 512389.931636058,146060.223243322 512398.012701713,146060.262243322 512402.573701713,146059.7883581 512411.656955259,146059.2833581 512416.114955259,146057.213496243 512427.050516025,146056.688496243 512429.013516025,146052.841276933 512439.937415777,146050.883339039 512444.370436111,146049.74912714 512448.260639125,146048.602040581 512451.855809194,146047.131040581 512456.094809194,146043.818802383 512464.110172266,146041.990802383 512467.897172266,146039.885701639 512471.925759398,146039.942773595 512479.578364232,146040.61946415 512485.822912165,146040.842276676 512488.245195917,146041.181276676 512492.726195917,146041.214881873 512493.865328219,146044.32877048 512498.629029421,146045.728476222 512500.854553149,146048.052476222 512504.697553149,146051.355132213 512510.775283735,146052.541132213 512513.220283735,146057.453576793 512526.349091164,146057.783246656 512527.566484813,146059.446185907 512526.635621117,146060.997538858 512525.79105702,146064.999538858 512523.67305702,146071.530800114 512520.609048209,146075.674800114 512518.903048209,146087.166213225 512515.221991634,146090.060213225 512514.545991634,146095.149883514 512513.609553683,146097.260587609 512512.686743259,146104.578561552 512509.932145889,146111.607561552 512507.697145889,146114.422443778 512506.86240649,146118.758443778 512505.66840649,146119.768804542 512505.460385872,146124.173587901 512502.201467244,146125.310248092 512501.507216032,146127.027052853 512498.01644808,146128.929097065 512493.805659059,146131.790404731 512485.727145977,146134.426614427 512479.258478887,146137.160638771 512473.35281299,146138.138723824 512468.83758026,146138.55356072 512465.891367461,146139.070326178 512460.306564851,146139.094263736 512459.820836383,146139.074009868 512458.518223309,146131.150856926 512446.62646068,146126.945590272 512439.489831226,146124.207590272 512434.194831226,146120.252440831 512425.124963807,146118.705440831 512420.822963807,146115.125150132 512406.665043552,146114.453150132 512402.224043552,146113.620495716 512389.689031063,146113.747495716 512382.441031063,146114.010409293 512377.344966647,146114.784409293 512368.321966647,146115.482478327 512362.693369809,146116.930478327 512353.789369809,146118.007278605 512348.415505667,146120.671278605 512337.254505667,146121.93390625 512332.625674578,146124.59590625 512323.967674578,146126.136049455 512319.470953069,146129.374049455 512310.911953069,146136.520249982 512296.758691278,146139.057249982 512292.830691278,146146.650527786 512282.975937982,146155.768390522 512274.511978536,146159.280390522 512271.756978536,146170.629720208 512264.403531091,146183.115063238 512259.207697847,146196.330495087 512256.338406173,146200.607495087 512255.807406173,146215.30345241 512255.434662316,146225.65545241 512256.189662316,146238.02521772 512258.140033884,146250.71521772 512261.245033884,146262.104322338 512265.019777129,146264.860929343 512266.455561697,146264.051157917 512260.055933909,146264.075141688 512248.886939879,146263.831185196 512244.834419908,146263.647011297 512244.717118879,146258.848664716 512241.391643106,146255.267664716 512238.697643106,146248.262583799 512232.720240905,146246.640583799 512231.154240905,146236.862440829 512219.587984079,146233.918440829 512215.290984079,146226.363081824 512201.271834749,146224.661081824 512197.106834749,146222.163612255 512189.993562596,146220.820612255 512185.449562596,146219.711138352 512181.252384873,146217.664138352 512172.489384873,146216.8937512 512168.768215609,146214.7337512 512156.817215609,146213.947353077 512151.303432546,146212.988353077 512142.162432546,146212.752553856 512139.436514606,146212.446553856 512134.946514606,146212.298892925 512131.818156614,146212.128892925 512125.352156614,146212.110322503 512122.331903677,146212.215442812 512114.817470142,146212.202599351 512114.320007444,146211.816466238 512110.160443428,146210.518873503 512100.022118668,146209.861513672 512094.9623714,146209.780118043 512094.701735643,146207.132247706 512087.454746906,146195.526825505 512071.19644236,146191.655494679 512066.690310254,146189.777206437 512064.414973587,146186.966206437 512060.869973587,146180.460987801 512051.211022651,146178.383987801 512047.541022651,146172.379144857 512033.937909804,146169.175992617 512019.417488541,146168.900437923 512004.550515496,146169.097437923 512002.116515496,146171.563840795 511988.185002364,146175.219078694 511978.594789147,146179.898286967 511962.318985156,146174.248642708 511955.125823338,146173.443425464 511954.081854714,146164.435871062 511942.188801302,146156.400986805 511932.741678058,146147.732020724 511923.286345762,146142.475204054 511916.874504711,146139.501988848 511912.808894142,146137.197065522 511910.044743195,146133.271902142 511906.826435899,146129.497770574 511903.514605224,146126.031658823 511900.261357655,146120.454780701 511897.329567315,146115.518307519 511894.490179218,146111.723307519 511892.111179218,146106.696454615 511888.580879625,146097.507919426 511888.75926053,146091.340424848 511888.249651719,146090.59870786 511888.22557107,146083.514800452 511888.351194679,146071.786396658 511887.638616,146070.486396658 511887.456616,146061.55176564 511885.646332782,146056.78776564 511884.375332782,146053.777983367 511883.504609645,146048.759983367 511881.938609645,146043.912861215 511880.034496976,146043.324811988 511879.949292499,146038.771811988 511878.906292499,146037.122148048 511878.360987132,146032.563666518 511879.038674687,146028.848664137 511879.496533841,146026.841995148 511879.693152705,146014.332026289 511882.9598319,146012.239026289 511883.3098319,146003.818024229 511884.232946768,145997.199024229 511884.581946768,145993.566578491 511884.685316788,145989.065578491 511884.704316787,145983.750940641 511884.538263377,145971.08566392 511883.692361443,145968.316353774 511884.105167963,145967.434787875 511884.277489899,145967.216830011 511886.718688686,145966.413880576 511892.847634692,145965.997880576 511895.249634692,145965.235566751 511899.061046277,145964.238566751 511903.451046277,145962.206542228 511910.694700251,145961.546571986 511912.662006029))
+ </op></test></case><case><desc>
+ #88 Polygon - gid: 2588
+ </desc>
+ <a>POLYGON((167532.477985 512809.448985,167555.559985 512773.894985,167560.645985 512730.879985,167581.079985 512731.212985,167606.259985 512686.118985,167617.210985 512664.753985,167628.468985 512640.940985,167597.450985 512637.978985,167581.803985 512637.728985,167556.555985 512632.534985,167547.781985 512627.528985,167513.601985 512631.705985,167490.695985 512631.340985,167471.007985 512626.155985,167475.732985 512640.627985,167482.838985 512659.940985,167492.745985 512684.143985,167503.099985 512701.159985,167507.038985 512713.225985,167508.550985 512727.632985,167499.191985 512749.026985,167495.486985 512763.329985,167491.846985 512768.058985,167481.381985 512777.436985,167460.916985 512781.885985,167425.096985 512774.037985,167424.939985 512795.525985,167423.600985 512814.612985,167420.790985 512833.544985,167420.668985 512850.249985,167421.333985 512859.894985,167427.557985 512867.347985,167437.147985 512869.901985,167461.115985 512877.483985,167486.197985 512894.246985,167505.321985 512851.981985,167514.324985 512823.525985,167522.807985 512814.080985,167532.477985 512809.448985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>POLYGON( EMPTY)
+ #89 Polygon - gid: 2589
+ </desc>
+ <a>POLYGON((164372.606985 512890.176985,164324.811985 512880.193985,164323.666985 512914.388985,164331.604985 512958.853985,164350.402985 512964.195985,164391.299985 512979.726985,164454.259985 513002.043985,164502.492985 513022.119985,164552.192985 513041.053985,164558.382985 513043.657985,164576.953985 513051.470985,164592.038985 513040.219985,164595.863985 513032.750985,164611.578985 513009.064985,164629.578985 512994.920985,164626.260985 512987.836985,164600.829985 512976.485985,164523.959985 512955.303985,164510.527985 512945.800985,164431.119985 512911.854985,164372.606985 512890.176985))</a>
+ #90 Polygon - gid: 2590
+ </desc>
+ <a>POLYGON((155418.520985 513085.717985,155400.143985 513071.569985,155370.702985 513097.312985,155348.413985 513124.256985,155334.276985 513145.103985,155324.433985 513167.135985,155314.900985 513197.823985,155293.396985 513250.465985,155281.650985 513277.996985,155264.569985 513307.253985,155252.427985 513331.225985,155236.340985 513356.837985,155217.667985 513407.428985,155244.525985 513419.754985,155271.368985 513429.290985,155283.571985 513410.496985,155322.096985 513324.107985,155339.112985 513295.890985,155349.832985 513271.657985,155363.984985 513253.183985,155421.428985 513170.677985,155456.713985 513126.870985,155443.701985 513110.996985,155418.520985 513085.717985))</a>
+ #91 Polygon - gid: 2591
+ </desc>
+ <a>POLYGON((166387.863985 513465.987985,166413.814985 513435.239985,166454.386985 513435.727985,166462.438985 513436.310985,166456.999985 513382.178985,166446.221985 513361.906985,166439.149985 513358.988985,166405.819985 513348.211985,166349.398985 513333.283985,166288.061985 513312.194985,166276.204985 513316.629985,166264.022985 513356.675985,166262.695985 513364.228985,166258.961985 513385.471985,166282.343985 513410.305985,166286.133985 513412.866985,166327.046985 513440.506985,166354.031985 513472.209985,166380.174985 513466.677985,166387.863985 513465.987985))</a>
+ #92 Polygon - gid: 2592
+ </desc>
+ <a>POLYGON((153201.327985 513295.818985,153226.912985 513272.838985,153240.302985 513281.911985,153282.966985 513342.907985,153287.232985 513349.007985,153310.162985 513372.145985,153338.326985 513391.395985,153372.548985 513386.775985,153399.672985 513387.103985,153440.243985 513369.694985,153483.249985 513348.552985,153521.235985 513335.287985,153552.489985 513341.581985,153585.786985 513360.695985,153617.380985 513383.704985,153639.382985 513396.019985,153663.846985 513408.126985,153718.985985 513419.295985,153723.902985 513420.291985,153763.134985 513416.882985,153805.106985 513411.106985,153825.172985 513392.221985,153822.154985 513354.195985,153791.182985 513314.212985,153756.511985 513292.424985,153715.682985 513274.824985,153689.942985 513246.766985,153691.749985 513225.302985,153710.502985 513199.946985,153745.088985 513192.753985,153766.799985 513182.803985,153787.870985 513144.522985,153784.039985 513111.169985,153761.533985 513086.127985,153735.204985 513069.676985,153715.986985 513046.641985,153705.754985 513022.981985,153712.351985 512993.515985,153716.387985 512988.183985,153736.567985 512961.525985,153775.863985 512967.269985,153804.701985 512977.344985,153840.921985 512987.562985,153863.302985 513002.651985,153879.277985 513023.277985,153891.556985 513047.051985,153902.749985 513097.542985,153906.019985 513136.783985,153914.811985 513155.032985,153934.801985 513183.161985,153941.688985 513209.182985,153945.277985 513236.635985,153954.682985 513271.076985,153974.307985 513291.640985,153998.334985 513310.524985,154022.287985 513346.805985,154047.856985 513378.812985,154086.098985 513411.216985,154113.196985 513422.599985,154142.014985 513416.474985,154164.428985 513408.373985,154165.569985 513407.127985,154178.679985 513392.818985,154205.335985 513385.772985,154230.846985 513375.101985,154244.263985 513337.841985,154243.386985 513308.802985,154208.806985 513283.898985,154177.676985 513268.476985,154162.078985 513245.276985,154158.446985 513221.398985,154157.986985 513171.460985,154149.270985 513136.844985,154123.459985 513090.000985,154107.167985 513068.292985,154094.948985 513052.011985,154076.373985 513047.009985,154061.578985 513057.829985,154031.411985 513063.123985,153984.551985 513054.041985,153957.058985 513028.116985,153947.947985 513002.556985,153952.346985 512983.883985,153976.123985 512949.924985,153983.887985 512932.847985,153996.487985 512894.246985,154028.021985 512877.669985,154068.066985 512863.923985,154075.796985 512828.768985,154074.893985 512770.551985,154043.848985 512733.687985,154003.264985 512710.015985,153966.255985 512712.388985,153936.827985 512716.348985,153912.933985 512723.953985,153879.560985 512721.080985,153843.470985 512726.852985,153820.456985 512739.259985,153797.975985 512758.057985,153767.137985 512785.980985,153744.767985 512802.198985,153720.964985 512810.467985,153708.070985 512834.152985,153679.882985 512843.837985,153654.329985 512844.694985,153636.123985 512831.799985,153626.553985 512805.764985,153605.236985 512802.037985,153582.908985 512813.348985,153573.985985 512817.868985,153560.453985 512847.489985,153551.985985 512889.573985,153555.109985 512925.676985,153578.672985 512951.618985,153597.250985 512967.807985,153596.944985 512978.668985,153587.475985 512994.806985,153576.295985 513010.457985,153558.742985 513027.177985,153552.552985 513043.269985,153557.760985 513070.500985,153564.618985 513091.397985,153563.372985 513099.704985,153540.931985 513098.182985,153513.679985 513097.136985,153451.601985 513088.120985,153434.166985 513073.086985,153414.508985 513059.064985,153388.431985 513055.047985,153368.376985 513057.902985,153357.554985 513073.586985,153361.949985 513104.716985,153363.585985 513143.808985,153363.701985 513182.599985,153356.162985 513189.535985,153341.513985 513187.480985,153310.732985 513173.723985,153275.728985 513162.829985,153233.550985 513165.629985,153209.115985 513186.380985,153197.266985 513215.733985,153184.292985 513230.539985,153146.242985 513231.663985,153118.440985 513226.217985,153096.885985 513247.200985,153093.357985 513260.228985,153092.263985 513262.605985,153087.803985 513263.035985,153082.778985 513262.845985,153076.497985 513261.659985,153071.281985 513260.063985,153055.923985 513250.436985,153033.931985 513239.087985,153015.307985 513233.412985,153006.635985 513232.228985,152996.172985 513231.665985,152987.242985 513230.525985,152982.556985 513230.723985,152974.418985 513231.858985,152970.794985 513232.794985,152961.965985 513239.194985,152955.583985 513250.126985,152952.564985 513254.159985,152941.417985 513259.329985,152928.100985 513267.043985,152916.934985 513271.741985,152911.597985 513274.544985,152905.880985 513279.270985,152902.860985 513283.303985,152910.867985 513287.443985,152915.392985 513290.322985,152928.090985 513301.585985,152939.258985 513309.171985,152947.015985 513313.813985,152952.723985 513316.300985,152960.090985 513318.841985,152983.972985 513325.878985,152991.794985 513328.551985,152999.927985 513332.409985,153004.955985 513335.231985,153019.213985 513344.762985,153023.201985 513346.836985,153033.085985 513351.198985,153043.206985 513354.628985,153051.243985 513358.682985,153058.527985 513363.312985,153061.845985 513366.353985,153064.669985 513369.434985,153068.040985 513374.363985,153072.140985 513386.330985,153072.901985 513390.757985,153073.871985 513400.687985,153073.924985 513405.177985,153072.405985 513410.305985,153067.072985 513421.537985,153063.536985 513427.582985,153053.230985 513442.950985,153039.346985 513464.721985,153026.435985 513482.811985,153012.952985 513509.466985,153009.212985 513518.289985,153000.494985 513543.991985,152997.121985 513556.173985,152995.943985 513562.563985,152995.654985 513566.242985,152996.366985 513572.809985,152998.891985 513581.458985,153001.483985 513586.984985,153020.855985 513620.435985,153026.242985 513628.995985,153033.223985 513644.556985,153035.690985 513648.323985,153038.496985 513651.695985,153042.246985 513654.701985,153049.671985 513658.825985,153056.569985 513661.100985,153068.194985 513666.667985,153079.818985 513672.234985,153088.929985 513675.960985,153095.902985 513680.122985,153099.932985 513682.158985,153105.266985 513687.400985,153109.487985 513690.840985,153114.233985 513696.130985,153122.711985 513704.466985,153135.555985 513715.121985,153137.765985 513717.391985,153139.714985 513721.448985,153142.866985 513724.734985,153145.367985 513728.862985,153149.163985 513737.372985,153150.038985 513740.992985,153150.096985 513745.498985,153149.465985 513749.556985,153147.941985 513753.792985,153146.556985 513756.418985,153221.601985 513713.434985,153243.039985 513693.223985,153249.433985 513648.436985,153241.906985 513608.578985,153239.679985 513583.675985,153242.975985 513553.159985,153244.171985 513516.224985,153234.234985 513488.502985,153208.367985 513465.446985,153196.520985 513425.096985,153191.753985 513354.604985,153201.327985 513295.818985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>MULTIPOLYGON(((153314.366408853 513256.946373533,153344.425090418 513299.920762731,153344.428307148 513299.925362002,153345.019027492 513300.770039474,153357.292865102 513313.15521412,153362.514942791 513312.450229054,153373.455864573 513311.781468071,153384.696070673 513311.917391519,153408.891657558 513301.535074788,153450.161712931 513281.246475274,153458.523693422 513277.746131484,153496.509693422 513264.481131484,153509.454653284 513261.219096639,153522.772872664 513260.303733478,153536.04239993 513261.764042798,153567.29639993 513268.058042798,153578.904974802 513271.387624017,153589.828661247 513276.537206147,153623.125661247 513295.651206147,153629.939444942 513300.069585791,153651.402601521 513315.70058439,153634.676215225 513297.467913577,153625.451760944 513285.053823728,153618.969762242 513271.011606082,153615.505862725 513255.938398603,153615.207362908 513240.475181556,153617.014362908 513219.011181556,153619.43248915 513205.423855392,153624.299289231 513192.5096375,153631.44997307 513180.70580391,153650.20297307 513155.34980391,153659.283744334 513145.160222132,153670.060787432 513136.785060901,153682.177189719 513130.501687667,153688.930355783 513128.441002977,153685.92154806 513126.211424445,153677.615653278 513117.723513198,153658.397653278 513094.688513198,153647.148394857 513076.411911219,153637.42076158 513053.918185328,153637.324677965 513054.052693795,153632.951539397 513059.089474235,153635.879610916 513068.011595924,153639.353840605 513085.097083656,153638.789276955 513102.523082361,153637.543276955 513110.830082361,153634.201590111 513124.368899897,153628.411229936 513137.055041166,153620.372379684 513148.449923257,153610.362956986 513158.159604431,153598.729005737 513165.8484034,153585.872732732 513171.250504441,153572.238602643 513174.179147122,153558.297972073 513174.533082957,153536.95533708 513173.085576586,153510.803415323 513172.081800344,153502.900335114 513171.358270009,153440.822335114 513162.342270009,153438.640153453 513161.811056861,153438.701649662 513182.375707175,153437.138951167 513197.831925132,153432.425490879 513212.634627326,153424.763496524 513226.148714148,153414.481700623 513237.794373132,153406.942700623 513244.730373132,153393.622779106 513254.511086581,153378.484258408 513261.137386896,153362.262083874 513264.287580253,153345.743810109 513263.808730975,153331.094810109 513261.753730975,153314.366408853 513256.946373533)),((153663.604508215 512933.649641924,153674.652150649 512919.055585829,153656.843931777 512919.652840303,153654.048229341 512919.443407929,153657.699714222 512923.412589569,153663.604508215 512933.649641924)),((153758.883863202 512888.990949085,153786.711657314 512893.058611173,153800.600235846 512896.466610122,153827.272897789 512905.785115881,153861.285378758 512915.380354162,153872.465013832 512919.518607333,153882.847749304 512925.375926157,153895.692678836 512934.035822574,153910.714944618 512912.580587528,153913.88546164 512905.607001851,153925.190173663 512870.974209091,153930.971355511 512857.742584438,153939.180996602 512845.864042957,153949.51479589 512835.778878268,153961.58971764 512827.860910141,153993.12371764 512811.283910141,154000.467606639 512808.115371856,154000.317352548 512798.428392478,153994.845561675 512791.930982307,153985.236205669 512786.325998191,153973.665681018 512787.067894892,153953.32758408 512789.804705544,153935.680678951 512795.421375566,153921.251842618 512798.491312861,153906.501211173 512798.677605234,153882.307675006 512796.594842839,153867.870062007 512798.903900812,153862.737031022 512801.671151852,153847.220330287 512814.645794457,153817.478242466 512841.57647473,153811.160108057 512846.702090734,153788.790108057 512862.920090734,153773.268486522 512871.017112799,153766.206508123 512881.53716961,153758.883863202 512888.990949085)),((153990.108182012 513131.514460519,153995.936815762 513139.716243348,154002.712902558 513151.332638848,154007.305505499 513163.972417125,154014.192505499 513189.993417125,154016.056172848 513199.460774779,154018.980204051 513221.827291528,154022.036739822 513233.020289774,154024.865966578 513235.984886921,154044.680163522 513251.557837979,154053.512327266 513259.726747821,154060.924709775 513269.202759109,154083.006073029 513302.648838523,154101.904440147 513326.305611818,154122.168713438 513343.476353717,154123.380753089 513342.153464673,154133.958162066 513332.611356302,154136.654555011 513330.981247067,154133.313214698 513328.948927954,154123.567306259 513320.411007245,154115.43630788 513310.323109212,154099.83830788 513287.123109212,154092.193301943 513272.498140444,154087.931829395 513256.555252408,154084.299829395 513232.677252408,154083.450166684 513222.089812354,154083.072573594 513181.097978162,154078.906777441 513164.553324694,154062.016455659 513133.899330911,154044.375613461 513136.995118314,154030.747603531 513138.121042257,154017.141679456 513136.753859234,153990.108182012 513131.514460519)),((153129.558892559 513463.256147829,153128.274910414 513465.451190834,153125.827034416 513469.355580607,153116.002068797 513484.006276477,153102.582457504 513505.049085282,153100.393635915 513508.291543318,153090.790757281 513521.74643252,153081.018927562 513541.064694122,153079.347575667 513545.007565183,153073.620678631 513561.891335271,153085.066941185 513581.656404892,153089.719238659 513589.048954806,153093.155431415 513595.464797976,153100.588321987 513599.024273401,153100.590588832 513599.025358999,153110.237478323 513603.645475464,153117.319437878 513606.54168678,153127.369021378 513611.56036014,153132.077087556 513614.370480811,153133.752777555 513615.217057693,153143.648069656 513621.216459835,153152.502673599 513628.666669284,153155.350295181 513631.465175534,153156.868974625 513632.702857904,153165.313688058 513640.756148192,153168.491595461 513644.298316368,153173.036019042 513648.766624338,153173.195605074 513648.899012159,153168.20959292 513622.496398573,153167.205092577 513615.259349391,153164.978092577 513590.356349391,153165.113666398 513575.622157955,153168.106611313 513547.911991985,153168.669434958 513530.530811951,153158.464435212 513521.434802591,153148.98341495 513511.256076238,153141.545183943 513499.501547968,153136.405612332 513486.575565644,153129.558892559 513463.256147829)))
+ #93 Polygon - gid: 2593
+ </desc>
+ <a>POLYGON((144142.989985 514088.951985,144136.449985 514054.961985,144132.731985 514033.263985,144127.866985 514013.332985,144126.033985 514004.523985,144123.194985 513984.498985,144121.950985 513977.743985,144119.474985 513965.987985,144116.997985 513955.498985,144114.004985 513944.396985,144111.364985 513935.792985,144104.055985 513915.874985,144099.268985 513901.813985,144095.552985 513888.833985,144092.293985 513878.724985,144090.002985 513870.475985,144088.955985 513866.101985,144087.123985 513855.157985,144085.447985 513846.294985,144084.879985 513841.845985,144084.800985 513839.927985,144085.669985 513820.505985,144086.874985 513812.816985,144087.854985 513808.424985,144085.355985 513807.847985,144081.847985 513810.575985,144081.061985 513814.139985,144080.321985 513815.397985,144076.741985 513819.927985,144070.813985 513826.699985,144068.515985 513829.942985,144066.267985 513833.838985,144065.506985 513835.614985,144064.259985 513839.956985,144063.081985 513846.147985,144062.077985 513852.889985,144060.916985 513861.814985,144059.234985 513868.846985,144058.119985 513877.778985,144056.474985 513887.398985,144055.675985 513904.802985,144055.567985 513911.744985,144055.264985 513916.555985,144053.261985 513926.195985,144051.759985 513939.993985,144051.299985 513947.409985,144050.945985 513963.879985,144051.901985 513981.625985,144052.777985 514006.209985,144052.802985 514010.705985,144052.525985 514016.993985,144051.223985 514036.894985,144051.208985 514041.388985,144051.664985 514047.744985,144052.166985 514052.223985,144053.651985 514062.584985,144054.499985 514067.055985,144055.829985 514071.244985,144056.995985 514072.928985,144061.349985 514075.995985,144065.576985 514077.579985,144071.276985 514083.651985,144073.625985 514085.443985,144077.782985 514087.370985,144083.025985 514085.365985,144087.943985 514084.820985,144092.174985 514086.440985,144096.761985 514089.493985,144100.786985 514096.214985,144106.124985 514105.807985,144109.287985 514110.877985,144111.976985 514114.527985,144115.094985 514118.007985,144119.064985 514120.147985,144120.248985 514120.616985,144124.620985 514121.695985,144137.912985 514121.582985,144151.392985 514120.745985,144147.230985 514106.336985,144142.989985 514088.951985))</a>
+ #94 Polygon - gid: 2594
+ </desc>
+ <a>POLYGON((146479.081985 514136.773985,146478.714985 514132.400985,146477.568985 514128.020985,146476.252985 514124.982985,146473.696985 514121.266985,146471.885985 514119.791985,146467.951985 514117.478985,146464.896985 514115.364985,146459.731985 514111.590985,146449.118985 514103.426985,146445.431985 514100.853985,146438.988985 514097.422985,146420.476985 514084.864985,146410.008985 514078.144985,146406.594985 514075.475985,146403.293985 514072.424985,146402.417985 514071.373985,146399.916985 514067.612985,146396.063985 514062.810985,146394.253985 514060.275985,146390.917985 514055.377985,146385.928985 514047.887985,146381.971985 514040.637985,146371.896985 514023.770985,146363.206985 514010.769985,146359.366985 514005.398985,146356.174985 514000.205985,146350.242985 513986.956985,146348.661985 513982.759985,146348.018985 513980.004985,146345.920985 513967.273985,146343.206985 513954.080985,146342.126985 513949.607985,146340.683985 513945.344985,146336.388985 513938.017985,146333.562985 513933.769985,146325.253985 513924.184985,146323.627985 513922.704985,146316.621985 513917.038985,146310.551985 513911.712985,146307.028985 513908.936985,146303.951985 513907.084985,146299.856985 513905.177985,146294.015985 513903.097985,146288.626985 513900.881985,146284.619985 513897.582985,146282.346985 513893.679985,146280.440985 513888.656985,146279.676985 513884.231985,146279.152985 513879.731985,146278.585985 513876.871985,146278.129985 513872.432985,146278.560985 513870.690985,146280.450985 513866.529985,146282.958985 513858.900985,146284.615985 513854.733985,146286.254985 513851.405985,146288.509985 513847.461985,146291.167985 513843.864985,146292.806985 513842.160985,146296.325985 513839.297985,146300.136985 513836.851985,146302.653985 513835.598985,146311.462985 513832.015985,146315.327985 513829.714985,146320.784985 513825.997985,146328.041985 513820.671985,146334.570985 513816.117985,146337.956985 513813.151985,146340.303985 513810.793985,146346.430985 513804.195985,146350.723985 513799.305985,146354.581985 513794.164985,146356.967985 513790.337985,146359.098985 513786.371985,146356.925985 513784.344985,146353.343985 513781.608985,146351.160985 513780.340985,146347.127985 513778.317985,146341.387985 513775.017985,146334.128985 513769.411985,146330.367985 513766.944985,146326.816985 513765.066985,146321.737985 513762.782985,146317.469985 513761.348985,146307.868985 513759.381985,146298.937985 513757.947985,146293.990985 513756.697985,146290.285985 513754.090985,146283.117985 513750.818985,146281.983985 513750.147985,146274.500985 513745.136985,146267.323985 513740.889985,146260.479985 513737.509985,146252.565985 513731.306985,146244.686985 513726.625985,146240.634985 513724.637985,146236.699985 513722.476985,146231.698985 513718.659985,146224.714985 513712.958985,146211.868985 513703.630985,146205.062985 513697.739985,146194.890985 513691.020985,146191.411985 513688.135985,146188.225985 513684.826985,146185.687985 513681.124985,146181.993985 513674.493985,146178.581985 513666.935985,146177.129985 513662.679985,146176.213985 513658.394985,146175.616985 513653.926985,146175.504985 513652.576985,146175.600985 513647.593985,146176.461985 513643.173985,146178.964985 513636.048985,146180.631985 513631.864985,146183.762985 513624.568985,146186.478985 513619.197985,146188.785985 513615.318985,146192.164985 513610.645985,146195.164985 513607.272985,146198.434985 513604.177985,146213.147985 513593.658985,146218.529985 513590.075985,146226.316985 513585.557985,146231.500985 513581.909985,146235.294985 513579.520985,146244.772985 513575.912985,146248.280985 513573.656985,146252.907985 513570.075985,146259.880985 513564.383985,146265.073985 513560.374985,146266.003985 513559.291985,146268.532985 513555.045985,146270.217985 513550.871985,146271.596985 513546.578985,146272.254985 513544.163985,146272.984985 513538.959985,146272.872985 513534.455985,146272.384985 513529.970985,146271.633985 513526.049985,146270.401985 513521.714985,146268.823985 513517.605985,146264.736985 513508.248985,146262.619985 513504.303985,146260.103985 513501.227985,146255.643985 513496.995985,146252.055985 513494.269985,146242.001985 513487.640985,146234.786985 513483.442985,146230.921985 513480.977985,146227.280985 513478.321985,146223.757985 513475.497985,146220.334985 513472.346985,146217.293985 513469.037985,146214.461985 513465.521985,146211.480985 513461.477985,146209.011985 513457.691985,146206.944985 513453.700985,146206.040985 513450.812985,146204.852985 513446.079985,146201.554985 513437.705985,146199.723985 513430.002985,146198.858985 513423.346985,146198.729985 513418.833985,146198.981985 513413.944985,146199.585985 513409.495985,146202.341985 513393.330985,146204.018985 513381.604985,146204.289985 513377.137985,146203.940985 513373.739985,146202.588985 513368.770985,146201.014985 513364.562985,146193.633985 513347.926985,146188.343985 513337.470985,146179.395985 513322.231985,146177.406985 513317.723985,146176.277985 513313.368985,146175.554985 513308.909985,146174.522985 513300.450985,146173.700985 513291.481985,146173.067985 513279.144985,146173.153985 513274.609985,146173.776985 513270.271985,146175.536985 513266.566985,146178.912985 513263.457985,146160.329985 513252.483985,146153.075985 513248.510985,146144.955985 513244.623985,146137.312985 513241.362985,146125.568985 513235.881985,146114.189985 513230.108985,146101.309985 513223.226985,146097.454985 513220.539985,146094.341985 513217.256985,146091.850985 513213.488985,146083.684985 513205.357985,146082.597985 513212.274985,146081.647985 513216.686985,146080.306985 513221.732985,146078.908985 513226.013985,146077.270985 513230.221985,146075.406985 513234.316985,146075.851985 513239.281985,146074.445985 513243.892985,146070.610985 513252.849985,146068.317985 513256.754985,146065.673985 513260.377985,146063.670985 513262.207985,146060.010985 513264.884985,146055.763985 513268.385985,146048.871985 513273.568985,146045.377985 513276.403985,146037.835985 513283.388985,146032.176985 513288.382985,146030.188985 513290.728985,146026.831985 513295.149985,146023.917985 513299.329985,146022.121985 513303.449985,146018.110985 513313.677985,146016.770985 513317.973985,146015.995985 513322.317985,146015.430985 513326.785985,146015.139985 513330.588985,146015.036985 513335.089985,146019.408985 513334.005985,146022.631985 513333.471985,146027.107985 513333.051985,146041.611985 513332.575985,146049.738985 513332.923985,146054.240985 513332.921985,146063.738985 513332.380985,146070.654985 513331.525985,146075.071985 513330.688985,146087.871985 513327.862985,146093.290985 513327.494985,146095.749985 513331.216985,146097.615985 513335.493985,146099.166985 513339.883985,146099.857985 513344.684985,146099.817985 513346.552985,146099.080985 513351.001985,146097.127985 513355.574985,146093.783985 513361.802985,146091.249985 513365.509985,146084.546985 513374.375985,146081.780985 513377.936985,146080.165985 513379.645985,146076.645985 513382.432985,146072.783985 513384.802985,146066.921985 513387.233985,146054.515985 513394.555985,146051.789985 513396.322985,146039.520985 513406.330985,146029.153985 513416.300985,146025.727985 513419.223985,146023.019985 513421.304985,146019.116985 513423.591985,146017.345985 513424.834985,146012.642985 513430.297985,146007.454985 513434.794985,146004.348985 513438.307985,146002.742985 513439.282985,145998.366985 513439.664985,145993.737985 513439.140985,145988.546985 513437.396985,145980.808985 513433.869985,145976.757985 513431.823985,145974.597985 513431.066985,145970.142985 513430.351985,145965.622985 513430.248985,145960.693985 513431.184985,145956.534985 513432.407985,145952.110985 513433.378985,145950.366985 513433.996985,145946.424985 513436.225985,145944.222985 513438.024985,145941.424985 513441.523985,145937.088985 513448.257985,145934.927985 513452.199985,145933.224985 513456.550985,145931.146985 513462.688985,145928.360985 513469.576985,145926.520985 513475.958985,145924.971985 513480.182985,145920.025985 513492.681985,145911.406985 513513.274985,145907.967985 513524.157985,145905.191985 513532.021985,145901.510985 513544.159985,145897.336985 513555.604985,145896.428985 513560.011985,145897.275985 513564.439985,145899.152985 513569.022985,145905.340985 513581.631985,145908.586985 513587.097985,145910.309985 513591.256985,145912.982985 513600.599985,145913.783985 513605.107985,145915.301985 513610.334985,145916.864985 513614.554985,145918.881985 513618.827985,145920.821985 513621.986985,145923.849985 513625.397985,145925.144985 513626.290985,145929.423985 513627.576985,145936.173985 513629.294985,145938.023985 513629.934985,145941.998985 513632.053985,145945.757985 513635.203985,145947.126985 513636.582985,145950.141985 513639.958985,145951.459985 513641.863985,145953.146985 513646.046985,145953.414985 513647.191985,145953.874985 513651.661985,145954.096985 513658.513985,145954.043985 513662.795985,145953.626985 513671.814985,145953.228985 513676.297985,145952.779985 513679.412985,145951.502985 513683.703985,145949.833985 513687.915985,145947.235985 513696.116985,145944.953985 513705.922985,145943.415985 513710.166985,145941.636985 513714.326985,145939.837985 513717.738985,145937.228985 513721.588985,145934.193985 513724.196985,145929.917985 513725.238985,145925.266985 513725.352985,145917.072985 513724.542985,145912.531985 513724.375985,145908.987985 513724.705985,145904.524985 513726.029985,145901.883985 513727.777985,145899.550985 513731.507985,145897.946985 513735.873985,145896.436985 513740.961985,145895.477985 513745.374985,145894.359985 513752.883985,145894.105985 513759.166985,145894.366985 513763.684985,145894.953985 513768.180985,145895.652985 513771.335985,145898.043985 513775.170985,145904.293985 513779.456985,145907.725985 513782.450985,145911.235985 513785.240985,145916.251985 513786.864985,145928.643985 513788.724985,145938.188985 513791.948985,145949.160985 513795.142985,145953.342985 513796.792985,145961.102985 513800.269985,145971.617985 513805.424985,145979.736985 513808.676985,145983.834985 513810.547985,145990.251985 513813.832985,145996.957985 513818.576985,146007.477985 513824.220985,146011.119985 513826.855985,146019.141985 513833.212985,146024.607985 513838.295985,146044.502985 513858.336985,146047.324985 513861.479985,146050.061985 513865.094985,146051.186985 513867.257985,146052.620985 513871.495985,146055.812985 513883.744985,146056.619985 513887.643985,146056.676985 513893.498985,146055.930985 513897.935985,146054.457985 513909.647985,146051.861985 513924.853985,146051.872985 513940.661985,146052.072985 513947.397985,146052.482985 513950.679985,146054.529985 513959.445985,146057.420985 513969.123985,146060.476985 513967.705985,146064.865985 513966.275985,146069.275985 513965.468985,146070.291985 513965.510985,146074.526985 513967.314985,146081.217985 513970.595985,146082.397985 513970.826985,146086.929985 513970.967985,146092.645985 513971.828985,146113.599985 513974.332985,146133.112985 513975.402985,146136.737985 513974.998985,146147.199985 513973.338985,146151.996985 513972.512985,146156.382985 513971.516985,146157.539985 513971.824985,146161.637985 513973.850985,146174.892985 513977.638985,146178.820985 513979.847985,146184.075985 513982.181985,146186.092985 513984.501985,146188.418985 513988.437985,146193.920985 514000.829985,146196.035985 514004.799985,146200.597985 514012.678985,146209.606985 514027.052985,146214.200985 514032.039985,146221.768985 514039.326985,146230.115985 514046.868985,146233.730985 514049.498985,146235.757985 514050.548985,146252.830985 514056.920985,146259.961985 514059.868985,146264.241985 514061.286985,146268.851985 514062.519985,146273.342985 514062.849985,146274.575985 514062.465985,146282.815985 514058.754985,146286.427985 514057.728985,146290.885985 514057.127985,146293.866985 514057.134985,146298.432985 514057.472985,146303.313985 514058.553985,146307.456985 514062.565985,146313.362985 514069.361985,146320.712985 514078.294985,146323.474985 514081.845985,146325.878985 514085.271985,146329.490985 514090.982985,146339.561985 514107.851985,146346.200985 514119.450985,146349.975985 514124.212985,146355.077985 514130.172985,146358.228985 514133.359985,146360.327985 514134.759985,146364.444985 514136.649985,146368.646985 514138.201985,146373.966985 514138.806985,146382.511985 514135.796985,146385.640985 514135.815985,146392.037985 514137.070985,146401.238985 514140.001985,146405.401985 514141.678985,146408.384985 514143.356985,146418.276985 514149.793985,146422.151985 514152.075985,146427.537985 514154.576985,146432.140985 514156.430985,146436.476985 514157.642985,146444.150985 514161.340985,146449.150985 514162.902985,146456.343985 514163.308985,146460.788985 514163.007985,146462.874985 514161.871985,146466.456985 514158.988985,146471.437985 514155.719985,146473.998985 514152.004985,146475.591985 514148.803985,146477.255985 514144.618985,146478.341985 514141.194985,146479.081985 514136.773985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>MULTIPOLYGON(((146011.847522543 513740.890335071,146014.984307229 513742.322478592,146018.011201398 513743.787321187,146024.428201398 513747.072321187,146033.566291871 513752.604961839,146036.493665821 513754.675862826,146042.935029827 513758.13166686,146051.440930471 513763.45702014,146055.082930471 513766.09202014,146057.700853077 513768.074842368,146065.722853077 513774.431842368,146070.2158857 513778.290706576,146075.6818857 513783.373706576,146077.834518588 513785.457210202,146097.729518588 513805.498210202,146100.309160202 513808.23039053,146103.131160202 513811.37339053,146107.119921677 513816.207857286,146109.856921677 513819.822857286,146116.600222878 513830.48771842,146117.725222878 513832.65071842,146122.230218704 513843.219288178,146123.664218704 513847.457288178,146125.197185838 513852.583156763,146128.389185838 513864.832156763,146129.256356421 513868.543958907,146130.063356421 513872.442958907,146131.616431173 513886.913874422,146131.673431173 513892.768874422,146131.108825876 513899.953929188,146134.959352858 513899.34296811,146137.318948726 513898.93666705,146139.774375819 513898.379073483,146157.765635587 513896.529730901,146175.676491337 513899.041053732,146176.833491337 513899.349053732,146186.164377291 513902.857601769,146195.501380849 513905.525920854,146209.222567228 513911.251698752,146206.534467748 513901.417341877,146205.770467748 513896.992341877,146205.1803459 513892.906704753,146204.989884337 513891.271061556,146203.978602791 513884.536090945,146203.522602791 513880.097090945,146203.314130135 513867.180570234,146205.325260586 513854.419875801,146205.756260586 513852.677875802,146210.275071433 513839.674311931,146210.477032007 513839.229678096,146211.710284299 513835.478289843,146213.266858336 513831.188037104,146214.923858336 513827.021037104,146217.332991849 513821.597919563,146218.971991849 513818.269919563,146221.145894415 513814.179565307,146223.400894415 513810.235565307,146227.060181039 513804.624529814,146214.213235884 513796.538689257,146210.103192982 513793.317234099,146208.958646493 513792.637246522,146207.600077938 513791.970703016,146204.532771508 513790.377091938,146200.597771508 513788.216091938,146191.196115791 513782.095756264,146186.195115791 513778.278756264,146184.271868982 513776.760489871,146178.930882644 513772.400672701,146167.80106412 513764.318861461,146162.78504905 513760.338720202,146159.661996558 513757.635531511,146153.554337978 513753.601186446,146147.016034602 513748.753030905,146143.537034602 513745.868030905,146137.384343372 513740.155346205,146134.198343372 513736.846346205,146126.367313328 513727.23576639,146123.829313328 513723.53376639,146120.168646448 513717.62452302,146116.474646448 513710.99352302,146113.636813155 513705.353295708,146110.224813155 513697.795295708,146107.599279608 513691.152829039,146106.147279608 513686.896829039,146103.787047984 513678.358428479,146102.871047984 513674.073428479,146101.874656251 513668.327970511,146101.277656251 513663.859970511,146100.873767208 513660.127903811,146100.761767208 513658.777903811,146100.518899611 513651.132340369,146100.614899612 513646.149340369,146101.984689183 513633.253797059,146102.845689183 513628.833797059,146105.701299377 513618.315880282,146108.204299377 513611.190880282,146109.291399104 513608.289456394,146110.958399104 513604.105456394,146111.710285435 513602.287978238,146114.841285435 513594.991978238,146116.833661888 513590.724255606,146119.549661888 513585.353255606,146122.017937054 513580.860362517,146124.324937054 513576.981362517,146128.010088172 513571.37253617,146131.389088172 513566.69953617,146136.123955204 513560.802199235,146139.123955204 513557.429199235,146143.609554063 513552.802465075,146146.879554063 513549.707465075,146154.815451024 513543.167033067,146169.528451024 513532.648033067,146171.585632309 513531.2284569,146172.731747701 513530.46544474,146169.539682841 513527.527029206,146165.112892883 513523.096571621,146162.071892883 513519.787571621,146158.884736665 513516.084342021,146156.052736665 513512.568342021,146154.091428412 513510.023624266,146151.110428412 513505.979624266,146148.659199946 513502.446550055,146146.190199946 513498.660550055,146142.413986224 513492.184108145,146140.346986224 513488.193108145,146135.369578457 513476.105475136,146134.465578457 513473.217475136,146133.297507522 513469.071859128,146133.291225392 513469.04683108,146131.771944583 513465.189202972,146128.588019266 513455.05020339,146126.757019266 513447.34720339,146125.349413787 513439.66855052,146125.333509108 513439.54616724,146123.202128707 513441.233711893,146115.873841133 513446.356183474,146112.011841133 513448.726183474,146101.514293052 513454.08190964,146100.511940734 513454.497590036,146095.499821203 513457.455734419,146089.301229719 513462.512014765,146081.141827901 513470.358955647,146077.832919083 513473.356759262,146074.406919083 513476.279759262,146071.427632069 513478.69281934,146068.719632069 513480.77381934,146066.359203061 513482.363239454,146061.767349912 513486.970701292,146060.053668985 513488.456133661,146052.447934138 513495.853541664,146043.270261658 513502.418313523,146041.664261658 513503.393313523,146026.075330476 513510.561324309,146009.265256284 513513.998846618,146004.889256284 513514.380846618,145992.162649537 513514.217644662,145989.764384456 513520.278282601,145989.210645291 513521.638552137,145981.900192566 513539.105097324,145979.482413151 513546.756360302,145978.690931684 513549.123257126,145976.475479026 513555.399308892,145976.438362152 513555.521700801,145977.876266427 513558.392663553,145979.599266427 513562.551663553,145981.828103128 513568.939622633,145990.170574216 513574.569221868,145993.929574216 513577.719221868,145998.983628831 513582.364313931,146000.352628831 513583.743313931,146003.066429269 513586.625217087,146006.081429269 513590.001217087,146011.819217687 513597.286757872,146013.137217687 513599.191757872,146021.016327875 513613.811976769,146022.703327875 513617.994976769,146026.173297299 513628.954363433,146026.441297299 513630.099363433,146028.020982394 513639.514410324,146028.480982394 513643.984410324,146028.835651666 513649.233311912,146029.057651666 513656.085311912,146029.091240665 513659.44221843,146029.038240665 513663.72421843,146028.963947968 513666.259963774,146028.546947968 513675.278963774,146028.333151116 513678.447386096,146027.935151116 513682.930386096,146027.461793032 513686.99799489,146027.012793032 513690.11299489,146024.664272548 513700.805722171,146023.387272548 513705.096722171,146021.228562699 513711.332662394,146020.533592679 513713.086535207,146019.619527672 513715.971926707,146018.002063619 513722.922344107,146015.466585062 513731.476325928,146013.928585062 513735.720325927,146012.374991285 513739.656906197,146011.847522543 513740.890335071)),((146263.503396356 513971.644383436,146264.845146421 513973.961711091,146269.154816161 513980.837856373,146272.633703185 513984.187572248,146272.694587294 513984.174888747,146272.160337612 513980.932976116,146271.322748897 513976.861381452,146269.459899281 513975.354829079,146267.156598206 513973.414294395,146266.521108814 513972.856696948,146265.492769349 513972.462429559,146263.503396356 513971.644383436)))
