[geos-commits] r2401 - in trunk: source/geom
source/headers/geos/geom tests/unit/geom
svn_geos at osgeo.org
Tue Apr 21 11:12:20 EDT 2009
Author: strk
Date: 2009-04-21 11:12:20 -0400 (Tue, 21 Apr 2009)
New Revision: 2401
trunk/source/geom/LinearRing.cpp
trunk/source/headers/geos/geom/LinearRing.h
trunk/tests/unit/geom/LinearRingTest.cpp
Sync LinearRing to JTS-1.10 (fixing a bug in isClosed)
Modified: trunk/source/geom/LinearRing.cpp
--- trunk/source/geom/LinearRing.cpp 2009-04-21 14:03:45 UTC (rev 2400)
+++ trunk/source/geom/LinearRing.cpp 2009-04-21 15:12:20 UTC (rev 2401)
@@ -12,13 +12,19 @@
* by the Free Software Foundation.
* See the COPYING file for more information.
+ * Last port: geom/LinearRing.java rev. 1.32 (JTS-1.10)
#include <geos/geom/LinearRing.h>
+#include <geos/geom/Dimension.h>
#include <geos/geom/CoordinateSequence.h>
#include <geos/geom/GeometryFactory.h>
#include <geos/util/IllegalArgumentException.h>
+#include <sstream>
#include <string>
#include <memory>
@@ -52,12 +58,23 @@
void
LinearRing::validateConstruction()
- if (!LineString::isEmpty() && !LineString::isClosed()) {
- throw util::IllegalArgumentException("points must form a closed linestring");
- if (!points->isEmpty() && (points->getSize()>=1 && points->getSize()<=3)) {
- throw util::IllegalArgumentException("Number of points must be 0 or >3");
+ // Empty ring is valid
+ if ( points->isEmpty() ) return;
+ if ( !LineString::isClosed() )
+ throw util::IllegalArgumentException(
+ "Points of LinearRing do not form a closed linestring"
+ if ( points->getSize() <= 3 )
+ std::ostringstream os;
+ os << "Invalid number of points in LinearRing found "
+ << points->getSize() << " - must be 0 or >= 4";
+ throw util::IllegalArgumentException(os.str());
@@ -66,15 +83,21 @@
LinearRing::~LinearRing(){
-bool LinearRing::isSimple() const {
+int
+LinearRing::getBoundaryDimension() const
+ return Dimension::False;
+bool
+LinearRing::isSimple() const
return true;
string LinearRing::getGeometryType() const {
return "LinearRing";
-bool LinearRing::isClosed() const {
- return true;
void LinearRing::setPoints(CoordinateSequence* cl){
const vector<Coordinate> *v=cl->toVector();
@@ -87,6 +110,16 @@
return GEOS_LINEARRING;
+Geometry*
+LinearRing::reverse() const
+ assert(points.get());
+ CoordinateSequence* seq = points->clone();
+ CoordinateSequence::reverse(seq);
+ assert(getFactory());
+ return getFactory()->createLinearRing(seq);
} // namespace geos::geom
} // namespace geos
Modified: trunk/source/headers/geos/geom/LinearRing.h
--- trunk/source/headers/geos/geom/LinearRing.h 2009-04-21 14:03:45 UTC (rev 2400)
+++ trunk/source/headers/geos/geom/LinearRing.h 2009-04-21 15:12:20 UTC (rev 2401)
@@ -12,6 +12,10 @@
#ifndef GEOS_GEOS_LINEARRING_H
@@ -36,13 +40,19 @@
namespace geom { // geos::geom
+ * \brief
+ * Models an OGC SFS <code>LinearRing</code>.
- * \brief Basic implementation of <code>LinearRing</code>.
- * The first and last point in the coordinate sequence must be equal.
+ * A LinearRing is a LineString which is both closed and simple.
+ * In other words,
+ * the first and last coordinate in the ring must be equal,
+ * and the interior of the ring must not self-intersect.
* Either orientation of the ring is allowed.
- * A valid ring must not self-intersect.
+ * A ring must have either 0 or 4 or more points.
+ * The first and last points must be equal (in 2D).
+ * If these conditions are not met, the constructors throw
+ * an {@link IllegalArgumentException}
class LinearRing : public LineString {
@@ -70,13 +80,37 @@
const GeometryFactory *newFactory);
virtual Geometry *clone() const { return new LinearRing(*this); }
virtual ~LinearRing();
+ /** \brief
+ * Returns <code>Dimension.FALSE</code>, since by definition
+ * LinearRings do not have a boundary.
+ * @return Dimension::False
+ int getBoundaryDimension() const;
+ /** \brief
+ * Returns <code>true</code>, since by definition LinearRings
+ * are always simple.
+ * @return <code>true</code>
+ * @see Geometry::isSimple
bool isSimple() const;
std::string getGeometryType() const;
virtual GeometryTypeId getGeometryTypeId() const;
- bool isClosed() const;
void setPoints(CoordinateSequence* cl);
+ Geometry* reverse() const;
private:
void validateConstruction();
Modified: trunk/tests/unit/geom/LinearRingTest.cpp
--- trunk/tests/unit/geom/LinearRingTest.cpp 2009-04-21 14:03:45 UTC (rev 2400)
+++ trunk/tests/unit/geom/LinearRingTest.cpp 2009-04-21 15:12:20 UTC (rev 2401)
@@ -136,7 +136,7 @@
template<>
void object::test<4>()
- ensure( empty_ring_.isClosed() );
+ ensure( ! empty_ring_.isClosed() );
// Test of isRing() for empty LinearRing
@@ -144,7 +144,7 @@
template<>
void object::test<5>()
- ensure( empty_ring_.isRing() );
+ ensure( ! empty_ring_.isRing() );
// Test of isSimple() for empty LinearRing
More information about the geos-commits
