[geos-commits] r2357 - in trunk/source: algorithm algorithm/locate
headers/geos/algorithm
svn_geos at osgeo.org
Tue Apr 14 08:55:39 EDT 2009
Author: strk
Date: 2009-04-14 08:55:39 -0400 (Tue, 14 Apr 2009)
New Revision: 2357
trunk/source/algorithm/RayCrossingCounter.cpp
trunk/source/algorithm/locate/IndexedPointInAreaLocator.cpp
trunk/source/headers/geos/algorithm/RayCrossingCounter.h
Fix memory leak in RayCrossingCounter; update signatures to avoid pointers when unneeded; add a locatePointInRing taking a vector of coordinate pointers, for use by CGAlgorithms
Modified: trunk/source/algorithm/RayCrossingCounter.cpp
--- trunk/source/algorithm/RayCrossingCounter.cpp 2009-04-14 12:42:42 UTC (rev 2356)
+++ trunk/source/algorithm/RayCrossingCounter.cpp 2009-04-14 12:55:39 UTC (rev 2357)
@@ -39,38 +39,58 @@
// public:
/*static*/ int
-RayCrossingCounter::locatePointInRing( const geom::Coordinate * point, const geom::CoordinateSequence * ring)
+RayCrossingCounter::locatePointInRing(const geom::Coordinate& point,
+ const geom::CoordinateSequence& ring)
- RayCrossingCounter * rcc = new RayCrossingCounter( point);
+ RayCrossingCounter rcc(point);
- for (int i = 1, ni = ring->size(); i < ni; i++)
+ for (int i = 1, ni = ring.size(); i < ni; i++)
- const geom::Coordinate & p1 = (*ring)[ i ];
- const geom::Coordinate & p2 = (*ring)[ i - 1 ];
+ const geom::Coordinate & p1 = ring[ i ];
+ const geom::Coordinate & p2 = ring[ i - 1 ];
- rcc->countSegment( &p1, &p2);
+ rcc.countSegment(p1, p2);
- if ( rcc->isOnSegment() )
- return rcc->getLocation();
+ if ( rcc.isOnSegment() )
+ return rcc.getLocation();
+/*static*/ int
+ const std::vector<const geom::Coordinate*>& ring)
+ const geom::Coordinate & p1 = *ring[ i ];
+ const geom::Coordinate & p2 = *ring[ i - 1 ];
void
-RayCrossingCounter::countSegment(const geom::Coordinate * p1,
- const geom::Coordinate * p2)
+RayCrossingCounter::countSegment(const geom::Coordinate& p1,
+ const geom::Coordinate& p2)
// For each segment, check if it crosses
// a horizontal ray running from the test point in
// the positive x direction.
// check if the segment is strictly to the left of the test point
- if (p1->x < point->x && p2->x < point->x)
+ if (p1.x < point.x && p2.x < point.x)
return;
// check if the point is equal to the current ring vertex
- if (point->x == p2->x && point->y == p2->y)
+ if (point.x == p2.x && point.y == p2.y)
isPointOnSegment = true;
return;
@@ -78,18 +98,18 @@
// For horizontal segments, check if the point is on the segment.
// Otherwise, horizontal segments are not counted.
- if (p1->y == point->y && p2->y == point->y)
+ if (p1.y == point.y && p2.y == point.y)
- double minx = p1->x;
- double maxx = p2->x;
+ double minx = p1.x;
+ double maxx = p2.x;
if (minx > maxx)
- minx = p2->x;
- maxx = p1->x;
+ minx = p2.x;
+ maxx = p1.x;
- if (point->x >= minx && point->x <= maxx)
+ if (point.x >= minx && point.x <= maxx)
return;
@@ -102,15 +122,15 @@
// final endpoint
// - a downward edge excludes its starting endpoint, and includes its
// final endpoint
- if (((p1->y > point->y) && (p2->y <= point->y)) ||
- ((p2->y > point->y) && (p1->y <= point->y)) )
+ if (((p1.y > point.y) && (p2.y <= point.y)) ||
+ ((p2.y > point.y) && (p1.y <= point.y)) )
// translate the segment so that the test point lies
// on the origin
- double x1 = p1->x - point->x;
- double y1 = p1->y - point->y;
- double x2 = p2->x - point->x;
- double y2 = p2->y - point->y;
+ double x1 = p1.x - point.x;
+ double y1 = p1.y - point.y;
+ double x2 = p2.x - point.x;
+ double y2 = p2.y - point.y;
// The translated segment straddles the x-axis.