+ #95 Polygon - gid: 2595
+ </desc>
+ <a>POLYGON((152747.244985 514163.075985,152750.222985 514162.865985,152762.227985 514163.357985,152765.838985 514164.275985,152776.630985 514167.853985,152784.077985 514169.654985,152795.626985 514175.727985,152800.056985 514177.203985,152805.566985 514178.290985,152810.480985 514178.365985,152815.012985 514179.178985,152819.420985 514179.392985,152823.072985 514177.882985,152827.019985 514175.502985,152835.565985 514171.245985,152837.084985 514170.146985,152841.503985 514165.822985,152844.238985 514162.245985,152847.722985 514154.557985,152849.262985 514149.500985,152849.452985 514142.388985,152850.715985 514130.165985,152854.579985 514108.250985,152855.312985 514098.346985,152857.278985 514089.733985,152859.500985 514081.827985,152862.415985 514074.361985,152866.473985 514066.324985,152871.582985 514058.454985,152874.488985 514054.574985,152880.379985 514047.771985,152891.153985 514036.794985,152902.009985 514027.885985,152907.437985 514023.431985,152923.267985 514009.540985,152929.973985 514004.580985,152935.475985 514001.216985,152939.529985 513999.220985,152947.627985 513996.379985,152952.070985 513995.270985,152956.453985 513994.775985,152957.977985 513995.027985,152962.007985 513997.311985,152968.886985 514002.852985,152975.323985 514007.391985,152983.086985 514014.935985,152989.043985 514019.895985,152995.859985 514027.807985,153008.635985 514044.568985,153011.618985 514047.976985,153014.918985 514050.909985,153017.338985 514052.376985,153021.618985 514054.009985,153026.424985 514055.095985,153030.899985 514055.144985,153055.639985 514052.224985,153061.294985 514050.966985,153068.401985 514047.971985,153084.487985 514042.766985,153091.735985 514040.113985,153096.408985 514037.940985,153103.935985 514032.998985,153110.244985 514027.659985,153117.783985 514020.217985,153122.060985 514015.234985,153127.554985 514008.104985,153139.559985 513997.107985,153145.303985 513992.530985,153154.505985 513987.088985,153158.166985 513984.484985,153163.747985 513978.577985,153171.147985 513969.045985,153173.668985 513965.324985,153180.637985 513949.947985,153183.187985 513942.152985,153188.073985 513933.422985,153189.159985 513929.039985,153190.078985 513921.778985,153190.426985 513916.983985,153190.068985 513912.495985,153185.862985 513905.476985,153179.518985 513886.559985,153176.400985 513880.496985,153172.336985 513874.800985,153160.951985 513862.562985,153156.433985 513856.339985,153151.396985 513851.959985,153142.738985 513842.886985,153135.922985 513834.974985,153130.949985 513828.224985,153126.944985 513825.146985,153119.109985 513820.649985,153115.239985 513819.412985,153111.703985 513816.997985,153095.957985 513803.789985,153090.619985 513800.267985,153086.268985 513799.212985,153079.246985 513798.413985,153077.385985 513798.511985,153069.766985 513801.027985,153052.681985 513805.263985,153048.530985 513806.983985,153035.310985 513813.782985,153022.371985 513819.572985,153010.779985 513826.491985,152998.307985 513832.718985,152986.401985 513840.022985,152978.337985 513844.031985,152964.726985 513848.610985,152951.529985 513853.757985,152928.653985 513860.833985,152920.997985 513862.406985,152912.173985 513864.930985,152904.462985 513866.658985,152895.879985 513868.220985,152890.402985 513868.449985,152880.815985 513868.059985,152864.829985 513865.581985,152860.332985 513865.146985,152857.986985 513864.721985,152853.735985 513863.281985,152848.769985 513861.216985,152840.910985 513857.601985,152835.803985 513854.706985,152824.859985 513844.217985,152823.050985 513842.027985,152821.482985 513837.821985,152820.962985 513835.100985,152820.667985 513827.554985,152821.148985 513823.064985,152824.742985 513813.937985,152825.940985 513811.508985,152828.593985 513807.866985,152833.790985 513803.295985,152841.590985 513798.778985,152861.106985 513792.783985,152881.771985 513783.860985,152889.672985 513781.216985,152894.045985 513780.183985,152911.753985 513777.044985,152924.313985 513773.178985,152938.498985 513764.447985,152941.841985 513761.432985,152945.914985 513756.742985,152948.841985 513750.352985,152950.467985 513745.487985,152951.187985 513740.696985,152949.197985 513726.637985,152944.856985 513711.713985,152938.590985 513697.248985,152932.892985 513679.260985,152932.052985 513669.392985,152932.301985 513664.167985,152931.064985 513655.751985,152930.540985 513640.871985,152928.716985 513629.667985,152928.469985 513624.260985,152929.623985 513618.961985,152936.827985 513594.240985,152925.855985 513592.298985,152912.444985 513589.295985,152892.923985 513586.002985,152884.722985 513585.253985,152873.280985 513582.877985,152865.965985 513582.437985,152861.459985 513582.424985,152855.123985 513582.942985,152846.852985 513582.590985,152842.379985 513582.092985,152823.641985 513578.893985,152820.885985 513578.940985,152812.601985 513580.109985,152802.841985 513582.175985,152789.868985 513585.914985,152777.216985 513587.422985,152765.958985 513589.763985,152750.899985 513591.610985,152742.030985 513593.139985,152729.904985 513596.497985,152719.099985 513598.801985,152715.833985 513600.302985,152709.204985 513604.531985,152705.819985 513607.458985,152704.964985 513608.634985,152703.307985 513612.868985,152703.112985 513614.477985,152703.547985 513619.000985,152706.348985 513625.244985,152709.568985 513633.649985,152711.881985 513642.244985,152712.847985 513647.448985,152711.808985 513652.345985,152708.137985 513655.059985,152704.382985 513656.694985,152698.688985 513658.421985,152692.786985 513659.189985,152681.958985 513659.969985,152674.629985 513659.687985,152661.943985 513657.891985,152655.571985 513657.466985,152649.688985 513657.947985,152642.863985 513657.559985,152626.064985 513657.514985,152613.920985 513660.400985,152600.982985 513666.190985,152597.955985 513667.872985,152594.342985 513670.518985,152593.520985 513671.490985,152588.828985 513680.433985,152585.901985 513686.823985,152583.628985 513692.792985,152581.790985 513698.405985,152581.080985 513702.833985,152581.877985 513705.678985,152584.660985 513710.396985,152589.111985 513713.700985,152592.947985 513716.057985,152598.515985 513718.920985,152602.238985 513721.449985,152606.006985 513724.926985,152607.497985 513725.822985,152629.149985 513736.282985,152634.862985 513738.251985,152644.738985 513740.211985,152650.242985 513741.654985,152654.804985 513742.227985,152659.856985 513743.707985,152664.473985 513745.695985,152668.657985 513748.192985,152675.140985 513751.447985,152680.210985 513753.398985,152686.638985 513755.238985,152695.915985 513759.948985,152707.390985 513764.833985,152716.642985 513767.925985,152723.560985 513770.672985,152731.786985 513774.899985,152737.193985 513778.352985,152746.398985 513785.838985,152754.987985 513796.492985,152757.040985 513801.273985,152757.627985 513806.000985,152756.984985 513813.706985,152755.505985 513821.538985,152752.715985 513831.219985,152746.744985 513843.680985,152735.140985 513857.735985,152731.651985 513863.630985,152729.550985 513867.824985,152727.840985 513872.403985,152725.525985 513876.860985,152725.078985 513881.527985,152733.081985 513886.294985,152737.828985 513891.584985,152743.443985 513895.856985,152749.473985 513899.149985,152760.195985 513906.316985,152778.305985 513916.664985,152782.507985 513919.632985,152790.819985 513923.211985,152794.352985 513925.072985,152817.785985 513939.459985,152822.336985 513942.969985,152833.310985 513952.333985,152840.480985 513959.124985,152843.334985 513962.648985,152845.629985 513966.518985,152848.522985 513974.605985,152852.091985 513987.549985,152853.072985 513992.664985,152852.731985 513997.167985,152851.866985 514000.228985,152845.740985 514015.720985,152841.492985 514023.165985,152838.001985 514026.762985,152835.133985 514029.112985,152831.380985 514031.563985,152825.534985 514032.987985,152804.881985 514042.418985,152800.333985 514043.552985,152795.944985 514042.505985,152778.924985 514036.800985,152772.912985 514033.979985,152769.227985 514032.625985,152765.542985 514031.270985,152760.435985 514028.375985,152750.277985 514024.001985,152741.910985 514019.008985,152724.617985 514010.196985,152714.925985 514002.288985,152703.547985 513989.970985,152694.149985 513980.780985,152690.812985 513977.762985,152679.079985 513968.842985,152671.575985 513961.828985,152663.594985 513953.465985,152656.937985 513947.411985,152652.772985 513945.386985,152646.215985 513940.244985,152632.252985 513931.449985,152611.390985 513920.380985,152604.472985 513917.634985,152601.112985 513916.755985,152595.709985 513915.766985,152583.472985 513914.620985,152579.510985 513917.783985,152574.246985 513922.472985,152565.980985 513931.665985,152557.589985 513944.756985,152554.632985 513949.932985,152545.321985 513972.156985,152541.526985 513979.564985,152540.007985 513981.605985,152536.733985 513984.688985,152535.315985 513985.408985,152530.905985 513986.584985,152525.946985 513987.463985,152513.202985 513986.612985,152499.250985 513983.503985,152489.827985 513980.953985,152480.251985 513979.844985,152468.426985 513980.337985,152456.720985 513981.769985,152450.800985 513981.307985,152443.107985 513981.936985,152431.715985 513982.252985,152425.601985 513983.102985,152415.362985 513985.867985,152401.539985 513988.792985,152397.098985 513989.485985,152382.988985 513990.080985,152378.507985 513990.059985,152367.405985 513987.636985,152353.905985 513987.813985,152328.397985 513985.641985,152326.159985 513984.727985,152343.155985 514009.776985,152345.547985 514013.575985,152348.450985 514020.382985,152350.886985 514024.172985,152354.067985 514027.864985,152361.872985 514039.241985,152375.524985 514057.714985,152380.879985 514063.460985,152384.223985 514066.497985,152391.301985 514072.064985,152399.165985 514075.815985,152403.841985 514078.756985,152407.937985 514080.620985,152417.977985 514083.085985,152422.390985 514083.220985,152424.943985 514082.052985,152442.772985 514066.832985,152446.324985 514064.070985,152455.412985 514057.977985,152463.242985 514053.204985,152467.279985 514051.239985,152474.609985 514049.455985,152479.056985 514048.777985,152484.181985 514049.837985,152499.921985 514056.864985,152512.577985 514064.400985,152520.205985 514069.166985,152529.937985 514073.130985,152544.200985 514082.842985,152556.472985 514093.900985,152571.160985 514108.272985,152579.390985 514115.870985,152590.270985 514129.477985,152593.414985 514136.321985,152600.252985 514153.416985,152602.311985 514157.738985,152606.845985 514165.536985,152612.066985 514172.868985,152614.883985 514176.092985,152621.659985 514182.048985,152625.286985 514184.242985,152630.331985 514185.979985,152634.803985 514186.432985,152640.693985 514186.427985,152649.669985 514185.718985,152657.684985 514183.778985,152668.022985 514182.579985,152704.755985 514175.352985,152719.865985 514170.892985,152729.749985 514169.166985,152738.749985 514165.436985,152742.867985 514164.085985,152747.244985 514163.075985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>MULTIPOLYGON(((152597.239547324 514029.678575879,152606.678441824 514038.183733586,152608.926208731 514040.294461888,152622.835937061 514053.904934079,152630.265885999 514060.764320717,152637.967903619 514069.033557604,152648.847903619 514082.640557604,152658.423790211 514098.16991668,152661.567790211 514105.01391668,152662.517340891 514107.225410577,152686.862372445 514102.435669934,152698.633931665 514098.961073367,152706.964296294 514097.011008656,152708.68782781 514096.710035831,152710.035074062 514096.151677107,152715.370621248 514094.174053889,152719.488621248 514092.823053889,152720.136823795 514092.642335451,152711.844861917 514088.406138982,152705.628187309 514084.696343796,152690.566315703 514077.021260665,152677.203554368 514068.307842573,152667.511554368 514060.399842573,152659.83253405 514053.178194686,152649.748363042 514042.260914102,152642.836939028 514035.502456272,152633.689321872 514028.54799066,152627.866066085 514023.634722601,152620.362066085 514016.620722601,152617.318280618 514013.60833914,152611.557280295 514007.571596163,152611.474695349 514007.519958978,152608.277829548 514013.760375802,152601.692834863 514024.342998692,152600.173834863 514026.383998692,152597.239547324 514029.678575879)),((152979.39142877 513923.39395504,152982.971243821 513924.314923876,152994.958013 513929.778636121,152998.988013 513932.062636121,153009.055554761 513938.9037135,153014.067370819 513942.940706199,153018.544937842 513946.098027423,153027.592891475 513953.605728244,153033.290382452 513959.142488765,153037.034018889 513962.259567283,153045.866385123 513970.944837472,153049.565287583 513975.238516501,153060.015813883 513971.857005287,153062.890625998 513969.019181735,153063.860375556 513967.889356612,153068.145995532 513962.327567309,153076.89462411 513952.801026421,153088.89962411 513941.804026421,153092.821268542 513938.452274418,153098.565268542 513933.875274418,153107.126126376 513927.97518657,153108.665998205 513927.06451688,153110.631601416 513922.727441177,153111.575413015 513919.842338661,153111.447332744 513919.460419607,153106.039801021 513913.647738603,153100.619179573 513907.061733153,153097.137580943 513903.737558055,153088.479580943 513894.664558055,153085.916584877 513891.838132528,153079.738127788 513884.666191141,153072.940822268 513881.346665919,153070.786713562 513879.875463282,153069.612655922 513880.479277041,153065.94505217 513882.241395211,153057.027815264 513886.231719169,153049.219187626 513890.892510631,153044.282261894 513893.593381728,153034.737621442 513898.358814385,153025.62057717 513903.951867582,153019.789678547 513907.181468601,153011.725678547 513911.190468601,153002.252391439 513915.117153387,152990.324366736 513919.129968399,152979.39142877 513923.39395504)),((152801.412882746 513735.377900866,152804.005720959 513733.876381609,152819.567849259 513727.08532076,152835.151968897 513722.298130904,152852.040751769 513715.005674598,152857.971202143 513712.737692505,152864.167594032 513710.664124582,152861.394377541 513701.909365326,152858.163243385 513685.62225202,152857.323243385 513675.75425202,152857.195936799 513668.928851093,152856.862228842 513666.658449992,152856.111445543 513658.391477922,152856.09040641 513657.794030773,152851.934996434 513657.875156675,152843.663996434 513657.523156675,152838.554159662 513657.130434274,152834.081159662 513656.632434274,152829.758404822 513656.023328661,152822.218943343 513654.736172226,152821.016752643 513654.990652348,152810.639563306 513657.981503418,152798.745454116 513660.38785453,152789.312251617 513661.51220399,152786.312745304 513662.135924391,152786.214807049 513663.015276221,152785.175807049 513667.912276221,152781.167293184 513680.88411889,152774.88583807 513692.920738318,152766.537291284 513703.627682429,152763.113476725 513706.674866787,152766.065546159 513708.191812751,152772.153957948 513711.689958145,152777.560957948 513715.142958145,152784.514842389 513720.165903479,152793.719842389 513727.651903479,152801.412882746 513735.377900866)))
+ #96 Polygon - gid: 2596
+ </desc>
+ <a>POLYGON((154470.187985 514355.480985,154486.830985 514323.594985,154500.001985 514288.890985,154498.444985 514263.472985,154497.741985 514239.518985,154493.223985 514222.771985,154489.801985 514204.219985,154488.879985 514182.090985,154478.186985 514157.249985,154474.040985 514134.114985,154467.747985 514111.146985,154466.497985 514095.633985,154470.929985 514076.999985,154488.837985 514040.402985,154492.458985 514010.825985,154489.681985 513972.417985,154476.127985 513929.415985,154462.300985 513907.359985,154442.174985 513901.882985,154433.051985 513885.013985,154426.097985 513857.073985,154434.970985 513823.089985,154437.859985 513804.326985,154431.686985 513785.260985,154412.115985 513791.727985,154392.134985 513804.951985,154371.213985 513800.320985,154338.806985 513824.583985,154337.552985 513838.841985,154340.231985 513863.853985,154341.818985 513883.430985,154325.354985 513942.782985,154308.149985 513990.662985,154286.061985 514032.755985,154276.691985 514036.801985,154273.287985 514053.119985,154278.102985 514068.611985,154281.466985 514088.671985,154268.460985 514110.359985,154256.186985 514135.862985,154255.695985 514155.176985,154260.846985 514174.967985,154273.610985 514186.731985,154296.316985 514203.897985,154304.090985 514222.423985,154304.305985 514232.504985,154274.433985 514236.105985,154245.243985 514243.659985,154199.558985 514250.286985,154168.633985 514270.372985,154143.684985 514291.596985,154128.476985 514317.331985,154126.062985 514342.110985,154129.235985 514339.245985,154157.746985 514338.714985,154195.964985 514348.920985,154238.413985 514354.748985,154265.909985 514362.594985,154277.321985 514360.996985,154291.054985 514356.469985,154316.729985 514343.357985,154339.936985 514337.091985,154355.837985 514336.573985,154383.710985 514341.477985,154410.238985 514348.604985,154426.380985 514358.909985,154440.500985 514366.676985,154453.903985 514366.741985,154470.187985 514355.480985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>POLYGON((154372.475003626 514263.349143873,154396.706937495 514267.612531514,154403.170413394 514269.046426639,154423.988413027 514274.639380627,154423.585300499 514268.058575085,154423.477262909 514265.673131474,154423.033047317 514250.536943284,154420.812790206 514242.307052659,154419.468203972 514236.376571173,154416.046203972 514217.824571173,154414.866998649 514207.342135003,154414.520949841 514199.036588282,154409.298243715 514186.90367489,154404.363076076 514170.479893208,154400.813488545 514150.672920818,154395.413932334 514130.965784784,154392.990283739 514117.170779661,154391.740283739 514101.657779661,154391.717630648 514089.898254615,154393.533403613 514078.279738746,154397.965403613 514059.645738746,154403.562880398 514044.035258131,154415.926643621 514018.768525795,154417.127981621 514008.955774066,154415.510664071 513986.587055149,154410.12603403 513969.503547621,154408.340036344 513968.817253125,154397.830595583 513962.092880346,154397.625941273 513962.830650185,154395.936468377 513968.14544159,154378.731468377 514016.02544159,154374.561855468 514025.512137945,154353.616308301 514065.427970836,154355.434134709 514076.267922606,154356.462902434 514089.454524599,154355.15919933 514102.616788591,154351.563572263 514115.345351006,154345.787849925 514127.244336955,154337.521882801 514141.02815173,154341.546834423 514144.071061954,154351.291906253 514152.880752292,154359.35032728 514163.255670093,154365.474862182 514174.877509063,154373.248862182 514193.403509063,154377.45396137 514206.839579392,154379.073933883 514220.824804957,154379.288933883 514230.905804957,154377.970664843 514246.594518123,154373.406257847 514261.662356151,154372.475003626 514263.349143873))
+ #97 Polygon - gid: 2597
+ </desc>
+ <a>POLYGON((144573.637985 514299.611985,144569.108985 514299.348985,144562.201985 514299.403985,144559.226985 514299.220985,144554.798985 514298.485985,144551.780985 514297.383985,144547.881985 514295.120985,144545.571985 514292.973985,144542.929985 514289.294985,144542.014985 514286.888985,144540.935985 514282.467985,144536.953985 514270.768985,144535.431985 514264.430985,144527.414985 514231.256985,144525.265985 514220.631985,144523.947985 514211.728985,144523.487985 514204.993985,144523.420985 514200.490985,144524.298985 514164.227985,144524.246985 514144.674985,144524.388985 514131.151985,144524.184985 514126.675985,144523.627985 514123.147985,144522.187985 514118.870985,144520.491985 514115.580985,144517.606985 514111.957985,144512.831985 514110.603985,144508.249985 514111.180985,144503.782985 514111.952985,144498.898985 514113.438985,144494.884985 514115.441985,144487.162985 514120.130985,144485.689985 514121.174985,144478.796985 514127.041985,144477.763985 514127.744985,144471.584985 514131.179985,144467.467985 514132.997985,144463.910985 514134.276985,144459.581985 514135.505985,144456.662985 514136.016985,144444.326985 514137.623985,144439.854985 514138.108985,144426.535985 514138.704985,144419.602985 514139.421985,144415.193985 514140.261985,144408.154985 514142.204985,144404.351985 514144.259985,144403.046985 514146.503985,144401.777985 514151.441985,144391.539985 514175.978985,144389.658985 514180.059985,144386.465985 514186.103985,144381.806985 514193.809985,144376.400985 514200.696985,144374.525985 514204.168985,144372.626985 514208.272985,144371.009985 514212.470985,144374.512985 514215.316985,144375.460985 514216.345985,144378.007985 514220.054985,144380.900985 514225.738985,144383.595985 514232.197985,144386.138985 514236.910985,144387.373985 514240.200985,144387.317985 514244.627985,144384.667985 514260.523985,144384.974985 514262.704985,144387.859985 514266.096985,144390.911985 514268.033985,144395.098985 514269.518985,144399.531985 514270.567985,144407.215985 514272.774985,144408.690985 514274.244985,144408.377985 514278.224985,144406.906985 514282.756985,144405.074985 514287.247985,144402.861985 514292.013985,144397.918985 514301.215985,144396.222985 514305.380985,144394.726985 514309.633985,144393.515985 514313.470985,144392.388985 514317.822985,144389.131985 514332.080985,144388.711985 514336.562985,144388.628985 514344.005985,144389.175985 514346.743985,144391.242985 514350.685985,144393.902985 514354.402985,144395.123985 514355.983985,144398.178985 514359.312985,144400.071985 514360.831985,144403.826985 514363.306985,144407.752985 514365.546985,144410.944985 514367.097985,144415.106985 514368.785985,144419.373985 514370.244985,144424.773985 514371.874985,144437.115985 514374.708985,144441.437985 514375.956985,144457.977985 514381.432985,144463.670985 514383.077985,144481.352985 514387.388985,144495.281985 514390.226985,144508.880985 514394.003985,144514.170985 514394.585985,144523.083985 514394.435985,144526.965985 514394.025985,144538.798985 514391.486985,144547.666985 514389.950985,144556.364985 514387.609985,144561.437985 514386.414985,144564.927985 514385.410985,144568.997985 514383.496985,144573.050985 514381.530985,144580.697985 514379.417985,144595.229985 514372.568985,144602.375985 514369.467985,144607.797985 514367.957985,144615.688985 514366.916985,144623.577985 514365.386985,144626.043985 514365.367285,144624.394985 514363.206985,144621.092985 514359.540985,144616.630985 514352.244985,144609.694985 514342.524985,144604.237985 514332.792985,144598.713985 514323.815985,144590.528985 514311.126985,144587.880985 514307.506985,144586.451985 514305.981985,144582.933985 514303.147985,144581.553985 514302.214985,144577.498985 514300.258985,144573.637985 514299.611985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>POLYGON( EMPTY)
+ </op></test></case><case><desc>
+ #98 Polygon - gid: 2598
+ </desc>
+ <a>POLYGON((146978.395985 514128.105985,146993.088985 514109.724985,146990.935985 514109.919985,146986.515985 514108.676985,146984.834985 514107.491985,146981.559985 514104.355985,146978.605985 514100.856985,146976.054985 514097.475985,146971.011985 514090.004985,146967.745985 514085.474985,146964.701985 514082.154985,146959.542985 514075.969985,146956.337985 514072.894985,146952.680985 514071.027985,146947.749985 514069.211985,146939.485985 514065.648985,146927.297985 514062.022985,146919.855985 514059.063985,146915.584985 514057.875985,146911.533985 514057.834985,146907.047985 514058.932985,146902.995985 514060.801985,146899.081985 514063.093985,146893.310985 514066.882985,146889.708985 514069.594985,146885.365985 514073.314985,146874.977985 514084.255985,146871.396985 514088.322985,146864.758985 514096.561985,146858.269985 514103.545985,146851.525985 514109.507985,146845.834985 514113.792985,146843.682985 514115.048985,146833.562985 514120.296985,146827.089985 514122.419985,146822.686985 514123.116985,146818.808985 514122.219985,146814.499985 514120.648985,146810.509985 514118.510985,146805.983985 514115.339985,146799.004985 514109.608985,146789.184985 514100.497985,146782.878985 514094.071985,146773.731985 514084.130985,146772.704985 514082.828985,146770.140985 514078.765985,146767.239985 514075.730985,146765.038985 514075.353985,146760.639985 514077.133985,146756.696985 514093.552985,146755.166985 514104.428985,146754.236985 514107.679985,146747.054985 514128.282985,146745.452985 514132.485985,146740.637985 514142.592985,146736.292985 514152.151985,146732.113985 514160.830985,146729.632985 514165.603985,146720.451985 514182.099985,146718.255985 514185.582985,146715.669985 514189.265985,146708.041985 514198.572985,146700.623985 514208.288985,146697.764985 514212.325985,146695.357985 514216.136985,146693.225985 514220.099985,146691.843985 514223.389985,146688.846985 514231.402985,146687.411985 514235.659985,146686.889985 514238.098985,146686.285985 514244.852985,146686.270985 514253.857985,146686.450985 514255.277985,146686.301985 514260.300985,146683.033985 514264.144985,146683.155985 514265.983985,146682.338985 514271.113985,146682.374985 514276.109985,146680.337985 514280.147985,146677.579985 514283.544985,146668.796985 514293.186985,146665.431985 514297.393985,146661.798985 514300.600985,146659.382985 514304.403985,146657.401985 514310.058985,146656.451985 514315.110985,146657.862985 514320.479985,146660.328985 514325.311985,146664.346985 514327.493985,146671.146985 514330.078985,146674.727985 514332.813985,146678.721985 514337.242985,146681.490985 514340.795985,146686.032985 514347.673985,146690.888985 514355.863985,146692.808985 514359.916985,146693.698985 514363.305985,146695.616985 514373.416985,146698.231985 514382.035985,146699.836985 514386.527985,146701.571985 514390.707985,146703.974985 514394.998985,146706.750985 514398.590985,146710.002985 514401.691985,146712.889985 514403.299985,146717.072985 514405.089985,146726.061985 514410.373985,146734.615985 514414.500985,146745.317985 514418.731985,146749.574985 514420.166985,146751.177985 514420.590985,146755.638985 514421.241985,146756.964985 514414.062985,146760.786985 514395.658985,146762.453985 514390.190985,146763.644985 514384.449985,146765.274985 514379.265985,146767.350985 514375.290985,146772.077985 514367.066985,146782.052985 514344.326985,146787.377985 514332.973985,146796.553985 514316.678985,146800.956985 514309.903985,146805.131985 514302.406985,146810.612985 514294.080985,146815.038985 514286.445985,146817.815985 514282.583985,146823.033985 514277.958985,146826.565985 514274.275985,146829.279985 514270.683985,146831.879985 514268.007985,146838.691985 514261.283985,146846.154985 514255.376985,146849.511985 514252.379985,146854.426985 514246.995985,146866.975985 514234.461985,146873.174985 514227.718985,146875.892985 514224.130985,146883.032985 514216.049985,146888.426985 514211.137985,146895.661985 514205.813985,146898.228985 514203.079985,146900.862985 514199.416985,146903.718985 514196.294985,146910.227985 514189.724985,146918.475985 514180.160985,146921.638985 514177.199985,146925.123985 514174.344985,146929.916985 514170.920985,146942.656985 514162.441985,146948.828985 514158.846985,146952.598985 514156.414985,146955.585985 514153.824985,146964.483985 514144.873985,146967.826985 514140.249985,146969.666985 514137.975985,146978.395985 514128.105985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>POLYGON((146797.091534784 514198.560801946,146799.036341277 514196.430417783,146800.519647422 514194.878956067,146799.137713142 514194.468888446,146798.660722856 514195.421904049,146796.985503573 514198.644726154,146797.091534784 514198.560801946))
+ #99 Polygon - gid: 2599
+ </desc>
+ <a>POLYGON((144130.790985 514542.589985,144136.106985 514541.268985,144140.618985 514541.819985,144146.580985 514542.271985,144155.308985 514545.689985,144159.779985 514546.073985,144165.774985 514546.027985,144170.614985 514545.336985,144174.457985 514542.248985,144180.591985 514535.602985,144185.031985 514531.945985,144188.930985 514529.699985,144202.240985 514526.170985,144204.522985 514525.434985,144208.647985 514523.675985,144209.506985 514523.064985,144212.582985 514519.733985,144214.710985 514516.736985,144217.305985 514512.269985,144225.821985 514492.742985,144230.222985 514479.998985,144238.048985 514458.756985,144239.749985 514453.779985,144242.237985 514445.130985,144246.840985 514428.052985,144247.696985 514425.401985,144249.538985 514420.578985,144253.385985 514411.927985,144260.058985 514394.218985,144264.745985 514384.187985,144266.213985 514379.927985,144267.402985 514375.585985,144266.909985 514372.870985,144264.565985 514368.375985,144255.527985 514363.949985,144249.852985 514362.074985,144245.934985 514359.844985,144246.620985 514355.223985,144248.164985 514351.697985,144250.544985 514347.859985,144251.479985 514346.801985,144258.417985 514340.953985,144264.816985 514336.013985,144266.807985 514330.309985,144266.470985 514325.834985,144264.754985 514315.479985,144263.754985 514311.093985,144261.914985 514304.532985,144260.268985 514300.367985,144258.258985 514296.998985,144255.314985 514293.564985,144253.224985 514291.582985,144249.714985 514288.669985,144245.918985 514286.308985,144244.887985 514285.843985,144240.548985 514284.624985,144234.199985 514283.756985,144225.189985 514283.542985,144216.921985 514283.099985,144200.074985 514283.128985,144195.587985 514283.291985,144186.779985 514284.886985,144177.834985 514285.878985,144169.973985 514286.948985,144165.504985 514287.444985,144158.597985 514287.500985,144150.714985 514288.363985,144146.268985 514289.065985,144138.749985 514290.519985,144129.998985 514292.618985,144122.836985 514294.931985,144118.663985 514296.619985,144116.254985 514315.702985,144113.154985 514338.329985,144110.932985 514350.449985,144109.642985 514359.358985,144103.633985 514384.235985,144100.698985 514392.568985,144099.732985 514399.419985,144098.307985 514417.516985,144097.345985 514425.834985,144096.877985 514434.147985,144095.446985 514450.289985,144095.470985 514467.498985,144095.977985 514472.854985,144095.698985 514478.235985,144090.849985 514512.499985,144086.867985 514532.967985,144086.837985 514540.297985,144083.986985 514558.486985,144082.564985 514573.165985,144082.617985 514579.549985,144083.019985 514582.853985,144084.070985 514587.218985,144088.382985 514601.055985,144090.700985 514599.014985,144094.407985 514596.448985,144099.296985 514594.867985,144103.775985 514594.417985,144104.772985 514593.932985,144108.205985 514590.960985,144109.332985 514588.480985,144110.651985 514584.097985,144115.058985 514573.308985,144115.953985 514570.340985,144117.115985 514565.480985,144117.981985 514561.064985,144120.043985 514555.351985,144121.899985 514551.257985,144123.475985 514548.300985,144126.738985 514544.570985,144130.790985 514542.589985))</a>
+ <test><op name='buffer' arg1='A' arg2='-75'>POLYGON((144176.60740853 514401.555584319,144177.632982782 514398.643143597,144179.373625931 514394.085531269,144178.682298521 514392.965629534,144176.60740853 514401.555584319))
+ #100 Polygon - gid: 2600
+ </desc>
+ <a>POLYGON((153556.031985 514886.227985,153560.525985 514886.012985,153566.393985 514886.836985,153572.264985 514888.653985,153582.160985 514890.869985,153584.416985 514890.833985,153588.654985 514889.150985,153590.995985 514887.355985,153594.093985 514881.247985,153600.596985 514871.470985,153607.108985 514856.972985,153612.956985 514847.521985,153608.356985 514841.430985,153606.284985 514837.439985,153605.664985 514834.687985,153605.359985 514830.122985,153602.267985 514813.476985,153597.582985 514800.609985,153596.965985 514795.730985,153594.556985 514792.788985,153590.938985 514790.044985,153579.228985 514795.635985,153573.643985 514797.721985,153559.445985 514799.291985,153546.944985 514802.898985,153541.754985 514805.976985,153537.104985 514807.634985,153532.352985 514810.440985,153520.030985 514819.197985,153514.515985 514821.769985,153510.278985 514822.486985,153507.876985 514821.350985,153504.524985 514817.626985,153501.188985 514808.128985,153492.871985 514787.013985,153489.388985 514780.831985,153486.307985 514777.186985,153482.664985 514774.839985,153479.481985 514774.368985,153474.831985 514774.926985,153469.574985 514776.303985,153466.025985 514779.167985,153457.313985 514787.843985,153455.681985 514790.459985,153452.692985 514795.895985,153448.357985 514807.237985,153450.054985 514811.435985,153451.618985 514813.811985,153455.073985 514816.927985,153474.460985 514819.993985,153483.496985 514823.991985,153487.335985 514827.674985,153490.999985 514832.613985,153492.523985 514837.561985,153493.082985 514843.424985,153490.543985 514855.424985,153490.223985 514860.751985,153488.498985 514874.433985,153495.036985 514879.182985,153501.180985 514882.939985,153516.063985 514894.582985,153519.796985 514897.079985,153525.665985 514899.415985,153529.748985 514901.565985,153534.832985 514900.527985,153538.446985 514898.728985,153542.061985 514896.077985,153549.964985 514888.768985,153554.033985 514886.791985,153556.031985 514886.227985))</a>
+ </op></test></case></run>
\ No newline at end of file
Modified: trunk/tests/xmltester/XMLTester.cpp
--- trunk/tests/xmltester/XMLTester.cpp 2009-04-14 09:22:22 UTC (rev 2351)
+++ trunk/tests/xmltester/XMLTester.cpp 2009-04-14 09:53:59 UTC (rev 2352)
@@ -703,10 +703,10 @@
profile.start();
GeomAutoPtr gRealRes;
- double dist = std::atof(opArg3.c_str());
+ double dist = std::atof(opArg2.c_str());
- if ( opArg2 != "" ) {
- gRealRes.reset(gT->buffer(dist, std::atoi(opArg2.c_str())));
+ if ( opArg3 != "" ) {
+ gRealRes.reset(gT->buffer(dist, std::atoi(opArg3.c_str())));
} else {
gRealRes.reset(gT->buffer(dist));
Modified: trunk/tests/xmltester/badguy3.xml
--- trunk/tests/xmltester/badguy3.xml 2009-04-14 09:22:22 UTC (rev 2351)
+++ trunk/tests/xmltester/badguy3.xml 2009-04-14 09:53:59 UTC (rev 2352)
@@ -30,8 +30,8 @@
<test>
- <!--op name="buffer" arg1="a" arg3="0.000000001"-->
- <op name="buffer" arg1="a" arg3="0">
+ <!--op name="buffer" arg1="a" arg2="0.000000001"-->
