[geos-commits] r2250 - trunk/capi
svn_geos at osgeo.org
Mon Jan 19 18:55:25 EST 2009
Author: pramsey
Date: 2009-01-19 18:55:24 -0500 (Mon, 19 Jan 2009)
New Revision: 2250
trunk/capi/geos_c.cpp
trunk/capi/geos_ts_c.cpp
Formatting changes to function decls.
Modified: trunk/capi/geos_c.cpp
--- trunk/capi/geos_c.cpp 2009-01-19 20:41:10 UTC (rev 2249)
+++ trunk/capi/geos_c.cpp 2009-01-19 23:55:24 UTC (rev 2250)
@@ -82,11 +82,11 @@
finishGEOS_r( handle );
-// relate()-related functions
-// return 0 = false, 1 = true, 2 = error occured
+** relate()-related functions
+** return 0 = false, 1 = true, 2 = error occured
char
GEOSDisjoint(const Geometry *g1, const Geometry *g2)
@@ -490,8 +490,7 @@
int
-GEOSCoordSeq_setOrdinate(CoordinateSequence *s, unsigned int idx,
- unsigned int dim, double val)
+GEOSCoordSeq_setOrdinate(CoordinateSequence *s, unsigned int idx, unsigned int dim, double val)
return GEOSCoordSeq_setOrdinate_r( handle, s, idx, dim, val );
@@ -521,8 +520,7 @@
int
-GEOSCoordSeq_getOrdinate(const CoordinateSequence *s, unsigned int idx,
- unsigned int dim, double *val)
+GEOSCoordSeq_getOrdinate(const CoordinateSequence *s, unsigned int idx, unsigned int dim, double *val)
return GEOSCoordSeq_getOrdinate_r( handle, s, idx, dim, val );
@@ -766,31 +764,27 @@
char
-GEOSPreparedContains(const geos::geom::prep::PreparedGeometry *pg1,
- const Geometry *g2)
+GEOSPreparedContains(const geos::geom::prep::PreparedGeometry *pg1, const Geometry *g2)
return GEOSPreparedContains_r( handle, pg1, g2 );
char
-GEOSPreparedContainsProperly(const geos::geom::prep::PreparedGeometry *pg1,
+GEOSPreparedContainsProperly(const geos::geom::prep::PreparedGeometry *pg1, const Geometry *g2)
return GEOSPreparedContainsProperly_r( handle, pg1, g2 );
char
-GEOSPreparedCovers(const geos::geom::prep::PreparedGeometry *pg1,
+GEOSPreparedCovers(const geos::geom::prep::PreparedGeometry *pg1, const Geometry *g2)
return GEOSPreparedCovers_r( handle, pg1, g2 );
char
-GEOSPreparedIntersects(const geos::geom::prep::PreparedGeometry *pg1,
+GEOSPreparedIntersects(const geos::geom::prep::PreparedGeometry *pg1, const Geometry *g2)
return GEOSPreparedIntersects_r( handle, pg1, g2 );
-} //extern "C"
+} /* extern "C" */
Modified: trunk/capi/geos_ts_c.cpp
--- trunk/capi/geos_ts_c.cpp 2009-01-19 20:41:10 UTC (rev 2249)
+++ trunk/capi/geos_ts_c.cpp 2009-01-19 23:55:24 UTC (rev 2250)
@@ -155,8 +155,7 @@
char
-GEOSDisjoint_r(GEOSContextHandle_t extHandle, const Geometry *g1,
+GEOSDisjoint_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2)
GEOSContextHandleInternal_t *handle;
@@ -190,8 +189,7 @@
char
-GEOSTouches_r(GEOSContextHandle_t extHandle, const Geometry *g1,
+GEOSTouches_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2)
@@ -226,8 +224,7 @@
char
-GEOSIntersects_r(GEOSContextHandle_t extHandle, const Geometry *g1,
+GEOSIntersects_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2)
@@ -262,8 +259,7 @@
char
-GEOSCrosses_r(GEOSContextHandle_t extHandle, const Geometry *g1,
+GEOSCrosses_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2)
@@ -298,8 +294,7 @@
char
-GEOSWithin_r(GEOSContextHandle_t extHandle, const Geometry *g1,
+GEOSWithin_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2)
@@ -338,8 +333,7 @@
// 1 = true
// 2 = error was trapped
char
-GEOSContains_r(GEOSContextHandle_t extHandle, const Geometry *g1,
