[geos-commits] r2763 - in trunk/source/operation: buffer linemerge
overlay predicate valid
svn_geos at osgeo.org
Thu Dec 3 14:02:18 EST 2009
Author: mloskot
Date: 2009-12-03 14:02:17 -0500 (Thu, 03 Dec 2009)
New Revision: 2763
trunk/source/operation/buffer/BufferInputLineSimplifier.h
trunk/source/operation/buffer/OffsetCurveBuilder.cpp
trunk/source/operation/linemerge/LineSequencer.cpp
trunk/source/operation/overlay/OverlayOp.cpp
trunk/source/operation/overlay/PolygonBuilder.cpp
trunk/source/operation/predicate/RectangleIntersects.cpp
trunk/source/operation/valid/IsValidOp.cpp
Part 3 of larger changeset - source/operation:
* Declare noncopyable types as such explicitly (Ticket #304).
* Tidy up.
Modified: trunk/source/operation/buffer/BufferInputLineSimplifier.h
--- trunk/source/operation/buffer/BufferInputLineSimplifier.h 2009-12-03 19:01:10 UTC (rev 2762)
+++ trunk/source/operation/buffer/BufferInputLineSimplifier.h 2009-12-03 19:02:17 UTC (rev 2763)
@@ -20,7 +20,7 @@
#ifndef GEOS_OP_BUFFER_BUFFERINPUTLINESIMPLIFIER_H
#define GEOS_OP_BUFFER_BUFFERINPUTLINESIMPLIFIER_H
+#include <geos/geom/CoordinateSequence.h> // complete type required
#include <geos/algorithm/CGAlgorithms.h> // for enum
#include <memory>
@@ -169,6 +169,10 @@
std::vector<int> isDeleted;
int angleOrientation;
+ // Declare type as noncopyable
+ BufferInputLineSimplifier(const BufferInputLineSimplifier& other);
+ BufferInputLineSimplifier& operator=(const BufferInputLineSimplifier& rhs);
Modified: trunk/source/operation/buffer/OffsetCurveBuilder.cpp
--- trunk/source/operation/buffer/OffsetCurveBuilder.cpp 2009-12-03 19:01:10 UTC (rev 2762)
+++ trunk/source/operation/buffer/OffsetCurveBuilder.cpp 2009-12-03 19:02:17 UTC (rev 2763)
@@ -35,6 +35,7 @@
#include <geos/geom/PrecisionModel.h>
#include <geos/algorithm/NotRepresentableException.h>
#include <geos/algorithm/HCoordinate.h>
+#include <geos/util.h>
#include "OffsetCurveVertexList.h"
#include "BufferInputLineSimplifier.h"
@@ -626,6 +627,9 @@
void
OffsetCurveBuilder::addInsideTurn(int orientation, bool addStartPoint)
+ ::geos::ignore_unused_variable_warning(orientation);
+ ::geos::ignore_unused_variable_warning(addStartPoint);
// add intersection point of offset segments (if any)
li.computeIntersection(offset0.p0, offset0.p1, offset1.p0, offset1.p1);
if (li.hasIntersection())
@@ -718,34 +722,36 @@
* by the check for whether the offset segment endpoints are
* almost coincident
- try
- HCoordinate::intersection(offset0.p0, offset0.p1,
- offset1.p0, offset1.p1,
- intPt);
+ try
+ HCoordinate::intersection(offset0.p0, offset0.p1,
+ offset1.p0, offset1.p1,
+ intPt);
- double mitreRatio = distance <= 0.0 ? 1.0
- : intPt.distance(p) / fabs(distance);
+ double mitreRatio = distance <= 0.0 ? 1.0
+ : intPt.distance(p) / fabs(distance);
- if (mitreRatio > bufParams.getMitreLimit())
- isMitreWithinLimit = false;
- catch (const NotRepresentableException& e)
- intPt = Coordinate(0,0);
+ if (mitreRatio > bufParams.getMitreLimit())
+ isMitreWithinLimit = false;
+ catch (const NotRepresentableException& e)
+ ::geos::ignore_unused_variable_warning(e);
- if (isMitreWithinLimit)
- vertexList->addPt(intPt);
- else
- addLimitedMitreJoin(offset0, offset1, distance,
- bufParams.getMitreLimit());
- //addBevelJoin(offset0, offset1);
+ intPt = Coordinate(0,0);
+ if (isMitreWithinLimit)
+ vertexList->addPt(intPt);
+ else
+ addLimitedMitreJoin(offset0, offset1, distance,
+ bufParams.getMitreLimit());
+ //addBevelJoin(offset0, offset1);
/* private */
@@ -755,6 +761,9 @@
const geom::LineSegment& offset1,
double distance, double mitreLimit)
