[geos-commits] r2420 - in trunk/source: geom/prep
headers/geos/geom/prep
svn_geos at osgeo.org
Wed Apr 29 04:56:14 EDT 2009
Author: strk
Date: 2009-04-29 04:56:14 -0400 (Wed, 29 Apr 2009)
New Revision: 2420
trunk/source/geom/prep/AbstractPreparedPolygonContains.cpp
trunk/source/geom/prep/PreparedPolygonContainsProperly.cpp
trunk/source/geom/prep/PreparedPolygonCovers.cpp
trunk/source/geom/prep/PreparedPolygonIntersects.cpp
trunk/source/geom/prep/PreparedPolygonPredicate.cpp
trunk/source/headers/geos/geom/prep/AbstractPreparedPolygonContains.h
trunk/source/headers/geos/geom/prep/PreparedPolygonContainsProperly.h
trunk/source/headers/geos/geom/prep/PreparedPolygonCovers.h
trunk/source/headers/geos/geom/prep/PreparedPolygonIntersects.h
trunk/source/headers/geos/geom/prep/PreparedPolygonPredicate.h
Bring all geom::prep package in sync with JTS-1.10
Modified: trunk/source/geom/prep/AbstractPreparedPolygonContains.cpp
--- trunk/source/geom/prep/AbstractPreparedPolygonContains.cpp 2009-04-29 08:22:16 UTC (rev 2419)
+++ trunk/source/geom/prep/AbstractPreparedPolygonContains.cpp 2009-04-29 08:56:14 UTC (rev 2420)
@@ -13,7 +13,8 @@
- * Last port: geom/prep/AbstractPreparedPolygonContains.java rev. 1.6 (2007-12-12)
+ * Last port: geom/prep/AbstractPreparedPolygonContains.java rev 1.7 (JTS-1.10)
+ * (2007-12-12)
@@ -118,7 +119,7 @@
// If a point of any test components does not lie in target,
// result is false
- bool isAllInTargetArea = isAllTestComponentsInTargetArea( geom);
+ bool isAllInTargetArea = isAllTestComponentsInTarget( geom);
if ( !isAllInTargetArea )
return false;
@@ -181,7 +182,7 @@
|| geom->getGeometryTypeId() == geos::geom::GEOS_POLYGON )
// TODO: generalize this to handle GeometryCollections
- bool isTargetInTestArea = isAnyTargetComponentInTestArea( geom, prepPoly->getRepresentativePoints());
+ bool isTargetInTestArea = isAnyTargetComponentInAreaTest( geom, prepPoly->getRepresentativePoints());
if ( isTargetInTestArea )
return false;
Modified: trunk/source/geom/prep/PreparedPolygonContainsProperly.cpp
--- trunk/source/geom/prep/PreparedPolygonContainsProperly.cpp 2009-04-29 08:22:16 UTC (rev 2419)
+++ trunk/source/geom/prep/PreparedPolygonContainsProperly.cpp 2009-04-29 08:56:14 UTC (rev 2420)
@@ -13,7 +13,8 @@
- * Last port: geom/prep/PreparedPolygonContainsProperly.java rev 1.4 (2007-12-12)
+ * Last port: geom/prep/PreparedPolygonContainsProperly.java rev 1.5 (JTS-1.10)
+ * (2007-12-12)
@@ -75,7 +76,7 @@
- bool isTargetGeomInTestArea = isAnyTargetComponentInTestArea( geom, prepPoly->getRepresentativePoints());
+ bool isTargetGeomInTestArea = isAnyTargetComponentInAreaTest( geom, prepPoly->getRepresentativePoints());
if (isTargetGeomInTestArea)
return false;
Modified: trunk/source/geom/prep/PreparedPolygonCovers.cpp
--- trunk/source/geom/prep/PreparedPolygonCovers.cpp 2009-04-29 08:22:16 UTC (rev 2419)
+++ trunk/source/geom/prep/PreparedPolygonCovers.cpp 2009-04-29 08:56:14 UTC (rev 2420)
@@ -13,7 +13,8 @@
- * Last port: geom/prep/PreparedPolygonCovers.java rev 1.1 (2007-08-17)
+ * Last port: geom/prep/PreparedPolygonCovers.java rev 1.2 (JTS-1.10)
+ * (2007-12-12)
Modified: trunk/source/geom/prep/PreparedPolygonIntersects.cpp
--- trunk/source/geom/prep/PreparedPolygonIntersects.cpp 2009-04-29 08:22:16 UTC (rev 2419)
+++ trunk/source/geom/prep/PreparedPolygonIntersects.cpp 2009-04-29 08:56:14 UTC (rev 2420)
@@ -13,7 +13,8 @@
- * Last port: geom/prep/PreparedPolygonIntersects.java rev 1.5 (2007-08-17)
+ * Last port: geom/prep/PreparedPolygonIntersects.java rev 1.6 (JTS-1.10)
+ * (2007-12-12)
@@ -48,7 +49,7 @@
// Do point-in-poly tests first, since they are cheaper and may result
// in a quick positive result.
