[geos-commits] r2374 - in trunk/tests/unit: . algorithm
svn_geos at osgeo.org
Thu Apr 16 06:48:14 EDT 2009
Author: strk
Date: 2009-04-16 06:48:14 -0400 (Thu, 16 Apr 2009)
New Revision: 2374
Added:
trunk/tests/unit/algorithm/RobustLineIntersectionTest.cpp
trunk/tests/unit/Makefile.am
Port RobustLineIntersectionTest (mostly failing, but reported by Martin Davis to be expected)
Modified: trunk/tests/unit/Makefile.am
--- trunk/tests/unit/Makefile.am 2009-04-15 15:58:09 UTC (rev 2373)
+++ trunk/tests/unit/Makefile.am 2009-04-16 10:48:14 UTC (rev 2374)
@@ -34,6 +34,7 @@
algorithm/CGAlgorithms/computeOrientationTest.cpp \
algorithm/ConvexHullTest.cpp \
algorithm/PointLocatorTest.cpp \
+ algorithm/RobustLineIntersectionTest.cpp \
geom/CoordinateArraySequenceFactoryTest.cpp \
geom/CoordinateArraySequenceTest.cpp \
geom/CoordinateListTest.cpp \
Added: trunk/tests/unit/algorithm/RobustLineIntersectionTest.cpp
--- trunk/tests/unit/algorithm/RobustLineIntersectionTest.cpp (rev 0)
+++ trunk/tests/unit/algorithm/RobustLineIntersectionTest.cpp 2009-04-16 10:48:14 UTC (rev 2374)
@@ -0,0 +1,290 @@
+// $Id$
+// Ported from JTS junit/algorithm/RobustLineIntersectionTest.java rev. 1.3
+#include <tut.hpp>
+// geos
+#include <geos/io/WKTReader.h>
+#include <geos/algorithm/LineIntersector.h>
+#include <geos/geom/PrecisionModel.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/Geometry.h> // required for use in auto_ptr
+#include <geos/geom/LineString.h>
+#include <geos/geom/Coordinate.h>
+// std
+#include <sstream>
+#include <string>
+#include <memory>
+namespace geos {
+ namespace geom {
+ class Geometry;
+using namespace geos::geom; //
+namespace tut
+ // Test Group
+ struct test_lineintersector_data {};
+ typedef test_group<test_lineintersector_data> group;
+ typedef group::object object;
+ group test_lineintersector_group(
+ "geos::algorithm::RobustLineIntersection");
+ // These are static to avoid namespace pollution
+ // The struct test_*_data above is probably there
+ // for the same reason...
+ static PrecisionModel pm;
+ static GeometryFactory gf(&pm);
+ static geos::io::WKTReader reader(&gf);
+ typedef std::auto_ptr<Geometry> GeomPtr;
+ bool equals(const Coordinate& p0, const Coordinate& p1,
+ double distanceTolerance)
+ return p0.distance(p1) <= distanceTolerance;
+ void testIntPoints(const Coordinate& p, const Coordinate& q,
+ bool isEqual = equals(p, q, distanceTolerance);
+ ensure("testIntPoints", isEqual);
+ * @param pt array of 4 Coordinates
+ * @param expectedIntersectionNum
+ * @param intPt the expected intersection points
+ * (maybe null if not tested)
+ * must contain at least expectedIntersectionNum
+ * elements
+ void computeIntersection(const std::vector<Coordinate>& pt,
+ int expectedIntersectionNum,
+ const std::vector<Coordinate>& intPt,
+ geos::algorithm::LineIntersector li;
+ li.computeIntersection(pt[0], pt[1], pt[2], pt[3]);
+ int intNum = li.getIntersectionNum();
+ ensure_equals(intNum, expectedIntersectionNum);
+ if ( intPt.empty() ) return;
+ ensure_equals(intPt.size(), intNum);
+ // test that both points are represented here
+ //bool isIntPointsCorrect = true;
+ if (intNum == 1)
+ testIntPoints(intPt[0], li.getIntersection(0),
+ distanceTolerance);
+ else if (intNum == 2)
+ testIntPoints(intPt[1], li.getIntersection(0),
+ if ( !(
+ equals(intPt[0],li.getIntersection(0), distanceTolerance)
+ equals(intPt[0],li.getIntersection(1), distanceTolerance) ) )
+ testIntPoints(intPt[0], li.getIntersection(1),
+ else if ( !(
+ equals(intPt[1],li.getIntersection(0), distanceTolerance)