+GEOSContains_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2)
@@ -374,8 +368,7 @@
char
-GEOSOverlaps_r(GEOSContextHandle_t extHandle, const Geometry *g1,
+GEOSOverlaps_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2)
@@ -415,8 +408,7 @@
char
-GEOSRelatePattern_r(GEOSContextHandle_t extHandle, const Geometry *g1,
- const Geometry *g2, const char *pat)
+GEOSRelatePattern_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2, const char *pat)
@@ -452,8 +444,7 @@
char *
-GEOSRelate_r(GEOSContextHandle_t extHandle, const Geometry *g1,
+GEOSRelate_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2)
@@ -611,8 +602,7 @@
char
-GEOSEquals_r(GEOSContextHandle_t extHandle, const Geometry *g1,
+GEOSEquals_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2)
@@ -647,8 +637,7 @@
char
-GEOSEqualsExact_r(GEOSContextHandle_t extHandle, const Geometry *g1,
- const Geometry *g2, double tolerance)
+GEOSEqualsExact_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2, double tolerance)
@@ -683,8 +672,7 @@
int
-GEOSDistance_r(GEOSContextHandle_t extHandle, const Geometry *g1,
- const Geometry *g2, double *dist)
+GEOSDistance_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2, double *dist)
@@ -862,8 +850,7 @@
// Remember to free the result!
unsigned char *
-GEOSGeomToWKB_buf_r(GEOSContextHandle_t extHandle, const Geometry *g,
- size_t *size)
+GEOSGeomToWKB_buf_r(GEOSContextHandle_t extHandle, const Geometry *g, size_t *size)
@@ -908,8 +895,7 @@
Geometry *
-GEOSGeomFromWKB_buf_r(GEOSContextHandle_t extHandle, const unsigned char *wkb,
- size_t size)
+GEOSGeomFromWKB_buf_r(GEOSContextHandle_t extHandle, const unsigned char *wkb, size_t size)
@@ -952,8 +938,7 @@
/* Read/write wkb hex values. Returned geometries are
owned by the caller.*/
unsigned char *
-GEOSGeomToHEX_buf_r(GEOSContextHandle_t extHandle, const Geometry *g,
- size_t *size)
+GEOSGeomToHEX_buf_r(GEOSContextHandle_t extHandle, const Geometry *g, size_t *size)
@@ -998,8 +983,7 @@
Geometry *
-GEOSGeomFromHEX_buf_r(GEOSContextHandle_t extHandle, const unsigned char *hex,
- size_t size)
+GEOSGeomFromHEX_buf_r(GEOSContextHandle_t extHandle, const unsigned char *hex, size_t size)
@@ -1260,8 +1244,7 @@
Geometry *
-GEOSIntersection_r(GEOSContextHandle_t extHandle, const Geometry *g1,
+GEOSIntersection_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2)
@@ -1297,8 +1280,7 @@
Geometry *
-GEOSBuffer_r(GEOSContextHandle_t extHandle, const Geometry *g1, double width,
- int quadrantsegments)
+GEOSBuffer_r(GEOSContextHandle_t extHandle, const Geometry *g1, double width, int quadrantsegments)
@@ -1366,8 +1348,7 @@
Geometry *
-GEOSDifference_r(GEOSContextHandle_t extHandle, const Geometry *g1,
+GEOSDifference_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2)
@@ -1437,8 +1418,7 @@
Geometry *
-GEOSSymDifference_r(GEOSContextHandle_t extHandle, const Geometry *g1,
+GEOSSymDifference_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2)
@@ -1474,8 +1454,7 @@
Geometry *
-GEOSUnion_r(GEOSContextHandle_t extHandle, const Geometry *g1,
+GEOSUnion_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2)
@@ -1615,26 +1594,7 @@
g->setSRID(SRID);
-void
-GEOSdeleteChar(char *a)
- try{
- free(a);
- catch (const std::exception &e)
- handle->ERROR_MESSAGE("%s", e.what());
- catch (...)
