[geos-commits] r2801 - trunk/source/linearref
svn_geos at osgeo.org
Sat Dec 5 15:30:56 EST 2009
Author: mloskot
Date: 2009-12-05 15:30:54 -0500 (Sat, 05 Dec 2009)
New Revision: 2801
trunk/source/linearref/ExtractLineByLocation.cpp
small cleanup
Modified: trunk/source/linearref/ExtractLineByLocation.cpp
--- trunk/source/linearref/ExtractLineByLocation.cpp 2009-12-05 20:23:15 UTC (rev 2800)
+++ trunk/source/linearref/ExtractLineByLocation.cpp 2009-12-05 20:30:54 UTC (rev 2801)
@@ -91,29 +91,46 @@
CoordinateSequence* coordinates = line->getCoordinates();
CoordinateArraySequence newCoordinateArray;
+ const unsigned int indexStep = 1;
unsigned int startSegmentIndex = start.getSegmentIndex();
if (start.getSegmentFraction() > 0.0)
- startSegmentIndex += 1;
- unsigned int lastSegmentIndex = end.getSegmentIndex();
+ startSegmentIndex += indexStep;
+ unsigned int lastSegmentIndex = end.getSegmentIndex();
if (end.getSegmentFraction() == 1.0)
- lastSegmentIndex += 1;
+ lastSegmentIndex += indexStep;
if (lastSegmentIndex >= coordinates->size())
- lastSegmentIndex = coordinates->size() - 1;
- // not needed - LinearLocation values should always be correct
- //Assert.isTrue(end.getSegmentFraction() <= 1.0, "invalid segment fraction value");
+ assert(coordinates->size() > 0);
+ lastSegmentIndex = coordinates->size() - indexStep;
if (! start.isVertex())
newCoordinateArray.add(start.getCoordinate(line));
for (unsigned int i = startSegmentIndex; i <= lastSegmentIndex; i++)
newCoordinateArray.add((*coordinates)[i]);
if (! end.isVertex())
newCoordinateArray.add(end.getCoordinate(line));
// ensure there is at least one coordinate in the result
if (newCoordinateArray.size() == 0)
* Ensure there is enough coordinates to build a valid line.
More information about the geos-commits