+ <op name="buffer" arg1="a" arg2="0">
MULTIPOLYGON(((
3135840 10098400,
3135702 10098200,
Modified: trunk/tests/xmltester/buffer.xml
--- trunk/tests/xmltester/buffer.xml 2009-04-14 09:22:22 UTC (rev 2351)
+++ trunk/tests/xmltester/buffer.xml 2009-04-14 09:53:59 UTC (rev 2352)
@@ -6,7 +6,7 @@
POINT (100 100)
</a>
<test>
-<op name="buffer" arg1="a" arg3=" 30">
+<op name="buffer" arg1="a" arg2=" 30">
POLYGON ((70.0000000000000000 99.9999999999999005, 70.5764415879030622 105.8527096604837396, 72.2836140246613610 111.4805029709525854, 75.0559116309235748 116.6671069905879676, 78.7867965644034882 121.2132034355963413, 83.3328930094118192 124.9440883690762831, 88.5194970290471872 127.7163859753385537, 94.1472903395160330 129.4235584120968952, 99.9999999999998863 130.0000000000000000, 105.8527096604837396 129.4235584120969236, 111.4805029709525996 127.7163859753386390, 116.6671069905879961 124.9440883690764110, 121.2132034355963697 121.2132034355964834, 124.9440883690763116 116.6671069905881382, 127.7163859753385680 111.4805029709527560, 129.4235584120968952 105.8527096604839102, 130.0000000000000000 100.0000000000000000, 129.4235584120969236 94.1472903395161609, 127.7163859753386106 88.5194970290473151, 124.9440883690763684 83.3328930094119471, 121.2132034355964407 78.7867965644035877, 116.6671069905880955 75.0559116309236600, 111.4805029709527275 72.2836140246614036, 105.8527096604838817 70.5764415879030906, 100.0000000000000426 70.0000000000000000, 94.1472903395162035 70.5764415879030764, 88.5194970290473577 72.2836140246613752, 83.3328930094119897 75.0559116309236032, 78.7867965644036303 78.7867965644035309, 75.0559116309236884 83.3328930094118761, 72.2836140246614320 88.5194970290472298, 70.5764415879031048 94.1472903395160614, 70.0000000000000000 99.9999999999999005))
</op>
</test>
@@ -16,7 +16,7 @@
LINESTRING (10 10, 100 100)
</a>
<test>
-<op name="buffer" arg1="a" arg3=" 20">
+<op name="buffer" arg1="a" arg2=" 20">
POLYGON ((-10.0000000000000000 9.9999999999999805, -9.6157056080646157 13.9018064403225328, -8.4775906502257463 17.6536686473017674, -6.6293922460509283 21.1114046603920080, -4.1421356237309501 24.1421356237309510, 85.8578643762690490 114.1421356237309510, 85.8578643762690774 114.1421356237309794, 88.8885953396079884 116.6293922460509265, 92.3463313526982290 118.4775906502257499, 96.0981935596774548 119.6157056080646157, 100.0000000000000142 120.0000000000000000, 103.9018064403225736 119.6157056080646015, 107.6536686473017994 118.4775906502257357, 111.1114046603920542 116.6293922460508981, 114.1421356237309510 114.1421356237309510, 116.6293922460508981 111.1114046603920542, 118.4775906502257357 107.6536686473017994, 119.6157056080646015 103.9018064403225736, 120.0000000000000000 100.0000000000000142, 119.6157056080646157 96.0981935596774548, 118.4775906502257499 92.3463313526982290, 116.6293922460509265 88.8885953396079884, 114.1421356237309510 85.8578643762690490, 24.1421356237309510 -4.1421356237309501, 24.1421356237309297 -4.1421356237309723, 21.1114046603920222 -6.6293922460509194, 17.6536686473017745 -8.4775906502257428, 13.9018064403225488 -9.6157056080646122, 9.9999999999999876 -10.0000000000000000, 6.0981935596774273 -9.6157056080646068, 2.3463313526982019 -8.4775906502257339, -1.1114046603920393 -6.6293922460509078, -4.1421356237309492 -4.1421356237309519, -6.6293922460508963 -1.1114046603920573, -8.4775906502257303 2.3463313526981944, -9.6157056080646051 6.0981935596774104, -10.0000000000000000 9.9999999999999805))
</op>
</test>
@@ -26,7 +26,7 @@
LINESTRING (100 100, 200 100, 200 200, 100 200, 100 100)
</a>
<test>
-<op name="buffer" arg1="a" arg3=" 10">
+<op name="buffer" arg1="a" arg2=" 10">
POLYGON ((0.6250000000000000 0.6944444444444445, 0.6250000000000000 1.3888888888888891, 0.6261574074074074 1.4021990740740742, 0.6302083333333334 1.4155092592592593, 0.6365740740740741 1.4276620370370372, 0.6452546296296297 1.4380787037037039, 0.6556712962962964 1.4467592592592593, 0.6678240740740741 1.4531250000000000, 0.6811342592592592 1.4571759259259258, 0.6944444444444445 1.4583333333333333, 1.3888888888888891 1.4583333333333333, 1.4021990740740742 1.4571759259259258, 1.4155092592592593 1.4531250000000000, 1.4276620370370372 1.4467592592592593, 1.4380787037037039 1.4380787037037039, 1.4467592592592593 1.4276620370370372, 1.4531250000000000 1.4155092592592593, 1.4571759259259258 1.4021990740740742, 1.4583333333333333 1.3888888888888891, 1.4583333333333333 0.6944444444444445, 1.4571759259259258 0.6811342592592592, 1.4531250000000000 0.6678240740740741, 1.4467592592592593 0.6556712962962964, 1.4380787037037039 0.6452546296296297, 1.4276620370370372 0.6365740740740741, 1.4155092592592593 0.6302083333333334, 1.4021990740740742 0.6261574074074074, 1.3888888888888891 0.6250000000000000, 0.6944444444444445 0.6250000000000000, 0.6811342592592592 0.6261574074074074, 0.6678240740740741 0.6302083333333334, 0.6556712962962964 0.6365740740740741, 0.6452546296296297 0.6452546296296297, 0.6365740740740741 0.6556712962962964, 0.6302083333333334 0.6678240740740741, 0.6261574074074074 0.6811342592592592, 0.6250000000000000 0.6944444444444445), (0.7638888888888888 0.7638888888888888, 1.3194444444444444 0.7638888888888888, 1.3194444444444444 1.3194444444444444, 0.7638888888888888 1.3194444444444444, 0.7638888888888888 0.7638888888888888))
</op>
</test>
@@ -36,7 +36,7 @@
LINESTRING (40 40, 160 40, 100 180, 40 80)
</a>
<test>
-<op name="buffer" arg1="a" arg3=" 50">
+<op name="buffer" arg1="a" arg2=" 50">
POLYGON ((-10.0000000000000000 40.0000000000000071, -9.0392640201615233 49.7545161008064056, -6.1939766255643445 59.1341716182544701, -5.7089632597009334 60.0415678037439804, -8.5071250072665823 67.8732187481833051, -9.9408918612425712 77.5695020872925056, -9.4554582481658347 87.3591880981481808, -7.0694791095526091 96.8660646374722063, -2.8746462856272093 105.7247877713763273, 57.1253537143727925 205.7247877713763273, 63.0793179783294420 213.7174026142983507, 70.5002381509231526 220.3703362736521001, 79.0932615344621155 225.4192501780203202, 88.5169646845435523 228.6635376842249343, 98.3969190624655141 229.9742947074564938, 108.3405680669374220 229.2994414199672519, 117.9528243414483342 226.6657915197535260, 126.8517676352035579 222.1779868517338627, 134.6838195002822829 216.0143397117292352, 141.1377918943432235 208.4197480294549791, 145.9572515009028848 199.6959649289583751, 205.9572515009028848 59.6959649289583822, 205.9572515009028848 59.6959649289583894, 208.9292730958345885 50.2920471390894264, 209.9976214261368739 40.4877004497635937, 209.1207306555521086 30.6643789780913245, 206.3327176513530503 21.2042750860734870, 201.7420546119134031 12.4754495626896720, 195.5273487787097508 4.8175116179098252, 187.9303934299507546 -1.4715941681551830, 179.2467605182728221 -6.1471798656456880, 169.8143009612940659 -9.0273341784064609, 160.0000000000000000 -10.0000000000000000, 40.0000000000000000 -10.0000000000000000, 39.9999999999999005 -10.0000000000000000, 30.2454838991935233 -9.0392640201615091, 20.8658283817454411 -6.1939766255643089, 12.2214883490198183 -1.5734806151272143, 4.6446609406725869 4.6446609406726607, -1.5734806151272844 12.2214883490199231, -6.1939766255643489 20.8658283817455370, -9.0392640201615251 30.2454838991936050, -10.0000000000000000 40.0000000000000071))
</op>
</test>
@@ -46,7 +46,7 @@
POLYGON ((80 300, 280 300, 280 80, 80 80, 80 300))
</a>
<test>
POLYGON ((70.0000000000000000 80.0000000000000000, 70.0000000000000000 300.0000000000000000, 70.1921471959676921 301.9509032201613081, 70.7612046748871393 303.8268343236508713, 71.6853038769745439 305.5557023301960271, 72.9289321881345245 307.0710678118654755, 74.4442976698039871 308.3146961230254419, 76.1731656763491003 309.2387953251128465, 78.0490967798387203 309.8078528040322794, 80.0000000000000000 310.0000000000000000, 280.0000000000000000 310.0000000000000000, 281.9509032201613081 309.8078528040322794, 283.8268343236508713 309.2387953251128465, 285.5557023301960271 308.3146961230254419, 287.0710678118654755 307.0710678118654755, 288.3146961230254419 305.5557023301960271, 289.2387953251128465 303.8268343236508713, 289.8078528040322794 301.9509032201613081, 290.0000000000000000 300.0000000000000000, 290.0000000000000000 80.0000000000000000, 289.8078528040322794 78.0490967798387203, 289.2387953251128465 76.1731656763491003, 288.3146961230254419 74.4442976698039729, 287.0710678118654755 72.9289321881345245, 285.5557023301960271 71.6853038769745439, 283.8268343236508713 70.7612046748871393, 281.9509032201613081 70.1921471959676921, 280.0000000000000000 70.0000000000000000, 80.0000000000000000 70.0000000000000000, 79.9999999982041317 70.0000000000000000, 78.0490967782975389 70.1921471962742629, 76.1731656751047410 70.7612046754025670, 74.4442976688707176 71.6853038775981304, 72.9289321874995977 72.9289321887694655, 71.6853038766004005 74.4442976703639232, 70.7612046747153158 76.1731656767638867, 70.1921471959238943 78.0490967800588891, 70.0000000000000000 80.0000000000000000))
</op>
</test>
@@ -56,7 +56,7 @@
POLYGON ((60 300, 60 160, 240 160, 240 300, 60 300))
</a>
<test>
POLYGON ((50.0000000000000000 159.9999999982041459, 50.0000000000000000 160.0000000000000000, 50.0000000000000000 300.0000000000000000, 50.1921471959676992 301.9509032201613081, 50.7612046748871322 303.8268343236508713, 51.6853038769745439 305.5557023301960271, 52.9289321881345245 307.0710678118654755, 54.4442976698039800 308.3146961230254419, 56.1731656763491003 309.2387953251128465, 58.0490967798387203 309.8078528040322794, 60.0000000000000000 310.0000000000000000, 240.0000000000000000 310.0000000000000000, 241.9509032201612797 309.8078528040322794, 243.8268343236508997 309.2387953251128465, 245.5557023301960271 308.3146961230254419, 247.0710678118654755 307.0710678118654755, 248.3146961230254419 305.5557023301960271, 249.2387953251128749 303.8268343236508713, 249.8078528040323079 301.9509032201613081, 250.0000000000000000 300.0000000000000000, 250.0000000000000000 160.0000000000000000, 249.8078528040323079 158.0490967798387203, 249.2387953251128749 156.1731656763491003, 248.3146961230254419 154.4442976698039729, 247.0710678118654755 152.9289321881345245, 245.5557023301960271 151.6853038769745581, 243.8268343236508997 150.7612046748871251, 241.9509032201612797 150.1921471959676921, 240.0000000000000000 150.0000000000000000, 60.0000000000000000 150.0000000000000000, 58.0490967800588891 150.1921471959238943, 56.1731656767638938 150.7612046747153158, 54.4442976703639303 151.6853038766004147, 52.9289321887694584 152.9289321874995835, 51.6853038775981304 154.4442976688707176, 50.7612046754025670 156.1731656751047410, 50.1921471962742558 158.0490967782975247, 50.0000000000000000 159.9999999982041459))
</op>
</test>
@@ -66,7 +66,7 @@
POLYGON ((80 300, 280 300, 280 80, 80 80, 80 300), (260 280, 180 200, 100 280, 100 100, 260 100, 260 280))
</a>
<test>
POLYGON ((70.0000000000000000 80.0000000000000000, 70.0000000000000000 300.0000000000000000, 70.1921471959676921 301.9509032201613081, 70.7612046748871393 303.8268343236508713, 71.6853038769745439 305.5557023301960271, 72.9289321881345245 307.0710678118654755, 74.4442976698039871 308.3146961230254419, 76.1731656763491003 309.2387953251128465, 78.0490967798387203 309.8078528040322794, 80.0000000000000000 310.0000000000000000, 280.0000000000000000 310.0000000000000000, 281.9509032201613081 309.8078528040322794, 283.8268343236508713 309.2387953251128465, 285.5557023301960271 308.3146961230254419, 287.0710678118654755 307.0710678118654755, 288.3146961230254419 305.5557023301960271, 289.2387953251128465 303.8268343236508713, 289.8078528040322794 301.9509032201613081, 290.0000000000000000 300.0000000000000000, 290.0000000000000000 80.0000000000000000, 289.8078528040322794 78.0490967798387203, 289.2387953251128465 76.1731656763491003, 288.3146961230254419 74.4442976698039729, 287.0710678118654755 72.9289321881345245, 285.5557023301960271 71.6853038769745439, 283.8268343236508713 70.7612046748871393, 281.9509032201613081 70.1921471959676921, 280.0000000000000000 70.0000000000000000, 80.0000000000000000 70.0000000000000000, 79.9999999982041317 70.0000000000000000, 78.0490967782975389 70.1921471962742629, 76.1731656751047410 70.7612046754025670, 74.4442976688707176 71.6853038775981304, 72.9289321874995977 72.9289321887694655, 71.6853038766004005 74.4442976703639232, 70.7612046747153158 76.1731656767638867, 70.1921471959238943 78.0490967800588891, 70.0000000000000000 80.0000000000000000), (110.0000000000000000 110.0000000000000000, 250.0000000000000000 110.0000000000000000, 250.0000000000000000 255.8578643762690490, 187.0710678118654755 192.9289321881345245, 185.5557023301960271 191.6853038769745581, 183.8268343236508997 190.7612046748871251, 181.9509032201612797 190.1921471959676921, 180.0000000000000000 190.0000000000000000, 178.0490967798387203 190.1921471959676921, 176.1731656763491003 190.7612046748871251, 174.4442976698039729 191.6853038769745581, 172.9289321881345245 192.9289321881345245, 110.0000000000000000 255.8578643762690490, 110.0000000000000000 110.0000000000000000))
</op>
</test>
@@ -76,7 +76,7 @@
</a>
<test>
-<op name="buffer" arg1="a" arg3=" 200">
+<op name="buffer" arg1="a" arg2=" 200">
POLYGON ((-120.0000000000000000 80.0000000000000000, -120.0000000000000000 300.0000000000000000, -116.1570560806460719 339.0180644032257078, -104.7759065022573424 376.5366864730179941, -86.2939224605090658 411.1140466039204284, -61.4213562373094888 441.4213562373095101, -31.1140466039203929 466.2939224605090658, 3.4633135269820596 484.7759065022573850, 40.9819355967743633 496.1570560806461003, 80.0000000000000000 500.0000000000000000, 280.0000000000000000 500.0000000000000000, 319.0180644032256509 496.1570560806461003, 356.5366864730179373 484.7759065022573282, 391.1140466039204284 466.2939224605090658, 421.4213562373095101 441.4213562373095101, 446.2939224605090658 411.1140466039204284, 464.7759065022573282 376.5366864730179373, 476.1570560806461003 339.0180644032256509, 480.0000000000000000 300.0000000000000000, 480.0000000000000000 80.0000000000000000, 476.1570560806461003 40.9819355967743491, 464.7759065022573282 3.4633135269820485, 446.2939224605090658 -31.1140466039204426, 421.4213562373095101 -61.4213562373095030, 391.1140466039204284 -86.2939224605090374, 356.5366864730179373 -104.7759065022573424, 319.0180644032256509 -116.1570560806460861, 280.0000000000000000 -120.0000000000000000, 80.0000000000000000 -120.0000000000000000, 79.9999999640827326 -120.0000000000000000, 40.9819355659506570 -116.1570560745148697, 3.4633135020947048 -104.7759064919486747, -31.1140466225855583 -86.2939224480374207, -61.4213562500081807 -61.4213562246108253, -86.2939224679919903 -31.1140465927214258, -104.7759065056935981 3.4633135352778681, -116.1570560815219864 40.9819356011778027, -120.0000000000000000 80.0000000000000000))
</op>
</test>
@@ -86,7 +86,7 @@
</a>
<test>
-<op name="buffer" arg1="a" arg3=" -10">
+<op name="buffer" arg1="a" arg2=" -10">
POLYGON ((90.0000000000000000 90.0000000000000000, 90.0000000000000000 290.0000000000000000, 270.0000000000000000 290.0000000000000000, 270.0000000000000000 90.0000000000000000, 90.0000000000000000 90.0000000000000000))
</op>
</test>
@@ -96,7 +96,7 @@
POLYGON ((100 300, 300 300, 300 100, 100 100, 100 300), (220 220, 180 220, 180 180, 220 180, 220 220))
</a>
<test>
POLYGON ((90.0000000000000000 100.0000000000000000, 90.0000000000000000 300.0000000000000000, 90.1921471959676921 301.9509032201613081, 90.7612046748871393 303.8268343236508713, 91.6853038769745439 305.5557023301960271, 92.9289321881345245 307.0710678118654755, 94.4442976698039871 308.3146961230254419, 96.1731656763491003 309.2387953251128465, 98.0490967798387203 309.8078528040322794, 100.0000000000000000 310.0000000000000000, 300.0000000000000000 310.0000000000000000, 301.9509032201613081 309.8078528040322794, 303.8268343236508713 309.2387953251128465, 305.5557023301960271 308.3146961230254419, 307.0710678118654755 307.0710678118654755, 308.3146961230254419 305.5557023301960271, 309.2387953251128465 303.8268343236508713, 309.8078528040322794 301.9509032201613081, 310.0000000000000000 300.0000000000000000, 310.0000000000000000 100.0000000000000000, 309.8078528040322794 98.0490967798387203, 309.2387953251128465 96.1731656763491003, 308.3146961230254419 94.4442976698039729, 307.0710678118654755 92.9289321881345245, 305.5557023301960271 91.6853038769745439, 303.8268343236508713 90.7612046748871393, 301.9509032201613081 90.1921471959676921, 300.0000000000000000 90.0000000000000000, 100.0000000000000000 90.0000000000000000, 99.9999999982041317 90.0000000000000000, 98.0490967782975389 90.1921471962742629, 96.1731656751047410 90.7612046754025670, 94.4442976688707176 91.6853038775981304, 92.9289321874995977 92.9289321887694655, 91.6853038766004005 94.4442976703639232, 90.7612046747153158 96.1731656767638867, 90.1921471959238943 98.0490967800588891, 90.0000000000000000 100.0000000000000000), (190.0000000000000000 190.0000000000000000, 210.0000000000000000 190.0000000000000000, 210.0000000000000000 210.0000000000000000, 190.0000000000000000 210.0000000000000000, 190.0000000000000000 190.0000000000000000))
</op>
</test>
@@ -106,7 +106,7 @@
GEOMETRYCOLLECTION (POINT (100 100), POLYGON ((400 260, 280 380, 240 220, 120 300, 120 100, 260 40, 200 160, 400 260)), LINESTRING (260 400, 220 280, 120 400, 20 280, 160 160, 60 40, 160 20, 360 140))
</a>
<test>
POLYGON ((0.0700425798558265 278.3276372309692306, 0.1228569041891950 282.2134096658008957, 0.9261335993623063 286.0156147259132808, 2.4495449200752391 289.5906999998719016, 4.6355744080524834 292.8036879932895999, 104.6355744080524772 412.8036879932895999, 107.4027140469530792 415.5341039850120524, 110.6457864955514481 417.6776324691173841, 114.2422665854686130 419.1532896894290161, 118.0562772015389754 419.9053244556008622, 121.9437227984610246 419.9053244556008622, 125.7577334145313870 419.1532896894290161, 129.3542135044485519 417.6776324691173841, 132.5972859530469066 415.5341039850120524, 135.3644255919475086 412.8036879932895999, 212.3798679762521431 320.3851571321240499, 241.0263340389897166 406.3245553203367422, 241.0263340389897451 406.3245553203367990, 242.6247672442066516 409.9046093654421838, 244.8909209000858880 413.1040348272026108, 247.7377079925056762 415.7998795793810132, 251.0557280900008550 417.8885438199983469, 254.7174715409918520 419.2897613536241010, 258.5822195981864411 419.9496841762528447, 262.5014521611223017 419.8429518239000231, 266.3245553203367422 418.9736659610102834, 269.9046093654421838 417.3752327557933768, 273.1040348272025540 415.1090790999141404, 275.7998795793809563 412.2622920074943522, 277.8885438199982900 408.9442719099992019, 279.2897613536240442 405.2825284590081765, 279.9496841762528447 401.4177804018136158, 279.9100410175586262 399.9620759689305487, 280.3536479122308833 399.9968730844143465, 284.1616087256720107 399.5622343512802672, 287.8167399063642620 398.4091981692916988, 291.1848115464001125 396.5801082828645576, 294.1421356237309510 394.1421356237309510, 414.1421356237309510 274.1421356237309510, 416.5501405931683507 271.2291071036998460, 418.3671308115406759 267.9150809062039116, 419.5282205447628598 264.3184027550822748, 419.9919466308888332 260.5675120330809023, 419.7417491527499465 256.7963551398606228, 418.7865628018326447 253.1396021913596144, 417.1604978154628043 249.7278378748436296, 414.9216218812061925 246.6828981968932624, 412.1498865073597813 244.1135196516573842, 408.9442719099991450 242.1114561800016816, 226.8328157299974634 151.0557280900008550, 252.8452122963902013 99.0309349572153366, 349.7100848914494691 157.1498585142508944, 353.2535741450111004 158.8277916438210298, 357.0563247607407220 159.7821832992663360, 360.9721991650829978 159.9763567444970249, 364.8507125007266723 159.4028500029066322, 368.5428156752783480 158.0837026169481874, 371.9066232342952958 156.0696086808776784, 374.8128659397295337 153.4379686951414214, 377.1498585142508659 150.2899151085505309, 378.8277916438210013 146.7464258549889280, 379.7821832992663076 142.9436752392593064, 379.9763567444970249 139.0278008349170591, 379.4028500029066322 135.1492874992733562, 378.0837026169481874 131.4571843247216805, 376.0696086808777068 128.0933767657047042, 373.4379686951414214 125.1871340602704805, 370.2899151085505309 122.8501414857491199, 270.7866027420680552 63.1481540658596430, 277.8885438199982900 48.9442719099991592, 279.3258977375772929 45.1487548627513107, 279.9674142813494768 41.1412129148242087, 279.7866759027806438 37.0866760018289554, 278.7911253793552078 33.1521093045119386, 277.0217593221912011 29.4995376493510548, 274.5514399421601865 26.2793733521494808, 271.4818945957121059 23.6242222629593108, 267.9395266686285595 21.6434230784131323, 264.0702103048396339 20.4185447917071947, 260.0332833325381898 20.0000276945247961, 255.9949857579331365 20.4051062539027406, 252.1216140284166443 21.6170993996388425, 222.6321098525542084 34.2554583321513206, 170.2899151085505309 2.8501414857491163, 170.2899151085505309 2.8501414857491159, 166.9699144252653014 1.2537925727767922, 163.4134465985324027 0.2934431642925626, 159.7411713289505428 0.0016748771542679, 156.0776772972363062 0.3883864861815968, 56.0776772972363204 20.3883864861815951, 56.0776772972361996 20.3883864861816200, 52.4812515061284230 21.4670989565609567, 49.1498221084192508 23.1989988476563624, 46.2008044925838703 25.5230457848307566, 43.7381360403424253 28.3573293202294003, 41.8486128798686963 31.6019558458453318, 40.5988307781546069 35.1425693185266184, 40.0328379900072235 38.8543817098608457, 40.1705827884231823 42.6065711287477029, 41.0072103927405820 46.2668926059394607, 42.5132340741584116 49.7063390346116378, 44.6355744080524843 52.8036879932895999, 80.4723709979361956 95.8078439011500365, 80.3842943919353985 96.0981935596773695, 80.0000000000000000 99.9999999999999289, 80.3842943919353843 103.9018064403225026, 81.5224093497742359 107.6536686473017284, 83.3706077539490451 111.1114046603919832, 85.8578643762689921 114.1421356237308942, 88.8885953396078889 116.6293922460508554, 92.3463313526981295 118.4775906502257072, 96.0981935596773553 119.6157056080645873, 99.9999999999999289 120.0000000000000000, 100.0000000000000000 120.0000000000000000, 100.0000000000000000 185.0870158363060227, 6.9841725308806293 264.8148679526940441, 6.9841725308805440 264.8148679526941578, 4.2932660917386549 267.6186224540613807, 2.1953680497354338 270.8898363837075749, 0.7696846333914061 274.5050049225884550, 0.0700425798558265 278.3276372309692306), (47.9915194493919586 282.3488246356437230, 100.0000000000000000 237.7701270208368101, 100.0000000000000000 300.0000000000000000, 100.3839234475633617 303.8999411135228002, 101.5209540688945395 307.6501543432858057, 103.3674385923808785 311.1066602100622163, 105.8524861476094685 314.1367553489624243, 108.8806899321040760 316.6241073027693460, 112.3357901021779242 318.4732207977419876, 116.0851372609338910 319.6131040310878006, 119.9847851796418183 319.9999942127302006, 123.8850172309783346 319.6190377214327327, 127.6360943613988326 318.4848603701465208, 131.0940039245045909 316.6410058867568864, 203.8537364874001696 268.1345175114931862, 120.0000000000000000 368.7590012963734125, 47.9915194493919586 282.3488246356437230), (215.0040775095006609 260.7009568300928208, 227.4803348551585884 252.3834519329875548, 230.0892518816914674 262.8191200391190705, 229.1695405949105009 262.2258748378918085, 225.5864699071360917 260.7960588946783673, 221.7955438638937835 260.0807625087496717, 217.9378111584315434 260.1065996576324437, 215.0040775095006609 260.7009568300928208), (96.8836262557126844 53.0193528032286068, 156.3403380937374152 41.1280104356236578, 177.2802617815351880 53.6919646483023243, 118.4536428779042296 78.9033727498584483, 96.8836262557126844 53.0193528032286068))
</op>
</test>
@@ -116,7 +116,7 @@
GEOMETRYCOLLECTION (POINT (100 100), POLYGON ((400 260, 120 300, 120 100, 400 260)), LINESTRING (20 280, 160 160, 60 40))
</a>
<test>
-<op name="buffer" arg1="a" arg3="20">
+<op name="buffer" arg1="a" arg2="20">
POLYGON ((0.0589102899683682 278.4660700223052459, 0.1428178439019948 282.3858576695903366, 0.9898257720584154 286.2139581446373882, 2.5673840347661048 289.8032596930139562, 4.8148679526940592 293.0158274691193583, 7.6459079792798290 295.7282042949466359, 10.9517088339672366 297.8361550501977035, 14.6052304438251515 299.2586723695006867, 18.4660700223052352 299.9410897100316333, 22.3858576695902869 299.8571821560980197, 26.2139581446373811 299.0101742279416044, 29.8032596930139349 297.4326159652339356, 33.0158274691193370 295.1851320473059559, 33.0158274691193725 295.1851320473059559, 100.0000000000000000 237.7701270208368385, 100.0000000000000000 300.0000000000000000, 100.3610465527466715 303.7830553123919231, 101.4311507496616827 307.4295247168449805, 103.1716768476074293 310.8077536925416666, 105.5197837518210235 313.7957724468756737, 108.3906938719777600 316.2856995927674575, 111.6807539878648328 318.1876371689555185, 115.2711776131651931 319.4329163748977862, 119.0323337405973660 319.9765768341428611, 122.8284271247461845 319.7989898732233200, 402.8284271247462129 279.7989898732233200, 406.5320848573002763 278.9032237308092022, 409.9986364407343444 277.3212952554368371, 413.1022505800438012 275.1106263846917273, 415.7302701354329884 272.3514615113477362, 417.7873014293543292 269.1439547167125284, 419.1986769124150101 265.6045343082814156, 419.9131654979004225 261.8616766242365088, 419.9048321833120667 258.0512425101661620, 419.1739794570858635 254.3115457478108112, 417.7471363186568851 250.7783324454299532, 415.6760953104280247 247.5798536313625959, 413.0360325161242372 244.8322099092006283, 409.9227787671366627 242.6351371575108260, 129.9227787671366627 82.6351371575108118, 126.4648010002813976 81.0736599410567322, 122.7741579330332939 80.1933332495700171, 119.4045292180186522 80.0444363579957638, 75.3644255919475228 27.1963120067104036, 75.3644255919474944 27.1963120067103752, 72.5713268488278942 24.4448805449800837, 69.2951190649891373 22.2912236004947175, 65.6617050682456949 20.8181050018461171, 61.8107149208503515 20.0821358706459208, 57.8901400145073524 20.1115990878699122, 54.0506458441837196 20.9053623986033301, 50.4397820176318632 22.4329219239622866, 47.1963120067104001 24.6355744080524843, 44.4448805449801085 27.4286731511720845, 42.2912236004947317 30.7048809350108236, 40.8181050018461278 34.3382949317542696, 40.0821358706459208 38.1892850791496201, 40.1115990878699051 42.1098599854926121, 40.9053623986033230 45.9493541558162519, 42.4329219239622688 49.5602179823681013, 44.6355744080524701 52.8036879932895786, 44.6355744080524843 52.8036879932895999, 80.4723709979361956 95.8078439011500365, 80.3842943919353985 96.0981935596773695, 80.0000000000000000 99.9999999999999289, 80.3842943919353843 103.9018064403225026, 81.5224093497742359 107.6536686473017284, 83.3706077539490451 111.1114046603919832, 85.8578643762689921 114.1421356237308942, 88.8885953396078889 116.6293922460508554, 92.3463313526981295 118.4775906502257072, 96.0981935596773553 119.6157056080645873, 99.9999999999999289 120.0000000000000000, 100.0000000000000000 120.0000000000000000, 100.0000000000000000 185.0870158363060227, 6.9841725308806293 264.8148679526940441, 6.9841725308806115 264.8148679526941009, 4.2717957050533339 267.6459079792798548, 2.1638449498022680 270.9517088339672455, 0.7413276304993075 274.6052304438251781, 0.0589102899683682 278.4660700223052459))
</op>
</test>
@@ -126,7 +126,7 @@
POLYGON ((260 400, 220 300, 80 300, 180 220, 40 200, 180 160, 60 20, 200 80, 280 20, 260 140, 440 20, 340 180, 520 160, 280 220, 460 340, 300 300, 260 400), (260 320, 240 260, 220 220, 160 180, 220 160, 200 100, 260 160, 300 140, 320 180, 260 200, 260 320))
</a>
<test>
-<op name="buffer" arg1="a" arg3=" 5">
+<op name="buffer" arg1="a" arg2=" 5">
POLYGON ((35.0116240372882501 200.3407422114144651, 35.1713912564989570 201.2978973773705036, 35.5130370199346430 202.2061648205705353, 36.0236926034150855 203.0313329556259703, 36.6841232130156953 203.7423202874070967, 37.4694524994158655 204.3123461534630394, 38.3500995719418896 204.7199394675666895, 39.2928932179245507 204.9497474681788560, 39.2928932188134539 204.9497474683058442, 167.8519380725216195 223.3153253045498730, 76.8765247622278736 296.0956559527848526, 76.1961497616868115 296.7548923955460509, 75.6523334151183633 297.5306285685009584, 75.2645987908988161 298.3950154552634899, 75.0468656059109946 299.3170214687909265, 75.0069505061331085 300.2635464888699062, 75.1462864481637354 301.2006101601772912, 75.4598712559176619 302.0945717908817301, 75.9364471993134771 302.9133380572862961, 76.5589051480572351 303.6275151577812608, 77.3048987913560381 304.2114640536476031, 78.1476468730040352 304.6442209134480663, 79.0568946415105529 304.9102497169480444, 79.9999999991020729 305.0000000000000000, 80.0000000000000000 305.0000000000000000, 216.6148351928655131 305.0000000000000000, 255.3576165455737055 401.8569533817704951, 255.8146424205861820 402.7354674065766744, 256.4358447295115297 403.5066789427960430, 257.1968559534740848 404.1403361523463786, 258.0678243757334371 404.6115829556661083, 259.0145850565194792 404.9019340457787735, 260.0000000000000000 405.0000000000000000, 260.9854149434805208 404.9019340457787735, 261.9321756242665629 404.6115829556661083, 262.8031440465259152 404.1403361523463786, 263.5641552704884703 403.5066789427960430, 264.1853575794138465 402.7354674065766744, 264.6423834544262945 401.8569533817704951, 303.0214654493869375 305.9092483943688308, 458.7873218748183604 344.8507125007266723, 459.7746718505221679 344.9949201420095619, 460.7709957975484372 344.9401989312336809, 461.7366138865052676 344.6887282080748491, 462.6330691866506868 344.2505231040791500, 463.4246592605662727 343.6430356777030966, 464.0798580577391022 342.8904598645719375, 464.5725714783865214 342.0227679241687611, 464.8831766031471489 341.0745167576526455, 464.9993032000341486 340.0834716366707084, 464.9163263841733738 339.0891021548600861, 464.6375508095448481 338.1310103026260094, 464.1740790570639206 337.2473532690553384, 463.5443694606101417 336.4733237848231511, 462.7735009811261193 335.8397485283107926, 292.1779645357767663 222.1093908980778906, 521.2126781251816965 164.8507125007266723, 521.2126781251816965 164.8507125007266438, 522.1543805669399489 164.5120554487718039, 523.0097792050349881 163.9926468835772653, 523.7446070407530669 163.3132941478750126, 524.3294271035638303 162.5012118972463213, 524.7408116868432444 161.5889318896323061, 524.9622808543857673 160.6129997734068411, 524.9849626214331693 159.6125110802694280, 524.8079483635763154 158.6275450706185381, 524.4383292159610619 157.6975591710650235, 523.8909120046585031 156.8598083224101458, 523.1876260898992541 156.1478525585079637, 522.3566448828429429 155.5902126019307730, 521.4312572276436413 155.2092273328493377, 520.4485338608891425 155.0201589005636151, 519.4478423696257323 155.0305813266319035, 349.7151310357609759 173.8897714748391081, 444.2399915200254554 22.6499947000158990, 444.2399915200254554 22.6499947000158883, 444.6715115921828101 21.7824083269838624, 444.9275854436395434 20.8478807083734132, 444.9985958041454523 19.8815095498393895, 444.8818757640429453 18.9195884930036193, 444.5818089343991346 17.9982440486761526, 444.1096648133582221 17.1520788069461005, 443.4831755417974932 16.4128718805953362, 442.7258699439179281 15.8083853887976744, 441.8661898639580272 15.3613218055506042, 440.9364219864447136 15.0884713313161907, 439.9714852572094514 15.0000813097167676, 439.0076194455472773 15.0994713718677183, 438.0810241007007448 15.3829087622282490, 437.2264990188738807 15.8397485283107695, 437.2264990188738807 15.8397485283107819, 266.8293246457370742 129.4378647770686541, 284.9319696191607250 20.8219949365267851, 284.9972548509964554 19.8343378311375389, 284.8667019190206133 18.8531728851298759, 284.5454270815070004 17.9169511175436220, 284.0460208258600119 17.0623622625131048, 283.3880544581302843 16.3228969298177553, 282.5973131201902788 15.7275341363929542, 281.7047852919733941 15.2996056433240497, 280.7454483793235909 15.0558816039900698, 279.7568979792339974 15.0059133560280014, 278.7778745404031611 15.1516591125411484, 277.8467451580276020 15.4874072213945020, 277.0000000000000000 16.0000000000000000, 199.3125897611296296 74.2655576791527636, 61.9695964928958389 15.4042748499097097, 61.0577229412326901 15.1131582612499038, 60.1070833258100023 15.0011468153852068, 59.1525190540580397 15.0723457866581878, 58.2290153739834082 15.3241456979057968, 57.3704191476974827 15.7473179590752430, 56.6081983473453221 16.3263530995686352, 55.9702887385167855 17.0400291979353362, 55.4800700207576227 17.8621896756854248, 55.1555089501321589 18.7627019487001512, 55.0085008488152880 19.7085618011956996, 55.0444336357096375 20.6651030063937284, 55.2619903565793607 21.5972678607087296, 55.6531974510677969 22.4708920657520679, 56.2037169875891536 23.2539568665980845, 56.2037169881735181 23.2539568672798431, 171.1297155297759502 157.3342884991493520, 38.6263943605131104 195.1923802617958756, 37.7236070748838870 195.5482548084508210, 36.9065643697948431 196.0718126315338168, 36.2060416809180552 196.7433329502282788, 35.6484255004332908 197.5375217006599371, 35.2547194806408726 198.4244642839367998, 35.0397532922671431 199.3707523552484702, 35.0116240372882501 200.3407422114144651), (171.2797148927206194 181.5105578027070976, 221.5811388300841998 164.7434164902525708, 222.4761523413605460 164.3438081889483442, 223.2760087068006385 163.7772697749785209, 223.9499698948452533 163.0655730018735881, 224.4721359549995725 162.2360679774997720, 224.8224403384060111 161.3206321147520441, 224.9874210440632112 160.3544451004533755, 224.9607379559749916 159.3746369597194246, 224.7434164902525708 158.4188611699158002, 211.4412280563536797 118.5122958682191552, 256.4644660940672907 163.5355339059327378, 256.4644660940672907 163.5355339059327662, 257.2715015137021624 164.1899040574063804, 258.1963542034216061 164.6633530683924107, 259.1990887849651699 164.9354372881874724, 260.2364069198474681 164.9944080498341634, 261.2635169428083373 164.8377189805977991, 262.2360679774997720 164.4721359549995725, 297.7639320225001711 146.7082039324993730, 312.9496560052372729 177.0796518979736049, 258.4188611699158287 195.2565835097474292, 258.4188611690639732 195.2565835100313620, 257.4726575011026739 195.6857747053187495, 256.6355851356503308 196.3012552642088053, 255.9437890738596764 197.0764485770453973, 255.4271412485323651 197.9778815961655880, 255.1079506463375708 198.9666302107517879, 255.0000000000000000 200.0000000000000000, 255.0000000000000000 289.1886116991581162, 244.7434164902525708 258.4188611699158287, 244.4721359549995725 257.7639320225002280, 224.4721359549995725 217.7639320225001995, 224.0203216174686531 217.0272884276953107, 223.4484154518346486 216.3794432925932369, 222.7735009811261477 215.8397485283107926, 171.2797148927206194 181.5105578027070976))
</op>
</test>
@@ -136,7 +136,7 @@
POLYGON ((260 320, 240 260, 220 220, 160 180, 220 160, 260 160, 260 200, 260 320))
</a>
<test>
-<op name="buffer" arg1="a" arg3=" -17">
+<op name="buffer" arg1="a" arg2=" -17">
POLYGON ((198.3510306352500834 185.1358965292041319, 229.4299033358288966 205.8551449962566551, 231.7246125362377711 207.6901071948169886, 233.6690934993933979 209.8927806541640280, 235.2052622469985579 212.3973688765007068, 243.0000000000000000 227.9868443825035911, 243.0000000000000000 177.0000000000000000, 222.7587202228624506 177.0000000000000000, 198.3510306352500834 185.1358965292041319))
</op>
</test>
@@ -146,7 +146,7 @@
POLYGON ((260 320, 240 260, 220 220, 260 160, 260 320))
</a>
<test>
POLYGON ((239.6172404168401044 221.2213252161837715, 243.0000000000000000 227.9868443825035627, 243.0000000000000000 216.1471858414438998, 239.6172404168401044 221.2213252161837715))
</op>
</test>
@@ -156,7 +156,7 @@
</a>
<test>
-<op name="buffer" arg1="a" arg3=" -14">
+<op name="buffer" arg1="a" arg2=" -14">
POLYGON ((236.1553744609271348 221.0057972368572052, 246.0000000000000000 240.6950483150029356, 246.0000000000000000 206.2388589282479074, 236.1553744609271348 221.0057972368572052))
</op>
</test>
@@ -166,7 +166,7 @@
LINESTRING (260 160, 260 200, 260 320, 240 260, 220 220)
</a>
<test>
-<op name="buffer" arg1="a" arg3=" 26">
+<op name="buffer" arg1="a" arg2=" 26">
POLYGON ((194.0654105708713075 221.8431145223576380, 194.9233102402886857 226.8672869967105612, 196.7448930340021889 231.6275534829989056, 215.9185482506166807 269.9748639162278891, 235.3342342506866487 328.2219219164377932, 237.4777395232139554 332.9902957247247173, 240.5318638861003819 337.2334464414602166, 244.3731231112844569 340.7798151749462932, 248.8462075669875730 343.4860152933884478, 253.7702616902279829 345.2426298271744827, 258.9461963313527804 345.9786354111978994, 264.1647383181811506 345.6642738985748906, 269.2148917801190464 344.3122555407904315, 273.8924691243435632 341.9772450873434195, 278.0083467399866208 338.7536515828895176, 281.3961116360320602 334.7718112247094950, 283.9187898443843778 330.1927176150511514, 285.4743845455978999 325.2015124745599906, 286.0000000000000000 320.0000000000000000, 286.0000000000000000 160.0000000000000000, 286.0000000000000000 159.9999999999999716, 285.5004172904839947 154.9276516275806443, 284.0208678452934237 150.0502307585076380, 281.6182099198661604 145.5551739414903238, 278.3847763108502136 141.6152236891497580, 274.4448260585096477 138.3817900801338112, 269.9497692414923335 135.9791321547065479, 265.0723483724193557 134.4995827095160053, 260.0000000000000000 134.0000000000000000, 254.9276516275806728 134.4995827095160053, 250.0502307585076949 135.9791321547065479, 245.5551739414903807 138.3817900801338112, 241.6152236891497864 141.6152236891497580, 238.3817900801338396 145.5551739414902954, 235.9791321547065479 150.0502307585076380, 234.4995827095160053 154.9276516275806159, 234.0000000000000000 160.0000000000000000, 234.0000000000000000 198.2083323711141816, 232.8759921750747992 197.4121974174686045, 228.2219219164377648 195.3342342506866487, 223.2518878094589638 194.2041626289299927, 218.1568854776423336 194.0654105708713075, 213.1327130032893820 194.9233102402887141, 208.3724465170010944 196.7448930340021889, 204.0590203902573592 199.4601565468047113, 200.3581971701116515 202.9647547246366344, 197.4121974174686329 207.1240078249251440, 195.3342342506866487 211.7780780835621783, 194.2041626289299927 216.7481121905409793, 194.0654105708713075 221.8431145223576380))
</op>
</test>
@@ -176,7 +176,7 @@
</a>
<test>
-<op name="buffer" arg1="a" arg3=" -7">
+<op name="buffer" arg1="a" arg2=" -7">