- handle->ERROR_MESSAGE("Unknown exception thrown");
int
GEOSGetNumCoordinates_r(GEOSContextHandle_t extHandle, const Geometry *g1)
@@ -1905,6 +1865,8 @@
Geometry *
GEOSGetCentroid_r(GEOSContextHandle_t extHandle, const Geometry *g)
@@ -1946,8 +1908,7 @@
Geometry *
-GEOSGeom_createCollection_r(GEOSContextHandle_t extHandle, int type,
- Geometry **geoms, unsigned int ngeoms)
+GEOSGeom_createCollection_r(GEOSContextHandle_t extHandle, int type, Geometry **geoms, unsigned int ngeoms)
@@ -2012,8 +1973,7 @@
Geometry *
-GEOSPolygonize_r(GEOSContextHandle_t extHandle, const Geometry * const * g,
- unsigned int ngeoms)
+GEOSPolygonize_r(GEOSContextHandle_t extHandle, const Geometry * const * g, unsigned int ngeoms)
@@ -2078,8 +2038,7 @@
Geometry *
-GEOSPolygonizer_getCutEdges_r(GEOSContextHandle_t extHandle,
- const Geometry * const * g, unsigned int ngeoms)
+GEOSPolygonizer_getCutEdges_r(GEOSContextHandle_t extHandle, const Geometry * const * g, unsigned int ngeoms)
@@ -2354,8 +2313,7 @@
-GEOSCoordSeq_create_r(GEOSContextHandle_t extHandle, unsigned int size,
- unsigned int dims)
+GEOSCoordSeq_create_r(GEOSContextHandle_t extHandle, unsigned int size, unsigned int dims)
@@ -2391,8 +2349,7 @@
int
-GEOSCoordSeq_setOrdinate_r(GEOSContextHandle_t extHandle, CoordinateSequence *s,
- unsigned int idx, unsigned int dim, double val)
+GEOSCoordSeq_setOrdinate_r(GEOSContextHandle_t extHandle, CoordinateSequence *s, unsigned int idx, unsigned int dim, double val)
@@ -2426,22 +2383,19 @@
int
-GEOSCoordSeq_setX_r(GEOSContextHandle_t extHandle, CoordinateSequence *s,
- unsigned int idx, double val)
+GEOSCoordSeq_setX_r(GEOSContextHandle_t extHandle, CoordinateSequence *s, unsigned int idx, double val)
return GEOSCoordSeq_setOrdinate_r(extHandle, s, idx, 0, val);
int
-GEOSCoordSeq_setY_r(GEOSContextHandle_t extHandle, CoordinateSequence *s,
+GEOSCoordSeq_setY_r(GEOSContextHandle_t extHandle, CoordinateSequence *s, unsigned int idx, double val)
return GEOSCoordSeq_setOrdinate_r(extHandle, s, idx, 1, val);
int
-GEOSCoordSeq_setZ_r(GEOSContextHandle_t extHandle, CoordinateSequence *s,
+GEOSCoordSeq_setZ_r(GEOSContextHandle_t extHandle, CoordinateSequence *s, unsigned int idx, double val)
return GEOSCoordSeq_setOrdinate_r(extHandle, s, idx, 2, val);
@@ -2477,8 +2431,7 @@
int
-GEOSCoordSeq_getOrdinate_r(GEOSContextHandle_t extHandle, const CoordinateSequence *s,
- unsigned int idx, unsigned int dim, double *val)
+GEOSCoordSeq_getOrdinate_r(GEOSContextHandle_t extHandle, const CoordinateSequence *s, unsigned int idx, unsigned int dim, double *val)
@@ -2513,29 +2466,25 @@
int
-GEOSCoordSeq_getX_r(GEOSContextHandle_t extHandle, const CoordinateSequence *s,
- unsigned int idx, double *val)
+GEOSCoordSeq_getX_r(GEOSContextHandle_t extHandle, const CoordinateSequence *s, unsigned int idx, double *val)
return GEOSCoordSeq_getOrdinate_r(extHandle, s, idx, 0, val);
int
-GEOSCoordSeq_getY_r(GEOSContextHandle_t extHandle, const CoordinateSequence *s,