+ equals(intPt[1],li.getIntersection(1), distanceTolerance) ) )
+ testIntPoints(intPt[1], li.getIntersection(1),
+ //assertTrue("Int Pts not equal", isIntPointsCorrect);
+ void computeIntersection(const std::string& wkt1,
+ const std::string& wkt2,
+ const std::string& expectedWKT,
+ //throws ParseException
+ GeomPtr g1(reader.read(wkt1));
+ GeomPtr g2(reader.read(wkt2));
+ LineString* l1ptr = dynamic_cast<LineString*>(g1.get());
+ LineString* l2ptr = dynamic_cast<LineString*>(g2.get());
+ ensure(l1ptr);
+ ensure(l2ptr);
+ LineString& l1 = *l1ptr;
+ LineString& l2 = *l2ptr;
+ std::vector<Coordinate> pt;
+ pt.push_back(l1.getCoordinateN(0));
+ pt.push_back(l1.getCoordinateN(1));
+ pt.push_back(l2.getCoordinateN(0));
+ pt.push_back(l2.getCoordinateN(1));
+ GeomPtr g(reader.read(expectedWKT));
+ std::auto_ptr<CoordinateSequence> cs ( g->getCoordinates() );
+ std::vector<Coordinate> intPt;
+ for (size_t i=0; i<cs->size(); ++i)
+ intPt.push_back(cs->getAt(i));
+ computeIntersection(pt, expectedIntersectionNum,
+ intPt, distanceTolerance);
+ // throws ParseException
+ ensure(l1ptr);
+ ensure(l2ptr);
+ // Test Cases
+ // 1 - Test from strk which is bad in GEOS (2009-04-14).
+ template<>
+ template<>
+ void object::test<1>()
+ "LINESTRING (588750.7429703881 4518950.493668233, 588748.2060409798 4518933.9452804085)",
+ "LINESTRING (588745.824857241 4518940.742239175, 588748.2060437313 4518933.9452791475)",
+ 1,
+ "POINT (588748.2060416829 4518933.945284994)",
+ 0);
+ // 2 - Test from strk which is bad in GEOS (2009-04-14).
+ template<>
+ template<>
+ void object::test<2>()
+ "LINESTRING (588743.626135934 4518924.610969561, 588732.2822865889 4518925.4314047815)",
+ "LINESTRING (588739.1191384895 4518927.235700594, 588731.7854614238 4518924.578370095)",
+ 1,
+ "POINT (588733.8306132929 4518925.319423238)",
+ 0);
+ // 3 - DaveSkeaCase
+ // This used to be a failure case (exception),
+ // but apparently works now.
+ // Possibly normalization has fixed this?
+#if 0 // fails: finds 1 intersection rather then two
+ template<>
+ template<>
+ void object::test<3>()
+ intPt.push_back(Coordinate(2089426.5233462777, 1180182.3877339689));
+ intPt.push_back(Coordinate(2085646.6891757075, 1195618.7333999649));
+ "LINESTRING ( 2089426.5233462777 1180182.3877339689, 2085646.6891757075 1195618.7333999649 )",
+ "LINESTRING ( 1889281.8148903656 1997547.0560044837, 2259977.3672235999 483675.17050843034 )",
+ 2,
+ intPt, 0);
+#endif // fails
+#if 0 // fails: the intersection point doesn't match
+ // 4 - Outside envelope using HCoordinate method (testCmp5CaseWKT)
+ template<>
+ template<>
+ void object::test<4>()
+ intPt.push_back(Coordinate(4348437.0557510145, 5552597.375203926));
+ "LINESTRING (4348433.262114629 5552595.478385733, 4348440.849387404 5552599.272022122 )",
+ "LINESTRING (4348433.26211463 5552595.47838573, 4348440.8493874 5552599.27202212 )",
+ 1,
+ intPt, 0);
+#endif // fails
+ // 5 - Result of this test should be the same as the WKT one!
+ // (testCmp5CaseRaw)
+ template<>
+ template<>
+ void object::test<5>()
+ pt.push_back(Coordinate(4348433.262114629, 5552595.478385733));
+ pt.push_back(Coordinate(4348440.849387404, 5552599.272022122));
+ pt.push_back(Coordinate(4348433.26211463, 5552595.47838573));
+ pt.push_back(Coordinate(4348440.8493874, 5552599.27202212));
+ computeIntersection( pt, 1, intPt, 0);
+#endif // fails
+} // namespace tut
Property changes on: trunk/tests/unit/algorithm/RobustLineIntersectionTest.cpp
___________________________________________________________________
More information about the geos-commits