// Compute the sign of the ordinate of intersection
@@ -140,8 +160,8 @@
if (isPointOnSegment)
return geom::Location::BOUNDARY;
- // The point is in the interior of the ring if the number of X-crossings is
- // odd.
+ // The point is in the interior of the ring if the number
+ // of X-crossings is odd.
if ((crossingCount % 2) == 1)
return geom::Location::INTERIOR;
Modified: trunk/source/algorithm/locate/IndexedPointInAreaLocator.cpp
--- trunk/source/algorithm/locate/IndexedPointInAreaLocator.cpp 2009-04-14 12:42:42 UTC (rev 2356)
+++ trunk/source/algorithm/locate/IndexedPointInAreaLocator.cpp 2009-04-14 12:55:39 UTC (rev 2357)
@@ -113,7 +113,7 @@
int
IndexedPointInAreaLocator::locate( const geom::Coordinate * /*const*/ p)
- algorithm::RayCrossingCounter rcc( p);
+ algorithm::RayCrossingCounter rcc(*p);
IndexedPointInAreaLocator::SegmentVisitor visitor( &rcc);
@@ -127,7 +127,7 @@
geom::LineSegment * seg = (geom::LineSegment *)item;
- counter->countSegment( &(*seg)[ 0 ], &(*seg)[ 1 ]);
+ counter->countSegment( (*seg)[ 0 ], (*seg)[ 1 ]);
void
Modified: trunk/source/headers/geos/algorithm/RayCrossingCounter.h
--- trunk/source/headers/geos/algorithm/RayCrossingCounter.h 2009-04-14 12:42:42 UTC (rev 2356)
+++ trunk/source/headers/geos/algorithm/RayCrossingCounter.h 2009-04-14 12:55:39 UTC (rev 2357)
@@ -21,6 +21,7 @@
#ifndef GEOS_ALGORITHM_RAYCROSSINGCOUNTER_H
#define GEOS_ALGORITHM_RAYCROSSINGCOUNTER_H
+#include <vector>
// forward declarations
namespace geos {
@@ -64,7 +65,7 @@
class RayCrossingCounter
private:
- const geom::Coordinate * point;
+ const geom::Coordinate& point;
int crossingCount;
@@ -81,10 +82,14 @@
* @param ring an array of Coordinates forming a ring
* @return the location of the point in the ring
- static int locatePointInRing(const geom::Coordinate * p,
- const geom::CoordinateSequence * ring);
+ static int locatePointInRing(const geom::Coordinate& p,
+ const geom::CoordinateSequence& ring);
- RayCrossingCounter( const geom::Coordinate * point)
+ /// Semantically equal to the above, just different args encoding
+ const std::vector<const geom::Coordinate*>& ring);
+ RayCrossingCounter(const geom::Coordinate& point)
: point( point),
crossingCount( 0),
isPointOnSegment( false)
@@ -96,7 +101,8 @@
* @param p1 an endpoint of the segment
* @param p2 another endpoint of the segment
- void countSegment( const geom::Coordinate * p1, const geom::Coordinate * p2);
+ void countSegment(const geom::Coordinate& p1,
+ const geom::Coordinate& p2);
* Reports whether the point lies exactly on one of the supplied segments.
More information about the geos-commits