POLYGON ((73.4860813026739379 197.7126580885165197, 180.9899494936611575 213.0703535443718408, 182.3056363280740300 213.3906096254900149, 183.5350455074643037 213.9581912261180889, 184.6321721438235670 214.7518592597011207, 185.5559614045681940 215.7419144124444017, 186.2718447976156142 216.8913085012144109, 186.7530337355075574 218.1570308285006945, 186.9815219729924536 219.4917176565886905, 186.9487594065303711 220.8454245739010844, 186.6559720219250664 222.1674954309872589, 186.1141160175398568 223.4084579099737482, 185.3434678198210861 224.5218747946550195, 184.3728653328809628 225.4660816661012177, 99.9554674155074849 293.0000000000000000, 220.0000000000000000 293.0000000000000000, 221.3795809208727405 293.1372923359097058, 222.7050458739731766 293.5437838620674711, 223.9244016651362870 294.2035293867151040, 224.9898173786838527 295.0906494800855171, 225.8595006111793566 296.1703456307926672, 226.4993368361968180 297.4002652655212842, 260.0000000000000000 381.1519231750292533, 293.5006631638032104 297.4002652655212842, 294.1661219403375753 296.1314257426036534, 295.0759831943759082 295.0246549367977309, 296.1921295120130253 294.1263195229296343, 297.4678014439602407 293.4740540553273149, 298.8495564298037834 293.0951843187675081, 300.2795077022184955 293.0055825514628509, 301.6977493752543182 293.2090024989826702, 422.4918692298074916 323.4075324626209635, 276.1170986264233989 225.8243520603649017, 275.0751191377321447 224.9744897720738948, 274.2148564119547700 223.9410802663354616, 273.5680521626788959 222.7622539741994387, 273.1585719772567700 221.4815068712711650, 273.0015247315887450 220.1460955763733693, 273.1027051073951384 218.8052936911329880, 273.4583797818045241 217.5085737175472218, 274.0554251783708537 216.3037816365840911, 274.8718116968233858 215.2353715016632805, 275.8774165545875121 214.3427651864527661, 277.0351352480957985 213.6588978085102610, 278.3022506235261062 213.2090024992875783, 278.3022506247456818 213.2090024989826702, 417.3387123436478987 178.4498870692571018, 340.7730206825239065 186.9571861427153294, 339.3500498878744907 186.9697607456603521, 337.9539393295281116 186.6942987483938907, 336.6423855272677770 186.1421840620824071, 335.4695905565998828 185.3362337163163147, 334.4840220605933041 184.3097549085741491, 333.7264102463850008 183.1051685305852743, 333.2280646437002360 181.7722560565836432, 333.0095801880563045 180.3661022436220946, 333.0799861018467709 178.9448186651734716, 333.4363727471683205 177.5671421566632660, 334.0640118712981348 176.2900074210437538, 334.0640118719643965 176.2900074199777407, 416.8351501132551675 43.8561862339125383, 263.8829013735766011 145.8243520603649017, 262.6893944488330703 146.4627515423839270, 261.3953364072212366 146.8595215803059375, 260.0491095087077724 146.9998277304626981, 258.7010465032032016 146.8784242245705798, 257.4015487890115423 146.4998500985878707, 256.1992020046532161 145.8782594871754270, 255.1389595083396387 145.0368924287141965, 254.2604616611944550 144.0072059664286428, 253.5965537528831817 142.8276980320192422, 253.1720579814688108 141.5424680844595855, 253.0028454007270966 140.1995683188137320, 253.0952425329683138 138.8492070901025102, 253.0952425331749964 138.8492070888624994, 270.2229832929357372 36.0827625302982113, 204.1999999999999886 85.5999999999999943, 202.9423960790961701 86.3515592820755131, 201.5559026611282718 86.8248931793174563, 200.1012540709528764 86.9992676483411742, 198.6421701206390367 86.8670443437271160, 197.2425649099458269 86.4340152101264039, 84.8909725436656686 38.2833327674349064, 185.3147962165570846 155.4444603858082132, 186.1142829007226851 156.5918414634981559, 186.6697395331827920 157.8752471768465000, 186.9589970202038671 159.2434549102705148, 186.9705106687025307 160.6418574744477041, 186.7038209519796794 162.0146425598100848, 186.1695718501092358 163.3070202881657167, 185.6570600448659434 164.0689987779851435, 211.1456225515285325 155.5728112757642805, 193.3592169136464065 102.2135943621178598, 193.3592169132488721 102.2135943609252706, 193.0594928825265981 100.9106925673908677, 193.0129397948266501 99.5745711701319181, 193.2212557809792770 98.2539682668711265, 193.6768420367806414 96.9970558826086204, 194.3630800068345650 95.8496827843342061, 195.2549375845420059 94.8537020419132375, 196.3198822157007442 94.0454443412052683, 197.5190675981640709 93.4543927388270106, 198.8087506899613288 93.1021071999245748, 200.1418873372542748 93.0014381489103812, 201.4698483179327297 93.1560577207087448, 202.7441932042174528 93.5603258111976857, 203.9184373385559468 94.1994958129649973, 204.9497474683058442 95.0502525316941700, 261.3821713435749530 151.4826764069632645, 296.8695048315003078 133.7390096630005871, 298.1511150393471326 133.2485835262315845, 299.5037768593652459 133.0176105383115157, 300.8755082563928340 133.0549668616349948, 302.2135943621178740 133.3592169136464065, 303.4666132779047416 133.9186685354723068, 304.5864121895208996 134.7118223150300480, 305.5299578527833546 135.7081977973769824, 306.2609903369993845 136.8695048315003078, 326.2609903369993845 176.8695048315003078, 326.7401067069822034 178.1103011937101428, 326.9758738477949578 179.4193244798940441, 326.9597794680934726 180.7493128555578323, 326.6924046499087808 182.0522475488787961, 326.1834028688805915 183.2810865519092260, 325.4511514588469936 184.3914630560566081, 324.5220881045417514 185.3432873004136354, 323.4297563181003738 186.1021939987557232, 322.2135943621178740 186.6407830863535935, 267.0000000000000000 205.0453145403928943, 267.0000000000000000 320.0000000000000000, 266.8584881468917160 321.4004072046892020, 266.4396741888727433 322.7441932040522374, 265.7604915943163064 323.9770260989602662, 264.8484010453810242 325.0490600415471931, 263.7402801488617001 325.9169506004386108, 262.4809324023397608 326.5456072609820239, 261.1212757010487735 326.9096122034624727, 259.7162836276718849 326.9942479953224961, 258.3227627627537117 326.7960926457777759, 256.9970558834197618 326.3231579636045581, 255.7927639145765966 325.5945656240240282, 254.7585787385654896 324.6397740419316165, 253.9363144870191604 323.4973873105028019, 253.3592169136464065 322.2135943621178740, 233.5165322213198635 262.6855402851382451, 214.5703578501880884 224.7931915428746947, 156.1170986264233989 185.8243520603649017, 156.1170986253774231 185.8243520596676035, 155.0231091408172404 184.9224544056581294, 154.1332973523846590 183.8186123192153332, 153.4841679225465896 182.5581110879766982, 153.1023514838049664 181.1926629645598155, 153.0035121129924391 179.7782856636201529, 153.1917047101640605 178.3730042266809903, 153.6592086457127948 177.0344705360768103, 154.3868445003602119 175.8175981378084032, 155.3447609037176562 174.7723094050580812, 156.3685660265952038 174.0319481673961661, 73.4860813026739379 197.7126580885165197))
</op>
</test>
@@ -186,7 +186,7 @@
POLYGON ((32 136, 27 163, 30 236, 34 252, 49 291, 72 326, 83 339, 116 369, 155 391, 176 400, 219 414, 264 417, 279 416, 339 401, 353 395, 380 381, 394 372, 441 328, 458 303, 463 294, 480 251, 486 205, 486 183, 473 115, 469 105, 460 85, 454 74, 423 33, 382 2, 373 -3, 336 -19, 319 -24, 275 -31, 252 -32, 203 -27, 190 -24, 149 -10, 139 -5, 84 37, 76 46, 52 81, 36 121, 32 136))
</a>
<test>
-<op name="buffer" arg1="a" arg3=" -183">
+<op name="buffer" arg1="a" arg2=" -183">
POLYGON ((210.7267553108988238 176.9256915755600801, 211.8671630388668063 204.6756129561149464, 212.7392713423978705 206.9430945452957076, 217.1208592864501838 213.6107283732014253, 223.8552432300779174 219.7328955946811675, 236.2393055009007128 226.7187768756581363, 240.5016559451048010 228.5454984946027537, 253.9490540002205137 232.9237211171985678, 256.1814740341310426 233.0725491194592678, 278.4949667339785151 227.4941759444973854, 283.1893383949868621 225.0600573054560130, 299.5152762254757022 209.7762006130834607, 301.4726576684510633 204.8251769632046262, 302.4401896474719820 197.4074317907112288, 297.2128574239011982 170.0644632366487485, 292.3573443617199246 163.6426556382799902, 285.7526778147497453 158.6488833710586164, 276.1059779842289004 154.4773374984009706, 257.0088333017464493 151.4391553898242080, 236.3522756410080490 153.5469673960220121, 230.1160214134394835 155.6764200590941982, 214.5153345565076393 167.5896718407512651, 214.3853233124629014 167.7792715716498435, 210.7267553108988238 176.9256915755600801))
</op>
</test>
@@ -196,7 +196,7 @@
POLYGON ((13841 1031, 13851 903, 13853 885, 13853 875, 13856 862, 13859 831, 13670 900, 13841 1031))
</a>
<test>
-<op name="buffer" arg1="a" arg3=" 164">
+<op name="buffer" arg1="a" arg2=" 164">
POLYGON ((13506.2449358346930239 891.0401473105671357, 13507.5974451398560632 922.8344076975459984, 13515.0648325523125095 953.7688933116278349, 13528.3659315359454922 982.6788404026061698, 13546.9999211581762211 1008.4757143553580363, 13570.2651832991996343 1030.1881958460821807, 13741.2651832991996343 1161.1881958460821807, 13741.2651832991996343 1161.1881958460819533, 13768.4021467823731655 1178.0562875506921046, 13798.2948576844864874 1189.3422584776781150, 13829.8086163241805480 1194.6177036002541172, 13861.7471895460166706 1193.6823718967168588, 13892.8982186255980196 1186.5717676941726495, 13922.0792392863841087 1173.5558029570918279, 13948.1825669508853025 1155.1285516785676464, 13970.2173434235901368 1131.9894952881238623, 13987.3471489523926721 1105.0169709830538523, 13998.9217519494322914 1075.2348308601026474, 14004.5017911812756211 1043.7735774360371579, 14014.2929847110062838 918.4463002554892910, 14015.9969324864741793 903.1107702762748204, 14015.9969324864741793 903.1107702762747067, 14016.4532573949691141 894.8716483052672857, 14019.2374022230687842 877.7971679570712240, 14022.2374022230687842 846.7971679570712240, 14022.0923450200498337 813.7695909549128146, 14015.3326253785835434 781.4408409853512012, 14002.2324024788667884 751.1221001770096564, 13983.3229921980455401 724.0430291616075920, 13959.3713181210496259 701.3018947762033122, 13931.3488068273163663 683.8210268052406491, 13900.3919889913086081 672.3094103377792408, 13867.7564042285048345 667.2339309106217797, 13834.7656792036668776 668.8004386703205455, 13802.7578442799749610 676.9453995494958463, 13802.7578442799749610 676.9453995494959599, 13613.7578442799749610 745.9453995494959599, 13613.7578442799731420 745.9453995494963010, 13585.0645211260962242 759.7075752990896262, 13559.5692394115667412 778.7521253140495219, 13538.2319627288889023 802.3619728091613297, 13521.8560949787515710 829.6481456885808257, 13511.0582301259437372 859.5832486547654980, 13506.2449358346930239 891.0401473105671357))
</op>
</test>
@@ -206,7 +206,7 @@
POLYGON ((20 60, 20 20, 240 20, 40 21, 240 22, 40 22, 240 23, 240 60, 20 60))
</a>
<test>
-<op name="buffer" arg1="a" arg3=" 160">
+<op name="buffer" arg1="a" arg2=" 160">
POLYGON ((-140.0000000000000000 19.9999999712661989, -140.0000000000000000 20.0000000000000000, -140.0000000000000000 60.0000000000000000, -136.9256448645168689 91.2144515225805748, -127.8207252018058711 121.2293491784143811, -113.0351379684072555 148.8912372831363484, -93.1370849898475939 173.1370849898476081, -68.8912372831363200 193.0351379684072697, -41.2293491784143527 207.8207252018058853, -11.2144515225805126 216.9256448645168689, 20.0000000000000107 220.0000000000000000, 240.0000000000000000 220.0000000000000000, 271.2144515225805321 216.9256448645168689, 301.2293491784143953 207.8207252018058853, 328.8912372831363768 193.0351379684072413, 353.1370849898476081 173.1370849898476081, 373.0351379684072413 148.8912372831363484, 387.8207252018058853 121.2293491784143669, 396.9256448645168689 91.2144515225805179, 400.0000000000000000 60.0000000000000000, 400.0000000000000000 23.0000000000000000, 399.9699034646581026 22.6934426863818643, 399.9995000085935999 22.3999962500605676, 399.8653662226012102 21.0000000000001599, 399.9995000085935999 19.6000037499394679, 396.8569884248131530 -11.5576485546376748, 387.7056613593456973 -41.5064029382169224, 372.8960842304180119 -69.0989943614496838, 352.9955764620684135 -93.2784167439007064, 328.7664788360034436 -113.1184143349722859, 301.1369500424084436 -127.8589643528996618, 271.1654111438951986 -136.9353916369152557, 240.0000000000000000 -140.0000000000000000, 20.0000000000000000 -140.0000000000000000, -11.2144515190578034 -136.9256448652175777, -41.2293491717777130 -127.8207252045548756, -68.8912372741771435 -113.0351379743935922, -93.1370849796886660 -93.1370850000065360, -113.0351379584299423 -68.8912372980684324, -127.8207251935589142 -41.2293491983242930, -136.9256448596119071 -11.2144515472394666, -140.0000000000000000 19.9999999712661989))
</op>
</test>
@@ -221,7 +221,7 @@
634656.8370616816 6184664.2814434115, 634660.1436502574 6184665.506014449, 634663.4481081718 6184666.7388333315, 634666.7496027217 6184667.976549702, 634670.0489665787 6184669.222513908, 634673.3453155413 6184670.475036258, 634676.6396367943 6184671.732485097, 634679.9308916207 6184672.9981527375, 634683.2200672035 6184674.270407524, 634686.5062278372 6184675.54922043, 634689.789322 6184676.8362521175, 634693.0703883899 6184678.128210268, 634696.3493754807 6184679.426755545, 634699.6253475712 6184680.731858918, 634702.8982531315 6184682.04518105, 634706.1681951834 6184683.363400595, 635074.6769928858 6184832.427381967))
</a>
<test>
-<op name="buffer" arg1="a" arg3="0.1">
+<op name="buffer" arg1="a" arg2="0.1">
POLYGON ((4399.2025462962965321 42946.8368055555547471, 4399.2025462962965321 42946.8373842592554865, 4399.2031250000000000 42946.8373842592554865, 4400.3501157407399660 42947.1429398148102337, 4400.4826388888886868 42947.1782407407445135, 4401.7540509259260944 42947.5167824074087548, 4404.7291666666669698 42948.3090277777737356, 4406.2667824074069358 42948.7181712962992606, 4406.2893518518512792 42948.7245370370364981, 4406.3125000000000000 42948.7303240740802721, 4406.3350694444443434 42948.7366898148102337, 4406.3582175925930642 42948.7430555555547471, 4406.3807870370374076 42948.7494212962992606, 4406.4033564814817510 42948.7557870370364981, 4406.4265046296295623 42948.7621527777737356, 4406.4490740740739056 42948.7685185185182490, 4406.4722222222217169 42948.7748842592554865, 4406.4947916666669698 42948.7812500000000000, 4406.5173611111113132 42948.7876157407445135, 4406.5399305555556566 42948.7945601851897663, 4406.5630787037034679 42948.8009259259197279, 4406.5856481481487208 42948.8078703703722567, 4406.6082175925930642 42948.8148148148102337, 4406.6307870370374076 42948.8211805555547471, 4406.6533564814817510 42948.8281250000000000, 4406.6759259259260944 42948.8350694444452529, 4406.6990740740739056 42948.8420138888905058, 4406.7216435185182490 42948.8489583333357587, 4406.7442129629625924 42948.8559027777737356, 4406.7667824074069358 42948.8628472222262644, 4406.7893518518512792 42948.8697916666642413, 4406.8119212962965321 42948.8773148148102337, 4406.8344907407399660 42948.8842592592554865, 4406.8570601851852189 42948.8917824074087548, 4406.8790509259260944 42948.8987268518540077, 4406.9016203703704377 42948.9062500000000000, 4406.9241898148147811 42948.9137731481459923, 4406.9467592592600340 42948.9207175925912452, 4406.9693287037034679 42948.9282407407445135, 4406.9837962962965321 42948.9334490740802721, 4406.9924768518512792 42948.9363425925912452, 4407.0034722222217169 42948.9396412037021946, 4407.0034722222217169 42948.9398148148102337, 4407.0040509259260944 42948.9398148148102337, 4407.0040509259260944 42948.9403935185182490, 4407.0044795953372159 42948.9399648491089465, 4407.0156250000000000 42948.9438657407445135, 4407.0387731481487208 42948.9519675925912452, 4407.0619212962965321 42948.9594907407445135, 4407.0850694444443434 42948.9675925925912452, 4407.1082175925930642 42948.9756944444452529, 4407.1313657407399660 42948.9837962962992606, 4407.1545138888886868 42948.9918981481459923, 4407.1776620370374076 42949.0000000000000000, 4407.2008101851852189 42949.0081018518540077, 4407.2239583333330302 42949.0162037037007394, 4407.2471064814817510 42949.0243055555547471, 4407.2696759259260944 42949.0329861111094942, 4407.2928240740739056 42949.0410879629635019, 4407.3159722222217169 42949.0497685185182490, 4407.3391203703704377 42949.0584490740802721, 4407.3616898148147811 42949.0665509259197279, 4407.3848379629625924 42949.0752314814817510, 4407.4079861111113132 42949.0839120370364981, 4407.4305555555556566 42949.0925925925912452, 4407.4537037037034679 42949.1012731481459923, 4407.4762731481487208 42949.1099537037007394, 4407.4994212962965321 42949.1186342592554865, 4407.5219907407399660 42949.1273148148102337, 4407.5451388888886868 42949.1365740740802721, 4407.5677083333330302 42949.1452546296277433, 4407.5902777777782831 42949.1545138888905058, 4407.6134259259260944 42949.1631944444452529, 4407.6359953703704377 42949.1724537037007394, 4407.6585648148147811 42949.1817129629635019, 4407.6817129629625924 42949.1903935185182490, 4410.2407407407399660 42950.2256944444452529, 4410.2413194444443434 42950.2256944444452529, 4410.2413194444443434 42950.2251157407445135, 4410.2482638888886868 42949.9994212962992606, 4410.2482638888886868 42949.9988425925912452, 4407.7615740740739056 42948.9930555555547471, 4407.6464120370374076 42948.9473379629635019, 4407.6232638888886868 42948.9380787037007394, 4407.6001157407399660 42948.9293981481459923, 4407.5775462962965321 42948.9207175925912452, 4407.5543981481487208 42948.9114583333357587, 4407.5312500000000000 42948.9027777777737356, 4407.5086805555556566 42948.8940972222262644, 4407.4855324074069358 42948.8854166666642413, 4407.4623842592600340 42948.8767361111094942, 4407.4392361111113132 42948.8680555555547471, 4407.4160879629625924 42948.8593750000000000, 4407.3935185185182490 42948.8512731481459923, 4407.3703703703704377 42948.8425925925912452, 4407.3472222222217169 42948.8344907407445135, 4407.3240740740739056 42948.8258101851897663, 4407.3009259259260944 42948.8177083333357587, 4407.2777777777782831 42948.8090277777737356, 4407.2546296296295623 42948.8009259259197279, 4407.2314814814817510 42948.7928240740802721, 4407.2077546296295623 42948.7847222222262644, 4407.1846064814817510 42948.7766203703722567, 4407.1620370370374076 42948.7690972222262644, 4407.1961805555556566 42948.6695601851897663, 4407.1967592592600340 42948.6689814814817510, 4407.1961805555556566 42948.6689814814817510, 4407.1961805555556566 42948.6684027777737356, 4407.1753472222217169 42948.6614583333357587, 4407.1550925925930642 42948.6545138888905058, 4407.1348379629625924 42948.6475694444452529, 4407.1140046296295623 42948.6406250000000000, 4407.0937500000000000 42948.6336805555547471, 4407.0729166666669698 42948.6267361111094942, 4407.0526620370374076 42948.6203703703722567, 4407.0324074074069358 42948.6134259259197279, 4407.0115740740739056 42948.6064814814817510, 4406.9913194444443434 42948.6001157407445135, 4406.9704861111113132 42948.5931712962992606, 4406.9502314814817510 42948.5868055555547471, 4406.9293981481487208 42948.5798611111094942, 4406.9085648148147811 42948.5734953703722567, 4406.8883101851852189 42948.5671296296277433, 4406.8674768518512792 42948.5601851851897663, 4406.8472222222217169 42948.5538194444452529, 4406.8263888888886868 42948.5474537037007394, 4406.8055555555556566 42948.5410879629635019, 4406.7853009259260944 42948.5347222222262644, 4406.7644675925930642 42948.5283564814817510, 4406.7436342592600340 42948.5225694444452529, 4406.7228009259260944 42948.5162037037007394, 4406.7025462962965321 42948.5098379629635019, 4406.6817129629625924 42948.5034722222262644, 4406.6608796296295623 42948.4976851851897663, 4406.6400462962965321 42948.4913194444452529, 4406.6192129629625924 42948.4855324074087548, 4406.5983796296295623 42948.4791666666642413, 4406.5775462962965321 42948.4733796296277433, 4406.5572916666669698 42948.4675925925912452, 4406.5364583333330302 42948.4618055555547471, 4406.5156250000000000 42948.4554398148102337, 4406.4947916666669698 42948.4496527777737356, 4406.4739583333330302 42948.4438657407445135, 4406.4531250000000000 42948.4380787037007394, 4406.4322916666669698 42948.4328703703722567, 4406.4114583333330302 42948.4270833333357587, 4406.3906250000000000 42948.4212962962992606, 4406.3697916666669698 42948.4155092592554865, 4406.3489583333330302 42948.4103009259197279, 4406.3483796296295623 42948.4103009259197279, 4406.3478009259260944 42948.4103009259197279, 4406.3206018518512792 42948.5121527777737356, 4404.7361111111113132 42948.0902777777737356, 4401.8090277777782831 42947.3107638888905058, 4400.4473379629625924 42946.9484953703722567, 4400.3165509259260944 42946.9137731481459923, 4399.2100694444443434 42946.6186342592554865, 4399.2094907407399660 42946.6186342592554865, 4399.2094907407399660 42946.6192129629635019, 4399.2089120370374076 42946.6192129629635019, 4399.2060185185182490 42946.7280092592554865, 4399.2025462962965321 42946.8368055555547471))
</op>
</test>
@@ -231,7 +231,7 @@
MULTILINESTRING (( 80 285, 85.5939933259177 234.65406006674084 ), ( 85.5939933259177 234.65406006674084, 98 123, 294 92, 344.3694502052736 126.0884157954882 ), ( 344.3694502052736 126.0884157954882, 393 159 ), ( 51 235, 85.5939933259177 234.65406006674084 ), ( 85.5939933259177 234.65406006674084, 251 233, 344.3694502052736 126.0884157954882 ), ( 344.3694502052736 126.0884157954882, 382 83 ))
</a>
<test>
-<op name="buffer" arg1="a" arg3="30">
+<op name="buffer" arg1="a" arg2="30">
POLYGON ((0.1458333333333333 1.6342592592592593, 0.1504629629629630 1.6747685185185184, 0.1626157407407408 1.7135416666666667, 0.1822916666666667 1.7494212962962961, 0.2083333333333333 1.7806712962962965, 0.2401620370370371 1.8061342592592593, 0.2766203703703704 1.8252314814814812, 0.3153935185185185 1.8368055555555556, 0.3564814814814815 1.8402777777777777, 0.3612234904558542 1.8402320716671812, 0.3483796296296296 1.9560185185185188, 0.3478009259259260 1.9971064814814812, 0.3553240740740740 2.0370370370370368, 0.3703703703703704 2.0752314814814814, 0.3929398148148148 2.1093750000000000, 0.4212962962962963 2.1383101851851856, 0.4548611111111111 2.1614583333333335, 0.4924768518518519 2.1776620370370368, 0.5324074074074074 2.1863425925925926, 0.5734953703703703 2.1869212962962963, 0.6134259259259259 2.1793981481481479, 0.6516203703703703 2.1643518518518521, 0.6857638888888888 2.1417824074074074, 0.7146990740740741 2.1134259259259260, 0.7378472222222222 2.0798611111111112, 0.7540509259259259 2.0422453703703702, 0.7627314814814814 2.0023148148148144, 0.7811687997909398 1.8361037661743242, 1.7453703703703705 1.8263888888888891, 1.7887731481481479 1.8211805555555556, 1.8304398148148147 1.8072916666666667, 1.8680555555555556 1.7847222222222223, 1.8998842592592593 1.7552083333333333, 2.4274509725820850 1.1514009353019461, 2.6122685185185186 1.2766203703703705, 2.6481481481481479 1.2962962962962963, 2.6875000000000000 1.3084490740740740, 2.7280092592592591 1.3125000000000000, 2.7685185185185186 1.3084490740740740, 2.8078703703703702 1.2968750000000000, 2.8437500000000000 1.2783564814814816, 2.8755787037037037 1.2523148148148149, 2.9016203703703702 1.2210648148148149, 2.9212962962962963 1.1851851851851851, 2.9334490740740744 1.1458333333333333, 2.9375000000000000 1.1053240740740740, 2.9334490740740744 1.0648148148148149, 2.9218750000000000 1.0254629629629630, 2.9033564814814814 0.9895833333333334, 2.8773148148148149 0.9577546296296297, 2.8460648148148149 0.9317129629629629, 2.7034393799947556 0.8352454171514502, 2.8096064814814814 0.7135416666666666, 2.8333333333333335 0.6799768518518520, 2.8501157407407409 0.6429398148148148, 2.8593750000000000 0.6030092592592592, 2.8605324074074079 0.5625000000000000, 2.8541666666666665 0.5219907407407408, 2.8396990740740744 0.4837962962962963, 2.8177083333333335 0.4490740740740741, 2.7899305555555554 0.4195601851851852, 2.7563657407407409 0.3958333333333333, 2.7193287037037037 0.3790509259259260, 2.6793981481481484 0.3697916666666667, 2.6388888888888888 0.3686342592592593, 2.5983796296296298 0.3750000000000000, 2.5601851851851856 0.3894675925925926, 2.5254629629629632 0.4114583333333333, 2.4959490740740740 0.4392361111111111, 2.3555506357080023 0.5998245903926580, 2.1585648148148144 0.4664351851851852, 2.1244212962962963 0.4473379629629630, 2.0868055555555558 0.4357638888888889, 2.0480324074074074 0.4305555555555556, 2.0092592592592591 0.4328703703703704, 0.6481481481481481 0.6481481481481481, 0.6105324074074074 0.6579861111111110, 0.5752314814814815 0.6741898148148148, 0.5439814814814815 0.6967592592592592, 0.5173611111111110 0.7251157407407408, 0.4959490740740741 0.7575231481481480, 0.4814814814814815 0.7934027777777778, 0.4733796296296297 0.8310185185185186, 0.4075464183465707 1.4230755864332771, 0.3518518518518519 1.4236111111111109, 0.3113425925925926 1.4282407407407407, 0.2725694444444445 1.4403935185185184, 0.2366898148148149 1.4600694444444444, 0.2054398148148148 1.4861111111111109, 0.1799768518518519 1.5179398148148149, 0.1608796296296296 1.5543981481481481, 0.1493055555555556 1.5931712962962961, 0.1458333333333333 1.6342592592592593), (0.8273606239796916 1.4189782356462863, 0.8697916666666666 1.0353009259259260, 1.9930555555555556 0.8576388888888888, 2.0794276720091411 0.9159888402507564, 1.6475694444444444 1.4108796296296295, 0.8273606239796916 1.4189782356462863))
</op>
</test>
@@ -241,7 +241,7 @@
</a>
<test>
-<op name="buffer" arg1="a" arg3=" 30">
+<op name="buffer" arg1="a" arg2=" 30">
</op>
</test>
@@ -252,7 +252,7 @@
</a>
<test> <op name="isvalid" arg1="a">false</op> </test>
<test>
-<op name="buffer" arg1="a" arg3=" .0001">
+<op name="buffer" arg1="a" arg2=" .0001">
POLYGON ((708247.8964913242962211 2402252.4826993490569293, 708247.8964935755357146 2402252.4827196551486850, 708247.8964999067829922 2402252.4827390797436237, 708247.8965100536588579 2402252.4827568121254444, 708247.8965235925279558 2402252.4827721123583615, 708247.8965399585431442 2402252.4827843415550888, 708367.3795424886047840 2402324.0077023315243423, 708367.3795424884883687 2402324.0077023315243423, 708367.3795602144673467 2402324.0077107031829655, 708367.3795792331220582 2402324.0077154561877251, 708367.3795988133642823 2402324.0077164070680737, 708367.3796182030346245 2402324.0077135199680924, 708367.3796366568421945 2402324.0077069052495062, 708367.3796534657012671 2402324.0076968176290393, 708367.3796679835068062 2402324.0076836450025439, 708367.3796796525130048 2402324.0076678926125169, 708367.3796880241716281 2402324.0076501667499542, 708367.3796927768271416 2402324.0076311482116580, 708367.3796937278239056 2402324.0076115676201880, 708367.3796908406075090 2402324.0075921779498458, 708367.3796842261217535 2402324.0075737242586911, 708367.3796741386177018 2402324.0075569157488644, 708367.3796609656419605 2402324.0075423978269100, 708367.3796452134847641 2402324.0075307288207114, 708248.8827136848121881 2402253.0728945857845247, 708249.5237211110070348 2402244.3124597654677927, 708257.0394274791469797 2402206.5717926472425461, 708652.9610695739975199 2402312.6547309630550444, 708652.9610886982409284 2402312.6547341416589916, 708652.9611080762697384 2402312.6547335702925920, 708652.9611269800225273 2402312.6547292708419263, 708652.9611446990165859 2402312.6547214044257998, 708652.9611605671234429 2402312.6547102672047913, 708652.9611739881802350 2402312.6546962773427367, 708652.9611844575265422 2402312.6546799610368907, 708657.0688752535497770 2402304.6356819909997284, 708657.0688824839890003 2402304.6356635885313153, 708657.0688859523506835 2402304.6356441229581833, 708657.0688855230109766 2402304.6356243551708758, 708657.0688812127336860 2402304.6356050586327910, 708657.0688731900881976 2402304.6355869872495532, 708657.0688617686973885 2402304.6355708478949964, 708657.0688473950140178 2402304.6355572710745037, 708657.0688306309748441 2402304.6355467871762812, 708657.0688121319981292 2402304.6355398069135845, 708657.0445044980151579 2402304.6290268381126225, 708708.8958459561690688 2402203.4725457550957799, 708708.8958531989483163 2402203.4725273284129798, 708708.8958566694054753 2402203.4725078358314931, 708708.8958562314510345 2402203.4724880419671535, 708708.8958519023144618 2402203.4724687216803432, 708708.8958438517292961 2402203.4724506335332990, 708708.8958323950646445 2402203.4724344857968390, 708708.8958179816836491 2402203.4724209117703140, 708708.8958011765498668 2402203.4724104437045753, 708708.8957826382247731 2402203.4724034913815558, 708280.3264799062162638 2402089.6336824516765773, 708280.3264597709057853 2402089.6336792535148561, 708280.3264394054422155 2402089.6336802057921886, 708280.3264196563977748 2402089.6336852684617043, 708280.3264013445004821 2402089.6336942315101624, 708280.3263852309901267 2402089.6337067219428718, 708280.3263719857204705 2402089.6337222210131586, 708280.3263621591031551 2402089.6337400842458010, 708280.3263561597559601 2402089.6337595693767071, 708258.7633657812839374 2402197.9138868227601051, 708258.7549465369665995 2402197.9116309769451618, 708258.7549263836117461 2402197.9116277340799570, 708258.7549059916054830 2402197.9116286509670317, 708258.7548862107796595 2402197.9116336894221604, 708258.7548678650055081 2402197.9116426398977637, 708258.7548517190152779 2402197.9116551289334893, 708258.7548384453402832 2402197.9116706363856792, 708258.7548285971861333 2402197.9116885163821280, 708258.7548225849168375 2402197.9117080233991146, 708257.0293493838980794 2402206.5689955335110426, 708257.0293474586214870 2402206.5690142284147441, 708257.0293490652693436 2402206.5690329535864294, 708257.0293541471473873 2402206.5690510477870703, 708257.0293625248596072 2402206.5690678711980581, 708257.0293739024782553 2402206.5690828296355903, 708257.0293878779048100 2402206.5690953955054283, 708257.0294039577711374 2402206.5691051245667040, 708257.0294215739704669 2402206.5691116731613874, 708257.0392338818637654 2402206.5717407753691077, 708247.8964932467788458 2402252.4826790094375610, 708247.8964913242962211 2402252.4826993490569293), (708258.7635593785671517 2402197.9139386950992048, 708261.8547960097203031 2402182.3910687258467078, 708262.8183218683116138 2402183.3545945808291435, 708262.8183402057038620 2402183.3546090582385659, 708262.8183614019071683 2402183.3546188860200346, 708522.7761432345723733 2402268.6532660527154803, 708258.7635593785671517 2402197.9139386950992048))
</op>
</test>
@@ -262,7 +262,7 @@
GEOMETRYCOLLECTION (POLYGON ((0 10, 10 0, 10 10, 0 10), (4 8, 8 4, 8 8, 4 8)), LINESTRING (6 6, 20 20))
</a>
<test>
-<op name="buffer" arg1="a" arg3="1">
+<op name="buffer" arg1="a" arg2="1">
POLYGON ((-1.0000000000000000 9.9999999999999982, -0.9807852804032310 10.1950903220161262, -0.9238795325112880 10.3826834323650861, -0.8314696123025475 10.5555702330195995, -0.7071067811865505 10.7071067811865444, -0.5555702330196066 10.8314696123025431, -0.3826834323650944 10.9238795325112843, -0.1950903220161339 10.9807852804032287, -0.0000000000000064 11.0000000000000000, 0.0000000000000000 11.0000000000000000, 9.5857864376269042 11.0000000000000000, 19.2928932188134539 20.7071067811865461, 19.2928932188134539 20.7071067811865497, 19.4444297669803987 20.8314696123025449, 19.6173165676349122 20.9238795325112861, 19.8049096779838720 20.9807852804032322, 20.0000000000000000 21.0000000000000000, 20.1950903220161280 20.9807852804032287, 20.3826834323650914 20.9238795325112861, 20.5555702330196013 20.8314696123025449, 20.7071067811865461 20.7071067811865461, 20.8314696123025449 20.5555702330196013, 20.9238795325112861 20.3826834323650914, 20.9807852804032287 20.1950903220161280, 21.0000000000000000 20.0000000000000000, 20.9807852804032322 19.8049096779838720, 20.9238795325112861 19.6173165676349122, 20.8314696123025449 19.4444297669803987, 20.7071067811865461 19.2928932188134539, 11.0000000000000000 9.5857864376269042, 11.0000000000000000 0.0000000000000000, 10.9807852804032304 -0.1950903220161285, 10.9238795325112861 -0.3826834323650899, 10.8314696123025449 -0.5555702330196024, 10.7071067811865479 -0.7071067811865477, 10.5555702330196013 -0.8314696123025453, 10.3826834323650896 -0.9238795325112868, 10.1950903220161280 -0.9807852804032304, 10.0000000000000000 -1.0000000000000000, 9.8049096779838720 -0.9807852804032304, 9.6173165676349104 -0.9238795325112866, 9.4444297669803969 -0.8314696123025451, 9.2928932188134521 -0.7071067811865472, 9.2928932188134521 -0.7071067811865476, -0.7071067811865476 9.2928932188134521, -0.8314696123025448 9.4444297669803969, -0.9238795325112862 9.6173165676349086, -0.9807852804032300 9.8049096779838703, -1.0000000000000000 9.9999999999999982))
</op>
</test>
@@ -272,7 +272,7 @@
POLYGON ((-140 700, 880 1120, 1280 -120, 300 -600, -480 -480, -140 700), (0 360, 780 500, 240 -220, 0 360))
</a>
<test>
-<op name="buffer" arg1="a" arg3=" 300">
+<op name="buffer" arg1="a" arg2=" 300">
POLYGON ((-778.7369624023256165 -452.5004128279801421, -768.2720863281218726 -396.9385513969818362, -428.2720863281219295 783.0614486030182206, -428.2720863281218726 783.0614486030182206, -408.7534841560095060 833.3100324581969289, -380.5574411245926285 879.2543375195929229, -344.5943435555216752 919.4109263119892148, -302.0253583570249702 952.4832336003277078, -254.2249415762884723 977.4034295424147558, -254.2249415762884439 977.4034295424147558, 765.7750584237115845 1397.4034295424148695, 824.9820997649247829 1414.9119032079297540, 886.5194673034418429 1419.9291525445289608, 947.7806977050495334 1412.2426680322651009, 1006.1710236399521818 1392.1780167347219503, 1059.2172771825498785 1360.5850526513920613, 1104.6726427733435685 1318.8019204868039651, 1140.6118228493280640 1268.5983774849189558, 1165.5125853281651871 1212.1008339768277438, 1165.5125853281651871 1212.1008339768275164, 1565.5125853281651871 -27.8991660231724943, 1565.5125853281651871 -27.8991660231724730, 1578.2479052970841167 -87.6242840094385542, 1578.6248988264201216 -148.6909358667574566, 1566.6279446527257733 -208.5687379618446755, 1542.7541536469450421 -264.7765683433532899, 1507.9927703179562286 -314.9853755612036252, 1463.7841820583996650 -357.1146862282575398, 1411.9602346430190210 -389.4188123961639008, 431.9602346430190778 -869.4188123961638439, 431.9602346430191346 -869.4188123961638439, 375.0205313378135656 -890.4684490229396943, 315.0089731600441496 -899.6243159769932163, 254.3828447238176693 -896.5115092951851921, -525.6171552761823023 -776.5115092951851921, -525.6171552761842349 -776.5115092951848510, -580.4397169479343574 -762.6868643206097431, -631.6948450433227435 -738.8217030839614381, -677.5620519058279569 -705.7636721147999879, -716.4122189080046610 -664.6869317277042910, -746.8654597417037166 -617.0504520125676891, -767.8401314357936371 -564.5461929067481606, -778.5912523203892306 -509.0390088973724687, -778.7369624023256165 -452.5004128279801421))
</op>
</test>
@@ -282,7 +282,7 @@
POLYGON ((-140 700, 880 1120, 1280 -120, 300 -600, -480 -480, -140 700), (0 360, 240 -220, 780 500, 0 360))
</a>
<test>
-<op name="buffer" arg1="a" arg3=" 230">
+<op name="buffer" arg1="a" arg2=" 230">
POLYGON ((-709.0316711751162302 -458.9169831681181222, -701.0085995182267879 -416.3195560710194059, -361.0085995182267879 763.6804439289805941, -346.0443378529406573 802.2043582179510395, -324.4273715288543940 837.4283254316878811, -296.8556633925666119 868.2150435058583753, -264.2194414070523862 893.5704790935845949, -227.5724552084877814 912.6759626491847257, 792.4275447915122186 1332.6759626491846120, 837.8196098197755646 1346.0991257927460083, 884.9982582659720265 1349.9456836174722412, 931.9652015738713544 1344.0527121580698804, 976.7311181239632560 1328.6698128299535711, 1017.3999125066216038 1304.4485403660671636, 1052.2490261262300919 1272.4148057065497142, 1079.8023975178182354 1233.9254227384378737, 1098.8929820849266434 1190.6106393822344671, 1498.8929820849266434 -49.3893606177655755, 1498.8929820849266434 -49.3893606177655542, 1508.6567273944313001 -95.1786177405695497, 1508.9457557669220478 -141.9963841645140405, 1499.7480909004232217 -187.9026991040809094, 1481.4448511293244337 -230.9953690632375469, 1454.7944572437663737 -269.4887879302561373, 1420.9012062447729932 -301.7879261083307938, 1381.1695132263146206 -326.5544228370590076, 401.1695132263146206 -806.5544228370589508, 357.5157406923237318 -822.6924775842537656, 311.5068794227005355 -829.7119755823614469, 265.0268476215935607 -827.3254904596419692, -514.9731523784064393 -707.3254904596419692, -514.9731523784079172 -707.3254904596417418, -557.0037829934162801 -696.7265959791341174, -596.2993811998808269 -678.4299723643704283, -631.4642397944680852 -653.0854819546800627, -661.2493678294702022 -621.5933143245732708, -684.5968524686394403 -585.0720132096352017, -700.6774341007751445 -544.8187478951736011, -708.9199601122983267 -502.2632401546522374, -709.0316711751162302 -458.9169831681181222))
</op>
</test>
@@ -292,7 +292,7 @@
MULTIPOLYGON (((0 400, 440 400, 440 0, 0 0, 0 400),(380 360, 160 120, 260 80, 380 360)), ((360 320, 200 120, 240 100, 360 320)))
</a>
<test>
POLYGON ((-30.0000000000000000 0.0000000000000000, -30.0000000000000000 400.0000000000000000, -29.4235584120969129 405.8527096604838675, -27.7163859753385999 411.4805029709526707, -24.9440883690763577 416.6671069905880813, -21.2132034355964230 421.2132034355964265, -16.6671069905880600 424.9440883690763826, -11.4805029709526902 427.7163859753385964, -5.8527096604838462 429.4235584120968952, 0.0000000000000000 430.0000000000000000, 440.0000000000000000 430.0000000000000000, 445.8527096604838675 429.4235584120968952, 451.4805029709526707 427.7163859753385964, 456.6671069905880813 424.9440883690763826, 461.2132034355964265 421.2132034355964265, 464.9440883690763826 416.6671069905880813, 467.7163859753385964 411.4805029709526707, 469.4235584120968952 405.8527096604838675, 470.0000000000000000 400.0000000000000000, 470.0000000000000000 0.0000000000000000, 469.4235584120968952 -5.8527096604838480, 467.7163859753385964 -11.4805029709526920, 464.9440883690763826 -16.6671069905880671, 461.2132034355964265 -21.2132034355964265, 456.6671069905880813 -24.9440883690763577, 451.4805029709526707 -27.7163859753386035, 445.8527096604838675 -29.4235584120969129, 440.0000000000000000 -30.0000000000000000, 0.0000000000000000 -30.0000000000000000, -0.0000000053875892 -30.0000000000000000, -5.8527096651074020 -29.4235584111772326, -11.4805029746857947 -27.7163859737923026, -16.6671069933878329 -24.9440883672056124, -21.2132034375012282 -21.2132034336916249, -24.9440883701987985 -16.6671069889082126, -27.7163859758540383 -11.4805029697083203, -29.4235584122282994 -5.8527096598233301, -30.0000000000000000 0.0000000000000000))
</op>
</test>
@@ -302,7 +302,7 @@
POLYGON ((60 320, 260 240, 280 60, 60 60, 60 320), (140 240, 100 100, 80 240, 140 240))
</a>
<test>
-<op name="buffer" arg1="a" arg3=" 12.2">
+<op name="buffer" arg1="a" arg2=" 12.2">
POLYGON ((47.7999999999999972 60.0000000000000000, 47.7999999999999972 320.0000000000000000, 48.0315264859667153 322.3655108843300354, 48.7173183186694629 324.6412384206985280, 49.8313461582508239 326.7408070026280598, 51.3313268979948205 328.5845271652299857, 53.1603285264767607 330.1024202117251320, 55.2489309912589661 331.2368742661907959, 57.5178610482016879 331.9448309416234792, 59.8810010902576906 332.1994196279774201, 62.2486577551672084 331.9909773705118141, 64.5309662515200699 331.3274156288001677, 264.5309662515200557 251.3274156288001677, 266.8526771887014775 250.0936026941548675, 268.8561264807556199 248.3910085065419082, 270.4482671257503057 246.2987073331728141, 271.5551546948153714 243.9138727596698857, 272.1253815630181521 241.3472646181131154, 292.1253815630181521 61.3472646181131296, 292.1646248250303870 59.0716127606139096, 291.7804983265691590 56.8282718941085747, 290.9863709586593927 54.6953178079431552, 289.8098810182789293 52.7469844611216772, 288.2919743028874109 51.0510803914519897, 286.4854790592872291 49.6666287509086999, 284.4532673833778631 48.6418131019012137, 282.2660670602604682 48.0123004676292240, 280.0000000000000000 47.7999999999999972, 60.0000000000000000 47.7999999999999972, 59.9999999978090486 47.7999999999999972, 57.6198980695229892 48.0344195794545925, 55.3312621236277806 48.7286697039911303, 53.2220431560222806 49.8560707306697211, 51.3732972687495035 51.3732972702987425, 49.8560707294524903 53.2220431578439914, 48.7286697031526899 55.3312621256519535, 48.0344195790271584 57.6198980716718481, 47.7999999999999972 60.0000000000000000), (94.0667181863941124 227.8000000000000114, 103.9865101885854841 158.3614559846603811, 123.8260941929682275 227.8000000000000114, 94.0667181863941124 227.8000000000000114))
