[geos-commits] r2368 - in trunk/source: headers/geos/geom
headers/geos/geom/util precision
svn_geos at osgeo.org
Wed Apr 15 06:02:02 EDT 2009
Author: strk
Date: 2009-04-15 06:02:01 -0400 (Wed, 15 Apr 2009)
New Revision: 2368
trunk/source/headers/geos/geom/CoordinateSequence.h
trunk/source/headers/geos/geom/util/CoordinateOperation.h
trunk/source/precision/SimpleGeometryPrecisionReducer.cpp
Fix leak in SimpleGeometryPrecisionReducer, improve memory management docs where topic.
Modified: trunk/source/headers/geos/geom/CoordinateSequence.h
--- trunk/source/headers/geos/geom/CoordinateSequence.h 2009-04-15 09:29:52 UTC (rev 2367)
+++ trunk/source/headers/geos/geom/CoordinateSequence.h 2009-04-15 10:02:01 UTC (rev 2368)
@@ -217,6 +217,8 @@
/// Equality test is 2D based
+ /// Ownership of returned object goes to the caller.
static CoordinateSequence* removeRepeatedPoints(
const CoordinateSequence *cl);
Modified: trunk/source/headers/geos/geom/util/CoordinateOperation.h
--- trunk/source/headers/geos/geom/util/CoordinateOperation.h 2009-04-15 09:29:52 UTC (rev 2367)
+++ trunk/source/headers/geos/geom/util/CoordinateOperation.h 2009-04-15 10:02:01 UTC (rev 2368)
@@ -43,7 +43,7 @@
public:
- * Return a newly created geometry
+ * Return a newly created geometry, ownership to caller
virtual Geometry* edit(const Geometry *geometry,
const GeometryFactory *factory);
Modified: trunk/source/precision/SimpleGeometryPrecisionReducer.cpp
--- trunk/source/precision/SimpleGeometryPrecisionReducer.cpp 2009-04-15 09:29:52 UTC (rev 2367)
+++ trunk/source/precision/SimpleGeometryPrecisionReducer.cpp 2009-04-15 10:02:01 UTC (rev 2368)
@@ -39,22 +39,33 @@
namespace geos {
namespace precision { // geos.precision
-class PrecisionReducerCoordinateOperation: public geom::util::CoordinateOperation {
+class PrecisionReducerCoordinateOperation :
+ public geom::util::CoordinateOperation
using CoordinateOperation::edit;
private:
SimpleGeometryPrecisionReducer *sgpr;
public:
- PrecisionReducerCoordinateOperation(SimpleGeometryPrecisionReducer *newSgpr);
- CoordinateSequence* edit(const CoordinateSequence *coordinates, const Geometry *geom);
+ PrecisionReducerCoordinateOperation(
+ SimpleGeometryPrecisionReducer *newSgpr);
+ /// Ownership of returned CoordinateSequence to caller
+ CoordinateSequence* edit(const CoordinateSequence *coordinates,
+ const Geometry *geom);
-PrecisionReducerCoordinateOperation::PrecisionReducerCoordinateOperation(SimpleGeometryPrecisionReducer *newSgpr)
+PrecisionReducerCoordinateOperation::PrecisionReducerCoordinateOperation(
sgpr=newSgpr;
CoordinateSequence*
-PrecisionReducerCoordinateOperation::edit(const CoordinateSequence *cs, const Geometry *geom)
+PrecisionReducerCoordinateOperation::edit(const CoordinateSequence *cs,
if (cs->getSize()==0) return NULL;
@@ -70,26 +81,35 @@
(*vc)[i] = coord;
- CoordinateSequence *reducedCoords = geom->getFactory()->getCoordinateSequenceFactory()->create(vc);
+ // reducedCoords take ownership of 'vc'
+ CoordinateSequence *reducedCoords =
+ geom->getFactory()->getCoordinateSequenceFactory()->create(vc);
- // remove repeated points, to simplify returned geometry as much as possible
+ // remove repeated points, to simplify returned geometry as
+ // much as possible.
CoordinateSequence *noRepeatedCoords=CoordinateSequence::removeRepeatedPoints(reducedCoords);
- * Check to see if the removal of repeated points
- * collapsed the coordinate List to an invalid length
- * for the type of the parent geometry.
- * It is not necessary to check for Point collapses, since the coordinate list can
- * never collapse to less than one point.
- * If the length is invalid, return the full-length coordinate array
- * first computed, or null if collapses are being removed.
- * (This may create an invalid geometry - the client must handle this.)
+ * Check to see if the removal of repeated points
+ * collapsed the coordinate List to an invalid length
+ * for the type of the parent geometry.
+ * It is not necessary to check for Point collapses,
+ * since the coordinate list can
+ * never collapse to less than one point.
+ * If the length is invalid, return the full-length coordinate array
+ * first computed, or null if collapses are being removed.
+ * (This may create an invalid geometry - the client must handle this.)
unsigned int minLength = 0;
if (typeid(*geom)==typeid(LineString)) minLength = 2;
if (typeid(*geom)==typeid(LinearRing)) minLength = 4;
CoordinateSequence *collapsedCoords = reducedCoords;
- if (sgpr->getRemoveCollapsed()) collapsedCoords=NULL;
+ if (sgpr->getRemoveCollapsed())
+ delete reducedCoords; reducedCoords=0;
+ collapsedCoords=0;
// return null or orginal length coordinate array
if (noRepeatedCoords->getSize()<minLength) {
delete noRepeatedCoords;
More information about the geos-commits