// If a point of any test components lie in target, result is true
- bool isInPrepGeomArea = isAnyTestComponentInTargetArea( geom);
+ bool isInPrepGeomArea = isAnyTestComponentInTarget( geom);
if ( isInPrepGeomArea )
return true;
@@ -72,7 +73,7 @@
if ( geom->getDimension() == 2)
- bool isPrepGeomInArea = isAnyTargetComponentInTestArea( geom, prepPoly->getRepresentativePoints());
+ bool isPrepGeomInArea = isAnyTargetComponentInAreaTest( geom, prepPoly->getRepresentativePoints());
if ( isPrepGeomInArea )
return true;
Modified: trunk/source/geom/prep/PreparedPolygonPredicate.cpp
--- trunk/source/geom/prep/PreparedPolygonPredicate.cpp 2009-04-29 08:22:16 UTC (rev 2419)
+++ trunk/source/geom/prep/PreparedPolygonPredicate.cpp 2009-04-29 08:56:14 UTC (rev 2420)
@@ -13,7 +13,8 @@
- * Last port: geom/prep/PreparedPolygonPredicate.java rev. 1.2 (2007-08-16)
+ * Last port: geom/prep/PreparedPolygonPredicate.java rev. 1.4 (JTS-1.10)
+ * (2007-12-12)
@@ -38,7 +39,7 @@
// protected:
bool
-PreparedPolygonPredicate::isAllTestComponentsInTargetArea(const geom::Geometry* testGeom)
+PreparedPolygonPredicate::isAllTestComponentsInTarget(const geom::Geometry* testGeom) const
geom::Coordinate::ConstVect pts;
geom::util::ComponentCoordinateExtracter::getCoordinates(*testGeom, pts);
@@ -56,7 +57,8 @@
bool
-PreparedPolygonPredicate::isAllTestComponentsInTargetInterior(const geom::Geometry* testGeom)
+PreparedPolygonPredicate::isAllTestComponentsInTargetInterior(
+ const geom::Geometry* testGeom) const
@@ -74,7 +76,8 @@
bool
-PreparedPolygonPredicate::isAnyTestComponentInTargetArea(const geom::Geometry* testGeom)
+PreparedPolygonPredicate::isAnyTestComponentInTarget(
@@ -92,7 +95,8 @@
bool
-PreparedPolygonPredicate::isAnyTestComponentInTargetInterior( const geom::Geometry * testGeom)
+PreparedPolygonPredicate::isAnyTestComponentInTargetInterior(
+ const geom::Geometry * testGeom) const
@@ -110,25 +114,22 @@
bool
-PreparedPolygonPredicate::isAnyTargetComponentInTestArea(const geom::Geometry* testGeom,
- const geom::Coordinate::ConstVect* targetRepPts)
+PreparedPolygonPredicate::isAnyTargetComponentInAreaTest(
+ const geom::Geometry* testGeom,
+ const geom::Coordinate::ConstVect* targetRepPts) const
- // TODO - mloskot: Replace manual delete with scoped_ptr
- algorithm::locate::PointOnGeometryLocator* piaLoc = 0;
- piaLoc = new algorithm::locate::SimplePointInAreaLocator(testGeom);
+ algorithm::locate::SimplePointInAreaLocator piaLoc(testGeom);
for (std::size_t i = 0, ni = targetRepPts->size(); i < ni; i++)
const geom::Coordinate * pt = (*targetRepPts)[i];
- const int loc = piaLoc->locate(pt);
+ const int loc = piaLoc.locate(pt);
if (geom::Location::EXTERIOR != loc)
- delete piaLoc;
return true;
- delete piaLoc;
return false;
Modified: trunk/source/headers/geos/geom/prep/AbstractPreparedPolygonContains.h
--- trunk/source/headers/geos/geom/prep/AbstractPreparedPolygonContains.h 2009-04-29 08:22:16 UTC (rev 2419)
+++ trunk/source/headers/geos/geom/prep/AbstractPreparedPolygonContains.h 2009-04-29 08:56:14 UTC (rev 2420)
@@ -14,7 +14,8 @@
+ * (2007-12-12)
Modified: trunk/source/headers/geos/geom/prep/PreparedPolygonContainsProperly.h
--- trunk/source/headers/geos/geom/prep/PreparedPolygonContainsProperly.h 2009-04-29 08:22:16 UTC (rev 2419)
+++ trunk/source/headers/geos/geom/prep/PreparedPolygonContainsProperly.h 2009-04-29 08:56:14 UTC (rev 2420)
@@ -14,7 +14,8 @@
+ * (2007-12-12)
Modified: trunk/source/headers/geos/geom/prep/PreparedPolygonCovers.h
--- trunk/source/headers/geos/geom/prep/PreparedPolygonCovers.h 2009-04-29 08:22:16 UTC (rev 2419)
+++ trunk/source/headers/geos/geom/prep/PreparedPolygonCovers.h 2009-04-29 08:56:14 UTC (rev 2420)
@@ -14,7 +14,8 @@
+ * (2007-12-12)
@@ -61,7 +62,7 @@
* Used when short-circuit tests are not conclusive.