</op>
</test>
@@ -312,7 +312,7 @@
MULTILINESTRING ((635074.5625 6184832.5, 635074.5625 6184832.5, 635074.625 6184832.5), (635074.6875 6184832.5, 635074.6875 6184832.5, 635074.5625 6184832.5))
</a>
<test>
-<op name="buffer" arg1="a" arg3=" .01">
+<op name="buffer" arg1="a" arg2=" .01">
POLYGON ((635074.5524999999906868 6184832.5000000000000000, 635074.5526921472046524 6184832.5019509028643370, 635074.5532612046226859 6184832.5038268342614174, 635074.5541853038594127 6184832.5055557023733854, 635074.5554289321880788 6184832.5070710675790906, 635074.5569442976266146 6184832.5083146961405873, 635074.5586731656221673 6184832.5092387953773141, 635074.5605490967864171 6184832.5098078530281782, 635074.5625000000000000 6184832.5099999997764826, 635074.6250000000000000 6184832.5099999997764826, 635074.6875000000000000 6184832.5099999997764826, 635074.6894509032135829 6184832.5098078530281782, 635074.6913268343778327 6184832.5092387953773141, 635074.6930557023733854 6184832.5083146961405873, 635074.6945710678119212 6184832.5070710675790906, 635074.6958146961405873 6184832.5055557023733854, 635074.6967387953773141 6184832.5038268342614174, 635074.6973078527953476 6184832.5019509028643370, 635074.6975000000093132 6184832.5000000000000000, 635074.6973078527953476 6184832.4980490971356630, 635074.6967387953773141 6184832.4961731657385826, 635074.6958146961405873 6184832.4944442976266146, 635074.6945710678119212 6184832.4929289324209094, 635074.6930557023733854 6184832.4916853038594127, 635074.6913268343778327 6184832.4907612046226859, 635074.6894509032135829 6184832.4901921469718218, 635074.6875000000000000 6184832.4900000002235174, 635074.6250000000000000 6184832.4900000002235174, 635074.5625000000000000 6184832.4900000002235174, 635074.5605490967864171 6184832.4901921469718218, 635074.5586731656221673 6184832.4907612046226859, 635074.5569442976266146 6184832.4916853038594127, 635074.5554289321880788 6184832.4929289324209094, 635074.5541853038594127 6184832.4944442976266146, 635074.5532612046226859 6184832.4961731657385826, 635074.5526921472046524 6184832.4980490971356630, 635074.5524999999906868 6184832.5000000000000000))
</op>
</test>
Modified: trunk/tests/xmltester/buffer_snapround.xml
--- trunk/tests/xmltester/buffer_snapround.xml 2009-04-14 09:22:22 UTC (rev 2351)
+++ trunk/tests/xmltester/buffer_snapround.xml 2009-04-14 09:53:59 UTC (rev 2352)
@@ -7,7 +7,7 @@
</a>
<test>
-<op name="buffer" arg1="A" arg3="30">
+<op name="buffer" arg1="A" arg2="30">
POLYGON ((251.2999850011249 262.9985001124906, 257.5681863594468
262.27215277268783, 263.54579707741004 260.25074266313584,
268.9683548466559 257.0237012990225, 273.5959540907721 252.733799905941,
Modified: trunk/tests/xmltester/fme.xml
--- trunk/tests/xmltester/fme.xml 2009-04-14 09:22:22 UTC (rev 2351)
+++ trunk/tests/xmltester/fme.xml 2009-04-14 09:53:59 UTC (rev 2352)
@@ -12,7 +12,7 @@
POLYGON((377888.21875 5686717.5,377888.09375 5686717.5,377886.46875 5686721,377885.25 5686725,377884.40625 5686730.5,377883.59375 5686735,377883.5625 5686737,377883.5 5686743.5,377883.09375 5686747,377883.03125 5686752.5,377883 5686758,377883.75 5686762,377884.46875 5686767.5,377885.25 5686771.5,377885.21875 5686775,377887.53125 5686781,377891.8125 5686788,377895.4375 5686792,377896.5 5686793,377900.03125 5686797,377905.5 5686802.5,377908.65625 5686804.5,377911.40625 5686807.5,377915.34375 5686809,377918.6875 5686810.5,377920.90625 5686806.5,377923.3125 5686801,377926.09375 5686797.5,377928.21875 5686794.5,377928.90625 5686793.5,377932.09375 5686790.5,377935.6875 5686786,377939.28125 5686782,377944.46875 5686776,377948.0625 5686773,377953.625 5686769,377958.8125 5686765.5,377962.75 5686763.5,377964.0625 5686763,377964.59375 5686762,377965.0625 5686761,377965.5625 5686760,377965.625 5686759,377965.65625 5686759,377966.125 5686758,377967.03125 5686757,377967.46875 5686756.5,377968.46875 5686754.5,377969.71875 5686753.5,377970.625 5686752.5,377971.125 5686751.5,377971.53125 5686751.5,377971.5625 5686751,377973.125 5686751,377975.6875 5686749.5,377978.15625 5686748.5,377978.9375 5686748.5,377979.75 5686748.5,377980.15625 5686748.5,377980.96875 5686748,377981.75 5686748,377982.96875 5686748,377984.15625 5686748,377986.625 5686747,377989 5686747,377990.1875 5686747,377990.96875 5686747,377991.84375 5686746.5,377992.25 5686746,377993.03125 5686746,377993.84375 5686746,377994.65625 5686746,377995.4375 5686746,377996.625 5686746,377997.40625 5686746,377998.59375 5686746.5,377999.375 5686746.5,378000.9375 5686746.5,378001.71875 5686746.5,378002.90625 5686746.5,378003.6875 5686747,378004.46875 5686747,378004.875 5686747,378005.71875 5686746,378006.125 5686746,378007.40625 5686745,378008.21875 5686745,378009.03125 5686745,378009.09375 5686744,378010.375 5686743,378012.40625 5686742.5,378013.6875 5686742,378014.53125 5686741,378015.3125 5686741,378015.34375 5686741,378016.1875 5686740.5,378017.59375 5686738.5,378018.0625 5686737.5,378018.125 5686736.5,378018.59375 5686736,378018.78125 5686734,378018.90625 5686733,378019.03125 5686731,378019.1875 5686729.5,378019.28125 5686729,378019.34375 5686728,378019.40625 5686727.5,378019.5 5686726.5,378019.6875 5686724.5,378020.9375 5686724,378021.40625 5686723,378021.5 5686722,378021.5625 5686721.5,378021.6875 5686720,378021.78125 5686719,378022.5625 5686719.5,378022.625 5686718.5,378022.71875 5686717.5,378022.84375 5686716,378023.3125 5686715.5,378023.4375 5686714,378023.5 5686713.5,378023.65625 5686712,378024.53125 5686711,378025.4375 5686710,378025.46875 5686709.5,378025.96875 5686708.5,378026.78125 5686708,378027.71875 5686706.5,378028.9375 5686706.5,378029.40625 5686705.5,378030.28125 5686705,378031.09375 5686704.5,378031.5625 5686704,378032.84375 5686703,378034.0625 5686702.5,378034.96875 5686701.5,378035.8125 5686701,378036.25 5686700.5,378036.6875 5686700,378037.53125 5686699.5,378037.9375 5686699.5,378038.78125 5686698.5,378039.1875 5686698.5,378040.0625 5686698,378040.875 5686697.5,378042.125 5686697,378042.5625 5686696.5,378043.78125 5686696.5,378044.5625 5686696.5,378045.34375 5686696.5,378046.125 5686696.5,378047.40625 5686695.5,378049.03125 5686695.5,378049.84375 5686695,378050.65625 5686694.5,378051.5 5686694.5,378052.3125 5686694,378053.59375 5686693,378054.8125 5686692.5,378055.59375 5686693,378055.6875 5686692,378056.15625 5686691.5,378057.78125 5686690.5,378059 5686690.5,378059.84375 5686690,378060.25 5686689.5,378060.65625 5686690,378061.4375 5686690,378061.84375 5686690,378062.6875 5686689,378063.46875 5686689.5,378064.65625 5686689.5,378065.0625 5686689.5,378066.28125 5686689,378067.0625 5686689,378067.84375 5686689.5,378069.40625 5686689.5,378070.96875 5686689.5,378071.375 5686689.5,378071.78125 5686689.5,378072.5625 5686690,378073.34375 5686690,378074.40625 5686691,378075.5 5686692,378076.25 5686692.5,378076.96875 5686693.5,378077.6875 5686694.5,378078.4375 5686694.5,378079.15625 5686695,378079.125 5686695.5,378079.53125 5686695.5,378079.4375 5686696.5,378080.4375 5686698.5,378080.71875 5686699.5,378080.5625 5686701.5,378081.21875 5686703,378081.0625 5686704.5,378080.9375 5686705.5,378080.84375 5686707,378081.5 5686708,378082.1875 5686709.5,378082.90625 5686710.5,378083.21875 5686711,378083.125 5686712,378083.5 5686712.5,378083.40625 5686713,378084.59375 5686713,378085.6875 5686714,378086.4375 5686714.5,378088.8125 5686715,378091.46875 5686716,378093.78125 5686716.5,378094.59375 5686716.5,378095.28125 5686717.5,378095.6875 5686717.5,378096.0625 5686717.5,378096.875 5686717.5,378097.65625 5686717.5,378098.8125 5686718,378100.1875 5686716,378102.3125 5686714.5,378102.78125 5686714,378102.84375 5686713,378104.03125 5686713,378105.34375 5686712,378107.4375 5686711,378108.65625 5686710.5,378109.0625 5686710,378109.875 5686710,378110.65625 5686710.5,378111.90625 5686709.5,378113.0625 5686710,378115.125 5686709,378116.6875 5686709.5,378117.53125 5686708.5,378117.96875 5686708.5,378118.8125 5686708,378119.28125 5686707,378120.1875 5686705.5,378121.46875 5686705,378122.34375 5686704,378122.84375 5686703,378123.71875 5686702,378124.15625 5686701.5,378125.09375 5686700,378125.5 5686700,378127.28125 5686698,378128.96875 5686697,378129.8125 5686696.5,378130.6875 5686695.5,378131.46875 5686695.5,378132.28125 5686695.5,378133.0625 5686695.5,378134.625 5686695.5,378135.8125 5686696,378137.78125 5686696,378139.34375 5686696,378140.1875 5686696,378140.96875 5686696,378141.0625 5686694.5,378142.3125 5686694,378142.84375 5686693,378144.09375 5686692,378144.9375 5686691.5,378145.84375 5686690.5,378146.28125 5686690,378147.125 5686689.5,378147.96875 5686689,378149.1875 5686689,378150.8125 5686688,378152.4375 5686688,378153.59375 5686688,378154 5686688,378155.1875 5686688,378155.96875 5686688.5,378156.34375 5686688.5,378156.75 5686688.5,378156.84375 5686687,378156.15625 5686686.5,378155.90625 5686684.5,378155.1875 5686684,378155.28125 5686683,378154.46875 5686683,378153.5 5686681,378152.0625 5686679,378151.71875 5686678.5,378151.75 5686678.5,378150.96875 5686678,378150.625 5686678,378149.5 5686677,378148.375 5686676.5,378148.09375 5686675,378146.9375 5686674.5,378146.5625 5686674.5,378146.625 5686674,378146.65625 5686673.5,378145.875 5686673.5,378146.0625 5686671.5,378145.4375 5686669.5,378145.125 5686669,378145.1875 5686668,378145.28125 5686667.5,378145.34375 5686666.5,378145.375 5686666,378145.53125 5686664.5,378146.375 5686664,378146.9375 5686662.5,378147.03125 5686661,378147.90625 5686660.5,378147.96875 5686659.5,378148.46875 5686658.5,378149.34375 5686658,378149.8125 5686657,378149.84375 5686656.5,378149.875 5686656.5,378150.65625 5686656.5,378151.53125 5686655.5,378152.3125 5686655.5,378153.09375 5686656,378154 5686654.5,378155.65625 5686654,378156.46875 5686654,378157.34375 5686653,378158.15625 5686652.5,378158.59375 5686652.5,378159.84375 5686651.5,378161.0625 5686651.5,378161.875 5686651,378162.75 5686650.5,378163.5625 5686650,378164.40625 5686649.5,378165.65625 5686648.5,378167.28125 5686648.5,378168.53125 5686648,378169.40625 5686647,378169.78125 5686647,378169.875 5686646.5,378170.65625 5686646.5,378171.0625 5686646,378171.15625 5686645.5,378171.96875 5686645,378172.15625 5686643,378172.28125 5686642,378172.375 5686640.5,378172.84375 5686640,378172.96875 5686638.5,378173.4375 5686638,378173.9375 5686637,378174 5686636,378174.9375 5686634.5,378175.03125 5686634,378175.0625 5686633.5,378175.09375 5686633,378176 5686632,378176.03125 5686631.5,378176.1875 5686630,378176.25 5686629,378176.34375 5686628.5,378176.375 5686628,378176.59375 5686628,378182.875 5686630.5,378186.8125 5686632,378193.09375 5686633.5,378194.34375 5686630,378194.78125 5686625.5,378194.46875 5686618,378193.6875 5686614,378192.96875 5686607.5,378192.21875 5686604,378191.0625 5686599.5,378189.9375 5686593.5,378188.78125 5686588,378187.6875 5686580,378187.71875 5686575.5,378187.71875 5686574,378187.75 5686571,378186.59375 5686567.5,378186.65625 5686563,378187.5 5686557,378188.3125 5686553.5,378189.90625 5686550.5,378192.3125 5686546.5,378195.125 5686543,378196.5 5686541.5,378196.6875 5686539.5,378197.625 5686538,378198.09375 5686537,378198.21875 5686536,378198.25 5686535.5,378198.71875 5686535,378198.8125 5686533.5,378198.90625 5686533,378199.6875 5686533,378199.84375 5686531.5,378201.5625 5686530,378202.8125 5686529.5,378203.3125 5686528,378203.6875 5686528,378203.78125 5686527.5,378204.15625 5686527.5,378205.03125 5686526.5,378206.21875 5686527,378206.71875 5686525.5,378207.5625 5686525,378208 5686524.5,378208.46875 5686524,378209.4375 5686522,378211.09375 5686521.5,378212.40625 5686520,378213.71875 5686519,378214.5625 5686518,378215.03125 5686517.5,378215.875 5686517,378216.28125 5686517,378217.15625 5686516,378217.59375 5686515.5,378218.4375 5686515,378219.65625 5686514.5,378220.46875 5686514.5,378220.5625 5686513.5,378221.375 5686513.5,378221.78125 5686513.5,378222.59375 5686513,378223.09375 5686512,378223.90625 5686511.5,378225.28125 5686509.5,378226.96875 5686508.5,378227.84375 5686508,378228.25 5686507.5,378228.71875 5686507,378228.75 5686506.5,378229.21875 5686505.5,378230.09375 5686505,378230.125 5686504.5,378231.0625 5686503,378231.9375 5686502.5,378232.4375 5686501.5,378233.34375 5686500,378234.21875 5686499,378235.09375 5686498.5,378235.9375 5686497.5,378236.40625 5686497,378237.3125 5686496,378237.8125 5686494.5,378238.71875 5686493.5,378239.21875 5686492.5,378240.125 5686491.5,378241.0625 5686490,378241.5625 5686488.5,378242.46875 5686487.5,378242.875 5686487.5,378243.34375 5686486.5,378243.8125 5686486,378244.65625 5686485.5,378245.53125 5686484.5,378246.78125 5686483.5,378247.3125 5686482.5,378247.84375 5686481,378248.3125 5686480.5,378248.4375 5686479,378248.5 5686478.5,378248.96875 5686477.5,378249.8125 5686477,378249.90625 5686476,378250.09375 5686474,378251 5686473,378251.53125 5686471.5,378251.65625 5686470.5,378251.75 5686469,378252.21875 5686468.5,378252.71875 5686467,378252.75 5686467,378252.84375 5686466,378253.09375 5686463.5,378254.4375 5686462,378255.3125 5686460.5,378255.4375 5686459.5,378255.5 5686458.5,378255.90625 5686459,378257 5686455.5,378258.40625 5686453.5,378258.5 5686452.5,378259.0625 5686450.5,378259.125 5686450,378260.78125 5686447,378262.78125 5686443.5,378265.59375 5686439,378266.9375 5686437,378269.1875 5686434,378270.28125 5686433,378270.625 5686432.5,378271.15625 5686432,378271.34375 5686429.5,378272.28125 5686428,378272.75 5686427.5,378272.84375 5686426.5,378272.875 5686426.5,378273.25 5686426.5,378274.15625 5686425.5,378274.25 5686424.5,378274.375 5686423,378275.71875 5686421.5,378276.625 5686420.5,378276.71875 5686419,378277.15625 5686419,378277.21875 5686418,378278 5686418,378278.5625 5686416.5,378279.5 5686415,378279.5625 5686414.5,378279.65625 5686413.5,378280.15625 5686412.5,378280.5625 5686412,378281.5 5686410.5,378282.375 5686410,378282.40625 5686409.5,378282.4375 5686409,378282.96875 5686408,378284.21875 5686407,378284.75 5686405.5,378284.78125 5686405.5,378284.8125 5686405,378285.25 5686404.5,378286.0625 5686404,378286.46875 5686404,378287 5686402.5,378288.6875 5686401.5,378289.125 5686401.5,378290 5686400.5,378290.375 5686400.5,378291.1875 5686400.5,378292 5686400.5,378293.15625 5686400.5,378293.9375 5686400.5,378295.53125 5686401,378295.90625 5686401,378296.6875 5686401,378297.09375 5686401,378298.15625 5686402.5,378299.3125 5686403,378299.96875 5686404,378301.03125 5686405.5,378302.09375 5686406.5,378302.78125 5686408,378303.53125 5686408.5,378303.84375 5686409,378304.15625 5686410,378304.09375 5686411,378304.84375 5686411.5,378305.625 5686411.5,378306.6875 5686412.5,378307.03125 5686413,378308.15625 5686414,378309.28125 5686414.5,378309.96875 5686416,378310.65625 5686416.5,378311.375 5686417.5,378312.09375 5686418.5,378313.21875 5686419,378313.1875 5686419.5,378313.9375 5686419.5,378314.34375 5686420,378315.40625 5686421,378316.9375 5686421.5,378319.9375 5686423.5,378322.21875 5686424.5,378323.3125 5686425.5,378324.03125 5686426.5,378325.15625 5686427,378325.53125 5686427.5,378326.3125 5686427.5,378326.625 5686428,378327.75 5686428.5,378328.15625 5686428.5,378329.25 5686429.5,378330.03125 5686429.5,378331.09375 5686431,378332.65625 5686431.5,378333.71875 5686433,378334.375 5686434,378335.4375 5686435.5,378336.15625 5686436.5,378337.25 5686437,378337.9375 5686438.5,378338.65625 5686439.5,378339.34375 5686440,378340.09375 5686440.5,378340.46875 5686441,378341.15625 5686442,378342.3125 5686442.5,378343.8125 5686443.5,378344.90625 5686444.5,378345.25 5686445,378345.21875 5686445,378345.96875 5686445.5,378346.75 5686445.5,378348.1875 5686447.5,378350.09375 5686448,378350.8125 5686449,378351.5625 5686449.5,378352.34375 5686449.5,378353.0625 5686450.5,378353.46875 5686450.5,378354.5625 5686451.5,378354.90625 5686451.5,378355.625 5686452.5,378356.375 5686453,378357.84375 5686454.5,378359.375 5686455,378360.46875 5686456,378361.1875 5686456.5,378362.28125 5686457.5,378363 5686458.5,378364.125 5686459,378364.5 5686459.5,378365.5625 5686460.5,378366.3125 5686461,378367.09375 5686461.5,378367 5686462,378368.59375 5686462,378370.46875 5686463,378372.4375 5686463.5,378373.21875 5686463.5,378374.375 5686464,378375.9375 5686464,378378.6875 5686464.5,378379.84375 5686464.5,378380.65625 5686464.5,378381.4375 5686464.5,378381.8125 5686465,378382.25 5686464.5,378384.25 5686464,378385.5 5686463.5,378386.6875 5686463.5,378387.875 5686464,378387.90625 5686463.5,378388.71875 5686463,378389.5 5686463,378391.15625 5686462.5,378393.125 5686462.5,378394.375 5686462,378395.1875 5686461.5,378395.625 5686461.5,378395.65625 5686461,378396.4375 5686461,378396.59375 5686459.5,378397.40625 5686459,378398.3125 5686458,378398.40625 5686457.5,378399.28125 5686456,378399.75 5686455.5,378399.90625 5686454,378400.03125 5686452.5,378400.09375 5686452,378400.21875 5686450.5,378400.34375 5686449,378400.46875 5686448,378400.59375 5686447,378400.71875 5686445,378401.1875 5686444.5,378401.3125 5686443.5,378401.4375 5686442,378401.5 5686441.5,378401.625 5686440,378401.6875 5686439.5,378401.75 5686438.5,378401.5625 5686436.5,378401.71875 5686435,378401.8125 5686434,378402.09375 5686431,378402.21875 5686429.5,378402.40625 5686427.5,378402.65625 5686425,378402.78125 5686423.5,378402.9375 5686422,378403.0625 5686421,378403.15625 5686419.5,378402.84375 5686419,378402.65625 5686417,378402.78125 5686415,378402.9375 5686413.5,378403.03125 5686413,378402.6875 5686412,378402.78125 5686411,378402.84375 5686410.5,378402.96875 5686409.5,378403.03125 5686408.5,378402 5686407,378402.125 5686405.5,378402.1875 5686405,378401.875 5686404,378401.5625 5686403,378400.875 5686402,378401.0625 5686400,378400.03125 5686398.5,378399.4375 5686396,378398.84375 5686394,378398.5625 5686393,378398.6875 5686392,378397.96875 5686391,378398.09375 5686389.5,378398.15625 5686389,378397.84375 5686388,378397.59375 5686386.5,378396.9375 5686385,378397.125 5686383.5,378397.34375 5686381,378397.0625 5686379.5,378396.8125 5686378,378396.5 5686377,378396.53125 5686377,378396.65625 5686375.5,378396.71875 5686375,378396.9375 5686372.5,378396.6875 5686371,378396.96875 5686368,378398.3125 5686366.5,378398.75 5686366,378398.84375 5686365,378398.90625 5686364.5,378400.90625 5686364,378401.8125 5686363,378402.625 5686363,378403.4375 5686362.5,378403.5 5686362,378403.59375 5686361,378404.8125 5686360.5,378405.59375 5686360.5,378406.46875 5686360,378408.09375 5686359.5,378409.03125 5686358,378410.3125 5686357,378411.09375 5686357,378411.15625 5686356.5,378411.96875 5686356,378412.78125 5686356,378414.0625 5686355,378415.6875 5686354.5,378416.53125 5686354,378416.5625 5686354,378416.96875 5686354,378417.75 5686354,378419 5686353.5,378420.21875 5686353,378420.59375 5686353,378421.375 5686353,378422.5625 5686353,378424.59375 5686352.5,378425.8125 5686352.5,378426.59375 5686352.5,378426.65625 5686352,378429 5686352.5,378430.40625 5686351.5,378430.6875 5686351.5,378432.28125 5686351,378433.0625 5686351,378433.46875 5686351,378434.25 5686351,378434.65625 5686351.5,378436.21875 5686351.5,378437.40625 5686351.5,378438.1875 5686351.5,378438.5625 5686351.5,378440.15625 5686352,378441.3125 5686352,378442.0625 5686352.5,378442.46875 5686352.5,378443.65625 5686352.5,378444.8125 5686352.5,378446 5686353,378446.40625 5686353,378447.1875 5686353,378447.96875 5686353,378448.8125 5686352.5,378451.21875 5686352,378452.5 5686351,378453.375 5686350.5,378453.75 5686350.5,378453.84375 5686349.5,378454.625 5686349.5,378454.71875 5686348.5,378455.59375 5686348,378456.5 5686346.5,378456.96875 5686346,378457.0625 5686345,378457.15625 5686344,378457.25 5686343,378457.34375 5686342,378457.59375 5686339.5,378458.125 5686338,378458.3125 5686336,378458.5625 5686333.5,378458.625 5686332.5,378458.75 5686331.5,378458.84375 5686330.5,378458.875 5686330,378459.03125 5686328.5,378458.6875 5686328,378457.625 5686326.5,378457.65625 5686326,378457.25 5686326,378456.6875 5686323.5,378452.53125 5686321.5,378451.09375 5686320,378450.4375 5686318.5,378449.65625 5686318.5,378448.9375 5686318,378448.59375 5686317.5,378447.90625 5686316,378446.8125 5686315,378446.15625 5686313.5,378445.53125 5686312,378445.28125 5686310,378445.4375 5686308.5,378445.5625 5686307.5,378445.25 5686306.5,378445.3125 5686306,378445.375 5686305,378445.625 5686302.5,378445.71875 5686301.5,378445.875 5686300,378446.03125 5686298.5,378446.09375 5686297.5,378446.1875 5686297,378446.28125 5686295.5,378446.3125 5686295,378447.1875 5686294.5,378447.21875 5686294,378447.625 5686294,378448 5686294,378448.09375 5686293.5,378448.125 5686293,378448.15625 5686292.5,378450.5 5686293,378451.8125 5686292,378452.28125 5686291,378452.6875 5686290.5,378452.75 5686290.5,378453.53125 5686290.5,378454.09375 5686288.5,378456.1875 5686287.5,378456.71875 5686286,378457.65625 5686284.5,378457.6875 5686284,378458.125 5686283.5,378458.53125 5686284,378459.3125 5686284,378460.59375 5686283,378462.28125 5686282,378463.0625 5686282,378463.125 5686281,378464.03125 5686280,378464.84375 5686279.5,378466.625 5686278,378467.875 5686277,378468.71875 5686276.5,378469.1875 5686275.5,378469.625 5686275.5,378470.0625 5686275,378470.90625 5686274.5,378471.75 5686274,378473.0625 5686272.5,378474.3125 5686272,378474.78125 5686271,378475.65625 5686270.5,378476.5 5686269.5,378477.40625 5686268.5,378477.84375 5686268,378478.6875 5686267.5,378480 5686266.5,378481.25 5686266,378481.75 5686265.5,378482.0625 5686265.5,378482.5 5686265,378483.4375 5686263.5,378485.875 5686263,378487.59375 5686261.5,378489.34375 5686260,378490.1875 5686259,378491.09375 5686258,378491.96875 5686257.5,378492.375 5686257,378493.25 5686256.5,378493.6875 5686256,378494.5625 5686255,378496.21875 5686254,378497.5625 5686252.5,378498.875 5686251.5,378499.75 5686250.5,378500.625 5686249.5,378501.0625 5686249,378501.9375 5686248.5,378502.78125 5686247.5,378503.21875 5686247.5,378504.0625 5686246.5,378504.90625 5686246.5,378505.8125 5686245,378506.625 5686245,378507.46875 5686244,378507.9375 5686243.5,378508.5 5686242,378510.125 5686241.5,378511.4375 5686240,378511.9375 5686239,378512.78125 5686238.5,378513.65625 5686237.5,378514.90625 5686237,378515.8125 5686236,378516.65625 5686235,378517.90625 5686234.5,378518.75 5686234,378519.59375 5686233.5,378520 5686233.5,378520.78125 5686233.5,378521.625 5686233,378522.5 5686232,378524.15625 5686231.5,378525.75 5686231.5,378526.65625 5686230.5,378527.90625 5686229.5,378528.71875 5686229.5,378529.59375 5686228.5,378530.8125 5686228.5,378531.625 5686228,378532.875 5686227.5,378534.09375 5686227,378534.875 5686227,378535.75 5686226.5,378536.5625 5686226,378537.46875 5686225,378539.0625 5686225,378539.9375 5686224,378539.96875 5686223.5,378540.78125 5686223.5,378541.6875 5686222,378542.5625 5686221.5,378543.84375 5686220.5,378545.0625 5686220,378546.34375 5686219,378547.21875 5686218.5,378548.0625 5686217.5,378548.9375 5686217,378549.78125 5686216.5,378550.21875 5686216,378551.0625 5686215,378551.90625 5686215,378552.71875 5686214.5,378553.59375 5686214,378554.4375 5686213,378556.0625 5686213,378557.3125 5686212.5,378558.15625 5686211.5,378559.375 5686211.5,378559.8125 5686211,378560.59375 5686211,378560.6875 5686210.5,378561.46875 5686210.5,378561.5 5686210,378561.6875 5686208,378563.84375 5686206,378564.90625 5686203,378566 5686200,378566.5 5686199,378567 5686198,378567.46875 5686197,378567.5625 5686196.5,378567.59375 5686196,378567.65625 5686195,378568.0625 5686195,378569.0625 5686193,378570.03125 5686191,378570.9375 5686190,378571.40625 5686189,378571.875 5686188.5,378572.3125 5686188,378572.8125 5686187,378573.6875 5686186,378575.40625 5686184.5,378577.0625 5686183.5,378578.375 5686182.5,378578.875 5686181.5,378579.6875 5686181,378579.78125 5686180.5,378580.25 5686179.5,378580.375 5686178,378581.21875 5686178,378582.53125 5686176.5,378583.4375 5686175,378583.90625 5686174.5,378584.8125 5686173.5,378585.28125 5686172.5,378585.34375 5686172,378586.3125 5686170,378587.21875 5686169,378588.0625 5686168,378588.59375 5686167,378589.03125 5686166,378589.5 5686165.5,378590.40625 5686164.5,378591.65625 5686163.5,378592.09375 5686163.5,378592.15625 5686162.5,378593 5686162.5,378593.0625 5686161.5,378593.09375 5686161,378593.53125 5686160.5,378593.96875 5686160,378598.0625 5686158,378601.25 5686156.5,378604.40625 5686156.5,378609.15625 5686154,378615.125 5686151.5,378618.28125 5686151.5,378622.65625 5686149.5,378625.84375 5686146,378628.21875 5686143.5,378628.25 5686140,378628.25 5686139.5,378629.46875 5686136,378630.3125 5686132,378631.90625 5686129,378635.53125 5686123.5,378640.65625 5686123,378645 5686122.5,378649.5 5686122,378649.5625 5686122,378650.40625 5686121.5,378651.3125 5686120,378651.84375 5686119,378651.875 5686118.5,378652.6875 5686118,378653.1875 5686117,378654.84375 5686116.5,378655.75 5686115.5,378656.25 5686114,378657.09375 5686113.5,378657.5625 5686113,378658.4375 5686112,378658.90625 5686111.5,378659.8125 5686110,378659.84375 5686110,378660.8125 5686108,378661.65625 5686107,378662.1875 5686106,378662.25 5686105.5,378663.0625 5686105,378663.15625 5686104,378663.25 5686103,378664.5625 5686102,378665.4375 5686101,378665.53125 5686100,378665.59375 5686099.5,378666.0625 5686098.5,378666.65625 5686096.5,378666.71875 5686096,378666.78125 5686095,378666.84375 5686094.5,378666.90625 5686094,378667.15625 5686091,378667.28125 5686090,378667.34375 5686089,378667.40625 5686088.5,378667.46875 5686088,378667.65625 5686086,378666.59375 5686084.5,378665.96875 5686083,378665.28125 5686082,378664.96875 5686081,378665.03125 5686080,378663.875 5686080,378662.59375 5686076.5,378660.5 5686073.5,378659.78125 5686073,378659.46875 5686072,378659.0625 5686072,378659.15625 5686071,378658.375 5686071,378658.4375 5686070.5,378656.9375 5686069.5,378656.21875 5686068.5,378654.84375 5686066.5,378654.1875 5686065,378653.90625 5686064,378653.53125 5686063.5,378653.5625 5686063,378652.90625 5686062,378652.96875 5686061,378652.34375 5686059.5,378651.625 5686058.5,378651.375 5686057,378651.53125 5686055.5,378651.5625 5686055,378651.625 5686054.5,378651.71875 5686053.5,378651.75 5686053,378651.84375 5686052,378651.90625 5686051.5,378651.9375 5686051,378652.84375 5686050,378652.9375 5686049,378653 5686048.5,378653.03125 5686048,378653.4375 5686048,378654.375 5686046.5,378654.84375 5686045.5,378654.875 5686045.5,378654.90625 5686045,378655.3125 5686045,378656.1875 5686044,378657.0625 5686043,378657.4375 5686043,378657.84375 5686043.5,378658.625 5686043.5,378659.40625 5686043.5,378660.625 5686043,378661.03125 5686043,378662.1875 5686043.5,378662.59375 5686043.5,378663.78125 5686043.5,378664.15625 5686043.5,378665.34375 5686043.5,378666.125 5686043.5,378666.90625 5686044,378668.09375 5686044,378668.875 5686044,378669.65625 5686044,378670.4375 5686044,378671.21875 5686044,378672.40625 5686044.5,378673.1875 5686044.5,378674.4375 5686043.5,378675.25 5686044,378676.8125 5686044,378677.1875 5686044,378678 5686044,378679.15625 5686044,378679.5625 5686044.5,378680.78125 5686044,378681.5625 5686044,378681.9375 5686044,378682.75 5686044,378683.90625 5686044.5,378686.34375 5686044,378687.90625 5686044,378688.75 5686043.5,378689.53125 5686043.5,378690.84375 5686042,378691.71875 5686041.5,378692.15625 5686041,378693.40625 5686040.5,378693.78125 5686040.5,378695.03125 5686040,378695.90625 5686039,378696.84375 5686037.5,378697.28125 5686037.5,378698.1875 5686036,378699.0625 5686035,378699.96875 5686034,378700.03125 5686033,378700.9375 5686032,378701.40625 5686031.5,378701.90625 5686030,378702.03125 5686029,378702.875 5686028.5,378703 5686027,378703.125 5686025.5,378704 5686025,378704.53125 5686023.5,378704.65625 5686022,378704.78125 5686021,378704.875 5686020,378705 5686018.5,378705.0625 5686018,378705.1875 5686016.5,378705.21875 5686016.5,378705.375 5686014.5,378704.6875 5686013.5,378703.28125 5686011.5,378702.40625 5686008.5,378701.71875 5686007,378701.84375 5686006,378702.03125 5686004,378702.21875 5686002,378702.28125 5686001.5,378702.3125 5686001,378703.09375 5686001,378703.15625 5686000.5,378703.71875 5685994.5,378704.15625 5685990,378704.21875 5685989,378704.3125 5685988.5,378704.40625 5685987,378705.3125 5685986,378705.5625 5685983.5,378705.6875 5685982,378705.75 5685981.5,378705.8125 5685981,378706.1875 5685981,378706.3125 5685980,378707.5625 5685979,378708.5625 5685977,378709.5 5685975.5,378709.53125 5685975,378709.59375 5685974.5,378709.96875 5685974.5,378710.125 5685973,378712.21875 5685971.5,378713.0625 5685971.5,378713.09375 5685971,378713.21875 5685970,378714.03125 5685969.5,378715.4375 5685967,378716.75 5685966,378717.1875 5685965.5,378717.25 5685964.5,378718.0625 5685964.5,378718.59375 5685963,378720.65625 5685962,378722.03125 5685960.5,378723.28125 5685959.5,378723.75 5685959,378724.21875 5685958,378724.625 5685958,378724.65625 5685958,378725.46875 5685957.5,378726.375 5685956.5,378727.1875 5685956,378728.5625 5685954.5,378730.25 5685953,378731.09375 5685952.5,378731.625 5685951.5,378732.46875 5685950.5,378733.375 5685949.5,378733.8125 5685949,378733.875 5685948.5,378735.09375 5685948,378736 5685947,378736.8125 5685946.5,378738.09375 5685945.5,378739.34375 5685945,378740.1875 5685944.5,378740.59375 5685944.5,378741.46875 5685943.5,378741.875 5685943.5,378743.15625 5685942.5,378744.375 5685942.5,378745.15625 5685942.5,378746 5685941.5,378746.84375 5685941.5,378748.09375 5685940.5,378748.46875 5685941,378749.6875 5685940.5,378750.09375 5685940.5,378751.75 5685940,378752.53125 5685940,378753.8125 5685939,378755.53125 5685939,378758.5 5685935.5,378761.6875 5685932.5,378766.875 5685927.5,378770.46875 5685924,378774.84375 5685920,378778.8125 5685917,378783.21875 5685913,378787.96875 5685909.5,378793.53125 5685906.5,378796.71875 5685904.5,378799.5 5685903.5,378802.65625 5685903,378806.25 5685899.5,378808.09375 5685898,378808.65625 5685896,378809.9375 5685895,378810.4375 5685894,378810.59375 5685892,378811.40625 5685892,378811.5 5685891,378812.4375 5685889.5,378813.28125 5685889,378813.75 5685888,378813.875 5685887,378813.9375 5685886,378814.4375 5685885,378815.40625 5685883,378816.28125 5685882.5,378816.78125 5685881.5,378816.90625 5685880,378816.96875 5685879.5,378817 5685879,378817.125 5685878,378817.96875 5685877,378819.09375 5685873.5,378819.25 5685872,378819.40625 5685870.5,378819.5625 5685869,378819.625 5685868,378819.75 5685867,378819.84375 5685865.5,378819.96875 5685864.5,378820.1875 5685862,378820.3125 5685861,378820.5 5685859,378820.53125 5685858.5,378820.6875 5685857,378820.8125 5685855.5,378820.9375 5685854.5,378821 5685853.5,378821.0625 5685853,378821.46875 5685849,378821.0625 5685845,378821.1875 5685843,378821.3125 5685842,378821.375 5685841.5,378821.46875 5685840.5,378821.5 5685840,378820.78125 5685839,378820.59375 5685837,378820.3125 5685836,378820.375 5685835,378820.5 5685834,378820.21875 5685833,378817.96875 5685831.5,378817.3125 5685825.5,378814.8125 5685822.5,378813.875 5685820,378813.28125 5685818,378812.5625 5685817.5,378812.28125 5685816,378811.9375 5685815.5,378812 5685815,378809.25 5685814.5,378806.71875 5685812,378803.8125 5685809.5,378801.96875 5685808,378801.25 5685807,378800.0625 5685807,378799.75 5685806,378799.375 5685806,378798.625 5685805.5,378797.84375 5685805.5,378794.28125 5685805,378792.71875 5685805,378790.75 5685805,378789.59375 5685804.5,378789.1875 5685804.5,378788.40625 5685804.5,378787.625 5685804.5,378786.84375 5685804.5,378785.65625 5685804.5,378784.09375 5685804,378782.03125 5685804.5,378780.875 5685804.5,378780.09375 5685804.5,378779.28125 5685804.5,378778.90625 5685804.5,378777.6875 5685804.5,378775.34375 5685804.5,378773.65625 5685805.5,378772.4375 5685805.5,378771.21875 5685806,378770.40625 5685806.5,378769.59375 5685806,378768.8125 5685806,378767.65625 5685806,378767.25 5685806,378766.0625 5685806,378765.6875 5685806,378764.53125 5685805.5,378763.75 5685805,378762.6875 5685804,378761.1875 5685803,378760 5685803,378759.28125 5685802.5,378758.09375 5685802.5,378757.3125 5685802,378756.125 5685802,378755.90625 5685802,378754.9375 5685802,378752.1875 5685801.5,378750.625 5685801.5,378749.84375 5685801.5,378748.65625 5685801.5,378747.875 5685801,378746.65625 5685801.5,378745.46875 5685801.5,378745.0625 5685801.5,378744.1875 5685802.5,378743.375 5685803,378742.125 5685803.5,378740.875 5685804,378740 5685805,378739.15625 5685805.5,378738.28125 5685806,378737.8125 5685807,378737.03125 5685807,378737 5685807.5,378736.21875 5685807,378734.8125 5685809.5,378731.875 5685811,378730.625 5685812,378730.53125 5685812.5,378729.375 5685812.5,378727.59375 5685814.5,378723.90625 5685815.5,378723.0625 5685816,378722.625 5685816.5,378721.84375 5685816.5,378721.03125 5685817,378720.59375 5685817,378719.65625 5685818.5,378717.65625 5685819,378716.375 5685820,378715.46875 5685821,378714.65625 5685821.5,378714.59375 5685821.5,378713.75 5685822.5,378713.3125 5685823,378712.375 5685824.5,378711.90625 5685825,378711.84375 5685826,378711.75 5685826.5,378711.6875 5685827.5,378710.8125 5685828,378710.25 5685830,378709.75 5685831,378709.59375 5685832.5,378709.46875 5685834,378709.375 5685835,378708.46875 5685836,378707.96875 5685837.5,378707.875 5685838,378707 5685839,378706.90625 5685840,378705.90625 5685842.5,378705.03125 5685843,378704.5 5685844.5,378704.34375 5685846,378703.53125 5685846.5,378703.46875 5685847,378702.5625 5685848.5,378702.09375 5685849,378700.75 5685850.5,378699.90625 5685851,378699.03125 5685852,378698.1875 5685852.5,378697.3125 5685853.5,378696.84375 5685854,378696 5685855,378695.53125 5685855.5,378694.65625 5685856.5,378694.1875 5685857,378692.90625 5685858,378691.21875 5685859,378690.375 5685860,378689.875 5685861,378689.03125 5685861,378688.59375 5685861.5,378687.75 5685862.5,378686.9375 5685862.5,378686.125 5685862.5,378685.75 5685862.5,378684.84375 5685863.5,378683.625 5685864,378681.9375 5685865,378680.34375 5685865,378679.5625 5685865,378678.78125 5685865,378677.90625 5685865.5,378676.71875 5685865.5,378674.3125 5685866,378672.34375 5685866,378671.15625 5685866,378670.375 5685865.5,378669.125 5685866.5,378668.34375 5685866.5,378667.09375 5685867,378665.90625 5685867,378665.03125 5685867.5,378664.1875 5685868.5,378663.34375 5685868.5,378662.90625 5685869.5,378662.46875 5685869.5,378661.6875 5685869.5,378660.375 5685870.5,378658.78125 5685871,378657.96875 5685871,378657.125 5685871.5,378656.6875 5685872,378655.875 5685872,378654.125 5685874,378652.46875 5685874.5,378651.1875 5685875.5,378650.3125 5685876.5,378649.46875 5685877,378648.625 5685877.5,378648.1875 5685878,378647.75 5685878.5,378646.90625 5685879,378646.4375 5685879.5,378645.59375 5685880.5,378643.9375 5685881,378643.46875 5685881.5,378642.65625 5685882,378641.78125 5685882.5,378640.9375 5685883.5,378639.71875 5685883.5,378638.84375 5685884.5,378638.375 5685885,378637.5625 5685885.5,378636.75 5685886,378636.3125 5685886,378635.46875 5685887,378635.0625 5685887,378633.6875 5685888.5,378632.0625 5685889.5,378630.8125 5685890,378630.28125 5685891,378629.4375 5685892,378629 5685892,378628.5625 5685892.5,378628.5 5685893.5,378627.625 5685894,378627.21875 5685894.5,378626.28125 5685896,378625.03125 5685896.5,378624.5 5685897.5,378624.03125 5685898.5,378623.15625 5685899.5,378622.65625 5685900.5,378622.34375 5685901,378623.25 5685903,378626.75 5685907.5,378629.09375 5685910.5,378631.03125 5685914.5,378633.375 5685918.5,378636.125 5685922.5,378637.65625 5685928,378638.40625 5685931.5,378638.34375 5685938,378636.34375 5685941.5,378634.3125 5685945.5,378628.34375 5685951.5,378627.09375 5685951.5,378627.4375 5685954.5,378629.5625 5685957,378630.5625 5685959,378631.125 5685961.5,378631.4375 5685962.5,378631.375 5685963,378632.125 5685963.5,378632.09375 5685964,378632.40625 5685965,378632.65625 5685966.5,378633.34375 5685967.5,378634.3125 5685970,378634.96875 5685971,378634.9375 5685971.5,378634.875 5685972,378635.53125 5685973.5,378635.90625 5685974,378636.53125 5685975.5,378637.25 5685976.5,378637.15625 5685977,378637.09375 5685978,378637.0625 5685978.5,378638.9375 5685979.5,378639.375 5685983,378640.375 5685985,378640.65625 5685986.5,378640.5 5685988,378640.46875 5685988.5,378641.65625 5685988.5,378642.53125 5685991.5,378643.875 5685994,378644.15625 5685995.5,378644.09375 5685996,378644.46875 5685996,378644.59375 5685999,378644.8125 5686001,378644.75 5686002,378644.65625 5686002.5,378644.5625 5686004,378644.46875 5686004.5,378644.375 5686005.5,378644.25 5686007,378643.65625 5686009,378642.78125 5686010,378640.71875 5686015,378640.25 5686015.5,378639.78125 5686016.5,378638.8125 5686018.5,378637.53125 5686019.5,378637 5686020.5,378636.875 5686022,378636.03125 5686022.5,378636 5686023,378635.875 5686024,378634.28125 5686024,378633.125 5686028,378632.15625 5686030,378632.0625 5686030.5,378631.5625 5686032,378631.53125 5686032.5,378631.09375 5686032.5,378630.25 5686033.5,378629.78125 5686034,378628.40625 5686036,378626.71875 5686037,378625.78125 5686038.5,378624.84375 5686040,378624.8125 5686040.5,378624.78125 5686040.5,378623.90625 5686041.5,378623.4375 5686042,378623.0625 5686042,378622.15625 5686043,378620.90625 5686044,378620 5686045,378618.75 5686045.5,378617.90625 5686046.5,378617 5686047.5,378616.1875 5686048,378615.71875 5686048.5,378614.875 5686049,378614.0625 5686049,378612.8125 5686050,378611.15625 5686050.5,378609.90625 5686051,378609.0625 5686052,378608.1875 5686052.5,378608.15625 5686053,378607.34375 5686053,378606.875 5686054,378605.59375 5686054.5,378604.78125 5686055,378604.40625 5686055,378603.21875 5686055,378601.65625 5686054.5,378599.28125 5686054.5,378598.5 5686054.5,378598.1875 5686053.5,378597.40625 5686053.5,378597 5686053.5,378595.9375 5686052,378594.40625 5686051.5,378593.3125 5686050.5,378592.1875 5686049.5,378591.09375 5686049,378590 5686048,378588.9375 5686046.5,378587.8125 5686045.5,378586.71875 5686045,378586 5686044,378584.90625 5686043,378584.1875 5686042,378583.4375 5686041.5,378582.75 5686041,378582.375 5686040.5,378581.625 5686040,378580.96875 5686038.5,378579.8125 5686038,378579.46875 5686037.5,378579.125 5686037.5,378578.4375 5686036,378577.28125 5686035.5,378576.625 5686034,378575.90625 5686033.5,378575.65625 5686032,378575 5686030.5,378574.40625 5686028.5,378573 5686026.5,378572.46875 5686024,378571.84375 5686022,378571.21875 5686020,378570.625 5686018,378570 5686016.5,378569.3125 5686015,378568.625 5686014,378568.3125 5686013,378567.625 5686012.5,378567.65625 5686012,378566.9375 5686011,378566.96875 5686010.5,378565.875 5686009.5,378565.53125 5686009.5,378564.40625 5686008.5,378563.3125 5686007.5,378562.5625 5686007,378562.21875 5686006.5,378561.5 5686005.5,378560.75 5686005,378559.28125 5686004,378557.78125 5686003,378556.71875 5686001.5,378556.0625 5686000.5,378555 5685999,378554.3125 5685998,378553.21875 5685997,378552.53125 5685995.5,378551.84375 5685995,378551.65625 5685994.5,378551.5 5685994,378551.15625 5685993.5,378551.1875 5685993,378550 5685993,378549.46875 5685990.5,378546.90625 5685988.5,378546.21875 5685987,378545.96875 5685985.5,378545.625 5685985,378545.65625 5685984.5,378544.9375 5685984,378544.59375 5685983.5,378543.96875 5685981.5,378543.59375 5685981,378542.5625 5685979.5,378541.8125 5685979,378541.5 5685978,378541.1875 5685977.5,378540.5625 5685976,378539.0625 5685975,378538.375 5685973.5,378537.3125 5685972.5,378536.59375 5685971.5,378535.875 5685971,378535.15625 5685970,378534.78125 5685969.5,378534.03125 5685969,378532.875 5685969,378531.875 5685967,378530.46875 