[geos-commits] r2392 - trunk/tests/xmltester
svn_geos at osgeo.org
Sat Apr 18 03:55:02 EDT 2009
Author: strk
Date: 2009-04-18 03:55:02 -0400 (Sat, 18 Apr 2009)
New Revision: 2392
trunk/tests/xmltester/XMLTester.cpp
Use BufferResultMatcher for buffer operations. No failures.
Modified: trunk/tests/xmltester/XMLTester.cpp
--- trunk/tests/xmltester/XMLTester.cpp 2009-04-18 07:49:38 UTC (rev 2391)
+++ trunk/tests/xmltester/XMLTester.cpp 2009-04-18 07:55:02 UTC (rev 2392)
@@ -725,20 +725,7 @@
success=1;
do
-#if USE_BUFFER_RESULT_MATCHER
- geos::xmltester::BufferResultMatcher matcher;
- if ( ! matcher.isBufferResultMatch(*gRealRes,
- *gRes,
- dist) )
- success=0;
- break;
-#endif
- // TODO: Is a buffer always an area ?
- // we might check geometry type..
if ( gRes->getGeometryTypeId() != gRealRes->getGeometryTypeId() )
std::cerr << "Expected result is of type "
@@ -750,12 +737,7 @@
break;
- if ( gRes->isEmpty() && gRealRes->isEmpty() )
- // Success !
- break;
+ // Is a buffer always an area ?
if ( gRes->getDimension() != 2 )
std::cerr << "Don't know how to validate "
@@ -765,33 +747,16 @@
<< std::endl;
- double expectedArea = gRes->getArea();
- /// Allow area difference being at most
- /// 1/1000 of the area of the expected result.
- double areatol = expectedArea / 1e3;
- GeomAutoPtr gDiff = BinaryOp(gRes.get(), gRealRes.get(),
- overlayOp(OverlayOp::opSYMDIFFERENCE));
- double areaDiff = gDiff->getArea();
- if ( areaDiff > areatol )
+ geos::xmltester::BufferResultMatcher matcher;
+ if ( ! matcher.isBufferResultMatch(*gRealRes,
+ *gRes,
+ dist) )
- std::cerr << "Area of difference between "
- << "obtained and expected: "
- << areaDiff << " - Tolerated diff: "
- << areatol << std::endl;
+std::cerr << "BufferResultMatcher FAILED" << std::endl;
success=0;
break;
- else
- << areatol << " (SUCCESS!)"
- << std::endl;
while (0);
@@ -834,8 +799,6 @@
success=1;
do
@@ -848,12 +811,7 @@
break;
- // Success !
- break;
@@ -863,33 +821,16 @@
<< std::endl;
+ *gRes,
+ dist) )
success=0;
break;
- else
- << std::endl;
while (0);
More information about the geos-commits