+GEOSCoordSeq_getY_r(GEOSContextHandle_t extHandle, const CoordinateSequence *s, unsigned int idx, double *val)
return GEOSCoordSeq_getOrdinate_r(extHandle, s, idx, 1, val);
int
-GEOSCoordSeq_getZ_r(GEOSContextHandle_t extHandle, const CoordinateSequence *s,
+GEOSCoordSeq_getZ_r(GEOSContextHandle_t extHandle, const CoordinateSequence *s, unsigned int idx, double *val)
return GEOSCoordSeq_getOrdinate_r(extHandle, s, idx, 2, val);
int
-GEOSCoordSeq_getSize_r(GEOSContextHandle_t extHandle,
- const CoordinateSequence *s, unsigned int *size)
+GEOSCoordSeq_getSize_r(GEOSContextHandle_t extHandle, const CoordinateSequence *s, unsigned int *size)
@@ -2569,8 +2518,7 @@
int
-GEOSCoordSeq_getDimensions_r(GEOSContextHandle_t extHandle,
- const CoordinateSequence *s, unsigned int *dims)
+GEOSCoordSeq_getDimensions_r(GEOSContextHandle_t extHandle, const CoordinateSequence *s, unsigned int *dims)
@@ -2725,8 +2673,7 @@
Geometry *
-GEOSGeom_createLinearRing_r(GEOSContextHandle_t extHandle,
- CoordinateSequence *cs)
+GEOSGeom_createLinearRing_r(GEOSContextHandle_t extHandle, CoordinateSequence *cs)
@@ -2761,8 +2708,7 @@
Geometry *
-GEOSGeom_createLineString_r(GEOSContextHandle_t extHandle,
+GEOSGeom_createLineString_r(GEOSContextHandle_t extHandle, CoordinateSequence *cs)
@@ -2797,8 +2743,7 @@
Geometry *
-GEOSGeom_createPolygon_r(GEOSContextHandle_t extHandle, Geometry *shell,
- Geometry **holes, unsigned int nholes)
+GEOSGeom_createPolygon_r(GEOSContextHandle_t extHandle, Geometry *shell, Geometry **holes, unsigned int nholes)
@@ -2936,8 +2881,7 @@
Geometry *
-GEOSSimplify_r(GEOSContextHandle_t extHandle, const Geometry *g1,
- double tolerance)
+GEOSSimplify_r(GEOSContextHandle_t extHandle, const Geometry *g1, double tolerance)
@@ -2974,8 +2918,7 @@
Geometry *
-GEOSTopologyPreserveSimplify_r(GEOSContextHandle_t extHandle,
- const Geometry *g1, double tolerance)
+GEOSTopologyPreserveSimplify_r(GEOSContextHandle_t extHandle, const Geometry *g1, double tolerance)
@@ -3091,8 +3034,7 @@
Geometry*
-GEOSWKTReader_read_r(GEOSContextHandle_t extHandle, WKTReader *reader,
- const char *wkt)
+GEOSWKTReader_read_r(GEOSContextHandle_t extHandle, WKTReader *reader, const char *wkt)
@@ -3206,8 +3148,7 @@
char*
-GEOSWKTWriter_write_r(GEOSContextHandle_t extHandle, WKTWriter *writer,
- const Geometry *geom)
+GEOSWKTWriter_write_r(GEOSContextHandle_t extHandle, WKTWriter *writer, const Geometry *geom)
@@ -3321,8 +3262,7 @@
Geometry*
-GEOSWKBReader_read_r(GEOSContextHandle_t extHandle, WKBReader *reader,
- const unsigned char *wkb, size_t size)
+GEOSWKBReader_read_r(GEOSContextHandle_t extHandle, WKBReader *reader, const unsigned char *wkb, size_t size)
@@ -3360,8 +3300,7 @@
Geometry*
-GEOSWKBReader_readHEX_r(GEOSContextHandle_t extHandle, WKBReader *reader,
- const unsigned char *hex, size_t size)
+GEOSWKBReader_readHEX_r(GEOSContextHandle_t extHandle, WKBReader *reader, const unsigned char *hex, size_t size)
@@ -3477,8 +3416,7 @@
/* The owner owns the result */
unsigned char*