5685965,378529.75 5685964.5,378529.78125 5685964,378529.375 5685964,378528.6875 5685963,378527.90625 5685963,378525.96875 5685962.5,378524.40625 5685962,378523.625 5685962,378522.8125 5685962,378522.03125 5685962,378521.65625 5685962,378520.46875 5685962,378519.6875 5685961.5,378518.5 5685961.5,378517.71875 5685961.5,378516.53125 5685961.5,378515.75 5685961.5,378514.25 5685960.5,378512.34375 5685960,378511.21875 5685959,378510.53125 5685958,378509.78125 5685957.5,378509.8125 5685957,378508.65625 5685956.5,378508.28125 5685956.5,378507.21875 5685955.5,378506.90625 5685954.5,378506.09375 5685954.5,378506.21875 5685953,378505.46875 5685952.5,378503.71875 5685950,378502.65625 5685949,378502.0625 5685947,378502.21875 5685945.5,378501.53125 5685944,378501.65625 5685943,378501.78125 5685941.5,378501.5 5685940.5,378501.125 5685940,378501.21875 5685939,378500.4375 5685939,378499.40625 5685937.5,378498.34375 5685936,378497.53125 5685936,378497.59375 5685935.5,378496.0625 5685935,378495.21875 5685935,378494.46875 5685935,378493.78125 5685934,378492.96875 5685934,378492.1875 5685934,378491.40625 5685934,378490.21875 5685933.5,378488.65625 5685933.5,378487.46875 5685933.5,378486.3125 5685933.5,378485.15625 5685933,378484.78125 5685933,378484.03125 5685932.5,378483.25 5685932,378482.53125 5685931.5,378481.375 5685931,378479.84375 5685930.5,378478.6875 5685930,378477.9375 5685929.5,378477.53125 5685929.5,378477.21875 5685929,378476.875 5685928.5,378476.21875 5685926.5,378475.125 5685926,378474.4375 5685924.5,378473.78125 5685923.5,378473.40625 5685923,378473.46875 5685922.5,378473.6875 5685920,378473.125 5685917.5,378473.3125 5685915.5,378473.53125 5685913.5,378473.65625 5685912,378473.75 5685911,378473.875 5685910,378473.9375 5685909,378474.0625 5685908,378474.15625 5685906.5,378474.34375 5685904.5,378474.53125 5685902.5,378474.6875 5685901,378474.84375 5685899.5,378475 5685898,378475.15625 5685896.5,378475.25 5685895.5,378474.53125 5685894.5,378473.84375 5685893.5,378473.875 5685893,378473.15625 5685892.5,378472.09375 5685891,378471.4375 5685889.5,378470.75 5685888.5,378470.875 5685887.5,378469.75 5685886.5,378469.46875 5685885,378468.84375 5685883.5,378467.8125 5685882,378467.1875 5685880,378466.5 5685879,378466.65625 5685877.5,378465.9375 5685876.5,378466.03125 5685875.5,378465.28125 5685875,378465.3125 5685875,378464.53125 5685874.5,378463.84375 5685873.5,378461.96875 5685872.5,378461.21875 5685872,378461 5685872,378460.46875 5685871.5,378459.6875 5685871.5,378458.53125 5685871,378457.4375 5685870,378454.6875 5685869.5,378453.1875 5685869,378451.6875 5685868,378450.53125 5685867.5,378449.71875 5685867.5,378448.625 5685866.5,378448.28125 5685866.5,378447.09375 5685866,378446.3125 5685866,378445.125 5685866,378444.75 5685866,378443.5625 5685866,378442.78125 5685865.5,378442 5685865.5,378441.59375 5685865.5,378440.40625 5685865.5,378439.625 5685865.5,378438.46875 5685865.5,378438.25 5685865.5,378437.28125 5685865,378435.25 5685866,378432.4375 5685866,378430.875 5685865.5,378429.28125 5685866,378428.09375 5685866,378426.84375 5685866.5,378425.28125 5685866.5,378424.09375 5685866,378422.84375 5685867,378422 5685867,378421.21875 5685867,378420.84375 5685867,378419.96875 5685868,378419.125 5685868.5,378417.46875 5685869,378415.46875 5685869.5,378414.21875 5685870,378413.71875 5685871,378412.875 5685871.5,378412.46875 5685872,378411.5625 5685873,378410.125 5685873,378410.09375 5685873.5,378408.8125 5685882.5,378405.96875 5685892.5,378403.53125 5685899.5,378401.53125 5685904,378399.28125 5685908,378399.46875 5685908,378399.875 5685912.5,378400.34375 5685916,378400.15625 5685918,378399.96875 5685920,378399.875 5685920.5,378399.8125 5685921.5,378399.75 5685922,378399.625 5685923.5,378399.5 5685924.5,378398.0625 5685927,378397.0625 5685929.5,378395.625 5685932,378395.15625 5685933,378395.03125 5685934,378394.90625 5685935.5,378390.84375 5685936.5,378389.15625 5685937.5,378387.90625 5685938,378387.09375 5685938.5,378386.21875 5685939,378385.8125 5685939.5,378384.96875 5685940,378384.15625 5685940,378382.9375 5685940.5,378381.25 5685941.5,378378.875 5685941.5,378377.25 5685942,378376 5685942.5,378374.78125 5685942.5,378373.53125 5685943.5,378371.9375 5685943.5,378371.09375 5685944,378369.9375 5685944,378369.53125 5685944,378368.71875 5685944,378367.9375 5685944,378366.34375 5685944,378365.5625 5685944,378364.3125 5685944.5,378363.125 5685944.5,378362.75 5685944.5,378361.875 5685945,378361.09375 5685945,378359.90625 5685945,378359.125 5685944.5,378357.84375 5685946,378357.0625 5685945.5,378355.40625 5685946.5,378353.84375 5685946,378352.96875 5685947,378352.15625 5685947,378351.34375 5685947.5,378350.90625 5685948,378349.625 5685949,378348 5685949,378346.75 5685950,378345.5 5685950.5,378344.28125 5685950.5,378343.0625 5685951,378341.84375 5685951.5,378341.03125 5685951.5,378340.25 5685951.5,378339.84375 5685951.5,378339.1875 5685950,378339.28125 5685949,378339.3125 5685948.5,378338.6875 5685947,378338.71875 5685946.5,378338.0625 5685945.5,378337.5 5685943,378337.59375 5685941.5,378337.71875 5685940.5,378337.78125 5685940,378337.84375 5685939.5,378337.5625 5685938,378337.28125 5685937,378336.09375 5685937,378335.3125 5685936.5,378334.15625 5685936,378333.375 5685936,378333 5685936,378331.8125 5685936,378331.40625 5685936,378329.84375 5685936,378329.0625 5685935.5,378328.28125 5685935.5,378327.5 5685935.5,378326.3125 5685935.5,378325.53125 5685935.5,378323.96875 5685935,378323.15625 5685935,378321.59375 5685935,378320.03125 5685935,378319.25 5685934.5,378318.0625 5685934.5,378316.84375 5685935,378316.03125 5685935,378315.15625 5685936,378313.9375 5685936,378313.15625 5685936,378312.375 5685936,378311.53125 5685936.5,378311.0625 5685937.5,378309.75 5685938.5,378308.9375 5685939,378308.4375 5685940,378307.9375 5685941,378307.46875 5685942,378306.5625 5685943,378306.09375 5685943.5,378306.03125 5685944.5,378305.53125 5685945.5,378305.09375 5685946,378304.1875 5685947,378303.375 5685947.5,378302.5 5685948,378302.03125 5685949,378301.5625 5685949.5,378301.53125 5685950,378301.46875 5685951,378300.65625 5685950.5,378300.3125 5685950.5,378299.53125 5685950,378299.125 5685950,378299.09375 5685950.5,378298.28125 5685951,378297.5 5685951,378296.59375 5685952,378294.53125 5685953,378293.6875 5685953,378293.28125 5685953.5,378292.875 5685953.5,378292.8125 5685954.5,378291.59375 5685954.5,378291.1875 5685954.5,378291.125 5685955.5,378289.53125 5685955,378288.59375 5685956.5,378287.34375 5685957.5,378286.5 5685958,378285.625 5685958.5,378285.21875 5685959,378284.75 5685960,378283.90625 5685960,378283.125 5685960,378282.21875 5685961,378280.59375 5685962,378279.34375 5685962.5,378278.46875 5685963,378277.625 5685964,378277.1875 5685964,378276.3125 5685965,378275.9375 5685965,378274.6875 5685965.5,378274.28125 5685965.5,378273.03125 5685966,378272.625 5685966,378271 5685967,378270.59375 5685966.5,378269.3125 5685968,378268.5 5685968,378267.21875 5685969,378265.96875 5685969.5,378265.1875 5685969.5,378264.40625 5685969.5,378263.15625 5685970,378262.375 5685970,378260.8125 5685969.5,378260 5685969.5,378259.15625 5685970.5,378258.375 5685970.5,378257.59375 5685970,378256.375 5685970.5,378255.1875 5685970.5,378253.21875 5685970,378251.65625 5685970,378250.875 5685970,378250.46875 5685970,378249.6875 5685970,378248.90625 5685969.5,378247.71875 5685969.5,378246.90625 5685970,378245.25 5685970.5,378244.46875 5685970.5,378243.6875 5685970.5,378243.28125 5685970.5,378242.03125 5685971,378241.21875 5685971.5,378239.5625 5685972,378239.15625 5685972.5,378238.75 5685972.5,378237.84375 5685973.5,378237.03125 5685973.5,378235.78125 5685974.5,378235.28125 5685975.5,378235.1875 5685976.5,378235.15625 5685976.5,378234.8125 5685980,378233.375 5685983,378233.3125 5685983.5,378233.28125 5685984,378233.1875 5685985,378233.15625 5685985,378233.03125 5685986.5,378232.5625 5685987,378231.53125 5685990,378231.375 5685991.5,378231.21875 5685993,378231.09375 5685994.5,378231.03125 5685995,378231 5685995.5,378230.90625 5685996.5,378230.8125 5685997.5,378230.71875 5685998.5,378230.625 5685999.5,378230.46875 5686001,378230.4375 5686001,378230.28125 5686003,378230.1875 5686004,378230.0625 5686005,378230 5686006,378229.34375 5686008.5,378228.40625 5686010,378228.25 5686011.5,378228.15625 5686013,378227.6875 5686013.5,378227.59375 5686014.5,378227.21875 5686014.5,378226.40625 5686014.5,378225.8125 5686016.5,378225.625 5686018.5,378224.84375 5686018.5,378223.90625 5686020,378222.5625 5686021.5,378222.1875 5686021.5,378220.96875 5686021.5,378220.0625 5686023,378219.25 5686023,378218.78125 5686024,378218.34375 5686024,378217.5625 5686024,378216.78125 5686024,378215.96875 5686024,378215.1875 5686024,378214.03125 5686024,378213.25 5686023.5,378212.0625 5686023.5,378212.125 5686023,378211.34375 5686022.5,378211.03125 5686022,378210.3125 5686021,378210.40625 5686020.5,378209.65625 5686020,378209.71875 5686019,378209.375 5686018.5,378209.09375 5686017.5,378209.125 5686017,378208.03125 5686016,378208.0625 5686015.5,378208.15625 5686014.5,378205.9375 5686013,378204.96875 5686010.5,378203.90625 5686009.5,378203.59375 5686008.5,378203.65625 5686007.5,378202.875 5686007.5,378201.6875 5686007.5,378200.53125 5686007.5,378199.71875 5686007.5,378198.9375 5686007,378197.78125 5686007,378196.59375 5686007,378195.03125 5686007,378193.84375 5686006.5,378193.0625 5686006.5,378192.96875 5686007.5,378191.8125 5686007,378191.40625 5686007,378190.625 5686007,378190.5625 5686008,378189.34375 5686008,378188.40625 5686009.5,378187.5 5686011,378187.4375 5686011.5,378186.59375 5686012,378186.125 5686012.5,378184.84375 5686013.5,378184.375 5686014.5,378183.46875 5686015.5,378183 5686016.5,378182.59375 5686016.5,378182.53125 5686017,378181.28125 5686017.5,378180.8125 5686018.5,378180.71875 5686019.5,378179.46875 5686020.5,378179.03125 5686020.5,378179 5686021,378178.96875 5686021.5,378178.5625 5686021.5,378177.6875 5686022,378176.375 5686023.5,378175.9375 5686024,378175.09375 5686024.5,378173.78125 5686025.5,378173.375 5686026,378172.5 5686027,378171.59375 5686028,378170.34375 5686028.5,378169.0625 5686029.5,378167.40625 5686030,378165.78125 5686031,378164.875 5686032,378163.65625 5686032,378162.84375 5686032.5,378162.4375 5686032.5,378162.5 5686031.5,378162.5625 5686031.5,378162.59375 5686030.5,378152.25 5686035.5,378151.90625 5686039,378153.625 5686042,378154.40625 5686042,378154.3125 5686043,378154.03125 5686046,378158.40625 5686046,378163.125 5686048,378164.6875 5686052,378166.59375 5686059.5,378167.71875 5686064.5,378168.09375 5686067.5,378169.625 5686072.5,378174.53125 5686078,378175.5625 5686078,378176.75 5686078,378177.53125 5686078,378178.3125 5686078,378179.09375 5686078.5,378179.875 5686078.5,378181.46875 5686078.5,378182.25 5686078.5,378183.40625 5686078.5,378184.21875 5686079,378185.78125 5686079,378186.5625 5686079,378186.96875 5686079,378188.0625 5686080,378188.84375 5686080,378190.34375 5686081,378191.90625 5686081,378192.6875 5686081,378193.46875 5686081.5,378194.53125 5686082.5,378195.6875 5686083,378197.5625 5686084,378199.0625 5686085,378200.21875 5686085.5,378200.96875 5686086,378202.09375 5686086.5,378203.25 5686087,378204 5686087.5,378205.125 5686088,378206.28125 5686088.5,378207.375 5686089.5,378208.5 5686090,378209.25 5686090.5,378210.40625 5686091,378211.53125 5686091.5,378212.34375 5686091.5,378213.125 5686091.5,378214.21875 5686092.5,378215 5686092.5,378216.1875 5686093,378216.9375 5686093,378218.375 5686094.5,378220.3125 5686095,378221.375 5686096.5,378222.5 5686097.5,378223.9375 5686098.5,378225.03125 5686099.5,378226.15625 5686100.5,378227.25 5686101.5,378228.34375 5686102.5,378229.0625 5686103,378229.78125 5686104,378230.53125 5686104.5,378231.15625 5686106,378232.65625 5686107,378233.375 5686108,378234.09375 5686109,378234.78125 5686109.5,378235.5 5686110.5,378235.78125 5686112,378236.5 5686112.5,378237.1875 5686113.5,378237.125 5686114.5,378237.875 5686115,378238.5625 5686116,378239.28125 5686116.5,378240.3125 5686118,378241.375 5686119.5,378242.5 5686120.5,378243.15625 5686121.5,378243.90625 5686122,378244.28125 5686122.5,378245.34375 5686124,378245.6875 5686124.5,378246.84375 5686125,378247.625 5686125,378248 5686125,378248.71875 5686126,378249.46875 5686126.5,378250.9375 5686127.5,378252.4375 5686128.5,378253.46875 5686129.5,378253.53125 5686129.5,378254.25 5686130.5,378255.375 5686131,378256.125 5686131.5,378257.3125 5686131.5,378258 5686132.5,378259.125 5686133.5,378261.03125 5686134,378261.78125 5686134.5,378262.53125 5686135,378263.3125 5686135,378264.125 5686135,378264.8125 5686136,378267.125 5686136.5,378268.3125 5686136.5,378269.0625 5686137,378269.84375 5686137,378270.25 5686137,378271.03125 5686137,378271.875 5686136.5,378272.3125 5686136,378273.5625 5686135.5,378274.40625 5686135,378275.6875 5686134,378276.9375 5686133.5,378278.1875 5686133,378278.65625 5686132,378279.53125 5686131.5,378280 5686130.5,378280.9375 5686129,378282.1875 5686128.5,378282.71875 5686127,378282.875 5686125.5,378283.71875 5686124.5,378283.78125 5686124,378283.90625 5686122.5,378284.0625 5686121,378284.5625 5686116,378283.21875 5686113.5,378283.03125 5686111,378283.21875 5686109,378283.34375 5686108,378283.03125 5686107,378282.34375 5686106,378282.46875 5686104.5,378281.78125 5686103.5,378281.46875 5686102.5,378281.21875 5686101,378280.96875 5686099.5,378280.6875 5686098,378280.84375 5686096.5,378280.1875 5686095.5,378280.28125 5686094,378280.34375 5686093.5,378280.375 5686093.5,378280.625 5686090.5,378279.6875 5686088,378279.5 5686085.5,378279.71875 5686083.5,378279.84375 5686082,378279.96875 5686081,378280.03125 5686080,378279.3125 5686079.5,378278.9375 5686079,378278.71875 5686077,378276.53125 5686075.5,378276.03125 5686075,378272.375 5686073.5,378267.28125 5686070,378262.5625 5686067,378258.25 5686062.5,378255.53125 5686058,378255.5625 5686054.5,378256.78125 5686050.5,378260 5686041.5,378260.84375 5686037.5,378263.25 5686032,378265.28125 5686027.5,378267.6875 5686021.5,378270.53125 5686014.5,378273.34375 5686008.5,378277.75 5686000.5,378282.40625 5685992.5,378282.96875 5685992,378285.3125 5685987.5,378286.03125 5685988,378287.28125 5685987,378288.875 5685987.5,378289.71875 5685986.5,378290.96875 5685986,378292.1875 5685985.5,378292.625 5685985.5,378293.40625 5685985.5,378294.28125 5685984.5,378294.6875 5685984.5,378295.5 5685984.5,378295.875 5685984.5,378296.75 5685983.5,378297.15625 5685983.5,378298 5685983,378298.84375 5685982.5,378299.25 5685982.5,378300.15625 5685981,378300.53125 5685981.5,378301.78125 5685980.5,378302.5625 5685980.5,378303 5685980.5,378304.25 5685979.5,378304.6875 5685979.5,378305.90625 5685979,378307.15625 5685978.5,378307.5625 5685978.5,378308.8125 5685978,378310.375 5685978,378311.625 5685977,378312.0625 5685977,378312.4375 5685977,378313.25 5685977,378314.5 5685976.5,378314.875 5685976.5,378316.09375 5685976,378316.875 5685976,378317.75 5685975.5,378318.53125 5685975.5,378319.3125 5685975.5,378320.96875 5685975,378322.1875 5685974.5,378322.5625 5685975,378323.4375 5685974,378324.21875 5685974,378324.59375 5685974,378325.46875 5685973.5,378326.6875 5685973,378327.0625 5685973,378327.9375 5685972.5,378328.75 5685972,378330.8125 5685971.5,378331.96875 5685972,378333.15625 5685972,378333.59375 5685971.5,378333.96875 5685971.5,378334.75 5685971.5,378335.9375 5685972,378336.34375 5685972,378337.9375 5685971.5,378338.71875 5685971.5,378339.5 5685971.5,378340.28125 5685971.5,378340.78125 5685971,378342.375 5685971,378342.78125 5685971,378343.9375 5685971,378344.34375 5685971,378345.59375 5685970.5,378346.375 5685970.5,378347.15625 5685970.5,378347.9375 5685970.5,378349.15625 5685970.5,378349.9375 5685970.5,378351.1875 5685969.5,378352 5685970,378353.28125 5685968.5,378354.5 5685968.5,378355.28125 5685968.5,378355.65625 5685968.5,378356.53125 5685968,378356.96875 5685967.5,378357.75 5685967.5,378358.125 5685967.5,378358.96875 5685967.5,378359.75 5685967.5,378361.03125 5685966.5,378361.875 5685966,378362.65625 5685966,378363.46875 5685966,378363.875 5685966,378365.125 5685965,378365.90625 5685965.5,378367.59375 5685964,378369.1875 5685964,378370.40625 5685963.5,378371.21875 5685963.5,378372.03125 5685963.5,378373.21875 5685963,378374.03125 5685963.5,378374.125 5685962,378375.3125 5685962,378376.53125 5685962,378377.6875 5685962,378378.59375 5685961,378379 5685961,378380.625 5685960.5,378381.4375 5685960.5,378382.75 5685959,378384 5685958.5,378384.40625 5685958.5,378385.25 5685957.5,378386.09375 5685957.5,378386.90625 5685957,378388.09375 5685957,378389.75 5685956,378391.03125 5685955.5,378391.8125 5685955.5,378392.1875 5685955.5,378393.03125 5685955.5,378393.40625 5685955.5,378394.1875 5685955.5,378394.96875 5685955.5,378396.625 5685955,378397.40625 5685955,378398.625 5685954.5,378399.8125 5685955,378401.5 5685954,378402.34375 5685953,378402.75 5685953,378403.59375 5685952.5,378405.65625 5685952,378406.90625 5685951,378408.125 5685951,378408.90625 5685951,378409.28125 5685951,378410.53125 5685950.5,378410.96875 5685950,378412.625 5685949.5,378413.40625 5685949.5,378413.84375 5685949,378414.71875 5685948,378415.15625 5685947.5,378416.40625 5685947,378417.28125 5685946,378418.53125 5685945.5,378419.4375 5685944.5,378420.25 5685944,378421.125 5685943.5,378421.53125 5685943,378422.84375 5685942,378424.03125 5685941.5,378425.3125 5685941,378425.78125 5685940.5,378426.1875 5685940,378427.03125 5685939.5,378427.96875 5685938,378429.59375 5685937.5,378430.4375 5685937,378430.46875 5685937,378430.53125 5685936,378432.15625 5685936,378432.96875 5685935.5,378433.375 5685935.5,378434.6875 5685934,378436.3125 5685934,378437.125 5685933.5,378437.9375 5685933,378437.96875 5685933,378438.75 5685933,378439.5625 5685933,378441.5 5685933,378442.59375 5685934.5,378443.375 5685934.5,378443.71875 5685935,378443.5625 5685936.5,378445.8125 5685938,378447.125 5685941,378448.53125 5685942.5,378449.28125 5685943,378449.21875 5685944,378449.15625 5685944.5,378449.84375 5685945.5,378451.625 5685947.5,378453.125 5685948.5,378453.84375 5685949.5,378454.5625 5685950.5,378454.90625 5685951,378455.25 5685951,378455.96875 5685952,378456.71875 5685952.5,378457.375 5685954,378458.125 5685954.5,378458.5 5685954.5,378459.625 5685955.5,378460 5685955.5,378460.375 5685955.5,378460.3125 5685956.5,378461.0625 5685957,378461.84375 5685957,378462.46875 5685958.5,378463.625 5685959,378464 5685959.5,378463.9375 5685960,378465.8125 5685961,378466.5 5685962.5,378467.96875 5685963.5,378469.09375 5685964,378469.03125 5685965,378468.90625 5685966,378470.8125 5685967,378471.4375 5685969,378472.15625 5685969.5,378472.46875 5685970.5,378472.4375 5685971,378472.34375 5685971.5,378473.4375 5685972.5,378474.09375 5685974,378474.75 5685975.5,378475.125 5685976,378475.4375 5685976.5,378475.78125 5685977,378476.96875 5685977.5,378478.53125 5685977.5,378479.71875 5685977.5,378480.46875 5685978,378481.25 5685978,378482.40625 5685978.5,378484.34375 5685979,378485.15625 5685979,378486.71875 5685979,378487.4375 5685980,378487.375 5685980.5,378488.5625 5685980.5,378489.25 5685981.5,378490.3125 5685983,378490.96875 5685984.5,378490.8125 5685986,378490.75 5685986.5,378490.71875 5685987,378491.09375 5685987,378491.34375 5685988.5,378491.25 5685990,378491.15625 5685990.5,378491.09375 5685991.5,378491.46875 5685991.5,378492.0625 5685993.5,378493.5 5685995,378494.125 5685997,378494.71875 5685999,378495.4375 5686000,378495.71875 5686001,378496.4375 5686002,378496.34375 5686002.5,378497.0625 5686003.5,378498.125 5686005,378498.8125 5686006,378499.53125 5686007,378499.5625 5686007,378500.1875 5686008,378500.90625 5686009,378501.25 5686009.5,378501.1875 5686010.5,378501.5625 5686010.5,378501.78125 5686012.5,378502.8125 5686014,378503.40625 5686016,378503.25 5686017.5,378503.21875 5686018,378503.1875 5686018.5,378502.96875 5686021,378503.9375 5686023,378504.5625 5686025,378505.1875 5686026.5,378505.46875 5686028,378505.375 5686028.5,378506.1875 5686028.5,378506.625 5686032.5,378507.53125 5686035,378507.75 5686037,378507.5625 5686039,378507.53125 5686039.5,378507.84375 5686040.5,378508.1875 5686041,378508.15625 5686041,378509.34375 5686041.5,378510.75 5686043,378512.21875 5686044.5,378512.96875 5686045,378513.28125 5686045.5,378513.6875 5686046,378514.40625 5686046,378514.8125 5686046.5,378515.5625 5686046.5,378516.6875 5686047.5,378517.5 5686047.5,378519.4375 5686047.5,378520.25 5686047.5,378520.625 5686047.5,378521.8125 5686048,378522.5625 5686048.5,378523.71875 5686048.5,378524.53125 5686048.5,378525.65625 5686049,378527.21875 5686049,378527.625 5686049,378528.75 5686049.5,378530.25 5686050.5,378532.21875 5686051,378533.375 5686051.5,378534.15625 5686051.5,378534.9375 5686051.5,378534.875 5686052.5,378536.03125 5686052.5,378537.1875 5686053,378539.09375 5686053.5,378539.78125 5686055,378540.875 5686055.5,378541.625 5686056,378542 5686056.5,378542.78125 5686056.5,378543.5625 5686056.5,378544.34375 5686057,378545.4375 5686057.5,378546.1875 5686058,378546.59375 5686058,378547.375 5686058.5,378548.15625 5686058.5,378549.34375 5686058.5,378550.125 5686058.5,378550.90625 5686058.5,378552.09375 5686059,378552.46875 5686059,378552.875 5686059,378553.25 5686059,378554.125 5686058,378554.9375 5686058,378555.34375 5686058,378556.125 5686058,378556.96875 5686057.5,378558.59375 5686057,378559 5686057,378559.78125 5686057,378560.5625 5686057.5,378561.40625 5686056.5,378561.8125 5686056.5,378562.59375 5686056.5,378563.375 5686057,378564.15625 5686057,378564.5625 5686057,378564.9375 5686057,378566.125 5686057,378566.90625 5686057,378567.3125 5686057,378568.09375 5686057,378568.8125 5686058,378569.96875 5686058,378569.84375 5686060,378570.5 5686061,378570.75 5686062.5,378570.59375 5686064,378570.4375 5686066,378571.15625 5686066.5,378571.40625 5686068.5,378571.25 5686070,378571.1875 5686070.5,378571.09375 5686071.5,378570.75 5686075,378570.53125 5686077.5,378570.34375 5686079.5,378570.21875 5686081,378570.125 5686081.5,378570.03125 5686083,378569.6875 5686086.5,378568.59375 5686089.5,378568.4375 5686091,378568.34375 5686092,378568.25 5686093,378568.21875 5686093.5,378568.15625 5686094,378567.96875 5686096,378566.59375 5686098,378566 5686100,378565.0625 5686101.5,378564.5625 5686102.5,378564.0625 5686103.5,378563.15625 5686105,378562.65625 5686106,378561.71875 5686107.5,378560.84375 5686108.5,378560.28125 5686110,378559.40625 5686111,378558.84375 5686112.5,378558.3125 5686114.5,378557.40625 5686115.5,378556.90625 5686116.5,378556.40625 5686117.5,378555.90625 5686119,378555.375 5686120,378555.3125 5686120.5,378554.46875 5686121.5,378554.375 5686122,378553.40625 5686124,378552.53125 5686125,378551.65625 5686126,378551.5 5686127.5,378551.03125 5686128,378550.96875 5686129,378550.84375 5686130,378550.8125 5686130.5,378550.03125 5686130.5,378549.78125 5686133,378548.40625 5686135,378547.8125 5686137,378547.625 5686139,378547.5 5686140,378547 5686141.5,378546.125 5686142.5,378546.0625 5686143,378545.6875 5686143,378545.03125 5686145.5,378544.0625 5686147.5,378543.875 5686149.5,378543.28125 5686151.5,378543.1875 5686152.5,378543.03125 5686154,378542.09375 5686155.5,378541.9375 5686157,378541.875 5686158,378541.75 5686159,378541.625 5686160.5,378541.59375 5686160.5,378541.40625 5686162.5,378540.46875 5686164,378540.375 5686165.5,378540.25 5686166.5,378539.90625 5686170,378538.875 5686172.5,378538.78125 5686173.5,378538.75 5686174,378538.5625 5686176,378537.28125 5686177,378536.78125 5686178,378536.6875 5686179,378536.5 5686181,378534.75 5686182.5,378533.84375 5686183.5,378533.75 5686185,378533.71875 5686185.5,378533.625 5686186,378532.84375 5686186,378531.84375 5686188.5,378530.4375 5686190.5,378530.34375 5686191.5,378530.28125 5686192,378529.8125 5686193,378529.75 5686193.5,378528.84375 5686194.5,378528.78125 5686195.5,378527.90625 5686196,378527.875 5686196.5,378527 5686197.5,378525.78125 5686197.5,378524.90625 5686198.5,378524.03125 5686199.5,378523.1875 5686200,378522.75 5686200.5,378522.28125 5686201,378522.25 5686201.5,378521.46875 5686201.5,378520.5625 5686202.5,378519.3125 5686203.5,378518.53125 5686203,378518.125 5686203,378516.84375 5686204,378515.15625 5686205.5,378514.28125 5686206,378513.46875 5686206.5,378513.0625 5686206,378512.625 5686207,378511.8125 5686207,378511.03125 5686207,378509.875 5686206.5,378509.46875 5686206.5,378508.6875 5686206.5,378507.90625 5686206.5,378506.71875 5686206.5,378505.9375 5686206.5,378504.375 5686206,378503.5625 5686206,378502.40625 5686206,378501.625 5686206,378500.03125 5686205.5,378499.65625 5686205.5,378498.46875 5686205.5,378497.6875 5686205.5,378496.90625 5686205.5,378495.71875 5686205.5,378495.34375 5686205,378494.15625 5686205,378493.375 5686205,378491.40625 5686205,378490.625 5686205,378489.84375 5686204.5,378489.4375 5686204.5,378488.65625 5686204.5,378487.875 5686204.5,378487.78125 5686205.5,378487.75 5686205.5,378486.46875 5686206.5,378486.4375 5686207,378486.15625 5686210,378487.1875 5686211.5,378487.40625 5686213.5,378487.59375 5686215.5,378487.5625 5686216,378487.5 5686217,378487.8125 5686217.5,378488.15625 5686218,378488.84375 5686219.5,378488.75 5686220,378489.46875 5686221,378489.4375 5686221.5,378489.28125 5686223,378489.1875 5686224,378489.09375 5686225,378489.0625 5686225.5,378489 5686226,378488.9375 5686226.5,378488.84375 5686227.5,378488.75 5686228.5,378487.90625 5686229,378487.875 5686229.5,378487.46875 5686229.5,378486.625 5686230,378484.625 5686230.5,378483.75 5686231,378482.53125 5686231.5,378481.75 5686231.5,378480.875 5686232,378480.5 5686232,378480.09375 5686232,378479.21875 5686233,378478.375 5686233.5,378476.75 5686234,378475.125 5686234,378473.875 5686235,378473.0625 5686235,378472.28125 5686235,378471.875 5686235,378471 5686236,378470.21875 5686235.5,378468.59375 5686236.5,378467 5686236,378465.78125 5686236.5,378465 5686236.5,378464.1875 5686236.5,378463.40625 5686236.5,378462.21875 5686236.5,378461.4375 5686236.5,378459.875 5686236,378457.90625 5686236,378457.125 5686236,378455.9375 5686236,378454.6875 5686236.5,378453.875 5686237,378452.6875 5686236.5,378451.90625 5686236.5,378450.71875 5686236.5,378449.9375 5686236.5,378448.75 5686236.5,378447.59375 5686236,378445.53125 5686237,378443.9375 5686237,378442.375 5686237,378441.5625 5686237,378440.78125 5686236.5,378440.40625 5686236.5,378439.625 5686236.5,378439.21875 5686236.5,378438.03125 5686236.5,378437.65625 5686236.5,378436.59375 5686235,378436.21875 5686234.5,378435.0625 5686234.5,378434.65625 5686234.5,378433.46875 5686234.5,378433.09375 5686234.5,378432 5686233.5,378431.59375 5686233.5,378430.5 5686232.5,378429.3125 5686232.5,378429 5686231.5,378428.59375 5686231.5,378427.9375 5686230,378427.1875 5686229.5,378425.65625 5686229,378424.59375 5686228,378423.84375 5686227.5,378423.875 5686227,378423.5625 5686226,378423.59375 5686226,378422.53125 5686224.5,378421.40625 5686223.5,378421.125 5686222.5,378420.4375 5686221.5,378420.15625 5686220.5,378419.46875 5686219,378418.75 5686218,378418.4375 5686217.5,378418.09375 5686217,378418.125 5686216.5,378416.9375 5686216.5,378415.90625 5686214.5,378414.5 5686213,378414.09375 5686213,378413.3125 5686213,378412.53125 5686213,378410.96875 5686212.5,378410.1875 5686212.5,378408.625 5686212.5,378407.8125 5686212.5,378407.03125 5686212,378405.875 5686212,378404.6875 5686212,378402.71875 5686212,378400.75 5686211.5,378399.5625 5686211.5,378398.78125 5686211.5,378398 5686211.5,378397.21875 5686211,378396.03125 5686211,378395.1875 5686212,378393.09375 5686213,378391.875 5686213,378391 5686214,378390.09375 5686215.5,378389.625 5686216,378389.15625 5686216.5,378388.6875 5686217.5,378388.65625 5686218,378388.59375 5686218.5,378387.28125 5686219.5,378386.8125 5686220.5,378386.34375 5686221,378386.25 5686222.5,378385.34375 5686223.5,378385.28125 5686224.5,378384.40625 5686225,378384.03125 5686225,378382.4375 5686225,378381.65625 5686224.5,378380.875 5686224.5,378380.09375 5686224.5,378378.53125 5686224.5,378376.15625 5686224,378374.96875 5686224,378373.40625 5686224,378372.625 5686224,378371.84375 5686223.5,378370.96875 5686224.5,378370.59375 5686224.5,378369.71875 5686225,378368.5 5686225.5,378366.84375 5686226.5,378365.5625 5686227,378364.71875 5686228,378363.84375 5686228.5,378363.4375 5686229,378363.375 5686229,378362.78125 5686230,378362.5 5686230.5,378361.65625 5686230.5,378360.6875 5686232.5,378359.40625 5686233.5,378358.90625 5686234.5,378358.34375 5686236.5,378357.53125 5686236.5,378357.5 5686237,378357 5686238,378356.96875 5686238.5,378356.875 5686239.5,378356.84375 5686239.5,378356.65625 5686241.5,378355.78125 5686242.5,378355.6875 5686243.5,378355.5625 5686244.5,378355.40625 5686246.5,378354.9375 5686247,378354.5625 5686247,378354.46875 5686248,378354.375 5686249,378353.90625 5686249.5,378352.9375 5686251.5,378352.4375 5686253,378352.34375 5686253.5,378352.28125 5686254.5,378351.875 5686254.5,378350.84375 5686257,378350.25 5686259,378350.15625 5686260,378350.0625 5686261,378349.6875 5686261,378349.0625 5686263,378347.6875 5686265,378347.125 5686267,378346.9375 5686269,378346.46875 5686269.5,378346.40625 5686270,378346.34375 5686271,378346.3125 5686271,378346.28125 5686271.5,378346.09375 5686273.5,378345.96875 5686275,378345.875 5686276,378345.75 5686277,378345.625 5686278.5,378345.5625 5686279,378345.5 5686280,378345.4375 5686280.5,378345.34375 5686281.5,378345.25 5686282,378345.15625 5686283.5,378345.46875 5686284.5,378345.78125 5686285,378345.65625 5686286.5,378346.46875 5686286.5,378347.125 5686287.5,378347.4375 5686288.5,378348.21875 5686288.5,378348.9375 5686289.5,378349.34375 5686289.5,378350.5 5686289.5,378350.90625 5686289.5,378352.0625 5686290,378352.84375 5686290,378354.75 5686291,378355.53125 5686291,378357.5 5686291,378358.28125 5686291,378359.09375 5686291,378359.875 5686291.5,378361.03125 5686291.5,378362.625 5686291.5,378363.40625 5686291.5,378364.1875 5686291.5,378365.25 5686293,378366.03125 5686293,378366.8125 5686293,378367.59375 5686293,378368.75 5686294,378369.53125 5686294,378370.71875 5686294,378371.5 5686294,378371.875 5686294,378373.0625 5686294,378373.84375 5686294.5,378375.03125 5686294.5,378375.4375 5686294.5,378376.65625 5686294,378377.03125 5686294,378378.21875 5686294.5,378378.59375 5686294.5,378379.78125 5686294.5,378380.5625 5686294.5,378381.34375 5686294.5,378382.53125 5686295,378383.28125 5686295,378384.03125 5686295.5,378385.90625 5686296.5,378386.6875 5686297,378387.5 5686297,378388.1875 5686297.5,378388.96875 5686298,378389.375 5686298,378390.0625 5686299,378390.8125 5686299.5,378391.0625 5686301,378391.03125 5686301,378391.625 5686303,378391.53125 5686304.5,378391.40625 5686305.5,378391.34375 5686306.5,378391.25 5686307,378390.40625 5686308,378389.15625 5686308.5,378388.71875 5686309,378387.9375 5686309,378386.75 5686308.5,378386.25 5686310,378384.21875 5686310.5,378383.3125 5686311.5,378382 5686313,378381.125 5686313.5,378380.28125 5686314.5,378379.8125 5686315,378379.71875 5686316,378378.875 5686316.5,378378.4375 5686317,378377.5625 5686317.5,378377.15625 5686318,378376.28125 5686319,378375.8125 5686319.5,378374.5 5686321,378372.8125 5686322,378371.875 5686323.5,378370.9375 5686325,378370.0625 5686325.5,378369.59375 5686326.5,378369.125 5686327,378369.09375 5686327.5,378368.28125 5686328,378367.40625 5686328.5,378366.1875 5686329,378365.40625 5686329,378363.0625 5686328.5,378361.5 5686328.5,378360.3125 5686328.5,378359.875 5686328.5,378359.09375 5686328.5,378358.3125 5686328.5,378357.53125 5686328.5,378356.75 5686328.5,378355.5625 5686328,378355.15625 5686328,378354.375 5686328,378353.59375 5686328,378353.21875 5686328,378352.40625 5686328,378351.625 5686328,378350.46875 5686327.5,378349.65625 5686327.5,378347.71875 5686327.5,378345.75 5686327,378344.875 5686328,378344.03125 5686328.5,378343.25 5686328.5,378342.84375 5686328.5,378341.65625 5686328.5,378340.875 5686328.5,378339.6875 5686328,378338.53125 5686328,378336.5625 5686328,378335 5686327.5,378334.21875 5686327.5,378333.40625 5686327.5,378332.625 5686327.5,378331.84375 5686327.5,378330.65625 5686327.5,378329.875 5686327,378328.28125 5686327.5,378327.5 5686327.5,378325.90625 5686327,378325.53125 5686327,378323.96875 5686327,378323.5625 5686327,378322 5686327,378321.21875 5686326.5,378319.625 5686326.5,378319.25 5686326.5,378318.40625 5686327,378317.625 5686326.5,378316.8125 5686327,378316.03125 5686327,378315.25 5686327,378314.46875 5686327,378312.875 5686326.5,378312.09375 5686326.5,378310.03125 5686327.5,378309.25 5686327.5,378308.4375 5686327.5,378307.625 5686327.5,378307.25 5686327.5,378306.40625 5686328,378304.84375 5686328,378304.0625 5686327.5,378303.65625 5686327.5,378302.375 5686329,378301.59375 5686328.5,378300.8125 5686328.5,378300.03125 5686328.5,378298.75 5686329,378297.15625 5686329.5,378296.375 5686329.5,378295.59375 5686329.5,378294.71875 5686330,378294.28125 5686330.5,378293.5 5686330.5,378292.71875 5686330,378291.53125 5686330,378290.375 5686330,378288.78125 5686330,378288 5686329.5,378287.1875 5686330,378285.96875 5686330.5,378284.40625 5686330,378283.625 5686330,378282.78125 5686330.5,378282.375 5686330.5,378281.96875 5686330.5,378281.5625 5686330.5,378280.71875 5686331.5,378280.3125 5686331.5,378279.5 5686331.5,378278.71875 5686331.5,378277.0625 5686332,378275.84375 5686332.5,378275.0625 5686332.5,378274.25 5686332.5,378274.15625 5686333.5,378273.375 5686333.5,378272.5625 5686333.5,378271 5686333.5,378270.96875 5686333.5,378270.46875 5686335.5,378268.40625 5686344,378266.78125 5686349.5,378264.75 5686356.5,378262.71875 5686362.5,378258.6875 5686369,378256.6875 5686372,378254.625 5686373,378254.53125 5686373,378254.46875 5686374,378254.40625 5686374.5,378253.0625 5686376,378252.1875 5686377,378251.65625 5686378.5,378251.15625 5686379.5,378250.25 5686380.5,378250.1875 5686381.5,378249.3125 5686382,378249.25 5686383,378249.15625 5686384,378249 5686385.5,378246.15625 5686386.5,378244.4375 5686387.5,378242.75 5686388.5,378241.875 5686389.5,378241.84375 5686390,378241.46875 5686390,378240.28125 5686389.5,378239.5 5686389.5,378238.3125 5686389.5,378237.8125 5686390.5,378237.40625 5686390.5,378236.15625 5686391,378235.375 5686391,378233.71875 5686392,378231.375 5686391.5,378230.1875 5686391.5,378229.40625 5686391.5,378228.25 5686391,378227.84375 5686391,378227.0625 5686391,378226.65625 5686391,378225.875 5686391,378225.8125 5686392,378225.40625 5686391.5,378223.75 5686392.5,378223.375 5686392.5,378221.65625 5686393.5,378220 5686394.5,378218.71875 5686395.5,378217.8125 5686396.5,378216.96875 5686397,378216.09375 5686398,378215.25 5686398.5,378215.1875 5686399,378215.0625 5686400.5,378212.1875 5686401.5,378210.8125 5686403.5,378208.75 5686404.5,378208.34375 5686404.5,378207.9375 5686404.5,378207.5 5686405,378206.71875 5686405,378206.3125 5686405,378205.9375 5686405,378205.53125 5686405,378204.8125 5686404,378204.46875 5686403.5,378203.75 5686402.5,378202.96875 5686402.5,378202.25 5686401.5,378201.46875 5686401.5,378200.0625 5686400,378199.3125 5686399.5,378198.90625 5686399.5,378198.125 5686399.5,378197.34375 5686399,378196.5625 5686399,378195.78125 5686399,378194.09375 5686400,378191.65625 5686400.5,378190.46875 5686400.5,378189.65625 5686401,378188.875 5686400.5,378188.46875 5686400.5,378187.6875 5686400.5,378186.90625 5686400.5,378185.71875 5686400.5,378184.53125 5686400.5,378182.59375 5686400,378181 5686400,378180.21875 5686400,378179.84375 5686400,378179.0625 5686399.5,378177.875 5686399.5,378177.71875 5686401,378174.90625 5686401.5,378173.21875 5686402.5,378171.59375 5686403,378170.4375 5686403,378169.5625 5686403.5,378169.1875 5686403.5,378168.375 5686403.5,378168.28125 5686404.5,378166.625 5686405,378165.71875 5686406.5,378165.65625 5686407,378165.59375 5686408,378165.5 5686408.5,378164.53125 5686410.5,378164.46875 5686411.5,378164.3125 5686413,378164.15625 5686414.5,378164.09375 5686415.5,378164 5686416,378164.6875 5686417.5,378164.59375 5686418,378165.40625 5686418,378166.09375 5686423.5,378168.46875 5686427.5,378169.03125 5686430,378169.1875 5686432.5,378169.5 5686433.5,378169.46875 5686433.5,378169.40625 5686434.5,378170.15625 5686435,378170.46875 5686436,378170.4375 5686436,378171.09375 5686437.5,378171.40625 5686438.5,378171.65625 5686440,378171.59375 5686440.5,378171.5 5686441.5,378172.625 5686442.5,378172.625 5686446.5,378172.4375 5686448.5,378172.375 5686449,378172.28125 5686450,378172.6875 5686450,378173.15625 5686453,378173.3125 5686456,378173.125 5686458,378172.96875 5686459.5,378172.84375 5686460.5,378172.78125 5686461.5,378172.65625 5686462.5,378172.59375 5686463.5,378172.40625 5686465.5,378172.28125 5686466.5,378172.15625 5686468,378172 5686470,378171.8125 5686471.5,378171.65625 5686473.5,378171.46875 5686475.5,378171.25 5686477.5,378171.15625 5686478.5,378171.09375 5686479,378170.6875 5686479,378169.8125 5686480.5,378169.34375 5686481,378169.21875 5686482,378168.75 5686483,378167.78125 5686485,378167.71875 5686485.5,378167.3125 5686485.5,378166.40625 5686486.5,378165.9375 5686487.5,378165.84375 5686488.5,378165 5686489,378164.21875 5686489,378163.28125 5686490.5,378161.625 5686491.5,378160.71875 5686492.5,378160.59375 5686493.5,378159.8125 5686493.5,378159.375 5686494,378156.9375 5686494.5,378155.65625 5686495.5,378154.40625 5686496,378154.03125 5686496,378153.625 5686496,378153.5625 5686497,378152.75 5686497,378152.71875 5686497,378152.28125 5686497.5,378151.09375 5686498,378150.28125 5686498,378149.03125 5686498.5,378148.25 5686498.5,378146.6875 5686498,378144.25 5686498.5,378140.3125 5686498.5,378138.75 5686498,378137.1875 5686498,378136.40625 5686498,378135.5625 5686498.5,378134.78125 5686498,378133.625 5686498,378132.4375 5686498,378130.09375 5686497.5,378128.90625 5686497.5,378127.71875 5686497.5,378126.53125 5686497.5,378125.375 5686497,378124.1875 5686497,378122.625 5686497,378121.4375 5686497,378119.78125 5686497.5,378118.625 5686497.5,378117.84375 5686497.5,378116.65625 5686497,378115.875 5686497,378115.09375 5686497,378114.28125 5686497,378112.34375 5686496.5,378111.53125 5686496.5,378110.75 5686496.5,378108.78125 5686496.5,378107.625 5686496,378106.0625 5686496,378104.875 5686496,378104.46875 5686496,378103.6875 5686496,378103.3125 5686496,378102.5 5686495.5,378101.71875 5686495.5,378100.125 5686496,378098.9375 5686495.5,378098.15625 5686495.5,378097.375 5686495.5,378096.15625 5686496,378094.96875 5686495.5,378092.625 5686495.5,378090.25 5686495.5,378089.09375 5686495,378087.90625 5686495,378087.125 5686495,378086.34375 5686495,378085.1875 5686494.5,378083.625 5686494,378082.84375 5686494,378082.0625 5686494,378081.3125 5686493.5,378080.53125 5686493.5,378078.15625 5686493,378077 5686493,378075.40625 5686493,378074.25 5686493,378073.4375 5686493,378072.65625 5686492.5,378072.28125 5686492.5,378071.09375 5686492.5,378070.3125 5686492.5,378068.3125 5686492.5,378066.75 5686492.5,378065.5625 5686492.5,378064.78125 5686492.5,378064 5686492,378063.25 5686491.5,378062.46875 5686491.5,378061.65625 5686491.5,378060.5625 5686490.5,378059.78125 5686490.5,378058.21875 5686490.5,378057.4375 5686490.5,378055.46875 5686490,378054.28125 5686490,378053.15625 5686489.5,378052.75 5686489.5,378051.59375 5686489,378051.21875 5686489,378049.65625 5686489,378048.9375 5686488,378048.625 5686487,378047.875 5686486.5,378047.1875 5686485.5,378046.125 5686484,378045.78125 5686483.5,378045.03125 5686483,378044.625 5686483,378043.53125 5686482,378042.03125 5686481,378041.28125 5686481,378041.3125 5686480.5,378040.53125 5686480.5,378039.75 5686480,378038.96875 5686480,378038.5625 5686480,378037 5686480,378036.21875 5686480,378034.65625 5686479.5,378033.4375 5686480,378032.59375 5686480.5,378032.1875 