+ ::geos::ignore_unused_variable_warning(offset0);
+ ::geos::ignore_unused_variable_warning(offset1);
const Coordinate& basePt = seg0.p1;
double ang0 = Angle::angle(basePt, seg0.p0);
Modified: trunk/source/operation/linemerge/LineSequencer.cpp
--- trunk/source/operation/linemerge/LineSequencer.cpp 2009-12-03 19:01:10 UTC (rev 2762)
+++ trunk/source/operation/linemerge/LineSequencer.cpp 2009-12-03 19:02:17 UTC (rev 2763)
@@ -40,6 +40,10 @@
using namespace geos::geom;
//using namespace geos::planargraph::algorithm;
+#ifdef _MSC_VER
+#pragma warning(disable : 4127)
+#endif
namespace geos {
namespace operation { // geos.operation
namespace linemerge { // geos.operation.linemerge
@@ -50,7 +54,7 @@
const MultiLineString *mls;
- if ( ! (mls=dynamic_cast<const MultiLineString *>(geom)) )
+ if ( 0 == (mls=dynamic_cast<const MultiLineString *>(geom)) )
return true;
Modified: trunk/source/operation/overlay/OverlayOp.cpp
--- trunk/source/operation/overlay/OverlayOp.cpp 2009-12-03 19:01:10 UTC (rev 2762)
+++ trunk/source/operation/overlay/OverlayOp.cpp 2009-12-03 19:02:17 UTC (rev 2763)
@@ -911,6 +911,11 @@
"A point on first geom boundary isn't covered "
"by either result or second geom");
+private:
+ PointCoveredByAny(const PointCoveredByAny& other);
+ PointCoveredByAny& operator=(const PointCoveredByAny& rhs);
void
Modified: trunk/source/operation/overlay/PolygonBuilder.cpp
--- trunk/source/operation/overlay/PolygonBuilder.cpp 2009-12-03 19:01:10 UTC (rev 2762)
+++ trunk/source/operation/overlay/PolygonBuilder.cpp 2009-12-03 19:02:17 UTC (rev 2763)
@@ -31,6 +31,7 @@
#include <geos/util/TopologyException.h>
#include <geos/util/GEOSException.h>
#include <vector>
#include <cassert>
@@ -176,6 +177,7 @@
delete (*maxEdgeRings)[i];
delete maxEdgeRings;
//cerr << "Exception! " << e.what() << endl;
throw;
maxEdgeRings->push_back(er);
Modified: trunk/source/operation/predicate/RectangleIntersects.cpp
--- trunk/source/operation/predicate/RectangleIntersects.cpp 2009-12-03 19:01:10 UTC (rev 2762)
+++ trunk/source/operation/predicate/RectangleIntersects.cpp 2009-12-03 19:02:17 UTC (rev 2763)
@@ -51,6 +51,10 @@
const geom::Envelope &rectEnv;
bool intersectsVar;
+ EnvelopeIntersectsVisitor(const EnvelopeIntersectsVisitor& other);
+ EnvelopeIntersectsVisitor& operator=(const EnvelopeIntersectsVisitor& rhs);
protected:
@@ -130,6 +134,10 @@
bool containsPointVar;
const geom::CoordinateSequence &rectSeq;
+ ContainsPointVisitor(const ContainsPointVisitor& other);
+ ContainsPointVisitor& operator=(const ContainsPointVisitor& rhs);
protected:
void visit(const geom::Geometry &geom)
@@ -138,7 +146,7 @@
const geom::Polygon *poly;
- if ( !(poly=dynamic_cast<const geom::Polygon *>(&geom)) ) {
+ if ( 0 == (poly=dynamic_cast<const geom::Polygon *>(&geom)) ) {
return;
@@ -212,6 +220,10 @@
+ LineIntersectsVisitor(const LineIntersectsVisitor& other);
+ LineIntersectsVisitor& operator=(const LineIntersectsVisitor& rhs);
protected:
Modified: trunk/source/operation/valid/IsValidOp.cpp
--- trunk/source/operation/valid/IsValidOp.cpp 2009-12-03 19:01:10 UTC (rev 2762)
+++ trunk/source/operation/valid/IsValidOp.cpp 2009-12-03 19:02:17 UTC (rev 2763)
@@ -127,7 +127,7 @@
else if (typeid(*g)==typeid(LineString)) checkValid((LineString*)g);
else if (typeid(*g)==typeid(Polygon)) checkValid((Polygon*)g);
else if (typeid(*g)==typeid(MultiPolygon)) checkValid((MultiPolygon*)g);
- else if ((gc=dynamic_cast<const GeometryCollection *>(g)))
+ else if (0 != (gc=dynamic_cast<const GeometryCollection *>(g)))
checkValid(gc);
else throw util::UnsupportedOperationException();
isChecked=true;
More information about the geos-commits