-GEOSWKBWriter_write_r(GEOSContextHandle_t extHandle, WKBWriter *writer,
- const Geometry *geom, size_t *size)
+GEOSWKBWriter_write_r(GEOSContextHandle_t extHandle, WKBWriter *writer, const Geometry *geom, size_t *size)
@@ -3519,8 +3457,7 @@
unsigned char*
-GEOSWKBWriter_writeHEX_r(GEOSContextHandle_t extHandle, WKBWriter *writer,
+GEOSWKBWriter_writeHEX_r(GEOSContextHandle_t extHandle, WKBWriter *writer, const Geometry *geom, size_t *size)
@@ -3561,8 +3498,7 @@
int
-GEOSWKBWriter_getOutputDimension_r(GEOSContextHandle_t extHandle,
- const GEOSWKBWriter* writer)
+GEOSWKBWriter_getOutputDimension_r(GEOSContextHandle_t extHandle, const GEOSWKBWriter* writer)
@@ -3590,8 +3526,7 @@
void
-GEOSWKBWriter_setOutputDimension_r(GEOSContextHandle_t extHandle,
- GEOSWKBWriter* writer, int newDimension)
+GEOSWKBWriter_setOutputDimension_r(GEOSContextHandle_t extHandle, GEOSWKBWriter* writer, int newDimension)
@@ -3618,8 +3553,7 @@
int
-GEOSWKBWriter_getByteOrder_r(GEOSContextHandle_t extHandle,
+GEOSWKBWriter_getByteOrder_r(GEOSContextHandle_t extHandle, const GEOSWKBWriter* writer)
@@ -3647,8 +3581,7 @@
void
-GEOSWKBWriter_setByteOrder_r(GEOSContextHandle_t extHandle,
- GEOSWKBWriter* writer, int newByteOrder)
+GEOSWKBWriter_setByteOrder_r(GEOSContextHandle_t extHandle, GEOSWKBWriter* writer, int newByteOrder)
@@ -3675,8 +3608,7 @@
char
-GEOSWKBWriter_getIncludeSRID_r(GEOSContextHandle_t extHandle,
+GEOSWKBWriter_getIncludeSRID_r(GEOSContextHandle_t extHandle, const GEOSWKBWriter* writer)
@@ -3704,8 +3636,7 @@
void
-GEOSWKBWriter_setIncludeSRID_r(GEOSContextHandle_t extHandle,
- GEOSWKBWriter* writer, const char newIncludeSRID)
+GEOSWKBWriter_setIncludeSRID_r(GEOSContextHandle_t extHandle, GEOSWKBWriter* writer, const char newIncludeSRID)
@@ -3771,8 +3702,7 @@
void
-GEOSPreparedGeom_destroy_r(GEOSContextHandle_t extHandle,
- const geos::geom::prep::PreparedGeometry *a)
+GEOSPreparedGeom_destroy_r(GEOSContextHandle_t extHandle, const geos::geom::prep::PreparedGeometry *a)
@@ -3813,9 +3743,7 @@
char
-GEOSPreparedContains_r(GEOSContextHandle_t extHandle,
- const geos::geom::prep::PreparedGeometry *pg1,
+GEOSPreparedContains_r(GEOSContextHandle_t extHandle, const geos::geom::prep::PreparedGeometry *pg1, const Geometry *g2)
@@ -3849,9 +3777,7 @@
char
-GEOSPreparedContainsProperly_r(GEOSContextHandle_t extHandle,
+GEOSPreparedContainsProperly_r(GEOSContextHandle_t extHandle, const geos::geom::prep::PreparedGeometry *pg1, const Geometry *g2)
@@ -3885,9 +3811,7 @@
char
-GEOSPreparedCovers_r(GEOSContextHandle_t extHandle,
+GEOSPreparedCovers_r(GEOSContextHandle_t extHandle, const geos::geom::prep::PreparedGeometry *pg1, const Geometry *g2)
@@ -3921,9 +3845,7 @@
char
-GEOSPreparedIntersects_r(GEOSContextHandle_t extHandle,
+GEOSPreparedIntersects_r(GEOSContextHandle_t extHandle, const geos::geom::prep::PreparedGeometry *pg1, const Geometry *g2)
@@ -3956,4 +3878,4 @@
-} //extern "C"
+} /* extern "C" */
More information about the geos-commits
