[geos-commits] r2831 - trunk/source/io
svn_geos at osgeo.org
Tue Dec 15 09:38:39 EST 2009
Author: mloskot
Date: 2009-12-15 09:38:37 -0500 (Tue, 15 Dec 2009)
New Revision: 2831
trunk/source/io/WKTWriter.cpp
In WKTWriter, initialise formatting buffer and avoid unnecessary calls to string constructor.
Modified: trunk/source/io/WKTWriter.cpp
--- trunk/source/io/WKTWriter.cpp 2009-12-14 19:21:40 UTC (rev 2830)
+++ trunk/source/io/WKTWriter.cpp 2009-12-15 14:38:37 UTC (rev 2831)
@@ -120,8 +120,8 @@
// the default number of decimal places is 16, which is sufficient
// to accomodate the maximum precision of a double.
int decimalPlaces = precisionModel->getMaximumSignificantDigits();
- string fmt="%.";
- char buffer[255];
+ std::string fmt("%.");
+ char buffer[255] = { 0 };
sprintf(buffer,"%i",decimalPlaces);
fmt.append(buffer);
fmt.append("f");
@@ -281,10 +281,9 @@
string WKTWriter::writeNumber(double d) {
- string out="";
- char buffer[255];
sprintf(buffer,formatter.c_str(),d);
- out.append(buffer);
+ std::string out(buffer);
out.append("");
return out;
More information about the geos-commits