5686480.5,378031.3125 5686481.5,378030.9375 5686481.5,378029.65625 5686482,378028.875 5686482,378028.03125 5686482.5,378026.46875 5686482.5,378025.59375 5686483,378024.40625 5686483,378023.5625 5686483.5,378023.125 5686484,378022.3125 5686484.5,378021.90625 5686484.5,378021.0625 5686485,378019.84375 5686485.5,378019.4375 5686485.5,378018.53125 5686486.5,378017.3125 5686486.5,378016.5 5686487,378016.03125 5686488,378015.5625 5686488.5,378015.125 5686489,378013.8125 5686490.5,378013.34375 5686491,378013.28125 5686492,378013.1875 5686492.5,378012.8125 5686492.5,378012.03125 5686492.5,378011.125 5686493.5,378009.4375 5686494.5,378008.96875 5686495.5,378008.53125 5686495.5,378008.15625 5686495.5,378008.0625 5686496.5,378007.25 5686497,378006.46875 5686496.5,378005.3125 5686496,378004.9375 5686496,378004.53125 5686496,378003.34375 5686496,378002.5625 5686496,378001 5686496,378000.21875 5686495.5,377998.25 5686495.5,377996.6875 5686495.5,377995.53125 5686495,377994.78125 5686494.5,377994 5686494.5,377993.21875 5686494,377992.09375 5686493.5,377991.28125 5686493.5,377989.71875 5686493.5,377989.34375 5686493.5,377987.75 5686493,377987.375 5686493,377986.1875 5686493,377985.78125 5686493,377984.6875 5686492,377984.3125 5686492,377983.125 5686492,377982.34375 5686492,377981.5625 5686492,377980.78125 5686491.5,377979.96875 5686491.5,377980.0625 5686491,377979.3125 5686490.5,377978.90625 5686490.5,377979 5686489.5,377978.21875 5686489.5,377977.5625 5686488,377976.53125 5686486,377975.875 5686485,377975.625 5686483.5,377975.65625 5686483,377974.9375 5686482,377974.65625 5686481,377974.75 5686480,377974 5686479.5,377974.03125 5686479,377973.75 5686478,377973.9375 5686476,377972.84375 5686475,377972.59375 5686473.5,377972.75 5686472,377972.46875 5686470.5,377972.5625 5686469.5,377971.90625 5686468,377971.625 5686467,377971.3125 5686466,377971.40625 5686465,377971.5 5686464,377971.1875 5686463.5,377970.46875 5686462.5,377970.5 5686462,377969.71875 5686462,377969.15625 5686459.5,377967.34375 5686458,377966.71875 5686456,377966.03125 5686455,377965.71875 5686454,377965.40625 5686453,377965.03125 5686453,377964.6875 5686452.5,377963.96875 5686451.5,377963.625 5686451,377962.84375 5686451,377962.4375 5686451,377962.0625 5686451,377960.875 5686451,377960.15625 5686450,377959.78125 5686450,377958.96875 5686450,377958.625 5686449.5,377957.5 5686449,377957.09375 5686449,377955.90625 5686448.5,377955.125 5686448.5,377955.25 5686447.5,377954.46875 5686447.5,377953.78125 5686446,377953.0625 5686445,377952.75 5686444.5,377952.46875 5686443,377952.125 5686442.5,377952.1875 5686442,377951.53125 5686440.5,377951.5625 5686440.5,377950.53125 5686438.5,377949.8125 5686437.5,377949.5 5686437,377949.1875 5686436,377948.875 5686435.5,377948.9375 5686434.5,377948.3125 5686433,377947.1875 5686432,377946.59375 5686430,377946.375 5686428.5,377946.09375 5686427,377945.8125 5686426,377945.46875 5686425,377945.59375 5686424,377944.875 5686423,377944.96875 5686422,377945.03125 5686421.5,377945.0625 5686421,377944.28125 5686421,377944.375 5686420,377944.4375 5686419.5,377944.03125 5686419.5,377943.84375 5686417.5,377941.625 5686415.5,377940.96875 5686414,377941.0625 5686413,377940.75 5686412,377939.96875 5686412,377940 5686411.5,377939.4375 5686409.5,377939.1875 5686407.5,377939.34375 5686406,377938.28125 5686405,377937.90625 5686405,377937.96875 5686404,377936.0625 5686403,377935.40625 5686401.5,377933.875 5686401,377933.1875 5686400,377932.875 5686399,377932.15625 5686398,377932.21875 5686398,377931.15625 5686396.5,377930.40625 5686396,377929.3125 5686394.5,377928.3125 5686393,377927.625 5686392,377927.375 5686390,377926.6875 5686389.5,377926.75 5686388.5,377925.96875 5686388.5,377926 5686388,377926.03125 5686387.5,377925.3125 5686387,377924.96875 5686386.5,377925 5686386,377924.625 5686386,377923.90625 5686385,377923.28125 5686383.5,377922.5625 5686382.5,377921.9375 5686381,377921.6875 5686379.5,377920.96875 5686378.5,377920.6875 5686377,377920.40625 5686376,377920.15625 5686374.5,377919.53125 5686372.5,377919.28125 5686371,377919.03125 5686369.5,377919.1875 5686368,377919.375 5686366,377919.53125 5686364.5,377919.6875 5686363,377919.84375 5686361,377919.9375 5686360,377919.625 5686359,377919.40625 5686357,377919.5 5686356.5,377919.6875 5686354.5,377919.78125 5686353.5,377919.9375 5686351.5,377920.0625 5686350.5,377920.15625 5686349.5,377920.25 5686348.5,377920.28125 5686348,377920.125 5686345.5,377919.09375 5686344,377918.375 5686343,377918.4375 5686342.5,377918.0625 5686342.5,377917.53125 5686339.5,377916.96875 5686337,377917.15625 5686335,377913.75 5686333.5,377912.25 5686332.5,377911.1875 5686331.5,377910.46875 5686330.5,377910.09375 5686330,377909.71875 5686330,377908.9375 5686330,377909.03125 5686328.5,377907.5 5686328,377906.8125 5686327.5,377906.40625 5686327.5,377905.71875 5686326,377903.875 5686324.5,377902.8125 5686323.5,377902.09375 5686322.5,377901 5686321.5,377900.28125 5686320.5,377899.59375 5686320,377899.25 5686319,377898.5 5686318.5,377898.5625 5686318,377898.15625 5686318,377896.96875 5686318,377896.1875 5686318,377894.21875 5686317.5,377893.4375 5686317.5,377892.28125 5686317.5,377891.4375 5686318,377891.03125 5686318,377890.15625 5686319,377889.375 5686319,377887.8125 5686318.5,377887.375 5686319,377886.15625 5686319.5,377885.375 5686319,377885.25 5686320.5,377884.40625 5686321,377882.75 5686321.5,377881.5 5686322.5,377880.6875 5686322.5,377880.25 5686323,377879.375 5686323.5,377879 5686323.5,377877.65625 5686325,377876.40625 5686326,377875.5625 5686326.5,377875.46875 5686327.5,377875.09375 5686327.5,377874.96875 5686328.5,377874.15625 5686329,377872.65625 5686332,377871.71875 5686333.5,377871.21875 5686334.5,377871.125 5686335.5,377871.09375 5686336,377871 5686337,377870.09375 5686338,377870 5686339,377869.03125 5686341,377868.15625 5686341.5,377868.0625 5686343,377867.53125 5686344,377867.4375 5686345,377866.9375 5686346.5,377865.9375 5686348,377865.4375 5686349.5,377865.375 5686350,377865.34375 5686350.5,377865.3125 5686351,377864.5 5686351,377863.53125 5686352.5,377863.03125 5686354,377862.9375 5686355,377862.375 5686356.5,377862.21875 5686358,377861.71875 5686359.5,377860.8125 5686360.5,377860.75 5686361,377860.375 5686361,377859.65625 5686364.5,377858.625 5686367,377858.5 5686368,377858.40625 5686369.5,377858.34375 5686369.5,377858.3125 5686370,377858.25 5686371,377858.21875 5686371.5,377857.75 5686372,377857.6875 5686372.5,377856.8125 5686373.5,377856.53125 5686376.5,377856.5 5686376.5,377856.46875 5686377,377856.3125 5686378.5,377856.25 5686379.5,377856.09375 5686381,377856.03125 5686382,377855.875 5686383.5,377855.78125 5686384,377855.46875 5686387.5,377855.3125 5686389,377855.125 5686391,377854.9375 5686393,377854.8125 5686394.5,377854.34375 5686395,377853.46875 5686396,377853.03125 5686396.5,377852.125 5686397.5,377851.6875 5686398,377850.71875 5686400,377849.875 5686400.5,377849.34375 5686402,377849.25 5686403,377849.1875 5686403.5,377849.09375 5686404.5,377848.1875 5686405.5,377848.125 5686406.5,377847.90625 5686409,377847.75 5686410.5,377847.5625 5686412.5,377847.375 5686414.5,377847.3125 5686415,377847.21875 5686416,377847.15625 5686416.5,377847 5686418,377846.8125 5686420,377846.6875 5686421.5,377846.5625 5686423,377847.15625 5686425,377847.4375 5686426,377847.3125 5686427.5,377847.21875 5686428.5,377847.09375 5686429.5,377847.03125 5686430.5,377846.96875 5686431,377847.375 5686431,377847.15625 5686433.5,377847.78125 5686435,377847.71875 5686436,377847.625 5686436.5,377848.40625 5686436.5,377848.65625 5686438,377850.875 5686440,377851.96875 5686441,377852.28125 5686442,377853.0625 5686442,377853.40625 5686442.5,377854.53125 5686443,377856.03125 5686444,377857.21875 5686444.5,377857.96875 5686444.5,377858.625 5686446,377859.40625 5686446,377860.53125 5686447,377862.0625 5686447.5,377863.15625 5686448.5,377863.5 5686449,377864.3125 5686449,377864.6875 5686449,377865 5686450,377865.78125 5686450,377866.9375 5686450.5,377867.71875 5686450.5,377869.28125 5686450.5,377870.0625 5686450.5,377871.65625 5686451,377872.4375 5686451,377874.03125 5686450.5,377875.21875 5686451,377876 5686451,377876.875 5686450,377877.65625 5686450.5,377879.25 5686450,377880.84375 5686450,377881.625 5686450.5,377882.90625 5686449.5,377883.3125 5686449.5,377884.15625 5686448.5,377884.9375 5686448.5,377886.21875 5686447.5,377887.03125 5686447.5,377888.25 5686447.5,377888.625 5686447.5,377889.4375 5686447,377890.25 5686447,377891.09375 5686446.5,377892.28125 5686446.5,377894.25 5686447,377896.1875 5686447,377897.375 5686447,377898.15625 5686447,377899.34375 5686447.5,377900.125 5686447.5,377901.21875 5686448.5,377903.5625 5686449,377905.0625 5686450,377905.75 5686451,377906.53125 5686451,377907.34375 5686451,377908.03125 5686452,377908.78125 5686452.5,377909.90625 5686453,377910.6875 5686453.5,377912.5 5686455,377913.59375 5686456,377914.34375 5686456.5,377915.0625 5686457.5,377915.40625 5686457.5,377915.71875 5686458.5,377916.3125 5686460.5,377918.5625 5686462,377919.625 5686463.5,377920.3125 5686464.5,377921.03125 5686465.5,377921.375 5686466,377921.71875 5686466.5,377922.4375 5686467,377922.78125 5686467.5,377923.125 5686468.5,377924.59375 5686469.5,377925.71875 5686470.5,377926.03125 5686471,377926.75 5686472,377927.09375 5686472.5,377927.5 5686472.5,377928.1875 5686473.5,377928.5625 5686473.5,377929.21875 5686475,377930.75 5686475.5,377931.46875 5686476.5,377932.21875 5686477,377932.9375 5686478,377933.625 5686478.5,377934.34375 5686479.5,377934.65625 5686480.5,377935.375 5686481,377935.6875 5686482,377936.4375 5686482.5,377936.40625 5686483,377937.125 5686483.5,377937.46875 5686484,377938.1875 5686485,377938.09375 5686486,377938.46875 5686486.5,377939.53125 5686487.5,377940.28125 5686488,377940.25 5686488.5,377940.5625 5686489.5,377941.28125 5686490,377941.59375 5686491,377941.875 5686492,377942.96875 5686493,377943.6875 5686494,377944.34375 5686495,377945.09375 5686495.5,377945.03125 5686496.5,377945.40625 5686496.5,377946.09375 5686498,377947.59375 5686498.5,377948.21875 5686500.5,377949.71875 5686501.5,377950.03125 5686502,377950.75 5686503,377951.0625 5686504,377951.4375 5686504.5,377952.21875 5686504.5,377952.125 5686505,377952.53125 5686505,377953.71875 5686505.5,377954.6875 5686507.5,377956.53125 5686509,377957.25 5686509.5,377957.5625 5686510.5,377957.96875 5686510.5,377957.90625 5686511.5,377958.625 5686512,377959.75 5686512.5,377960.125 5686512.5,377960.8125 5686514,377961.15625 5686514.5,377960.9375 5686517,377960.78125 5686518.5,377960.59375 5686520.5,377960.4375 5686522,377960.3125 5686523.5,377960.1875 5686524.5,377960.09375 5686526,377959.96875 5686527,377959 5686529,377958.90625 5686529.5,377958.8125 5686531,377958.71875 5686531.5,377958.625 5686533,377958.59375 5686533,377957.5625 5686535.5,377957 5686537.5,377956.90625 5686538,377956.4375 5686539,377956.34375 5686540,377955.5 5686540.5,377954.21875 5686541.5,377953.40625 5686542,377952.53125 5686542.5,377952.125 5686543,377951.21875 5686544,377950 5686544.5,377949.125 5686545,377948.71875 5686545.5,377948.3125 5686545.5,377947.90625 5686545,377947.0625 5686546,377946.625 5686546.5,377945.40625 5686546.5,377944.25 5686546.5,377943.0625 5686546.5,377941.875 5686546,377941.40625 5686547,377940.59375 5686547.5,377939.40625 5686547,377938.625 5686547,377937.4375 5686547,377936.65625 5686547,377935.09375 5686546.5,377933.90625 5686546.5,377933.125 5686546.5,377932.34375 5686546.5,377931.5625 5686546.5,377930.375 5686546,377929.59375 5686546,377928.0625 5686545.5,377926.90625 5686545,377926.125 5686545,377925.34375 5686545,377924.53125 5686545.5,377922.09375 5686546,377921.28125 5686546,377920.40625 5686547,377919.625 5686546.5,377919.21875 5686546.5,377918.40625 5686547,377917.5 5686548,377917.40625 5686549.5,377916.4375 5686550,377916.40625 5686552.5,377915.59375 5686558,377914.71875 5686565.5,377914.6875 5686571,377914.65625 5686574,377914.625 5686576.5,377914.1875 5686581.5,377914.15625 5686585.5,377914.125 5686589.5,377914.09375 5686593,377914.8125 5686600.5,377915.53125 5686607,377916.6875 5686610.5,377917.84375 5686614,377920.15625 5686616,377920.09375 5686616.5,377920.375 5686618,377920.3125 5686618.5,377920.125 5686620.5,377920 5686622,377919.875 5686623.5,377919.71875 5686625,377919.6875 5686625.5,377919.59375 5686626,377918.75 5686627,377918.6875 5686627.5,377918.625 5686628,377918.1875 5686628.5,377918.15625 5686629,377918.125 5686629,377917.9375 5686631,377917.78125 5686633,377917.625 5686634.5,377918.28125 5686636,377918.59375 5686637,377918.5 5686637.5,377918.46875 5686638,377920.4375 5686638,377921.125 5686639.5,377921.90625 5686639.5,377922.6875 5686639.5,377923.0625 5686639.5,377923.40625 5686640.5,377924.15625 5686641,377925.3125 5686641,377926.09375 5686641,377927.28125 5686641.5,377928.0625 5686641.5,377929.625 5686641.5,377930.4375 5686641.5,377931.125 5686642.5,377931.5 5686643,377931.84375 5686643.5,377932.625 5686643.5,377934.09375 5686645,377935.21875 5686645.5,377936.375 5686646,377936.6875 5686646.5,377937 5686647.5,377937.75 5686648,377938.4375 5686649,377939.125 5686650,377939.84375 5686651,377940.15625 5686651.5,377940.5 5686652.5,377941.15625 5686654,377941.46875 5686654.5,377941.75 5686656,377942.03125 5686657,377942.71875 5686658.5,377943.03125 5686659,377942.90625 5686660.5,377943.59375 5686661.5,377943.90625 5686662.5,377944.1875 5686663.5,377944.4375 5686665.5,377944.71875 5686666.5,377945.03125 5686667.5,377945.28125 5686669,377945.5625 5686670,377945.84375 5686671.5,377945.71875 5686672.5,377945.65625 5686673.5,377946.3125 5686674.5,377947 5686676,377946.90625 5686676.5,377946.8125 5686678,377946.71875 5686678.5,377946.53125 5686680.5,377946.4375 5686682,377946.3125 5686683,377946.21875 5686684,377946.09375 5686685.5,377946.0625 5686685.5,377945.9375 5686687,377945.875 5686687.5,377945.71875 5686689.5,377945.65625 5686690,377944.84375 5686690,377944.46875 5686690,377943.59375 5686690.5,377942.375 5686691,377941.59375 5686691,377940.8125 5686691,377940.03125 5686690.5,377938.84375 5686690.5,377938.46875 5686690.5,377937.28125 5686690.5,377936.5 5686690.5,377934.9375 5686690,377933.75 5686690,377932.96875 5686690,377932.5625 5686690,377931.78125 5686690,377931.46875 5686689,377930.3125 5686688.5,377929.53125 5686688.5,377929.15625 5686688.5,377927.96875 5686688.5,377927.5625 5686688,377926.78125 5686688,377926 5686688,377923.9375 5686689,377922.6875 5686689.5,377921.46875 5686690,377921 5686690.5,377920.59375 5686690.5,377919.4375 5686690.5,377918.21875 5686691,377916.625 5686690.5,377916.25 5686690.5,377915.84375 5686690.5,377915.46875 5686690.5,377914.28125 5686690.5,377913.875 5686690.5,377913.09375 5686690.5,377912.71875 5686690.5,377911.96875 5686690,377911.5625 5686690,377910.40625 5686689.5,377910 5686689.5,377909.25 5686689,377908.84375 5686689,377908.0625 5686689,377907.28125 5686689,377906.09375 5686689,377905.71875 5686689,377904.8125 5686690,377903.21875 5686690,377901.96875 5686691,377901.5625 5686691,377900.28125 5686692,377898.25 5686692.5,377897.375 5686693,377896.5 5686694,377896.125 5686694,377895.96875 5686695.5,377893.5 5686696.5,377892.1875 5686698,377891.3125 5686698.5,377890.875 5686699,377890.8125 5686699.5,377890.75 5686700.5,377890.6875 5686701,377889.90625 5686700.5,377889.84375 5686701.5,377889.375 5686702,377889.09375 5686705,377888.21875 5686706,377888.125 5686707,377888.03125 5686708,377887.9375 5686709,377887.875 5686709.5,377887.75 5686711,377887.6875 5686711.5,377887.5625 5686713,377887.5 5686713.5,377887.4375 5686714.5,377887.96875 5686717,377888.21875 5686717.5),(378145.21875 5686513.5,378145.125 5686514.5,378145.4375 5686515.5,378146.34375 5686518.5,378147.03125 5686519.5,378147.6875 5686521,378147.59375 5686522,378147.90625 5686523,378147.875 5686523.5,378147.75 5686524.5,378148.5 5686525,378149.125 5686526.5,378149.84375 5686527.5,378150.15625 5686528.5,378150.90625 5686529,378151.21875 5686529.5,378151.53125 5686530.5,378151.75 5686532.5,378152.8125 5686534,378153.5 5686535,378154.125 5686536.5,378154.4375 5686537.5,378154.375 5686538.5,378155.0625 5686539,378154.9375 5686540.5,378155.625 5686541.5,378155.5 5686543,378155.40625 5686544,378155.8125 5686544,378156 5686546,378156.65625 5686547.5,378156.5625 5686548.5,378156.53125 5686549,378156.3125 5686551,378156.9375 5686553,378156.90625 5686553.5,378156.84375 5686554,378157.625 5686554,378157.8125 5686556,378157.71875 5686557.5,378158.4375 5686558,378158.375 5686558.5,378159.15625 5686558.5,378159.8125 5686560.5,378160.09375 5686561.5,378160 5686562.5,378161.15625 5686563,378160.96875 5686565,378160.8125 5686566.5,378160.71875 5686567.5,378160.59375 5686568.5,378159.59375 5686571,378159.40625 5686573,378159.25 5686574.5,378157.96875 5686575.5,378157.4375 5686577,378157.375 5686577.5,378157.3125 5686578.5,378157.21875 5686579,378156.84375 5686579,378156.375 5686580,378156.28125 5686580.5,378156.21875 5686581.5,378156.1875 5686582,378155.3125 5686582.5,378155.28125 5686583,378155.21875 5686583.5,378155.125 5686584.5,378155.03125 5686585.5,378154.9375 5686586.5,378154.84375 5686587.5,378154.75 5686588.5,378154.6875 5686589,378154.65625 5686589.5,378154.53125 5686591,378154.5 5686591,378154.40625 5686592,378153.59375 5686592.5,378153.40625 5686594,378152.125 5686595.5,378152 5686596.5,378151.9375 5686597.5,378151.84375 5686598,378151.375 5686599,378151.28125 5686600,378151.1875 5686601,378150.59375 5686603,378150.09375 5686604,378150 5686605,378149.9375 5686606,378149.84375 5686606.5,378149.03125 5686607,378148.09375 5686608.5,378147.625 5686609,378147.5625 5686610,378147.46875 5686610.5,378147.46875 5686611,378147.40625 5686611.5,378146.9375 5686612.5,378146.15625 5686612,378146.125 5686612.5,378145.25 5686613.5,378144.6875 5686615,378144.5625 5686616.5,378143.78125 5686616.5,378142.40625 5686618,378141.875 5686619.5,378141.84375 5686620,378139.84375 5686620.5,378139.3125 5686621.5,378139.25 5686622,378139.1875 5686623,378136.78125 5686623,378135.90625 5686624,378135.875 5686624.5,378135.09375 5686624,378133.8125 5686625,378132.96875 5686625.5,378132.5625 5686626,378132.5 5686626.5,378132.28125 5686628.5,378131.34375 5686630,378131.28125 5686631,378131.15625 5686632,378131.09375 5686633,378131.0625 5686633.5,378130.90625 5686635,378129.96875 5686636.5,378129.9375 5686637,378129.84375 5686637.5,378129.78125 5686638.5,378129.75 5686638.5,378129.65625 5686639.5,378129.5625 5686640.5,378129.46875 5686641.5,378129.40625 5686642.5,378130.125 5686643,378130.09375 5686643.5,378130 5686644.5,378130.78125 5686644.5,378130.96875 5686647,378130.8125 5686648.5,378130.6875 5686649.5,378130.59375 5686650.5,378130.4375 5686652.5,378130.3125 5686653.5,378130.25 5686654.5,378130.03125 5686656.5,378130 5686657,378129.90625 5686658,378129.875 5686658,378129.75 5686659.5,378128.15625 5686659.5,378127.25 5686660.5,378126.78125 5686661.5,378126.75 5686662,378126.3125 5686662,378125.5 5686662.5,378125.09375 5686662.5,378124.3125 5686662.5,378123.46875 5686663,378123.375 5686664,378122.59375 5686664,378120.53125 5686665,378119.65625 5686665.5,378118.875 5686665.5,378118.40625 5686666,378116.75 5686667,378116.34375 5686667,378115.15625 5686667,378114.375 5686667,378113.46875 5686668,378112.28125 5686668,378111.5 5686668,378109.875 5686668.5,378108.65625 5686669,378107.46875 5686668.5,378107.0625 5686668.5,378106.6875 5686668.5,378105.90625 5686668.5,378105.03125 5686669,378103.875 5686669,378101.90625 5686669,378100.71875 5686669,378099.9375 5686668.5,378099.15625 5686668.5,378098.75 5686668.5,378097.96875 5686668.5,378096.40625 5686668.5,378094.5 5686667.5,378093.34375 5686667,378092.9375 5686667,378092.15625 5686667,378091.375 5686667,378090.65625 5686666,378089.90625 5686665.5,378088.34375 5686665.5,378087.5625 5686665.5,378087.15625 5686665.5,378086.375 5686665.5,378085.1875 5686665,378084.40625 5686665,378083.21875 5686665,378082.84375 5686665,378082.0625 5686665,378081.28125 5686665,378080.46875 5686664.5,378079.3125 5686664.5,378077.34375 5686664.5,378075.78125 5686664.5,378074.59375 5686664,378074.1875 5686664,378073.8125 5686664,378073.03125 5686664,378071.84375 5686664,378069.875 5686663.5,378069.09375 5686663.5,378067.125 5686663.5,378065.90625 5686663.5,378065.125 5686663.5,378064.34375 5686663.5,378075.375 5686660.5,378075.40625 5686660,378076.1875 5686660,378076.6875 5686659,378077.15625 5686658,378077.28125 5686657,378078.125 5686656,378078.90625 5686656,378079.03125 5686655,378080.71875 5686654,378081.5 5686654,378081.59375 5686653,378081.65625 5686652.5,378082.15625 5686651.5,378082.1875 5686651,378083.4375 5686650.5,378083.875 5686650,378084.34375 5686649,378085.5625 5686649,378085.96875 5686648.5,378086.40625 5686648.5,378087.3125 5686647,378088.5625 5686646.5,378089.4375 5686646,378089.9375 5686644.5,378091.1875 5686644,378091.65625 5686643,378092.125 5686642.5,378092.15625 5686642,378092.21875 5686641.5,378092.625 5686641.5,378093.59375 5686639.5,378093.71875 5686638.5,378093.78125 5686637.5,378093.90625 5686636.5,378093.96875 5686635.5,378094 5686635,378094.09375 5686634.5,378094.15625 5686633.5,378093.5625 5686631.5,378093.25 5686630.5,378093.3125 5686630,378093.34375 5686629.5,378093.5 5686628,378092.75 5686627.5,378092.5 5686626,378092.5625 5686625.5,378092.65625 5686624.5,378092.6875 5686624,378092.84375 5686622.5,378092.9375 5686621.5,378093.4375 5686620.5,378093.5 5686619.5,378094.78125 5686618.5,378094.875 5686617.5,378094.96875 5686616.5,378095.0625 5686616,378095.90625 5686615,378095.96875 5686614.5,378096.4375 5686614,378098.0625 5686613.5,378098.96875 5686612,378099.4375 5686611.5,378099.46875 5686611,378099.53125 5686610,378099.65625 5686609,378100.125 5686608.5,378100.28125 5686606.5,378100.34375 5686606,378100.53125 5686604,378100.625 5686603,378100.6875 5686602.5,378100.8125 5686601,378100.90625 5686600,378101.40625 5686599,378102.34375 5686597.5,378102.46875 5686596,378102.53125 5686595.5,378103 5686594.5,378103.40625 5686594.5,378103.5 5686593.5,378104.75 5686593,378105.6875 5686591.5,378106.96875 5686590.5,378107.40625 5686590,378107.84375 5686589.5,378108.75 5686588.5,378109.40625 5686588.5,378109.96875 5686588.5,378110.78125 5686588,378110.875 5686587,378111.65625 5686587,378111.6875 5686587,378111.71875 5686586.5,378112.59375 5686585.5,378112.71875 5686584,378112.8125 5686583.5,378113.75 5686582,378113.84375 5686580.5,378114 5686579,378114.09375 5686578.5,378114.1875 5686577,378114.28125 5686576.5,378114.34375 5686575.5,378114.03125 5686575,378114.125 5686573.5,378114.21875 5686573,378114.28125 5686572,378113.5625 5686571,378113.28125 5686570,378113.34375 5686569.5,378113.5625 5686567,378113.65625 5686566,378113.84375 5686564,378113.25 5686562,378112.96875 5686560.5,378113.125 5686559,378113.21875 5686558.5,378113.28125 5686557.5,378113.3125 5686557,378112.96875 5686557,378113.03125 5686556,378113.0625 5686555.5,378111.90625 5686555.5,378110.3125 5686555.5,378108.3125 5686555.5,378107.53125 5686555.5,378107.15625 5686555.5,378106.71875 5686555.5,378105.90625 5686556,378105.09375 5686556,378104.3125 5686556,378103.53125 5686556,378102.75 5686555.5,378101.5625 5686555.5,378100.40625 5686555.5,378100.03125 5686555,378099.3125 5686554,378098.59375 5686553.5,378096.625 5686553.5,378095.125 5686552.5,378094.34375 5686552.5,378093.15625 5686552.5,378092.8125 5686552,378091.65625 5686551.5,378091.28125 5686551.5,378089.6875 5686551,378088.53125 5686551,378086.5625 5686551,378084.625 5686550.5,378083.4375 5686550,378083.0625 5686550,378082.65625 5686550,378082.28125 5686550,378081.5 5686550,378081.09375 5686550,378080 5686549,378078.8125 5686549,378078.21875 5686547,378077.125 5686546,378076 5686545,378075.65625 5686544.5,378074.875 5686544.5,378074.15625 5686543.5,378073.375 5686543.5,378071.53125 5686542,378069.71875 5686540.5,378068.6875 5686539,378067.65625 5686537,378066.96875 5686536,378066.3125 5686534.5,378066 5686533.5,378065.3125 5686532.5,378065 5686531.5,378065.0625 5686531,378064.34375 5686530,378064.4375 5686529,378063.71875 5686528.5,378063.75 5686528,378063.90625 5686526.5,378063.96875 5686525.5,378063.3125 5686524.5,378063.375 5686523.5,378063.46875 5686523,378063.5 5686522.5,378063.65625 5686521,378063.75 5686519.5,378063.84375 5686519,378064.625 5686519,378065.90625 5686518,378067.90625 5686517.5,378069.125 5686517.5,378070 5686516.5,378070.8125 5686516.5,378072.0625 5686515.5,378072.9375 5686515,378073.78125 5686514.5,378074.6875 5686513,378075.53125 5686512.5,378076.34375 5686512.5,378076.40625 5686511.5,378076.4375 5686511.5,378077.625 5686511.5,378078.875 5686511,378080.875 5686510.5,378081.65625 5686510.5,378082.4375 5686511,378083.21875 5686511,378083.625 5686511,378084.8125 5686511,378085.59375 5686511,378087.21875 5686510.5,378089.1875 5686510.5,378090.0625 5686510,378090.84375 5686510,378092.0625 5686510,378092.21875 5686510,378095.40625 5686512,378099.71875 5686514.5,378103.28125 5686515.5,378108 5686517.5,378113.125 5686518,378117.46875 5686519,378121.8125 5686519,378126.5625 5686519,378131.3125 5686519,378135.25 5686518.5,378138.4375 5686517.5,378143.1875 5686515,378145.21875 5686513.5),(378774.4375 5685824.5,378776.46875 5685827,378781.53125 5685834,378783.875 5685837.5,378787 5685842,378790.90625 5685846.5,378796.40625 5685850,378798.6875 5685851,378798.625 5685851.5,378798.5625 5685852,378798.4375 5685853,378798.34375 5685854.5,378799.34375 5685856,378799.28125 5685857,378798.875 5685861,378798.65625 5685863.5,378798.375 5685866.5,378798.125 5685869,378798 5685870.5,378797.46875 5685872,378797 5685872.5,378796.875 5685873.5,378796.8125 5685874.5,378796.78125 5685875,378796 5685875,378794.9375 5685877.5,378790.625 5685881,378789.15625 5685884,378787.6875 5685887,378786.40625 5685888,378785.09375 5685889,378783.8125 5685890.5,378782.53125 5685891.5,378780.875 5685892,378780.03125 5685892.5,378778.75 5685893.5,378777.90625 5685894,378776.65625 5685894.5,378775.4375 5685895,378774.1875 5685895.5,378773.34375 5685896,378772.53125 5685896.5,378771.3125 5685896.5,378770.53125 5685896.5,378769.75 5685896.5,378768.53125 5685896.5,378766.875 5685897.5,378765.65625 5685897.5,378764.46875 5685898,378763.625 5685898,378762.375 5685899,378761.5625 5685899,378760.6875 5685900,378759.84375 5685900.5,378758.625 5685901,378757.71875 5685902,378756.4375 5685903,378755.09375 5685904.5,378753.375 5685906,378752.4375 5685907.5,378751.5625 5685908.5,378750.65625 5685909.5,378749.78125 5685910.5,378748.96875 5685910.5,378748.15625 5685911,378747.28125 5685911.5,378746.0625 5685912,378744.78125 5685913,378742.78125 5685913,378741.5 5685914,378740.1875 5685915.5,378739.375 5685915.5,378739.3125 5685916.5,378738.46875 5685916.5,378738.4375 5685917,378737.625 5685917.5,378736.6875 5685919,378735.4375 5685919.5,378734.53125 5685920.5,378732.8125 5685922,378731.90625 5685923,378731 5685924.5,378730.15625 5685925,378729.28125 5685925.5,378728.4375 5685926.5,378727.5625 5685927,378726.71875 5685928,378725.84375 5685928.5,378724.59375 5685929,378723.75 5685930,378722.90625 5685930,378722.0625 5685931,378721.1875 5685931.5,378720.34375 5685932.5,378719.46875 5685933,378718.21875 5685933.5,378717.375 5685934.5,378716.90625 5685935,378716.03125 5685936,378715.21875 5685936,378714.78125 5685936.5,378713.90625 5685937.5,378713.4375 5685938,378712.9375 5685939,378712.125 5685939.5,378711.65625 5685940,378711.53125 5685941.5,378710.65625 5685942.5,378709.34375 5685943.5,378708.875 5685944.5,378708.40625 5685945,378707.5625 5685946,378707.09375 5685946.5,378705.78125 5685948,378704.5625 5685948,378703.65625 5685949.5,378703.15625 5685950.5,378702.25 5685951.5,378701.34375 5685952.5,378700.84375 5685954,378699.90625 5685955.5,378698.96875 5685957,378698.4375 5685958.5,378697.53125 5685959.5,378697 5685961,378696.5 5685962,378696.03125 5685963,378695.5625 5685963.5,378695.53125 5685964,378695.125 5685964,378694.125 5685966.5,378692.75 5685968,378692.21875 5685969.5,378692.0625 5685971,378692.03125 5685971.5,378691.96875 5685972,378691.875 5685973,378690.96875 5685974.5,378690.71875 5685977,378689.375 5685978.5,378688.53125 5685979,378688 5685980.5,378687.625 5685980.5,378687.5 5685981.5,378686.6875 5685982,378684.53125 5685983.5,378682.875 5685984,378681.5625 5685985.5,378680.65625 5685987,378680.1875 5685987.5,378680.15625 5685988,378659.96875 5685975,378660 5685974.5,378660.0625 5685974,378660.15625 5685973,378660.25 5685972,378660.3125 5685971.5,378659.65625 5685970,378659.34375 5685969,378659.40625 5685968.5,378659.5 5685967.5,378659.5625 5685966.5,378659.1875 5685966.5,378658.875 5685966,378658.90625 5685965.5,378658.21875 5685964,378658.3125 5685963.5,378657.28125 5685961.5,378656.96875 5685961,378657.0625 5685959.5,378657.15625 5685959,378656.875 5685957.5,378656.53125 5685957,378655.90625 5685955,378655.1875 5685954.5,378655.28125 5685953.5,378655.3125 5685953,378655.03125 5685952,378654.6875 5685951.5,378654.03125 5685950,378653.71875 5685949,378653.78125 5685948.5,378653.90625 5685947,378653.9375 5685946.5,378653.96875 5685946.5,378653.6875 5685945,378653.75 5685944.5,378653.09375 5685943,378653.1875 5685942.5,378652.65625 5685939.5,378652.03125 5685938,378652.125 5685936.5,378652.25 5685935.5,378652.3125 5685934.5,378652.40625 5685934,378652.4375 5685933.5,378652.125 5685932.5,378652.25 5685931,378651.9375 5685930,378651.65625 5685929,378651.75 5685928,378651.875 5685926.5,378651.1875 5685926,378651.3125 5685924,378651.4375 5685923,378651.5625 5685922,378651.28125 5685920.5,378651.4375 5685919,378651.5 5685918,378651.53125 5685918,378651.59375 5685917,378650.9375 5685916,378650.96875 5685915.5,378651.0625 5685914.5,378651.09375 5685914,378651.15625 5685913.5,378651.1875 5685913,378651.375 5685911,378652.25 5685910.5,378652.40625 5685909,378653.28125 5685907.5,378653.8125 5685906.5,378654.65625 5685906,378655.09375 5685905.5,378655.5625 5685904.5,378656.375 5685904.5,378657.15625 5685904.5,378658.84375 5685903.5,378660.46875 5685903.5,378661.34375 5685902,378662.21875 5685901.5,378663.46875 5685901,378664.71875 5685900,378665.96875 5685899.5,378666.84375 5685898.5,378668.0625 5685898.5,378668.90625 5685898,378669.8125 5685896.5,378671.0625 5685896,378671.96875 5685895,378673.21875 5685894,378674.46875 5685893.5,378675.3125 5685893,378676.53125 5685892.5,378677.375 5685892,378678.21875 5685891.5,378679.0625 5685891,378679.875 5685891,378680.6875 5685890.5,378681.96875 5685889.5,378683.625 5685889,378684.5 5685888,378685.34375 5685887.5,378686.59375 5685887,378687.46875 5685886,378688.71875 5685885.5,378689.96875 5685885,378690.78125 5685884.5,378692 5685884,378693.3125 5685883,378694.9375 5685882.5,378696.625 5685881.5,378697.875 5685881,378699.5625 5685880,378701.25 5685879,378702.5 5685878,378703.78125 5685877,378705.4375 5685876.5,378706.28125 5685875.5,378707.1875 5685874.5,378708.0625 5685874,378708.90625 5685873,378709.375 5685872.5,378710.21875 5685872,378710.625 5685872,378711.53125 5685870.5,378712.34375 5685870.5,378713.65625 5685869.5,378714.90625 5685868.5,378715.34375 5685868.5,378715.8125 5685867.5,378717.09375 5685866.5,378717.9375 5685866,378720.0625 5685864.5,378722.53125 5685863.5,378723.40625 5685862.5,378724.25 5685862,378724.6875 5685861.5,378725.53125 5685861,378726 5685860,378727.25 5685859.5,378729.03125 5685857.5,378731.0625 5685857,378732.34375 5685856,378733.25 5685855,378734.09375 5685854.5,378734.5625 5685853.5,378735 5685853,378735.84375 5685853,378736.71875 5685852,378738.34375 5685851.5,378739.1875 5685851,378740.5 5685850,378741.34375 5685849,378742.21875 5685848.5,378743.46875 5685847.5,378744.3125 5685847,378744.78125 5685846,378745.65625 5685845.5,378746.5 5685845,378746.96875 5685844,378747.4375 5685843.5,378747.53125 5685842.5,378748.40625 5685841.5,378748.5 5685840.5,378748.625 5685839,378749.15625 5685838,378749.28125 5685836.5,378749.40625 5685835,378749.5625 5685833.5,378749.71875 5685832,378750.21875 5685831,378750.375 5685829.5,378751.21875 5685828.5,378751.34375 5685827.5,378751.375 5685827,378751.40625 5685826.5,378752.59375 5685826.5,378753.90625 5685825.5,378756.34375 5685824.5,378757.5625 5685824.5,378758.78125 5685824,378759.96875 5685824.5,378760.75 5685824.5,378762.78125 5685824,378765.5625 5685823.5,378767.125 5685824,378768.71875 5685824,378770.28125 5685824,378771.46875 5685824.5,378772.25 5685824.5,378773.03125 5685824.5,378774.21875 5685824.5,378774.4375 5685824.5))
</a>
<test>
- <op name="buffer" arg1="a" arg3="60">
+ <op name="buffer" arg1="a" arg2="60">
POLYGON((377787.21236766 5686430.83570257,377787.091569461 5686434.83708883,377787.737693002 5686438.88795447,377787.864087559 5686442.68909533,377788.459649403 5686444.80578393,377788.880197144 5686448.70852724,377792.362122552 5686459.86695051,377797.94149236 5686470.13850574,377798.930849234 5686471.33060785,377799.58710372 5686472.52852275,377804.899910503 5686478.52288668,377805.406547456 5686479.13334686,377805.529915074 5686479.23371183,377805.644567469 5686479.36307249,377807.392061045 5686481.81156509,377816.741061307 5686490.34144172,377819.268024607 5686491.8162556,377819.445913559 5686491.96408342,377821.252932048 5686492.97470892,377821.845793585 5686493.32072123,377822.749238227 5686493.92301766,377822.749238226 5686493.92301766,377823.285211318 5686494.21114939,377825.784078899 5686496.21427985,377828.942060624 5686497.86905437,377829.459811307 5686498.34144172,377829.814097052 5686498.54821383,377830.563106926 5686499.15138158,377833.445420292 5686500.66756629,377840.389980754 5686504.72062639,377852.415040396 5686508.66531166,377853.163293988 5686508.74466712,377854.777839837 5686509.25493736,377860.602216238 5686509.85131204,377862.571299679 5686510.30820919,377870.722679781 5686510.92891152,377865.18357042 5686518.6232882,377864.473453212 5686520.3059776,377860.565589664 5686528.1292516,377857.549254266 5686538.50328245,377856.91908596 5686544.62059585,377856.237925827 5686549.23152597,377855.997961655 5686551.04715803,377855.122961655 5686558.54715803,377854.719718468 5686565.15909641,377854.689275479 5686570.51706246,377854.660155864 5686573.31254549,377854.65773972 5686573.50583704,377854.41587695 5686576.26998298,377854.189330971 5686581.0312643,377854.127092524 5686588.99778552,377854.096141439 5686592.46430707,377854.367387449 5686598.72377641,377855.086137449 5686606.22377641,377855.17598771 5686607.09442203,377855.89473771 5686613.59442203,377858.280137917 5686624.53884835,377858.199446436 5686625.39955748,377858.119771519 5686626.32673996,377858.023869995 5686627.55427948,377857.947895467 5686628.28363494,377857.764790992 5686638.5933333,377859.05375186 5686646.88004093,377856.001223071 5686649.83265362,377854.203654971 5686651.45270116,377853.326280308 5686652.05597871,377846.157898318 5686658.98972353,377845.720398318 5686659.48972353,377842.727400395 5686663.68434142,377841.391454247 5686665.19681894,377840.139069476 5686667.31182779,377838.825885171 5686669.15222545,377838.128428148 5686670.70736908,377835.625770583 5686674.93382011,377833.502392192 5686680.82867703,377832.29696122 5686683.50412238,377831.973057845 5686685.07436739,377831.790848094 5686685.58021243,377831.644992471 5686686.50242365,377830.932850338 5686688.15831566,377828.480696436 5686700.39955748,377828.206798474 5686703.32113575,377828.082254505 5686704.51727121,377827.999100384 5686705.51512066,377827.894754505 5686706.51727121,377827.786916907 5686707.81132239,377825.943807975 5686715.901891,377825.220199407 5686720.61874685,377824.548478334 5686724.33904817,377823.601072878 5686734.06261442,377823.569822878 5686736.06261442,377823.565273476 5686736.42310359,377823.533360075 5686739.74209727,377823.493888631 5686740.08215895,377823.097623592 5686746.31822584,377823.035123592 5686751.81822584,377823.032218468 5686752.15909641,377823.000968468 5686757.65909641,377823.000968468 5686757.65909641,377824.027668784 5686769.0573121,377824.471288948 5686771.42328631,377824.974612037 5686775.27480212,377825.581424615 5686779.00143074,377825.630407432 5686779.25222276,377826.18246145 5686785.71058515,377829.233057786 5686796.57781887,377831.545557786 5686802.57781887,377831.545557786 5686802.57781887,377836.345640303 5686812.3054845,377840.626890303 5686819.3054845,377840.626890303 5686819.3054845,377847.353282914 5686828.29116548,377850.978282914 5686832.29116548,377852.700599818 5686834.04625263,377855.051235229 5686836.70891929,377857.484142848 5686839.30536223,377862.952892848 5686844.80536223,377862.952892848 5686844.80536223,377869.686775859 5686850.21221063,377877.705497875 5686857.14130645,377890.046530344 5686863.5692641,377892.365742884 5686864.45277363,377894.129456389 5686865.24397222,377894.129456389 5686865.24397222,377904.662578639 5686868.8378229,377915.678245555 5686870.42448905,377926.797449571 5686869.94937946,377937.637620798 5686867.42884086,377947.825789816 5686862.94959549,377957.011420141 5686856.66575728,377964.878468864 5686848.79352942,377971.156260501 5686839.60376559,377971.156260501 5686839.60376559,377973.375010501 5686835.60376559,377975.066906348 5686832.18392847,377978.977625886 5686827.94198421,377981.484173001 5686824.80335131,377983.913558476 5686822.09933965,377984.669362103 5686821.24180526,377986.185425879 5686819.48828571,377987.926419053 5686818.23633556,377989.293706174 5686817.31382859,377989.921927409 5686816.99473209,377989.873018893 5686816.89844345,377995.095714589 5686814.35114013,378003.770653794 5686807.98069055,378004.698589966 5686807,378004.875 5686807,378017.82150131 5686805.58658638,378030.158043911 5686801.41293679,378031.59311331 5686800.54545313,378041.188704049 5686795.65469523,378043.084469103 5686794.18364035,378044.434002771 5686793.52332062,378045.233912908 5686792.95104325,378045.931893418 5686792.61749202,378045.931893418 5686792.61749202,378046.775643418 5686792.11749202,378046.775643418 5686792.11749202,378056.930405571 5686784.5456087,378065.269249503 5686775.01060512,378066.675499503 5686773.01060512,378066.675499503 5686773.01060512,378067.710879139 5686771.22544555,378068.621616828 5686771.50978914,378070.328964472 5686772.15255531,378070.328964472 5686772.15255531,378071.629707797 5686772.53575925,378072.614108282 5686773.05358392,378083.73168367 5686776.37790347,378086.021479365 5686776.60036826,378086.217855703 5686776.66323325,378097.923439188 5686777.99341273,378109.663298452 5686777.01067847,378120.984829107 5686773.75291761,378131.451554502 5686768.34572595,378132.83400169 5686767.24255441,378133.275728824 5686767.16134463,378144.21991248 5686762.81009532,378147.862764532 5686760.44920264,378148.556893418 5686760.11749202,378148.556893418 5686760.11749202,378149.400643418 5686759.61749202,378149.400643418 5686759.61749202,378151.27530229 5686758.23757414,378154.103268256 5686756.40480024,378155.154383617 5686755.38222069,378158.072315767 5686753.23435965,378163.061983609 5686751.78430809,378173.126204049 5686746.65469523,378174.586891142 5686745.52124735,378178.843233609 5686744.28430809,378188.907454049 5686739.15469523,378197.831858343 5686732.22963429,378205.300122319 5686723.754583,378211.047534476 5686714.0299383,378214.870378653 5686703.40038876,378216.633154709 5686692.24269717,378216.633154709 5686692.24269717,378216.726904709 5686690.74269717,378216.726904709 5686690.74269717,378216.645742475 5686688.60917386,378227.027757499 5686682.98214966,378236.551161192 5686674.86971613,378244.185292614 5686664.95877101,378249.598264696 5686653.68018382,378249.598264696 5686653.68018382,378250.848264696 5686650.18018382,378250.848264696 5686650.18018382,378254.062179706 