[geos-commits] r2389 - trunk/tests/unit/algorithm/distance
svn_geos at osgeo.org
Fri Apr 17 12:50:16 EDT 2009
Author: strk
Date: 2009-04-17 12:50:16 -0400 (Fri, 17 Apr 2009)
New Revision: 2389
trunk/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp
comment out debugging lines
Modified: trunk/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp
--- trunk/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp 2009-04-17 16:49:25 UTC (rev 2388)
+++ trunk/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp 2009-04-17 16:50:16 UTC (rev 2389)
@@ -54,7 +54,7 @@
double distance = DiscreteHausdorffDistance::distance(*g1, *g2);
double diff = fabs(distance-expectedDistance);
- std::cerr << "expectedDistance:" << expectedDistance << " actual distance:" << distance << std::endl;
+ //std::cerr << "expectedDistance:" << expectedDistance << " actual distance:" << distance << std::endl;
ensure( diff <= TOLERANCE );
@@ -67,7 +67,7 @@
*g2, densifyFactor);
More information about the geos-commits
