[geos-commits] r2385 - in trunk/source: algorithm/distance
headers/geos/algorithm/distance
svn_geos at osgeo.org
Fri Apr 17 12:26:20 EDT 2009
Author: strk
Date: 2009-04-17 12:26:20 -0400 (Fri, 17 Apr 2009)
New Revision: 2385
trunk/source/algorithm/distance/DiscreteHausdorffDistance.cpp
trunk/source/headers/geos/algorithm/distance/DiscreteHausdorffDistance.h
Add missing implementation bits
Modified: trunk/source/algorithm/distance/DiscreteHausdorffDistance.cpp
--- trunk/source/algorithm/distance/DiscreteHausdorffDistance.cpp 2009-04-17 15:47:07 UTC (rev 2384)
+++ trunk/source/algorithm/distance/DiscreteHausdorffDistance.cpp 2009-04-17 16:26:20 UTC (rev 2385)
@@ -13,7 +13,7 @@
- * Last port: algorithm/distance/DiscreteHausdorffDistance.java 1.5 (JTS-1.9)
+ * Last port: algorithm/distance/DiscreteHausdorffDistance.java 1.5 (JTS-1.10)
@@ -63,7 +63,26 @@
+/* static public */
+double
+DiscreteHausdorffDistance::distance(const geom::Geometry& g0,
+ const geom::Geometry& g1)
+ DiscreteHausdorffDistance dist(g0, g1);
+ return dist.distance();
+double
+ const geom::Geometry& g1,
+ double densifyFrac)
+ dist.setDensifyFraction(densifyFrac);
} // namespace geos.algorithm.distance
} // namespace geos
Modified: trunk/source/headers/geos/algorithm/distance/DiscreteHausdorffDistance.h
--- trunk/source/headers/geos/algorithm/distance/DiscreteHausdorffDistance.h 2009-04-17 15:47:07 UTC (rev 2384)
+++ trunk/source/headers/geos/algorithm/distance/DiscreteHausdorffDistance.h 2009-04-17 16:26:20 UTC (rev 2385)
@@ -13,7 +13,7 @@
More information about the geos-commits