* @param geom the test geometry
- * @return true if this prepared polygon contains the test geometry
+ * @return true if this prepared polygon covers the test geometry
bool fullTopologicalPredicate( const geom::Geometry * geom);
@@ -93,7 +94,7 @@
* Tests whether this PreparedPolygon <tt>covers</tt> a given geometry.
- * @return true if the test geometry is contained
+ * @return true if the test geometry is covered
bool covers( const Geometry * geom)
Modified: trunk/source/headers/geos/geom/prep/PreparedPolygonIntersects.h
--- trunk/source/headers/geos/geom/prep/PreparedPolygonIntersects.h 2009-04-29 08:22:16 UTC (rev 2419)
+++ trunk/source/headers/geos/geom/prep/PreparedPolygonIntersects.h 2009-04-29 08:56:14 UTC (rev 2420)
@@ -14,7 +14,8 @@
+ * (2007-12-12)
Modified: trunk/source/headers/geos/geom/prep/PreparedPolygonPredicate.h
--- trunk/source/headers/geos/geom/prep/PreparedPolygonPredicate.h 2009-04-29 08:22:16 UTC (rev 2419)
+++ trunk/source/headers/geos/geom/prep/PreparedPolygonPredicate.h 2009-04-29 08:56:14 UTC (rev 2420)
@@ -14,7 +14,8 @@
+ * (2007-12-12)
@@ -60,55 +61,63 @@
protected:
const PreparedPolygon * const prepPoly;
+ /** \brief
* Tests whether all components of the test Geometry
* are contained in the target geometry.
* Handles both linear and point components.
* @param geom a geometry to test
- * @return true if all componenta of the argument are contained in the target geometry
+ * @return true if all components of the argument are contained
+ * in the target geometry
- bool isAllTestComponentsInTargetArea( const geom::Geometry * testGeom);
+ bool isAllTestComponentsInTarget(const geom::Geometry * testGeom) const;
+ /** \brief
* are contained in the interior of the target geometry.
- * @return true if all componenta of the argument are contained in the target geometry interior
+ * @return true if all componenta of the argument are contained in
+ * the target geometry interior
- bool isAllTestComponentsInTargetInterior( const geom::Geometry * testGeom);
+ bool isAllTestComponentsInTargetInterior( const geom::Geometry * testGeom) const;
+ /** \brief
* Tests whether any component of the test Geometry intersects
* the area of the target geometry.
* Handles test geometries with both linear and point components.
- * @return true if any component of the argument intersects the prepared geometry
+ * @return true if any component of the argument intersects the
+ * prepared geometry
- bool isAnyTestComponentInTargetArea( const geom::Geometry * testGeom);
+ bool isAnyTestComponentInTarget( const geom::Geometry * testGeom) const;
+ /** \brief
* the interior of the target geometry.
- * @return true if any component of the argument intersects the prepared area geometry interior
+ * prepared area geometry interior
- bool isAnyTestComponentInTargetInterior( const geom::Geometry * testGeom);
+ bool isAnyTestComponentInTargetInterior( const geom::Geometry * testGeom) const;
* Tests whether any component of the target geometry
- * intersects the area of the test geometry
+ * intersects the test geometry (which must be an areal geometry)
* @param repPts the representative points of the target geometry
* @return true if any component intersects the areal test geometry
- bool isAnyTargetComponentInTestArea( const geom::Geometry * testGeom, const geom::Coordinate::ConstVect * targetRepPts);
+ bool isAnyTargetComponentInAreaTest( const geom::Geometry * testGeom, const geom::Coordinate::ConstVect * targetRepPts) const;
public:
@@ -120,7 +129,7 @@
: prepPoly( prepPoly)
- ~PreparedPolygonPredicate()
+ virtual ~PreparedPolygonPredicate()
More information about the geos-commits
