[geos-commits] r2403 - in trunk/tests/unit: . operation/valid
svn_geos at osgeo.org
Tue Apr 21 11:30:16 EDT 2009
Author: strk
Date: 2009-04-21 11:30:16 -0400 (Tue, 21 Apr 2009)
New Revision: 2403
Added:
trunk/tests/unit/operation/valid/ValidClosedRingTest.cpp
trunk/tests/unit/Makefile.am
Port ValidClosedRingTest
Modified: trunk/tests/unit/Makefile.am
--- trunk/tests/unit/Makefile.am 2009-04-21 15:13:23 UTC (rev 2402)
+++ trunk/tests/unit/Makefile.am 2009-04-21 15:30:16 UTC (rev 2403)
@@ -72,6 +72,7 @@
operation/overlay/OverlayResultValidatorTest.cpp \
operation/union/CascadedPolygonUnionTest.cpp \
operation/valid/IsValidTest.cpp \
+ operation/valid/ValidClosedRingTest.cpp \
precision/GeometrySnapperTest.cpp \
precision/LineStringSnapperTest.cpp \
precision/SimpleGeometryPrecisionReducerTest.cpp \
Added: trunk/tests/unit/operation/valid/ValidClosedRingTest.cpp
--- trunk/tests/unit/operation/valid/ValidClosedRingTest.cpp (rev 0)
+++ trunk/tests/unit/operation/valid/ValidClosedRingTest.cpp 2009-04-21 15:30:16 UTC (rev 2403)
@@ -0,0 +1,163 @@
+// $Id$
+// Test Suite for geos::operation::valid::IsValidOp class
+// Ported from JTS junit/operation/valid/ValidClosedRingTest.java rev. 1.1
+#include <tut.hpp>
+// geos
+#include <geos/operation/valid/IsValidOp.h>
+#include <geos/geom/Coordinate.h>
+#include <geos/geom/CoordinateArraySequence.h>
+#include <geos/geom/Dimension.h>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/LineString.h>
+#include <geos/geom/LinearRing.h>
+#include <geos/geom/Polygon.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/PrecisionModel.h>
+#include <geos/util/GEOSException.h>
+#include <geos/io/WKTReader.h>
+#include <geos/operation/valid/TopologyValidationError.h>
+#include <geos/platform.h> // for ISNAN
+// std
+#include <string>
+#include <memory>
+#include <iostream>
+using namespace geos::geom;
+//using namespace geos::operation;
+using namespace geos::operation::valid;
+using namespace geos::util;
+using namespace std;
+namespace tut
+ // Test Group
+ struct test_validclosedring_data
+ typedef std::auto_ptr<Geometry> GeomPtr;
+ geos::geom::PrecisionModel pm_;
+ geos::geom::GeometryFactory factory_;
+ geos::io::WKTReader rdr;
+ test_validclosedring_data()
+ : pm_(1), factory_(&pm_, 0), rdr(&factory_)
+ GeomPtr fromWKT(const std::string& wkt)
+ GeomPtr geom;
+ try {
+ geom.reset( rdr.read(wkt) );
+ catch (const GEOSException& ex) {
+ cerr << ex.what() << endl;
+ return geom;
+ void updateNonClosedRing(LinearRing& ring)
+ CoordinateSequence& pts = *(const_cast<CoordinateSequence*>(
+ ring.getCoordinatesRO()
+ Coordinate c = pts[0];
+ c.x += 0.0001;
+ pts.setAt(c, 0);
+ void checkIsValid(Geometry& geom, bool expected)
+ IsValidOp validator(&geom);
+ bool isValid = validator.isValid();
+ ensure_equals(isValid, expected);
+ typedef test_group<test_validclosedring_data> group;
+ typedef group::object object;
+ group test_validclosedring_group("geos::operation::valid::ValidClosedRing");
+ // Test Cases
+ // 1 - testBadLinearRing
+ template<>
+ template<>
+ void object::test<1>()
+ GeomPtr geom = fromWKT("LINEARRING (0 0, 0 10, 10 10, 10 0, 0 0)");
+ LinearRing* ring_chk = dynamic_cast<LinearRing*>(geom.get());
+ ensure(ring_chk);
+ LinearRing& ring = *ring_chk;
+ //cout << ring.toString() << endl;
+ updateNonClosedRing(ring);
+ checkIsValid(*geom, false);
+ // 2 - testGoodLinearRing
+ template<>
+ template<>
+ void object::test<2>()
+ checkIsValid(*geom, true);
+ // 3 - testBadPolygonShell
+ template<>
+ template<>
+ void object::test<3>()
+ GeomPtr geom = fromWKT("POLYGON ((0 0, 0 10, 10 10, 10 0, 0 0), (1 1, 2 1, 2 2, 1 2, 1 1) ))");
+ Polygon* poly = dynamic_cast<Polygon*>(geom.get());
+ ensure(poly);
+ const LineString* ring = poly->getExteriorRing();
+ const LinearRing* lr = dynamic_cast<const LinearRing*>(ring);
+ ensure(lr);
+ LinearRing* nclr = const_cast<LinearRing*>(lr);
+ updateNonClosedRing(*nclr);
+ // 4 - testBadPolygonHole
+ template<>
+ template<>
+ void object::test<4>()
+ ensure(poly);
+ const LineString* ring = poly->getInteriorRingN(0);
+ ensure(lr);
+ // 5 - testGoodPolygon
+ template<>
+ template<>
+ void object::test<5>()
+ GeomPtr geom = fromWKT("POLYGON ((0 0, 0 10, 10 10, 10 0, 0 0))");
+} // namespace tut
More information about the geos-commits