5686635.80595844,378254.499679706 5686631.30595844,378254.499679706 5686631.30595844,378254.729234386 5686623.00216732,378254.416734386 5686615.50216732,378253.356075385 5686606.49856926,378253.050996439 5686604.93656506,378252.60526229 5686600.90557797,378251.636894845 5686594.92825468,378250.886894845 5686591.42825468,378250.331105977 5686589.06835298,378249.668944511 5686586.49129214,378248.909831216 5686582.4426879,378248.654024391 5686581.15618521,378247.938225112 5686577.75130216,378247.715857559 5686576.12484234,378247.717303293 5686575.91665662,378247.71875 5686575.5,378247.71875 5686574.31249152,378247.737534969 5686572.50913452,378248.39564958 5686571.61381003,378250.086972119 5686567.80307527,378250.783169124 5686567.17477502,378251.960406524 5686565.56243201,378252.034074363 5686565.52578072,378253.415790902 5686564.48337878,378254.03959554 5686564.099499,378262.909901064 5686557.43656111,378264.933487426 5686555.226561,378265.24510196 5686554.98677176,378265.763339467 5686554.37955416,378266.671507815 5686553.74281608,378271.889194546 5686548.41174489,378272.022232248 5686548.53646773,378272.490982248 5686548.03646773,378273.453968001 5686546.81296766,378274.410590007 5686545.8355575,378274.816840007 5686545.33555751,378274.694827002 5686545.23642194,378277.147059306 5686542.12079289,378277.641602136 5686541.59510565,378277.947947396 5686541.10324239,378278.891109616 5686539.90492867,378279.078203741 5686539.55762228,378279.349962447 5686539.27034681,378280.020015725 5686538.20549869,378280.178482248 5686538.03646773,378280.865467086 5686537.29116548,378281.771717086 5686536.29116548,378281.771717086 5686536.29116548,378289.111109473 5686526.28042366,378289.588184921 5686525.2273648,378289.810851682 5686525.01027647,378290.497979114 5686524.22498798,378292.972080264 5686521.7936966,378299.768193168 5686511.64931356,378300.299443167 5686510.64931356,378300.299443167 5686510.64931356,378302.780656154 5686505.00791412,378303.295109949 5686504.19577969,378305.408136913 5686498.84630532,378305.516626195 5686498.60215308,378305.528653296 5686498.54119833,378307.443388493 5686493.6937321,378307.582809068 5686492.9597446,378307.950301597 5686491.92211864,378308.385479485 5686492.16072969,378314.207170076 5686496.95035064,378317.15747356 5686498.62266775,378317.530488227 5686498.92301766,378318.280488227 5686499.42301766,378318.280488226 5686499.42301766,378319.277926173 5686499.95504202,378321.075314038 5686501.4022915,378321.182831792 5686501.52701992,378324.324605925 5686504.08281167,378324.324779073 5686504.08297463,378324.781547456 5686504.63334686,378333.848959523 5686512.01008414,378344.174584471 5686517.48874125,378353.459109908 5686520.28659093,378355.699519231 5686521.15384615,378357.668269231 5686521.65384615,378359.426962812 5686521.87368285,378362.215339837 5686522.75493736,378365.566960279 5686523.09811944,378367.954373708 5686523.53219461,378370.998826888 5686523.80671278,378373.647177666 5686524.44179936,378385.481215174 5686524.88773271,378394.988365155 5686523.35316882,378398.235660894 5686523.09870308,378404.265772984 5686521.43700791,378404.471451269 5686521.4173832,378406.550548316 5686520.80740102,378409.249217489 5686520.06373896,378409.487854801 5686519.94563045,378415.408440581 5686518.20860145,378416.658440581 5686517.70860145,378416.658440581 5686517.70860145,378417.205932556 5686517.43318833,378417.718233609 5686517.28430809,378420.19869325 5686516.02004746,378420.856221764 5686515.80625902,378422.637998175 5686514.7767629,378427.782454049 5686512.15469523,378429.550356832 5686510.7828575,378431.723905632 5686509.52699844,378435.162318673 5686506.42814917,378436.706858343 5686505.22963429,378437.535289576 5686504.28952328,378441.047459662 5686501.12420091,378448.418885996 5686490.96557208,378448.624675583 5686490.50245318,378449.381599944 5686489.4951906,378450.392909613 5686487.45810343,378450.536892713 5686487.21127526,378451.314091539 5686486.1780779,378456.699493191 5686474.38796509,378459.427104533 5686461.71636506,378459.583354533 5686460.21636506,378459.698995495 5686458.98272879,378459.782149616 5686457.98487934,378459.886495495 5686456.98272879,378460.033802457 5686455.21504524,378460.118158214 5686454.54019919,378460.724172603 5686451.94208407,378460.849172603 5686450.94208408,378461.105245495 5686448.48272879,378461.188399616 5686447.48487934,378461.292745495 5686446.48272879,378461.417745495 5686444.98272879,378461.407762427 5686444.98189687,378461.570654709 5686443.24269717,378461.633154709 5686442.24269717,378461.633154709 5686442.24269717,378461.586212728 5686439.2200781,378461.831803564 5686436.60044252,378461.886495495 5686435.98272879,378461.985745646 5686434.79172697,378462.126964899 5686433.28538828,378462.358481413 5686430.97022314,378462.448995495 5686429.98272879,378462.52254423 5686429.10014397,378462.550689799 5686428.8299465,378462.599172603 5686428.44208407,378462.945654709 5686424.74269717,378463.039404709 5686423.24269717,378463.039404709 5686423.24269717,378462.760497768 5686416.45785223,378463.026022923 5686413.79197347,378462.913720164 5686412.2536499,378462.914404709 5686412.24269717,378462.848800117 5686410.88732273,378463.185646724 5686410.79501182,378463.425537409 5686410.74516441,378463.706274599 5686410.65233669,378468.916223591 5686409.22457959,378470.919633681 5686408.26718909,378476.4382307 5686406.44242641,378480.856071903 5686403.74435199,378482.244813679 5686403.05342394,378482.268336301 5686403.09458853,378482.983655565 5686402.68583466,378485.315324363 5686401.52578072,378494.147855443 5686394.86229565,378501.606683948 5686386.69029983,378501.686676282 5686386.56132124,378502.481683948 5686385.69029983,378504.660033884 5686382.17795703,378506.948682517 5686379.0269384,378507.797555292 5686377.62190759,378508.638023677 5686376.50059274,378514.04678878 5686364.49587762,378516.706803564 5686351.60044252,378517.064464899 5686347.78538828,378517.167259982 5686346.75743745,378517.863053564 5686343.60044252,378518.033214899 5686341.78538828,378518.264731413 5686339.47022314,378518.368139354 5686338.19706551,378518.488053564 5686337.10044252,378518.581803564 5686336.10044252,378518.634623593 5686335.42418208,378518.708354533 5686334.71636506,378518.712933798 5686334.42156822,378518.726904709 5686334.24269717,378518.758154709 5686333.74269717,378518.723512761 5686333.74053205,378518.872640897 5686324.14019089,378517.245233236 5686314.11876861,378525.327054795 5686308.20547945,378526.844298538 5686306.88133946,378528.391232407 5686305.55539614,378528.391232408 5686305.55539614,378530.433059692 5686303.49763807,378530.534230962 5686303.42670452,378531.236219692 5686302.94402129,378532.885980675 5686301.34826067,378534.491385764 5686300.20828228,378539.198661458 5686295.6800569,378539.59190745 5686295.45819816,378542.138030614 5686293.22902237,378543.05340656 5686292.67568768,378546.266262528 5686289.61468242,378548.850854898 5686287.35182616,378549.385775754 5686286.6426082,378549.497957834 5686286.53572824,378550.065942003 5686286.35193674,378555.043688699 5686283.49137127,378555.228753112 5686283.44222475,378562.484597062 5686280.09149011,378563.855476946 5686279.63797484,378574.844866515 5686273.16245682,378578.195086568 5686270.06962916,378579.925374024 5686268.55473194,378580.485185386 5686268.16609236,378581.978751324 5686267.29894701,378582.828406369 5686266.63580161,378583.728884702 5686266.36032462,378584.098168333 5686266.16106896,378584.167976946 5686266.13797484,378584.461319104 5686265.96512243,378589.118933177 5686263.45199732,378593.626204049 5686261.15469523,378602.550608343 5686254.22963429,378610.018872319 5686245.754583,378615.766284476 5686236.0299383,378616.636689569 5686233.60974705,378620.40138351 5686226.03082854,378620.919053422 5686224.56917231,378621.027280372 5686224.48588919,378622.44197345 5686222.82818932,378624.585394632 5686220.77008529,378625.836940187 5686218.85005723,378629.13146682 5686214.9896182,378630.965230287 5686211.61708631,378632.504951879 5686209.64043998,378643.226835616 5686206.06846854,378647.601835616 5686204.06846854,378658.026050605 5686197.9662481,378667.016792889 5686189.89978013,378669.778875653 5686186.86690494,378671.718716016 5686184.82496771,378671.718716016 5686184.82496771,378678.666192883 5686175.98161798,378679.80628052 5686173.78205631,378680.150643418 5686173.61749202,378680.150643418 5686173.61749202,378680.994393418 5686173.11749202,378680.994393418 5686173.11749202,378689.016905355 5686167.42621575,378696.001741737 5686160.50065555,378697.445240391 5686158.50218896,378699.302967086 5686156.79116549,378699.302967086 5686156.79116549,378700.209217086 5686155.79116548,378700.209217086 5686155.79116548,378702.179269768 5686153.10406446,378702.717101682 5686152.51027647,378703.592101682 5686151.51027647,378703.510176204 5686151.43859168,378706.697738223 5686147.23085638,378708.05211086 5686145.72049752,378708.888508611 5686144.33893402,378710.261182517 5686142.5269384,378711.167432517 5686141.0269384,378711.054203941 5686140.95852946,378716.72558217 5686131.8379137,378716.741039557 5686131.79819963,378717.791067693 5686130.31047509,378722.723399662 5686118.84168434,378723.150942352 5686116.70737561,378723.581311977 5686115.57589731,378724.175061977 5686113.57589731,378724.175061977 5686113.57589731,378726.192922603 5686103.94208407,378726.255422603 5686103.44208407,378726.442199357 5686101.44787004,378726.442922603 5686101.44208407,378726.698995495 5686098.98272879,378726.903726676 5686096.52595461,378727.004699357 5686095.44787004,378727.005422603 5686095.44208407,378727.206803564 5686093.60044252,378727.394303564 5686091.60044252,378727.400868624 5686090.21980753,378729.70932404 5686088.96356994,378740.185851682 5686079.51027647,378741.060851682 5686078.51027647,378741.090535847 5686078.47030038,378741.225854898 5686078.35182616,378743.537483929 5686075.28698248,378743.8728117 5686074.90375074,378744.427967086 5686074.29116548,378744.427967086 5686074.29116548,378747.349409706 5686070.23298961,378748.636182517 5686068.52693839,378748.942132528 5686068.02053838,378752.28517958 5686063.3767118,378752.554464219 5686062.73861656,378752.947238098 5686062.21687722,378754.892621556 5686057.97059332,378756.525230487 5686055.3635956,378760.318371987 5686045.5535046,378760.55763351 5686045.03082853,378761.08888351 5686043.53082853,378764.119716025 5686029.43293325,378764.192922603 5686029.44208407,378764.297348442 5686028.60667736,378764.323995495 5686028.48272879,378764.357685096 5686028.07845357,378764.519303564 5686026.60044252,378764.613053564 5686025.60044252,378764.667745495 5686024.98272879,378764.750899616 5686023.98487934,378764.855245495 5686022.98272879,378764.97772926 5686021.5129236,378765.036478481 5686021.17326004,378765.192728481 5686019.17326004,378764.712117656 5686005.60581829,378764.087602098 5686003.27845524,378764.760311183 5686002.65652859,378764.885498412 5686002.54347771,378764.901640586 5686002.52586807,378767.053482248 5686000.53646773,378767.522232248 5686000.03646773,378767.794136784 5685999.6963826,378768.368058548 5685999.28125337,378768.42433033 5685999.34455912,378769.052518591 5685998.78616956,378770.542014955 5685997.70878667,378771.700012641 5685996.49550307,378780.743480126 5685993.44578452,378791.8665466 5685986.74668806,378801.287904958 5685977.8114484,378802.076355126 5685976.88190715,378802.80938194 5685976.19199956,378803.326001028 5685975.69994482,378808.513501028 5685970.69994482,378808.737049828 5685970.48335473,378811.653086552 5685967.64338853,378813.260840081 5685966.17344245,378814.993147565 5685964.86398167,378819.141493108 5685961.42490647,378820.680900257 5685960.02743048,378820.901908995 5685959.90823475,378823.912518014 5685959.10856503,378834.890522105 5685953.60584652,378844.518299828 5685945.98335473,378848.112049828 5685942.48335473,378848.066158661 5685942.43623434,378854.623970899 5685935.88058267,378861.348710525 5685925.63890699,378861.678801755 5685924.8038634,378863.60313146 5685921.83281573,378864.10313146 5685920.83281573,378864.555712231 5685919.6562937,378865.094427308 5685918.78767659,378865.213754785 5685918.48045524,378867.608786158 5685914.46603257,378868.077536158 5685913.46603257,378869.165152867 5685910.57513817,378869.94688146 5685909.33281573,378870.44688146 5685908.33281573,378874.552846828 5685897.70008024,378874.891592625 5685895.82004503,378875.090463677 5685895.36055082,378876.215463677 5685891.86055082,378876.215463677 5685891.86055082,378878.770854533 5685879.71636506,378879.239604533 5685875.21636506,378879.444196981 5685872.76019745,378879.633154709 5685870.74269717,378879.633643026 5685870.7348841,378879.74037305 5685869.73001702,378879.868664309 5685868.26383119,378880.050553564 5685866.60044252,378880.238053564 5685864.60044252,378880.290873593 5685863.92418208,378880.364604533 5685863.21636506,378880.480245495 5685861.98272879,378880.559976677 5685861.02595461,378880.68865159 5685859.6520935,378880.755425319 5685859.06256273,378881.161675319 5685855.06256273,378881.161675319 5685855.06256273,378881.161675319 5685846.58181046,378881.206803564 5685846.10044252,378881.351904709 5685844.24269717,378881.383154709 5685843.74269717,378881.383154709 5685843.74269717,378880.67402079 5685830.07854529,378880.049842602 5685827.91108609,378878.259056409 5685817.75526539,378877.977806409 5685816.75526538,378874.658656173 5685808.01009282,378874.557579977 5685807.52777648,378869.982610536 5685796.76222945,378867.906156209 5685793.70815317,378867.688303869 5685792.9770032,378867.265578075 5685792.19961426,378866.185489212 5685789.23310731,378860.364952091 5685779.49181208,378852.81440755 5685771.02063966,378843.803937489 5685764.12260266,378842.564372905 5685763.5023179,378842.501604784 5685763.43045671,378836.333689154 5685758.61063122,378835.290188693 5685757.65855828,378834.599378598 5685757.25538016,378833.555058031 5685756.43931146,378832.01932966 5685755.65186093,378831.907011773 5685755.57698234,378831.907011774 5685755.57698234,378829.776251417 5685754.44045408,378824.360019246 5685751.27937361,378823.034923463 5685750.84469087,378821.54734454 5685750.05122976,378810.309900209 5685746.64880539,378806.160818512 5685746.24088685,378806.183067702 5685746.08236137,378802.620567702 5685745.58236137,378802.620567702 5685745.58236137,378794.896531841 5685745.04296711,378793.640025358 5685744.91430979,378791.704589973 5685744.48466488,378780.776064765 5685744.09179551,378778.011169716 5685744.5,378775.34375 5685744.5,378774.331260387 5685744.59051271,378772.872400209 5685744.14880539,378772.619267546 5685744.12391856,378771.354298877 5685743.7272045,378770.584865243 5685743.64899291,378768.630544417 5685743.07715324,378763.681500867 5685742.60614623,378762.920626292 5685742.46780539,378759.351818049 5685742.14600616,378758.962579723 5685742.033352,378747.523116618 5685741.00103186,378736.096548767 5685742.16745725,378734.606338054 5685742.61776609,378732.379410671 5685742.85582514,378720.269523054 5685746.86202516,378709.280133485 5685753.33754318,378709.22462373 5685753.38878821,378706.19692596 5685755.03643006,378704.970337347 5685756.14321874,378699.837063399 5685759.28865041,378697.176956001 5685761.78279137,378696.959308011 5685761.85099138,378691.870814747 5685764.67127677,378690.39790446 5685765.400501,378690.39790446 5685765.400501,378689.58540446 5685765.900501,378689.602593435 5685765.92843308,378686.353713423 5685767.72911717,378684.3497119 5685769.4465256,378680.739998676 5685771.70105299,378679.458748676 5685772.70105299,378679.458748676 5685772.70105299,378678.406830535 5685773.67833603,378678.16534344 5685773.82431232,378674.856619359 5685776.97665463,378671.915782914 5685779.70883452,378671.4535599 5685780.2188737,378668.73626099 5685782.80774365,378668.24027845 5685783.39557481,378668.157898318 5685783.48972353,378662.43260176 5685791.2000636,378662.410519235 5685791.23539564,378661.733890384 5685792.09507133,378656.826161565 5685801.20538174,378654.845604472 5685807.15314028,378654.661405339 5685807.62614885,378650.207672737 5685809.3215261,378645.552496888 5685810.55777525,378636.137913699 5685814.90541147,378635.262913699 5685815.40541147,378634.290907651 5685816.08021024,378632.793219186 5685816.79592627,378631.082023054 5685817.36202516,378628.822481722 5685818.69346405,378627.380606582 5685819.38250798,378626.536856582 5685819.88250798,378626.536856582 5685819.88250798,378625.176215335 5685820.84203323,378620.092633485 5685823.83754318,378618.490948039 5685825.31617353,378615.552498676 5685827.20105299,378614.271248676 5685828.20105299,378612.868489354 5685829.52724449,378610.272855003 5685831.35768781,378609.739921226 5685831.87727007,378608.446346597 5685832.68003912,378603.936383485 5685835.33754318,378602.250679396 5685836.89373715,378599.88409344 5685838.32431232,378599.099956155 5685839.07138856,378590.733998846 5685845.34897823,378585.414353045 5685851.04130925,378583.845398318 5685852.48972353,378583.407898318 5685852.98972353,378581.994432069 5685855.01454958,378577.772697069 5685859.53205206,378572.044306833 5685868.35068644,378571.838173476 5685868.73870217,378571.77635176 5685868.7000636,378571.46385176 5685869.2000636,378571.46385176 5685869.2000636,378570.463716367 5685871.21772283,378569.49061854 5685872.66718427,378568.99061854 5685873.66718427,378569.198113776 5685873.77093189,378566.227854681 5685879.76309127,378563.15844897 5685891.14605957,378562.374142008 5685902.90948091,378563.905215283 5685914.59917866,378563.945426146 5685914.71771567,378561.624393074 5685912.84861842,378552.559120642 5685908.08000872,378545.581045653 5685898.60214456,378542.900060347 5685896.21194793,378539.835311923 5685892.65890761,378537.429913119 5685890.76045454,378536.693251013 5685889.9892428,378534.718242295 5685888.60525161,378533.157729507 5685879.79347704,378529.431659302 5685869.72505489,378526.596792458 5685864.92656496,378524.937543479 5685861.49418064,378524.856349961 5685861.388558,378524.724425222 5685861.03796298,378523.58377914 5685859.19247,378523.298992842 5685858.4136909,378522.655679579 5685855.65878091,378521.089873527 5685852.37261397,378520.9041998 5685851.86486898,378520.609791466 5685851.36506275,378517.110911015 5685844.02194049,378509.208525032 5685833.83799188,378507.405171181 5685832.33247121,378506.959014286 5685831.80778024,378505.473906323 5685830.6354288,378503.821630274 5685828.75886581,378499.559475357 5685825.78253248,378499.313261773 5685825.57698234,378498.563261773 5685825.07698234,378498.558768469 5685825.0837223,378495.161282336 5685822.7112015,378495.250761773 5685822.57698234,378494.500761773 5685822.07698234,378494.500761774 5685822.07698234,378493.597004531 5685821.59492642,378492.660982755 5685820.86740032,378492.140510344 5685820.60174641,378492.079044118 5685820.55882353,378490.204044118 5685819.55882353,378490.181183176 5685819.6016878,378489.101008897 5685819.0503569,378488.988754928 5685818.9655184,378487.108124264 5685818.03317025,378482.587520607 5685815.72581254,378482.264212419 5685815.63173527,378478.954541551 5685813.99092107,378475.860918869 5685813.12366841,378475.502169041 5685812.92857784,378474.345919041 5685812.42857784,378473.591766921 5685812.19023132,378470.340159184 5685810.56743469,378464.992636409 5685809.04278175,378458.97046355 5685807.18721504,378454.738472604 5685806.76417854,378454.099294417 5685806.57715324,378445.814130912 5685805.78864328,378443.443794055 5685805.31731364,378432.253276928 5685805.2110421,378428.922780543 5685805.80777847,378424.918847315 5685805.79636322,378423.364853639 5685806.11415208,378422.247067112 5685806.02842538,378409.515017138 5685807.79810529,378406.578009806 5685808.87939861,378396.050773054 5685812.36202516,378394.159768006 5685813.47630337,378393.185309419 5685813.79139855,378391.935309419 5685814.29139855,378382.237494848 5685819.23387627,378378.574174462 5685822.03611347,378377.967545951 5685822.34530477,378369.043141657 5685829.27036571,378361.574877681 5685837.745417,378355.827465523 5685847.4700617,378352.004621347 5685858.09961124,378350.902831554 5685865.07351508,378350.692662324 5685865.04359516,378349.985849542 5685870.00852397,378348.7331974 5685874.41345457,378347.758789978 5685877.21175281,378347.525090354 5685877.62721881,378346.315910163 5685877.24506264,378340.696880242 5685876.66971397,378340.380544417 5685876.57715324,378334.481835622 5685876.01576533,378333.222751029 5685875.71793302,378326.862945037 5685875.22453404,378319.25 5685874.5,378318.0625 5685874.5,378306.456618434 5685875.63317137,378304.441117635 5685876.23898779,378303.348160671 5685876.35582514,378300.656668531 5685877.24622613,378291.427526409 5685879.77542041,378281.786856582 5685884.38250798,378280.943106582 5685884.88250798,378280.943106582 5685884.88250798,378271.335057685 5685891.95489787,378269.708212699 5685893.74704021,378268.621348936 5685894.56343889,378261.889680078 5685901.91523231,378253.885533457 5685906.73631912,378250.616477734 5685909.66276463,378248.90625 5685909.5,378247.71875 5685909.5,378236.747723614 5685910.51155554,378233.486806621 5685911.43453263,378231.934798731 5685911.5826168,378220.997809419 5685914.79139855,378219.747809419 5685915.29139855,378219.747809419 5685915.29139855,378216.462115851 5685916.94425043,378215.935284758 5685917.1622879,378214.434057997 5685917.64806326,378213.591226335 5685918.13241397,378211.239334504 5685919.10578201,378207.30359047 5685921.74573444,378203.600182905 5685923.87397448,378202.765108728 5685924.62163022,378199.549547146 5685926.64787143,378199.549547147 5685926.64787143,378198.299547147 5685927.64787143,378198.299547147 5685927.64787143,378189.121284722 5685936.7793473,378182.220677787 5685947.50390673,378182.045468976 5685947.52013032,378180.511377027 5685947.95628226,378179.379078188 5685948.06334551,378168.531766391 5685951.21569191,378158.467545951 5685956.34530477,378156.124893031 5685958.16313078,378155.103713423 5685958.72911717,378152.309148623 5685961.12403009,378149.543141657 5685963.27036571,378148.736489089 5685964.1857621,378145.8965485 5685966.6195616,378140.581371466 5685973.47065024,378140.495828194 5685973.55530235,378140.099170374 5685973.86473539,378139.544653626 5685974.49656784,378138.151918961 5685975.87479337,378136.481425453 5685976.48012859,378126.137675453 5685981.48012859,378126.137675453 5685981.48012859,378115.710327539 5685987.90953524,378106.806144543 5685996.32276169,378099.796299445 5686006.36910063,378094.972999303 5686017.62976802,378092.537304526 5686029.63536027,378092.193554526 5686033.13536027,378092.256836574 5686045.47668727,378094.84382494 5686057.54399219,378096.089521947 5686060.35426616,378097.126227984 5686065.02152647,378102.28181264 5686076.36438264,378109.668954347 5686086.39785544,378111.679556709 5686088.19038111,378112.255051206 5686090.06954682,378112.255051206 5686090.06954682,378117.342309051 5686101.93671563,378124.850689549 5686112.44072012,378129.756939549 5686117.94072012,378129.756939548 5686117.94072012,378139.095593642 5686126.41811911,378150.000078066 5686132.75601888,378161.988545602 5686136.67436038,378167.043594189 5686137.20862895,378167.775705583 5686137.42284676,378170.929305485 5686137.72297903,378173.283312044 5686139.00310359,378174.426402972 5686139.63220604,378174.521767939 5686139.70622614,378183.006692037 5686144.32869292,378183.791506063 5686144.67749915,378185.435330959 5686145.57142216,378186.059145529 5686145.84117981,378186.440328447 5686146.61018638,378192.281965243 5686153.99530037,378192.413531134 5686154.18104045,378192.413531134 5686154.18104045,378192.54531074 5686154.32822701,378194.207343764 5686156.42940237,378195.017328168 5686157.10135574,378196.019271166 5686158.30926235,378196.264128741 5686158.51465843,378197.974316826 5686160.56295615,378200.576405756 5686163.77241257,378200.824297808 5686163.97638744,378203.417330742 5686167.08207124,378212.060168336 5686174.19107128,378215.707534879 5686176.19094762,378220.635283202 5686180.19960578,378226.919114586 5686183.68531783,378230.803864518 5686186.39530494,378235.369022803 5686188.18725527,378239.60890546 5686190.44877024,378240.315725558 5686190.66277814,378241.346250518 5686191.22078536,378252.132532448 5686194.64484993,378254.445032448 5686195.14484993,378254.445032448 5686195.14484993,378255.371847678 5686195.24390174,378257.377599791 5686195.85119461,378269.0625 5686197,378271.03125 5686197,378281.673740887 5686196.04860191,378291.978723591 5686193.22457959,378301.619393418 5686188.61749202,378301.619393418 5686188.61749202,378302.463143418 5686188.11749202,378302.463143418 5686188.11749202,378303.256718141 5686187.55786252,378304.150643418 5686187.11749202,378304.994393418 5686186.61749202,378304.994393418 5686186.61749202,378306.37071544 5686185.67823676,378310.4893487 5686183.56273895,378319.369579626 5686176.63526461,378324.226593568 5686171.10104222,378325.456479778 5686170.06675822,378327.023086172 5686168.04444268,378327.557397254 5686167.46511059,378327.851602177 5686166.97492018,378333.249102472 5686160.00734443,378338.74513351 5686148.53082853,378339.27638351 5686147.03082853,378339.516861003 5686145.96588274,378340.73818421 5686143.17576297,378343.255422603 5686131.94208407,378343.255422603 5686131.94208407,378343.317922603 5686131.44208407,378343.573995495 5686128.98272879,378343.64754423 5686128.10014397,378343.739604533 5686127.21636505,378343.764731413 5686126.97022314,378344.264731413 5686121.97022314,378344.264731413 5686121.97022314,378344.274887638 5686110.13222678,378343.078871214 5686104.13242761,378343.104861821 5686102.65121379,378341.852922473 5686096.34824333,378341.836197064 5686095.81056796,378341.478852803 5686094.46496512,378340.612548682 5686090.10350041,378340.383396199 5686089.37021247,378340.380157902 5686089.05579863,378340.224503146 5686088.41552969,378340.05611435 5686082.25726701,378339.816894469 5686081.31368851,378339.421695955 5686071.46917769,378336.439833931 5686059.5531993,378334.745770587 5686056.04879669,378330.201857814 5686046.18621072,378325.142116805 5686039.48786053,378325.52683558 5686038.54086047,378326.841994115 5686035.73518893,378326.981378739 5686035.48212181,378327.744393418 5686035.11749202,378327.744393418 5686035.11749202,378327.858641822 5686035.04978926,378329.25738518 5686034.55913658,378330.792270128 5686034.15152573,378337.922332482 5686033.00065126,378341.687848842 5686031.59306344,378345.428700321 5686031.30820919,378347.788886508 5686030.76056234,378351.986669321 5686030.34711682,378352.353917565 5686030.23571329,378355.690201269 5686029.9173832,378356.061788788 5686029.80836387,378363.318831118 5686028.98880215,378365.086795369 5686028.36863378,378367.263978727 5686028.02595069,378372.420664412 5686026.0947433,378372.897046354 5686026.04190954,378380.282004811 5686023.50111123,378385.546481495 5686022.07919844,378390.171446883 5686021.28835561,378398.79742894 5686017.88935639,378402.003442003 5686016.85193674,378403.29756351 5686016.10824296,378406.230476946 5686015.13797484,378407.571203584 5686014.3479492,378409.464225985 5686014.21861351,378420.288242584 5686011.39808477,378425.098165519 5686009.12421498,378425.994984548 5686010.49172937,378426.338734548 5686010.99172937,378426.338734548 5686010.99172937,378426.716791326 5686011.44305532,378426.75 5686011.5,378427.125 5686012,378427.160818034 5686011.97313647,378433.647939148 5686019.71749193,378441.039453961 5686025.73782703,378441.305527045 5686026.18216112,378441.584439473 5686027.02382333,378444.129057211 5686031.44620916,378445.168506962 5686037.0975745,378446.976387614 5686041.88109574,378447.293701318 5686042.89649959,378447.42914556 5686043.26889358,378447.90983673 5686044.80935034,378447.964407252 5686046.69661345,378450.262451318 5686057.39649959,378450.574951318 5686058.39649959,378452.436126491 5686063.08708748,378452.628450515 5686063.73023283,378452.880132208 5686064.20608362,378453.884596499 5686066.73756379,378457.521229266 5686072.98093604,378458.116075298 5686074.10560248,378458.328754351 5686074.36729535,378458.401234548 5686074.49172937,378458.744984548 5686074.99172937,378458.803525845 5686074.95148223,378465.518603033 5686083.21410974,378468.894114969 5686086.01381834,378469.34812441 5686086.47748756,378469.34812441 5686086.47748756,378471.096722031 5686087.92644935,378474.541820716 5686091.47104346,378483.195790578 5686097.67451651,378485.806007041 5686098.91690257,378495.364666549 5686103.58330209,378496.165693331 5686103.80714234,378495.951161565 5686104.20538174,378495.641981302 5686105.1338728,378494.494401965 5686107.76478327,378494.17752199 5686109.27895625,378492.888120439 5686112.20621023,378492.656172009 5686113.32317709,378490.887438023 5686117.92410269,378490.293688023 5686119.92410269,378490.293688023 5686119.92410269,378490.038215987 5686121.24512057,378489.226145426 5686123.46585501,378489.218491316 5686123.48292164,378489.216171835 5686123.49312936,378488.217241206 5686126.22486199,378486.272775927 5686131.36470355,378485.457342653 5686135.77385019,378485.35449995 5686135.98955398,378483.381837077 5686144.91604782,378476.857968976 5686145.52013032,378466.215564864 5686148.54583242,378456.309675637 5686153.47421928,378447.477144557 5686160.13770435,378445.712019665 5686162.07159963,378438.351749789 5686157.94462758,378426.679442823 5686154.24916024,378422.976888441 5686153.86941514,378420.222751029 5686153.21793302,378418.089806525 5686153.05245743,378408.871753294 5686152.17516313,378408.536794417 5686152.07715324,378397.21875 5686151,378396.03125 5686151,378383.08474869 5686152.41341362,378370.748206089 5686156.5870632,378368.694212555 5686157.8286797,378367.082023054 5686158.36202516,378356.092633485 5686164.83754318,378354.502666276 5686166.30535559,378345.968279381 5686169.3662765,378341.472881069 5686172.1064123,378340.825413699 5686172.40541147,378340.076410342 5686172.83341339,378337.487854058 5686174.13613328,378337.197664211 5686174.31134225,378334.815997229 5686175.47667938,378326.726924277 5686181.26382112,378325.754150764 5686182.23964366,378325.015992185 5686182.75718392,378322.841023348 5686184.97941655,378320.912514265 5686186.45515923,378313.44788914 5686194.77950248,378313.067081186 5686195.40852183,378312.97366441 5686195.49980269,378310.004319798 5686200.08428963,378308.981127681 5686201.245417,378306.153864883 5686206.02915713,378305.74061854 5686206.66718427,378305.541955708 5686207.06450993,378303.233715524 5686210.9700617,378300.164721798 5686219.50350417,378299.063654724 5686222.39936232,378298.814694849 5686223.91576723,378298.495350338 5686224.65831566,378297.800841321 5686228.12533004,378297.668811462 5686228.46525504,378296.016502117 5686232.52633404,378295.93911819 5686232.75848582,378295.377433934 5686234.12014462,378295.377433934 5686234.12014462,378293.627932165 5686239.06730913,378293.357184263 5686239.53989804,378289.928443591 5686248.75526538,378289.365943591 5686250.75526538,378288.570517129 5686255.03356946,378288.561292023 5686255.07311949,378288.192121347 5686256.09961124,378287.919782994 5686257.82340782,378286.932077397 5686262.05791592,378286.869577397 5686262.55791593,378286.556484802 5686265.90080326,378286.543196436 5686265.89955748,378286.355696436 5686267.89955748,378286.301004505 5686268.51727121,378286.216197542 5686269.53495476,378286.213327397 5686269.55791593,378286.198533846 5686269.699995,378277.376371744 5686270.44800154,378276.790815717 5686270.61095001,378272.982509113 5686270.95139809,378270.038941888 5686271.75806607,378268.61599869 5686271.91341362,378264.965834824 5686273.14832241,378263.801031729 5686273.46753012,378263.232968976 5686273.52013032,378252.590564864 5686276.54583242,378252.127953088 5686276.77599144,378248.780120358 5686277.7535677,378238.681421946 5686282.92798751,378229.737518657 5686289.91117618,378222.26829995 5686298.45337156,378216.540911415 5686308.24905176,378212.760199991 5686318.9478625,378212.260199991 5686320.9478625,378212.160719698 5686321.35172794,378210.446585784 5686328.4160374,378209.240187516 5686332.49923154,378209.158255013 5686332.77904163,378208.881223643 5686333.73373435,378203.781766391 5686335.21569191,378196.357012929 5686339,378195.78125 5686339,378185.138759113 5686339.95139809,378184.795091371 5686340.04557829,378179.0625 5686339.5,378177.875 5686339.5,378165.392523102 5686340.81279722,378153.456278236 5686344.69374098,378150.35466243 5686346.48582972,378150.083746888 5686346.55777525,378149.912122419 5686346.6370311,378146.715564864 5686347.54583242,378136.809675637 5686352.47421928,378130.977557062 5686356.87411719,378129.826006776 5686357.60976791,378129.090400571 5686358.29783583,378127.977144557 5686359.13770435,378126.719995225 5686360.51505457,378121.795121559 5686365.12166003,378115.270067483 5686373.9730616,378114.363817483 5686375.4730616,378109.032787365 5686386.83526913,378108.041070634 5686391.08733387,378106.49793905 5686395.26402874,378104.883738308 5686405.29322795,378104.791645467 5686405.28363495,378104.479145467 5686408.28363494,378104.273095291 5686410.75730283,378104.210595291 5686411.75730283,378104.460625361 5686411.77292971,378104.011629082 5686417.18125126,378105.5086817 5686429.37032847,378106.483657896 5686432.242566,378107.648244037 5686435.97468073,378102.5 5686435.5,378101.71875 5686435.5,378100.140074503 5686435.62021125,378098.9375 5686435.5,378097.375 5686435.5,378096.532809999 5686435.58222948,378094.464048687 5686435.09287082,378092.997400209 5686434.64880539,378091.567748734 5686434.50824866,378090.516878863 5686434.2870129,378090.516878863 5686434.2870129,378084.126208825 5686433.62160381,378083.974294417 5686433.57715324,378080.775310503 5686433.27270171,378078.172012418 5686433.00164121,378077.613969466 5686432.70398616,378076.813261773 5686432.07698234,378075.313261773 5686431.07698234,378075.313261774 5686431.07698234,378073.300528278 5686430.00340854,378065.135687228 5686425.43226216,378062.813099321 5686424.69792192,378061.979713227 5686424.26993765,378055.001087444 5686422.22797248,378053.476704246 5686421.74600324,378053.287766154 5686421.72664994,378051.068044417 5686421.07715324,378044.546690613 5686420.45650738,378042.728578699 5686420.04550051,378032.268467407 5686419.54753137,378021.881091886 5686420.87581271,378016.891153862 5686422.42999057,378014.45719621 5686419.01966198,378014.473765452 5686419.00827063,378014.130015452 5686418.50827063,378013.408422281 5686417.48183711,378012.689672281 5686416.48183711,378012.660771406 5686416.50260961,378010.295438955 5686413.18843491,378008.407105479 5686411.46554999,378005.599698655 5686408.12664379,378002.807542065 5686405.87815699,378002.658281672 5686405.27813361,378002.537271275 5686404.51946003,378002.319601725 5686403.91664792,378001.509047328 5686400.65823767,378000.936226672 5686399.46620892,377997.463887609 5686390.57638875,377997.186543718 5686390.13234884,377993.425308938 5686380.01567813,377990.519433217 5686375.16625725,377990.256324968 5686374.57196058,377989.591228767 5686373.61723916,377987.761869038 5686370.56434354,377986.35695907 5686368.97456259,377983.692357771 5686365.1496243,377980.052548883 5686361.61563751,377979.648463586 5686360.77474379,377979.631521291 5686357.75671207,377979.661743092 5686357.36987301,377979.800553564 5686356.10044252,377979.988053564 5686354.10044252,377980.133154709 5686352.24269717,377980.164404709 5686351.74269717,377980.164404709 5686351.74269717,377980.164404709 5686344.25730283,377980.008154709 5686341.75730283,377980.008154709 5686341.75730283,377978.371241693 5686331.09946776,377975.701958091 5686323.36591394,377974.053316086 5686315.95468901,377968.886638814 5686304.60317659,377961.484757713 5686294.56507198,377952.167498583 5686286.27410881,377950.108550497 5686285.09814125,377947.319310436 5686282.30449775,377945.843331616 5686281.29914387,377943.115449585 5686278.20904762,377942.50961659 5686277.42349735,377942.1745247 5686277.14318464,377939.609879151 5686274.23799976,377930.690005005 5686267.32630444,377920.633748104 5686262.20698962,377909.796808551 5686259.06113073,377898.5625 5686258,377898.21875 5686258,377894.21875 5686257.5,377892.28125 5686257.5,377881.638759113 5686258.45139809,377876.556073103 5686259.84427949,377871.743182592 5686260.6918947,377871.697717158 5686260.70942128,377870.328885159 5686260.91717613,377858.782694968 5686265.21478537,377848.357695104 5686271.78009807,377847.02882866 5686273.06278234,377843.640842367 5686275.02598664,377840.180629417 5686278.15547427,377840.174547147 5686278.14787143,377838.924547147 5686279.14787143,377838.991214461 5686279.23120558,377838.955557203 5686279.26345473,377835.845022471 5686281.527542,377828.122362464 5686289.76536579,377824.383122888 5686295.66825783,377823.558077582 5686296.77420516,377823.217682564 5686297.50806196,377822.079890051 5686299.30422031,377821.747704321 5686300.14520297,377820.49061854 5686302.16718427,377819.781681905 5686303.58505754,377818.05311854 5686306.66718427,377817.55311854 5686307.66718427,377815.330365766 5686313.37922188,377814.342888867 5686314.96469967,377810.176942326 5686326.05979658,377810.167740165 5686326.11633596,377806.610252117 5686333.52633404,377806.110252117 5686335.02633404,377805.839142079 5686336.31335692,377805.064867551 5686337.7451242,377801.601488028 5686348.93043951,377800.882738028 5686352.43043951,377800.912196992 5686352.43648911,377799.526600338 5686355.65831566,377797.074446436 5686367.89955748,377796.80394407 5686370.78491605,377796.791645467 5686370.78363494,377796.635395467 5686372.28363494,377796.543730068 5686373.38409386,377793.31736649 5686380.46917147,377792.78611649 5686381.96917147,377792.11064063 5686385.03397965,377790.642193022 5686388.51360413,377788.304345291 5686401.75730283,377788.304345291 5686401.75730283,377788.28836736 5686402.01294973,377788.177813823 5686403.27641872,377788.072895467 5686404.28363494,377788.011946436 5686404.89955748,377787.68397999 5686408.39786624,377787.574446436 5686409.39955748,377787.547481292 5686409.68718568,377787.479145467 5686410.28363494,377787.322895467 5686411.78363494,377787.261946436 5686412.39955748,377787.074446436 5686414.39955748,377787.019754505 5686415.01727121,377786.769754505 5686418.01727121,377786.878782577 5686429.15255025,377787.21236766 5686430.83570257),(378241.097744652 5686581.54216122,378241.116955388 5686581.55236693,378240.803657309 5686581.94224898,378241.097744652 5686581.54216122))
</op>
</test>
Modified: trunk/tests/xmltester/testLeaksBig.xml
--- trunk/tests/xmltester/testLeaksBig.xml 2009-04-14 09:22:22 UTC (rev 2351)
+++ trunk/tests/xmltester/testLeaksBig.xml 2009-04-14 09:53:59 UTC (rev 2352)
@@ -10494,7 +10494,7 @@
MULTIPOINT(0 0, 5 5)
</a>
<test>
- <op name="buffer" arg1="a" arg3="10">
+ <op name="buffer" arg1="a" arg2="10">
POLYGON ((-10.0 -2.0, -10.0 -0.0, -10.0 2.0, -9.0 4.0, -8.0 6.0, -7.0 7.0, -6.0 8.0, -4.0 9.0, -3.0 11.0, -2.0 12.0, -1.0 13.0, 1.0 14.0, 3.0 15.0, 5.0 15.0, 7.0 15.0, 9.0 14.0, 11.0 13.0, 12.0 12.0, 13.0 11.0, 14.0 9.0, 15.0 7.0, 15.0 5.0, 15.0 3.0, 14.0 1.0, 13.0 -1.0, 12.0 -2.0, 11.0 -3.0, 9.0 -4.0, 8.0 -6.0, 7.0 -7.0, 6.0 -8.0, 4.0 -9.0, 2.0 -10.0, 0.0 -10.0, -2.0 -10.0, -4.0 -9.0, -6.0 -8.0, -7.0 -7.0, -8.0 -6.0, -9.0 -4.0, -10.0 -2.0))
</op>
</test>
@@ -10510,7 +10510,7 @@
<a>MULTIPOLYGON (((10 10, 10 20, 20 20, 20 15, 10 10)), ((60 60, 80 60, 70 7, 60 60)))</a>
<test>
- <op name="buffer" arg1="a" arg3="0">
+ <op name="buffer" arg1="a" arg2="0">
MULTIPOLYGON (((10 10, 10 20, 20 20, 20 15, 10 10)), ((60 60, 70 7, 80 60, 60 60)))
</op>
</test>
More information about the geos-commits
